  4. [gelöst]yr.no Wetter Adapter "Error while requesting data"
  • Weihnachtsangebot 2025! 🎄
    2.5k
wetteryr adapter
17 Beiträge 6 Kommentatoren 1.6k Aufrufe 3 Watching
    Darth2010
    schrieb am zuletzt editiert von Darth2010
    Fehlerbeschreibung:
    Nachdem der DasWetter Adapter nicht mehr funktioniert, wollte ich yr.no Wetter ausprobieren.
    Nach der Installation, Konfiguration und Start des Adapter liefert das Log folgende Einträge:
    yr.0 81859	2025-03-20 16:21:52.106	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    yr.0 81859	2025-03-20 16:21:52.106	debug	Plugin sentry destroyed
    yr.0 81859	2025-03-20 16:21:52.105	debug	Update of data done, existing ...
    yr.0 81859	2025-03-20 16:21:52.105	info	Data updated.
    yr.0 81859	2025-03-20 16:21:52.105	info	Please check your settings!
    yr.0 81859	2025-03-20 16:21:52.104	info	Error while requesting data:
    yr.0 81859	2025-03-20 16:21:52.028	debug	Get forecast from: https://aa0465pwwdn1nx8wo.api.met.no/weatherapi/locationforecast/2.0/compact?lat=7&lon=53&altitude=74
    yr.0 81859	2025-03-20 16:21:28.685	debug	Delay execution by 23339ms to better spread API calls
    yr.0 81859	2025-03-20 16:21:28.684	debug	Configured version: {"val":"5.3.0","ack":true,"ts":1742481262686,"q":0,"from":"system.adapter.yr.0","user":"system.user.admin","lc":1742481262686}
    yr.0 81859	2025-03-20 16:21:28.669	info	longitude/longitude will be set by self-Config - longitude: 6.757311447027663 latitude: 50.73762218877986
    yr.0 81859	2025-03-20 16:21:28.649	info	starting. Version 5.3.0 in /opt/iobroker/node_modules/iobroker.yr, node: v20.18.3, js-controller: 7.0.6
    yr.0 81859	2025-03-20 16:21:28.577	debug	Plugin sentry Do not initialize Plugin (enabled=false)
    yr.0 81859	2025-03-20 16:21:28.561	debug	States connected to redis: 127.0.0.1:6379
    yr.0 81859	2025-03-20 16:21:28.557	debug	States create User PubSub Client
    yr.0 81859	2025-03-20 16:21:28.556	debug	States create System PubSub Client
    yr.0 81859	2025-03-20 16:21:28.553	debug	Redis States: Use Redis connection: 127.0.0.1:6379
    yr.0 81859	2025-03-20 16:21:28.528	debug	Objects connected to redis: 127.0.0.1:6379
    yr.0 81859	2025-03-20 16:21:28.525	debug	Objects client initialize lua scripts
    yr.0 81859	2025-03-20 16:21:28.498	debug	Objects create User PubSub Client
    yr.0 81859	2025-03-20 16:21:28.497	debug	Objects create System PubSub Client
    yr.0 81859	2025-03-20 16:21:28.496	debug	Objects client ready ... initialize now
    yr.0 81859	2025-03-20 16:21:28.482	debug	Redis Objects: Use Redis connection: 127.0.0.1:6379
    Entsprechend enthalten die Datenpunkte des Adapters auch keine Daten:
    Wenn man den Link jedoch per Postman oder Browser abruft kommt ein "korrektes" JSON zurück:
    response.json
    Hat sonst noch jemand dieses Problem?
    Infos zum System:
    • Adaptername: yr.no Wetter
    • Adapterversion: 5.3.0
    • js-controller Version: 7.0.6
    • Admin Version: 7.4.10
    • Hardwaresystem: Proxmox LXC mit 1 Cores, 4 GB RAM und 10 GB SSD auf (Lenovo ThinkCentre M700 Tiny i5-6500T 4x2.5GHz mit 16 GB RAM)
    • Arbeitsspeicher: 4GB
    • Festplattenart: SSD
    • Betriebssystem: Ububtu 22.04
    • Nodejs-Version: v20.18.3
    • NPM-Version: 10.8.2
    • Installationsart: Skript
    • Image, Docker genutzt: Nein
    iob diag:
    bash
    Script v.2025-02-23
    *** BASE SYSTEM ***
    Static hostname: iobroker-master
          Icon name: computer-container
            Chassis: container
     Virtualization: lxc
    Operating System: Ubuntu 22.04.5 LTS
             Kernel: Linux 6.8.12-8-pve
       Architecture: x86-64
    OS is similar to: debian
    model name      : Intel(R) Core(TM) i5-6500T CPU @ 2.50GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
    16:31:43 up 23 days,  8:53,  2 users,  load average: 2.70, 1.62, 1.34
    CPU threads: 1
    *** LIFE CYCLE STATUS ***
    Operating System codenamed 'jammy' is an aging Ubuntu release! Please upgrade to the latest LTS release 'noble' in due time!
    *** TIME AND TIMEZONES ***
                  Local time: Thu 2025-03-20 16:31:43 CET
              Universal time: Thu 2025-03-20 15:31:43 UTC
                    RTC time: n/a
                 NTP service: inactive
             RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    darth
    HOME=/home/darth
    GROUPS=darth sudo iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video redis
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
    *** MEMORY ***
    Mem:            4.1G        2.9G        973M        5.0M        243M        1.2G
    Swap:             0B          0B          0B
    Total:          4.1G        2.9G        973M
    Active iob-Instances:   28
            4096 M total memory
            2879 M used memory
            1476 M active memory
            1546 M inactive memory
             972 M free memory
               0 M buffer memory
             243 M swap cache
               0 M total swap
               0 M used swap
               0 M free swap
    top - 16:31:43 up 23 days,  8:53,  2 users,  load average: 2.70, 1.62, 1.34
    Tasks:  60 total,   1 running,  59 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  6.7 sy,  0.0 ni, 93.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   4096.0 total,    972.0 free,   2879.9 used,    244.1 buff/cache
    MiB Swap:      0.0 total,      0.0 free,      0.0 used.   1211.1 avail Mem
    *** FAILED SERVICES ***
     UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    dmesg: read kernel buffer failed: Operation not permitted
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--110--disk--0 ext4      9.8G  7.1G  2.2G  77% /
    /dev/mapper/pve-root             ext4       94G   55G   35G  62% /shared
    none                             tmpfs     492K  4.0K  488K   1% /dev
    efivarfs                         efivarfs  128K  101K   23K  82% /sys/firmware/efi/efivars
    tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
    tmpfs                            tmpfs     3.2G  144K  3.2G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    log2ram                          tmpfs     500M  4.7M  496M   1% /var/log
    log2ram                          tmpfs     500M  252K  500M   1% /opt/iobroker/log
    tmpfs                            tmpfs     1.6G     0  1.6G   0% /run/user/1001
    Show mounted filesystems:
    TARGET                  SOURCE                                              FSTYPE OPTIONS
    /                       /dev/mapper/pve-vm--110--disk--0                    ext4   rw,relatime,stripe=16
    |-/var/hdd.log          /dev/mapper/pve-vm--110--disk--0[/var/log]          ext4   rw,relatime,stripe=16
    |-/shared               /dev/mapper/pve-root[/home/darth/shared]            ext4   rw,relatime,errors=remount-ro
    `-/opt/iobroker/hdd.log /dev/mapper/pve-vm--110--disk--0[/opt/iobroker/log] ext4   rw,relatime,stripe=16
    /var:
    1.2G    /var/
    934M    /var/lib
    582M    /var/lib/redis
    220M    /var/cache
    213M    /var/lib/apt/lists
    Archived and active journals take up 512.0K in the file system.
    /opt/iobroker/backups:
    96M     /opt/iobroker/backups/
    4.0K    /opt/iobroker/backups/redistmp
    /opt/iobroker/iobroker-data:
    406M    /opt/iobroker/iobroker-data/
    219M    /opt/iobroker/iobroker-data/files
    137M    /opt/iobroker/iobroker-data/backup-objects
    67M     /opt/iobroker/iobroker-data/files/javascript.admin
    48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
    27M     /opt/iobroker/iobroker-data/objects.jsonl
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    12M     /opt/iobroker/iobroker-data/objects.json.migrated
    12M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    9.9M    /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.3
    /usr/bin/node           v20.18.3
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.30.0
    nodejs:
     Installed: 20.18.3-1nodesource1
     Candidate: 20.18.3-1nodesource1
     Version table:
    *** 20.18.3-1nodesource1 1001
           500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
        20.18.2-1nodesource1 1001
        20.18.1-1nodesource1 1001
        20.18.0-1nodesource1 1001
        20.17.0-1nodesource1 1001
        20.16.0-1nodesource1 1001
        20.15.1-1nodesource1 1001
        20.15.0-1nodesource1 1001
        20.14.0-1nodesource1 1001
        20.13.1-1nodesource1 1001
        20.13.0-1nodesource1 1001
        20.12.2-1nodesource1 1001
        20.12.1-1nodesource1 1001
        20.12.0-1nodesource1 1001
        20.11.1-1nodesource1 1001
        20.11.0-1nodesource1 1001
        20.10.0-1nodesource1 1001
        20.9.0-1nodesource1 1001
        20.8.1-1nodesource1 1001
        20.8.0-1nodesource1 1001
        20.7.0-1nodesource1 1001
        20.6.1-1nodesource1 1001
        20.6.0-1nodesource1 1001
        20.5.1-1nodesource1 1001
        20.5.0-1nodesource1 1001
        20.4.0-1nodesource1 1001
        20.3.1-1nodesource1 1001
        20.3.0-1nodesource1 1001
        20.2.0-1nodesource1 1001
        20.1.0-1nodesource1 1001
        20.0.0-1nodesource1 1001
        12.22.9~dfsg-1ubuntu3.6 500
           500 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
           500 http://archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
        12.22.9~dfsg-1ubuntu3 500
           500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    At least one iobroker host is running.
    Objects type: redis
    States  type: redis
    Hosts:
    iobroker-master     iobroker-master (version: 7.0.6, hostname: iobroker-master, alive, uptime: 2019220)
    iobroker-slave-Flur iobroker-slave-Flur (version: 7.0.6, hostname: iobroker-slave-Flur, alive, uptime: 4174563)
    Core adapters versions
    admin:          7.4.10
    javascript:     8.8.3
    nodejs modules from github:     1
    | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker-master                          -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
     system.adapter.alias-manager.0          : alias-manager         : iobroker-master                          -  enabled
     system.adapter.backitup.0               : backitup              : iobroker-master                          - disabled
     system.adapter.cloud.0                  : cloud                 : iobroker-master                          - disabled
     system.adapter.daswetter.0              : daswetter             : iobroker-master                          - disabled
     system.adapter.device-reminder.0        : device-reminder       : iobroker-master                          - disabled
     system.adapter.discovery.0              : discovery             : iobroker-master                          - disabled
    + system.adapter.email.0                  : email                 : iobroker-master                          -  enabled
     system.adapter.feiertage.0              : feiertage             : iobroker-master                          -  enabled
     system.adapter.flot.0                   : flot                  : iobroker-master                          - disabled
     system.adapter.hikvision-alarmserver.0  : hikvision-alarmserver : iobroker-master                          - disabled, port: 7070, bind: 192.168.12.34
     system.adapter.history.0                : history               : iobroker-master                          - disabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker-master                          -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-master                          -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-master                          -  enabled, port: 0
     system.adapter.ical.0                   : ical                  : iobroker-master                          -  enabled
     system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker-master                          - disabled
    + system.adapter.javascript.0             : javascript            : iobroker-master                          -  enabled
    + system.adapter.jeelink.0                : jeelink               : iobroker-slave-Flur                      -  enabled
     system.adapter.lgtv.0                   : lgtv                  : iobroker-master                          - disabled
     system.adapter.linux-control.0          : linux-control         : iobroker-master                          - disabled
    + system.adapter.logparser.0              : logparser             : iobroker-master                          -  enabled
     system.adapter.material.0               : material              : iobroker-master                          - disabled
     system.adapter.mobile.0                 : mobile                : iobroker-master                          - disabled
    + system.adapter.modbus.0                 : modbus                : iobroker-master                          -  enabled
    + system.adapter.modbus.1                 : modbus                : iobroker-master                          -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker-master                          -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.nut.0                    : nut                   : iobroker-master                          -  enabled
    + system.adapter.ping.0                   : ping                  : iobroker-master                          -  enabled
    + system.adapter.plenticore.0             : plenticore            : iobroker-master                          -  enabled, port: 80
    + system.adapter.proxmox.0                : proxmox               : iobroker-master                          -  enabled, port: 8006
    + system.adapter.proxmox.1                : proxmox               : iobroker-master                          -  enabled, port: 8006
    + system.adapter.proxmox.2                : proxmox               : iobroker-master                          -  enabled, port: 8006
    + system.adapter.scenes.0                 : scenes                : iobroker-master                          -  enabled
     system.adapter.schoolfree.0             : schoolfree            : iobroker-master                          -  enabled
     system.adapter.shelly.0                 : shelly                : iobroker-master                          - disabled, port: 1883, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : iobroker-master                          -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartmeter.0             : smartmeter            : iobroker-master                          -  enabled
    + system.adapter.smartmeter.1             : smartmeter            : iobroker-master                          -  enabled
    + system.adapter.socketio.0               : socketio              : iobroker-master                          -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : iobroker-master                          -  enabled, port: 1884, bind: 0.0.0.0
    + system.adapter.sql.0                    : sql                   : iobroker-master                          -  enabled, port: 3306
     system.adapter.synology.0               : synology              : iobroker-master                          - disabled, port: 5001
    + system.adapter.tr-064.0                 : tr-064                : iobroker-master                          -  enabled
    + system.adapter.unifi.0                  : unifi                 : iobroker-master                          -  enabled
     system.adapter.viessmann.0              : viessmann             : iobroker-master                          - disabled, port: 3002
     system.adapter.vis-history.0            : vis-history           : iobroker-master                          - disabled
     system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker-master                          - disabled
     system.adapter.vis.0                    : vis                   : iobroker-master                          - disabled
    + system.adapter.web.0                    : web                   : iobroker-master                          -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
     system.adapter.yr.0                     : yr                    : iobroker-master                          - disabled
     system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker-master                          - disabled
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name            │ url                                                     │ auto upgrade │
    │ 0       │ 'stable'        │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'Beta (latest)' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.4.10   , installed 7.4.10
    Adapter    "alias-manager": 2.0.0    , installed 2.0.0
    Adapter    "backitup"     : 3.0.31   , installed 3.0.31
    Adapter    "daswetter"    : 3.2.2    , installed 3.2.2
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Adapter    "jeelink"      : 1.2.5    , installed 1.2.5
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Adapter    "zigbee2mqtt"  : 3.0.2    , installed 3.0.2
    Objects and States
    Objects:        6615
    States:         5438
    2025-03-20 16:21:28.557  - debug: yr.0 (81859) States create User PubSub Client
    2025-03-20 16:21:28.561  - debug: yr.0 (81859) States connected to redis: 127.0.0.1:6379
    2025-03-20 16:21:28.577  - debug: yr.0 (81859) Plugin sentry Do not initialize Plugin (enabled=false)
    2025-03-20 16:21:28.649  - info: yr.0 (81859) starting. Version 5.3.0 in /opt/iobroker/node_modules/iobroker.yr, node: v20.18.3, js-controller: 7.0.6
    2025-03-20 16:21:28.669  - info: yr.0 (81859) longitude/longitude will be set by self-Config - longitude: 6.457311447027663 latitude: 50.63762218877986
    2025-03-20 16:21:28.684  - debug: yr.0 (81859) Configured version: {"val":"5.3.0","ack":true,"ts":1742481262686,"q":0,"from":"system.adapter.yr.0","user":"system.user.admin","lc":1742481262686}
    2025-03-20 16:21:28.685  - debug: yr.0 (81859) Delay execution by 23339ms to better spread API calls
    2025-03-20 16:21:52.028  - debug: yr.0 (81859) Get forecast from: https://aa0465pwwdn1nx8wo.api.met.no/weatherapi/locationforecast/2.0/compact?lat=5&lon=6.&altitude=255
    2025-03-20 16:21:52.104  - info: yr.0 (81859) Error while requesting data:
    2025-03-20 16:21:52.105  - info: yr.0 (81859) Please check your settings!
    2025-03-20 16:21:52.105  - info: yr.0 (81859) Data updated.
    2025-03-20 16:21:52.105  - debug: yr.0 (81859) Update of data done, existing ...
    2025-03-20 16:21:52.106  - debug: yr.0 (81859) Plugin sentry destroyed
    2025-03-20 16:21:52.106  - info: yr.0 (81859) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    MOD-EDIT: private Daten entfernt
    Darth
    HomoranH FredFF T 4 Antworten Letzte Antwort
    • D Darth2010
      Fehlerbeschreibung:
      response.json
      Infos zum System:
      iob diag:
      bash
      Script v.2025-02-23
      *** BASE SYSTEM ***
              Chassis: container
       Virtualization: lxc
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 1
                      RTC time: n/a
               RTC in local TZ: no
      darth
      HOME=/home/darth
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:             0B          0B          0B
              4096 M total memory
              2879 M used memory
               972 M free memory
                 0 M buffer memory
               243 M swap cache
                 0 M total swap
                 0 M used swap
                 0 M free swap
      *** FILESYSTEM ***
      /var:
      1.2G    /var/
      934M    /var/lib
      582M    /var/lib/redis
      220M    /var/cache
      USB-Devices by-id:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
       Version table:
      ioBroker Status
      Objects type: redis
      States  type: redis
      Hosts:
      admin:          7.4.10
      javascript:     8.8.3
      Adapter State
      + instance is alive
      Objects and States
      Objects:        6615
      States:         5438
      Darth
      @darth2010 Das dürfte kein Bug von ioBroker sein!
      ich bin zwar nicht das Maß aller Dinge :grin:
      aber bei mir ist alles aktuell
      • D Darth2010
        Fehlerbeschreibung:
        response.json
        Infos zum System:
        iob diag:
        bash
        Script v.2025-02-23
        *** BASE SYSTEM ***
                Chassis: container
         Virtualization: lxc
        Docker          : false
        Kernel          : x86_64
        Userland        : 64 bit
        CPU threads: 1
                        RTC time: n/a
                 RTC in local TZ: no
        darth
        HOME=/home/darth
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:             0B          0B          0B
                4096 M total memory
                2879 M used memory
                 972 M free memory
                   0 M buffer memory
                 243 M swap cache
                   0 M total swap
                   0 M used swap
                   0 M free swap
        *** FILESYSTEM ***
        /var:
        1.2G    /var/
        934M    /var/lib
        582M    /var/lib/redis
        220M    /var/cache
        USB-Devices by-id:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        nodejs:
         Version table:
        ioBroker Status
        Objects type: redis
        States  type: redis
        Hosts:
        admin:          7.4.10
        javascript:     8.8.3
        Adapter State
        + instance is alive
        Objects and States
        Objects:        6615
        States:         5438
        Darth
        @darth2010 sagte in yr.no Wetter Adapter "Error while requesting data":
        bitte die settings zeigen!
        Geokordinaten unkenntlich machen
        • D Darth2010
          Fehlerbeschreibung:
          response.json
          Infos zum System:
          iob diag:
          bash
          Script v.2025-02-23
          *** BASE SYSTEM ***
                  Chassis: container
           Virtualization: lxc
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
          CPU threads: 1
                          RTC time: n/a
                   RTC in local TZ: no
          darth
          HOME=/home/darth
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:             0B          0B          0B
                  4096 M total memory
                  2879 M used memory
                   972 M free memory
                     0 M buffer memory
                   243 M swap cache
                     0 M total swap
                     0 M used swap
                     0 M free swap
          *** FILESYSTEM ***
          /var:
          1.2G    /var/
          934M    /var/lib
          582M    /var/lib/redis
          220M    /var/cache
          USB-Devices by-id:
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          nodejs:
           Version table:
          ioBroker Status
          Objects type: redis
          States  type: redis
          Hosts:
          admin:          7.4.10
          javascript:     8.8.3
          Adapter State
          + instance is alive
          Objects and States
          Objects:        6615
          States:         5438
          Darth
          FredFF Online
          FredFF Online
          FredF
          Most Active Forum Testing
          schrieb am zuletzt editiert von FredF
          Falsche Werte für Längen- und Breitenrad in den Instanzeinstellungen verwendet?
          HomoranH D 2 Antworten Letzte Antwort
          • FredFF FredF
            @fredf sagte in yr.no Wetter Adapter "Error while requesting data":
            Falsche Werte
            falls du die Geokoordinaten mrinst, die habe ich entfernt
            FredFF mcm1957M 2 Antworten Letzte Antwort
              Falsche Werte
              FredFF Online
              FredFF Online
              FredF
              @homoran Ach so...
                Falsche Werte
                mcm1957M Online
                mcm1957M Online
                mcm1957
                @Darth2010
                Also bei mir tut der Adapter was er soll.
                Allerdings sind deinem Log unsinnige Geokoordinaten drinnen:
                Support Repositoryverwaltung.
                Wer Danke sagen will, kann nen Kaffee spendieren: https://paypal.me/mcm1957atiobroker
                LESEN - gute Forenbeitrage
                • FredFF FredF
                  Darth2010
                  @fredf
                  Hab beispielhaft die Geo-Daten von Berlin genommen, daher kein Problem, kann jeder sehen und ausprobieren.
                  HomoranH mcm1957M 2 Antworten Letzte Antwort
                  • mcm1957M mcm1957
                    @Darth2010
                    @mcm1957 sagte in yr.no Wetter Adapter "Error while requesting data":
                    @homoran sagte in yr.no Wetter Adapter "Error while requesting data":
                    Falsche Werte
                    • D Darth2010
                      @fredf
                      hab ich ja nicht gewusst
                      • D Darth2010
                        @fredf
                        mcm1957M Online
                        mcm1957M Online
                        mcm1957
                        @darth2010
                        Also in der URL stehen da sicher nicht die Geodaten von Berlin...
                        • mcm1957M mcm1957
                          @darth2010
                          und Was da stand waren andere
                            Darth2010
                            Ja ist mir beim Antworten auch aufgefallen :anguished: .
                            Hier die Adapter Settings:
                            @mcm1957
                            Und noch mal das Log dazu:
                            yr.082737	2025-03-20 17:35:32.093	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            yr.082737	2025-03-20 17:35:32.093	debug	Plugin sentry destroyed
                            yr.082737	2025-03-20 17:35:32.092	debug	Update of data done, existing ...
                            yr.082737	2025-03-20 17:35:32.092	info	Data updated.
                            yr.082737	2025-03-20 17:35:32.092	info	Please check your settings!
                            yr.082737	2025-03-20 17:35:32.091	info	Error while requesting data:
                            yr.082737	2025-03-20 17:35:32.015	debug	Get forecast from: https://aa0465pwwdn1nx8wo.api.met.no/weatherapi/locationforecast/2.0/compact?lat=52.52437&lon=13.41053&altitude=74
                            yr.082737	2025-03-20 17:35:12.132	debug	Delay execution by 19883ms to better spread API calls
                            yr.082737	2025-03-20 17:35:12.131	debug	Configured version: {"val":"5.3.0","ack":true,"ts":1742481262686,"q":0,"from":"system.adapter.yr.0","user":"system.user.admin","lc":1742481262686}
                            yr.082737	2025-03-20 17:35:12.119	info	longitude/longitude will be set by self-Config - longitude: 13.41053 latitude: 52.52437
                            yr.082737	2025-03-20 17:35:12.096	info	starting. Version 5.3.0 in /opt/iobroker/node_modules/iobroker.yr, node: v20.18.3, js-controller: 7.0.6
                            yr.082737	2025-03-20 17:35:12.021	debug	Plugin sentry Do not initialize Plugin (enabled=false)
                            yr.082737	2025-03-20 17:35:12.006	debug	States connected to redis: 127.0.0.1:6379
                            yr.082737	2025-03-20 17:35:12.002	debug	States create User PubSub Client
                            yr.082737	2025-03-20 17:35:12.001	debug	States create System PubSub Client
                            yr.082737	2025-03-20 17:35:11.998	debug	Redis States: Use Redis connection: 127.0.0.1:6379
                            yr.082737	2025-03-20 17:35:11.972	debug	Objects connected to redis: 127.0.0.1:6379
                            yr.082737	2025-03-20 17:35:11.969	debug	Objects client initialize lua scripts
                            yr.082737	2025-03-20 17:35:11.941	debug	Objects create User PubSub Client
                            yr.082737	2025-03-20 17:35:11.941	debug	Objects create System PubSub Client
                            yr.082737	2025-03-20 17:35:11.940	debug	Objects client ready ... initialize now
                            yr.082737	2025-03-20 17:35:11.921	debug	Redis Objects: Use Redis connection: 127.0.0.1:6379
                            • D Darth2010
                              Fehlerbeschreibung:
                              response.json
                              Infos zum System:
                              iob diag:
                              bash
                              Script v.2025-02-23
                              *** BASE SYSTEM ***
                                      Chassis: container
                               Virtualization: lxc
                              Docker          : false
                              Kernel          : x86_64
                              Userland        : 64 bit
                              CPU threads: 1
                                              RTC time: n/a
                                       RTC in local TZ: no
                              darth
                              HOME=/home/darth
                              iobroker
                              HOME=/home/iobroker
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Swap:             0B          0B          0B
                                      4096 M total memory
                                      2879 M used memory
                                       972 M free memory
                                         0 M buffer memory
                                       243 M swap cache
                                         0 M total swap
                                         0 M used swap
                                         0 M free swap
                              *** FILESYSTEM ***
                              /var:
                              1.2G    /var/
                              934M    /var/lib
                              582M    /var/lib/redis
                              220M    /var/cache
                              USB-Devices by-id:
                              zigbee.X
                              Extended Pan ID:
                              *** MASKED ***
                              Pan ID:
                              *** MASKED ***
                              Channel:
                              *** MASKED ***
                              Network Key:
                              *** MASKED ***
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              nodejs:
                               Version table:
                              ioBroker Status
                              Objects type: redis
                              States  type: redis
                              Hosts:
                              admin:          7.4.10
                              javascript:     8.8.3
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        6615
                              States:         5438
                              Darth
                              T Nicht stören
                              T Nicht stören
                              ticaki
                              @darth2010
                              das Wetter geht noch mal muss die api anpassen, wie das geht steht in einem issue auf GitHub beim adapter
                              Spenden
                              • D Darth2010
                                @mcm1957
                                ich habe sllerdings deutsch und bei compact nicht den Haken
                                  Darth2010
                                  Shame on me ... nachdem ich api.met.no im Pihole für ioBroker freigeschaltet habe läuft auch alles :confounded:.
                                  Aber vielen Dank für eure blitzschnellen Antworten.
                                  Manchmal braucht man einfach Sparrings-Partner um einen anderen Blickwinkel zu bekommen.
                                  Danke und Gruß
                                  Darth
                                  • D Darth2010
                                    Danke und Gruß
                                    Darth
                                    Meister MopperM Online
                                    Meister Mopper
                                    Shame on me ... nachdem ich api.met.no im Pihole für ioBroker freigeschaltet habe läuft auch alles .
                                    Na ja, erfahrene pihole-Nutzer suchen bei Fehlern als Erstes dort.
                                    Proxmox und HA
                                    32.7k
                                    82.4k
