  4. Tester wanted - Zigbee Adapter 3.1
testerzhczigbeezigbee 3.1
273 Beiträge 17 Kommentatoren 35.2k Aufrufe 16 Beobachtet
  • D dimaiv
    @asgothian
    Adapter 3.1.3 alpha 4 stürzt sofort ab.
    2025-09-24 22:25:18.298 - info: zigbee.0 (296477) 20 devices are part of the network
    2025-09-24 22:25:18.300 - info: zigbee.0 (296477) Zigbee started
    2025-09-24 22:25:18.333 - warn: zigbee.0 (296477) DeviceEvent:calling onEvent for start on 0x60a423fffe61dd4a
    2025-09-24 22:25:18.349 - warn: zigbee.0 (296477) DeviceEvent:calling onEvent for start on 0x28dba7fffe6df66f
    2025-09-24 22:25:18.355 - warn: zigbee.0 (296477) DeviceEvent:calling onEvent for start on 0x28dba7fffe6df516
    2025-09-24 22:25:18.357 - warn: zigbee.0 (296477) DeviceEvent:calling onEvent for start on 0x28dba7fffe6df594
    2025-09-24 22:25:18.359 - warn: zigbee.0 (296477) DeviceEvent:calling onEvent for start on 0x881a14fffeea1db2
    2025-09-24 22:25:18.361 - warn: zigbee.0 (296477) DeviceEvent:calling onEvent for start on 0x28dba7fffe6df5f6
    2025-09-24 22:25:18.362 - warn: zigbee.0 (296477) DeviceEvent:calling onEvent for start on 0xa4c13801838effff
    2025-09-24 22:25:18.365 - error: zigbee.0 (296477) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2025-09-24 22:25:18.365 - error: zigbee.0 (296477) unhandled promise rejection: Cannot read properties of undefined (reading 'measurement_poll_interval')
    2025-09-24 22:25:18.537 - error: zigbee.0 (296477) TypeError: Cannot read properties of undefined (reading 'measurement_poll_interval')
    at onEvent (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/lib/modernExtend.ts:678:58)
    at Object.onEvent (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/index.ts:376:27)
    at DeviceEvent.callOnEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:69:26)
    at processTicksAndRejections (node:internal/process/task_queues:95:5)
    at DeviceEvent.onZigbeeStarted (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:13:13)
    at async Promise.all (index 2)
    2025-09-24 22:25:18.538 - error: zigbee.0 (296477) Cannot read properties of undefined (reading 'measurement_poll_interval')
    2025-09-24 22:25:18.592 - info: zigbee.0 (296477) Halting zigbee adapter. Restart delay is at least 30 seconds.
    2025-09-24 22:25:18.592 - info: zigbee.0 (296477) cleaning everything up
    2025-09-24 22:25:18.596 - info: zigbee.0 (296477) Saved local configuration data
    2025-09-24 22:25:18.598 - info: zigbee.0 (296477) cleanup successful
    2025-09-24 22:25:18.599 - info: zigbee.0 (296477) terminating
    2025-09-24 22:25:18.602 - warn: zigbee.0 (296477) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2025-09-24 22:25:18.610 - info: zigbee.0 (296477) zigbecontroller stopped successfully - ZH was not running
    2025-09-24 22:25:18.797 - info: zigbee.0 (296477) debug devices set to []
    2025-09-24 22:25:19.207 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.208 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.209 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.210 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.211 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.212 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.213 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.214 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.215 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.216 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.217 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.218 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.219 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.220 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.221 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.222 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.223 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.224 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.225 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.226 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.227 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.228 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.229 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.230 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.231 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.232 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.233 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.234 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.235 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.236 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.237 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.238 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.239 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.240 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.241 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.242 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.243 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.244 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.245 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.246 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.247 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.248 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.249 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.250 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.251 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.252 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.253 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.254 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.255 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.256 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.257 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.258 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.470 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.471 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.472 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.473 - warn: zigbee.0 (296477) get state error: Connection is closed.
    2025-09-24 22:25:19.478 - error: zigbee.0 (296477) Cannot check file existence of "cfg.f.zigbee.admin$%$img/RTCGQ11LM.png$%$data": DB closed
    2025-09-24 22:25:19.478 - error: zigbee.0 (296477) Cannot check file existence of "cfg.f.zigbee.admin$%$img/WSDCGQ11LM.png$%$data": DB closed
    2025-09-24 22:25:19.479 - error: zigbee.0 (296477) Cannot check file existence of "cfg.f.zigbee.admin$%$img/ptvo.switch.png$%$data": DB closed
    2025-09-24 22:25:19.479 - error: zigbee.0 (296477) Cannot check file existence of "cfg.f.zigbee.admin$%$img/MCCGQ11LM.png$%$data": DB closed
    2025-09-24 22:25:19.499 - error: zigbee.0 (296477) Cannot check file existence of "cfg.f.zigbee.admin$%$img/MCCGQ11LM.png$%$data": Connection is closed.
    2025-09-24 22:25:19.500 - error: zigbee.0 (296477) Cannot check file existence of "cfg.f.zigbee.admin$%$img/TS0121_plug.png$%$data": Connection is closed.
    2025-09-24 22:25:19.500 - error: zigbee.0 (296477) Cannot check file existence of "cfg.f.zigbee.admin$%$img/DIYRuZ_Flower.png$%$data": Connection is closed.
    2025-09-24 22:25:19.501 - error: zigbee.0 (296477) Cannot check file existence of "cfg.f.zigbee.admin$%$img/SWV.png$%$data": Connection is closed.
    2025-09-24 22:25:19.501 - error: zigbee.0 (296477) Cannot check file existence of "cfg.f.zigbee.admin$%$img/HG08010.png$%$data": Connection is closed.
    2025-09-24 22:25:19.542 - error: zigbee.0 (296477) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2025-09-24 22:25:19.542 - error: zigbee.0 (296477) unhandled promise rejection: DB closed
    2025-09-24 22:25:19.544 - error: zigbee.0 (296477) Error: DB closed
    at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
    at Socket. (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
    at Object.onceWrapper (node:events:639:26)
    at Socket.emit (node:events:524:28)
    at Socket.emit (node:domain:489:12)
    at TCP. (node:net:343:12)
    2025-09-24 22:25:19.544 - error: zigbee.0 (296477) DB closed
    2025-09-24 22:25:19.552 - error: zigbee.0 (296477) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2025-09-24 22:25:19.553 - error: zigbee.0 (296477) unhandled promise rejection: DB closed
    2025-09-24 22:25:19.554 - error: zigbee.0 (296477) Error: DB closed
    2025-09-24 22:25:19.554 - error: zigbee.0 (296477) DB closed
    2025-09-24 22:25:19.556 - error: zigbee.0 (296477) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2025-09-24 22:25:19.557 - error: zigbee.0 (296477) unhandled promise rejection: DB closed
    2025-09-24 22:25:19.557 - error: zigbee.0 (296477) Error: DB closed
    2025-09-24 22:25:19.558 - error: zigbee.0 (296477) DB closed
    2025-09-24 22:25:19.560 - error: zigbee.0 (296477) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2025-09-24 22:25:19.561 - error: zigbee.0 (296477) unhandled promise rejection: DB closed
    2025-09-24 22:25:19.561 - error: zigbee.0 (296477) Error: DB closed
    2025-09-24 22:25:19.562 - error: zigbee.0 (296477) DB closed
    2025-09-24 22:25:19.564 - error: zigbee.0 (296477) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2025-09-24 22:25:19.564 - error: zigbee.0 (296477) unhandled promise rejection: DB closed
    2025-09-24 22:25:19.565 - error: zigbee.0 (296477) Error: DB closed
    2025-09-24 22:25:19.565 - error: zigbee.0 (296477) DB closed
    2025-09-24 22:25:19.567 - error: zigbee.0 (296477) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2025-09-24 22:25:19.568 - error: zigbee.0 (296477) unhandled promise rejection: DB closed
    2025-09-24 22:25:19.568 - error: zigbee.0 (296477) Error: DB closed
    2025-09-24 22:25:19.569 - error: zigbee.0 (296477) DB closed
    2025-09-24 22:25:19.571 - error: zigbee.0 (296477) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2025-09-24 22:25:19.572 - error: zigbee.0 (296477) unhandled promise rejection: DB closed
    2025-09-24 22:25:19.572 - error: zigbee.0 (296477) Error: DB closed
    2025-09-24 22:25:19.573 - error: zigbee.0 (296477) DB closed
    2025-09-24 22:25:19.575 - error: zigbee.0 (296477) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2025-09-24 22:25:19.576 - error: zigbee.0 (296477) unhandled promise rejection: DB closed
    2025-09-24 22:25:19.576 - error: zigbee.0 (296477) Error: DB closed
    2025-09-24 22:25:19.576 - error: zigbee.0 (296477) DB closed
    2025-09-24 22:25:19.579 - error: zigbee.0 (296477) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2025-09-24 22:25:19.580 - error: zigbee.0 (296477) unhandled promise rejection: DB closed
    2025-09-24 22:25:19.580 - error: zigbee.0 (296477) Error: DB closed
    2025-09-24 22:25:19.581 - error: zigbee.0 (296477) DB closed
    2025-09-24 22:25:19.582 - error: zigbee.0 (296477) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2025-09-24 22:25:19.583 - error: zigbee.0 (296477) unhandled promise rejection: DB closed
    2025-09-24 22:25:19.583 - error: zigbee.0 (296477) Error: DB closed
    2025-09-24 22:25:19.584 - error: zigbee.0 (296477) DB closed
    2025-09-24 22:25:19.586 - error: zigbee.0 (296477) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2025-09-24 22:25:19.586 - error: zigbee.0 (296477) unhandled promise rejection: DB closed
    2025-09-24 22:25:19.587 - error: zigbee.0 (296477) Error: DB closed
    2025-09-24 22:25:19.587 - error: zigbee.0 (296477) DB closed
    2025-09-24 22:25:19.589 - error: zigbee.0 (296477) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2025-09-24 22:25:19.590 - error: zigbee.0 (296477) unhandled promise rejection: DB closed
    2025-09-24 22:25:19.590 - error: zigbee.0 (296477) Error: DB closed
    2025-09-24 22:25:19.591 - error: zigbee.0 (296477) DB closed
    2025-09-24 22:25:19.592 - error: zigbee.0 (296477) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2025-09-24 22:25:19.593 - error: zigbee.0 (296477) unhandled promise rejection: DB closed
    2025-09-24 22:25:19.594 - error: zigbee.0 (296477) Error: DB closed
    2025-09-24 22:25:19.595 - error: zigbee.0 (296477) DB closed
    2025-09-24 22:25:19.596 - error: zigbee.0 (296477) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2025-09-24 22:25:19.596 - error: zigbee.0 (296477) unhandled promise rejection: DB closed
    2025-09-24 22:25:19.596 - error: zigbee.0 (296477) Error: DB closed
    2025-09-24 22:25:19.597 - error: zigbee.0 (296477) DB closed
    2025-09-24 22:25:19.598 - error: zigbee.0 (296477) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2025-09-24 22:25:19.599 - error: zigbee.0 (296477) unhandled promise rejection: DB closed
    2025-09-24 22:25:19.599 - error: zigbee.0 (296477) Error: DB closed
    2025-09-24 22:25:19.600 - error: zigbee.0 (296477) DB closed
    2025-09-24 22:25:19.602 - info: zigbee.0 (296477) downloading https://www.zigbee2mqtt.io/images/devices/RTCGQ11LM.png to img/RTCGQ11LM.png
    2025-09-24 22:25:19.629 - info: zigbee.0 (296477) downloading https://www.zigbee2mqtt.io/images/devices/WSDCGQ11LM.png to img/WSDCGQ11LM.png
    2025-09-24 22:25:19.639 - info: zigbee.0 (296477) downloading https://www.zigbee2mqtt.io/images/devices/ptvo.switch.png to img/ptvo.switch.png
    2025-09-24 22:25:19.647 - info: zigbee.0 (296477) downloading https://www.zigbee2mqtt.io/images/devices/MCCGQ11LM.png to img/MCCGQ11LM.png
    2025-09-24 22:25:19.878 - error: host.GartenIoB Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2025-09-24 22:25:19.879 - error: host.GartenIoB Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'measurement_poll_interval')
    2025-09-24 22:25:19.879 - error: host.GartenIoB Caught by controller[1]: at onEvent (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/lib/modernExtend.ts:678:58)
    2025-09-24 22:25:19.879 - error: host.GartenIoB Caught by controller[1]: at Object.onEvent (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/index.ts:376:27)
    2025-09-24 22:25:19.879 - error: host.GartenIoB Caught by controller[1]: at DeviceEvent.callOnEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:69:26)
    2025-09-24 22:25:19.879 - error: host.GartenIoB Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
    2025-09-24 22:25:19.879 - error: host.GartenIoB Caught by controller[1]: at DeviceEvent.onZigbeeStarted (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:13:13)
    2025-09-24 22:25:19.879 - error: host.GartenIoB Caught by controller[1]: at async Promise.all (index 2)
    2025-09-24 22:25:19.880 - error: host.GartenIoB Caught by controller[2]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2025-09-24 22:25:19.880 - error: host.GartenIoB Caught by controller[3]: Error: DB closed
    2025-09-24 22:25:19.880 - error: host.GartenIoB Caught by controller[3]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
    2025-09-24 22:25:19.880 - error: host.GartenIoB Caught by controller[3]: at Socket. (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
    2025-09-24 22:25:19.880 - error: host.GartenIoB Caught by controller[3]: at Object.onceWrapper (node:events:639:26)
    2025-09-24 22:25:19.880 - error: host.GartenIoB Caught by controller[3]: at Socket.emit (node:events:524:28)
    2025-09-24 22:25:19.880 - error: host.GartenIoB Caught by controller[3]: at Socket.emit (node:domain:489:12)
    2025-09-24 22:25:19.880 - error: host.GartenIoB Caught by controller[3]: at TCP. (node:net:343:12)
    2025-09-24 22:25:19.880 - error: host.GartenIoB Caught by controller[4]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2025-09-24 22:25:19.880 - error: host.GartenIoB Caught by controller[5]: Error: DB closed
    2025-09-24 22:25:19.881 - error: host.GartenIoB Caught by controller[5]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
    2025-09-24 22:25:19.881 - error: host.GartenIoB Caught by controller[5]: at Socket. (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
    2025-09-24 22:25:19.881 - error: host.GartenIoB Caught by controller[5]: at Object.onceWrapper (node:events:639:26)
    2025-09-24 22:25:19.881 - error: host.GartenIoB Caught by controller[5]: at Socket.emit (node:events:524:28)
    2025-09-24 22:25:19.881 - error: host.GartenIoB Caught by controller[5]: at Socket.emit (node:domain:489:12)
    2025-09-24 22:25:19.881 - error: host.GartenIoB Caught by controller[5]: at TCP. (node:net:343:12)
    2025-09-24 22:25:19.881 - error: host.GartenIoB Caught by controller[6]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2025-09-24 22:25:19.881 - error: host.GartenIoB Caught by controller[7]: Error: DB closed
    2025-09-24 22:25:19.881 - error: host.GartenIoB Caught by controller[7]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
    2025-09-24 22:25:19.881 - error: host.GartenIoB Caught by controller[7]: at Socket. (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
    2025-09-24 22:25:19.882 - error: host.GartenIoB Caught by controller[7]: at Object.onceWrapper (node:events:639:26)
    2025-09-24 22:25:19.882 - error: host.GartenIoB Caught by controller[7]: at Socket.emit (node:events:524:28)
    2025-09-24 22:25:19.882 - error: host.GartenIoB Caught by controller[7]: at Socket.emit (node:domain:489:12)
    2025-09-24 22:25:19.882 - error: host.GartenIoB Caught by controller[7]: at TCP. (node:net:343:12)
    2025-09-24 22:25:19.882 - error: host.GartenIoB Caught by controller[8]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2025-09-24 22:25:19.882 - error: host.GartenIoB Caught by controller[9]: Error: DB closed
    2025-09-24 22:25:19.882 - error: host.GartenIoB Caught by controller[9]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
    2025-09-24 22:25:19.882 - error: host.GartenIoB Caught by controller[9]: at Socket. (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
    2025-09-24 22:25:19.883 - error: host.GartenIoB Caught by controller[9]: at Object.onceWrapper (node:events:639:26)
    2025-09-24 22:25:19.883 - error: host.GartenIoB Caught by controller[9]: at Socket.emit (node:events:524:28)
    2025-09-24 22:25:19.883 - error: host.GartenIoB Caught by controller[9]: at Socket.emit (node:domain:489:12)
    2025-09-24 22:25:19.883 - error: host.GartenIoB Caught by controller[9]: at TCP. (node:net:343:12)
    2025-09-24 22:25:19.883 - error: host.GartenIoB Caught by controller[10]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2025-09-24 22:25:19.883 - error: host.GartenIoB Caught by controller[11]: Error: DB closed
    2025-09-24 22:25:19.883 - error: host.GartenIoB Caught by controller[11]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
    2025-09-24 22:25:19.883 - error: host.GartenIoB Caught by controller[11]: at Socket. (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
    2025-09-24 22:25:19.883 - error: host.GartenIoB Caught by controller[11]: at Object.onceWrapper (node:events:639:26)
    2025-09-24 22:25:19.883 - error: host.GartenIoB Caught by controller[11]: at Socket.emit (node:events:524:28)
    2025-09-24 22:25:19.884 - error: host.GartenIoB Caught by controller[11]: at Socket.emit (node:domain:489:12)
    2025-09-24 22:25:19.884 - error: host.GartenIoB Caught by controller[11]: at TCP. (node:net:343:12)
    2025-09-24 22:25:19.884 - error: host.GartenIoB Caught by controller[12]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2025-09-24 22:25:19.884 - error: host.GartenIoB Caught by controller[13]: Error: DB closed
    2025-09-24 22:25:19.884 - error: host.GartenIoB Caught by controller[13]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
    2025-09-24 22:25:19.884 - error: host.GartenIoB Caught by controller[13]: at Socket. (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
    2025-09-24 22:25:19.884 - error: host.GartenIoB Caught by controller[13]: at Object.onceWrapper (node:events:639:26)
    2025-09-24 22:25:19.884 - error: host.GartenIoB Caught by controller[13]: at Socket.emit (node:events:524:28)
    2025-09-24 22:25:19.884 - error: host.GartenIoB Caught by controller[13]: at Socket.emit (node:domain:489:12)
    2025-09-24 22:25:19.885 - error: host.GartenIoB Caught by controller[13]: at TCP. (node:net:343:12)
    2025-09-24 22:25:19.885 - error: host.GartenIoB Caught by controller[14]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2025-09-24 22:25:19.885 - error: host.GartenIoB Caught by controller[15]: Error: DB closed
    2025-09-24 22:25:19.885 - error: host.GartenIoB Caught by controller[15]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
    2025-09-24 22:25:19.885 - error: host.GartenIoB Caught by controller[15]: at Socket. (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
    2025-09-24 22:25:19.885 - error: host.GartenIoB Caught by controller[15]: at Object.onceWrapper (node:events:639:26)
    2025-09-24 22:25:19.885 - error: host.GartenIoB Caught by controller[15]: at Socket.emit (node:events:524:28)
    2025-09-24 22:25:19.885 - error: host.GartenIoB Caught by controller[15]: at Socket.emit (node:domain:489:12)
    2025-09-24 22:25:19.885 - error: host.GartenIoB Caught by controller[15]: at TCP. (node:net:343:12)
    2025-09-24 22:25:19.885 - error: host.GartenIoB Caught by controller[16]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2025-09-24 22:25:19.886 - error: host.GartenIoB Caught by controller[17]: Error: DB closed
    2025-09-24 22:25:19.886 - error: host.GartenIoB Caught by controller[17]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
    2025-09-24 22:25:19.886 - error: host.GartenIoB Caught by controller[17]: at Socket. (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
    2025-09-24 22:25:19.886 - error: host.GartenIoB Caught by controller[17]: at Object.onceWrapper (node:events:639:26)
    2025-09-24 22:25:19.886 - error: host.GartenIoB Caught by controller[17]: at Socket.emit (node:events:524:28)
    2025-09-24 22:25:19.886 - error: host.GartenIoB Caught by controller[17]: at Socket.emit (node:domain:489:12)
    2025-09-24 22:25:19.886 - error: host.GartenIoB Caught by controller[17]: at TCP. (node:net:343:12)
    2025-09-24 22:25:19.886 - error: host.GartenIoB Caught by controller[18]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2025-09-24 22:25:19.886 - error: host.GartenIoB Caught by controller[19]: Error: DB closed
    2025-09-24 22:25:19.887 - error: host.GartenIoB Caught by controller[19]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
    2025-09-24 22:25:19.887 - error: host.GartenIoB Caught by controller[19]: at Socket. (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
    2025-09-24 22:25:19.887 - error: host.GartenIoB Caught by controller[19]: at Object.onceWrapper (node:events:639:26)
    2025-09-24 22:25:19.887 - error: host.GartenIoB Caught by controller[19]: at Socket.emit (node:events:524:28)
    2025-09-24 22:25:19.887 - error: host.GartenIoB Caught by controller[19]: at Socket.emit (node:domain:489:12)
    2025-09-24 22:25:19.887 - error: host.GartenIoB Caught by controller[19]: at TCP. (node:net:343:12)
    2025-09-24 22:25:19.887 - error: host.GartenIoB Caught by controller[20]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2025-09-24 22:25:19.888 - error: host.GartenIoB Caught by controller[21]: Error: DB closed
    2025-09-24 22:25:19.888 - error: host.GartenIoB Caught by controller[21]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
    2025-09-24 22:25:19.888 - error: host.GartenIoB Caught by controller[21]: at Socket. (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
    2025-09-24 22:25:19.888 - error: host.GartenIoB Caught by controller[21]: at Object.onceWrapper (node:events:639:26)
    2025-09-24 22:25:19.888 - error: host.GartenIoB Caught by controller[21]: at Socket.emit (node:events:524:28)
    2025-09-24 22:25:19.888 - error: host.GartenIoB Caught by controller[21]: at Socket.emit (node:domain:489:12)
    2025-09-24 22:25:19.888 - error: host.GartenIoB Caught by controller[21]: at TCP. (node:net:343:12)
    2025-09-24 22:25:19.888 - error: host.GartenIoB Caught by controller[22]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2025-09-24 22:25:19.889 - error: host.GartenIoB Caught by controller[23]: Error: DB closed
    2025-09-24 22:25:19.889 - error: host.GartenIoB Caught by controller[23]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
    2025-09-24 22:25:19.889 - error: host.GartenIoB Caught by controller[23]: at Socket. (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
    2025-09-24 22:25:19.889 - error: host.GartenIoB Caught by controller[23]: at Object.onceWrapper (node:events:639:26)
    2025-09-24 22:25:19.889 - error: host.GartenIoB Caught by controller[23]: at Socket.emit (node:events:524:28)
    2025-09-24 22:25:19.889 - error: host.GartenIoB Caught by controller[23]: at Socket.emit (node:domain:489:12)
    2025-09-24 22:25:19.889 - error: host.GartenIoB Caught by controller[23]: at TCP. (node:net:343:12)
    2025-09-24 22:25:19.890 - error: host.GartenIoB Caught by controller[24]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2025-09-24 22:25:19.890 - error: host.GartenIoB Caught by controller[25]: Error: DB closed
    2025-09-24 22:25:19.890 - error: host.GartenIoB Caught by controller[25]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
    2025-09-24 22:25:19.890 - error: host.GartenIoB Caught by controller[25]: at Socket. (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
    2025-09-24 22:25:19.890 - error: host.GartenIoB Caught by controller[25]: at Object.onceWrapper (node:events:639:26)
    2025-09-24 22:25:19.890 - error: host.GartenIoB Caught by controller[25]: at Socket.emit (node:events:524:28)
    2025-09-24 22:25:19.890 - error: host.GartenIoB Caught by controller[25]: at Socket.emit (node:domain:489:12)
    2025-09-24 22:25:19.891 - error: host.GartenIoB Caught by controller[25]: at TCP. (node:net:343:12)
    2025-09-24 22:25:19.891 - error: host.GartenIoB Caught by controller[26]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2025-09-24 22:25:19.891 - error: host.GartenIoB Caught by controller[27]: Error: DB closed
    2025-09-24 22:25:19.891 - error: host.GartenIoB Caught by controller[27]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
    2025-09-24 22:25:19.891 - error: host.GartenIoB Caught by controller[27]: at Socket. (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
    2025-09-24 22:25:19.891 - error: host.GartenIoB Caught by controller[27]: at Object.onceWrapper (node:events:639:26)
    2025-09-24 22:25:19.891 - error: host.GartenIoB Caught by controller[27]: at Socket.emit (node:events:524:28)
    2025-09-24 22:25:19.891 - error: host.GartenIoB Caught by controller[27]: at Socket.emit (node:domain:489:12)
    2025-09-24 22:25:19.891 - error: host.GartenIoB Caught by controller[27]: at TCP. (node:net:343:12)
    2025-09-24 22:25:19.892 - error: host.GartenIoB Caught by controller[28]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2025-09-24 22:25:19.892 - error: host.GartenIoB Caught by controller[29]: Error: DB closed
    2025-09-24 22:25:19.892 - error: host.GartenIoB Caught by controller[29]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
    2025-09-24 22:25:19.892 - error: host.GartenIoB Caught by controller[29]: at Socket. (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
    2025-09-24 22:25:19.892 - error: host.GartenIoB Caught by controller[29]: at Object.onceWrapper (node:events:639:26)
    2025-09-24 22:25:19.892 - error: host.GartenIoB Caught by controller[29]: at Socket.emit (node:events:524:28)
    2025-09-24 22:25:19.892 - error: host.GartenIoB Caught by controller[29]: at Socket.emit (node:domain:489:12)
    2025-09-24 22:25:19.892 - error: host.GartenIoB Caught by controller[29]: at TCP. (node:net:343:12)
    2025-09-24 22:25:19.892 - error: host.GartenIoB Caught by controller[30]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2025-09-24 22:25:19.892 - error: host.GartenIoB Caught by controller[31]: Error: DB closed
    2025-09-24 22:25:19.893 - error: host.GartenIoB Caught by controller[31]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
    2025-09-24 22:25:19.893 - error: host.GartenIoB Caught by controller[31]: at Socket. (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
    2025-09-24 22:25:19.893 - error: host.GartenIoB Caught by controller[31]: at Object.onceWrapper (node:events:639:26)
    2025-09-24 22:25:19.893 - error: host.GartenIoB Caught by controller[31]: at Socket.emit (node:events:524:28)
    2025-09-24 22:25:19.893 - error: host.GartenIoB Caught by controller[31]: at Socket.emit (node:domain:489:12)
    2025-09-24 22:25:19.893 - error: host.GartenIoB Caught by controller[31]: at TCP. (node:net:343:12)
    2025-09-24 22:25:19.893 - error: host.GartenIoB Caught by controller[32]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2025-09-24 22:25:19.893 - error: host.GartenIoB Caught by controller[33]: Error: DB closed
    2025-09-24 22:25:19.894 - error: host.GartenIoB Caught by controller[33]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
    2025-09-24 22:25:19.894 - error: host.GartenIoB Caught by controller[33]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
    2025-09-24 22:25:19.894 - error: host.GartenIoB Caught by controller[33]: at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3011:37)
    2025-09-24 22:25:19.894 - error: host.GartenIoB Caught by controller[33]: at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3070:29)
    2025-09-24 22:25:19.894 - error: host.GartenIoB Caught by controller[33]: at processImmediate (node:internal/timers:485:21)
    2025-09-24 22:25:19.894 - error: host.GartenIoB Caught by controller[34]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2025-09-24 22:25:19.894 - error: host.GartenIoB Caught by controller[35]: Error: DB closed
    2025-09-24 22:25:19.894 - error: host.GartenIoB Caught by controller[35]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
    2025-09-24 22:25:19.895 - error: host.GartenIoB Caught by controller[35]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
    2025-09-24 22:25:19.895 - error: host.GartenIoB Caught by controller[35]: at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3011:37)
    2025-09-24 22:25:19.895 - error: host.GartenIoB Caught by controller[35]: at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3070:29)
    2025-09-24 22:25:19.895 - error: host.GartenIoB Caught by controller[35]: at processImmediate (node:internal/timers:485:21)
    2025-09-24 22:25:19.895 - error: host.GartenIoB Caught by controller[36]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2025-09-24 22:25:19.895 - error: host.GartenIoB Caught by controller[37]: Error: DB closed
    2025-09-24 22:25:19.895 - error: host.GartenIoB Caught by controller[37]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
    2025-09-24 22:25:19.895 - error: host.GartenIoB Caught by controller[37]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
    2025-09-24 22:25:19.896 - error: host.GartenIoB Caught by controller[37]: at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3011:37)
    2025-09-24 22:25:19.896 - error: host.GartenIoB Caught by controller[37]: at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3070:29)
    2025-09-24 22:25:19.896 - error: host.GartenIoB Caught by controller[37]: at processImmediate (node:internal/timers:485:21)
    2025-09-24 22:25:19.896 - error: host.GartenIoB Caught by controller[38]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2025-09-24 22:25:19.896 - error: host.GartenIoB Caught by controller[39]: Error: DB closed
    2025-09-24 22:25:19.896 - error: host.GartenIoB Caught by controller[39]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
    2025-09-24 22:25:19.896 - error: host.GartenIoB Caught by controller[39]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
    2025-09-24 22:25:19.896 - error: host.GartenIoB Caught by controller[39]: at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3011:37)
    2025-09-24 22:25:19.896 - error: host.GartenIoB Caught by controller[39]: at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3070:29)
    2025-09-24 22:25:19.897 - error: host.GartenIoB Caught by controller[39]: at processImmediate (node:internal/timers:485:21)
    2025-09-24 22:25:19.897 - error: host.GartenIoB Caught by controller[40]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2025-09-24 22:25:19.897 - error: host.GartenIoB Caught by controller[41]: Error: DB closed
    2025-09-24 22:25:19.897 - error: host.GartenIoB Caught by controller[41]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
    2025-09-24 22:25:19.897 - error: host.GartenIoB Caught by controller[41]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
    2025-09-24 22:25:19.897 - error: host.GartenIoB Caught by controller[41]: at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3011:37)
    2025-09-24 22:25:19.897 - error: host.GartenIoB Caught by controller[41]: at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3070:29)
    2025-09-24 22:25:19.897 - error: host.GartenIoB Caught by controller[41]: at processImmediate (node:internal/timers:485:21)
    2025-09-24 22:25:19.897 - error: host.GartenIoB Caught by controller[42]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2025-09-24 22:25:19.898 - error: host.GartenIoB Caught by controller[43]: Error: DB closed
    2025-09-24 22:25:19.898 - error: host.GartenIoB Caught by controller[43]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
    2025-09-24 22:25:19.898 - error: host.GartenIoB Caught by controller[43]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
    2025-09-24 22:25:19.898 - error: host.GartenIoB Caught by controller[43]: at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3011:37)
    2025-09-24 22:25:19.898 - error: host.GartenIoB Caught by controller[43]: at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3070:29)
    2025-09-24 22:25:19.899 - error: host.GartenIoB Caught by controller[43]: at processImmediate (node:internal/timers:485:21)
    2025-09-24 22:25:19.899 - error: host.GartenIoB Caught by controller[44]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2025-09-24 22:25:19.899 - error: host.GartenIoB Caught by controller[45]: Error: DB closed
    2025-09-24 22:25:19.899 - error: host.GartenIoB Caught by controller[45]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
    2025-09-24 22:25:19.899 - error: host.GartenIoB Caught by controller[45]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
    2025-09-24 22:25:19.899 - error: host.GartenIoB Caught by controller[45]: at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3011:37)
    2025-09-24 22:25:19.899 - error: host.GartenIoB Caught by controller[45]: at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3070:29)
    2025-09-24 22:25:19.900 - error: host.GartenIoB Caught by controller[45]: at processImmediate (node:internal/timers:485:21)
    2025-09-24 22:25:19.900 - error: host.GartenIoB Caught by controller[46]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2025-09-24 22:25:19.900 - error: host.GartenIoB Caught by controller[47]: Error: DB closed
    2025-09-24 22:25:19.900 - error: host.GartenIoB Caught by controller[47]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
    2025-09-24 22:25:19.901 - error: host.GartenIoB Caught by controller[47]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
    2025-09-24 22:25:19.901 - error: host.GartenIoB Caught by controller[47]: at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3011:37)
    2025-09-24 22:25:19.901 - error: host.GartenIoB Caught by controller[47]: at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3070:29)
    2025-09-24 22:25:19.901 - error: host.GartenIoB Caught by controller[47]: at processImmediate (node:internal/timers:485:21)
    2025-09-24 22:25:19.901 - error: host.GartenIoB Caught by controller[48]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2025-09-24 22:25:19.901 - error: host.GartenIoB Caught by controller[49]: Error: DB closed
    2025-09-24 22:25:19.902 - error: host.GartenIoB Caught by controller[49]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
    2025-09-24 22:25:19.902 - error: host.GartenIoB Caught by controller[49]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
    2025-09-24 22:25:19.902 - error: host.GartenIoB Caught by controller[49]: at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3011:37)
    2025-09-24 22:25:19.902 - error: host.GartenIoB Caught by controller[49]: at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3070:29)
    2025-09-24 22:25:19.902 - error: host.GartenIoB Caught by controller[49]: at processImmediate (node:internal/timers:485:21)
    2025-09-24 22:25:19.902 - error: host.GartenIoB Caught by controller[50]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2025-09-24 22:25:19.902 - error: host.GartenIoB Caught by controller[51]: Error: DB closed
    2025-09-24 22:25:19.903 - error: host.GartenIoB Caught by controller[51]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
    2025-09-24 22:25:19.903 - error: host.GartenIoB Caught by controller[51]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
    2025-09-24 22:25:19.903 - error: host.GartenIoB Caught by controller[51]: at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3011:37)
    2025-09-24 22:25:19.903 - error: host.GartenIoB Caught by controller[51]: at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3070:29)
    2025-09-24 22:25:19.903 - error: host.GartenIoB Caught by controller[51]: at processImmediate (node:internal/timers:485:21)
    2025-09-24 22:25:19.903 - error: host.GartenIoB Caught by controller[52]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2025-09-24 22:25:19.903 - error: host.GartenIoB Caught by controller[53]: Error: DB closed
    2025-09-24 22:25:19.903 - error: host.GartenIoB Caught by controller[53]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
    2025-09-24 22:25:19.904 - error: host.GartenIoB Caught by controller[53]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
    2025-09-24 22:25:19.904 - error: host.GartenIoB Caught by controller[53]: at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3011:37)
    2025-09-24 22:25:19.904 - error: host.GartenIoB Caught by controller[53]: at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3070:29)
    2025-09-24 22:25:19.904 - error: host.GartenIoB Caught by controller[53]: at processImmediate (node:internal/timers:485:21)
    2025-09-24 22:25:19.904 - error: host.GartenIoB Caught by controller[54]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2025-09-24 22:25:19.904 - error: host.GartenIoB Caught by controller[55]: Error: DB closed
    2025-09-24 22:25:19.904 - error: host.GartenIoB Caught by controller[55]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
    2025-09-24 22:25:19.904 - error: host.GartenIoB Caught by controller[55]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
    2025-09-24 22:25:19.905 - error: host.GartenIoB Caught by controller[55]: at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3011:37)
    2025-09-24 22:25:19.905 - error: host.GartenIoB Caught by controller[55]: at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3070:29)
    2025-09-24 22:25:19.905 - error: host.GartenIoB Caught by controller[55]: at processImmediate (node:internal/timers:485:21)
    2025-09-24 22:25:19.905 - error: host.GartenIoB Caught by controller[56]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2025-09-24 22:25:19.905 - error: host.GartenIoB Caught by controller[57]: Error: DB closed
    2025-09-24 22:25:19.905 - error: host.GartenIoB Caught by controller[57]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
    2025-09-24 22:25:19.905 - error: host.GartenIoB Caught by controller[57]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
    2025-09-24 22:25:19.905 - error: host.GartenIoB Caught by controller[57]: at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3011:37)
    2025-09-24 22:25:19.906 - error: host.GartenIoB Caught by controller[57]: at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3070:29)
    2025-09-24 22:25:19.906 - error: host.GartenIoB Caught by controller[57]: at processImmediate (node:internal/timers:485:21)
    2025-09-24 22:25:19.906 - error: host.GartenIoB Caught by controller[58]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2025-09-24 22:25:19.906 - error: host.GartenIoB Caught by controller[59]: Error: DB closed
    2025-09-24 22:25:19.906 - error: host.GartenIoB Caught by controller[59]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
    2025-09-24 22:25:19.906 - error: host.GartenIoB Caught by controller[59]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
    2025-09-24 22:25:19.906 - error: host.GartenIoB Caught by controller[59]: at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3011:37)
    2025-09-24 22:25:19.906 - error: host.GartenIoB Caught by controller[59]: at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3070:29)
    2025-09-24 22:25:19.907 - error: host.GartenIoB Caught by controller[59]: at processImmediate (node:internal/timers:485:21)
    2025-09-24 22:25:19.907 - error: host.GartenIoB Caught by controller[60]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2025-09-24 22:25:19.907 - error: host.GartenIoB Caught by controller[61]: Error: DB closed
    2025-09-24 22:25:19.907 - error: host.GartenIoB Caught by controller[61]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
    2025-09-24 22:25:19.907 - error: host.GartenIoB Caught by controller[61]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
    2025-09-24 22:25:19.907 - error: host.GartenIoB Caught by controller[61]: at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3011:37)
    2025-09-24 22:25:19.907 - error: host.GartenIoB Caught by controller[61]: at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3070:29)
    2025-09-24 22:25:19.907 - error: host.GartenIoB Caught by controller[61]: at processImmediate (node:internal/timers:485:21)
    2025-09-24 22:25:19.908 - error: host.GartenIoB Caught by controller[62]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2025-09-24 22:25:19.908 - error: host.GartenIoB Caught by controller[63]: Error: DB closed
    2025-09-24 22:25:19.908 - error: host.GartenIoB Caught by controller[63]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
    2025-09-24 22:25:19.908 - error: host.GartenIoB Caught by controller[63]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
    2025-09-24 22:25:19.908 - error: host.GartenIoB Caught by controller[63]: at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3011:37)
    2025-09-24 22:25:19.908 - error: host.GartenIoB Caught by controller[63]: at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3070:29)
    2025-09-24 22:25:19.908 - error: host.GartenIoB Caught by controller[63]: at processImmediate (node:internal/timers:485:21)
    2025-09-24 22:25:19.908 - error: host.GartenIoB Caught by controller[64]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2025-09-24 22:25:19.909 - error: host.GartenIoB Caught by controller[65]: Error: DB closed
    2025-09-24 22:25:19.909 - error: host.GartenIoB Caught by controller[65]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
    2025-09-24 22:25:19.909 - error: host.GartenIoB Caught by controller[65]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
    2025-09-24 22:25:19.909 - error: host.GartenIoB Caught by controller[65]: at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3011:37)
    2025-09-24 22:25:19.909 - error: host.GartenIoB Caught by controller[65]: at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3070:29)
    2025-09-24 22:25:19.909 - error: host.GartenIoB Caught by controller[65]: at processImmediate (node:internal/timers:485:21)
    2025-09-24 22:25:19.909 - error: host.GartenIoB Caught by controller[66]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2025-09-24 22:25:19.910 - error: host.GartenIoB Caught by controller[67]: Error: DB closed
    2025-09-24 22:25:19.910 - error: host.GartenIoB Caught by controller[67]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
    2025-09-24 22:25:19.910 - error: host.GartenIoB Caught by controller[67]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
    2025-09-24 22:25:19.910 - error: host.GartenIoB Caught by controller[67]: at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3011:37)
    2025-09-24 22:25:19.910 - error: host.GartenIoB Caught by controller[67]: at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3070:29)
    2025-09-24 22:25:19.910 - error: host.GartenIoB Caught by controller[67]: at processImmediate (node:internal/timers:485:21)
    2025-09-24 22:25:19.910 - error: host.GartenIoB instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2025-09-24 22:25:19.911 - info: host.GartenIoB Restart adapter system.adapter.zigbee.0 because enabled
    2025-09-24 22:25:19.911 - warn: host.GartenIoB Do not restart adapter system.adapter.zigbee.0 because restart loop detected
    2025-09-24 22:25:25.285 - info: host.GartenIoB "system.adapter.zigbee.0" disabled
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    #162
    @dimaiv Log bitte. Bei mir läuft der (sowohl auf dem Testsystem als auch auf dem Produktivsystem)
    • AsgothianA Asgothian
      dimaiv
      #163
      @asgothian
      Oben eingefügt.
      ioBroker- NUC8i3 / Proxmox / VM
      Node.js v22.21.0
      NPM v10.9.4
      JS controller 7.1.0
      Admin 7.7.20
      ZigBee Adapter 3.3.1alpha.0
      Zigbee LAN Gateway CC2652P
      Zigbee Firmware 20250321
      • D dimaiv
        @asgothian
        Oben eingefügt.
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        #164
        @dimaiv Patch mal bitte bei Dir die Datei
        /opt/iobroker/node-modules/iobroker.zigbee/lib/zbDeviceEvevnt.js
        von
                if (mappedDevice && mappedDevice.onEvent && eventData.data) {
                    this.warn(`calling onEvent for ${eventData.type} on ${device.ieeeAddr}`);
                    mappedDevice.onEvent({type, data});
        module.exports = DeviceEvent;
        zu
                    try {
                    catch (error)
                        this.warn(`error in onEvent: ${error && error.message ? error.message : 'no details'}`);
        Der eigentliche Fehler kommt aus dem Konverter.
        A.
          von
          zu
                      try {
                      catch (error)
          A.
          dimaiv
          #165
          @asgothian
          Gleiche Fehler
          2025-09-24 23:03:33.936 - info: zigbee.0 (298385) 20 devices are part of the network
          2025-09-24 23:03:33.938 - info: zigbee.0 (298385) Zigbee started
          2025-09-24 23:03:33.971 - warn: zigbee.0 (298385) DeviceEvent:calling onEvent for start on 0x60a423fffe61dd4a
          2025-09-24 23:03:33.986 - warn: zigbee.0 (298385) DeviceEvent:calling onEvent for start on 0x28dba7fffe6df66f
          2025-09-24 23:03:33.993 - warn: zigbee.0 (298385) DeviceEvent:calling onEvent for start on 0x28dba7fffe6df516
          2025-09-24 23:03:33.995 - warn: zigbee.0 (298385) DeviceEvent:calling onEvent for start on 0x28dba7fffe6df594
          2025-09-24 23:03:33.996 - warn: zigbee.0 (298385) DeviceEvent:calling onEvent for start on 0x881a14fffeea1db2
          2025-09-24 23:03:33.999 - warn: zigbee.0 (298385) DeviceEvent:calling onEvent for start on 0x28dba7fffe6df5f6
          2025-09-24 23:03:34.000 - warn: zigbee.0 (298385) DeviceEvent:calling onEvent for start on 0xa4c13801838effff
          2025-09-24 23:03:34.022 - error: zigbee.0 (298385) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2025-09-24 23:03:34.022 - error: zigbee.0 (298385) unhandled promise rejection: Cannot read properties of undefined (reading 'measurement_poll_interval')
          2025-09-24 23:03:34.169 - error: zigbee.0 (298385) TypeError: Cannot read properties of undefined (reading 'measurement_poll_interval')
          at DeviceEvent.callOnEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:71:30)
          2025-09-24 23:03:34.169 - error: zigbee.0 (298385) Cannot read properties of undefined (reading 'measurement_poll_interval')
          2025-09-24 23:03:34.285 - info: zigbee.0 (298385) Halting zigbee adapter. Restart delay is at least 30 seconds.
          2025-09-24 23:03:34.286 - info: zigbee.0 (298385) cleaning everything up
          2025-09-24 23:03:34.290 - info: zigbee.0 (298385) Saved local configuration data
          2025-09-24 23:03:34.292 - info: zigbee.0 (298385) cleanup successful
          2025-09-24 23:03:34.293 - info: zigbee.0 (298385) terminating
          2025-09-24 23:03:34.296 - warn: zigbee.0 (298385) Terminated (UNCAUGHT_EXCEPTION): Without reason
          2025-09-24 23:03:34.304 - info: zigbee.0 (298385) zigbecontroller stopped successfully - ZH was not running
          2025-09-24 23:03:34.439 - info: zigbee.0 (298385) debug devices set to []
          2025-09-24 23:03:34.885 - warn: zigbee.0 (298385) get state error: DB closed
          2025-09-24 23:03:34.886 - warn: zigbee.0 (298385) get state error: DB closed
          Node.js v22.21.0
          NPM v10.9.4
          JS controller 7.1.0
          Admin 7.7.20
          • D dimaiv
            @asgothian
            Gleiche Fehler
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            #166
            @dimaiv Seltsam - der try/catch sollte das eigentlich fangen.
            Das kann ich ohne Gerät effektiv nicht Debuggen.
            A.
            Nachtrag: Eine mögliche Quelle hab ich noch. Bitte den folgenden Aufruf auch noch patchen:
                        try {
            zu
                        try {
                            mappedDevice.onEvent(eventData);
              A.
                          try {
              zu
                          try {
              dimaiv
              #167
              @asgothian
              Aber welchen genau...
              So komme ich such nicht zum deaktivieren...
              Hätte ich eins nach dem anderen probiert...
              Node.js v22.21.0
              NPM v10.9.4
              JS controller 7.1.0
              Admin 7.7.20
              • D dimaiv
                @asgothian
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                #168
                @dimaiv sagte in Tester wanted - Zigbee Adapter 3.1:
                @asgothian
                Deaktivieren zieht an der Stelle ggf. noch nicht. Ansonsten, der der den Absturz erzeugt ist dieser:
                0xa4c13801838effff
                Erstmal geht es darum die Abstürze loszuwerden - der Fehler darf bleiben, der Adapter muss weiter laufen
                A.
                D 2 Antworten Letzte Antwort
                  @asgothian
                  0xa4c13801838effff
                  A.
                  dimaiv
                  schrieb am zuletzt editiert von dimaiv
                  #169
                  @asgothian
                  Jetzt startet gar nicht
                  2025-09-24 23:22:06.365 - info: host.GartenIoB iobroker Updating objects from io-package.json for adapter "zigbee" with version "3.1.3-alpha-4"
                  2025-09-24 23:22:07.449 - info: host.GartenIoB iobroker exit 0
                  2025-09-24 23:22:22.257 - info: host.GartenIoB "system.adapter.zigbee.0" enabled
                  2025-09-24 23:22:23.077 - info: host.GartenIoB instance system.adapter.zigbee.0 in version "3.1.3-alpha-4" (non-npm: ioBroker/ioBroker.zigbee) started with pid 305740
                  2025-09-24 23:22:24.723 - error: host.GartenIoB Caught by controller[0]: /opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:80
                  2025-09-24 23:22:24.724 - error: host.GartenIoB Caught by controller[0]: SyntaxError: Unexpected end of input
                  2025-09-24 23:22:24.724 - error: host.GartenIoB Caught by controller[0]: at wrapSafe (node:internal/modules/cjs/loader:1472:18)
                  2025-09-24 23:22:24.724 - error: host.GartenIoB Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1501:20)
                  2025-09-24 23:22:24.724 - error: host.GartenIoB Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1613:10)
                  2025-09-24 23:22:24.724 - error: host.GartenIoB Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1275:32)
                  2025-09-24 23:22:24.724 - error: host.GartenIoB Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1096:12)
                  2025-09-24 23:22:24.724 - error: host.GartenIoB Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1298:19)
                  2025-09-24 23:22:24.725 - error: host.GartenIoB Caught by controller[0]: at require (node:internal/modules/helpers:182:18)
                  2025-09-24 23:22:24.725 - error: host.GartenIoB Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:12:24)
                  2025-09-24 23:22:24.725 - error: host.GartenIoB Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1529:14)
                  2025-09-24 23:22:24.725 - error: host.GartenIoB Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1613:10)
                  2025-09-24 23:22:24.725 - error: host.GartenIoB Caught by controller[0]: Node.js v20.19.4
                  2025-09-24 23:22:24.725 - error: host.GartenIoB instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  2025-09-24 23:22:24.726 - info: host.GartenIoB Restart adapter system.adapter.zigbee.0 because enabled
                  2025-09-24 23:22:29.156 - info: host.GartenIoB "system.adapter.zigbee.0" disabled
                  es ist Version frisch vom Git
                  Node.js v22.21.0
                  NPM v10.9.4
                  JS controller 7.1.0
                  Admin 7.7.20
                    @asgothian
                    0xa4c13801838effff
                    A.
                    dimaiv
                    #170
                    @asgothian sagte in Tester wanted - Zigbee Adapter 3.1:
                    @asgothian
                    0xa4c13801838effff
                    A.
                    Es ist ein Temperatur Sensor: (https://www.zigbee2mqtt.io/devices/SNZB-02LD.html)
                    Node.js v22.21.0
                    NPM v10.9.4
                    JS controller 7.1.0
                    Admin 7.7.20
                    • D dimaiv
                      @asgothian
                      0xa4c13801838effff
                      A.
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      #171
                      @asgothian
                      0xa4c13801838effff
                      A.
                      Dumme Tippfehler, jetzt sollte die git Version wieder gehen.
                      Was genau für ein Sensor ?
                        @asgothian
                        0xa4c13801838effff
                        A.
                        dimaiv
                        #172
                        @asgothian
                        Immer noch
                        2025-09-24 23:36:41.771 - info: zigbee.0 (310968) 20 devices are part of the network
                        2025-09-24 23:36:41.774 - info: zigbee.0 (310968) Zigbee started
                        2025-09-24 23:36:41.809 - warn: zigbee.0 (310968) DeviceEvent:calling onEvent for start on 0x60a423fffe61dd4a
                        2025-09-24 23:36:41.825 - warn: zigbee.0 (310968) DeviceEvent:calling onEvent for start on 0x28dba7fffe6df66f
                        2025-09-24 23:36:41.832 - warn: zigbee.0 (310968) DeviceEvent:calling onEvent for start on 0x28dba7fffe6df516
                        2025-09-24 23:36:41.834 - warn: zigbee.0 (310968) DeviceEvent:calling onEvent for start on 0x28dba7fffe6df594
                        2025-09-24 23:36:41.835 - warn: zigbee.0 (310968) DeviceEvent:calling onEvent for start on 0x881a14fffeea1db2
                        2025-09-24 23:36:41.838 - warn: zigbee.0 (310968) DeviceEvent:calling onEvent for start on 0x28dba7fffe6df5f6
                        2025-09-24 23:36:41.839 - warn: zigbee.0 (310968) DeviceEvent:calling onEvent for start on 0xa4c13801838effff
                        2025-09-24 23:36:41.841 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:41.842 - error: zigbee.0 (310968) unhandled promise rejection: Cannot read properties of undefined (reading 'measurement_poll_interval')
                        2025-09-24 23:36:42.010 - error: zigbee.0 (310968) TypeError: Cannot read properties of undefined (reading 'measurement_poll_interval')
                        at DeviceEvent.callOnEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:70:30)
                        2025-09-24 23:36:42.011 - error: zigbee.0 (310968) Cannot read properties of undefined (reading 'measurement_poll_interval')
                        2025-09-24 23:36:42.069 - info: zigbee.0 (310968) Halting zigbee adapter. Restart delay is at least 30 seconds.
                        2025-09-24 23:36:42.070 - info: zigbee.0 (310968) cleaning everything up
                        2025-09-24 23:36:42.073 - info: zigbee.0 (310968) Saved local configuration data
                        2025-09-24 23:36:42.076 - info: zigbee.0 (310968) cleanup successful
                        2025-09-24 23:36:42.077 - info: zigbee.0 (310968) terminating
                        2025-09-24 23:36:42.081 - warn: zigbee.0 (310968) Terminated (UNCAUGHT_EXCEPTION): Without reason
                        2025-09-24 23:36:42.089 - info: zigbee.0 (310968) zigbecontroller stopped successfully - ZH was not running
                        2025-09-24 23:36:42.509 - info: zigbee.0 (310968) debug devices set to []
                        2025-09-24 23:36:42.684 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.685 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.686 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.687 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.688 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.689 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.690 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.691 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.693 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.694 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.695 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.696 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.697 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.698 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.699 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.700 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.701 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.702 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.703 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.704 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.705 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.706 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.707 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.708 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.709 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.710 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.711 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.712 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.713 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.714 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.715 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.716 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.717 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.718 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.719 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.720 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.721 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.722 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.723 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.724 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.725 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.726 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.727 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.728 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.729 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.730 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.731 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.732 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.733 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.734 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.735 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.736 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.737 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.738 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.739 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.797 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.798 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.799 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.800 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.801 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.802 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.803 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.804 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.805 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.806 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.807 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.808 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.809 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.810 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.811 - info: zigbee.0 (310968) downloading https://www.zigbee2mqtt.io/images/devices/RTCGQ11LM.png to img/RTCGQ11LM.png
                        2025-09-24 23:36:42.838 - info: zigbee.0 (310968) downloading https://www.zigbee2mqtt.io/images/devices/WSDCGQ11LM.png to img/WSDCGQ11LM.png
                        2025-09-24 23:36:42.984 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/ptvo.switch.png$%$data": DB closed
                        2025-09-24 23:36:42.985 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/MCCGQ11LM.png$%$data": DB closed
                        2025-09-24 23:36:42.985 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/TS0121_plug.png$%$data": DB closed
                        2025-09-24 23:36:42.986 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/DIYRuZ_Flower.png$%$data": DB closed
                        2025-09-24 23:36:42.986 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/SWV.png$%$data": DB closed
                        2025-09-24 23:36:42.994 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/HG08010.png$%$data": Connection is closed.
                        2025-09-24 23:36:42.995 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/WXCJKG13LM.png$%$data": Connection is closed.
                        2025-09-24 23:36:42.995 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/Egony_Flower.png$%$data": Connection is closed.
                        2025-09-24 23:36:42.996 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/WSDCGQ11LM.png$%$data": Connection is closed.
                        2025-09-24 23:36:42.996 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/SWV.png$%$data": Connection is closed.
                        2025-09-24 23:36:42.997 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/SWV.png$%$data": Connection is closed.
                        2025-09-24 23:36:42.998 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/TS0601_din.png$%$data": Connection is closed.
                        2025-09-24 23:36:42.999 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/SWV.png$%$data": Connection is closed.
                        2025-09-24 23:36:42.999 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/Egony_Flower.png$%$data": Connection is closed.
                        2025-09-24 23:36:43.000 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/SWV.png$%$data": Connection is closed.
                        2025-09-24 23:36:43.000 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/SNZB-02LD.png$%$data": Connection is closed.
                        2025-09-24 23:36:43.001 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/RB-SRAIN01.png$%$data": Connection is closed.
                        2025-09-24 23:36:43.039 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:43.040 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                        2025-09-24 23:36:43.042 - error: zigbee.0 (310968) Error: DB closed
                        2025-09-24 23:36:43.042 - error: zigbee.0 (310968) DB closed
                        2025-09-24 23:36:43.050 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:43.051 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                        2025-09-24 23:36:43.052 - error: zigbee.0 (310968) Error: DB closed
                        2025-09-24 23:36:43.052 - error: zigbee.0 (310968) DB closed
                        2025-09-24 23:36:43.054 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:43.054 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                        2025-09-24 23:36:43.055 - error: zigbee.0 (310968) Error: DB closed
                        2025-09-24 23:36:43.055 - error: zigbee.0 (310968) DB closed
                        2025-09-24 23:36:43.058 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:43.059 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                        2025-09-24 23:36:43.059 - error: zigbee.0 (310968) Error: DB closed
                        2025-09-24 23:36:43.059 - error: zigbee.0 (310968) DB closed
                        2025-09-24 23:36:43.061 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:43.061 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                        2025-09-24 23:36:43.062 - error: zigbee.0 (310968) Error: DB closed
                        2025-09-24 23:36:43.062 - error: zigbee.0 (310968) DB closed
                        2025-09-24 23:36:43.064 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:43.065 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                        2025-09-24 23:36:43.065 - error: zigbee.0 (310968) Error: DB closed
                        2025-09-24 23:36:43.065 - error: zigbee.0 (310968) DB closed
                        2025-09-24 23:36:43.067 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:43.068 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                        2025-09-24 23:36:43.068 - error: zigbee.0 (310968) Error: DB closed
                        2025-09-24 23:36:43.069 - error: zigbee.0 (310968) DB closed
                        2025-09-24 23:36:43.070 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:43.071 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                        2025-09-24 23:36:43.071 - error: zigbee.0 (310968) Error: DB closed
                        2025-09-24 23:36:43.072 - error: zigbee.0 (310968) DB closed
                        2025-09-24 23:36:43.074 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:43.075 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                        2025-09-24 23:36:43.075 - error: zigbee.0 (310968) Error: DB closed
                        2025-09-24 23:36:43.076 - error: zigbee.0 (310968) DB closed
                        2025-09-24 23:36:43.077 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:43.078 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                        2025-09-24 23:36:43.078 - error: zigbee.0 (310968) Error: DB closed
                        2025-09-24 23:36:43.079 - error: zigbee.0 (310968) DB closed
                        2025-09-24 23:36:43.081 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:43.082 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                        2025-09-24 23:36:43.082 - error: zigbee.0 (310968) Error: DB closed
                        2025-09-24 23:36:43.082 - error: zigbee.0 (310968) DB closed
                        2025-09-24 23:36:43.084 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:43.084 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                        2025-09-24 23:36:43.085 - error: zigbee.0 (310968) Error: DB closed
                        2025-09-24 23:36:43.085 - error: zigbee.0 (310968) DB closed
                        2025-09-24 23:36:43.087 - info: zigbee.0 (310968) downloading https://www.zigbee2mqtt.io/images/devices/ptvo.switch.png to img/ptvo.switch.png
                        2025-09-24 23:36:43.095 - info: zigbee.0 (310968) downloading https://www.zigbee2mqtt.io/images/devices/MCCGQ11LM.png to img/MCCGQ11LM.png
                        2025-09-24 23:36:43.101 - info: zigbee.0 (310968) downloading https://www.zigbee2mqtt.io/images/devices/TS0121_plug.png to img/TS0121_plug.png
                        2025-09-24 23:36:43.107 - info: zigbee.0 (310968) downloading https://www.zigbee2mqtt.io/images/devices/DIYRuZ_Flower.png to img/DIYRuZ_Flower.png
                        2025-09-24 23:36:43.113 - info: zigbee.0 (310968) downloading https://www.zigbee2mqtt.io/images/devices/SWV.png to img/SWV.png
                        2025-09-24 23:36:43.129 - info: zigbee.0 (310968) downloading https://www.zigbee2mqtt.io/images/devices/HG08010.png to img/HG08010.png
                        2025-09-24 23:36:43.137 - info: zigbee.0 (310968) downloading https://www.zigbee2mqtt.io/images/devices/WXCJKG13LM.png to img/WXCJKG13LM.png
                        2025-09-24 23:36:43.146 - info: zigbee.0 (310968) downloading https://www.zigbee2mqtt.io/images/devices/Egony_Flower.png to img/Egony_Flower.png
                        2025-09-24 23:36:43.153 - info: zigbee.0 (310968) downloading https://www.zigbee2mqtt.io/images/devices/TS0601_din.png to img/TS0601_din.png
                        2025-09-24 23:36:43.160 - info: zigbee.0 (310968) downloading https://www.zigbee2mqtt.io/images/devices/SNZB-02LD.png to img/SNZB-02LD.png
                        2025-09-24 23:36:43.166 - info: zigbee.0 (310968) downloading https://www.zigbee2mqtt.io/images/devices/RB-SRAIN01.png to img/RB-SRAIN01.png
                        2025-09-24 23:36:43.172 - warn: zigbee.0 (310968) Could not perform strict object check of state zigbee.0.00124b001ec80d25.link_quality: DB closed
                        2025-09-24 23:36:43.172 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:43.173 - warn: zigbee.0 (310968) Could not perform strict object check of state zigbee.0.00124b001ec80d25.msg_from_zigbee: DB closed
                        2025-09-24 23:36:43.174 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:43.174 - warn: zigbee.0 (310968) Could not perform strict object check of state zigbee.0.00124b001ec80d25.state_l1: DB closed
                        2025-09-24 23:36:43.175 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:43.175 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:43.176 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                        2025-09-24 23:36:43.177 - error: zigbee.0 (310968) Error: DB closed
                        2025-09-24 23:36:43.178 - error: zigbee.0 (310968) DB closed
                        2025-09-24 23:36:43.183 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:43.184 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                        2025-09-24 23:36:43.185 - error: zigbee.0 (310968) Error: DB closed
                        2025-09-24 23:36:43.186 - error: zigbee.0 (310968) DB closed
                        2025-09-24 23:36:43.191 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:43.191 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                        2025-09-24 23:36:43.193 - error: zigbee.0 (310968) Error: DB closed
                        2025-09-24 23:36:43.194 - error: zigbee.0 (310968) DB closed
                        2025-09-24 23:36:43.198 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:43.198 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                        2025-09-24 23:36:43.199 - error: zigbee.0 (310968) Error: DB closed
                        2025-09-24 23:36:43.200 - error: zigbee.0 (310968) DB closed
                        2025-09-24 23:36:43.203 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:43.204 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                        2025-09-24 23:36:43.205 - error: zigbee.0 (310968) Error: DB closed
                        2025-09-24 23:36:43.205 - error: zigbee.0 (310968) DB closed
                        2025-09-24 23:36:43.208 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:43.209 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                        2025-09-24 23:36:43.210 - error: zigbee.0 (310968) Error: DB closed
                        2025-09-24 23:36:43.211 - error: zigbee.0 (310968) DB closed
                        2025-09-24 23:36:43.214 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:43.214 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                        2025-09-24 23:36:43.215 - error: zigbee.0 (310968) Error: DB closed
                        2025-09-24 23:36:43.216 - error: zigbee.0 (310968) DB closed
                        2025-09-24 23:36:43.220 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:43.220 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                        2025-09-24 23:36:43.221 - error: zigbee.0 (310968) Error: DB closed
                        ich muss Log kürzen, sonnst meckert Forum.
                        Node.js v22.21.0
                        NPM v10.9.4
                        JS controller 7.1.0
                        Admin 7.7.20
                          @asgothian
                          0xa4c13801838effff
                          A.
                          dimaiv
                          #173
                          es ist verlinkt da.
                          Node.js v22.21.0
                          NPM v10.9.4
                          JS controller 7.1.0
                          Admin 7.7.20
                          • AsgothianA Offline
                            AsgothianA Offline
                            Asgothian
                            #174
                            @dimaiv ok, der kann es nicht sein, der hat kein on Event.
                            Dann sollte es der auf den folgende in der Liste der Geräte sein. Die müsste vorher im log stehen.
                            A.
                            P.s. damit ist für heute erst einmal Schluss. Morgen kann ich weiter machen. Zum Thema log kürzen, alles was nach DB closed oder connection closed kommt ist irrelevant.
                            A.
                              A.
                              A.
                              dimaiv
                              #175
                              @asgothian
                              0x60a423fffe61dd4a - Steckdose: (https://www.zigbee2mqtt.io/devices/TS0121_plug.html)
                              0x28dba7fffe6df66f - SWV: (https://www.zigbee2mqtt.io/devices/SWV.html)
                              0x28dba7fffe6df516 - SWV: (https://www.zigbee2mqtt.io/devices/SWV.html)
                              0x28dba7fffe6df594 - SWV: (https://www.zigbee2mqtt.io/devices/SWV.html)
                              0x881a14fffeea1db2 - SWV: (https://www.zigbee2mqtt.io/devices/SWV.html)
                              0x28dba7fffe6df5f6 - SWV: (https://www.zigbee2mqtt.io/devices/SWV.html)
                              0xa4c13801838effff - Temp Sensor: (https://www.zigbee2mqtt.io/devices/SNZB-02LD.html)
                              Node.js v22.21.0
                              NPM v10.9.4
                              JS controller 7.1.0
                              Admin 7.7.20
                                Auf Github ist die version 3.1.0 des Zigbee Adapters vorhanden. Dafür benötige ich freiwillige zum Testen. Da es eine massive Anpassung war gibt es durchaus ein Risiko von Abstürzen. Allerdings sind die Änderungen gegenüber 3.0.5 gering, so das ein zurückspielen der 3.0.5 immer gehen wird.
                                Installation via Github vom ioBroker repository.
                                Folgendes ist neu:
                                Synchronisation für Gruppen / Mitglieder
                                • Änderung eines Gruppen States (ack = false) => der Adapter versucht den Status der Mitglieder zu lesen. (Wichtig: Nur der in der Gruppe angepasste state wird gelesen - wichtig bei Gruppen von Leuchten, wenn via brightness eingeschaltet wird. (Hier kann es ggf. noch Timing-Probleme geben)
                                • Änderung eines Mitglieder States (ack = false) => der Adapter bewertet den Status aller Mitglieder und setzt den Gruppenstatus entsprechend (mit ack=true) Ansteuerung über den State stateupdate. Gültige Werte sind: 'off' - keine Synchronisation (default), 'mat' - match -> der Gruppenstatus ändert sich wenn alle Mitglieder den gleichen Status haben. 'avg' der Gruppenstatus wird auf den durchschnittlichen Status aller Mitglieder gesetzt, wobei bei true/false intern true=1, false=0 gerechnet wird, und beim setzen gilt true = avg>4.9999999, 'min' - Der Gruppenstatus entspricht dem 'geringsten' Mitgliederstatus. 'max' - Der Gruppenstatus entspricht dem 'höchsten' Mitgliederstatus
                                • Optional: automatisch ein device_query wenn ein Gerät sich neu am Netz meldet (und als 'pingable' gilt - Konfigurierbar über die Einstellungen)
                                • Optional: automatisch beim Start für alle 'pingable' Geräte ein Device-query absetzen (incl. Timeout in sekunden, min 0.5 sekunden, max 10 sekunden, default 1 Sekunde. - konfigurierbar über die Einstellungen / an/aus, timeout)
                                Improved device_query - Device_query liest jetzt mehr Werte, und wirft weniger Fehler
                                ZH 5.0.3
                                Admin: Wird das Pairing vom Tab aus gestartet, so kann es angehalten oder verlängert werden.
                                Admin: Die Funktionen 'firmware update', 'touchlink reset', 'pairing with code', 'gruppe erzeugen' sind nur noch im Zigbee-Tab zugänglich
                                Admin: Die Karte des Koordinators wird immer dargestellt wenn der Adapter gestartet wurde - auch wenn das Zigbee-Subsystem nicht läuft (mit begrenzter Info)
                                Admin: Die Koordinator-Karte zeigt die ZH/ZHC und Adapter version
                                ToDo:
                                • (Prio 2) optimierung bei den nicht unterstützten Gruppenstates
                                • (Prio 4) Umgang mit den 'color' states bei memberupdate und stateupdate
                                • 'no converter for' Meldungen beim anpassen von memberuptate und stateupdate Fixed 11.9.
                                • (Prio 3) Deaktivierte Geräte die in Gruppen sind werden aktuell nicht vom Leseversuch der States ausgenommen
                                • Lesen der States asynchron gestalten, sowie mit einer einstellbaren Verzögerung ausstatten Asynchron: done 11.9. Einstellbare Verzögerung - unnötig
                                • Bindings: Bindings aus dem Zigbee-Herdsman holen und damit synchronisieren
                                • (Prio 7) Umstieg zu Z2M: Export für Gruppen und Bindings, damit diese vor einem Umstieg nicht zwangsweise gelöscht werden müssen
                                • (Prio 1) Timing-Auffälligkeiten bei der Konfiguration von neuen Geräten.
                                • (Prio 6) Recall Map data Option
                                • (Prio 7) save map Data as png option
                                Über rege Mithilfe würde ich mich freuen.
                                Version 3.1.3: Es gibt weitere Neuigkeiten:
                                • Deaktivierte Geräte sind jetzt in den Objekten erkennbar:
                                Im Tab:
                                Im Objektbaum:
                                Debug Interface verbesserungen:
                                • Mehr Meldungen im Log
                                • Links um sich die Log Meldungen zu bestimmten events gezielt anschauen zu können (die blauen Icons links)
                                • Anzeige so das sie direkt kopiert und mit code tags und allem im Forum gepostet werden können
                                Da rauskopiert, hier einkopiert sieht das dann so aus:
                                I01: Zigbee Event of Type readResponse from device 0x00be44fffeab0b87, incoming event: {"type":"readResponse","data":{},"linkquality":163,"groupID":0,"cluster":"seMetering","meta":{"rawData":{"type":"Buffer","data":[8,14,1,1,0,134]},"zclTransactionSequenceNumber":14,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
                                I02: 1 converter available for 'E2206' '00be44fffeab0b87' with cluster 'seMetering' and type 'readResponse'
                                I03: message received '{"linkquality":163}' from device 00be44fffeab0b87 type 'E2206'
                                I04: value generated '163' from device 00be44fffeab0b87 for 'Link quality'
                                I02.1a: data: {} options: {} meta:{"deviceIEEE":"0x00be44fffeab0b87","logger":"StatesController","state":{"state":""}} result:{}
                                I02.1b: converter 1 : Cluster seMetering => payload : {}
                                I03-1: message received '{}' from device 00be44fffeab0b87 type 'E2206'
                                NOVAL: No value published for device 00be44fffeab0b87
                                A.
                                @Homoran - machst du den 3.0 Tester thread bitte zu ?
                                Nachtrag: Es gibt inzwischen eine 3.1.1, die die ZHC 25 integriert. Alle die die 3.1 installiert haben bitte ich auf die 3.1.1 zu aktualisieren. ! Es gibt inzwischen eine 3.1.2 - auch die nutzt ZHC25 und ZH 6, besitzt aber auch einen Fix für den Pairing bug.
                                P Online
                                P Online
                                pk68
                                #176
                                ich habe mal eine allgemeine Frage zur Konfig des Adapters.
                                Bin gerade dabei den Koordinator zu ersetzen und alles neu zu machen. Nach Neuinstallation des Adapters wurde Kanal 15 eingestellt. Neben "Channel" ist ein grüner Haken. Laut Channels Energy Scan müsste man eigentlich Kanal 20 nutzen. Wenn ich den einstelle, ist anstelle des grünen Hakens ein rotes Kreuz. Was bedeutet das?
                                Der Adapter wird nach einem Neustart wieder grün. Konnte auch unter Kanal 20 einen IKEA Schalter neu anlernen.
                                Was sollte ich als Kanal einstellen, bevor ich alles neu anlerne?
                                D AsgothianA 2 Antworten Letzte Antwort
                                • P pk68
                                  dimaiv
                                  #177
                                  @pk68
                                  Auf welchem Kanal läuft dein WLAN und meisten von Nachbarn?
                                  Node.js v22.21.0
                                  NPM v10.9.4
                                  JS controller 7.1.0
                                  Admin 7.7.20
                                  P 1 Antwort Letzte Antwort
                                  • D dimaiv
                                    @pk68
                                    P Online
                                    P Online
                                    pk68
                                    #178
                                    @pk68
                                    Bei meiner Fritzbox wird der Kanal automatisch gewählt. Kann also morgen wieder anders sein. Aktuell sieht es so aus:
                                    WLAN Kanal 3 am Stärksten belegt. Also gleich neben Zigbee-Kanal 15. Der wäre aktuelle eher ungünstig.
                                    Weißt Du, was der grünen Haken bzw. rotes Kreuz zu bedeuten hat?
                                    • P pk68
                                      AsgothianA Offline
                                      AsgothianA Offline
                                      Asgothian
                                      #179
                                      @pk68 sagte in Tester wanted - Zigbee Adapter 3.1:
                                      Ein rotes X bedeutet das der gewählte Kanal nicht dem entpricht der in der nvbackup.json eingestellt ist.
                                      Ein Gelbes Rufzeichen bedeutet das die Einstellung zum nvbackup.json passt, aber ein Wert ist der nicht empfohlen wird.
                                      Ein grünes Zeichen bedeutet das der Wert ok ist und mit dem nvbackup übereinstimmt.
                                      Keines der Zeichen gibt eine klare Aussage darüber ob das Zigbee-Subsystem starten wird oder nicht.
                                      A.
                                        A.
                                        P Online
                                        P Online
                                        pk68
                                        #180
                                        @asgothian
                                        Danke für die Infos. Ganz schlau werde ich daraus nicht. Wenn man einen anderen Kanal wählt, muss man dann auch die nvbackup.json bearbeiten oder wird die dann irgendwann automatisch aktualisiert?
                                        • P pk68
                                          @asgothian
                                          AsgothianA Offline
                                          AsgothianA Offline
                                          Asgothian
                                          #181
                                          @asgothian
                                          wenn der Adapter das Netzwerk erfolgreich aufbaut, und du dann das Netzwerk wieder anhälst wird die nvbackup.json neu geschrieben - mit den neuen Parametern.
                                          A.
