  3. Entwicklung
  4. Supportthread Resol-Adapter
    apollon77A
183 Beiträge 11 Kommentatoren 40.5k Aufrufe 10 Beobachtet
  • N
    N
    noio
    schrieb am zuletzt editiert von noio
    #141
    80
    19
    Log-Größe: 3.9 MB
    Zeit
    debug
    Nachricht
    resol.0
    2025-08-27 21:07:00.248	debug	Finishing loadMyConfig...
    resol.0
    2025-08-27 21:07:00.246	error	Error: Unable to complete value {"valueId":"Heizung_Heizkreis1_Betriebsart"}
    resol.0
    2025-08-27 21:07:00.063	debug	fct->item found{"name":"Heizung_Heizkreis2_Betriebsart","cmd":"Heizung_Heizkreis2_Betriebsart","val":"val"}
    resol.0
    2025-08-27 21:07:00.061	debug	fct->item found{"name":"Heizung_Heizkreis1_Betriebsart","cmd":"Heizung_Heizkreis1_Betriebsart","val":"val"}
    resol.0
    2025-08-27 21:07:00.033	debug	options1 {"deviceAddress":32273,"version":2}
    resol.0
    2025-08-27 21:07:00.031	debug	loadMyConfig (context) {"connection":{"_events":{},"_readableState":
    						       {"highWaterMark":65536,"buffer":[],"bufferIndex":0,"length":0,"pipes":
    						       [],"awaitDrainWriters":null},"_writableState":
    						       {"highWaterMark":65536,"length":0,"corked":0,"writelen":0,"bufferedIndex":0,"pendingcb":0},"allowHalfOpen":true,"channel":0,"selfAddress":32,"host":"10.0.0.10","port":7053,"viaTag":null,"password":"bonevbus","channelListCallback":null,"rawVBusDataOnly":false,"tlsOptions":null,"disableReconnect":false,"_eventsCount":3,"connectionState":"CONNECTED","rxBuffer":
    						       {"type":"Buffer","data":
    						       [170,16,0,49,126,16,0,1,10,37,100,48,36,3,1,67,58,0,0,0,0,69,95,75,0,0,1,84,49,32,1,0,1,44,33,70,68,0,0,84,26,118,8,0,1,102]},"socket":{"connecting":false,"_hadError":false,"_parent":null,"_host":null,"_closeAfterHandlingError":false,"_events":{"end":[null,null]},"_readableState":{"highWaterMark":65536,"buffer":[],"bufferIndex":0,"length":0,"pipes":[],"awaitDrainWriters":null},"_writableState":{"highWaterMark":65536,"length":0,"corked":0,"writelen":0,"bufferedIndex":0,"pendingcb":0},"allowHalfOpen":false,"_eventsCount":4,"_sockname":null,"_pendingData":null,"_pendingEncoding":"","server":null,"_server":null,"timeout":30000},"reconnectTimeout":0},"deviceAddress":32273,"deviceID":"007E110010","deviceVersion":2}
    resol.0
    2025-08-27 21:07:00.015	debug	received data: [{"id":"00_0010_7E11_10_0100_000_2_0","name":"Temperatur Sensor
    					       1","rawValue":30.6,"deviceName":"DeltaSol MX
    					       [Regler]","deviceId":"007E110010","addressId":32273,"unitId":"DegreesCelsius","unitText":"
    					       °C","typeId":"Number_0_1_DegreesCelsius","precision":1,"rootTypeId":"Number","parts":
    					       [{"offset":0,"mask":255,"bitPos":0,"isSigned":false,"factor":1},
    					       {"offset":1,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},
    					       {"id":"00_0010_7E11_10_0100_002_2_0","name":"Temperatur Sensor
    					       2","rawValue":51.2,"deviceName":"DeltaSol MX
    N 1 Antwort Letzte Antwort
    • N noio
      80
      19
      Log-Größe: 3.9 MB
      Zeit
      debug
      Nachricht
      resol.0
      resol.0
      resol.0
      resol.0
      resol.0
      resol.0
      resol.0
      N
      N
      noio
      #142
      • N noio
        N
        N
        noio
        #143
        Keine einträge zu "Daten gesendet" oder ähnliches in den Logs wenn ich "Schalter" in den "Objekten" umstelle....
        Also da geht anscheinend nix mehr.....
        Resol MX Firmware : 2.11
        • N noio
          N
          N
          noio
          #144
          Hier ein log mit der git version.......
          vbus-log
          Send.....geht nicht.....😞
          GrizzelbeeG 1 Antwort Letzte Antwort
          • N noio
            vbus-log
            GrizzelbeeG
            GrizzelbeeG
            Grizzelbee
            #145
            @noio sagte in Supportthread Resol-Adapter:
            Ich verstehe ehrlich gesagt nicht was Du da machen und erreichen willst.
            Für den Deltasol MX Controller sind lediglich 2 Actions definiert - nämlich die Betriebsart der beiden Heizkreise umzustellen. Und zwar auf: EIN, AUS und Automatik.
            That's it.
            Erkläre doch bitte mal, was Du zu erreichen versuchst und wie.
            viele Grüße
            grizzelbee1
            • GrizzelbeeG Grizzelbee
              That's it.
              viele Grüße
              grizzelbee1
              N
              N
              noio
              #146
              @grizzelbee said in Supportthread Resol-Adapter:
              Genau dass......mit eingaben im VIS...
              deltasol-mx2xx.js:
              {"dp": [
                      {"dpName":"Heizung_Heizkreis1_Betriebsart", "name":"Heizung_Heizkreis1_Betriebsart", "type":"number","min":0, "max":5,"states":{"0":"Automatik","1":"Tag", "2":"Nacht", "3":"Sommer", "4":"Urlaub", "5":"Aus"}},
                       {"dpName":"Heizung_Heizkreis2_Betriebsart", "name":"Heizung_Heizkreis2_Betriebsart", "type":"number","min":0, "max":5, "states":{"0":"Automatik", "1":"Tag", "2":"Nacht", "3":"Sommer", "4":"Urlaub", "5":"Aus"}}
                 "fct":[{"name":"Heizung_Heizkreis1_Betriebsart","cmd":"Heizung_Heizkreis1_Betriesbsart","val":"val"},
              • N noio
                deltasol-mx2xx.js:
                {"dp": [
                N
                N
                noio
                #147
                Meiner Meinung passt dass soweit ,jedoch zeigt der Regler keine Reaktion weinn ich unter "Aktions" etwas
                Umstelle.......um die Heizkreis zu schalten.......
                Danke , MFG
                Noio
                • N noio
                  Danke , MFG
                  Noio
                  N
                  N
                  noio
                  #148
                  Ok , liegt wohl (auch zum Teil) an meiner 2.11 Firmware......hab da nen Bug Report gefunden.........
                  dass das bei mir nicht geht...
                  Schade eigentlich , wär ganz praktisch gewesen....so bleibts beim Weg in den Keller.......
                  PS: Ich mach kein Firmware Update mehr wenn eh alles läuft.
                  • N noio
                    GrizzelbeeG
                    GrizzelbeeG
                    Grizzelbee
                    #149
                    Denkbar, mein Controller wird nicht auf 2.x aktualisiert, deswegen kann ich das selbst nicht testen.
                    Vielleicht bringt es was, wenn ich die zugrunde liegende Bibliothek gelegentlich mal aktualisiere.
                    Bedeutet das, das die Probleme erst nach dem, Update auftraten?
                    Ist vielleicht ein Downgrade möglich?
                    viele Grüße
                    Grizzelbee
                    N 2 Antworten Letzte Antwort
                      viele Grüße
                      Grizzelbee
                      N
                      N
                      noio
                      #150
                      Nö , ich hab den iobroker erst vor kurzem endteckt , den Regler hab ich >10Jahre im Betrieb ohne Probleme.....
                      Ich halte halt gern meine Geräte auf aktuellem Stand .....
                        viele Grüße
                        Grizzelbee
                        N
                        N
                        noio
                        #151
                        Ja , wenn man den Regler zu Resol schickt und kostet was.... (lt.deren Webseite)
                        MFG
                        F 1 Antwort Letzte Antwort
                        • N noio
                          MFG
                          F
                          F
                          Faz
                          #152
                          @noio, schon mal die RESOL APP "VBus Touch HC" für Android oder Apple angesehen?
                          Dort kann man mit dem MX Regler genau das schalten, kostet allerdings meine 10€ für die RESOL MX Geräte-Freischaltung.
                          Wäre eine Alternative wenn du nicht in den Keller rennen willst und es mit dem IoBroker nicht mehr funktioniert.
                          Grüße Faz
                          • F Faz
                            Grüße Faz
                            N
                            N
                            noio
                            #153
                            @faz said in Supportthread Resol-Adapter:
                            @noio, schon mal die RESOL APP "VBus Touch HC" gesehen ?
                            Grüße Faz
                            Habs mir grad nochmal angesehen......Die App will ne Registrierung bei Vbus.net von mir......will ich nicht....
                            Trotzdem Danke.......
                            MFG
                            • N
                              N
                              noio
                              #154
                              Hallo ich nochmal.....
                              Könnte die main.js geändert werden damit Angelegte Datenpunkte anpassbar werden ?
                              MFG
                              noio
                              • N noio
                                MFG
                                noio
                                GrizzelbeeG
                                GrizzelbeeG
                                Grizzelbee
                                #155
                                Ja, könnte man grundsätzlich, aber was soll das bringen?
                                Alles was sinnvoll Änderbar ist (also auch irgendwelche Aktionen auslöst) findest Du unter "Actions".
                                Alles Andere ist eben nicht änderbar, weil es keinen Sinn ergibt etwas daran zu ändern - und weil es mit dem nächsten Datenpoll vom Controller eh wieder überschrieben würde.
                                Was ist also deine Idee hinter der Frage?
                                viele Grüße
                                grizzelbee
                                  viele Grüße
                                  grizzelbee
                                  N
                                  N
                                  noio
                                  #156
                                  @Grizzelbee sagte in Supportthread Resol-Adapter:
                                  genau darum gehts mir.....
                                  Ich wollte die Sensoren benennen ......
                                  I wollte eine sinnvolle Skalierung im Istwertdiagramm vom Material Widgeds Adapter für jeden Sensor seperat........
                                  Natürlich kann man Workarounds machen ....
                                  Ich dachte halt , es würd doch reichen wenn der Resol Adapter nach dem ersten Anlegen nur mehr "Values und States" aktualisiert.........
                                  MFG
                                  noio
                                  GarganoG 1 Antwort Letzte Antwort
                                  • N noio
                                    MFG
                                    noio
                                    GarganoG
                                    GarganoG
                                    Gargano
                                    #157
                                    @noio erstelle Aliase, die kannst Du benennen wie Du willst.
                                    • GarganoG Gargano
                                      N
                                      N
                                      noio
                                      #158
                                      @Gargano sagte in Supportthread Resol-Adapter:
                                      Danke , hab ich noch nicht gekannt.....
                                      Naja ich mach das derweil selbst ,mit nem kurzen skript....
                                      MFG
                                      noio
                                      • N
                                        N
                                        noio
                                        #159
                                            //  Create or extend object
                                            createOrExtendObject(id, objData, value) {
                                                const self = this;
                                                this.getObject(id, function (err, oldObj) {
                                                    if (!err && oldObj) {
                                                        self.extendObject(id, objData, () => {
                                                            if (typeof value !== 'undefined') self.setState(id, value, true);
                                                    } else {
                                                        self.setObjectNotExists(id, objData, () => {
                                            const self = this;
                                            // Hole das aktuelle Objekt, um zu überprüfen, ob es bereits existiert
                                                    // Objekt existiert bereits, nur den Wert des States aktualisieren
                                                    const currentState = self.getState(id) ? self.getState(id).val : undefined;
                                                    // Nur den State setzen, wenn sich der Wert geändert hat
                                                    if (typeof value !== 'undefined' && currentState !== value) {
                                                        self.setState(id, value, true); // State nur aktualisieren, wenn der Wert sich geändert hat
                                                } else {
                                                    // Objekt existiert noch nicht - setze es mit den Metadaten
                                                        // Bei der ersten Erstellung setzen wir auch den Wert
                                                        if (typeof value !== 'undefined') {
                                        iobroker/node-modules/iobroker.resol/main.js
                                        Ca. Ab Zeile 882 , das "Auskommentierte" ist das Orginal
                                        Den Teil danach hab ich von ChatGPT .......gemacht bekommen .
                                        Scheint so zu Funktionieren.......
                                        Ich hab das (ChatGPT) zum ersten mal Benutzt , bin nicht mal Angemeldet....
                                        MFG noio
                                        • N
                                          N
                                          noio
                                          #160
                                          Ich hab jetzt auch einen debug Log von der Ausgabe wenn ich unter den Actions was umstelle....
                                          resol.0
                                          	2025-11-25 19:34:02.068	debug	Finishing runshot ...
                                          resol.0
                                          	2025-11-25 19:34:02.067	error	[runShot] Error: Error: Unable to complete value {"valueId":"Heizung_Heizkreis2_Betriebsart","value":3}
                                          resol.0
                                          	2025-11-25 19:34:02.005	debug	Start Optimizer
                                          resol.0
                                          	2025-11-25 19:34:02.005	debug	options1 {"deviceAddress":32273,"version":2}
                                          resol.0
                                          	2025-11-25 19:34:02.004	debug	Found master with address 0x7e11
                                          resol.0
                                          	2025-11-25 19:34:00.015	debug	Finishing loadMyConfig...
                                          resol.0
                                          	2025-11-25 19:34:00.015	error	TypeError: Cannot read properties of undefined (reading 'cmd')
                                          resol.0
                                          	2025-11-25 19:34:00.009	debug	options1 {"deviceAddress":32273,"version":2}
                                          resol.0
                                          	2025-11-25 19:33:59.059	debug	Waiting for free bus...
                                          resol.0
                                          	2025-11-25 19:33:59.059	debug	myJSON: [{"valueId":"Heizung_Heizkreis2_Betriebsart","value":3}]
                                          resol.0
                                          	2025-11-25 19:33:59.059	debug	Finishing Dpfunction...
                                          resol.0
                                          	2025-11-25 19:33:59.058	debug	[{"valueId":"Heizung_Heizkreis2_Betriebsart","value":3}]
                                          resol.0
                                          	2025-11-25 19:33:59.058	debug	getDpFunction jsoncontrollerSetupItems->item {"name":"Heizung_Heizkreis2_Betriebsart","cmd":"Heizung_Heizkreis2_Betriebsart","val":"val"}
                                          resol.0
                                          	2025-11-25 19:33:59.058	debug	"getDpFunction jsoncontrollerSetupItems [object Object]"
                                          resol.0
                                          	2025-11-25 19:33:59.058	debug	State :3
                                          resol.0
                                          	2025-11-25 19:33:59.057	debug	State of Object: {"val":3,"ack":false,"ts":1764095639054,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1764095639054}
                                          resol.0
                                          	2025-11-25 19:33:59.056	debug	Change on Object: "resol.0.007E110010.Actions.Heizung_Heizkreis2_Betriebsart"
                                          resol.0
                                          	2025-11-25 19:33:00.015	debug	Finishing loadMyConfig...
                                          resol.0
                                          	2025-11-25 19:33:00.015	error	TypeError: Cannot read properties of undefined (reading 'cmd')
                                          resol.0
                                          	2025-11-25 19:33:00.010	debug	options1 {"deviceAddress":32273,"version":2}
                                          resol.0
                                          	2025-11-25 19:32:37.001	debug	Finishing runshot ...
                                          resol.0
                                          	2025-11-25 19:32:37.001	error	[runShot] Error: TypeError: Cannot read properties of undefined (reading 'reduce')
                                          resol.0
                                          	2025-11-25 19:32:36.999	debug	Save config undefined
                                          resol.0
                                          	2025-11-25 19:32:36.999	debug	Optimizer savedConfig = loadedConfig
                                          resol.0
                                          	2025-11-25 19:32:36.997	debug	options1 {"deviceAddress":32273,"version":2}
                                          resol.0
                                          	2025-11-25 19:32:36.996	debug	Found master with address 0x7e11
                                          resol.0
                                          	2025-11-25 19:32:35.019	debug	Waiting for free bus...
                                          resol.0
                                          	2025-11-25 19:32:35.018	debug	myJSON: undefined
                                          resol.0
                                          	2025-11-25 19:32:35.018	debug	Finishing Dpfunction...
                                          resol.0
                                          	2025-11-25 19:32:35.018	error	[getDpFunction] : fctItem not defined!
                                          resol.0
                                          	2025-11-25 19:32:35.018	debug	getDpFunction jsoncontrollerSetupItems->item {"name":"Heizung_Heizkreis2_Betriebsart","cmd":"Heizung_Heizkreis2_Betriebsart","val":"val"}
                                          resol.0
                                          	2025-11-25 19:32:35.018	debug	"getDpFunction jsoncontrollerSetupItems [object Object]"
                                          resol.0
                                          	2025-11-25 19:32:35.017	debug	State :0
                                          resol.0
                                          	2025-11-25 19:32:35.017	debug	State of Object: {"val":0,"ack":false,"ts":1764095555014,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1764095555014}
                                          resol.0
                                          	2025-11-25 19:32:35.016	debug	Change on Object: "resol.0.007E110010.Actions.Heizung_Heizkreis1_Betriebsart"
                                          Heizkreis 2 bekommt nach wie vor keinen Namen......und kann auch nicht benannt werden......
                                          Ansonsten Funktioniert der Adapter bei mir anstandslos fehlerfrei...
                                          Nochmal vielen vielen Dank
                                          MFG Noio
                                          84.0k
