  4. DS18B20 wird nach Update nicht mehr erkannt
    1.0k
    6.1k
17 Beiträge 3 Kommentatoren 1.4k Aufrufe 3 Beobachtet
    @wusa
    iob stop
    iob fix
    iob start
    W Offline
    W Offline
    wusa
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    pi@iob-slave:/sys/bus/w1/devices/w1_bus_master1 $ ls -l
    total 0
    lrwxrwxrwx 1 root root    0 Apr 15 10:35 driver -> ../../bus/w1/drivers/w1_master_driver
    drwxr-xr-x 2 root root    0 Apr 15 10:35 power
    lrwxrwxrwx 1 root root    0 Apr 15 10:27 subsystem -> ../../bus/w1
    -rw-r--r-- 1 root root 4096 Apr 15 10:25 uevent
    -rw-rw-r-- 1 root root 4096 Apr 15 10:35 w1_master_add
    -r--r--r-- 1 root root 4096 Apr 15 10:35 w1_master_attempts
    -rw-rw-r-- 1 root root 4096 Apr 15 10:35 w1_master_max_slave_count
    -r--r--r-- 1 root root 4096 Apr 15 10:35 w1_master_name
    -r--r--r-- 1 root root 4096 Apr 15 10:35 w1_master_pointer
    -rw-rw-r-- 1 root root 4096 Apr 15 10:35 w1_master_pullup
    -rw-rw-r-- 1 root root 4096 Apr 15 10:35 w1_master_remove
    -rw-rw-r-- 1 root root 4096 Apr 15 10:35 w1_master_search
    -r--r--r-- 1 root root 4096 Apr 15 10:35 w1_master_slave_count
    -r--r--r-- 1 root root 4096 Apr 15 10:35 w1_master_slaves
    -r--r--r-- 1 root root 4096 Apr 15 10:35 w1_master_timeout
    -r--r--r-- 1 root root 4096 Apr 15 10:35 w1_master_timeout_us
    Ist aus meiner Sicht sauber durchgelaufen, aber im Verzeichnis taucht der Sensor dennoch nicht auf.
    • W wusa
      total 0
      @wusa
      Und was sagen die 143 CRITICAL ERRORS?
      W 1 Antwort Letzte Antwort
        @wusa
        W Offline
        W Offline
        wusa
        sudo dmesg --level=emerg,alert,crit -T
        [Tue Apr 15 10:26:30 2025] hwmon hwmon1: Undervoltage detected!
        [Tue Apr 15 10:27:34 2025] hwmon hwmon1: Undervoltage detected!
        [Tue Apr 15 10:27:52 2025] hwmon hwmon1: Undervoltage detected!
        [Tue Apr 15 10:28:55 2025] hwmon hwmon1: Undervoltage detected!
        [Tue Apr 15 10:29:09 2025] hwmon hwmon1: Undervoltage detected!
        [Tue Apr 15 10:29:17 2025] hwmon hwmon1: Undervoltage detected!
        [Tue Apr 15 10:29:31 2025] hwmon hwmon1: Undervoltage detected!
        [Tue Apr 15 10:29:41 2025] hwmon hwmon1: Undervoltage detected!
        • W wusa
          @wusa
          Dann spendier dem System eine gescheite Spannungsversorgung.
          Die knickt offenbar mit dem jetzigen 'Netzteil' andauernd weg. Damit kannst du keine Kiste stabil betreiben.
            @wusa
            W Offline
            W Offline
            wusa
            Ok verstehe, dass hier was besseres her muss.
            Jetzt kommt das große ABER:
            Warum hat es vor dem Systemupdate sauber funktioniert?
            Ich habe an dem Pi noch eine IR Diode dran, die läuft ohne Probleme.
            Der Sensor lief mit der selben Spannungsversorgung vorher ja auch?
            Wie kann das dann sein?
            CodierknechtC Thomas BraunT 2 Antworten Letzte Antwort
            • W wusa
              CodierknechtC Online
              Codierknecht
              @wusa sagte in DS18B20 wird nach Update nicht mehr erkannt:
              Netzteile (oder genauer: Die Kondensatoren darin) altern, so dass nach und nach immer weniger Leistung zur Verfügung steht.
              HmIP|ZigBee|Tasmota|Unifi
              Zabbix Certified Specialist
              • W wusa
                Weil...
                1000 Gründe...
                Vielleicht hast du es aber auch vorher nicht gesehen, das Spannungsversorgung zu dünn ist. Oder da laufen jetzt mehr Prozesse?
                  Weil...
                  1000 Gründe...
                  W Offline
                  W Offline
                  wusa
                  Ob Systemseitig mehr Prozesse laufen, kann ich so nicht sagen.
                  Die Adapter welche auf dem Pi laufen, haben sich nicht verändert.
                  Das einzige was ich gemacht habe, ist nur das Systemupdate.
                  • W wusa
                    Was genau?
                    Und ein neues 'System' braucht auch in der Regel mehr Power.
                      Was genau?
                      W Offline
                      W Offline
                      wusa
                      Wie im Eingangspost geschrieben.
                      sudo apt update
                      sudo apt upgrade -y
                      Mehr habe ich nicht gemacht. Seitdem geht der DS18B20 nicht mehr.
                      • W wusa
                        sudo apt update
                        sudo apt upgrade -y
                        @wusa
                        Ist in
                        raspi-config
                        auch 1Wire aktiv?
                        sudo apt update
                        sudo apt full-upgrade
                        sagen?
                        Besser aber noch die Ausgabe von
                        iob diag
                        in der Langfassung.
                        Zusätzlich noch
                        lsmod | grep w1
                        Info von hier:
                        https://www.waveshare.com/wiki/Raspberry_Pi_Tutorial_Series:_1-Wire_DS18B20_Sensor
