  4. Test Adapter Niu E-Scooter
37 Beiträge 7 Kommentatoren 4.9k Aufrufe 6 Beobachtet
  • hg6806H hg6806
    @tombox
    Das hatte gestern alles funktioniert, jetzt kommt wieder kein Update mehr und eine Menge Fehlermeldungen. Steht alles auf Debug.
    niu.0
    2022-06-02 17:26:20.823	error	TypeError [ERR_HTTP_INVALID_HEADER_VALUE]: Invalid value "undefined" for header "token"
    niu.0
    2022-06-02 17:26:20.822	error	https://app-api-fk.niu.com/v3/motor_data/cycling_statistics?sortby=3&sn=NA2L4Axxxxxxxxx
    niu.0
    2022-06-02 17:26:20.820	error	TypeError [ERR_HTTP_INVALID_HEADER_VALUE]: Invalid value "undefined" for header "token"
    niu.0
    2022-06-02 17:26:20.820	error	https://app-api-fk.niu.com/v3/motor_data/cycling_statistics?sortby=2&sn=NA2L4Axxxxxxxxxxx
    niu.0
    2022-06-02 17:26:20.817	error	TypeError [ERR_HTTP_INVALID_HEADER_VALUE]: Invalid value "undefined" for header "token"
    niu.0
    2022-06-02 17:26:20.816	error	https://app-api-fk.niu.com/v3/motor_data/cycling_statistics?sortby=1&sn=NA2L4Axxxxxxxxxxx
    niu.0
    2022-06-02 17:26:20.814	error	TypeError [ERR_HTTP_INVALID_HEADER_VALUE]: Invalid value "undefined" for header "token"
    niu.0
    2022-06-02 17:26:20.814	error	https://app-api-fk.niu.com/v5/track/list/v2
    niu.0
    2022-06-02 17:26:20.811	error	TypeError [ERR_HTTP_INVALID_HEADER_VALUE]: Invalid value "undefined" for header "token"
    niu.0
    2022-06-02 17:26:20.811	error	https://app-api-fk.niu.com/v3/motor_data/index_info?sn=NA2L4Axxxxxxx
    niu.0
    2022-06-02 17:26:20.808	error	TypeError [ERR_HTTP_INVALID_HEADER_VALUE]: Invalid value "undefined" for header "token"
    niu.0
    2022-06-02 17:26:20.808	error	https://app-api-fk.niu.com/v5/scooter/motor_data/index_info?sn=NA2L4Axxxxxxxx
    niu.0
    2022-06-02 17:26:20.805	error	TypeError [ERR_HTTP_INVALID_HEADER_VALUE]: Invalid value "undefined" for header "token"
    niu.0
    2022-06-02 17:26:20.805	error	https://app-api-fk.niu.com/v3/motor_data/battery_info?sn=NA2L4Axxxxxxx
    niu.0
    2022-06-02 17:26:20.802	error	TypeError [ERR_HTTP_INVALID_HEADER_VALUE]: Invalid value "undefined" for header "token"
    niu.0
    2022-06-02 17:26:20.802	error	https://app-api-fk.niu.com/v3/motor_data/battery_info/health?sn=NA2L4Axxxxxxx
    T
    T
    tombox
    @hg6806 Kannst du nochmal installieren und schauen ob der fehler weg ist
    C 1 Antwort Letzte Antwort
    • T tombox
      C
      C
      cws
      So, ich hab den Adapter jetzt seit dem letzten Update laufen und es kamen keine Fehler mehr usw. Würde sagen das Ding ist reif, um es auch auf mehr loszulassen. Was meint ihr?
      Jemand ne Idee für die Adapter-Beschreibung? Ich kann ansonsten gerne mal den Vorschlag machen - erst mal auf Deutsch. Hab ich aber noch nie gemacht, von daher bräuchte ich da mal Hilfe.
      • hg6806H
        hg6806H
        hg6806
        Sagt mal, gibt es seitens API keine Info über den derzeitigen Kilometerstand des Fahrzeugs?
        Also ich habe zumindest nichts gefunden.
        Da ich das Ladegerät PV-bedingt über einen SONOFF POW freigebe, kann ich auch die Ladeenergie mittracken und somit immer den derzeitigen Stromverbrauch des Rollers berechnen. Dazu brauche ich aber immer den Kilometerstand.
        • MichaelFM
          MichaelFM
          MichaelF
          Hi, arbeitet oder pflegt den Adapter noch jemand ?
          Da ich eine frage hätte ob es möglich wäre weitere Datenpunkte zu importieren :
          "/motoinfo/overallTally": {
          			"post": {
          				"summary": "Returns the odometer value and days of usage",
          				"requestBody": {
          					"required": true,
          					"content": {
          						"application/x-www-form-urlencoded": {
          							"schema": {
          								"type": "object",
          								"properties": {
          									"sn": {
          										"$ref": "#/components/schemas/MopedDesc/properties/sn"
          									"token": {
          										"$ref": "#/components/schemas/Token"
          				"responses": {
          					"200": {
          						"description": "Odometer and time value",
          						"content": {
          							"application/json": {
          								"schema": {
          									"type": "object",
          									"properties": {
          										"data": {
          											"type": "object",
          											"properties": {
          												"bindDaysCount": {
          													"type": "integer"
          												"totalMileage": {
          													"type": "integer"
          • MichaelFM MichaelF
            			"post": {
            				"requestBody": {
            					"required": true,
            					"content": {
            							"schema": {
            								"type": "object",
            								"properties": {
            									"sn": {
            									"token": {
            				"responses": {
            					"200": {
            						"content": {
            								"schema": {
            									"type": "object",
            									"properties": {
            										"data": {
            											"type": "object",
            											"properties": {
            												"bindDaysCount": {
            													"type": "integer"
            												"totalMileage": {
            													"type": "integer"
            T
            T
            tombox
            @michaelf habs mal in die GitHub version hinzugefügt
            MichaelFM 1 Antwort Letzte Antwort
            • T tombox
              MichaelFM
              MichaelFM
              MichaelF
              @tombox Mega, vielen Dank!
              Funktioniert:
              • MichaelFM
                MichaelFM
                MichaelF
                @tombox
                Hätte noch eine kleine Frage, wie sieht der Http Request zu dem neuen Datenpunkt aus?
                Gibt es da überhaupt einen ?
                Grüsse
                • W
                  W
                  Wolf-B
                  Hallo zusammen und vielen Dank für den Adapter. Gibt es irgendwo eine Liste, worin die Datenpunkte erklärt sind. Manche sagen mir nichts - wäre schön, wenn man nachschlagen könnte, was die einzelnen Datenpunkte bedeuten. Manche erklären sich ja von selbst, aber leider eben nicht alle.
                  Danke schonmal ...
                  Wolfgang
                  • W Wolf-B
                    Danke schonmal ...
                    Wolfgang
                    MichaelFM
                    MichaelFM
                    MichaelF
                    @wolf-b Hi, welche sind denn unklar?
                    Grüsse
                    W 2 Antworten Letzte Antwort
                      Grüsse
                      W
                      W
                      Wolf-B
                      @michaelf Viele - hier mal ein paar Unklarheiten:
                      • GradeBattery (ist bei mir 99.5)
                      • backend_tiure_gauge_value (bei mir 0)
                      • batteryDetail: (bei mir true)
                      • battery_cang_lock (bei mir false)
                      • battery_range (bei mir steht da nix)
                      • centreCtrlBattery (bei mir 100)
                      • cycling_model (bei mir 2)
                      • expire_time (bei mir 0)
                      • isDefault (bei mir true)
                      • isMaster (bei mir true)
                      • is_first_access (bei mir false)
                      • refresh (bei mir aus)
                      • estimatedMileage (Kilometerstand: bei mir 78 / in der App 73)
                      • estimatedMileageRatio (bei mir 440)
                      • new estimatedMileageRatio (bei mir 440)
                      • hdop (bei mir 0)
                      • head_light_status (bei mir steht da nix)
                      • istfortification (bei mir 1)
                      • istcushion_lock_on (bei mir false)
                      • leftTime (bei mir 0)
                      • locationType (bei mir 1)
                      • low_power_mode_value (bei mir 0)
                      Und noch eine Frage: kann man irgendwo einstellen, dass er bei 80% aufhört zu laden ?
                      Vielen Dank schonmal ...
                      Wolfgang
                      W MichaelFM 2 Antworten Letzte Antwort
                      • W Wolf-B
                        • hdop (bei mir 0)
                        Wolfgang
                        W
                        W
                        Wolf-B
                        @wolf-b Auch kann ich meinen Gesamt-km-Stand in den Objekten nicht finden. Wenn damit das Objekt "estimatedMileageRatio" sein sollte, dann steht da 440 drin, in meiner NIU-App habe ich aber einen km-Stand von 313 km.
                        Gibt es einen Datenpunkt (objekt) für den aktuellen Gesamt-km-Stand ?
                        W 1 Antwort Letzte Antwort
                        • W Wolf-B
                          W
                          W
                          Wolf-B
                          schrieb am zuletzt editiert von Wolf-B
                          @wolf-b Zu Eurer Information: Ich habe einen NIU NQI GTS Pro neuestes Modell
                          Insgesamt finde ich den Adapter klasse - bis auf die paar Unklarheiten, die ich anhand der Daten bisher !nicht zuordnen kann.
                            Grüsse
                            W
                            W
                            Wolf-B
                            @michaelf Das hier habe ich aus den Daten gebastelt. Könntest Du mal drüber schauen, ob das so passt - was mir halt noch fehlt sind die gefahrenen Gesamt-Km. Habe da mal einen Platzhalter eingefügt - nur finde ich keinen Datenpunkt, der meinem Km-Stand entspricht.
                            • W Wolf-B
                              • hdop (bei mir 0)
                              Wolfgang
                              MichaelFM
                              MichaelFM
                              MichaelF
                              @wolf-b sagte in Test Adapter Niu E-Scooter:
                              • batteryDetail: (bei mir true) Alle Batterie Infos verfügbar
                              • centreCtrlBattery (bei mir 100) Müsste die Spare Batterie sein
                              • cycling_model (bei mir 2) Der Momentane Fahrmodus
                              • estimatedMileage (Kilometerstand: bei mir 78 / in der App 73) Die KM die noch möglich zu fahren sind, weicht bei mir auch ein wenig ab
                              • hdop (bei mir 0)
                              Wolfgang
                              Die gesamt KM findet man unter :
                              Die Restlichen Datenpunkte sind glaube ich nicht relevant.
                              Ich habe den gleichen in der 2024 Version :-)
                              Das laden kann man so nicht beeinflussen, allerdings kann man den Lade stand abfragen und bei 80% über ein kleines Blockly einen Shelly oder ähnliches Ausschalten.
                              Die Vis is cool gemacht, gefällt mir.
                                • hdop (bei mir 0)
                                Wolfgang
                                W
                                W
                                Wolf-B
                                @michaelf Hallo und danke für Deinen Beitrag. Leider ist bei mir die ganze Sektion "overallTally" überhaupt nicht vorhanden und der Datenpunkt "totalMileage" auch nicht. Da scheint es wohl unterschiedliche Versionen zu geben ?
                                Kann ich das updaten oder geht das über Update die Adapter.
                                  • hdop (bei mir 0)
                                  Wolfgang
                                  W
                                  W
                                  Wolf-B
                                  @michaelf Ich habe übrigens die Version 0.0.3 - gibt es dafür schon ein Update oder wurde die Sektion "overallTally" mittlerweile entfernt ? Welche Version hast Du denn bitte ? Und was macht der Schalter bei "remote:refresh" ?
                                  • MichaelFM
                                    MichaelFM
                                    MichaelF
                                    Hi, also Version habe ich diese:
                                    Vielleicht mal direkt von hier installieren:
                                    https://github.com/TA2k/ioBroker.niu
                                    Zum Schalter kann ich so leider nichts sagen, außer noch nie gebraucht.
                                      W
                                      W
                                      Wolf-B
                                      @michaelf Oha, das ist ja ein richtiger Unterschied - vielen Dank für Deinen Hinweis.
                                      • W Wolf-B
                                        MichaelFM
                                        MichaelFM
                                        MichaelF
                                        @wolf-b Funktioniert jetzt ?
                                          W
                                          W
                                          Wolf-B
                                          @michaelf Hm, wenn ich Deinem Link folge, komme ich auch wieder bei der Version 0.0.3 raus und die habe ich ja - wie komme ich zu Deiner Version ?
                                          83.8k
