  3. Off Topic
  4. Microcontroller
  5. [] ESP32-Cam ESP32-D0WD-V3 (revision v3.1) - AI o t Edge
Geplant Angeheftet Gesperrt Verschoben Microcontroller
39 Beiträge 6 Kommentatoren 4.4k Aufrufe 5 Beobachtet
  • D
    D
    dojodojo
    schrieb am zuletzt editiert von dojodojo
    ESP32-Cam ESP32-D0WD-V3 (revision v3.1) - AI on the Edge
    Alter Thread: https://forum.iobroker.net/topic/36622/wasserzähler-version-2-all-in-device/2592?lang=de
    Problem: Der wifi Hotspot wird nicht erstellt.
    https://wiki.ubuntuusers.de/venv/
    esptool
     Usage: esptool [OPTIONS] COMMAND [ARGS]...
     esptool v5.1.0 - serial utility for flashing, provisioning, and interacting with Espressif SoCs.
    ╭─ Options ───────────────────────────────────────────────────────────────────────────────────────────────╮
    │ --chip              -c  [auto|esp8266|esp32|esp32s2|esp32s3|es  Target chip type.                       │
    │                         p32c3|esp32c2|esp32c6|esp32c61|esp32c5                                          │
    │                         |esp32h2|esp32h21|esp32p4|esp32h4]                                              │
    │ --port              -p  PATH                                    Serial port device.                     │
    │ --baud              -b  INTEGER                                 Serial port baud rate used when         │
    │        flashing/reading.                       │
    │ --port-filter           [TEXT]                                  Serial port device filter, can be       │
    │        vid=NUMBER, pid=NUMBER, name=SUBSTRING, │
    │        serial=SUBSTRING.                       │
    │ --before                [default-reset|usb-reset|no-reset|no-r  Which reset to perform before           │
    │                         eset-no-sync]                           connecting to the chip.                 │
    │ --after             -a  [hard-reset|soft-reset|no-reset|no-res  Which reset to perform after operation  │
    │                         et-stub|watchdog-reset]                 is finished.                            │
    │ --no-stub                                                       Disable launching the flasher stub,     │
    │        only talk to ROM bootloader. Some       │
    │        features will not be available.         │
    │ --trace             -t                                          Enable trace-level output of esptool    │
    │        interactions.                           │
    │ --verbose           -v                                          Print all output, disable collapsing    │
    │        output stages.                          │
    │ --silent            -s                                          Silence all output except for errors.   │
    │ --override-vddsdio      [1.8V|1.9V|OFF]                         Override ESP32 VDDSDIO internal voltage │
    │        regulator (use with care).              │
    │ --connect-attempts      INTEGER                                 Number of attempts to connect, negative │
    │        or 0 for infinite. Default: 7.          │
    │ --help              -h                                          Show this message and exit.             │
    ╭─ Basic commands ────────────────────────────────────────────────────────────────────────────────────────╮
    │ write-flash                Write a binary blob to flash. The address is followed by binary filename,    │
    │                            separated by space.                                                          │
    │ read-flash                 Read SPI flash memory content.                                               │
    │ erase-flash                Erase the SPI flash memory.                                                  │
    │ erase-region               Erase a region of the SPI flash memory.                                      │
    │ read-mac                   Print the device MAC address.                                                │
    │ flash-id                   Print the SPI flash memory manufacturer and device ID.                       │
    │ elf2image                  Create an application image from ELF file                                    │
    │ image-info                 Print information about a firmware image (bootloader or application).        │
    │ merge-bin                  Merge multiple raw binary files into a single flashable file.                │
    │ version                    Print esptool version.                                                       │
    ╭─ Advanced commands ─────────────────────────────────────────────────────────────────────────────────────╮
    │ verify-flash               Verify a binary blob against the flash memory content.                       │
    │ load-ram                   Download an image to RAM and execute.                                        │
    │ dump-mem                   Dump arbitrary memory to a file.                                             │
    │ read-mem                   Read arbitrary memory location.                                              │
    │ write-mem                  Modify or write to arbitrary memory location.                                │
    │ read-flash-status          Read SPI flash memory status register.                                       │
    │ write-flash-status         Write SPI flash memory status register.                                      │
    │ read-flash-sfdp            Read SPI flash SFDP (Serial Flash Discoverable Parameters).                  │
    │ get-security-info          Print security information report.                                           │
    │ chip-id                    Print the device chip ID.                                                    │
    │ run                        Run application code loaded in flash.                                        │
    Hallo Forum,
    wie kann einen DIYmore ESP32-Cam mit ai on the edge jomjol flashen?
    https://www.amazon.de/dp/B0D9BSRYF9?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
    diymore 2 Stücke für ESP32 USB C für ESP32 CAM Entwicklungsplatine, WLAN/Bluetooth, DC 5V Dual-Core-Entwicklungsplatine mit 2640 Kamera Modul
    Besuche den diymore-Store
    https://jomjol.github.io/AI-on-the-edge-device/
    Sollte das ohne Probleme funktionieren?
    Mit Tasmota kann ich den diymore ESP32-Cam ohne Probleme flashen.
    LG
    dojodojo
    MartinPM Samson71S 2 Antworten Letzte Antwort
    • D dojodojo
      esptool
      │        interactions.                           │
      │        output stages.                          │
      Hallo Forum,
      LG
      dojodojo
      MartinPM
      MartinPM
      MartinP
      @dojodojo Ich habe auch solche Kameramodule.
      Geflasht habe ich die mit Tasmota.
      Ich kann mir nicht vorstellen, dass der ESP32 performant genug für AI Bilderkennung ist.
      Für Auswertung habe ich einen Docker Container mit Frigate und einem Google Coral KI Modul.
      Die Kamera liefert bei der Auflösung von 800×600 Pixeln nur 10 Bilder pro Sekunde
      • MartinPM MartinP
        @martinp sagte in ESP32-Cam ESP32-D0WD-V3 (revision v3.1) - AI on the Edge:
        dann hast du wahrscheinlich das ganze Projekt von @jomjol noch nicht beobachtet
        • D dojodojo
          esptool
          │        interactions.                           │
          │        output stages.                          │
          Hallo Forum,
          LG
          dojodojo
          Samson71S
          Samson71S
          Samson71
          @dojodojo sagte in ESP32-Cam ESP32-D0WD-V3 (revision v3.1) - AI on the Edge:
          Hier Lesen und nach der Anleitung vorgehen.
          https://github.com/jomjol/AI-on-the-edge-device
          Da muss ich @Homoran beipflichten und empfehle mal den GitHub Link zu studieren.
          Markus
          Bitte beachten:
          • Samson71S Samson71
            D
            D
            dojodojo
            @samson71 Die Anleitung habe ich gelesen, den ersten meiner zwei ESP32-Cam konnte ich mit AI on the Edge ohne Probem flashen.
            Wie versetze ich den ESP-32 bewußt in den Schreibmodus?
            Macht Sinn die Esptools zu verwenden?
            Woher bekomme dann den firmware.bin File?
            https://jomjol.github.io/AI-on-the-edge-device-docs/Installation/
            1.2.2.3 Flashing using the Python based esptool (Console)
            esptool erase_flash
            esptool write_flash 0x01000 bootloader.bin 0x08000 partitions.bin 0x10000 firmware.bin
            gefunden:
            1.2.2.1 Files
            Grab the firmware from the
            Releases page (Stable, tested versions), or the
            AI-on-the-edge-device__manual-setup__v16.0.0.zip
            esptool -p /dev/ttyUSB0 write_flash 0x01000 bootloader.bin 0x08000 partitions.bin 0x10000 firmware.bin
            Warning: Deprecated: Command 'write_flash' is deprecated. Use 'write-flash' instead.
            esptool v5.1.0
            Connected to ESP32 on /dev/ttyUSB0:
            Chip type:          ESP32-D0WD-V3 (revision v3.1)
            Features:           Wi-Fi, BT, Dual Core + LP Core, 240MHz, Vref calibration in eFuse, Coding Scheme None
            Crystal frequency:  40MHz
            MAC:                xxxxxxxxxxxxxxxxx
            Stub flasher running.
            Configuring flash size...
            Flash will be erased from 0x00001000 to 0x00006fff...
            Flash will be erased from 0x00008000 to 0x00008fff...
            Flash will be erased from 0x00010000 to 0x00182fff...
            Wrote 21456 bytes (13813 compressed) at 0x00001000 in 1.4 seconds (125.3 kbit/s).
            Hash of data verified.
            Wrote 3072 bytes (128 compressed) at 0x00008000 in 0.0 seconds (776.0 kbit/s).
            Wrote 1515744 bytes (990692 compressed) at 0x00010000 in 89.0 seconds (136.3 kbit/s).
            Hard resetting via RTS pin...
            Leider kein Erfolg, jetzt ein neuer Versuch:
              MartinPM
              MartinPM
              MartinP
              @homoran da bin ich dem Projekttitel bzw der Entwicklung der KI Bilderkennung auf den Leim gegangen. Die AI Firmware ist ja doch etwas anderes, als das, was da Google mit den Coral Chips veranstaltet.
              Für Personenerkennung in freier Umgebung sind die ESP32 aktuell noch zu schmalbrüstig. Aber, wenn man sieht, mit welcher Vehemenz sich die Chinesen auf das Thema KI stürzen, ist das wohl nur eine Frage der Zeit.
              • MartinPM MartinP
                D
                D
                dojodojo
                Test mit andereem Releasestand:
                AI-on-the-edge-device__manual-setup__v15.7.0.zip
                dojo@pc:~$ source env/bin/activate
                (env) dojo@pc:~$ cd /media/dojo/store/AI-on-the-edge-device__manual-setup__v15.7.0/
                (env) dojo@pc:/media/dojo/store/AI-on-the-edge-device__manual-setup__v15.7.0$ esptool -p /dev/ttyUSB0 erase-flash
                esptool v5.1.0
                Flash memory erased successfully in 4.1 seconds.
                (env) dojo@pc:/media/dojo/store/AI-on-the-edge-device__manual-setup__v15.7.0$ esptool --port /dev/ttyUSB0 write-flash 0x01000 bootloader.bin 0x08000 partitions.bin 0x10000 firmware.bin
                esptool v5.1.0
                Flash will be erased from 0x00010000 to 0x0017efff...
                Wrote 21376 bytes (14127 compressed) at 0x00001000 in 1.4 seconds (122.3 kbit/s).
                Wrote 3072 bytes (128 compressed) at 0x00008000 in 0.0 seconds (858.9 kbit/s).
                Wrote 1500320 bytes (968156 compressed) at 0x00010000 in 87.8 seconds (136.8 kbit/s).
                Der Test verlief leider erfolglos.
                Gestern konnte ich AI-on-the-Edge einmal erfolgreich installieren,
                heute kann ich es nicht mehr. :-(
                So wie das sehe, ist es ein wifi Problem mit AI-on-the-edge-device__manual-setup__v16.0.0.zip bzw. dem Webinstaller,
                der auch v16.0.0 installiert. (mit Tasmota Version 15.0.1 (release-tasmota32) funktioniert wifi)
                Auch mit AI-on-the-edge-device__manual-setup__v14.0.3.zip kann ich das Problem nicht lösen.
                Wie finde ich passende Hardware, welchen Lieferanten sollte ich wählen?
                Nach der Liste hatte ich ausgesucht:
                https://github.com/jomjol/AI-on-the-edge-device/discussions/1732
                Noch besser, ist natürlich, wie löse ich das Problem?
                • D dojodojo
                  esptool v5.1.0
                  esptool v5.1.0
                  D
                  D
                  dojodojo
                  https://www.az-delivery.de/products/esp32-cam-modul-esp32-wifi-bluetooth-modul-inklusive-kamera?variant=32376084168800
                  Spezifikationen:
                  Das DIP-16-Paket enthält das ESP32 Cam-Modul, eine 2dBi PCB-Antenne und ein 20mm-Flachkabel mit einer 2MP OV2640-Kamera.
                  Unterstützt die Betriebsmodi STA/AP/STA+AP
                  Unterstützt microSD TF-Karte mit einer maximalen Größe von 4 GB
                  Datenblatt: https://cdn.shopify.com/s/files/1/1509/1638/files/ESP32-Cam_datasheet.pdf?v=1689236064
                  Ob das Modul trotzdem mit microSD 8 GB funktioniert?
                  Welche ESP32-Cam funktioniert mit AI-on-the-Edge wirklich?
                  • D dojodojo
                    Spezifikationen:
                    Samson71S
                    Samson71S
                    Samson71
                    Erwartest Du darauf ernsthaft eine (belastbare) Antwort? Soweit reicht die Glaskugel leider nicht. Das wirst Du wohl ausprobieren müssen. Was nützt Dir ein "ich vermute es wird funktionieren", wenn es das dann am Ende evtl. doch nicht tut?
                    Die Frage ist genauso (nicht) zu beantworten. Selbst wenn sich jemand vor 1-x Jahren bei Ali und Co oder anderweitig mit Cam-Modulen eingedeckt hat die funktionieren, kann Dir niemand sagen ob eine heute dort bestellte Cam 1 zu 1 identisch ist bzw. (sofern Link/Shop überhaupt noch existieren) der Zulieferer/Hersteller exakt derselbe ist wie damals. Deck Dich ggf. mit 2-3 Modulen verschiedener Hersteller/Lieferanten ein und probiere es aus.
                    Für echte Fehler ist wohl auch eher in Issue auf GitHub der bessere Weg als hier Selbstgespräche zu führen, aber in den meisten Fällen wird vermutlich das "Nicht Funktionieren" eher am Anwender als an der Hardware liegen ;)
                    Markus
                    Bitte beachten:
                      D
                      D
                      dojodojo
                      @samson71
                      Bei GitHub https://github.com/jomjol/AI-on-the-edge-device/issues habe ich bisher keinen Account.
                      Mir wäre damit geholfen, so in der Art:
                      Produkt vor einigen Tage gekauft und funktioniert mit AI-on-the-Edge.
                      Ganz schön kompliziert die passende Hardware zu finden.
                      HomoranH Samson71S 2 Antworten Letzte Antwort
                      • D dojodojo
                        @samson71
                        die Chance dass ein solcher User zeitnah diesen Thread liest und dir rechtzeitig antwortet, halte ich für gegen 0.
                        Soweit ich mich erinnere gab es in dem Thread von jomjol vor ein paar Jahren bereits den Hinweis auf inkompatible Kameras.
                        https://forum.iobroker.net/post/617369
                        Möglicherweise sogar innerhalb einer Lieferung, mit ganz geringen Unterschieden
                        dann ändere das
                        • D dojodojo
                          @samson71
                          Samson71S
                          Samson71S
                          Samson71
                          Dann wird es Zeit das zu ändern.
                          Sollte die wirklich kommen, dann solltest Du Dir bei dem Glück überlegen mit dem Lotto spielen anzufangen 😬
                          Markus
                          Bitte beachten:
                            D
                            D
                            dojodojo
                            Genau meine Erfahrung, obwohl ich die gar nicht habe. :-)
                            • D dojodojo
                              du hast keine Erfahrung?
                              hast du dir die Kameras genau angesehen?
                                D
                                D
                                dojodojo
                                Die sind mit einer 4 Stck. Bestellung gekommen:
                                Die linke ESP32-Cam 1x und die rechte ESP32-Cam 3x.
                                Die linke Linse sieht auch irgendwie sonderbar aus, gar nicht wie auf dem Angebotsbild.
                                Der Chipsatz sieht farblich auch anders aus.
                                Heißt der Chipsatz immer ESP32s?
                                • HomoranH
                                  @dojodojo und da erwartest du, dass du wirklich das selbe bekommst was henand anderes Wochen vorher bestellt und bekommen hat?
                                  aber zusätzlich
                                  @samson71 sagte in ESP32-Cam ESP32-D0WD-V3 (revision v3.1) - AI on the Edge:
                                  wenn du schon fragst
                                  und
                                  sieht das doch eher nach einem Handlingproblem aus.
                                  Wie flashst du eigentlich?
                                  ich habe von dir kaum harte Informationen gefunden!
                                  weder screenshots noch Fotos, oder Fehlermeldung u.ä.
                                    aber zusätzlich
                                    und
                                    D
                                    D
                                    dojodojo
                                    Anfänglichst habe ich wie empfohlen mit https://jomjol.github.io/AI-on-the-edge-device/ geflasht.
                                    Dann mit dem espressif - esptool
                                    wie folgt:
                                    esptool v5.1.0
                                    esptool v5.1.0
                                    Flash-Hardware - USB-C Anschluss - am PC USB-3 oder USB-2
                                    Wann sind die ESP32-CAM-MB Taster IO0 (links) und RST (rechts) zu verwenden?
                                    Anleitung: https://makesmart.net/blog/read/esp32-cam-programmieren-die-einrichtung-als-livestream-server
                                    Fehlt die Brücke zwischen IO0 und GND, so kann kein Programm hochgeladen werden.
                                    Die linke IO0 Taste habe ich teilweise beim USB Connecten gedrückt gehalten. (Bei Tasmota jedoch nicht erforderlich)
                                    Das will ich nicht ausschließen.
                                    Bei Tasmota funktioniert der Webflasher ohne Probleme, die ESP-Cam erstellt einen wifi Zugang.
                                    Wo kann mein Fehler liegen?
                                    HomoranH teletapiT 2 Antworten Letzte Antwort
                                    • D dojodojo
                                      wie folgt:
                                      esptool v5.1.0
                                      esptool v5.1.0
                                      die Doku sieht jetzt ganz anders aus als damals. ich würde fast sagen die fehlt sogar
                                      Damals sah das so aus
                                      das stand damals alles in der Doku.
                                      weiss ich nach 4 1/2 Jahren auch nicht mehr.
                                      müsstest du dir im Thread zusammensuchen
                                      hier war es das aber!
                                      • D dojodojo
                                        wie folgt:
                                        esptool v5.1.0
                                        esptool v5.1.0
                                        teletapiT
                                        teletapiT
                                        teletapi
                                        @dojodojo Ich hab am 1.07 diesen Jahres diese beiden bestellt und laufen beide super
                                        https://www.amazon.de/dp/B0F2F3N9LT?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
                                        • teletapiT teletapi
                                          D
                                          D
                                          dojodojo
                                          Evtl. ein Problem der Spannungsversorgung: https://raydiy.de/stromversorgung-von-arduino-und-esp32-microcontroller-mit-pc-netzteil-betreiben/
                                          @teletapi
                                          Danke, wie kann ich, kann einen Unterschied in der Verkaufsbeschreibung in Bezug auf die ESP32-cam Technik feststellen?
                                          Sind deine gelieferten ESP32-Cam völlig identisch?
                                          Hast Du Originalbilder von deiner Lieferung, sieht dein Chipsatz genauso aus wie meine(r)?
                                          VERGLEICHSANGEBOTE:
                                          dojodojo - bestellt am 20. Sept. 2025, gleicher Händler
                                          Es sind hier nur 4 MB externes PSRAM angegeben.
                                          teletapi - bestellt 01.07 2025
                                          Hat dein Chip ESP-32S wirklich 32MB Speicher, wie angegeben?
                                          Mir kommt es so vor, als wenn die Händler die Produktbeschreibungen auswürfeln.
                                          Die Produktauswahl ist so nicht möglich.
                                          https://www.espressif.com/en/products/socs/esp32
                                          Datenblatt https://www.espressif.com/sites/default/files/documentation/esp32_datasheet_en.pdf
                                          esptool https://docs.espressif.com/projects/esptool/en/latest/esp32/esptool/flashing-firmware.html
                                          Entering the Bootloader https://docs.espressif.com/projects/esptool/en/latest/esp32/esptool/entering-bootloader.html
                                          Wird der Impuls vom RST-Buton ESP32-CAM MB zur ESP32-Cam durchgereicht?
                                          INFO AZ Delivery, man weiß nie was man bekommt:
                                          IIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIII
                                          vielen Dank für Ihre Anfrage.
                                          Wir beziehen unsere Produkte von verschiedenen Lieferanten und es kann immer wieder mal zu minimalen Abweichungen kommen.
                                          Es ist in nächster Zeit nicht geplant, dieses Produkt aus dem Sortiment zu nehmen.
                                          (Zusatzinfo: Ab 500 Stück Abnahmemenge kann unsere B2B-Abteilung für Sie jederzeit bei den Lieferanten anfragen und Ihnen ein individuelles Angebot unterbreiten.)
                                          Für alles Weitere stehen wir Ihnen selbstverständlich jederzeit zur Verfügung.
                                          Wir freuen uns von Ihnen zu hören.
                                          Mit freundlichen Grüßen,
                                          xxxxxx
                                          AZ-Delivery Kundenservice-Team
                                          teletapiT HomoranH 2 Antworten Letzte Antwort
                                          83.8k
