  4. DS18B20 wird nach Update nicht mehr erkannt
    1.0k
    6.1k
17 Beiträge 3 Kommentatoren 1.4k Aufrufe 3 Beobachtet
  • W wusa
    Ich habe die Adapter alle beendet, aber der js-con bleibt bestehen.
    Wie kann ich den letzten Adapter noch sauber beenden?
    @wusa
    Keine Bildchen von Text aus der Konsole.
    Text in CodeTags eigebettet hier rein.
    W 1 Antwort Letzte Antwort
      @wusa
      W Offline
      W Offline
      wusa
      pi@iob-slave:~ $ iob fix
      library: loaded
      Library version=2024-10-22
      ioBroker or some processes are still running:
      496 iobroker.js-con
      621 io.smartmeter.0
      628 io.zigbee.0
      690 io.tahoma.0
      Please stop them first and try again!
      library: loaded
      496 iobroker.js-con
      pi@iob-slave:~ $
      • W wusa
        library: loaded
        496 iobroker.js-con
        621 io.smartmeter.0
        628 io.zigbee.0
        690 io.tahoma.0
        library: loaded
        496 iobroker.js-con
        pi@iob-slave:~ $
        @wusa
        iob stop
        iob fix
        iob start
          @wusa
          iob stop
          iob fix
          iob start
          W Offline
          W Offline
          wusa
              Your installation was fixed successfully
              Run iobroker start to start ioBroker again!
          pi@iob-slave:/sys/bus/w1/devices/w1_bus_master1 $ ls -l
          total 0
          lrwxrwxrwx 1 root root    0 Apr 15 10:35 driver -> ../../bus/w1/drivers/w1_master_driver
          drwxr-xr-x 2 root root    0 Apr 15 10:35 power
          lrwxrwxrwx 1 root root    0 Apr 15 10:27 subsystem -> ../../bus/w1
          -rw-r--r-- 1 root root 4096 Apr 15 10:25 uevent
          -rw-rw-r-- 1 root root 4096 Apr 15 10:35 w1_master_add
          -r--r--r-- 1 root root 4096 Apr 15 10:35 w1_master_attempts
          -rw-rw-r-- 1 root root 4096 Apr 15 10:35 w1_master_max_slave_count
          -r--r--r-- 1 root root 4096 Apr 15 10:35 w1_master_name
          -r--r--r-- 1 root root 4096 Apr 15 10:35 w1_master_pointer
          -rw-rw-r-- 1 root root 4096 Apr 15 10:35 w1_master_pullup
          -rw-rw-r-- 1 root root 4096 Apr 15 10:35 w1_master_remove
          -rw-rw-r-- 1 root root 4096 Apr 15 10:35 w1_master_search
          -r--r--r-- 1 root root 4096 Apr 15 10:35 w1_master_slave_count
          -r--r--r-- 1 root root 4096 Apr 15 10:35 w1_master_slaves
          -r--r--r-- 1 root root 4096 Apr 15 10:35 w1_master_timeout
          -r--r--r-- 1 root root 4096 Apr 15 10:35 w1_master_timeout_us
          Ist aus meiner Sicht sauber durchgelaufen, aber im Verzeichnis taucht der Sensor dennoch nicht auf.
          • W wusa
            total 0
            @wusa
            Und was sagen die 143 CRITICAL ERRORS?
              @wusa
              W Offline
              W Offline
              wusa
              sudo dmesg --level=emerg,alert,crit -T
              [Tue Apr 15 10:26:30 2025] hwmon hwmon1: Undervoltage detected!
              [Tue Apr 15 10:27:34 2025] hwmon hwmon1: Undervoltage detected!
              [Tue Apr 15 10:27:52 2025] hwmon hwmon1: Undervoltage detected!
              [Tue Apr 15 10:28:55 2025] hwmon hwmon1: Undervoltage detected!
              [Tue Apr 15 10:29:09 2025] hwmon hwmon1: Undervoltage detected!
              [Tue Apr 15 10:29:17 2025] hwmon hwmon1: Undervoltage detected!
              [Tue Apr 15 10:29:31 2025] hwmon hwmon1: Undervoltage detected!
              [Tue Apr 15 10:29:41 2025] hwmon hwmon1: Undervoltage detected!
              • W wusa
                @wusa
                Dann spendier dem System eine gescheite Spannungsversorgung.
                Die knickt offenbar mit dem jetzigen 'Netzteil' andauernd weg. Damit kannst du keine Kiste stabil betreiben.
                  @wusa
                  W Offline
                  W Offline
                  wusa
                  Ok verstehe, dass hier was besseres her muss.
                  Jetzt kommt das große ABER:
                  Warum hat es vor dem Systemupdate sauber funktioniert?
                  Ich habe an dem Pi noch eine IR Diode dran, die läuft ohne Probleme.
                  Der Sensor lief mit der selben Spannungsversorgung vorher ja auch?
                  Wie kann das dann sein?
                  CodierknechtC Thomas BraunT 2 Antworten Letzte Antwort
                  • W wusa
                    CodierknechtC Online
                    Codierknecht
                    @wusa sagte in DS18B20 wird nach Update nicht mehr erkannt:
                    Netzteile (oder genauer: Die Kondensatoren darin) altern, so dass nach und nach immer weniger Leistung zur Verfügung steht.
                    HmIP|ZigBee|Tasmota|Unifi
                    Zabbix Certified Specialist
                    • W wusa
                      Weil...
                      1000 Gründe...
                      Vielleicht hast du es aber auch vorher nicht gesehen, das Spannungsversorgung zu dünn ist. Oder da laufen jetzt mehr Prozesse?
                        Weil...
                        1000 Gründe...
                        W Offline
                        W Offline
                        wusa
                        Ob Systemseitig mehr Prozesse laufen, kann ich so nicht sagen.
                        Die Adapter welche auf dem Pi laufen, haben sich nicht verändert.
                        Das einzige was ich gemacht habe, ist nur das Systemupdate.
                        • W wusa
                          Was genau?
                          Und ein neues 'System' braucht auch in der Regel mehr Power.
                            Was genau?
                            W Offline
                            W Offline
                            wusa
                            Wie im Eingangspost geschrieben.
                            sudo apt update
                            sudo apt upgrade -y
                            Mehr habe ich nicht gemacht. Seitdem geht der DS18B20 nicht mehr.
                            • W wusa
                              sudo apt update
                              sudo apt upgrade -y
                              @wusa
                              Ist in
                              raspi-config
                              auch 1Wire aktiv?
                              sudo apt update
                              sudo apt full-upgrade
                              sagen?
                              Besser aber noch die Ausgabe von
                              iob diag
                              in der Langfassung.
                              Zusätzlich noch
                              lsmod | grep w1
                              Info von hier:
                              https://www.waveshare.com/wiki/Raspberry_Pi_Tutorial_Series:_1-Wire_DS18B20_Sensor
