  4. Adresse aus GPS Koordinaten ermitteln ?
87 Beiträge 12 Kommentatoren 12.0k Aufrufe 10 Beobachtet
  • M Micha 3
    Geht trotzdem nicht.
    Beim ersten
    	2025-09-13 19:19:24.405	warn	script.js.common.GPS: request package is deprecated - please use httpGet (or a stable lib like axios) instead!
    Wenn wir schon dabei sind, beim Warmwasser sogar die Meldung.
    	2025-09-13 19:16:21.923	error	script.js.Zentrale.Warmwassersteuerung: httpGet(url=http://192.168.178.136/cm?cmnd=counter1%200, error=timeout of 1500ms exceeded)
    das blockly-skript
      <variables>
        <variable type="timeout" id="timeout">timeout</variable>
        <variable id="t{9+flX*7=dsZdJ6pUDs">Position</variable>
        <variable id="InM51wH+hhRZ1K}Uo6R:">result</variable>
      </variables>
      <block type="http_get" id="m-)iMJC?nyP-2Z{jK*{S" x="338" y="502">
        <field name="TIMEOUT">2000</field>
        <field name="UNIT">ms</field>
        <field name="TYPE">arraybuffer</field>
        <value name="URL">
          <shadow type="text" id="mtY5?0cuLz,.0t!EWqIB">
            <field name="TEXT">http://</field>
          </shadow>
          <block type="text_join" id="%AIgcwHNe/@sw*U01y$j">
            <value name="ADD0">
              <block type="text" id="w`-_6V`Q}otb@4S:2plf">
                <field name="TEXT">https://dataservice.accuweather.com/locations/v1/cities/geoposition/search?apikey=xxxxxxxxxxxxx=</field>
              </block>
            </value>
            <value name="ADD1">
              <block type="get_value" id="SKOaXNue28T!,3USSm[}">
                <field name="OID">0_userdata.0.GPS.accuweather_GPS</field>
              </block>
            </value>
          </block>
        </value>
        <statement name="STATEMENT">
          <block type="variables_set" id="B.8O%)EDl50Pxp@#{+%.">
            <field name="VAR" id="t{9+flX*7=dsZdJ6pUDs">Position</field>
            <value name="VALUE">
              <block type="text_getSubstring" id="owiE8!SuQ*Q%@^B#G8=2">
                <mutation at1="true" at2="true"></mutation>
                <field name="WHERE1">FROM_START</field>
                <field name="WHERE2">FROM_START</field>
                <value name="STRING">
                  <block type="variables_get" id="e4z]G)3d#LQfW2QN0ZM!">
                    <field name="VAR" id="InM51wH+hhRZ1K}Uo6R:">result</field>
                  </block>
                </value>
                <value name="AT1">
                  <block type="math_number" id="/`f+By;MjuAQu~YW(O(4">
                    <field name="NUM">21</field>
                  </block>
                </value>
                <value name="AT2">
                  <block type="math_number" id="6!?5#)73q+T{zE_B].7O">
                    <field name="NUM">27</field>
                  </block>
                </value>
              </block>
            </value>
            <next>
              <block type="update" id="{b$:l~qpE|8N{)e*U6~I">
                <field name="OID">0_userdata.0.GPS.accuweather_Position</field>
                  <block type="convert_tonumber" id="QWY0%hWvBuBR#=3oK=L*">
                      <block type="variables_get" id="AMy:l(Q?52+HV;3@1K@N">
                      </block>
                    </value>
                  </block>
                </value>
              </block>
            </next>
          </block>
        </statement>
      </block>
      <block type="on" id="Oa.K#_8v*gk[2_8:{/hf" x="338" y="738">
        <field name="OID">hm-rpc.2.00021BE99E2EFA.3.STATE</field>
        <field name="CONDITION">false</field>
          <block type="timeouts_settimeout" id="OVb_d2mk9).9s77}ZxLm">
            <field name="DELAY">2000</field>
              <block type="http_get" id="n$[MBQ:|r$H4L_Fm0-9u">
                <field name="TIMEOUT">1500</field>
                <value name="URL">
                  <shadow type="text" id="jy.JTwBxm9C)KyeVI`--">
                    <field name="TEXT">http://192.168.178.136/cm?cmnd=counter1%200</field>
                  </shadow>
                </value>
              </block>
            </statement>
          </block>
        </statement>
      </block>
    </xml>
    @micha-3 bitte das Blockly zeigen!
    @micha-3 sagte in Adresse aus GPS Koordinaten ermitteln ?:
    und
    TYPE">arraybuffer
    sieht für mich nicht korrekt aus
      Micha 3
      schrieb am zuletzt editiert von Micha 3
      Geht mit "text" aber auch nicht.
      EDIT/ Jetzt hab ich den Fehler. Aber wie beheb ich das? ich kann kein JS, das ist alles nur zusammen kopiert.
      var request =require('request');
      let result;
      const options = {
          url: 'https://nominatim.openstreetmap.org/reverse.php?format=json&lat=' + lat + '&lon=' + lon + '&zoom=18',
          method: 'GET',
          headers: {
              'Accept': 'application/json',
              'Accept-Charset': 'utf-8',
              'User-Agent': 'iobroker script'
      request(options, function(err,response,body){
          result = JSON.parse(body);
      await wait(1000);
      return result;
      • bahnuhrB Online
        bahnuhrB Online
        bahnuhr
        Hab das ganze mal schnell mit "httpget" umgesetzt, anbei:
            var lat = "51.4";
            var lon = "9.5";
        httpGet('https://nominatim.openstreetmap.org/reverse.php?format=json&lat=' + lat + '&lon=' + lon + '&zoom=18', { timeout: 1000 }, (error, response) => {
            if (!error) {
                //console.log(response.statusCode);
                //console.log(response.data);
                var result = JSON.parse(response.data);
                //log (result.display_name);
                log (result.address.road + " " + result.address.house_number);
                log (result.address.postcode + " " + result.address.municipality);
            } else {
                console.error(error);
        Danke.
        • R Offline
          Razer2412
          vielen Dank für die schnellen Rückmeldungen.
          @Homoran Ich habe das Script von @David-G verwendet.
          @bahnuhr und @Codierknecht
          natürlich habe ich versucht das ganze mithilfe der Suche und anderen Hilfsmitteln (ChatGPT) selbst zu lösen. Leider ohne Erfolg.
          Mein bisheriges Script:
          var lat, lon, result, hausnummer, strasse, plz, ort, ort2, kreis, bundesland, land, stadt, stadtteil;
          // Beschreibe diese Funktion …
          async function OSM(lat, lon) {
              let result;
              const options = {
                 method: 'GET',
                 headers: {
              await wait(1000);
              return result;
          schedule("* * * * *", async () => {
            lat = getState('vw-connect.0.xyz.parkingposition.lat').val;
            lon = getState('vw-connect.0.xyz.parkingposition.lon').val;
            result = await OSM(lat, lon);
            hausnummer = '';
            strasse = '';
            plz = '';
            ort = '';
            ort2 = '';
            kreis = '';
            bundesland = '';
            land = '';
            hausnummer = getAttr(result, 'address.house_number');
            strasse = getAttr(result, 'address.road');
            plz = getAttr(result, 'address.postcode');
            stadt = getAttr(result, 'address.town');
            stadtteil = getAttr(result, 'address.village');
            kreis = getAttr(result, 'address.county');
            bundesland = getAttr(result, 'address.state');
            land = getAttr(result, 'address.country');
            setState('0_userdata.0.Helfer.Position_Auto' /* Position Auto */, ([strasse ? strasse : null,hausnummer ? [' ',hausnummer,''].join('') : null,strasse ? ', ' : null,plz ? String(plz) + ' ' : null,stadt ? String(stadt) + '' : null,stadtteil ? [' (',stadtteil,')'].join('') : null,kreis ? ', ' + String(kreis) : null,bundesland ? ', ' + String(bundesland) : null,land ? ', ' + String(land) : null,!land ? 'Keine Adressen verfügbar.' : null].join('')), true);
          Über weitere Tipps/Hilfe würde ich mich sehr freuen!
          bahnuhrB CodierknechtC 2 Antworten Letzte Antwort
          • R Razer2412
                let result;
                const options = {
                   method: 'GET',
                   headers: {
                await wait(1000);
                return result;
              hausnummer = '';
              strasse = '';
              plz = '';
              ort = '';
              ort2 = '';
              kreis = '';
              bundesland = '';
              land = '';
            bahnuhrB Online
            bahnuhrB Online
            bahnuhr
            @razer2412
            Warum nimmst du nicht das Script was ich 1 Beitrag vor deinem gesendet habe ?
            Funktioniert einwandfrei.
            Und benutzt httpget.
            Komisch.
            Warum stell ich hier was ein ?
            Danke.
            • R Razer2412
                  let result;
                  const options = {
                     method: 'GET',
                     headers: {
                  await wait(1000);
                  return result;
                hausnummer = '';
                strasse = '';
                plz = '';
                ort = '';
                ort2 = '';
                kreis = '';
                bundesland = '';
                land = '';
              CodierknechtC Offline
              Codierknecht
              @razer2412
              Ich hätte da auch noch 'ne Variante.
              Benötigt allerdings einen (kostenlosen) API-Key:
              async function getAddress(latitude, longitude) {
                  const url = `https://geocode.maps.co/reverse?lat=${latitude}&lon=${longitude}&api_key=${key}`;
                  httpGet(url, {timeout: 20000}, function(err, response) {
                      if (err) {
                          console.log(err);
                      } else if (response.statusCode == 200) {
                          return response.data.display_name;
              Im Übrigen finde ich das bisherige Script reichlich spooky.
              Warum wird da jede Minute die Position bestimmt, wenn das Auto geparkt ist?
              Die wird sich wohl kaum verändern. Es sei denn, jemand schraubt am Raum-Zeit-Kontinuum.
              Das Auto wird doch mit ziemlicher Sicherheit den Status (fährt, steht, geparkt, lädt) übermitteln. Dann muss man die Position doch nur bei Statusänderungen ermitteln.
              @bahnuhr Ist doch viel einfacher, wenn einem jemand das mundgerecht zurechtlegt 😀
              Ne, im Ernst:
              @Razer2412 Wir leisten hier "Hilfe zur Selbsthilfe". Da Eine oder Andere muss man sich dann schon noch selbst zurechfummeln. Das übt 😁
              HmIP|ZigBee|Tasmota|Unifi
              Zabbix Certified Specialist
              • bahnuhrB bahnuhr
                    var lat = "51.4";
                    var lon = "9.5";
                    if (!error) {
                    } else {
                Micha 3
                @bahnuhr sagte in Adresse aus GPS Koordinaten ermitteln ?:
        var lat = "51.4";        var lon = "9.5";        httpGet('https://nominatim.openstreetmap.org/reverse.php?format=json&lat=' + lat + '&lon=' + lon + '&zoom=18', { timeout: 1000 }, (error, response) => {        if (!error) {        //console.log(response.statusCode);        //console.log(response.data);        var result = JSON.parse(response.data);        //log (result.display_name);        log (result.address.road + " " + result.address.house_number);        log (result.address.postcode + " " + result.address.municipality);        } else {        console.error(error);        }        });
                Dankeschön. aber nun kommt wieder was neues. Ich kann es nicht speichern.
                • M Micha 3
                  bahnuhrB Online
                  bahnuhrB Online
                  bahnuhr
                  Danke.
                    Micha 3
                    <block xmlns="https://developers.google.com/blockly/xml" type="procedures_defcustomreturn" id="?;wMWdJ!vB8:m#;$39f@" x="-537" y="213">
                      <mutation statements="false">
                        <arg name="lat" varid="QN!T6w6a-/l=eT]qb^[m"></arg>
                        <arg name="lon" varid=";AX~{zgT$/kdtN6_QqtB"></arg>
                      </mutation>
                      <field name="NAME">OSM</field>
                      <field name="SCRIPT">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</field>
                    </block>
                    Ich bin echt zu doof. darin kommt das JS und das kann ich nicht speichern.
                      Micha 3
                      das JS was drin ist falls ich es nicht gepostet habe.
                      let result;
                      const options = {
                          method: 'GET',
                          headers: {
                      await wait(1000);
                      return result;
                      • M Micha 3
                        let result;
                        const options = {
                            method: 'GET',
                            headers: {
                        await wait(1000);
                        return result;
                        bahnuhrB Online
                        bahnuhrB Online
                        bahnuhr
                        @micha-3
                        Was machst du da ???
                        Versuchst du ein JS in ein blockly rein zu tun ?
                        Speichere das JS in ein JS; und nicht in ein blockly.
                        Danke.
                          Micha 3
                          ich sag doch, ich kann das nicht. ich hab mir das von oben kopiert und es lief ja auch. nun hab ich die Fehlermeldung und festgestellt, es das JS in der Funktion. aber wie und was das alles macht weiß ich nicht.
                          • R Offline
                            Razer2412
                            @bahnuhr
                            Danke für dein Skript! Leider habe ich das gleiche Problem welches auch @Micha-3 versucht zu erklären: Das Skript lässt sich im Javaskript Editor nicht speichern und damit auch nicht nutzen.
                            @Codierknecht vielen Dank auch für deine Hilfe!
                            Bitte beachte die Abfrage jede Minute nicht - die dient nur zu testzwecken.
                            Das fertige Skript funktioniert dann wie das ursprüngliche Skript bei jeder Statusänderung. :)
                            Ich habe schon weit über 30 Skripte (Blockly) zur Hausautomatisierung gebastelt, welche teilweise auch wirklich umfangreich sind. Sehr vieles habe ich über try and error herausgefunden.
                            Auch hier habe ich Stunden selbst versucht ein lauffähiges Skript zu erhalten, bevor ich hier unnötig nachfrage!
                            Ich möchte mich dafür entschuldigen, wenn meine Eigenleistung nicht den Erwartungen gerecht wird.
                            • R Razer2412
                              @bahnuhr
                              bahnuhrB Online
                              bahnuhrB Online
                              bahnuhr
                              @razer2412 sagte in Adresse aus GPS Koordinaten ermitteln ?:
                              Wo seid ihr.
                              Das Script läuft in JS einwandfrei.
                              Seit ihr in VIS Editor ???
                              Danke.
                              R 1 Antwort Letzte Antwort
                              • bahnuhrB bahnuhr
                                Wo seid ihr.
                                Razer2412
                                @bahnuhr
                                in Blockly:
                                Das JS läuft in Blockly
                                • R Razer2412
                                  @bahnuhr
                                  in Blockly:
                                  bahnuhrB Online
                                  bahnuhrB Online
                                  bahnuhr
                                  @razer2412
                                  Wie oft muss ichs das sagen !
                                  Es ist kein blockly !!
                                  Es ist ein stink normales JS.
                                  Danke.
                                    Micha 3
                                    In der JS-Funktion
                                    • bahnuhrB Online
                                      bahnuhrB Online
                                      bahnuhr
                                      Danke.
                                      • bahnuhrB bahnuhr
                                        @razer2412
                                        bahnuhrB Online
                                        bahnuhrB Online
                                        bahnuhr
                                        @razer2412
                                        Danke.
                                        • bahnuhrB Online
                                          bahnuhrB Online
                                          bahnuhr
                                          und nochmal !
                                          JS, kein Blockly !
                                          Danke.
