Test Adapter NSPanel-lovelace-ui v1.x.x
Zeig mir mal das log nach dem du das Skript gesendet hast, und bevor du den Adapter neustartest - das sieht z.B. so aus:
2025-08-12 22:08:59.059 - info: javascript.0 (174514) script.js.nspanel-lovelace-ui_0.NSPanel_Flur: Compiling TypeScript source 2025-08-12 22:08:59.127 - info: javascript.0 (174514) script.js.nspanel-lovelace-ui_0.NSPanel_Flur: source code did not change, using cached compilation result... 2025-08-12 22:08:59.138 - info: javascript.0 (174514) script.js.nspanel-lovelace-ui_0.NSPanel_Flur: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions 2025-08-12 22:08:59.141 - info: nspanel-lovelace-ui.0 (174592) [config-manager] Start converting configuration for nspanel/ns_panel1 2025-08-12 22:08:59.461 - info: javascript.0 (174514) script.js.nspanel-lovelace-ui_0.NSPanel_Flur: Stopping script 2025-08-12 22:09:00.351 - warn: nspanel-lovelace-ui.0 (174592) [config-manager] Page: WindowGrid dont have any navigation! Node 'main' provisionally added as home! 2025-08-12 22:09:00.383 - info: javascript.0 (174514) script.js.nspanel-lovelace-ui_0.NSPanel_Flur: [ 'Panel for Topic: nspanel/ns_panel1 Script version 0.8.8 is correct!', "Page: WindowGrid dont have any navigation! Node 'main' provisionally added as home!", 'done' ]Ich bin zu faul windowGrid zu reparieren :D
@ticaki Sorry mein Log ist auf dem Kopf..
javascript.0 2025-08-12 22:10:52.215 info script.js.nspanel-lovelace-ui_0.NSPanel_Buero: [ 'Panel for Topic: NSPanel/NSPanel_Buero Script version 0.9.0 is correct!', 'done'] javascript.0 2025-08-12 22:10:50.960 info script.js.nspanel-lovelace-ui_0.NSPanel_Buero: Stopping script nspanel-lovelace-ui.0 2025-08-12 22:10:49.932 info [config-manager] Start converting configuration for NSPanel/NSPanel_Buero javascript.0 2025-08-12 22:10:49.929 info script.js.nspanel-lovelace-ui_0.NSPanel_Buero: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions javascript.0 2025-08-12 22:10:49.924 info script.js.nspanel-lovelace-ui_0.NSPanel_Buero: source code did not change, using cached compilation result... javascript.0 2025-08-12 22:10:49.887 info script.js.nspanel-lovelace-ui_0.NSPanel_Buero: Compiling TypeScript source -
javascript.0 2025-08-12 22:10:52.215 info script.js.nspanel-lovelace-ui_0.NSPanel_Buero: [ 'Panel for Topic: NSPanel/NSPanel_Buero Script version 0.9.0 is correct!', 'done'] javascript.0 2025-08-12 22:10:50.960 info script.js.nspanel-lovelace-ui_0.NSPanel_Buero: Stopping script nspanel-lovelace-ui.0 2025-08-12 22:10:49.932 info [config-manager] Start converting configuration for NSPanel/NSPanel_Buero javascript.0 2025-08-12 22:10:49.929 info script.js.nspanel-lovelace-ui_0.NSPanel_Buero: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions javascript.0 2025-08-12 22:10:49.924 info script.js.nspanel-lovelace-ui_0.NSPanel_Buero: source code did not change, using cached compilation result... javascript.0 2025-08-12 22:10:49.887 info script.js.nspanel-lovelace-ui_0.NSPanel_Buero: Compiling TypeScript source@patricknitsch
Topics sind unterschiedlichStart converting configuration for NSPanel/NSPanel_Buero No script config found for tasmota/NSPanel_Buero -
javascript.0 2025-08-12 22:10:52.215 info script.js.nspanel-lovelace-ui_0.NSPanel_Buero: [ 'Panel for Topic: NSPanel/NSPanel_Buero Script version 0.9.0 is correct!', 'done'] javascript.0 2025-08-12 22:10:50.960 info script.js.nspanel-lovelace-ui_0.NSPanel_Buero: Stopping script nspanel-lovelace-ui.0 2025-08-12 22:10:49.932 info [config-manager] Start converting configuration for NSPanel/NSPanel_Buero javascript.0 2025-08-12 22:10:49.929 info script.js.nspanel-lovelace-ui_0.NSPanel_Buero: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions javascript.0 2025-08-12 22:10:49.924 info script.js.nspanel-lovelace-ui_0.NSPanel_Buero: source code did not change, using cached compilation result... javascript.0 2025-08-12 22:10:49.887 info script.js.nspanel-lovelace-ui_0.NSPanel_Buero: Compiling TypeScript source@patricknitsch sagte in Betatest NSPanel-lovelace-ui v0.2.x:
Ich gehe immer auf log herunterladen und kopiere dann, ist viel leichter auszuwählen - bin halt faul :D
@patricknitsch
Topics sind unterschiedlichStart converting configuration for NSPanel/NSPanel_Buero No script config found for tasmota/NSPanel_Buero@ticaki Das darfst keinem erzählen... Ändere die Struktur und vergesse, die Topics im Script anzupassen. Im Adapter hab ichs noch geschafft. Jetzt gehts natürlich.
Danke für die Hilfe.
PS: Warum soll es gleich faul sein, wenn man mit weniger Aufwand zum selben Ziel kommt?
War scherzhaft gemeint - aber
das es jetzt läuft -
Das kann (und sollte) man umstellen. Geht mit dem blauen Pfeil (Ausgaberichtung umkehren).
Besser ist es allerdings noch direkt auf das Log zuzugreifen.
Mitiob logsz. B.
TT-Tom hat den Bug behoben - als ich das geschrieben habe gab es noch keinen Datenpunkt
windDirectionText:) -
@ticaki said in Betatest NSPanel-lovelace-ui v0.2.x:
TT-Tom hat den Bug behoben - als ich das geschrieben habe gab es noch keinen Datenpunkt windDirectionText
Ist das dann in der kommenden Version mit drin oder wie kommt man da ran..?
@teletapi
Da der Adapter noch in keinem repo ist, kann man zwar auf Versionen warten - oder man läd die aktuelle Version von github per benutzerdefinierte Installation.Die Versionsnummer ist dann halt noch die alte, der code ist jedoch aktuell.
@ticaki
Ja aber erst wenn wir das okay geben. Da können auch Testvarianten liegen, die ggf. Fehler verursachen können.IMHO habe die nix in der mainbranch verloren.
EDIT: Bissle ausführlicher - wenn wir leute darum bitten einen Adapter über github zu installieren und die personen das tun, können wir nicht kontrollieren, wann sie das tun. Heißt die mainbranch muß immer funktionieren. Ja klar die funktioniert manchmal nicht, aber ob du ich oder ein user das als erster rausfindet ist unerheblich, die sollen ja mittesten :D
bitte um Starthilfe.
Das Script ist installiert und läuft.Desired TFT Firmware: 58 / v4.9.4 javascript.0 18:52:37.817 info Installed TFT Firmware: 58 / v4.9.4 javascript.0 18:57:09.535 info Stopping script script.js.nspanel-lovelace-ui_0.NSPanel_1 javascript.0 18:58:54.092 info Compiling TypeScript source script.js.nspanel-lovelace-ui_0.NSPanel_1 javascript.0 18:58:54.554 info source code did not change, using cached compilation result... javascript.0 18:58:54.659 info --- start of NsPanelTs: 0_userdata.0.NSPanel. --- javascript.0 18:58:54.680 info setObjects enabled - create Alias Channels possible javascript.0 18:58:54.685 info weather alias for openweathermap.0. already exists javascript.0 18:58:54.696 info registered 41 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions javascript.0 18:58:54.701 info No Updates for NSPanel available javascript.0 18:58:54.861 info Desired TFT Firmware: 58 / v4.9.4 javascript.0 18:58:54.861 info Installed TFT Firmware: 58 / v4.9.4 javascript.0 18:58:54.977 info Debug mode disabled javascript.0 18:58:56.163 info hidden Cards disabled javascript.0 18:58:56.253 info Desired TFT Firmware: 58 / v4.9.4 javascript.0 18:58:56.253 info Installed TFT Firmware: 58 / v4.9.4 javascript.0 18:58:57.539 info Start MQTT-Port-Check ------------------------------------- javascript.0 18:58:57.539 info -- admin.0 - 8081 javascript.0 18:58:57.539 info -- hm-rpc.0 - 0 javascript.0 18:58:57.539 info -- hm-rpc.1 - 8701 javascript.0 18:58:57.539 info -- influxdb.0 - 8086 javascript.0 18:58:57.539 info -- influxdb.1 - 8086 javascript.0 18:58:57.539 info -- mqtt.0 - 1883 javascript.0 18:58:57.539 info -- mqtt.3 - 1883 javascript.0 18:58:57.539 info -- mqtt.4 - 1886 javascript.0 18:58:57.539 info -- proxmox.0 - 8006 javascript.0 18:58:57.539 info -- shelly.0 - 1883 javascript.0 18:58:57.539 info -- shelly.1 - 1882 javascript.0 18:58:57.540 info -- simple-api.0 - 8087 javascript.0 18:58:57.540 info -- sonoff.0 - 1885 javascript.0 18:58:57.540 info -- sun2000.0 - 502 javascript.0 18:58:57.540 info -- telegram.0 - 8443 javascript.0 18:58:57.540 info -- web.0 - 8082 javascript.0 18:58:57.540 info -- zigbee.1 - /dev javascript.0 18:58:57.540 info - MQTT-Port-Check OK: Instance of Adapter: mqtt.4 is running on Port:1886 javascript.0 18:58:57.540 info End MQTT-Port-Check ----------Der Apapter startet nicht, Fehler: No compatible config found, paused!
Hier die Einstellungen:
Log:
nspanel-lovelace-ui.0 2025-08-13 19:15:32.584 debug {"command":"refreshMaintainTable","message":{"internalServerIp":"192.168.178.4"},"from":"system.adapter.admin.0","callback":{"message":{"internalServerIp":"192.168.178.4"},"id":236,"ack":false,"time":1755105332581},"_id":22998830} nspanel-lovelace-ui.0 2025-08-13 19:14:56.356 debug {"command":"getTimeZones","message":{"ip":"192.168.178.4"},"from":"system.adapter.admin.0","callback":{"message":{"ip":"192.168.178.4"},"id":235,"ack":false,"time":1755105296355},"_id":22998829} nspanel-lovelace-ui.0 2025-08-13 19:14:56.284 debug {"command":"getTasmotaDevices","message":{"ip":"192.168.178.4"},"from":"system.adapter.admin.0","callback":{"message":{"ip":"192.168.178.4"},"id":234,"ack":false,"time":1755105296281},"_id":22998828} nspanel-lovelace-ui.0 2025-08-13 19:00:28.147 error No compatible config found, paused! nspanel-lovelace-ui.0 2025-08-13 19:00:28.106 info starting. Version 0.2.4 (non-npm: ticaki/ioBroker.nspanel-lovelace-ui#955fb48e830b9ffc2f648d9d50adbbde0e5318ba) in /opt/iobroker/node_modules/iobroker.nspanel-lovelace-ui, node: v20.19.4, js-controller: 7.0.6 nspanel-lovelace-ui.0 2025-08-13 19:00:27.873 debug States connected to redis: 0.0.0.0:9000 nspanel-lovelace-ui.0 2025-08-13 19:00:27.771 debug States create User PubSub Client nspanel-lovelace-ui.0 2025-08-13 19:00:27.771 debug States create System PubSub Client nspanel-lovelace-ui.0 2025-08-13 19:00:27.741 debug Redis States: Use Redis connection: 0.0.0.0:9000 nspanel-lovelace-ui.0 2025-08-13 19:00:27.683 debug Objects connected to redis: 0.0.0.0:9001 nspanel-lovelace-ui.0 2025-08-13 19:00:27.678 debug Objects client initialize lua scripts nspanel-lovelace-ui.0 2025-08-13 19:00:27.578 debug Objects create User PubSub Client nspanel-lovelace-ui.0 2025-08-13 19:00:27.578 debug Objects create System PubSub Client nspanel-lovelace-ui.0 2025-08-13 19:00:27.577 debug Objects client ready ... initialize now nspanel-lovelace-ui.0 2025-08-13 19:00:27.534 debug Redis Objects: Use Redis connection: 0.0.0.0:9001 nspanel-lovelace-ui.0 2025-08-13 19:00:23.080 info terminating nspanel-lovelace-ui.0 2025-08-13 19:00:22.579 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason nspanel-lovelace-ui.0 2025-08-13 19:00:22.579 info terminating nspanel-lovelace-ui.0 2025-08-13 19:00:22.578 info Got terminate signal TERMINATE_YOURSELF nspanel-lovelace-ui.0 2025-08-13 18:59:52.362 debug {"command":"refreshMaintainTable","message":{"internalServerIp":"192.168.178.4"},"from":"system.adapter.admin.0","callback":{"message":{"internalServerIp":"192.168.178.4"},"id":232,"ack":false,"time":1755104392359},"_id":22998826}Bitte um Hilfe
Log:
Hast du dir die Hilfe zur Adapter Installation durchgelesen. Und diese schrittweise abgearbeitet.
Dann solltest du selber auf den Fehler kommen.
Du hast ein Schritt vergessen. Bitte lesen, damit du den Ablauf verstehst.
Wenn es dann immer noch nicht klappt, melde dich einfach noch mal.Edit: sehe grade das du auch ein falsches Script genommen hast. Also bitte lesen, der Link ins auf der General Seite oben.
@tt-tom
--Hm...??
Script habe ich dieses von hier: https://github.com/joBr99/nspanel-lovelace-ui/blob/main/ioBroker/DEV/NSPanelTs.tsHilfe zur Adapterinstallation mehrfach gelesen, ich finde den Fehler nicht.
Um ehrlich zu sein hast du so nicht richtig gelesen.
Das Script ist vom Parallel Projekt und hat mit dem Adapter nichts zu tun.
Hier wird genau gesagt welches Script du nutzen sollst.
Es wird vom Adapter angelegt. -
Es wird vom Adapter angelegt.Nabend, ich hab heute nach der Aufforderung zum testen des neuen Scriptes den Adapter aktualisiert danach stand dann unter Maintain das das neue script zur verfügung steht. Hab dann den Butten gedrückt und ein "OK" bekommen.
Leider ist der Fehler nach Neustart des scriptes und des Adapters immernoch vorhanden .
Die neue script Version wird aber geladenavascript.0 01:00:10.698 info Compiling TypeScript source javascript.0 01:00:10.758 info source code did not change, using cached compilation result... javascript.0 01:00:10.762 info registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions javascript.0 01:00:11.123 info Stopping script javascript.0 01:00:11.529 info [ 'Panel for Topic: SmartHome/NSPanel_Weiss Script version 0.9.1 is correct!', 'done'nspanel-lovelace-ui.0 2025-08-14 00:57:49.999 warn [StatesDB] Found more as 1 state for role in /^openweathermap\.0./ with .dp: openweathermap.0.forecast.current.windDirection and .regexp: /^openweathermap\.[0-9]+\.forecast\.current\.windDirection/ nspanel-lovelace-ui.0 2025-08-14 00:57:49.944 warn [StatesDB] Found more as 1 state for role in /^openweathermap\.0./ with .dp: openweathermap.0.forecast.current.windDirection and .regexp: /^openweathermap\.[0-9]+\.forecast\.current\.windDirection/ -
