  4. DS18B20 wird nach Update nicht mehr erkannt
    1.0k
    6.1k
17 Beiträge 3 Kommentatoren 1.4k Aufrufe 3 Beobachtet
  • W wusa
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    pi@iob-slave:/sys/bus/w1/devices/w1_bus_master1 $ ls -l
    total 0
    lrwxrwxrwx 1 root root    0 Apr 15 10:35 driver -> ../../bus/w1/drivers/w1_master_driver
    drwxr-xr-x 2 root root    0 Apr 15 10:35 power
    lrwxrwxrwx 1 root root    0 Apr 15 10:27 subsystem -> ../../bus/w1
    -rw-r--r-- 1 root root 4096 Apr 15 10:25 uevent
    -rw-rw-r-- 1 root root 4096 Apr 15 10:35 w1_master_add
    -r--r--r-- 1 root root 4096 Apr 15 10:35 w1_master_attempts
    -rw-rw-r-- 1 root root 4096 Apr 15 10:35 w1_master_max_slave_count
    -r--r--r-- 1 root root 4096 Apr 15 10:35 w1_master_name
    -r--r--r-- 1 root root 4096 Apr 15 10:35 w1_master_pointer
    -rw-rw-r-- 1 root root 4096 Apr 15 10:35 w1_master_pullup
    -rw-rw-r-- 1 root root 4096 Apr 15 10:35 w1_master_remove
    -rw-rw-r-- 1 root root 4096 Apr 15 10:35 w1_master_search
    -r--r--r-- 1 root root 4096 Apr 15 10:35 w1_master_slave_count
    -r--r--r-- 1 root root 4096 Apr 15 10:35 w1_master_slaves
    -r--r--r-- 1 root root 4096 Apr 15 10:35 w1_master_timeout
    -r--r--r-- 1 root root 4096 Apr 15 10:35 w1_master_timeout_us
    Ist aus meiner Sicht sauber durchgelaufen, aber im Verzeichnis taucht der Sensor dennoch nicht auf.
    @wusa
    Und was sagen die 143 CRITICAL ERRORS?
    W 1 Antwort Letzte Antwort
      @wusa
      W Offline
      W Offline
      wusa
      sudo dmesg --level=emerg,alert,crit -T
      [Tue Apr 15 10:26:30 2025] hwmon hwmon1: Undervoltage detected!
      [Tue Apr 15 10:27:34 2025] hwmon hwmon1: Undervoltage detected!
      [Tue Apr 15 10:27:52 2025] hwmon hwmon1: Undervoltage detected!
      [Tue Apr 15 10:28:55 2025] hwmon hwmon1: Undervoltage detected!
      [Tue Apr 15 10:29:09 2025] hwmon hwmon1: Undervoltage detected!
      [Tue Apr 15 10:29:17 2025] hwmon hwmon1: Undervoltage detected!
      [Tue Apr 15 10:29:31 2025] hwmon hwmon1: Undervoltage detected!
      [Tue Apr 15 10:29:41 2025] hwmon hwmon1: Undervoltage detected!
      • W wusa
        @wusa
        Dann spendier dem System eine gescheite Spannungsversorgung.
        Die knickt offenbar mit dem jetzigen 'Netzteil' andauernd weg. Damit kannst du keine Kiste stabil betreiben.
          @wusa
          W Offline
          W Offline
          wusa
          Ok verstehe, dass hier was besseres her muss.
          Jetzt kommt das große ABER:
          Warum hat es vor dem Systemupdate sauber funktioniert?
          Ich habe an dem Pi noch eine IR Diode dran, die läuft ohne Probleme.
          Der Sensor lief mit der selben Spannungsversorgung vorher ja auch?
          Wie kann das dann sein?
          CodierknechtC Thomas BraunT 2 Antworten Letzte Antwort
          • W wusa
            CodierknechtC Online
            Codierknecht
            @wusa sagte in DS18B20 wird nach Update nicht mehr erkannt:
            Netzteile (oder genauer: Die Kondensatoren darin) altern, so dass nach und nach immer weniger Leistung zur Verfügung steht.
            HmIP|ZigBee|Tasmota|Unifi
            Zabbix Certified Specialist
            • W wusa
              Weil...
              1000 Gründe...
              Vielleicht hast du es aber auch vorher nicht gesehen, das Spannungsversorgung zu dünn ist. Oder da laufen jetzt mehr Prozesse?
                Weil...
                1000 Gründe...
                W Offline
                W Offline
                wusa
                Ob Systemseitig mehr Prozesse laufen, kann ich so nicht sagen.
                Die Adapter welche auf dem Pi laufen, haben sich nicht verändert.
                Das einzige was ich gemacht habe, ist nur das Systemupdate.
                • W wusa
                  Was genau?
                  Und ein neues 'System' braucht auch in der Regel mehr Power.
                    Was genau?
                    W Offline
                    W Offline
                    wusa
                    Wie im Eingangspost geschrieben.
                    sudo apt update
                    sudo apt upgrade -y
                    Mehr habe ich nicht gemacht. Seitdem geht der DS18B20 nicht mehr.
                    • W wusa
                      sudo apt update
                      sudo apt upgrade -y
                      @wusa
                      Ist in
                      raspi-config
                      auch 1Wire aktiv?
                      sudo apt update
                      sudo apt full-upgrade
                      sagen?
                      Besser aber noch die Ausgabe von
                      iob diag
                      in der Langfassung.
                      Zusätzlich noch
                      lsmod | grep w1
                      Info von hier:
                      https://www.waveshare.com/wiki/Raspberry_Pi_Tutorial_Series:_1-Wire_DS18B20_Sensor
