  3. Entwicklung
  4. Supportthread Resol-Adapter
176 Beiträge 10 Kommentatoren 35.4k Aufrufe 9 Beobachtet
  • C ckhx78
    @gargano
    Moin!
    Das macht kein Unterschied, egal was ich dort Einstelle, es ändert nichts...
    resol.0
    2024-08-05 20:27:41.027	debug	fct->item found{"name":"Oelheizung_Status","cmd":"Feger_Relaismodus3","val":"val"}
    Was mich noch wundert, meist gibt es beim Start des Adapters noch folgende Meldungen... wenn man Ihn dann irgendwann nochmal neu startet, dann sind die meist weg:
    resol.0
    2024-08-05 20:28:48.411	error	[generateDP] Error: TypeError: Cannot read properties of undefined (reading 'setup')
    resol.0
    2024-08-05 20:28:48.410	warn	[getJSONByResolId] Controller type not found in setup file.
    resol.0
    2024-08-05 20:28:47.176	info	Connection established
    resol.0
    2024-08-05 20:28:47.144	info	Connection state changed to CONNECTING
    resol.0
    2024-08-05 20:28:47.144	info	Waiting for Connection...
    resol.0
    2024-08-05 20:28:47.143	info	TCP Connection to KM2/DL2 on [192.168.200.35:7053] selected
    resol.0
    2024-08-05 20:28:47.130	info	Config seems to be valid for KM2/DL2/DL3.
    resol.0
    2024-08-05 20:28:47.114	info	starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.resol, node: v18.20.4, js-controller: 6.0.9
    resol.0
    2024-08-05 20:28:27.119	info	terminating
    resol.0
    2024-08-05 20:28:26.624	info	Connection state changed to DISCONNECTED
    resol.0
    2024-08-05 20:28:26.616	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    resol.0
    2024-08-05 20:28:26.616	debug	Plugin sentry destroyed
    resol.0
    2024-08-05 20:28:26.615	info	terminating
    resol.0
    2024-08-05 20:28:26.614	info	Cleaned up everything...
    resol.0
    2024-08-05 20:28:26.614	info	Connection state changed to DISCONNECTING
    resol.0
    2024-08-05 20:28:26.612	info	Got terminate signal TERMINATE_YOURSELF
    resol.0
    2024-08-05 20:28:26.612	silly	States system redis pmessage system.adapter.resol.0.sigKill/system.adapter.resol.0.sigKill:{"val":-1,"ack":false,"ts":1722882506609,"q":0,"from":"system.host.ubuntu","lc":1722882506609}
    resol.0
    2024-08-05 20:28:12.019	silly	States user redis pmessage resol.0.0078210010.Actions.Oelheizung_Status/resol.0.0078210010.Actions.Oelheizung_Status:{"val":null,"ack":true,"ts":1722882492018,"q":0,"from":"system.adapter.resol.0","user":"system.user.admin","lc":1722882492018}
    resol.0
    2024-08-05 20:28:12.010	debug	Finishing loadMyConfig...
    resol.0
    2024-08-05 20:28:12.010	debug	fct->item found{"name":"Oelheizung_Status","cmd":"Feger_Relaismodus3","val":"val"}
    resol.0
    2024-08-05 20:28:12.010	debug	dp->Name found{"dpName":"Oelheizung_Status","name":"Manual control for this relay.","type":"number","min":0,"max":2,"states":{"0":"Off","1":"Auto","2":"On"}}
    resol.0
    2024-08-05 20:28:12.009	debug	dp->item found{"name":"Oelheizung_Status","cmd":"Feger_Relaismodus3","val":"val"}
    resol.0
    2024-08-05 20:28:12.009	debug	loadedConfig [{"valueId":"Feger_Relaismodus3","valueIndex":2243,"priority":0,"valueTextById":{},"pending":false,"transceived":false}]
    resol.0
    2024-08-05 20:28:00.016	debug	fct->item found{"name":"Oelheizung_Status","cmd":"Feger_Relaismodus3","val":"val"}
    GarganoG Offline
    GarganoG Offline
    Gargano
    schrieb am zuletzt editiert von Gargano
    #137
    @ckhx78 Ich habe jetzt mal bei mir den Index in dem Data-File von meinem Controller geändert , so daß er den Index nicht kennt.
    Save config [{"valueId":"THolyCool","value":500,"valueIndex":9999,"priority":0,"valueTextById":{},"pending":false,"transceived":false}]
    Also das gleiche Verhalten wie bei Dir. Der Controller kennt den Index nicht.
    Hast Du mal etwas anderes probiert, außer die Relais ?
    Noch ein Idee :
    Hast Du mal den User Code im Cosmo auf Expert geändert ?
    C 1 Antwort Letzte Antwort
    • GarganoG Gargano
      Noch ein Idee :
      ckhx78
      #138
      @gargano
      Moin! :-)
      Den User Code hab ich auf Expert stehen, Hm... was anderes als die Relais hab ich noch nicht probiert, komm ich erst die Tage zu :-)
      Die wichtigste Funktion bisher war immer nur das Auslesen der Daten, das geht ja einwandfrei :-)
      GarganoG 1 Antwort Letzte Antwort
      • C ckhx78
        @gargano
        Moin! :-)
        GarganoG Offline
        GarganoG Offline
        Gargano
        #139
        @ckhx78 Hi,
        ich habe inzwischen Antwort vom Daniel :
        Mit
        "valueId": "Relaismodus5",
        "valueIndex": 501,
        "value": 2
        sollte das Relais 5 in den Handbetrieb gehen.
        Daniel hat sich einen COSMO Multi geliehen, auf der eine Firmware-Version 1.05 und damit probiert.
        • GarganoG Gargano
          @ckhx78 Hi,
          Mit
          "valueIndex": 501,
          "value": 2
          ckhx78
          #140
          @gargano
          Ich les das grade erst, Sorry!
          Mega!! Aktuell war nur noch sehr wenig Zeit und die Heizung hinten angestellt, im Sommer ist's Interessanter wenn der Puffer über den Kollektor genug Wärme hat, aktuell hab ich an dem Puffer noch einen Holzofen (mit Wassertasche) und einen Pelletsofen mit Wassertasche, aber wenn die laufen kommt reichlich Hitze :-)
          Aber ganz ganz vielen Dank, denke spätestens zum Frühjahr wird das wieder Interessant! :-)
          Schöne Feiertage und guten Rutsch!!
          Christoph
          • N Offline
            N Offline
            noio
            schrieb am zuletzt editiert von noio
            #141
            80
            19
            Log-Größe: 3.9 MB
            Zeit
            debug
            Nachricht
            resol.0
            2025-08-27 21:07:00.248	debug	Finishing loadMyConfig...
            resol.0
            2025-08-27 21:07:00.246	error	Error: Unable to complete value {"valueId":"Heizung_Heizkreis1_Betriebsart"}
            resol.0
            2025-08-27 21:07:00.063	debug	fct->item found{"name":"Heizung_Heizkreis2_Betriebsart","cmd":"Heizung_Heizkreis2_Betriebsart","val":"val"}
            resol.0
            2025-08-27 21:07:00.061	debug	fct->item found{"name":"Heizung_Heizkreis1_Betriebsart","cmd":"Heizung_Heizkreis1_Betriebsart","val":"val"}
            resol.0
            2025-08-27 21:07:00.033	debug	options1 {"deviceAddress":32273,"version":2}
            resol.0
            2025-08-27 21:07:00.031	debug	loadMyConfig (context) {"connection":{"_events":{},"_readableState":
            						       {"highWaterMark":65536,"buffer":[],"bufferIndex":0,"length":0,"pipes":
            						       [],"awaitDrainWriters":null},"_writableState":
            						       {"highWaterMark":65536,"length":0,"corked":0,"writelen":0,"bufferedIndex":0,"pendingcb":0},"allowHalfOpen":true,"channel":0,"selfAddress":32,"host":"10.0.0.10","port":7053,"viaTag":null,"password":"bonevbus","channelListCallback":null,"rawVBusDataOnly":false,"tlsOptions":null,"disableReconnect":false,"_eventsCount":3,"connectionState":"CONNECTED","rxBuffer":
            						       {"type":"Buffer","data":
            						       [170,16,0,49,126,16,0,1,10,37,100,48,36,3,1,67,58,0,0,0,0,69,95,75,0,0,1,84,49,32,1,0,1,44,33,70,68,0,0,84,26,118,8,0,1,102]},"socket":{"connecting":false,"_hadError":false,"_parent":null,"_host":null,"_closeAfterHandlingError":false,"_events":{"end":[null,null]},"_readableState":{"highWaterMark":65536,"buffer":[],"bufferIndex":0,"length":0,"pipes":[],"awaitDrainWriters":null},"_writableState":{"highWaterMark":65536,"length":0,"corked":0,"writelen":0,"bufferedIndex":0,"pendingcb":0},"allowHalfOpen":false,"_eventsCount":4,"_sockname":null,"_pendingData":null,"_pendingEncoding":"","server":null,"_server":null,"timeout":30000},"reconnectTimeout":0},"deviceAddress":32273,"deviceID":"007E110010","deviceVersion":2}
            resol.0
            2025-08-27 21:07:00.015	debug	received data: [{"id":"00_0010_7E11_10_0100_000_2_0","name":"Temperatur Sensor
            					       1","rawValue":30.6,"deviceName":"DeltaSol MX
            					       [Regler]","deviceId":"007E110010","addressId":32273,"unitId":"DegreesCelsius","unitText":"
            					       °C","typeId":"Number_0_1_DegreesCelsius","precision":1,"rootTypeId":"Number","parts":
            					       [{"offset":0,"mask":255,"bitPos":0,"isSigned":false,"factor":1},
            					       {"offset":1,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},
            					       {"id":"00_0010_7E11_10_0100_002_2_0","name":"Temperatur Sensor
            					       2","rawValue":51.2,"deviceName":"DeltaSol MX
            N 1 Antwort Letzte Antwort
            • N noio
              80
              19
              Log-Größe: 3.9 MB
              Zeit
              debug
              Nachricht
              resol.0
              resol.0
              resol.0
              resol.0
              resol.0
              resol.0
              resol.0
              N Offline
              N Offline
              noio
              #142
              • N noio
                N Offline
                N Offline
                noio
                #143
                Keine einträge zu "Daten gesendet" oder ähnliches in den Logs wenn ich "Schalter" in den "Objekten" umstelle....
                Also da geht anscheinend nix mehr.....
                Resol MX Firmware : 2.11
                • N noio
                  N Offline
                  N Offline
                  noio
                  #144
                  Hier ein log mit der git version.......
                  vbus-log
                  Send.....geht nicht.....😞
                  GrizzelbeeG 1 Antwort Letzte Antwort
                  • N noio
                    vbus-log
                    GrizzelbeeG Offline
                    GrizzelbeeG Offline
                    Grizzelbee
                    #145
                    @noio sagte in Supportthread Resol-Adapter:
                    Ich verstehe ehrlich gesagt nicht was Du da machen und erreichen willst.
                    Für den Deltasol MX Controller sind lediglich 2 Actions definiert - nämlich die Betriebsart der beiden Heizkreise umzustellen. Und zwar auf: EIN, AUS und Automatik.
                    That's it.
                    Erkläre doch bitte mal, was Du zu erreichen versuchst und wie.
                    viele Grüße
                    grizzelbee1
                    • GrizzelbeeG Grizzelbee
                      That's it.
                      viele Grüße
                      grizzelbee1
                      N Offline
                      N Offline
                      noio
                      #146
                      @grizzelbee said in Supportthread Resol-Adapter:
                      Genau dass......mit eingaben im VIS...
                      deltasol-mx2xx.js:
                      {"dp": [
                              {"dpName":"Heizung_Heizkreis1_Betriebsart", "name":"Heizung_Heizkreis1_Betriebsart", "type":"number","min":0, "max":5,"states":{"0":"Automatik","1":"Tag", "2":"Nacht", "3":"Sommer", "4":"Urlaub", "5":"Aus"}},
                               {"dpName":"Heizung_Heizkreis2_Betriebsart", "name":"Heizung_Heizkreis2_Betriebsart", "type":"number","min":0, "max":5, "states":{"0":"Automatik", "1":"Tag", "2":"Nacht", "3":"Sommer", "4":"Urlaub", "5":"Aus"}}
                         "fct":[{"name":"Heizung_Heizkreis1_Betriebsart","cmd":"Heizung_Heizkreis1_Betriesbsart","val":"val"},
                      • N noio
                        deltasol-mx2xx.js:
                        {"dp": [
                        N Offline
                        N Offline
                        noio
                        #147
                        Meiner Meinung passt dass soweit ,jedoch zeigt der Regler keine Reaktion weinn ich unter "Aktions" etwas
                        Umstelle.......um die Heizkreis zu schalten.......
                        Danke , MFG
                        Noio
                        • N noio
                          Danke , MFG
                          Noio
                          N Offline
                          N Offline
                          noio
                          #148
                          Ok , liegt wohl (auch zum Teil) an meiner 2.11 Firmware......hab da nen Bug Report gefunden.........
                          dass das bei mir nicht geht...
                          Schade eigentlich , wär ganz praktisch gewesen....so bleibts beim Weg in den Keller.......
                          PS: Ich mach kein Firmware Update mehr wenn eh alles läuft.
                          • N noio
                            GrizzelbeeG Offline
                            GrizzelbeeG Offline
                            Grizzelbee
                            #149
                            Denkbar, mein Controller wird nicht auf 2.x aktualisiert, deswegen kann ich das selbst nicht testen.
                            Vielleicht bringt es was, wenn ich die zugrunde liegende Bibliothek gelegentlich mal aktualisiere.
                            Bedeutet das, das die Probleme erst nach dem, Update auftraten?
                            Ist vielleicht ein Downgrade möglich?
                            viele Grüße
                            Grizzelbee
                            N 2 Antworten Letzte Antwort
                              viele Grüße
                              Grizzelbee
                              N Offline
                              N Offline
                              noio
                              #150
                              Nö , ich hab den iobroker erst vor kurzem endteckt , den Regler hab ich >10Jahre im Betrieb ohne Probleme.....
                              Ich halte halt gern meine Geräte auf aktuellem Stand .....
                                viele Grüße
                                Grizzelbee
                                N Offline
                                N Offline
                                noio
                                #151
                                Ja , wenn man den Regler zu Resol schickt und kostet was.... (lt.deren Webseite)
                                MFG
                                F 1 Antwort Letzte Antwort
                                • N noio
                                  MFG
                                  Faz
                                  #152
                                  @noio, schon mal die RESOL APP "VBus Touch HC" für Android oder Apple angesehen?
                                  Dort kann man mit dem MX Regler genau das schalten, kostet allerdings meine 10€ für die RESOL MX Geräte-Freischaltung.
                                  Wäre eine Alternative wenn du nicht in den Keller rennen willst und es mit dem IoBroker nicht mehr funktioniert.
                                  Grüße Faz
                                  • F Faz
                                    Grüße Faz
                                    N Offline
                                    N Offline
                                    noio
                                    #153
                                    @faz said in Supportthread Resol-Adapter:
                                    @noio, schon mal die RESOL APP "VBus Touch HC" gesehen ?
                                    Grüße Faz
                                    Habs mir grad nochmal angesehen......Die App will ne Registrierung bei Vbus.net von mir......will ich nicht....
                                    Trotzdem Danke.......
                                    MFG
                                    • N Offline
                                      N Offline
                                      noio
                                      #154
                                      Hallo ich nochmal.....
                                      Könnte die main.js geändert werden damit Angelegte Datenpunkte anpassbar werden ?
                                      MFG
                                      noio
                                      • N noio
                                        MFG
                                        noio
                                        GrizzelbeeG Offline
                                        GrizzelbeeG Offline
                                        Grizzelbee
                                        #155
                                        Ja, könnte man grundsätzlich, aber was soll das bringen?
                                        Alles was sinnvoll Änderbar ist (also auch irgendwelche Aktionen auslöst) findest Du unter "Actions".
                                        Alles Andere ist eben nicht änderbar, weil es keinen Sinn ergibt etwas daran zu ändern - und weil es mit dem nächsten Datenpoll vom Controller eh wieder überschrieben würde.
                                        Was ist also deine Idee hinter der Frage?
                                        viele Grüße
                                        grizzelbee
                                          viele Grüße
                                          grizzelbee
                                          N Offline
                                          N Offline
                                          noio
                                          #156
                                          @Grizzelbee sagte in Supportthread Resol-Adapter:
                                          genau darum gehts mir.....
                                          Ich wollte die Sensoren benennen ......
                                          I wollte eine sinnvolle Skalierung im Istwertdiagramm vom Material Widgeds Adapter für jeden Sensor seperat........
                                          Natürlich kann man Workarounds machen ....
                                          Ich dachte halt , es würd doch reichen wenn der Resol Adapter nach dem ersten Anlegen nur mehr "Values und States" aktualisiert.........
                                          MFG
                                          noio
