  3. Einsteigerfragen
  4. Installation
  5. Nach update startet admin nicht mehr
27 Beiträge 6 Kommentatoren 4.7k Aufrufe 5 Beobachtet
  • R reinosmart
    ```bash
    Script v.2025-02-23
    *** BASE SYSTEM ***
     Static hostname: raspy
           Icon name: computer
              Kernel: Linux 6.6.51+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 3 Model B Plus Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     10:49:23 up 19:04,  4 users,  load average: 0.46, 0.16, 0.08
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Sat 2025-03-22 10:49:23 CET
               Universal time: Sat 2025-03-22 09:49:23 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    iobroker3
    HOME=/home/iobroker3
    GROUPS=iobroker3 adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: true
    Desktop:
    Terminal:       tty
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
    *** MEMORY ***
    Mem:            951M        521M        172M        4.8M        328M        429M
    Swap:           536M        339M        197M
    Total:          1.5G        860M        370M
    Active iob-Instances:   9
              907 M total memory
              497 M used memory
              243 M active memory
              378 M inactive memory
              164 M free memory
               87 M buffer memory
              226 M swap cache
              511 M total swap
              323 M used swap
              188 M free swap
    top - 10:49:24 up 19:04,  4 users,  load average: 0.46, 0.16, 0.08
    Tasks: 197 total,   1 running, 196 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  7.7 us, 15.4 sy,  0.0 ni, 69.2 id,  7.7 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :    907.3 total,    162.6 free,    499.4 used,    313.9 buff/cache
    MiB Swap:    512.0 total,    188.5 free,    323.5 used.    407.9 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  317M     0  317M   0% /dev
    tmpfs          tmpfs      91M  1.2M   90M   2% /run
    /dev/mmcblk0p2 ext4       29G  7.2G   20G  27% /
    tmpfs          tmpfs     454M  148K  454M   1% /dev/shm
    tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   71M  440M  14% /boot/firmware
    tmpfs          tmpfs      91M   48K   91M   1% /run/user/1000
    [Fri Mar 21 15:45:10 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=b5b55aeb-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
    [Fri Mar 21 15:45:20 2025] EXT4-fs (mmcblk0p2): mounted filesystem a36be96c-66be-4487-a7a6-0481bca99d89 ro with ordered data mode. Quota mode: none.
    [Fri Mar 21 15:45:23 2025] EXT4-fs (mmcblk0p2): re-mounted a36be96c-66be-4487-a7a6-0481bca99d89 r/w. Quota mode: none.
    Show mounted filesystems:
    TARGET               SOURCE         FSTYPE      OPTIONS
    /                    /dev/mmcblk0p2 ext4        rw,noatime
    |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    `-/boot/firmware     /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    952M    /var/
    196M    /var/cache
    195M    /var/lib
    189M    /var/cache/apt
    135M    /var/lib/apt/lists
    Archived and active journals take up 47.8M in the file system.
    /opt/iobroker/backups:
    1.8M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    362M    /opt/iobroker/iobroker-data/
    317M    /opt/iobroker/iobroker-data/files
    158M    /opt/iobroker/iobroker-data/files/admin.admin
    157M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    13M     /opt/iobroker/iobroker-data/objects.jsonl
    9.1M    /opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.bbf74d5f.chunk.js.map
    8.9M    /opt/iobroker/iobroker-data/files/echarts/static/js/2.3d2d025f.chunk.js.map
    8.9M    /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/2.3d2d025f.chunk.js.map
    7.4M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_icons-material_esm_index_js.d7ed606b.chunk.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.19.0
    /usr/bin/node           v20.19.0
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.31.0
    nodejs:
      Installed: 20.19.0-1nodesource1
      Candidate: 20.19.0-1nodesource1
      Version table:
     *** 20.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    raspy               raspy (version: 4.0.24, hostname: raspy         , alive, uptime: 68640)
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     6.1.4
    nodejs modules from github:     3
    +-- iobroker.mercedesme@0.2.3 (git+ssh://git@github.com/TA2k/ioBroker.mercedesme.git#127508de20b11a628957ab2478fbf590ef99cf9f)
    +-- iobroker.vw-connect@0.4.2 (git+ssh://git@github.com/TA2k/ioBroker.vw-connect.git#3bdf7271f809464125ed2ea67d46d1025d366f57)
    `-- iobroker.wolf-smartset@1.2.4 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.wolf-smartset.git#8e4c350d2730bf4dc1056c7314d57f2bb38038e8)
    Adapter State
      system.adapter.admin.0                  : admin                 : raspy                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.admin.1                  : admin                 : raspy                                    - disabled, port: 8089, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : raspy                                    -  enabled
      system.adapter.cloud.0                  : cloud                 : raspy                                    - disabled
    + system.adapter.discovery.0              : discovery             : raspy                                    -  enabled
      system.adapter.echarts.0                : echarts               : raspy                                    - disabled
      system.adapter.fritzdect.0              : fritzdect             : raspy                                    - disabled
      system.adapter.history.0                : history               : raspy                                    - disabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspy                                    -  enabled
    + system.adapter.javascript.0             : javascript            : raspy                                    -  enabled
      system.adapter.mercedesme.0             : mercedesme            : raspy                                    - disabled
      system.adapter.midea.0                  : midea                 : raspy                                    - disabled
    + system.adapter.modbus.0                 : modbus                : raspy                                    -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : raspy                                    -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.openweathermap.0         : openweathermap        : raspy                                    -  enabled
      system.adapter.shelly.0                 : shelly                : raspy                                    - disabled, port: 1882, bind: 0.0.0.0
      system.adapter.smartmeter.0             : smartmeter            : raspy                                    - disabled
    + system.adapter.tuya.0                   : tuya                  : raspy                                    -  enabled
      system.adapter.vis-history.0            : vis-history           : raspy                                    -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspy                                    -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : raspy                                    -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspy                                    -  enabled
      system.adapter.vis.0                    : vis                   : raspy                                    -  enabled
      system.adapter.vw-connect.0             : vw-connect            : raspy                                    - disabled
    + system.adapter.web.0                    : web                   : raspy                                    -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.wolf-smartset.0          : wolf-smartset         : raspy                                    -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.4.10   , installed 6.3.5  [Updatable]
    Adapter    "backitup"     : 3.0.31   , installed 2.6.19 [Updatable]
    Adapter    "cloud"        : 5.0.1    , installed 4.3.0  [Updatable]
    Adapter    "discovery"    : 5.0.0    , installed 3.1.0  [Updatable]
    Adapter    "echarts"      : 1.9.2    , installed 1.0.12 [Updatable]
    Adapter    "fritzdect"    : 2.5.11   , installed 2.2.6  [Updatable]
    Adapter    "history"      : 3.0.1    , installed 2.2.4  [Updatable]
    Adapter    "javascript"   : 8.8.3    , installed 6.1.4  [Updatable]
    Controller "js-controller": 7.0.6    , installed 4.0.24 [Updatable]
    Adapter    "midea"        : 0.0.7    , installed 0.0.7
    Adapter    "modbus"       : 6.3.2    , installed 5.0.11 [Updatable]
    Adapter    "mqtt"         : 6.1.2    , installed 4.0.7  [Updatable]
    Adapter    "openweathermap": 1.1.2   , installed 0.3.3  [Updatable]
    Adapter    "shelly"       : 8.5.1    , installed 6.3.1  [Updatable]
    Adapter    "smartmeter"   : 3.4.0    , installed 3.3.4  [Updatable]
    Adapter    "socketio"     : 6.7.1    , installed 4.2.0  [Updatable]
    Adapter    "tuya"         : 3.16.0   , installed 3.13.1 [Updatable]
    Adapter    "vis"          : 1.5.6    , installed 1.4.16 [Updatable]
    Adapter    "vis-icontwo"  : 1.11.0   , installed 0.93.0 [Updatable]
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.1  [Updatable]
    Adapter    "web"          : 6.2.5    , installed 4.3.0  [Updatable]
    Adapter    "wolf-smartset": 1.2.4    , installed 1.2.4
    Adapter    "ws"           : 2.6.2    , installed 1.3.0  [Updatable]
    Objects and States
    Objects:        2417
    States:         2075
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 114
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          30642      5488/cupsd
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       9573       1778/io.mqtt.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5009       567/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       5853       540/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       5863       540/iobroker.js-con
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       11453      1880/io.web.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          5011       567/sshd: /usr/sbin
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          30641      5488/cupsd
    udp        0      0 0.0.0.0:54490           0.0.0.0:*                           104        4865       373/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4863       373/avahi-daemon: r
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       9610       1793/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       9611       1793/io.tuya.0
    udp6       0      0 fe80::beae:f3f7:a77:546 :::*                                0          34254      461/NetworkManager
    udp6       0      0 :::5353                 :::*                                104        4864       373/avahi-daemon: r
    udp6       0      0 :::57614                :::*                                104        4866       373/avahi-daemon: r
    2025-03-22 10:44:51.381  - info: javascript.0 (1771) script.js.ABL_EMH1: disconnected from ABL
    2025-03-22 10:45:51.367  - info: javascript.0 (1771) script.js.ABL_EMH1: Warten auf Fahrzeug
    2025-03-22 10:45:51.368  - info: javascript.0 (1771) script.js.ABL_EMH1: Strom = 16 A
    2025-03-22 10:45:51.375  - info: javascript.0 (1771) script.js.ABL_EMH1: disconnected from ABL
    2025-03-22 10:46:00.076  - info: javascript.0 (1771) script.js.MI300-2: Response is 200
    2025-03-22 10:46:00.079  - info: javascript.0 (1771) script.js.MI300-1: Response is 200
    2025-03-22 10:46:51.367  - info: javascript.0 (1771) script.js.ABL_EMH1: Warten auf Fahrzeug
    2025-03-22 10:46:51.368  - info: javascript.0 (1771) script.js.ABL_EMH1: Strom = 16 A
    2025-03-22 10:46:51.374  - info: javascript.0 (1771) script.js.ABL_EMH1: disconnected from ABL
    2025-03-22 10:47:51.368  - info: javascript.0 (1771) script.js.ABL_EMH1: Warten auf Fahrzeug
    2025-03-22 10:47:51.369  - info: javascript.0 (1771) script.js.ABL_EMH1: Strom = 16 A
    2025-03-22 10:47:51.374  - info: javascript.0 (1771) script.js.ABL_EMH1: disconnected from ABL
    2025-03-22 10:48:00.083  - info: javascript.0 (1771) script.js.MI300-2: Response is 200
    2025-03-22 10:48:00.092  - info: javascript.0 (1771) script.js.MI300-1: Response is 200
    2025-03-22 10:48:51.360  - info: javascript.0 (1771) script.js.ABL_EMH1: Warten auf Fahrzeug
    2025-03-22 10:48:51.361  - info: javascript.0 (1771) script.js.ABL_EMH1: Strom = 16 A
    2025-03-22 10:48:51.369  - info: javascript.0 (1771) script.js.ABL_EMH1: disconnected from ABL
    2025-03-22 10:49:51.375  - info: javascript.0 (1771) script.js.ABL_EMH1: Warten auf Fahrzeug
    2025-03-22 10:49:51.376  - info: javascript.0 (1771) script.js.ABL_EMH1: Strom = 16 A
    2025-03-22 10:49:51.384  - info: javascript.0 (1771) script.js.ABL_EMH1: disconnected from ABL
    2025-03-22 10:50:00.068  - info: javascript.0 (1771) script.js.MI300-1: Response is 200
    2025-03-22 10:50:00.091  - info: javascript.0 (1771) script.js.MI300-2: Response is 200
    2025-03-22 10:50:51.375  - info: javascript.0 (1771) script.js.ABL_EMH1: Warten auf Fahrzeug
    2025-03-22 10:50:51.377  - info: javascript.0 (1771) script.js.ABL_EMH1: Strom = 16 A
    2025-03-22 10:50:51.385  - info: javascript.0 (1771) script.js.ABL_EMH1: disconnected from ABL
    iob diag has finished.
    Press any key for a summary
    @reinosmart sagte in Nach update startet admin nicht mehr:
    Ausschalten.
    1GB RAM ist erfahrungsgemäß mittlerweile auch nicht mehr gut verwendbar.
    Und die den ganzen alten Kram updaten...
    Immer und beständig!
    iob stop
    sudo apt udate
    sudo apt full-upgrade
    sudo reboot
    iob stop
    iob update
    iob upgrade self
    iob update
    iob upgrade all -y
    iob start
    iob start admin
    vielleicht helfen die ja irgendwie weiter?
    Nein.
    R 1 Antwort Letzte Antwort
      Ausschalten.
      iob stop
      sudo apt udate
      sudo reboot
      iob stop
      iob update
      iob upgrade self
      iob update
      iob upgrade all -y
      iob start
      iob start admin
      Nein.
      reinosmart
      Danke für deine Hilfe. Das hat mich schon ein gutes Stück weitergebracht.
      Leider wurde beim update des javascript Adapters abgebrochen.
      Update javascript from @6.1.4 to @8.8.3
      NPM version: 10.8.2
      Installing iobroker.javascript@8.8.3... (System call)
      client_loop: send disconnect: Connection reset
      Aber der Admin läuft wieder. Ein Versuch über die Weboberfläche den javascript Adapter nachzuinstallieren scheiterte.
      Aber ich konnte jetzt immerhin mit einigen screenshots die Adaptereinstellungen "sichern" um das System evtl. neu aufzusetzten. Ich fürchte die Blocklys sind für immer verschollen. Hab mir schon einen Raspy4 mit 4GRam bestellt.
      • R reinosmart
        NPM version: 10.8.2
        Da ist dir dein Netzwerk weggeknickt.
        Ein aktuelles
        iob diag
        schaut nun wie aus?
        • R Offline
          reinosmart
          Script v.2025-02-23
          *** BASE SYSTEM ***
                 Icon name: computer
                    Kernel: Linux 6.6.74+rpt-rpi-v8
              Architecture: arm64
          OS is similar to:
          Docker          : false
          Kernel          : aarch64
          Userland        : 64 bit
           16:39:00 up  4:20,  4 users,  load average: 2.32, 1.69, 0.91
          CPU threads: 4
          Current issues:
          ~ Under-voltage has occurred
                         Local time: Sat 2025-03-22 16:39:00 CET
                     Universal time: Sat 2025-03-22 15:39:00 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          iobroker3
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            951M        616M        201M        294K        195M        335M
          Swap:           536M        265M        271M
          Total:          1.5G        881M        473M
          Active iob-Instances:   7
                    907 M total memory
                    587 M used memory
                    402 M active memory
                    182 M inactive memory
                    192 M free memory
                     32 M buffer memory
                    153 M swap cache
                    511 M total swap
                    252 M used swap
                    259 M free swap
          top - 16:39:01 up  4:20,  4 users,  load average: 2.32, 1.69, 0.91
          Tasks: 202 total,   1 running, 201 sleeping,   0 stopped,   0 zombie
          %Cpu(s): 26.7 us,  6.7 sy,  0.0 ni, 53.3 id, 13.3 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :    907.2 total,    191.9 free,    588.0 used,    186.6 buff/cache
          MiB Swap:    512.0 total,    259.2 free,    252.8 used.    319.2 avail Mem
          *** FILESYSTEM ***
          /dev/mmcblk0p2 ext4       29G  8.4G   19G  32% /
          tmpfs          tmpfs     454M  156K  454M   1% /dev/shm
          /dev/mmcblk0p1 vfat      510M   67M  444M  14% /boot/firmware
          [Sat Mar 22 12:18:41 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=b5b55aeb-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
          [Sat Mar 22 12:18:45 2025] EXT4-fs (mmcblk0p2): mounted filesystem a36be96c-66be-4487-a7a6-0481bca99d89 ro with ordered data mode. Quota mode: none.
          [Sat Mar 22 12:18:46 2025] EXT4-fs (mmcblk0p2): re-mounted a36be96c-66be-4487-a7a6-0481bca99d89 r/w. Quota mode: none.
          /var:
          988M    /var/
          199M    /var/lib
          196M    /var/cache
          188M    /var/cache/apt
          Archived and active journals take up 79.8M in the file system.
          14M     /opt/iobroker/backups/
          464M    /opt/iobroker/iobroker-data/
          423M    /opt/iobroker/iobroker-data/files
          26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
          26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
          24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
          24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
          24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.70a15e1f.js.map
          USB-Devices by-id:
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          raspy               raspy (version: 7.0.6, hostname: raspy         , alive, uptime: 126)
          js-controller:  7.0.6
          admin:          7.4.10
          javascript:     "javascript" not found
          +-- iobroker.wolf-smartset@1.2.4 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.wolf-smartset.git#8e4c350d2730bf4dc1056c7314d57f2bb38038e8)
          Adapter State
          + system.adapter.admin.0                  : admin                 : raspy                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            system.adapter.backitup.0               : backitup              : raspy                                    - disabled
            system.adapter.discovery.0              : discovery             : raspy                                    - disabled
            system.adapter.vis-inventwo.0           : vis-inventwo          : raspy                                    - disabled
          + system.adapter.wolf-smartset.0          : wolf-smartset         : raspy                                    -  enabled
          + instance is alive
          Upgrade policy: none
          Adapter    "admin"        : 7.4.10   , installed 7.4.10
          Adapter    "echarts"      : 1.9.2    , installed 1.9.2
          Controller "js-controller": 7.0.6    , installed 7.0.6
          Adapter    "modbus"       : 6.3.2    , installed 6.3.2
          Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
          Adapter    "openweathermap": 1.1.2   , installed 1.1.2
          Adapter    "shelly"       : 8.5.1    , installed 8.5.1
          Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
          Adapter    "tuya"         : 3.16.0   , installed 3.16.0
          Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
          Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
          Adapter    "web"          : 6.2.5    , installed 6.2.5
          Objects and States
          Objects:        2449
          States:         2016
          Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
          Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
          Pending Updates: 0
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       46232      8837/iobroker.js-co
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       46227      8837/iobroker.js-co
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       49242      8878/io.mqtt.0
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          7340       542/cupsd
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5616       558/sshd: /usr/sbin
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       49418      9000/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       45499      8871/io.admin.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          5618       558/sshd: /usr/sbin
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          7339       542/cupsd
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6643       388/avahi-daemon: r
          udp        0      0 0.0.0.0:57070           0.0.0.0:*                           104        6645       388/avahi-daemon: r
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       46451      8893/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       46452      8893/io.tuya.0
          udp6       0      0 :::5353                 :::*                                104        6644       388/avahi-daemon: r
          udp6       0      0 fe80::beae:f3f7:a77:546 :::*                                0          7590       496/NetworkManager
          udp6       0      0 :::58427                :::*                                104        6646       388/avahi-daemon: r
          2025-03-22 16:37:59.795  - info: tuya.0 (8893) bf93c1131b5f453f12owfw: Error on Reconnect (1): connect EHOSTUNREACH 192.168.178.46:6668
          2025-03-22 16:37:59.942  - info: tuya.0 (8893) bfcc3cfbcb5414846ecian: Do not connect locally to device
          2025-03-22 16:38:00.511  - info: admin.0 (8871) ==> Connected system.user.admin from ::ffff:192.168.178.76
          2025-03-22 16:38:01.140  - info: tuya.0 (8893) bfa6d6adaccd450a39tdm2: Error on Reconnect (1): connect EHOSTUNREACH 192.168.178.22:6668
          2025-03-22 16:38:01.162  - info: web.0 (9000) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.19.0, js-controller: 7.0.6
          2025-03-22 16:38:02.222  - info: web.0 (9000) socket.io server listening on port 8082
          2025-03-22 16:38:02.245  - info: web.0 (9000) http server listening on port 8082
          2025-03-22 16:38:02.578  - info: tuya.0 (8893) bfd7236c79acf76e92joff: Error on Reconnect (1): connect EHOSTUNREACH 192.168.178.45:6668
          2025-03-22 16:38:03.228  - info: vis.0 (8993) Terminated (NO_ERROR): Without reason
          2025-03-22 16:38:04.571  - info: host.raspy instance system.adapter.vis.0 terminated while should be started once
          2025-03-22 16:38:12.966  - info: mqtt.0 (8878) Client [ESP8266-4_0] connected with secret 1742657892922_8591
          2025-03-22 16:38:13.814  - info: mqtt.0 (8878) Client [ESP8266-4_0] subscribes on "ESP8266-4/#" with regex /^ESP8266-4\..*/
          2025-03-22 16:38:13.816  - info: mqtt.0 (8878) Client [ESP8266-4_0] subscribes on "ESP8266-4/#"  with regex /^mqtt\.0\.ESP8266-4\..*/
          2025-03-22 16:38:14.017  - info: mqtt.0 (8878) Client [ESP8266-4_0] publishOnSubscribe send all known states
          2025-03-22 16:38:22.871  - info: tuya.0 (8893) bf93c1131b5f453f12owfw: Error on Reconnect (3): connect EHOSTUNREACH 192.168.178.46:6668
          2025-03-22 16:38:24.211  - info: tuya.0 (8893) bfa6d6adaccd450a39tdm2: Error on Reconnect (3): connect EHOSTUNREACH 192.168.178.22:6668
          2025-03-22 16:38:25.653  - info: tuya.0 (8893) bfd7236c79acf76e92joff: Error on Reconnect (3): connect EHOSTUNREACH 192.168.178.45:6668
          2025-03-22 16:38:30.198  - info: openweathermap.0 (8986) Terminated (NO_ERROR): Without reason
          2025-03-22 16:38:30.817  - info: host.raspy instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
          2025-03-22 16:39:05.939  - info: tuya.0 (8893) bf93c1131b5f453f12owfw: Error on Reconnect (5): connect EHOSTUNREACH 192.168.178.46:6668
          2025-03-22 16:39:07.283  - info: tuya.0 (8893) bfa6d6adaccd450a39tdm2: Error on Reconnect (5): connect EHOSTUNREACH 192.168.178.22:6668
          2025-03-22 16:39:08.723  - info: tuya.0 (8893) bfd7236c79acf76e92joff: Error on Reconnect (5): connect EHOSTUNREACH 192.168.178.45:6668
          2025-03-22 16:40:09.014  - info: tuya.0 (8893) bf93c1131b5f453f12owfw: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.46:6668
          2025-03-22 16:40:10.355  - info: tuya.0 (8893) bfa6d6adaccd450a39tdm2: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.22:6668
          2025-03-22 16:40:11.794  - info: tuya.0 (8893) bfd7236c79acf76e92joff: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.45:6668
          • R reinosmart
            Script v.2025-02-23
            *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
            OS is similar to:
            Docker          : false
            Kernel          : aarch64
            Userland        : 64 bit
            CPU threads: 4
            Current issues:
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            iobroker3
            iobroker
            HOME=/home/iobroker
            Desktop:
            Terminal:       tty
            *** MEMORY ***
                      907 M total memory
                      587 M used memory
                      402 M active memory
                      192 M free memory
                       32 M buffer memory
                      153 M swap cache
                      511 M total swap
                      252 M used swap
                      259 M free swap
            *** FILESYSTEM ***
            /var:
            988M    /var/
            199M    /var/lib
            196M    /var/cache
            188M    /var/cache/apt
            USB-Devices by-id:
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            admin:          7.4.10
            Adapter State
            + instance is alive
            Objects and States
            Objects:        2449
            States:         2016
            Pending Updates: 0
            Solltest du doch AUSSCHALTEN.
            Und hau die drei Adapter-Updates noch rein.
              reinosmart
              der Adapter Fritzbox lässt sich nicht upgraden
              iobroker3@raspy:~ $ iob upgrade fritzbox
              Adapter "fritzbox"       is not installed.
              iobroker3@raspy:~ $ iob install fritzdect
              adapter "fritzdect" already installed. Use "upgrade" to upgrade to a newer version.
              iobroker3@raspy:~ $
              und wo schaltet man den Display-server aus?
              mcm1957M Thomas BraunT 2 Antworten Letzte Antwort
              • R reinosmart
                iobroker3@raspy:~ $
                mcm1957M Offline
                mcm1957M Offline
                mcm1957
                Edit:
                Du versucht FRITZBOX zu aktualisiseren
                Das Update steht für FRITZDECT an
                Support Repositoryverwaltung.
                LESEN - gute Forenbeitrage
                • R reinosmart
                  iobroker3@raspy:~ $
                  Geht u.a. per
                  iob fix
                  Adapterupdates:
                  iob update
                  iob upgrade all
                    Geht u.a. per
                    iob fix
                    Adapterupdates:
                    iob update
                    iob upgrade all
                    reinosmart
                    Es geschehen noch Wunder. Nach gefühlten 20x diag und 10x fix ließ sich der javascript Adapter installieren und alle Scripte und Blocklys waren wieder da.
                    Ich möchte mich nochmal ganz herzlich für deine Hilfe bedanken.
                    • R reinosmart
                      @reinosmart
                      iob diag
                      ändert nichts am Setup, ist eine reine Darstellung.
                      Ist denn jetzt alles 'auf Stand'?
                        @reinosmart
                        iob diag
                        reinosmart
                        Der Javascript Adapter lässt sich immer noch nicht updaten, genauso zickig ist fritzdect.
                        Aber der iob läuft und wenn der raspy4 eintrudelt werde ich das System neu aufsetzen, der aktuellen Installation traue ich nicht so recht.
                        ```bash
                        Script v.2025-02-23
                        *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                        OS is similar to:
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : 64 bit
                         17:09:00 up  3:53,  3 users,  load average: 0.97, 0.34, 0.19
                        CPU threads: 4
                        Current issues:
                                       Local time: Sun 2025-03-23 17:09:00 CET
                                   Universal time: Sun 2025-03-23 16:09:00 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        iobroker3
                        iobroker
                        HOME=/home/iobroker
                        Display-Server: false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:            951M        681M        129M         16K        207M        269M
                        Swap:           536M        314M        222M
                        Total:          1.5G        995M        351M
                                  907 M total memory
                                  650 M used memory
                                  494 M active memory
                                  180 M inactive memory
                                  122 M free memory
                                   39 M buffer memory
                                  159 M swap cache
                                  511 M total swap
                                  299 M used swap
                                  212 M free swap
                        top - 17:09:01 up  3:53,  3 users,  load average: 0.97, 0.34, 0.19
                        Tasks: 167 total,   1 running, 166 sleeping,   0 stopped,   0 zombie
                        %Cpu(s): 18.2 us,  9.1 sy,  0.0 ni, 63.6 id,  9.1 wa,  0.0 hi,  0.0 si,  0.0 st
                        MiB Mem :    907.2 total,    120.3 free,    652.2 used,    199.0 buff/cache
                        MiB Swap:    512.0 total,    212.4 free,    299.6 used.    255.0 avail Mem
                        *** FILESYSTEM ***
                        tmpfs          tmpfs      91M  1.1M   90M   2% /run
                        /dev/mmcblk0p2 ext4       29G  8.8G   18G  33% /
                        tmpfs          tmpfs     454M  8.0K  454M   1% /dev/shm
                        tmpfs          tmpfs      91M   44K   91M   1% /run/user/1000
                        [Sun Mar 23 13:15:06 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=b5b55aeb-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
                        [Sun Mar 23 13:15:10 2025] EXT4-fs (mmcblk0p2): mounted filesystem a36be96c-66be-4487-a7a6-0481bca99d89 ro with ordered data mode. Quota mode: none.
                        [Sun Mar 23 13:15:12 2025] EXT4-fs (mmcblk0p2): re-mounted a36be96c-66be-4487-a7a6-0481bca99d89 r/w. Quota mode: none.
                        /var:
                        1021M   /var/
                        199M    /var/lib
                        196M    /var/cache
                        188M    /var/cache/apt
                        Archived and active journals take up 111.9M in the file system.
                        36M     /opt/iobroker/backups/
                        546M    /opt/iobroker/iobroker-data/
                        490M    /opt/iobroker/iobroker-data/files
                        USB-Devices by-id:
                        zigbee.X
                        Extended Pan ID:
                        *** MASKED ***
                        Pan ID:
                        *** MASKED ***
                        Channel:
                        *** MASKED ***
                        Network Key:
                        *** MASKED ***
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        raspy               raspy (version: 7.0.6, hostname: raspy         , alive, uptime: 12037)
                        admin:          7.4.10
                        javascript:     6.1.4
                        Adapter State
                        + instance is alive
                        Adapter    "backitup"     : 3.0.31   , installed 3.0.31
                        Objects and States
                        Objects:        2246
                        States:         1827
                        Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                        Pending Updates: 1
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7191       542/sshd: /usr/sbin
                        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          6195       529/cupsd
                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       20461      3668/io.mqtt.0
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       20225      3628/iobroker.js-co
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       20220      3628/iobroker.js-co
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          7193       542/sshd: /usr/sbin
                        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          6194       529/cupsd
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       19343      3646/io.admin.0
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       23629      3805/io.web.0
                        udp        0      0 0.0.0.0:52917           0.0.0.0:*                           104        4019       400/avahi-daemon: r
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4017       400/avahi-daemon: r
                        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       21235      3718/io.tuya.0
                        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       21236      3718/io.tuya.0
                        udp6       0      0 :::48835                :::*                                104        4020       400/avahi-daemon: r
                        udp6       0      0 :::5353                 :::*                                104        4018       400/avahi-daemon: r
                        udp6       0      0 fe80::beae:f3f7:a77:546 :::*                                0          6365       500/NetworkManager
                        2025-03-23 17:05:02.388  - info: javascript.0 (3929) script.js.ABL_EMH1: disconnected from ABL
                        2025-03-23 17:06:00.089  - info: javascript.0 (3929) script.js.MI300-1: Response is 200
                        2025-03-23 17:06:00.104  - info: javascript.0 (3929) script.js.MI300-2: Response is 200
                        2025-03-23 17:06:02.376  - info: javascript.0 (3929) script.js.ABL_EMH1: Warten auf Fahrzeug
                        2025-03-23 17:06:02.377  - info: javascript.0 (3929) script.js.ABL_EMH1: Strom = 16 A
                        2025-03-23 17:06:02.382  - info: javascript.0 (3929) script.js.ABL_EMH1: disconnected from ABL
                        2025-03-23 17:07:02.376  - info: javascript.0 (3929) script.js.ABL_EMH1: Warten auf Fahrzeug
                        2025-03-23 17:07:02.378  - info: javascript.0 (3929) script.js.ABL_EMH1: Strom = 16 A
                        2025-03-23 17:07:02.386  - info: javascript.0 (3929) script.js.ABL_EMH1: disconnected from ABL
                        2025-03-23 17:08:00.119  - info: javascript.0 (3929) script.js.MI300-2: Response is 200
                        2025-03-23 17:08:00.134  - info: javascript.0 (3929) script.js.MI300-1: Response is 200
                        2025-03-23 17:08:02.378  - info: javascript.0 (3929) script.js.ABL_EMH1: Warten auf Fahrzeug
                        2025-03-23 17:08:02.379  - info: javascript.0 (3929) script.js.ABL_EMH1: Strom = 16 A
                        2025-03-23 17:08:02.388  - info: javascript.0 (3929) script.js.ABL_EMH1: disconnected from ABL
                        2025-03-23 17:09:02.378  - info: javascript.0 (3929) script.js.ABL_EMH1: Warten auf Fahrzeug
                        2025-03-23 17:09:02.379  - info: javascript.0 (3929) script.js.ABL_EMH1: Strom = 16 A
                        2025-03-23 17:09:02.386  - info: javascript.0 (3929) script.js.ABL_EMH1: disconnected from ABL
                        2025-03-23 17:10:00.083  - info: javascript.0 (3929) script.js.MI300-1: Response is 200
                        2025-03-23 17:10:00.085  - info: javascript.0 (3929) script.js.MI300-2: Response is 200
                        2025-03-23 17:10:02.380  - info: javascript.0 (3929) script.js.ABL_EMH1: Warten auf Fahrzeug
                        2025-03-23 17:10:02.381  - info: javascript.0 (3929) script.js.ABL_EMH1: Strom = 16 A
                        2025-03-23 17:10:02.387  - info: javascript.0 (3929) script.js.ABL_EMH1: disconnected from ABL
                        2025-03-23 17:11:02.375  - info: javascript.0 (3929) script.js.ABL_EMH1: Warten auf Fahrzeug
                        2025-03-23 17:11:02.378  - info: javascript.0 (3929) script.js.ABL_EMH1: Strom = 16 A
                        2025-03-23 17:11:02.387  - info: javascript.0 (3929) script.js.ABL_EMH1: disconnected from ABL
                        • R reinosmart
                          ```bash
                          Script v.2025-02-23
                          *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                          OS is similar to:
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : 64 bit
                          CPU threads: 4
                          Current issues:
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          iobroker3
                          iobroker
                          HOME=/home/iobroker
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                                    907 M total memory
                                    650 M used memory
                                    494 M active memory
                                    122 M free memory
                                     39 M buffer memory
                                    159 M swap cache
                                    511 M total swap
                                    299 M used swap
                                    212 M free swap
                          *** FILESYSTEM ***
                          /var:
                          1021M   /var/
                          199M    /var/lib
                          196M    /var/cache
                          188M    /var/cache/apt
                          USB-Devices by-id:
                          zigbee.X
                          Extended Pan ID:
                          *** MASKED ***
                          Pan ID:
                          *** MASKED ***
                          Channel:
                          *** MASKED ***
                          Network Key:
                          *** MASKED ***
                          /usr/bin/npm            10.8.2
                          /usr/bin/npx            10.8.2
                          nodejs:
                            Version table:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          admin:          7.4.10
                          javascript:     6.1.4
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        2246
                          States:         1827
                          Pending Updates: 1
                          @reinosmart
                          Hast du auch ein passendes Netzteil dazu bestellt? Da klemmt es wohl im Moment.
                            @reinosmart
                            reinosmart
                            ja ein Hutschienennetzteil 3A, der ganze Raspy sitzt bei mir im Sicherungskasten.
                            • R reinosmart
                              Das ist offensichtlich zu schwach auf der Brust.
                                reinosmart
                                entspricht aber den Spezifikationen.
                                Stromversorgung
                                5V/3,0A DC über USB Type C Buchse - (Ein qualitativ hochwertiges 2,5A-Netzteil vom Raspberry Pi 3 / 3B+ kann mittels Adapter (siehe unter Zubehör) verwendet werden, wenn nachgeschaltete USB-Peripheriegeräte insgesamt weniger als 500mA verbrauchen.)
                                • R reinosmart
                                  Stromversorgung
                                  @reinosmart
                                  Mag ja sein. Dennoch:
                                  Der neue Raspberry wird bestimmt nicht weniger brauchen.
                                  • R reinosmart
                                    Stromversorgung
                                    Stromversorgung
                                    ...liefert meist 5.1V
                                    Schließlich ist die Meldung
                                    @thomas-braun sagte in Nach update startet admin nicht mehr:
                                    nicht Current
                                    Dann miss mal die echte anliegende Spannung unter Last
                                      Stromversorgung
                                      nicht Current
                                      reinosmart
                                      @homoran said in Nach update startet admin nicht mehr:
                                      ich kann ja erstmal ein Labornetzteil nehmen. Aber der Raspy4 wird ja auch im Set mit 3A Netzteil verkauft.
                                      • R reinosmart
                                        @reinosmart
                                        Zu den Feinheiten bei den Netzteilen siehe:
                                        https://techtest.org/netzteile-fuer-das-raspberry-pi-4-im-vergleich-welches-ist-das-beste-und-effizienteste/
                                        und
                                        https://www.datenreise.de/raspberry-pi-stromversorgung-netzteil-empfehlung/
                                        • R reinosmart
                                          nochmal: es geht um die Spannung, nicht die Stromstärke.
