  3. Off Topic
  4. Proxmox
  5. Proxmox Hilfe gesucht
    2.7k
    4.7k
    4.0k
Geplant Angeheftet Gesperrt Verschoben Proxmox
97 Beiträge 10 Kommentatoren 14.4k Aufrufe 5 Beobachtet
  • J jan_xx
    ```bash
    Script v.2025-02-23
    *** BASE SYSTEM ***
     Static hostname: iobroker12
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.8.12-4-pve
        Architecture: x86-64
    OS is similar to:
    model name      : Intel(R) N100
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     23:11:00 up 11 min,  2 users,  load average: 0.06, 0.05, 0.04
    CPU threads: 2
    *** LIFE CYCLE STATUS ***
    Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
    *** TIME AND TIMEZONES ***
                   Local time: Sun 2025-04-06 23:11:01 CEST
               Universal time: Sun 2025-04-06 21:11:01 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    home
    HOME=/home/home
    GROUPS=home sudo users iobroker
    js-controller is not running
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:            4.2G         74M        3.7G        110K        385M        4.1G
    Swap:           536M          0B        536M
    Total:          4.7G         74M        4.3G
    Active iob-Instances:   1
             4000 M total memory
               71 M used memory
              141 M active memory
              243 M inactive memory
             3561 M free memory
                0 M buffer memory
              367 M swap cache
              512 M total swap
                0 M used swap
              512 M free swap
    top - 23:11:01 up 11 min,  2 users,  load average: 0.06, 0.05, 0.04
    Tasks:  25 total,   1 running,  24 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   4000.0 total,   3560.0 free,     72.8 used,    367.2 buff/cache
    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   3927.2 avail Mem
    *** FAILED SERVICES ***
      UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
    * iobroker.service     loaded failed failed ioBroker Server
    2 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    dmesg: read kernel buffer failed: Operation not permitted
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--101--disk--0 ext4       20G  3.6G   15G  20% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    udev                             devtmpfs  7.7G     0  7.7G   0% /dev/tty
    tmpfs                            tmpfs     7.7G     0  7.7G   0% /dev/shm
    tmpfs                            tmpfs     3.1G  104K  3.1G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    Show mounted filesystems:
    TARGET SOURCE                           FSTYPE OPTIONS
    /      /dev/mapper/pve-vm--101--disk--0 ext4   rw,relatime,stripe=16
    /var:
    423M    /var/
    251M    /var/cache
    247M    /var/cache/apt
    172M    /var/cache/apt/archives
    147M    /var/lib
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    688M    /opt/iobroker/iobroker-data/
    682M    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
    8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
    7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.a9c6d34a.chunk.js.map
    7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.7e9d7842.chunk.js.map
    7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.279d2690.chunk.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.19.0
    /usr/bin/node           v20.19.0
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.31.0
    nodejs:
      Installed: 20.19.0-1nodesource1
      Candidate: 20.19.0-1nodesource1
      Version table:
     *** 20.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    iobroker is not running on this host.
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker12          iobroker12 (version: 7.0.6, hostname: iobroker12    , alive, uptime: 46)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.6.3
    javascript:     8.8.3
    nodejs modules from github:     0
    Adapter State
      system.adapter.admin.0                  : admin                 : iobroker12                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.backitup.0               : backitup              : iobroker12                               -  enabled
      system.adapter.discovery.0              : discovery             : iobroker12                               -  enabled
      system.adapter.javascript.0             : javascript            : iobroker12                               -  enabled
      system.adapter.proxmox.0                : proxmox               : iobroker12                               -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    ^[[1;2BUsed repository: stable
    Adapter    "admin"        : 7.6.3    , installed 7.6.3
    Adapter    "backitup"     : 3.0.31   , installed 3.0.31
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
    Objects and States
    Objects:        334
    States:         201
    ^[[1;2BHit:1 http://security.debian.org bookworm-security InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          385570     294/master
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          385149     1/init
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          385571     294/master
    tcp6       0      0 :::22                   :::*                    LISTEN      0          385303     1/init
    tcp6       0      0 :::111                  :::*                    LISTEN      0          385151     1/init
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          385150     1/init
    udp6       0      0 :::111                  :::*                                0          385152     1/init
    2025-04-06 23:00:21.486  - info: discovery.0 (408) terminating
    2025-04-06 23:00:21.486  - info: discovery.0 (408) Terminated (NO_ERROR): Without reason
    2025-04-06 23:00:21.488  - info: admin.0 (305) terminating
    2025-04-06 23:00:21.489  - info: admin.0 (305) Terminated (NO_ERROR): Without reason
    2025-04-06 23:00:21.517  - info: host.iobroker12 stopInstance system.adapter.admin.0 send kill signal
    2025-04-06 23:00:21.517  - info: host.iobroker12 stopInstance system.adapter.javascript.0 send kill signal
    2025-04-06 23:00:21.517  - info: host.iobroker12 stopInstance system.adapter.backitup.0 send kill signal
    2025-04-06 23:00:21.517  - info: host.iobroker12 stopInstance system.adapter.proxmox.0 send kill signal
    2025-04-06 23:00:21.517  - info: host.iobroker12 stopInstance system.adapter.discovery.0 send kill signal
    2025-04-06 23:00:21.523  - info: javascript.0 (350) terminating
    2025-04-06 23:00:21.524  - info: javascript.0 (350) Terminated (NO_ERROR): Without reason
    2025-04-06 23:00:21.526  - info: backitup.0 (371) terminating
    2025-04-06 23:00:21.527  - info: backitup.0 (371) Terminated (NO_ERROR): Without reason
    2025-04-06 23:00:21.971  - info: discovery.0 (408) terminating
    2025-04-06 23:00:21.971  - info: javascript.0 (350) terminating
    2025-04-06 23:00:21.974  - info: backitup.0 (371) terminating
    2025-04-06 23:00:21.974  - info: proxmox.0 (393) terminating
    2025-04-06 23:00:21.976  - info: admin.0 (305) terminating
    2025-04-06 23:00:22.001  - info: host.iobroker12 instance system.adapter.proxmox.0 terminated with code 0 (NO_ERROR)
    2025-04-06 23:00:22.006  - info: host.iobroker12 instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
    2025-04-06 23:00:22.018  - info: host.iobroker12 instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
    2025-04-06 23:00:22.042  - info: host.iobroker12 instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
    2025-04-06 23:00:22.047  - info: host.iobroker12 instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
    2025-04-06 23:00:22.047  - info: host.iobroker12 All instances are stopped.
    2025-04-06 23:00:22.164  - info: host.iobroker12 terminated
    iob diag has finished.
    #78
    @jan_xx
    An der UserID sehe ich, dass der user home entgegen der Anleitung nachträglich angelegt wurde.
    Dann funktionieren aber die im ioBroker-Installer vorgenommen Rechteanpassungen nicht und du bekommst halt die entsprechende Meldung um die Ohren gehauen.
    Der user fehlt auch in weiteren Gruppen.
    sudo usermod -aG adm,dialout,sudo,audio,video,plugdev,users,iobroker home
    Und da dürfte auch noch ein
    iob stop
    iob fix
    iob start
    erforderlich sein.
    Backup vom Rapi und dann zeitnah gleich auf den Proxmox iobroker schieben damit nichts verloren geht?
    Hab so etwas noch nicht gemacht.
    Mit dem Backitup-Adapter. Für Details schaust du dir das sehr gute Wiki zu diesem Adapter an.
    J crunchipC 2 Antworten Letzte Antwort
      @jan_xx
      iob stop
      iob fix
      iob start
      erforderlich sein.
      jan_xx
      #79
      Vielen Dank, habe ich gemacht....
      Also mache ich jetzt am besten erstmal ein Backup von diesem Stand.
      ```bash
      Script v.2025-02-23
      *** BASE SYSTEM ***
        Virtualization: lxc
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
       08:57:40 up 15 min,  2 users,  load average: 0.08, 0.03, 0.01
      CPU threads: 2
                     Local time: Mon 2025-04-07 08:57:40 CEST
                 Universal time: Mon 2025-04-07 06:57:40 UTC
                       RTC time: n/a
                RTC in local TZ: no
      home
      HOME=/home/home
      GROUPS=home adm dialout sudo audio video plugdev users iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:            6.3G        509M        5.5G        114K        235M        5.8G
      Swap:           536M          0B        536M
      Total:          6.8G        509M        6.1G
      Active iob-Instances:   6
               6000 M total memory
                486 M used memory
                606 M active memory
                 72 M inactive memory
               5289 M free memory
                  0 M buffer memory
                224 M swap cache
                512 M total swap
                  0 M used swap
                512 M free swap
      top - 08:57:40 up 15 min,  2 users,  load average: 0.08, 0.03, 0.01
      Tasks:  30 total,   1 running,  29 sleeping,   0 stopped,   0 zombie
      MiB Mem :   6000.0 total,   5287.3 free,    487.7 used,    225.0 buff/cache
      MiB Swap:    512.0 total,    512.0 free,      0.0 used.   5512.3 avail Mem
      1 loaded units listed.
      *** FILESYSTEM ***
      tmpfs                            tmpfs     3.1G  108K  3.1G   1% /run
      /var:
      423M    /var/
      251M    /var/cache
      247M    /var/cache/apt
      147M    /var/lib
      Archived and active journals take up 24.0M in the file system.
      1.8M    /opt/iobroker/backups/
      695M    /opt/iobroker/iobroker-data/
      USB-Devices by-id:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      iobroker12          iobroker12 (version: 7.0.6, hostname: iobroker12    , alive, uptime: 931)
      admin:          7.6.3
      javascript:     8.8.3
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker12                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : iobroker12                               -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker12                               -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker12                               -  enabled
      + system.adapter.proxmox.0                : proxmox               : iobroker12                               -  enabled
      + instance is alive
      Objects and States
      Objects:        334
      States:         246
      Hit:2 http://security.debian.org bookworm-security InRelease
      Pending Updates: 0
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          1438130    294/master
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       1438753    127/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       1438263    127/iobroker.js-con
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1435309    1/init
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       1438846    305/io.admin.0
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          1438131    294/master
      tcp6       0      0 :::111                  :::*                    LISTEN      0          1435311    1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          1435450    1/init
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1435310    1/init
      udp6       0      0 :::111                  :::*                                0          1435312    1/init
      2025-04-07 08:42:05.113  - info: admin.0 (305) received all objects
      2025-04-07 08:42:05.247  - info: admin.0 (305) socket.io server listening on port 8081
      2025-04-07 08:42:05.248  - info: admin.0 (305) http server listening on port 8081
      2025-04-07 08:42:05.248  - info: admin.0 (305) Use link "http://127.0.0.1:8081" to configure.
      2025-04-07 08:42:07.974  - info: host.iobroker12 instance system.adapter.javascript.0 in version "8.8.3" started with pid 350
      2025-04-07 08:42:08.793  - info: javascript.0 (350) starting. Version 8.8.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.19.0, js-controller: 7.0.6
      2025-04-07 08:42:08.925  - info: javascript.0 (350) requesting all states
      2025-04-07 08:42:08.926  - info: javascript.0 (350) requesting all objects
      2025-04-07 08:42:09.031  - info: javascript.0 (350) received all objects
      2025-04-07 08:42:09.031  - info: javascript.0 (350) received all states
      2025-04-07 08:42:11.955  - info: host.iobroker12 instance system.adapter.backitup.0 in version "3.0.31" started with pid 371
      2025-04-07 08:42:12.514  - info: backitup.0 (371) starting. Version 3.0.31 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.19.0, js-controller: 7.0.6
      2025-04-07 08:42:12.530  - info: backitup.0 (371) [iobroker] backup will be activated at 02:48 every 1 day(s)
      2025-04-07 08:42:15.342  - info: admin.0 (305) ==> Connected system.user.admin from ::ffff:192.168.122.132
      2025-04-07 08:42:16.050  - info: host.iobroker12 instance system.adapter.proxmox.0 in version "2.4.0" started with pid 400
      2025-04-07 08:42:16.729  - info: proxmox.0 (400) starting. Version 2.4.0 in /opt/iobroker/node_modules/iobroker.proxmox, node: v20.19.0, js-controller: 7.0.6
      2025-04-07 08:42:16.745  - warn: proxmox.0 (400) Using Proxmox API: https://192.168.122.5:8006/api2/json
      2025-04-07 08:42:19.986  - info: host.iobroker12 instance system.adapter.discovery.0 in version "5.0.0" started with pid 415
      2025-04-07 08:42:20.498  - info: discovery.0 (415) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.19.0, js-controller: 7.0.6
      2025-04-07 08:47:50.371  - info: admin.0 (305) <== Disconnect system.user.admin from ::ffff:192.168.122.132 admin
      2025-04-07 08:55:12.295  - info: admin.0 (305) ==> Connected system.user.admin from ::ffff:192.168.122.132
      2025-04-07 08:55:12.350  - info: admin.0 (305) ==> Connected system.user.admin from ::ffff:192.168.122.132
      2025-04-07 08:55:12.351  - info: admin.0 (305) <== Disconnect system.user.admin from ::ffff:192.168.122.132 admin
      2025-04-07 08:55:12.356  - info: admin.0 (305) <== Disconnect system.user.admin from ::ffff:192.168.122.132 admin
      2025-04-07 08:55:13.365  - info: admin.0 (305) ==> Connected system.user.admin from ::ffff:192.168.122.132
        @jan_xx
        iob stop
        iob fix
        iob start
        erforderlich sein.
        crunchipC Abwesend
        crunchipC Abwesend
        #80
        @thomas-braun sagte in Proxmox Hilfe gesucht:
        Und sowas verstehe ich nicht
        @jan_xx sagte in Proxmox Hilfe gesucht:
        Kannst du machen, ich würde dir allerdings empfehlen, den LXC nochmal zu löschen und das ganze richtig aufzusetzen, schließlich brauchst du diese Grundschritte noch öfters bei weiteren LXC oder auch VM's
          jan_xx
          #81
          @crunchip
          wann brauche ich das denn noch?
          Also wenn ich mich entscheide den lxc nochmal aufzusetzen dann muss ich
          addduser
          vor
          curl -sLf https://iobroker.net/install.sh | bash -
          machen?
          Habe ich das richtig verstanden?
          HomoranH Thomas BraunT crunchipC 3 Antworten Letzte Antwort
          • J jan_xx
            @crunchip
            addduser
            vor
            machen?
            #82
            @jan_xx ne7n!
            bei einer korrekten Betriebssysteminstallation wird der User direkt angelegt.
            Deswegen riet ich von den Templates ab, solange man nicht weiß was darin gemacht wurde.
            • J jan_xx
              @crunchip
              addduser
              vor
              machen?
              #83
              @jan_xx
              Ja, als allererstes wird ein User für den Alltagsbetrieb angelegt und dann wird alles weitere nur noch mit diesem user erledigt.
              Und der user heißt nicht wie irgendwelche Linux-Dienste oder Verzeichnisse. Also ist z.B. dein 'home' eine denkbar schlechte Wahl.
                @jan_xx ne7n!
                jan_xx
                #84
                Hast du Proxmox mit iobroker laufen?
                Machst du lxc oder VM?
                Lädst du das ISO von Debian12 runter oder wie machst du es?
                Das sind meine ersten Gehversuche mit Proxmox.
                • J jan_xx
                  #85
                  nicht mehr, bin wieder zurück zum pi(5)
                  VM!
                  Container sind mir zu komplex
                  ja, als webinstall!
                  und dann ganz normal installieren.
                  (so wie es in der Proxmox Anleitung steht. Nur immer mit aktuellen stable LTS Versionen.
                  • J jan_xx
                    @crunchip
                    addduser
                    vor
                    machen?
                    crunchipC Abwesend
                    crunchipC Abwesend
                    #86
                    so wie es in der Beschreibung steht
                    für jeden weiteren Container oder VM die du in Proxmox noch zusätzlich anlegst, solltest du allerdings nur den iobroker und nichts mehr anderes installieren wollen, stellst sich die Frage für was du Proxmox brauchst.
                    nur so am Rande, es besteht z.b. die Möglichkeit einen LXC aufzusetzen (nach Anleitung) aber nur bis zum Schritt iobroker installieren, somit hast du einen fertig konfigurierten LXC mit deinem eingerichteten User.
                    Diesen LXC kannst du dir dann als template anlegen und für jede Neue zusätzliche Maschine verwenden und sparst dir die ganzen Schritte.
                    die Wahl zwischen den beiden ist mittlerweile eine "Glaubensfrage", theoretisch geht alles in einer VM und umgekehrt auch so gut wie alles in einem LXC
                    der Unterschied zwischen beiden ist ebenfalls in der Proxmox Doku hinterlegt
                    mit eigenen kurzen Worten,
                    • ne VM ist einem alleinstehenden Rechner gleichgestellt, musst du also sehen als wenn du nen weiteren PC auf deinem Proxmox laufen hast,
                    • ein LXC teilt sich den Kernel des Proxmox Host und ist so zu sagen eine abgespeckte Version, nicht ganz als eigenständiger weiterer PC zu sehen, des weiteren gibt es bei LXC auch noch zusätzliche Einstellungen was Sicherheit, einbinden von Geräten und der gleichen zu beachten sind
                      jan_xx
                      #87
                      @all
                      Vielen Dank schon mal das ihr so aktiv hier mitarbeitet und mich unterstützt.
                      Jede Antwort wirft auch irgendwie immer wieder neue Fragen auf..:-) Warum sollte es wenn ich neue Container anlege Probleme mit dem User geben, das sind doch dann getrennte Maschinen?
                      Auch wenn wir jetzt im Nachgang noch Rechte vergeben haben, sollte doch der aktuelle Stand von iobroker mit den Usern funktionieren, hier habe ich doch mit Thomas einigen Schriftverkehr gehabt und er hat mit Tips gegeben um es grade zu ziehen oder sehe ich das falsch?
                      Der eigentliche Hintergrund ist das ich alles irgendwie auf einem Rechner habe und auch schnell und ohne Probleme ein Backup machen kann, bzw. auch wieder zeitnah zurück spielen kann.
                      OMV habe ich bereits als VM vom Raspi umgezogen und Pihole kommt dann auch noch, so der der aktuelle Plan.
                      Jetzt muss ich erstmal schauen das ich iobroker sauber rüber bekomme, hier habe ich noch ein paar Bauschmerzen wenn ich an Sourceanalytics denke wo ich viele Zahlenwerte mit verarbeite, ich hoffe mal das klappt. So wie ich gelesen haben sollte ja Backitup alles mitnehmen. Ja und für die Zukunft denke ich das ich mit dem NUC und Proxmox gut aufgestellt bin, hier könnte ich mir auch noch ein Testsystem anlegen was bis dato noch nicht vorhanden ist.
                      Meister MopperM crunchipC 3 Antworten Letzte Antwort
                      • J jan_xx
                        @all
                        Meister MopperM Offline
                        Meister Mopper
                        #88
                        Es gibt ja keine Probleme, wenn man es richtig macht. Wenn das dann als Template gespeichert wird, ist das Aufsetzen einer neuen Maschine ein Klacks.
                        Nein
                        Stimmt
                        Ja, dazu wurde der Hypervisor gemacht.
                        Proxmox und HA - dank KI/AI endlich "blocklyfrei"
                        • J jan_xx
                          @all
                          crunchipC Abwesend
                          crunchipC Abwesend
                          #89
                          weil der erste Gang immer ist, update upgrade, ggf. etwas benötigtes oder generell verwendetes nachinstallieren(z.b. curl) und user anlegen, dann ist das Grundgerüst eines LXC aufgebaut.
                          wenn du dies dann als fertiges template abspeicherst, kannst du mit diesem immer einen neuen LXC erstellen mit diesem template und musst die Anfangsschritte nicht immer erneut ausführen. egal ob du dann pihole, grafana, influxdb oder was auch immer als Container anlegst. Das schöne am LXC, du kannst deinen Ram jederzeit, je nach Anwendung anpassen, genauso kannst du das root Laufwerk jederzeit vergrößern.(verkleinern zwar auch, aber nur mit Umwegen) daher ne generelle Größe von 10-20 GB anlegen, wenn mehr benötigt, kann man je nach Bedarf/Anwendung erweitern
                            jan_xx
                            #90
                            @crunchip
                            Wie speichere ich denn das ganze als Template ab?
                            • J jan_xx
                              @crunchip
                              crunchipC Abwesend
                              crunchipC Abwesend
                              #91
                              @jan_xx habs jetzt nicht genau im Kopf, müsste wenn du mit der rechten Maustaste drauf klickst(aufn LXC) angezeigt werden
                                jan_xx
                                #92
                                @crunchip
                                convert to template steht da, werde mal testen...
                                Hast du auch ab uns zu das Problem das in der Konsole die Eingabe nicht angezeigt wird?
                                • J jan_xx
                                  @all
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                  #93
                                  und wohin soll das backup gehen?
                                  ja das funktioniert problemlos, sofern dein Umzug nicht über Nacht stattfindet
                                  • J jan_xx
                                    @crunchip
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    #94
                                    nein, ich hab kein proxmox mehr, aber einen Verdacht
                                    was hast du bei deiner Netzwerkeinstellung drin bei ipv6?
                                    wenn kein v6 verwendet wird, dann wie in der Doku
                                    edit
                                    arbeitest du immer in der Proxmox konsole? dann wohl auch immer mit root
                                      edit
                                      jan_xx
                                      #95
                                      @crunchip IP6 steht DHCP bei mir
                                      • J jan_xx
                                        crunchipC Abwesend
                                        crunchipC Abwesend
                                        #96
                                        @jan_xx wie geschrieben, wenn zu hause bei dir ipv6 läuft, dann ok, wenn nicht und du nur ipv4 verwendest, stelle es um wie gezeigt
                                          jan_xx
                                          #97
                                          @crunchip
                                          habe ich gemacht, funktioniert vorerst👍
                                          So hab nun auch das Backup umgezogen, soweit so gut, mal sehen ob Probleme auftreten...
