  3. Einsteigerfragen
  4. Installation
  5. Zigbee.0: You need save and run adapter before pairing!
51 Beiträge 8 Kommentatoren 8.3k Aufrufe 7 Beobachtet
    @nilli sagte in Zigbee.0: You need save and run adapter before pairing!:
    Hat jemand eine Idee was ich falsch mache ?
    zumindest das log als Screenshot statt als code in code-tags zu posten
    Adapter sollte korrekt konfiguriert sein :
    was für ein chip ist im Koordinator verbaut?
    N
    N
    nilli
    25-03-18 21:09:53.074  - ^[[32minfo^[[39m: admin.0 (21591) <== Disconnect system.user.admin from ::ffff:192.168.2.66
    2025-03-18 21:09:57.788  - ^[[32minfo^[[39m: admin.0 (21591) ==> Connected system.user.admin from ::ffff:192.168.2.66
    2025-03-18 21:10:52.747  - ^[[32minfo^[[39m: host.raspi5 stopInstance system.adapter.zigbee.0 (force=false, process=true)
    2025-03-18 21:10:52.751  - ^[[32minfo^[[39m: zigbee.0 (51917) Got terminate signal TERMINATE_YOURSELF
    2025-03-18 21:10:52.793  - ^[[32minfo^[[39m: host.raspi5 stopInstance system.adapter.zigbee.0 send kill signal
    2025-03-18 21:10:52.752  - ^[[32minfo^[[39m: zigbee.0 (51917) cleaned everything up...
    2025-03-18 21:10:52.760  - ^[[32minfo^[[39m: zigbee.0 (51917) Zigbee: disabling joining new devices.
    2025-03-18 21:10:52.808  - ^[[33mwarn^[[39m: zigbee.0 (51917) Failed to stop zigbee during startup
    2025-03-18 21:10:52.809  - ^[[32minfo^[[39m: zigbee.0 (51917) terminating
    2025-03-18 21:10:52.810  - ^[[32minfo^[[39m: zigbee.0 (51917) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-03-18 21:10:52.822  - ^[[32minfo^[[39m: zigbee.0 (51917) debug devices set to []
    2025-03-18 21:10:52.888  - ^[[35msilly^[[39m: fritzdect.0 (22085) Objects system redis pmessage system.config/cfg.o.system.config:{"_id":"system.config","type":"config","common":{"name":{"en":"Syst>
    2025-03-18 21:10:53.253  - ^[[32minfo^[[39m: zigbee.0 (51917) terminating
    2025-03-18 21:10:53.334  - ^[[32minfo^[[39m: host.raspi5 instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-03-18 21:10:56.515  - ^[[32minfo^[[39m: host.raspi5 instance system.adapter.zigbee.0 in version "1.10.14" started with pid 52284
    2025-03-18 21:10:59.384  - ^[[32minfo^[[39m: zigbee.0 (52284) starting. Version 1.10.14 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.0, js-controller: 7.0.6
    2025-03-18 21:10:59.446  - ^[[32minfo^[[39m: zigbee.0 (52284) delete old Backup files. keep only last 10
    2025-03-18 21:10:59.447  - ^[[32minfo^[[39m: zigbee.0 (52284) Starting Zigbee  npm ...
    2025-03-18 21:10:59.691  - ^[[32minfo^[[39m: zigbee.0 (52284) Installed Version: iobroker.zigbee@1.10.14
    2025-03-18 21:12:31.357  - ^[[32minfo^[[39m: admin.0 (21591) <== Disconnect system.user.admin from ::ffff:192.168.2.66
    2025-03-18 21:13:39.190  - ^[[32minfo^[[39m: admin.0 (21591) ==> Connected system.user.admin from ::ffff:192.168.2.66
    AsgothianA teletapiT 2 Antworten Letzte Antwort
    • N nilli
      AsgothianA
      AsgothianA
      Asgothian
      @nilli deine Logs zeigen das du den Adapter beendest bevor irgend ein Fehler auftritt.
      Der erste Start des Adapters nach Konfiguration kann bis zu 5 Minuten dauern, wenn das erste Mal ein Funk Netz aufgebaut wird.
      Bitte folgendes machen:
      • Adapter anhalten
      • 60 Sekunden warten
      • log löschen
      • Adapter starten
      • 5 Minuten warten - entweder der Adapter wird grün oder es gibt Fehlermeldungen im Log.
      • das log herunter laden, auf die zigbee-relevanten Zeilen reduzieren und als Text hier posten.
      A.
      N 1 Antwort Letzte Antwort
      • N nilli
        teletapiT
        teletapiT
        teletapi
        schrieb am zuletzt editiert von teletapi
        @nilli
        Ich hab heute den gleichen fehler mit dem Zigbee Adapter, hat mir den ganzen Log voll geknallt mit Error und warnungen bin mir nicht ganz sicher hatte aber kurz vorher den Admin Adapter upgedatet. auf die 7.6.3 ob es damit im zusammenhang steht weiß ich nicht hab den Zigbee Adapter runter geworfen denke ich werde wieder alles auf die Philips Hue Bridge anmelden
        • AsgothianA Asgothian
          • Adapter anhalten
          • log löschen
          • Adapter starten
          A.
          N
          N
          nilli
          schrieb am zuletzt editiert von nilli
          @asgothian
          Danke für die Tips ! Leider ohne Erfolg. Adapter wird nicht grün und im Log findet sich bis jetzt 22:21 Uhr auch nichts weiter :-(
          2025-03-18 22:04:38.280  - ^[[32minfo^[[39m: host.raspi5 "system.adapter.zigbee.0" disabled
          2025-03-18 22:04:38.280  - ^[[32minfo^[[39m: host.raspi5 stopInstance system.adapter.zigbee.0 (force=false, process=true)
          2025-03-18 22:04:38.284  - ^[[32minfo^[[39m: zigbee.0 (54373) Got terminate signal TERMINATE_YOURSELF
          2025-03-18 22:04:38.325  - ^[[32minfo^[[39m: host.raspi5 stopInstance system.adapter.zigbee.0 send kill signal
          2025-03-18 22:04:38.286  - ^[[32minfo^[[39m: zigbee.0 (54373) cleaned everything up...
          2025-03-18 22:04:38.295  - ^[[32minfo^[[39m: zigbee.0 (54373) Zigbee: disabling joining new devices.
          2025-03-18 22:04:38.346  - ^[[33mwarn^[[39m: zigbee.0 (54373) Failed to stop zigbee during startup
          2025-03-18 22:04:38.346  - ^[[32minfo^[[39m: zigbee.0 (54373) terminating
          2025-03-18 22:04:38.347  - ^[[32minfo^[[39m: zigbee.0 (54373) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2025-03-18 22:04:38.359  - ^[[32minfo^[[39m: zigbee.0 (54373) debug devices set to []
          2025-03-18 22:04:38.787  - ^[[32minfo^[[39m: zigbee.0 (54373) terminating
          2025-03-18 22:04:38.870  - ^[[32minfo^[[39m: host.raspi5 instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2025-03-18 22:06:47.993  - ^[[32minfo^[[39m: host.raspi5 "system.adapter.zigbee.0" enabled
          2025-03-18 22:06:48.221  - ^[[32minfo^[[39m: host.raspi5 instance system.adapter.zigbee.0 in version "1.10.14" started with pid 54685
          2025-03-18 22:06:49.859  - ^[[32minfo^[[39m: zigbee.0 (54685) starting. Version 1.10.14 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.0, js-controller: 7.0.6
          2025-03-18 22:06:49.892  - ^[[32minfo^[[39m: zigbee.0 (54685) delete old Backup files. keep only last 10
          2025-03-18 22:06:49.893  - ^[[32minfo^[[39m: zigbee.0 (54685) Starting Zigbee  npm ...
          2025-03-18 22:06:50.020  - ^[[32minfo^[[39m: zigbee.0 (54685) Installed Version: iobroker.zigbee@1.10.14
          Was könnte ich noch zur Diagnose prüfen ? 🤔
          • teletapiT teletapi
            @nilli
            N
            N
            nilli
            @teletapi : Bei mir läuft der Admin Adapter 7.4.10
            teletapiT 1 Antwort Letzte Antwort
            • N nilli
              teletapiT
              teletapiT
              teletapi
              @nilli
              Dann hat es vermutlich nichts damit zu tun. Ich frag mich halt nur warum so plötzlich lief jetzt knapp 6 Wochen ohne jeden fehler
              • N nilli
                @asgothian
                AsgothianA
                AsgothianA
                Asgothian
                Bist du sicher das du da die Fehlermeldungen nicht heraus gefiltert hast ? Es muss Fehlermeldungen geben wenn der Adapter sich beendet.
                Widerhol bitte den Test oben, stell aber vor dem Start den Zigbee-Adapter auf debug, nicht auf Info.
                A.
                  A.
                  N
                  N
                  nilli
                  @asgothian said in Zigbee.0: You need save and run adapter before pairing!:
                  Protokoll auf debug gestellt 👍 . Es finden sich aber keine weiteren Einträge nach dem neustart.
                  2025-03-18 22:39:47.464  - ^[[32minfo^[[39m: admin.0 (21591) ==> Connected system.user.admin from ::ffff:192.168.2.66
                  2025-03-18 22:39:51.669  - ^[[32minfo^[[39m: admin.0 (21591) <== Disconnect system.user.admin from ::ffff:192.168.2.66
                  2025-03-18 22:39:58.499  - ^[[32minfo^[[39m: host.raspi5 "system.adapter.zigbee.0" disabled
                  2025-03-18 22:39:58.500  - ^[[32minfo^[[39m: host.raspi5 stopInstance system.adapter.zigbee.0 (force=false, process=true)
                  2025-03-18 22:39:58.503  - ^[[32minfo^[[39m: zigbee.0 (54685) Got terminate signal TERMINATE_YOURSELF
                  2025-03-18 22:39:58.545  - ^[[32minfo^[[39m: host.raspi5 stopInstance system.adapter.zigbee.0 send kill signal
                  2025-03-18 22:39:58.504  - ^[[32minfo^[[39m: zigbee.0 (54685) cleaned everything up...
                  2025-03-18 22:39:58.508  - ^[[32minfo^[[39m: zigbee.0 (54685) Zigbee: disabling joining new devices.
                  2025-03-18 22:39:58.545  - ^[[33mwarn^[[39m: zigbee.0 (54685) Failed to stop zigbee during startup
                  2025-03-18 22:39:58.546  - ^[[32minfo^[[39m: zigbee.0 (54685) terminating
                  2025-03-18 22:39:58.546  - ^[[32minfo^[[39m: zigbee.0 (54685) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2025-03-18 22:39:58.554  - ^[[32minfo^[[39m: zigbee.0 (54685) debug devices set to []
                  2025-03-18 22:39:58.626  - ^[[35msilly^[[39m: fritzdect.0 (22085) Objects system redis pmessage system.config/cfg.o.system.config:{"_id":"system.config","type":"config","common":{"name":{"en":"System configuration","de":"Syst>
                  2025-03-18 22:39:59.004  - ^[[32minfo^[[39m: zigbee.0 (54685) terminating
                  2025-03-18 22:39:59.067  - ^[[32minfo^[[39m: host.raspi5 instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2025-03-18 22:41:21.551  - ^[[32minfo^[[39m: host.raspi5 "system.adapter.zigbee.0" enabled
                  2025-03-18 22:41:21.770  - ^[[35msilly^[[39m: fritzdect.0 (22085) Objects system redis pmessage system.config/cfg.o.system.config:{"_id":"system.config","type":"config","common":{"name":{"en":"System configuration","de":"Syst>
                  2025-03-18 22:41:21.840  - ^[[32minfo^[[39m: host.raspi5 instance system.adapter.zigbee.0 in version "1.10.14" started with pid 56000
                  2025-03-18 22:41:23.450  - ^[[32minfo^[[39m: zigbee.0 (56000) starting. Version 1.10.14 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.0, js-controller: 7.0.6
                  2025-03-18 22:41:23.487  - ^[[32minfo^[[39m: zigbee.0 (56000) delete old Backup files. keep only last 10
                  2025-03-18 22:41:23.489  - ^[[32minfo^[[39m: zigbee.0 (56000) Starting Zigbee  npm ...
                  2025-03-18 22:41:23.624  - ^[[32minfo^[[39m: zigbee.0 (56000) Installed Version: iobroker.zigbee@1.10.14
                  2025-03-18 22:43:55.876  - ^[[34mdebug^[[39m: fritzdect.0 (22085) polling! fritzdect is alive with 300 s
                  2025-03-18 22:43:55.876  - ^[[34mdebug^[[39m: fritzdect.0 (22085) __________________________
                  • AsgothianA
                    AsgothianA
                    Asgothian
                    @nilli Da ist etwas systematisch auf Deinem System nicht in Ordnung. Bist du sicher das du die 5 Minuten gewartet hast bevor Du das Log geladen hast ? Im Log selber ist davon wenig zu sehen.
                    Ansonsten bitte :
                    • Zigbee-Adapter deinstallieren
                    • sicherstellen das im NPM baum sowohl der zigbee-herdsman als auch die zigbee-herdsman-converters nicht mehr vorhanden sind
                    • dann den Zigbee Adapter neu installieren
                    • Dann den Zigbee-Adapter starten (so wie oben) und das Log posten.
                    A.
                    • N
                      N
                      nilli
                      Danke für die Hilfe ! Wie überprüfe ich das ?
                      • N nilli
                        AsgothianA
                        AsgothianA
                        Asgothian
                        @nilli Im ioBroker Verzeichnis:
                        npm list -a | grep -e zigbee darf keine Ausgabe liefern.
                        Du kannst vor der de-installation verifizieren das der Befehl funktioniert - er müsste etwas ähnliches wie dieses liefern:
                        iobroker.zigbee@2.0.4 /Users/ae/LocalDocuments/GitHub/ioBroker.zigbee
                        ├─┬ zigbee-herdsman-converters@23.6.0
                        │ └── zigbee-herdsman@3.3.2 deduped
                        └─┬ zigbee-herdsman@3.3.2
                        Wichtig - das ist von meinem Entwicklungssystem, Versionsnummern und Pfade werden bei Dir anders sein.
                        A.
                          A.
                          N
                          N
                          nilli
                          @asgothian
                          nils@raspi5:/opt/iobroker $ npm list -a | grep -e zigbee
                          └─┬ iobroker.zigbee@1.10.14
                            ├─┬ zigbee-herdsman-converters@20.58.0
                            │ └── zigbee-herdsman@2.1.9 deduped
                            └─┬ zigbee-herdsman@2.1.9
                          Adapter deinstalliert
                          Inhalt von Ordner /opt/iobroker/iobroker-data/zigbee_0 gelöscht
                          Adapter neu instaliert und konfiguruert mit :
                          /dev/ttyUSB0
                          Typ : TI Z-Stack/CCxxxx
                          Baud : 115200
                          Erweiterte PAN ID: abcdabcdabcdabcd
                          Pan ID : 6754
                          Kanal 11
                          Transportschlüssel : 01030507090B0D0F00020406080A0C0D
                          Leider immer noch das gleiche Verhalten 😧
                          Merkwürdig : Ordner /opt/iobroker/iobroker-data/zigbee_0 weiterhin leer ... 🤔
                          2025-03-19 10:23:59.374 - debug: fritzdect.0 (22085) With 087610147624got the following to parse{"devicestats":{"voltage":"","power":"","energy":""}}
                          2025-03-19 10:27:53.294 - info: host.raspi5 iobroker del zigbee
                          2025-03-19 10:27:54.886 - info: host.raspi5 iobroker Delete adapter "zigbee"
                          2025-03-19 10:27:54.895 - info: host.raspi5 iobroker host.raspi5 Counted 1 instances of zigbee
                          2025-03-19 10:27:54.911 - info: host.raspi5 iobroker host.raspi5 Counted 1 meta of zigbee
                          2025-03-19 10:27:54.913 - info: host.raspi5 iobroker host.raspi5 Counted 1 adapter for zigbee
                          2025-03-19 10:27:54.921 - info: host.raspi5 iobroker host.raspi5 Counted 2 channels of zigbee
                          2025-03-19 10:27:54.925 - info: host.raspi5 iobroker host.raspi5 Counted 8 states of zigbee
                          2025-03-19 10:27:54.929 - info: host.raspi5 iobroker host.raspi5 Counted 15 states of system.adapter.zigbee
                          2025-03-19 10:27:54.932 - info: host.raspi5 iobroker host.raspi5 Counted 8 states (io.zigbee.*) from states
                          2025-03-19 10:27:54.937 - info: host.raspi5 iobroker host.raspi5 Counted 16 states (system.adapter.zigbee.*) from states
                          2025-03-19 10:27:55.225 - info: host.raspi5 iobroker host.raspi5 Counted 1 objects of zigbee
                          2025-03-19 10:27:56.805 - info: host.raspi5 iobroker host.raspi5 file zigbee.admin deleted
                          2025-03-19 10:27:56.808 - info: host.raspi5 iobroker host.raspi5 object zigbee deleted
                          2025-03-19 10:27:56.812 - info: host.raspi5 iobroker host.raspi5 object zigbee.admin deletedhost.raspi5 Deleting 30 object(s).
                          2025-03-19 10:27:56.867 - info: host.raspi5 object deleted system.adapter.zigbee.0
                          2025-03-19 10:27:56.867 - info: host.raspi5 stopInstance system.adapter.zigbee.0 (force=false, process=true)
                          2025-03-19 10:27:56.870 - info: zigbee.0 (82664) Got terminate signal TERMINATE_YOURSELF
                          2025-03-19 10:27:56.869 - info: host.raspi5 iobroker host.raspi5 Deleting 24 state(s).
                          2025-03-19 10:27:56.871 - info: zigbee.0 (82664) cleaned everything up...
                          2025-03-19 10:27:56.872 - info: zigbee.0 (82664) Zigbee: disabling joining new devices.
                          2025-03-19 10:27:56.873 - warn: zigbee.0 (82664) Failed to stop zigbee during startup
                          2025-03-19 10:27:56.873 - info: zigbee.0 (82664) terminating
                          2025-03-19 10:27:56.874 - info: zigbee.0 (82664) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2025-03-19 10:27:56.912 - info: host.raspi5 stopInstance system.adapter.zigbee.0 send kill signal
                          2025-03-19 10:27:57.371 - info: zigbee.0 (82664) terminating
                          2025-03-19 10:27:57.405 - info: host.raspi5 instance system.adapter.zigbee.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                          2025-03-19 10:27:57.405 - info: host.raspi5 Do not restart adapter system.adapter.zigbee.0 because desired by instance
                          2025-03-19 10:28:01.292 - info: host.raspi5 iobroker
                          2025-03-19 10:28:01.293 - info: host.raspi5 iobroker removed 22 packages in 4s200 packages are looking for funding run `npm fund` for details
                          2025-03-19 10:28:02.320 - info: host.raspi5 iobroker exit 0
                          2025-03-19 10:28:55.926 - debug: fritzdect.0 (22085) polling! fritzdect is alive with 300 s
                          2025-03-19 10:28:59.038 - debug: fritzdect.0 (22085) With 087610147624got the following to parse{"devicestats":{"voltage":"","power":"","energy":""}}
                          2025-03-19 10:29:29.781 - info: host.raspi5 iobroker add zigbee --host raspi5
                          2025-03-19 10:29:31.948 - info: host.raspi5 iobroker NPM version: 10.8.2
                          2025-03-19 10:29:31.950 - info: host.raspi5 iobroker Installing iobroker.zigbee@1.10.14... (System call)
                          2025-03-19 10:29:49.217 - info: host.raspi5 iobroker
                          2025-03-19 10:29:49.217 - info: host.raspi5 iobroker added 22 packages in 17s202 packages are looking for funding run `npm fund` for details
                          2025-03-19 10:29:49.278 - info: host.raspi5 iobroker host.raspi5 install adapter zigbee
                          2025-03-19 10:29:49.444 - info: host.raspi5 iobroker upload [333] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
                          2025-03-19 10:29:51.617 - info: host.raspi5 iobroker upload [300] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Eurotronic_Spirit_04.png img/Eurotronic_Spirit_04.png image/png
                          2025-03-19 10:29:52.013 - info: host.raspi5 iobroker upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/cc2538_router_v1.png img/cc2538_router_v1.png image/png
                          2025-03-19 10:29:52.535 - info: host.raspi5 iobroker upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hue-smart-button.png img/hue-smart-button.png image/png
                          2025-03-19 10:29:52.938 - info: host.raspi5 iobroker upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lifecontrol_lamp.png img/lifecontrol_lamp.png image/png
                          2025-03-19 10:29:53.361 - info: host.raspi5 iobroker upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_fuzo_outdoor_wall_light.png img/philips_fuzo_outdoor_wall_light.png image/png
                          2025-03-19 10:29:53.424 - info: host.raspi5 iobroker upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_argenta_4.png img/philips_hue_argenta_4.png image/png
                          2025-03-19 10:29:53.452 - info: host.raspi5 iobroker upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_gu10_ambiance.png img/philips_hue_gu10_ambiance.png image/png
                          2025-03-19 10:29:53.487 - info: host.raspi5 iobroker upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_lwv001.png img/philips_hue_lwv001.png image/png
                          2025-03-19 10:29:53.515 - info: host.raspi5 iobroker upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/previous_track.png img/previous_track.png image/png
                          2025-03-19 10:29:53.542 - info: host.raspi5 iobroker upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/sensor_philipshue.png img/sensor_philipshue.png image/png
                          2025-03-19 10:29:53.570 - info: host.raspi5 iobroker upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/smartthings_motion.png img/smartthings_motion.png image/png
                          2025-03-19 10:29:53.602 - info: host.raspi5 iobroker upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ts0203.png img/ts0203.png image/png
                          2025-03-19 10:29:53.811 - info: host.raspi5 iobroker upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/tuya_tyzs1l.png img/tuya_tyzs1l.png image/png
                          2025-03-19 10:29:53.818 - info: host.raspi5 iobroker upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unavailable.png img/unavailable.png image/png
                          2025-03-19 10:29:53.825 - info: host.raspi5 iobroker upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unknown.png img/unknown.png image/png
                          2025-03-19 10:29:53.832 - info: host.raspi5 iobroker upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/wemo.png img/wemo.png image/png
                          2025-03-19 10:29:53.839 - info: host.raspi5 iobroker upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_plug_eu.png img/xiaomi_plug_eu.png image/png
                          2025-03-19 10:29:53.846 - info: host.raspi5 iobroker upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_wireless_switch.png img/xiaomi_wireless_switch.png image/png
                          2025-03-19 10:29:53.857 - info: host.raspi5 iobroker upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27.png img/zbt_e27.png image/png
                          2025-03-19 10:29:53.863 - info: host.raspi5 iobroker upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27_rgbw.png img/zbt_e27_rgbw.png image/png
                          2025-03-19 10:29:53.869 - info: host.raspi5 iobroker upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_led_panel.png img/zbt_led_panel.png image/png
                          2025-03-19 10:29:53.875 - info: host.raspi5 iobroker upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_smart_switch.png img/zbt_smart_switch.png image/png
                          2025-03-19 10:29:53.882 - info: host.raspi5 iobroker upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zemismart_sw2.png img/zemismart_sw2.png image/png
                          2025-03-19 10:29:53.888 - info: host.raspi5 iobroker upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index.html index.html text/html
                          2025-03-19 10:29:53.900 - info: host.raspi5 iobroker upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index_m.html index_m.html text/html
                          2025-03-19 10:29:53.913 - info: host.raspi5 iobroker upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/moment.min.js moment.min.js application/javascript
                          2025-03-19 10:29:53.924 - info: host.raspi5 iobroker upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/shuffle.min.js shuffle.min.js application/javascript
                          2025-03-19 10:29:53.934 - info: host.raspi5 iobroker upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/tab_m.html tab_m.html text/html
                          2025-03-19 10:29:53.946 - info: host.raspi5 iobroker upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.css vis-network.min.css text/css
                          2025-03-19 10:29:53.960 - info: host.raspi5 iobroker upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.js vis-network.min.js application/javascript
                          2025-03-19 10:29:53.979 - info: host.raspi5 iobroker upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/words.js words.js application/javascript
                          2025-03-19 10:29:53.992 - info: host.raspi5 iobroker upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.png zigbee.png image/png
                          2025-03-19 10:29:54.000 - info: host.raspi5 iobroker upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.svg zigbee.svg image/svg+xml
                          2025-03-19 10:29:54.038 - info: host.raspi5 iobroker host.raspi5 object system.adapter.zigbee created/updated
                          2025-03-19 10:29:54.039 - info: host.raspi5 iobroker Updating objects from io-package.json for adapter "zigbee" with version "1.10.14"
                          2025-03-19 10:29:54.067 - info: host.raspi5 iobroker host.raspi5 create instance zigbee
                          2025-03-19 10:29:54.071 - info: host.raspi5 iobroker host.raspi5 object system.adapter.zigbee.0.alive created
                          2025-03-19 10:29:54.074 - info: host.raspi5 iobroker host.raspi5 object system.adapter.zigbee.0.connected created
                          2025-03-19 10:29:54.077 - info: host.raspi5 iobroker host.raspi5 object system.adapter.zigbee.0.compactMode created
                          2025-03-19 10:29:54.080 - info: host.raspi5 iobroker host.raspi5 object system.adapter.zigbee.0.cpu created
                          2025-03-19 10:29:54.083 - info: host.raspi5 iobroker host.raspi5 object system.adapter.zigbee.0.cputime created
                          2025-03-19 10:29:54.087 - info: host.raspi5 iobroker host.raspi5 object system.adapter.zigbee.0.memHeapUsed created
                          2025-03-19 10:29:54.090 - info: host.raspi5 iobroker host.raspi5 object system.adapter.zigbee.0.memHeapTotal created
                          2025-03-19 10:29:54.093 - info: host.raspi5 iobroker host.raspi5 object system.adapter.zigbee.0.memRss created
                          2025-03-19 10:29:54.096 - info: host.raspi5 iobroker host.raspi5 object system.adapter.zigbee.0.uptime created
                          2025-03-19 10:29:54.099 - info: host.raspi5 iobroker host.raspi5 object system.adapter.zigbee.0.inputCount created
                          2025-03-19 10:29:54.102 - info: host.raspi5 iobroker host.raspi5 object system.adapter.zigbee.0.outputCount created
                          2025-03-19 10:29:54.105 - info: host.raspi5 iobroker host.raspi5 object system.adapter.zigbee.0.eventLoopLag created
                          2025-03-19 10:29:54.108 - info: host.raspi5 iobroker host.raspi5 object system.adapter.zigbee.0.sigKill created
                          2025-03-19 10:29:54.112 - info: host.raspi5 iobroker host.raspi5 object system.adapter.zigbee.0.logLevel created
                          2025-03-19 10:29:54.115 - info: host.raspi5 iobroker host.raspi5 object zigbee.0.exclude created
                          2025-03-19 10:29:54.118 - info: host.raspi5 iobroker host.raspi5 object zigbee.0.exclude.all created
                          2025-03-19 10:29:54.120 - info: host.raspi5 iobroker host.raspi5 object zigbee.0.info created
                          2025-03-19 10:29:54.123 - info: host.raspi5 iobroker host.raspi5 object zigbee.0.info.connection created
                          2025-03-19 10:29:54.126 - info: host.raspi5 iobroker host.raspi5 object zigbee.0.info.pairingMode created
                          2025-03-19 10:29:54.129 - info: host.raspi5 iobroker host.raspi5 object zigbee.0.info.pairingCountdown created
                          2025-03-19 10:29:54.133 - info: host.raspi5 iobroker host.raspi5 object zigbee.0.info.pairingMessage created
                          2025-03-19 10:29:54.136 - info: host.raspi5 iobroker host.raspi5 object zigbee.0.info.groups created
                          2025-03-19 10:29:54.139 - info: host.raspi5 iobroker host.raspi5 object zigbee.0.info.undefinedDevices created
                          2025-03-19 10:29:54.143 - info: host.raspi5 iobroker host.raspi5 object zigbee.0.info.debugmessages created
                          2025-03-19 10:29:54.146 - info: host.raspi5 iobroker host.raspi5 Set default value of zigbee.0.exclude.all: []
                          2025-03-19 10:29:54.149 - info: host.raspi5 iobroker host.raspi5 Set default value of zigbee.0.info.connection: false
                          2025-03-19 10:29:54.152 - info: host.raspi5 iobroker host.raspi5 Set default value of zigbee.0.info.pairingMode: false
                          2025-03-19 10:29:54.154 - info: host.raspi5 iobroker host.raspi5 Set default value of zigbee.0.info.pairingCountdown: 0
                          2025-03-19 10:29:54.156 - info: host.raspi5 iobroker host.raspi5 Set default value of zigbee.0.info.pairingMessage:
                          2025-03-19 10:29:54.159 - info: host.raspi5 iobroker host.raspi5 Set default value of zigbee.0.info.groups:
                          2025-03-19 10:29:54.161 - info: host.raspi5 iobroker host.raspi5 Set default value of zigbee.0.info.undefinedDevices:
                          2025-03-19 10:29:54.163 - info: host.raspi5 iobroker host.raspi5 Set default value of zigbee.0.info.debugmessages:
                          2025-03-19 10:29:54.170 - info: host.raspi5 iobroker host.raspi5 object system.adapter.zigbee.0 created
                          2025-03-19 10:29:55.180 - info: host.raspi5 iobroker exit 0
                          2025-03-19 10:29:56.875 - info: admin.0 (21591) ==> Connected system.user.admin from ::ffff:192.168.2.66
                          2025-03-19 10:29:57.472 - info: host.raspi5 instance system.adapter.zigbee.0 in version "1.10.14" started with pid 83159
                          2025-03-19 10:30:00.684 - info: zigbee.0 (83159) starting. Version 1.10.14 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.0, js-controller: 7.0.6
                          2025-03-19 10:30:00.706 - error: zigbee.0 (83159) Serial port not selected! Go to settings page.
                          2025-03-19 10:30:00.709 - info: zigbee.0 (83159) Starting Zigbee npm ...
                          2025-03-19 10:30:01.111 - info: zigbee.0 (83159) Installed Version: iobroker.zigbee@1.10.14
                          2025-03-19 10:31:32.746 - info: host.raspi5 stopInstance system.adapter.zigbee.0 (force=false, process=true)
                          2025-03-19 10:31:32.750 - info: zigbee.0 (83159) Got terminate signal TERMINATE_YOURSELF
                          2025-03-19 10:31:32.751 - info: zigbee.0 (83159) cleaned everything up...
                          2025-03-19 10:31:32.753 - info: zigbee.0 (83159) Zigbee: disabling joining new devices.
                          2025-03-19 10:31:32.754 - warn: zigbee.0 (83159) Failed to stop zigbee during startup
                          2025-03-19 10:31:32.754 - info: zigbee.0 (83159) terminating
                          2025-03-19 10:31:32.755 - info: zigbee.0 (83159) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2025-03-19 10:31:32.793 - info: host.raspi5 stopInstance system.adapter.zigbee.0 send kill signal
                          2025-03-19 10:31:33.252 - info: zigbee.0 (83159) terminating
                          2025-03-19 10:31:33.285 - info: host.raspi5 instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2025-03-19 10:31:36.506 - info: host.raspi5 instance system.adapter.zigbee.0 in version "1.10.14" started with pid 83248
                          2025-03-19 10:31:36.575 - info: admin.0 (21591) <== Disconnect system.user.admin from ::ffff:192.168.2.66
                          2025-03-19 10:31:38.535 - info: zigbee.0 (83248) starting. Version 1.10.14 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.0, js-controller: 7.0.6
                          2025-03-19 10:31:38.549 - info: zigbee.0 (83248) Starting Zigbee npm ...
                          2025-03-19 10:31:38.803 - info: zigbee.0 (83248) Installed Version: iobroker.zigbee@1.10.14
                          2025-03-19 10:33:55.927 - debug: fritzdect.0 (22085) polling! fritzdect is alive with 300 s
                          2025-03-19 10:33:55.927 - debug: fritzdect.0 (22085) __________________________
                          2025-03-19 10:33:55.927 - debug: fritzdect.0 (22085) updating Devices / Groups
                          2025-03-19 10:33:56.951 - debug: fritzdect.0 (22085) devices
                          2025-03-19 10:33:56.951 - debug: fritzdect.0 (22085) update Devices 1
                          2025-03-19 10:38:56.993 - debug: fritzdect.0 (22085) _____________________________________________
                          2025-03-19 10:38:56.993 - debug: fritzdect.0 (22085) updating Device FRITZ!DECT 200 #1
                          • N
                            N
                            nilli
                            Wie kann ich die obigen (doppelten) posts löschen ?
                            Was mir noch merkwürdig erscheint, ist dass im Instanzeneinstellungsmenue des Zigbee-Adapters ein klick auf den Pfeil hinter dem COM-Anschlussnamen keine Auswahl ergibt. Sollten dort nicht alle verfügbaren Adapter angezeigt werden ?
                            Irgendwie habe ich das Gefühl das der Anschluss nicht richtig für den Adapter konfiguriert ist.
                            Kann man sich die Adapterkonfiguration direkt im terminal anschauen ?
                            AsgothianA HomoranH 2 Antworten Letzte Antwort
                            • N nilli
                              AsgothianA
                              AsgothianA
                              Asgothian
                              @nilli Nein. Um da näher dran zu kommen müsstest Du die 2.1.0 RC3 von meinem Github installieren. Anbei ein Link und ein Hinweis in wie weit diese Version besonders ist.
                              Interessant für Deine Situation ist das du direkt versuchen kannst den Herdsman zu starten und zu stoppen, ohne immer die Ansicht zu wechseln. Relevante Log-Meldunge bekommst du auch direkt in der Oberfläche angezeigt
                              Wichtig - alle Breaking changes aus dem Wechsel von 1.10 zu 2.0.1 gelten auch (siehe hier)
                              Link: https://github.com/asgothian/ioBroker.zigbee/tarball/2.1.0
                              Was hier neu ist:
                              • der Adatper startet nicht mehr ‘durch’, sprich der Adapter startet das Zigbee-Subsystem nur dann wenn der entsprechende Haken gesetzt ist. Per default ist der nicht gesetzt. (Im Bild rot umrandet)
                              • der Adapter bietet die Option den Herdsman testweise zu starten, und direkt im Admin die Meldungen des Starts zu sehen. So kann ohne Jongliererei geprüft werden ob die Parameter passen. Im Bild lila umrandet
                              • Der Knopf zum Reset ist aktuell noch nicht getestet - da bin ich noch dran. Das sollte aber im Laufe der Woche passieren
                              • Mit Start/Stop kann der Herdsman gestartet / angehalten werden
                              Das icon mit dem Trauerrand taucht immer dann auf wenn der Herdsman nicht läuft.
                              Zum testen sollte das ganze ausreichen.
                              • N nilli
                                wenn du damit Converter meinst, bin ich schon länger dieser Meinung
                                  N
                                  N
                                  nilli
                                  @homoran : Ja. Converter ist wohl richtig. Sorry !
                                  • N nilli
                                    @nilli was sagt denn lsusb und ls /dev/serial/by-id?
                                      N
                                      N
                                      nilli
                                      leider genau was es sollte , oder ?
                                      nils@raspi5:/ $ lsusb
                                      Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
                                      Bus 003 Device 009: ID 10c4:ea60 Silicon Labs CP210x UART Bridge
                                      Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
                                      Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
                                      nils@raspi5:/ $ ls -l /dev/serial/by-id
                                      total 0
                                      lrwxrwxrwx 1 root root 13 Mar 19 10:00 usb-SMLIGHT_SMLIGHT_SLZB-07p7_9c66d41ef372ed1189a81df3fdf7b791-if00-port0 -> ../../ttyUSB0
                                      • N nilli
                                        total 0
                                        oder
                                        was steht denn hier
                                        ist leider abgeschnitten
                                          oder
                                          was steht denn hier
                                          N
                                          N
                                          nilli
                                          /dev/serial/by-id/usb-SMLIGHT_SMLIGHT_SLZB-07p7_9c66d41ef372ed1189a81df3fdf7b791-if00-port0
                                          84.1k
