  4. Alexa Shopping List mit Bring synchronisieren
187 Beiträge 32 Kommentatoren 60.6k Aufrufe 31 Beobachtet
  • Der-JetiD Der-Jeti
    Mit der neuen Version vom Alexa Adapter 3.27.0 und dem Script funktioniert das Synchronisieren auf beiden Seiten wieder.
    const bringBaseId = 'bring.0.xxxxxxxx-xxx-xxxx-xxxx-xxxxxxxxxxxx';
    const alexa2BaseId = 'alexa2.0.Lists.SHOP';
    const bringListId = bringBaseId + '.content';
    const bringListCompletedId = bringBaseId + '.recentContent';
    const bringAddToList = bringBaseId + '.saveItem';
    const bringCompleteItem = bringBaseId + '.moveToRecentContent';
    const alexaAddToList = alexa2BaseId + '.#New';
    const alexaListId = alexa2BaseId + '.json';
    const printDebug = true;
    function debug(msg) {
        if (printDebug) log(msg);
    const TodoItemStatus = {
        NeedsAction: 'needs_action',
        Completed: 'completed',
    function ListCleaner(Eintrag = '') {
        return Eintrag
            .split(' ')
            .map(w => w.charAt(0).toUpperCase() + w.slice(1))
            .join(' ');
    function compareCompleted(alexaItem, bringItem) {
        return (
            (alexaItem.completed && bringItem.status === TodoItemStatus.Completed) ||
            (!alexaItem.completed && bringItem.status === TodoItemStatus.NeedsAction)
    function eliminateDuplicated() {
        const raw = getState(alexaListId).val;
        if (!raw) return;
        const list = JSON.parse(raw);
        const seen = {};
        for (const item of list) {
            const cleaned = ListCleaner(item.value);
            if (seen[cleaned]) {
                debug(`Delete duplicate Alexa item: ${item.value}`);
                setState(`${alexa2BaseId}.items.${item.id}.#delete`, true);
            } else {
                seen[cleaned] = true;
    function syncLists(alexaList, bringList, timestampBring, source, recentList) {
        for (const alexaItem of alexaList) {
            const cleanedName = ListCleaner(alexaItem.value);
            alexaItem.found = false;
            // Suche im aktiven Bring-Einträgen
            for (const bringItem of bringList) {
                if (ListCleaner(bringItem.name) === cleanedName) {
                    alexaItem.found = true;
                    bringItem.found = true;
                    if (alexaItem.updatedDateTime > timestampBring) {
                        if (!compareCompleted(alexaItem, bringItem)) {
                            if (source === 'Alexa' && alexaItem.completed) {
                                debug(`Markiere "${bringItem.name}" als erledigt in Bring (von Alexa)`);
                                setState(bringCompleteItem, cleanedName);
                    } else {
                            if (source === 'Bring') {
                                debug(`Aktualisiere "${alexaItem.value}" in Alexa (von Bring)`);
                                setState(`${alexa2BaseId}.items.${alexaItem.id}.completed`, bringItem.status === TodoItemStatus.Completed);
            // Suche im "recentContent" von Bring
            for (const bringItem of recentList) {
                        if (source === 'Alexa' && !compareCompleted(alexaItem, bringItem)) {
                            debug(`Füge "${bringItem.name}" erneut zu Bring hinzu (von Alexa)`);
                            setState(bringAddToList, cleanedName);
                    } else {
                                debug(`Lösche Alexa-Eintrag "${alexaItem.value}" (von Bring)`);
                                setState(`${alexa2BaseId}.items.${alexaItem.id}.#delete`, true);
            // Alexa-Item nicht gefunden in Bring
            if (!alexaItem.found) {
                if (alexaItem.completed) {
                    debug(`Lösche erledigten Alexa-Eintrag "${alexaItem.value}", nicht in Bring gefunden.`);
                } else if (source === 'Alexa') {
                    debug(`Füge neuen Alexa-Eintrag "${alexaItem.value}" zu Bring hinzu`);
        // Bring-Einträge, die nicht in Alexa sind
            if (!bringItem.found && bringItem.status !== TodoItemStatus.Completed && source === 'Bring') {
                debug(`Füge Bring-Eintrag "${bringItem.name}" zu Alexa hinzu`);
                setState(alexaAddToList, ListCleaner(bringItem.name));
    function doSync(source) {
        eliminateDuplicated();
        const rawAlexa = getState(alexaListId).val;
        const rawBring = getState(bringListId).val;
        const rawCompleted = getState(bringListCompletedId).val;
        if (!rawAlexa || !rawBring || !rawCompleted) {
            debug('Datenpunkte unvollständig');
            return;
        const alexaList = JSON.parse(rawAlexa);
        const bringList = JSON.parse(rawBring);
        const bringCompleted = JSON.parse(rawCompleted);
        const timestamp = getState(bringListId).ts;
        syncLists(alexaList, bringList, timestamp, source, bringCompleted);
    on({ id: bringListId, change: 'any' }, () => {
        debug('Änderung durch Bring erkannt');
        doSync('Bring');
    on({ id: alexaListId, change: 'any' }, () => {
        debug('Änderung durch Alexa erkannt');
        doSync('Alexa');
    // Initial Sync beim Start
    doSync('Startup');
    M Online
    M Online
    MCU
    #146
    @der-jeti 3.27.0 gibt es nicht
    EDIT: anscheinend doch
    "version": "3.27.0",
    T mcBirneM 2 Antworten Letzte Antwort
    • M MCU
      thorschtn
      #147
      @mcu Funktioniert einwandfrei. Lediglich die noch nicht offiziell releaste 3.27.0 laden und im Javascript die const alexa2BaseId ändern.
      • M MCU
        mcBirneM Offline
        mcBirneM Offline
        mcBirne
        #148
        @mcu Wo findest du die v3.27.0? Ich finde nur die v3.26.7
        Der-JetiD M 2 Antworten Letzte Antwort
        • mcBirneM mcBirne
          Der-JetiD Offline
          Der-JetiD Offline
          Der-Jeti
          #149
          @mcbirne mit der Katze von github laden.
          • mcBirneM mcBirne
            M Online
            M Online
            MCU
            #150
            @mcbirne
            https://github.com/Apollon77/ioBroker.alexa2/blob/9baece37d4796b88d8debb7af9cbfef50cfc92c8/io-package.json#L4
            • M MCU
              @mcbirne
              M Online
              M Online
              martin_olw
              #151
              @Heimweh - kann mit der neuen Version vom Alexa Adapter 3.27.x über die Datenpunkte in alexa2.0.Lists.SHOP mit TODOIST gesycnt oder zuverlässig nach TODOIST geschrieben werden? Aktuell klappt das bei mir mit deinem Skript nur in 30 % der Fälle.
              Danke!
              VG Martin
              HeimwehH 3 Antworten Letzte Antwort
              • M martin_olw
                Danke!
                VG Martin
                HeimwehH Offline
                HeimwehH Offline
                Heimweh
                schrieb am zuletzt editiert von Heimweh
                #152
                @martin_olw bei mir hat das zu 100% funktioniert. Ich habe mir zuletzt einen eigenen Alexa Skill gebastelt für Einkaufs und Todoliste mit Todoist. Es hat auch geklappt allerdings blöd zum aufrufen. Bsp.: Alexa sag meinen Projekten, ich muss Fenster putzen. - bei dem Script den ich online gestellt hatte war bei mir öfters das Problem der summary Datenpunkt der zeitweise nicht funktioniert. Ich kann Dir derzeit nicht helfen weil ich noch 3 Wochen im Urlaub bin, habe aber interessiert hier mitgelesen und wollte mir das nach Rückkehr mal anschauen..... Ich denke schon dass man das wieder verknüpfen kann so das es mit Todoist läuft
                aruttkampA 1 Antwort Letzte Antwort
                • HeimwehH Heimweh
                  aruttkampA Offline
                  aruttkampA Offline
                  aruttkamp
                  #153
                  Das läuft jetzt wieder wie geschmiert !
                  Danke an alle beteiligten !
                  • aruttkampA aruttkamp
                    aruttkampA Offline
                    aruttkampA Offline
                    aruttkamp
                    schrieb am zuletzt editiert von aruttkamp
                    #154
                    @Heimweh
                    Mir ist aufgefallen, dass das Skript jede Minute eine Änderung durch Bring! erkennt.
                    Dabei ist es egal ob etwas geändert wurde oder nicht. Hat das schon mal jemand beleuchtet warum dies passiert und wie das evtl. unterbunden werden kann ?
                    HeimwehH 1 Antwort Letzte Antwort
                      @Heimweh
                      HeimwehH Offline
                      HeimwehH Offline
                      Heimweh
                      #155
                      @aruttkamp - Du meinst Todoist? Kannst Du mir näher beschreiben was Du genau meinst? Vielleicht wird er Summary Datenpunkt minütlich abgefragt? Aber das dürfte nicht relevant sein solange sich der Wert nicht ändert? Bei mir läuft der Skript seit Erstellung problemlos.... Habe mich daher auch nicht mehr damit befasst.....
                      • HeimwehH Heimweh
                        aruttkampA Offline
                        aruttkampA Offline
                        aruttkamp
                        #156
                        @heimweh
                        ich meine Diese Protokolleinträge :
                        ja, es sind nur infos und ich kann sie abstellen. aber es passiert ja doch ein permanentes schreiben Rtg. Alexa. ich bin nicht sicher ob das nicht zu viel traffic dort führt und die uns das irgendwann übel nehmen ;-)
                        HeimwehH mcBirneM 2 Antworten Letzte Antwort
                          @heimweh
                          HeimwehH Offline
                          HeimwehH Offline
                          Heimweh
                          #157
                          @aruttkamp bei mir ist das nicht so. Hast Du den Bring Teil in meinen Script reingebastelt? Was ich mir gerade noch überlege - der Listen Teil soll ja wieder funktionieren (s.o.) - hat es damit evtl zu tun?
                            @heimweh
                            mcBirneM Offline
                            mcBirneM Offline
                            mcBirne
                            #158
                            @aruttkamp
                            Bei mir funktioniert es seit heute nicht mehr. Allerdings werden auch keine Alexa IOT Befehle erkannt oder die Alexa Summary aktualisiert. Auch Ankündigungen sind nicht mehr möglich. Hat das noch jemand? Hat Amazon da ein Problem?
                            HeimwehH aruttkampA 2 Antworten Letzte Antwort
                            • mcBirneM mcBirne
                              @aruttkamp
                              HeimwehH Offline
                              HeimwehH Offline
                              Heimweh
                              #159
                              @mcbirne ist bei mir auch so. bzw. IOT Geräte lassen sich steuern aber summary und die Listen gehen nicht mehr
                              • mcBirneM mcBirne
                                @aruttkamp
                                aruttkampA Offline
                                aruttkampA Offline
                                aruttkamp
                                #160
                                @Heimweh
                                Nein. Dein Scrikt ist das von hier - 1:1 kopiert und nur oben im Kopf die entspr. ID´s geändert
                                  @Heimweh
                                  HeimwehH Offline
                                  HeimwehH Offline
                                  Heimweh
                                  #161
                                  @aruttkamp ich habe gar kein Bring sondern Todoist. Hoffe Du hast jetzt nichts gemischt. Der Todoist Script mit viel weniger Logeinträgen wäre der hier (bitte selber testen - hab leider keine Zeit gefunden):
                                  const axios = require('axios');
                                  // Konfiguration
                                  const todoistShoppingListId = 'XXXXXXXXXXX'; // <- Deine Projekt-ID
                                  const todoistToken = 'XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX'; // <- Dein API-Token
                                  on({ id: 'alexa2.0.History.summary', change: 'any' }, function (obj) {
                                      const inputRaw = obj.state.val;
                                      if (typeof inputRaw !== 'string') {
                                          console.warn('[ToDoist] ⚠️ Kein String erkannt in alexa2.0.History.summary:', inputRaw);
                                          return;
                                      const input = inputRaw.trim();
                                      const match = input.match(/^setze (.+) auf (?:meine|die) (einkaufsliste|todo[\s-]?liste)/i);
                                      if (match && match.length >= 3) {
                                          const rohAufgabe = match[1];
                                          const ziel = match[2].replace(/\s|-/g, '').toLowerCase();
                                          const mitZiffern = wordsToNumbersSmart(rohAufgabe);
                                          const aufgabe = capitalizeFirst(mitZiffern);
                                          let projektId = null;
                                          if (ziel === 'einkaufsliste') {
                                              projektId = todoistShoppingListId;
                                          console.log(`[ToDoist] 🧠 Alexa erkannt → "${aufgabe}" für Projekt: ${ziel}`);
                                          addTaskToTodoist(aufgabe, projektId);
                                  function addTaskToTodoist(text, projectId = null) {
                                      const todoistData = { content: text };
                                      if (projectId) todoistData.project_id = projectId;
                                      axios.post('https://api.todoist.com/rest/v2/tasks', todoistData, {
                                          headers: {
                                              'Content-Type': 'application/json',
                                              'Authorization': `Bearer ${todoistToken}`
                                      .then(() => {
                                          console.log(`[ToDoist] ✅ Aufgabe "${text}" erfolgreich zu Todoist hinzugefügt.`);
                                      .catch(error => {
                                          console.error('[ToDoist] ❌ Fehler beim Hinzufügen zu Todoist:', error.message || error.response?.data || error);
                                  function capitalizeFirst(text) {
                                      if (!text || typeof text !== 'string') return '';
                                      return text.charAt(0).toUpperCase() + text.slice(1);
                                  function wordsToNumbersSmart(text) {
                                      const ones = {
                                          'null': 0, 'eins': 1, 'eine': 1, 'einen': 1,
                                          'zwei': 2, 'drei': 3, 'vier': 4, 'fünf': 5,
                                          'sechs': 6, 'sieben': 7, 'acht': 8, 'neun': 9,
                                          'zehn': 10, 'elf': 11, 'zwölf': 12, 'dreizehn': 13,
                                          'vierzehn': 14, 'fünfzehn': 15, 'sechzehn': 16,
                                          'siebzehn': 17, 'achtzehn': 18, 'neunzehn': 19
                                      const tens = {
                                          'zwanzig': 20, 'dreißig': 30, 'vierzig': 40,
                                          'fünfzig': 50, 'sechzig': 60, 'siebzig': 70,
                                          'achtzig': 80, 'neunzig': 90
                                      const multipliers = {
                                          'hundert': 100,
                                          'tausend': 1000
                                      const skipWords = ['und', 'oder', 'mit', 'für', 'pro'];
                                      const words = text.toLowerCase().split(/\s+/);
                                      const finalText = [];
                                      let i = 0;
                                      let capitalizeNext = 0;
                                      while (i < words.length) {
                                          const word = words[i];
                                          if (ones[word] !== undefined) {
                                              if (i + 2 < words.length && words[i + 1] === 'und' && tens[words[i + 2]]) {
                                                  const value = ones[word] + tens[words[i + 2]];
                                                  finalText.push(value.toString());
                                                  capitalizeNext = 2;
                                                  i += 3;
                                                  continue;
                                              if (i + 1 < words.length && multipliers[words[i + 1]]) {
                                                  const value = ones[word] * multipliers[words[i + 1]];
                                                  capitalizeNext = 2;
                                                  i += 2;
                                                  continue;
                                              finalText.push(ones[word].toString());
                                              capitalizeNext = 2;
                                              i++;
                                          } else if (tens[word] !== undefined) {
                                              finalText.push(tens[word].toString());
                                              capitalizeNext = 2;
                                              i++;
                                          } else if (!isNaN(word)) {
                                              finalText.push(word);
                                              capitalizeNext = 2;
                                              i++;
                                          } else {
                                              if (capitalizeNext > 0 && !skipWords.includes(word)) {
                                                  finalText.push(word.charAt(0).toUpperCase() + word.slice(1));
                                                  capitalizeNext--;
                                              } else {
                                              i++;
                                      return finalText.join(' ');
                                  • M martin_olw
                                    Danke!
                                    VG Martin
                                    HeimwehH Offline
                                    HeimwehH Offline
                                    Heimweh
                                    #162
                                    @martin_olw sorry das ich mir so lange Zeit gelassen habe. Wenn ich das jetzt richtig gesehen habe - funktioniert mit der neuen Adapter Version der Datenpunkt alexa2.0.Lists.SHOP.json wieder - dann wäre ja alles wieder beim alten und mein erster Script den ich zum Thema Todoist reingestellt habe, müsste wieder funktionieren wie "früher" - ich hab jetzt den Script von damals nochmal korrigiert (er hat auf eine Testliste verwiesen) aber nicht getestet (mir fehlt die Zeit)
                                    // Todoist API-Konfiguration
                                    const todoistProjectId = '12345678'; // Todoist-Projekt-ID
                                    const todoistToken = 'xXxXxXxXxXxXxXxXxXxXxXxX'; // Todoist-API-Token
                                    let previousList = [];
                                    // 1. Überwachen der Änderungen in der Alexa-Liste
                                    on({ id: 'alexa2.0.Lists.SHOP.json', change: 'any' }, function (obj) {
                                        try {
                                            console.log('Änderung in der Alexa Liste erkannt.');
                                            // Alexa-Liste als JSON parsen
                                            const currentList = JSON.parse(obj.state.val);
                                            console.log('Alexa-Liste erfolgreich geparst.');
                                            if (currentList && currentList.length > 0) {
                                                console.log(`Alexa-Liste enthält ${currentList.length} Einträge.`);
                                                // Neues Item zur Todoist-Liste hinzufügen, wenn die Liste gewachsen ist
                                                if (previousList.length < currentList.length) {
                                                    const newItem = currentList.find(item => !previousList.some(prevItem => prevItem.id === item.id));
                                                    if (newItem) {
                                                        console.log(`Neues Item erkannt: "${newItem.value}" mit ID: ${newItem.id}`);
                                                        addTaskToTodoist(newItem.value);
                                                // Aktualisiere die vorherige Liste
                                                previousList = currentList;
                                            } else {
                                                console.log('Alexa-Liste ist leer oder nicht verfügbar.');
                                        } catch (e) {
                                            console.error('Fehler beim Parsen der Alexa-Liste:', e.message || e);
                                    // 2. Periodische Synchronisierung mit Todoist (alle 1 Minute)
                                    schedule('*/1 * * * *', function () {
                                        console.log("Todoist-Aufgaben werden abgefragt...");
                                        // Abrufen der aktiven Todoist-Aufgaben
                                        axios.get(`https://api.todoist.com/rest/v2/tasks`, {
                                            headers: {
                                        .then(response => {
                                            const activeTasks = response.data.map(task => task.content); // Extrahiere die Inhalte der aktiven Aufgaben
                                            console.log('Aktive Todoist-Aufgaben erfolgreich abgerufen.');
                                            // Vergleich der aktiven Todoist-Aufgaben mit der Alexa-Liste
                                            syncAlexaWithTodoist(activeTasks);
                                        .catch(error => {
                                            console.error('Fehler beim Abrufen der Todoist-Aufgaben:', error.message || error.response.data);
                                    // 3. Hilfsfunktion zum Hinzufügen von Aufgaben zu Todoist
                                    function addTaskToTodoist(itemValue) {
                                            content: itemValue,
                                            project_id: todoistProjectId
                                            headers: {
                                        .then(response => {
                                            console.log(`Item "${itemValue}" erfolgreich zu Todoist hinzugefügt.`);
                                        .catch(error => {
                                            console.error('Fehler beim Hinzufügen zu Todoist:', error.message || error);
                                    // 4. Hilfsfunktion zur Synchronisierung der Alexa-Liste mit Todoist
                                    function syncAlexaWithTodoist(activeTasks) {
                                        const alexaList = JSON.parse(getState('alexa2.0.Lists.SHOP.json').val);
                                        alexaList.forEach(item => {
                                            if (!activeTasks.includes(item.value)) {
                                                // Markiere das Item in Alexa als "completed", wenn es nicht mehr in Todoist aktiv ist
                                                const completeState = `alexa2.0.Lists.SHOP.items.${item.id}.completed`;
                                                setState(completeState, true, function(err) {
                                                    if (err) {
                                                        console.error(`Fehler beim Setzen von "completed" für "${item.value}" in Alexa:`, err.message || err);
                                                    } else {
                                                        console.log(`Item "${item.value}" in Alexa erfolgreich als "completed" markiert.`);
                                    • M martin_olw
                                      Danke!
                                      VG Martin
                                      HeimwehH Offline
                                      HeimwehH Offline
                                      Heimweh
                                      #163
                                      @martin_olw Ich hab es jetzt doch getestet und noch was geändert:
                                      Hier die Beschreibung:
                                      Der Skript überwacht den Datenpunkt alexa2.0.Lists.SHOP.json.
                                      Sobald Alexa z. B. sagt:
                                      „Alexa, setze vier Äpfel auf die Einkaufsliste“
                                      wird das als neuer Eintrag in dieser Liste erkannt.
                                      Zahlwort-Umwandlung:
                                      Aus „vier Äpfel“ wird „4 Äpfel“.
                                      Auch zusammengesetzte Zahlen wie „fünfzehn“ oder „dreiundzwanzig“ werden korrekt erkannt.
                                      Das erste Wort nach der Zahl wird großgeschrieben: z. B. „4 Äpfel“ statt „4 äpfel“.
                                      Todoist-Eintrag:
                                      Der bereinigte und umgewandelte Eintrag wird direkt über die REST-API an Todoist gesendet und dort im definierten Projekt als Aufgabe eingetragen.
                                      Automatisches Entfernen in Alexa:
                                      Nach 60 Sekunden wird der passende Alexa-Listeneintrag automatisch als „abgehakt“ markiert.
                                      Es muss nur die ListID und der Token eingesetzt werden.
                                      const todoistProjectId = 'XXXXXXXX'; // Deine Projekt-ID
                                      const todoistToken = 'XXXXXXXXXXXXXXXXXXXXXXX'; // Dein Token
                                      // 1. Alexa-Änderungen überwachen
                                          try {
                                                      if (newItem) {
                                                          const umgewandelt = wordsToNumbersSmart(newItem.value);
                                                          const aufgabe = capitalizeFirst(umgewandelt);
                                                          addTaskToTodoist(aufgabe);
                                                          // Nach 60 Sekunden Alexa-Eintrag auf "completed" setzen
                                                          setTimeout(() => {
                                                              const matchingItem = alexaList.find(item => {
        const itemText = wordsToNumbersSmart(item.value).trim().toLowerCase();
        return itemText === aufgabe.trim().toLowerCase();
                                                              if (matchingItem) {
        const completeState = `alexa2.0.Lists.SHOP.items.${matchingItem.id}.completed`;
        setState(completeState, true);
                                                              } else {
        console.warn(`⚠️ Kein passender Alexa-Eintrag zu "${aufgabe}" gefunden.`);
                                                          }, 60 * 1000); // 60 Sekunden
                                          } catch (e) {
                                      // 2. Aufgaben an Todoist senden
                                              content: itemValue,
                                              headers: {
                                          .then(() => {
                                              console.log(`✅ "${itemValue}" zu Todoist hinzugefügt.`);
                                          .catch(error => {
                                      // 3. Erstes Wort groß
                                      // 4. Wörter → Zahlen (z. B. „vierzehn“ → 14)
                                          const ones = {
                                          const tens = {
                                              'hundert': 100,
                                              'tausend': 1000
                                          let i = 0;
                                                      capitalizeNext = 2;
                                                      i += 3;
                                                      continue;
                                                      capitalizeNext = 2;
                                                      i += 2;
                                                      continue;
                                                  capitalizeNext = 2;
                                                  i++;
                                                  capitalizeNext = 2;
                                                  i++;
                                                  capitalizeNext = 2;
                                                  i++;
                                              } else {
                                                      capitalizeNext--;
                                                  } else {
                                                  i++;
                                      N M 2 Antworten Letzte Antwort
                                      • HeimwehH Heimweh
                                        Todoist-Eintrag:
                                            try {
                                                        if (newItem) {
                                                            setTimeout(() => {
        if (matchingItem) {
        } else {
                                            } catch (e) {
                                                content: itemValue,
                                                headers: {
                                            .then(() => {
                                            .catch(error => {
                                            const ones = {
                                            const tens = {
                                                'hundert': 100,
                                                'tausend': 1000
                                            let i = 0;
                                                        capitalizeNext = 2;
                                                        i += 3;
                                                        continue;
                                                        capitalizeNext = 2;
                                                        i += 2;
                                                        continue;
                                                    capitalizeNext = 2;
                                                    i++;
                                                    capitalizeNext = 2;
                                                    i++;
                                                    capitalizeNext = 2;
                                                    i++;
                                                } else {
                                                        capitalizeNext--;
                                                    } else {
                                                    i++;
                                        N Offline
                                        N Offline
                                        no6mis
                                        #164
                                        @heimweh, danke für das Script, endlich kann man die Einkaufsliste in Alexa wieder benutzen.
                                        sollte allerdings außerhalb des if-Zweigs gesetzt werden, ansonsten gibt es ein Problem, wenn man die Liste in der Alexa-App leert. Dann wird beim nächsten Aufruf die previousList mehr Inhalte haben als die currentList und die folgenden Einträge bis zum Neustart des Scripts oder bis die aktuelle Liste wieder einen Eintrag mehr hat als die vorherige Liste nicht mehr hinzugefügt.
                                        • daniel.driessenD daniel.driessen
                                          da mich die Änderung seitens Amazon auch nervt habe ich auch mal auf die schnelle ein kleines TypeScript zusammengebastelt.
                                          Es ist mit Sicherheit noch nicht perfekt, aber ein Anfang. Da ich es gerade erst fertig gestellt habe, hatte ich auch noch nicht die Möglichkeit und Zeit es ausgiebig zu testen.
                                          Gerne stelle ich es aber hier allen Interessierten zur Verfügung.
                                          Zusätzliche Info:
                                          Der Code-Dokumentationsblock am Anfang des Scripts gibt eine genauere Beschreibung des Scripts.
                                          Nachdem Ihr den Inhalt der Textdatei in ein neues TypeScript kopiert habt, sollte es denke ich reichen die 5 Werte im Code-Block "SCRIPT SETUP" anzupassen.
                                          JavaScript und TypeScript sind recht neu für mich und mit Sicherheit habe ich auch ungewollt das eine oder andere potentielle Problem ins Script eingebaut.
                                          Ihr dürft mir natürlich gerne feedback geben.
                                          P.S. Ich habe gerade erst gesehen das @icastillo15 ebenfalls etwas gebastelt hat. Hätte ich mal erst hier gelesen, dann hätte ich mir meine Arbeit vielleicht sparen können.
                                          😆 Ich werde sein Script auf jeden Fall in den nächsten Tagen ebenfalls mal testen.
                                          Vielleicht kann ich ja was lernen.
                                          Daniel
                                          Script-File:
                                          Shopping-List Sync.txt
                                          elron
                                          #165
                                          Damit das hinterlegt Script Stand 11/2025 wieder funktioniert, muss hier die Alexa Object-ID geändert werden
                                          von
                                          /*---------- OBJECT-ID CONSTANTS ------------------------------------------------------------------------------------------------*/
                                          const objectID_alexa_shoppingList_folder = 'alexa2.0.Lists.SHOPPING_LIST';
                                          const objectID_alexa_shoppingList_addItem = 'alexa2.0.Lists.SHOPPING_LIST.#New';
                                          auf
                                          const objectID_alexa_shoppingList_folder = 'alexa2.0.Lists.SHOP';
                                          const objectID_alexa_shoppingList_addItem = 'alexa2.0.Lists.SHOP.#New';
                                          Andernfalls erhält man die 2 Fehler
                                          script.js.Bring-Alexa-Sync: Cannot read properties of undefined (reading 'val') und script.js.Bring-Alexa-Sync: TypeError: Cannot read properties of undefined (reading 'stopScriptAsync')
