  4. Test Adapter drops-weather 1.2.x
    6.7k
drops-weathermcm1957
196 Beiträge 21 Kommentatoren 44.3k Aufrufe 24 Beobachtet
  • sigi234S sigi234
    @mcm1957
    Hallo, Adapter startet immer Neu.
    drops-weather.0
    2025-06-04 06:38:26.651	info	starting. Version 1.2.3 in C:/SmartHome/node_modules/iobroker.drops-weather, node: v20.19.2, js-controller: 7.0.7
    host.SmartHome
    2025-06-04 06:38:23.782	info	instance system.adapter.drops-weather.0 in version "1.2.3" started with pid 12836
    host.SmartHome
    2025-06-04 06:37:52.606	info	Restart adapter system.adapter.drops-weather.0 because enabled
    host.SmartHome
    2025-06-04 06:37:52.605	info	instance system.adapter.drops-weather.0 terminated with code 0 (NO_ERROR)
    drops-weather.0
    2025-06-04 06:37:52.499	info	terminating
    drops-weather.0
    2025-06-04 06:37:52.022	info	Terminated (NO_ERROR): Without reason
    drops-weather.0
    2025-06-04 06:37:52.020	info	terminating
    drops-weather.0
    2025-06-04 06:37:51.981	warn	TimeoutError: Waiting failed: 60000ms exceeded
    web.0
    2025-06-04 06:37:19.850	info	==> Connected system.user.admin from ::1
    web.0
    2025-06-04 06:37:17.855	info	<== Disconnect system.user.admin from ::1
    drops-weather.0
    2025-06-04 06:36:49.710	info	starting. Version 1.2.3 in C:/SmartHome/node_modules/iobroker.drops-weather, node: v20.19.2, js-controller: 7.0.7
    host.SmartHome
    2025-06-04 06:36:48.312	info	instance system.adapter.drops-weather.0 in version "1.2.3" started with pid 8824
    host.SmartHome
    2025-06-04 06:36:17.771	info	Restart adapter system.adapter.drops-weather.0 because enabled
    host.SmartHome
    2025-06-04 06:36:17.770	info	instance system.adapter.drops-weather.0 terminated with code 0 (NO_ERROR)
    drops-weather.0
    2025-06-04 06:36:17.680	info	terminating
    drops-weather.0
    2025-06-04 06:36:17.182	info	Terminated (NO_ERROR): Without reason
    drops-weather.0
    2025-06-04 06:36:17.181	info	terminating
    drops-weather.0
    2025-06-04 06:36:17.159	warn	TimeoutError: Waiting failed: 60000ms exceeded
    DEBUG:
    host.SmartHome
    2025-06-04 06:45:14.982	info	Restart adapter system.adapter.drops-weather.0 because enabled
    host.SmartHome
    2025-06-04 06:45:14.981	info	instance system.adapter.drops-weather.0 terminated with code 0 (NO_ERROR)
    drops-weather.0
    2025-06-04 06:45:14.364	debug	pages 2
    drops-weather.0
    2025-06-04 06:45:14.359	info	Terminated (NO_ERROR): Without reason
    drops-weather.0
    2025-06-04 06:45:14.358	info	terminating
    drops-weather.0
    2025-06-04 06:45:14.352	debug	destroy browser
    drops-weather.0
    2025-06-04 06:45:14.351	warn	TimeoutError: Waiting failed: 60000ms exceeded
    drops-weather.0
    2025-06-04 06:44:12.949	debug	creating new page ...
    drops-weather.0
    2025-06-04 06:44:12.948	debug	Reading data from : https://www.niederschlagsradar.de/de/city/XXXXXXX
    drops-weather.0
    2025-06-04 06:44:12.440	debug	puppeteer.lauch invoked with {"headless":true,"defaultViewport":null,"userDataDir":"/dev/null","args":["--periodic-task","--no-sandbox","--disable-setuid-sandbox","--disable-dev-shm-usage","--disable-accelerated-2d-canvas","--no-first-run","--no-zygote","--single-process","--disable-gpu","--ignore-certificate-errors","--disable-extensions","--disable-component-extensions-with-background-pages","--disable-default-apps","--mute-audio","--no-default-browser-check","--autoplay-policy=user-gesture-required","--disable-background-timer-throttling","--disable-backgrounding-occluded-windows","--disable-notifications","--disable-background-networking","--disable-breakpad","--disable-component-update","--disable-domain-reliability","--disable-sync"]}
    drops-weather.0
    2025-06-04 06:44:12.439	debug	browserPath set to puppeteer default
    drops-weather.0
    2025-06-04 06:44:12.438	debug	browserMode set to automatic, running on win32 / x64
    drops-weather.0
    2025-06-04 06:44:12.430	info	starting. Version 1.2.3 in C:/SmartHome/node_modules/iobroker.drops-weather, node: v20.19.2, js-controller: 7.0.7
    drops-weather.0
    2025-06-04 06:44:12.327	debug	States connected to redis: 127.0.0.1:9010
    drops-weather.0
    2025-06-04 06:44:12.292	debug	States create User PubSub Client
    drops-weather.0
    2025-06-04 06:44:12.292	debug	States create System PubSub Client
    drops-weather.0
    2025-06-04 06:44:12.274	debug	Redis States: Use Redis connection: 127.0.0.1:9010
    drops-weather.0
    2025-06-04 06:44:12.239	debug	Objects connected to redis: 127.0.0.1:9011
    drops-weather.0
    2025-06-04 06:44:12.236	debug	Objects client initialize lua scripts
    drops-weather.0
    2025-06-04 06:44:12.173	debug	Objects create User PubSub Client
    drops-weather.0
    2025-06-04 06:44:12.172	debug	Objects create System PubSub Client
    drops-weather.0
    2025-06-04 06:44:12.171	debug	Objects client ready ... initialize now
    drops-weather.0
    2025-06-04 06:44:12.142	debug	Redis Objects: Use Redis connection: 127.0.0.1:9011
    host.SmartHome
    2025-06-04 06:44:10.797	info	instance system.adapter.drops-weather.0 in version "1.2.3" started with pid 10236
    host.SmartHome
    2025-06-04 06:44:07.518	info	instance system.adapter.drops-weather.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    drops-weather.0
    2025-06-04 06:44:07.430	info	terminating
    drops-weather.0
    2025-06-04 06:44:06.984	warn	TargetCloseError: Protocol error (Runtime.callFunctionOn): Target closed
    mcm1957M Online
    mcm1957M Online
    mcm1957
    #145
    @sigi234 said in Test Adapter drops-weather 1.2.x:
    @mcm1957
    Der Adapter ist ein scheduled Adapter. Er startet alle 5 Minuten und beendet sich dann wieder. Dies ist normal.
    Timeouts beim Zugriff auf die Webseite soind bekannt. Leider konnte bisher noch keine klare Ursache und damit auch keine Lösung gefunden werden.
    DANKE jedenfalls für dein Feedback.
    Support Repositoryverwaltung.
    LESEN - gute Forenbeitrage
    • sigi234S sigi234
      @thomas-braun sagte in Test Adapter drops-weather 1.2.x:
      @sigi234 sagte in Test Adapter drops-weather 1.2.x:
      Lass mich raten: Genau alle 5 Minuten?
      Nein, jede Minute!
      Und:
      drops-weather.0
      2025-06-04 08:33:10.166	warn	TimeoutError: Waiting failed: 60000ms exceeded
      Das ist so gewollt, das ist ein scheduled adapter.
      Sollte hier nicht ein Chron Icon sein?
      mcm1957M Online
      mcm1957M Online
      mcm1957
      #146
      @sigi234
      Ev. DEINSTALLIERE den Adapetr und installier ihn nochmal neu. Der Adapter war in früheren Versionen ein Daemon. Kann sein, dass es da Probleme mit der Umstellung gibt. Einstellungen natürlich vorher notieren.
      • mcm1957M mcm1957
        @mcm1957
        sigi234S Online
        sigi234S Online
        #147
        @mcm1957 sagte in Test Adapter drops-weather 1.2.x:
        Ja, das weis ich. Wird aber nicht als solche erkannt.
        Er startet nach wie vor jede Minute. Habe den Chron manuell auf 5 Minuten gesetzt. Keine Änderung.
        Upload gemacht, Browser Chache geleert , System neu gestartet.
        Werde ihn mal deinstallieren und neu installieren.
        mcm1957M M 2 Antworten Letzte Antwort
        • sigi234S sigi234
          mcm1957M Online
          mcm1957M Online
          mcm1957
          #148
          @sigi234
          Jep - hab ich eben vorgeschlagen. Ich vermute dass ioBroker / js-controlelr die Umstellung nicht mitbekommen hat.
          • mcm1957M mcm1957
            @sigi234
            sigi234S Online
            sigi234S Online
            #149
            @sigi234
            Schaut besser aus, läuft.
            Edit:
            Daten kommen erst denke ich mal.
            • WinniW Winni
              @marco-3 schau dir auch mal den Weatherunderground forecast Adapter an. Der hat da auch einiges zu bieten. Läuft bei mir unauffällig und zuverlässig.
              Marco 3
              #150
              @winni
              liefert Daten, leider nur im 1 Stunden Takt.
              Kann man das eventuell auf 5 min einstellen?
              WinniW 2 Antworten Letzte Antwort
              • M Marco 3
                @winni
                WinniW Offline
                WinniW Offline
                Winni
                #151
                @marco-3 zum Einstellen habe ich nichts gefunden. Ich habe mal die history aktiviert um zu sehen wie oft Daten kommen.
                • sigi234S sigi234
                  Marco 3
                  #152
                  @sigi234
                  jup, ich habe es deinstalliert und aus dem BETA Repositories installiert.
                  Normal gestartet...
                  Mal sehen wann der erste Datensatz da ist.
                  • M Marco 3
                    @winni
                    WinniW Offline
                    WinniW Offline
                    Winni
                    #153
                    @marco-3 hatte die history aktiviert und ja, die Daten kommen im ein Stunden Takt.
                    • sigi234S sigi234
                      @sigi234
                      Edit:
                      sigi234S Online
                      sigi234S Online
                      #154
                      Edit:
                      Bei mir kommen keine Daten.
                      • sigi234S sigi234
                        Edit:
                        mcm1957M Online
                        mcm1957M Online
                        mcm1957
                        #155
                        Bitte Logfile (Loglevel DEBUG) posten.
                        sigi234S NegaleinN 2 Antworten Letzte Antwort
                        • mcm1957M mcm1957
                          sigi234S Online
                          sigi234S Online
                          #156
                          EDIT
                          drops-weather.0
                          2025-06-04 17:29:25.233	debug	pages 2
                          drops-weather.0
                          2025-06-04 17:29:25.220	info	Terminated (NO_ERROR): Without reason
                          drops-weather.0
                          2025-06-04 17:29:25.198	debug	destroy browser
                          drops-weather.0
                          2025-06-04 17:29:25.195	warn	TimeoutError: Waiting failed: 60000ms exceeded
                          drops-weather.0
                          2025-06-04 17:28:22.955	debug	creating new page ...
                          drops-weather.0
                          2025-06-04 17:28:22.955	debug	Reading data from : https://www.niederschlagsradar.de/de/cityxxxxxxx
                          drops-weather.0
                          2025-06-04 17:28:22.406	debug	puppeteer.lauch invoked with {"headless":true,"defaultViewport":null,"userDataDir":"/dev/null","args":["--periodic-task","--no-sandbox","--disable-setuid-sandbox","--disable-dev-shm-usage","--disable-accelerated-2d-canvas","--no-first-run","--no-zygote","--single-process","--disable-gpu","--ignore-certificate-errors","--disable-extensions","--disable-component-extensions-with-background-pages","--disable-default-apps","--mute-audio","--no-default-browser-check","--autoplay-policy=user-gesture-required","--disable-background-timer-throttling","--disable-backgrounding-occluded-windows","--disable-notifications","--disable-background-networking","--disable-breakpad","--disable-component-update","--disable-domain-reliability","--disable-sync"]}
                          drops-weather.0
                          2025-06-04 17:28:22.405	debug	browserPath set to puppeteer default
                          drops-weather.0
                          2025-06-04 17:28:22.405	debug	browserMode set to automatic, running on win32 / x64
                          drops-weather.0
                          2025-06-04 17:28:22.395	info	starting. Version 1.2.3 in C:/SmartHome/node_modules/iobroker.drops-weather, node: v20.19.2, js-controller: 7.0.7
                          drops-weather.0
                          2025-06-04 17:28:22.295	debug	States connected to redis: 127.0.0.1:9010
                          drops-weather.0
                          2025-06-04 17:28:22.259	debug	States create User PubSub Client
                          drops-weather.0
                          2025-06-04 17:28:22.259	debug	States create System PubSub Client
                          drops-weather.0
                          2025-06-04 17:28:22.238	debug	Redis States: Use Redis connection: 127.0.0.1:9010
                          drops-weather.0
                          2025-06-04 17:28:22.200	debug	Objects connected to redis: 127.0.0.1:9011
                          drops-weather.0
                          2025-06-04 17:28:22.197	debug	Objects client initialize lua scripts
                          drops-weather.0
                          2025-06-04 17:28:22.129	debug	Objects create User PubSub Client
                          drops-weather.0
                          2025-06-04 17:28:22.128	debug	Objects create System PubSub Client
                          drops-weather.0
                          2025-06-04 17:28:22.127	debug	Objects client ready ... initialize now
                          drops-weather.0
                          2025-06-04 17:28:22.088	debug	Redis Objects: Use Redis connection: 127.0.0.1:9011
                          Edit2
                          • sigi234S sigi234
                            EDIT
                            drops-weather.0
                            drops-weather.0
                            drops-weather.0
                            drops-weather.0
                            drops-weather.0
                            drops-weather.0
                            drops-weather.0
                            drops-weather.0
                            drops-weather.0
                            drops-weather.0
                            drops-weather.0
                            drops-weather.0
                            drops-weather.0
                            drops-weather.0
                            drops-weather.0
                            drops-weather.0
                            drops-weather.0
                            drops-weather.0
                            drops-weather.0
                            drops-weather.0
                            Edit2
                            mcm1957M Online
                            mcm1957M Online
                            mcm1957
                            #157
                            @sigi234
                            check mal obhttps://www.niederschlagsradar.de/de/cityxxxxxxx im Browser funktioniert. Der Adapter bekommt ein timeout - damit auch keine Daten.
                            • mcm1957M mcm1957
                              NegaleinN Offline
                              NegaleinN Offline
                              Negalein
                              #158
                              @mcm1957
                              bei mir kommt auch nichts
                              drops-weather.0 2025-06-04 17:30:32.488	debug	creating new page ...
                              drops-weather.0 2025-06-04 17:30:32.487	debug	Reading data from : https://www.niederschlagsradar.de/de/city/3307725
                              drops-weather.0 2025-06-04 17:30:32.166	debug	puppeteer.lauch invoked with {"headless":true,"defaultViewport":null,"userDataDir":"/dev/null","args":["--periodic-task","--no-sandbox","--disable-setuid-sandbox","--disable-dev-shm-usage","--disable-accelerated-2d-canvas","--no-first-run","--no-zygote","--single-process","--disable-gpu","--ignore-certificate-errors","--disable-extensions","--disable-component-extensions-with-background-pages","--disable-default-apps","--mute-audio","--no-default-browser-check","--autoplay-policy=user-gesture-required","--disable-background-timer-throttling","--disable-backgrounding-occluded-windows","--disable-notifications","--disable-background-networking","--disable-breakpad","--disable-component-update","--disable-domain-reliability","--disable-sync"]}
                              drops-weather.0 2025-06-04 17:30:32.165	debug	browserPath set to puppeteer default
                              drops-weather.0 2025-06-04 17:30:32.165	debug	browserMode set to automatic, running on linux / x64
                              drops-weather.0 2025-06-04 17:30:32.148	info	starting. Version 1.2.3 (non-npm: iobroker-community-adapters/ioBroker.drops-weather) in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.1, js-controller: 7.0.6
                              drops-weather.0 2025-06-04 17:29:52.263	debug	pages 2
                              drops-weather.0 2025-06-04 17:29:52.258	info	Terminated (NO_ERROR): Without reason
                              drops-weather.0 2025-06-04 17:29:52.252	debug	destroy browser
                              drops-weather.0 2025-06-04 17:29:52.251	warn	TimeoutError: Waiting failed: 60000ms exceeded
                              drops-weather.0 2025-06-04 17:28:51.029	debug	creating new page ...
                              drops-weather.0 2025-06-04 17:28:51.029	debug	Reading data from : https://www.niederschlagsradar.de/de/city/3307725
                              drops-weather.0 2025-06-04 17:28:50.749	debug	puppeteer.lauch invoked with {"headless":true,"defaultViewport":null,"userDataDir":"/dev/null","args":["--periodic-task","--no-sandbox","--disable-setuid-sandbox","--disable-dev-shm-usage","--disable-accelerated-2d-canvas","--no-first-run","--no-zygote","--single-process","--disable-gpu","--ignore-certificate-errors","--disable-extensions","--disable-component-extensions-with-background-pages","--disable-default-apps","--mute-audio","--no-default-browser-check","--autoplay-policy=user-gesture-required","--disable-background-timer-throttling","--disable-backgrounding-occluded-windows","--disable-notifications","--disable-background-networking","--disable-breakpad","--disable-component-update","--disable-domain-reliability","--disable-sync"]}
                              drops-weather.0 2025-06-04 17:28:50.748	debug	browserPath set to puppeteer default
                              drops-weather.0 2025-06-04 17:28:50.748	debug	browserMode set to automatic, running on linux / x64
                              drops-weather.0 2025-06-04 17:28:50.737	info	starting. Version 1.2.3 (non-npm: iobroker-community-adapters/ioBroker.drops-weather) in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.1, js-controller: 7.0.6
                              drops-weather.0 2025-06-04 17:28:50.512	debug	States connected to redis: 0.0.0.0:9000
                              drops-weather.0 2025-06-04 17:28:50.458	debug	States create User PubSub Client
                              drops-weather.0 2025-06-04 17:28:50.457	debug	States create System PubSub Client
                              drops-weather.0 2025-06-04 17:28:50.429	debug	Redis States: Use Redis connection: 0.0.0.0:9000
                              drops-weather.0 2025-06-04 17:28:50.376	debug	Objects connected to redis: 0.0.0.0:9001
                              drops-weather.0 2025-06-04 17:28:50.367	debug	Objects client initialize lua scripts
                              drops-weather.0 2025-06-04 17:28:50.287	debug	Objects create User PubSub Client
                              drops-weather.0 2025-06-04 17:28:50.287	debug	Objects create System PubSub Client
                              drops-weather.0 2025-06-04 17:28:50.263	debug	Objects client ready ... initialize now
                              drops-weather.0 2025-06-04 17:28:50.213	debug	Redis Objects: Use Redis connection: 0.0.0.0:9001
                              drops-weather.0 2025-06-04 17:26:05.488	info	Terminated (NO_ERROR): Without reason
                              drops-weather.0 2025-06-04 17:26:05.480	warn	TimeoutError: Waiting failed: 60000ms exceeded
                              drops-weather.0 2025-06-04 17:25:03.134	info	starting. Version 1.2.3 (non-npm: iobroker-community-adapters/ioBroker.drops-weather) in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.1, js-controller: 7.0.6
                              drops-weather.0 2025-06-04 17:21:05.252	info	Terminated (NO_ERROR): Without reason
                              drops-weather.0 2025-06-04 17:21:05.210	warn	TimeoutError: Waiting failed: 60000ms exceeded
                              drops-weather.0 2025-06-04 17:20:03.183	info	starting. Version 1.2.3 (non-npm: iobroker-community-adapters/ioBroker.drops-weather) in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.1, js-controller: 7.0.6
                              drops-weather.0 2025-06-04 17:16:04.821	info	Terminated (NO_ERROR): Without reason
                              drops-weather.0 2025-06-04 17:16:04.815	warn	TimeoutError: Waiting failed: 60000ms exceeded
                              drops-weather.0 2025-06-04 17:15:03.158	info	starting. Version 1.2.3 (non-npm: iobroker-community-adapters/ioBroker.drops-weather) in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.1, js-controller: 7.0.6
                              ° Fixer ---> iob fix
                              • NegaleinN Negalein
                                @mcm1957
                                mcm1957M Online
                                mcm1957M Online
                                mcm1957
                                #159
                                @negalein said in Test Adapter drops-weather 1.2.x:
                                Die URL ist falsch. Da müsste de-de stehen.
                                Ich muss mal schaun / testen warum dem so ist. Im Code siehts eigentlich ok aus...
                                Kanns aber erst am Anbend machen sonst werd ich schön langsam gelynched. Muss ein paar Adapter Reviews machen die seit Wochen überfällig sind. Spätestens moregn sollts aber Feedback geben.
                                sigi234S M 2 Antworten Letzte Antwort
                                • mcm1957M mcm1957
                                  sigi234S Online
                                  sigi234S Online
                                  #160
                                  @mcm1957
                                  Ev. wegen AUT ?
                                  • mcm1957M mcm1957
                                    @sigi234
                                    sigi234S Online
                                    sigi234S Online
                                    #161
                                    404 page not found error click to go to home
                                    • sigi234S sigi234
                                      @mcm1957
                                      Ev. wegen AUT ?
                                      NegaleinN Offline
                                      NegaleinN Offline
                                      Negalein
                                      #162
                                      Ev. wegen AUT ?
                                      nein, auch in DE funktionierts nicht
                                      • mcm1957M mcm1957
                                        Marco 3
                                        schrieb am zuletzt editiert von Marco 3
                                        #163
                                        @mcm1957 said in Test Adapter drops-weather 1.2.x:
                                        https://www.niederschlagsradar.de/de-de/city/14210
                                        so ist aktuell die Erreichbarkeit bei mir
                                        Eventuell ist es sinnvoll die abzurufende Html Seite als Anpassungsmöglichkeit in den Objekten zu verlinken , oder in den Einstellungen komplett bei Ländercode zu verpacken.
                                        d.h. der Ländercode ist die gesamte Html Zeile...
                                        just my 50 cents :)
                                        Kurze Abhilfe, bei der Adaptereinstellung auf "en" statt "de" gehen und schon kommen Daten, ABER Deutsch wäre schon "nice" :)
                                        • M Marco 3
                                          just my 50 cents :)
                                          NegaleinN Offline
                                          NegaleinN Offline
                                          Negalein
                                          #164
                                          @marco-3 sagte in Test Adapter drops-weather 1.2.x:
                                          so zB bei mir
                                          egal ob Deutschland oder Österreich
                                          https://www.meteox.com/de-de/city/2855681
