  4. Test Adapter sun2000 v0.1.x - Huawei Wechselrichter
adapteremmahuaweiinverterluna2000modbus tcpmodbus-proxysdonglesmartloggersun2000
1.3k Beiträge 97 Kommentatoren 490.8k Aufrufe 87 Beobachtet
  • Michael BirrM Michael Birr
    @bolliy Ich denke, dass ich diese Anregungen schon beachtet habe - siehe CC. Vieleicht erkennst du daraus mehr
    2025-03-06 10:00:00.026 - info: javascript.0 (7292) script.js.common.Batteriesteuerung.Skript_1: getState(id=sun2000.0.inverter.0.battery.SOC, timerId=undefined) => {"val":57,"ack":true,"ts":1741251580239,"q":0,"from":"system.adapter.sun2000.0","user":"system.user.admin","lc":1741251580239}
    2025-03-06 10:00:00.030 - info: javascript.0 (7292) script.js.common.Batteriesteuerung.Skript_1: getState(id=sun2000.0.inverter.0.battery.ratedCapacity, timerId=undefined) => {"val":25000,"ack":true,"ts":1741105021840,"q":0,"from":"system.adapter.sun2000.0","user":"system.user.admin","lc":1726907980177}
    2025-03-06 10:00:00.030 - info: javascript.0 (7292) script.js.common.Batteriesteuerung.Skript_1: setForeignState(id=sun2000.0.inverter.0.control.battery.maximumChargingPower, state={"val":2687.5000000000005,"ack":false,"ts":1741251600030,"q":0,"from":"system.adapter.javascript.0","lc":1741251600030,"c":"script.js.common.Batteriesteuerung.Skript_1"})
    2025-03-06 10:00:00.030 - info: javascript.0 (7292) script.js.common.Batteriesteuerung.Skript_1: setStateDelayed(id=sun2000.0.inverter.0.control.battery.maximumChargePower, state=2687.5000000000005, isAck=undefined, delay=500, clearRunning=false)
    2025-03-06 10:00:00.045 - info: sun2000.0 (21396) Control: Event - state: battery.maximumChargingPower changed: 2687.5000000000005 ack: false
    2025-03-06 10:00:00.385 - warn: sun2000.0 (21396) Error while writing to 192.168.200.1 [Reg: 47075, Len: 2, modbusID: 0] with: Modbus exception 128: Unknown error
    2025-03-06 10:00:00.385 - info: sun2000.0 (21396) Control: Event is discarded because it could not be processed. inverter.0.control.battery.maximumChargingPower
    2025-03-06 10:00:00.539 - info: javascript.0 (7292) script.js.common.Batteriesteuerung.Skript_1: setForeignState(id=sun2000.0.inverter.0.control.battery.maximumChargePower, state={"val":2687.5000000000005,"ack":false,"ts":1741251600539,"q":0,"from":"system.adapter.javascript.0","lc":1741251600539,"c":"script.js.common.Batteriesteuerung.Skript_1"})
    2025-03-06 10:00:00.555 - info: sun2000.0 (21396) Control: Event - state: battery.maximumChargePower changed: 2687.5000000000005 ack: false
    2025-03-06 10:00:20.544 - warn: sun2000.0 (21396) Control: maximumChargePower is deprecated use "maximumChargingPower" instead
    2025-03-06 10:00:20.648 - warn: sun2000.0 (21396) Error while writing to 192.168.200.1 [Reg: 47075, Len: 2, modbusID: 0] with: Modbus exception 128: Unknown error
    2025-03-06 10:00:20.648 - info: sun2000.0 (21396) Control: Event is discarded because it could not be processed. inverter.0.control.battery.maximumChargePower
    2025-03-06 10:14:58.097 - info: admin.0 (19984) ==> Connected system.user.admin from ::ffff:192.168.188.71
    2025-03-06 10:15:41.848 - info: admin.0 (19984) ==> Connected system.user.admin from ::ffff:192.168.188.71
    Danke und Gruß Michael
    EIN NEUER VERSUCH Gruß Michael
    B Online
    B Online
    bolliy
    schrieb am zuletzt editiert von bolliy
    #755
    @michael-birr keine 'Float' (Gleitkommazahl) verwenden! Der Inverter erwartet den Datentyp 'Integer' (ganze Zahl) . Du mußt die Zahl runden (Math.round())
    Ich werde die Gleitkommzahlen in der nächsten Version einfach runden. ;)
    LG Stephan
    Michael BirrM 1 Antwort Letzte Antwort
    • B bolliy
      LG Stephan
      Michael BirrM Offline
      Michael Birr
      #756
      @bolliy Vielen Dank, da bin ich nicht drauf gekommen - Test folgt !
      • P Offline
        PrinzEisenherz1
        #757
        Hi bolliy, zuerst einmal ein großes Lob für diesen mega Adapter.
        Jetzt hätte ich aber eine Frage bzw. ein Anliegen.
        Ich habe folgende Hardware-Konfiguration:
        10,53 kWp mit SUN2000 10ktl-m1
        10kW LUNA2000
        SDongleA-05
        DTSU666-H -> Modbus-ID 11
        zusätzlich läuft bei mir aber auch noch ein Balkonkraftwerk mit 840 Wp und Hoyemiles-800.
        Bisher habe ich mit einem shelly-1em die Werte des BK abgefragt. Ich wollte aber die Daten auch gerne auf Fusionsolar.
        Dazu habe ich mir noch einen DDSU666-H zugelegt. Dieser ist einphasig!
        Habe ihn gemäß Anleitung Vernetzung Fremdwechselrichter von Huawei ins System eingebunden.
        Da habe ich dem DDSU die ModBusadresse 19 gegeben.
        Der DDSU ist über den Dongle eingebunden.
        Funktioniert auch alles super. Werte passen auf Fusionsolar. es wird nur nicht der DDSU angezeigt, sondern die Werte sind saldierend. Stört mich aber nicht.
        Jetzt würde ich aber gerne mit Deinem Adapter die Daten des DDSU seperat abfragen wollen. er ließt ja den Modbus aus.
        Bei Integration-Settings im Adapter ist aber die ModBus-Adresse für den SmartLogger fest verankert. Lässt sich nicht ändern bzw erweitern.
        Besteht vielleicht die Möglichkeit das man noch eine zweite SmartLogger Abfrage integriert?
        Also z.B. so?
        Da wo auch die Möglichkeit besteht die Modbus-ID manuell einzugeben?
        Wäre mega wenn sowas gehen würde!
        Johnny
        Intel-NUC mit ProxMox: ioBroker,SQL, logging Strom- Gas- u. Wasserzähler;10Zoll Tab im Flur für VIS; weiteres: Homematic CCU2, Homeduino, Kameras, selbstgebaute Wetterstation;
        • P PrinzEisenherz1
          10kW LUNA2000
          SDongleA-05
          Also z.B. so?
          Johnny
          B Online
          B Online
          bolliy
          #758
          @prinzeisenherz1 die Abfrage der DDSU erfolgt durch den Smart Logger eigenständig. Du hast aber eine SDongle als Integration gewählt ?!
          Man müsste also den 2ten SmartMeter über die Modbus id 19 auslesen. Das bedeutet allerdings die Erstellung eines weiteren Treibers. Das wird leider nicht ohne größeren Aufwand funktionieren.
          Es gibt aber einen Fork zu meinem Projekt. Vielleicht wäre diese Anpassung ein Ansatz um dein Anliegen umzusetzen. https://github.com/edyso/ioBroker.sun2000
          Ansonsten kannst du gerne ein issue hier https://github.com/bolliy/ioBroker.sun2000/issues anlegen. Dann können wir schauen ob sich weitere Interessenten finden, die dein Anliegen unterstützen.
          LG Stephan
          • P Offline
            PrinzEisenherz1
            #759
            Hi bolliy danke für Deine Antwort.
            Welche Anpassung ist denn in dem Fork?
            Ich habe gestern mal ein issue auf github angelegt, mit der Hoffnung das diese Option vielleicht doch noch einzug in Deinem Adapter hält! :-)
            Wäre super!!
            Gruß Johnny
            • B Online
              B Online
              bolliy
              #760
              @prinzeisenherz1 das steht im github repository: "this fork reads meter-data directly from comunication between inverter and smartmeter by a rs485-adapter"
              surfer09S 1 Antwort Letzte Antwort
              • B bolliy
                surfer09S Offline
                surfer09S Offline
                surfer09
                #761
                ich hatte per Blockly versucht den Wert für den "sun2000.0.inverter.0.battery.dischargeCutoffCapacity" zu setzen. Leider scheint das nicht zu funktionieren. Hat jemand einen Tipp für mich? Muss ich da noch etwas beachten, um den Wert zu setzen?
                <block xmlns="https://developers.google.com/blockly/xml" type="schedule" id="3g`Uj6f2os+y,26H.+)!" x="88" y="63">
                  <field name="SCHEDULE">59 23 14 10 *</field>
                  <statement name="STATEMENT">
                    <block type="control" id="v0!u]czk1PE^j_W+r~0t">
                      <field name="OID">sun2000.0.inverter.0.battery.dischargeCutoffCapacity</field>
                      <value name="VALUE">
                        <block type="math_number" id="U*N?9F7L;1L0hMZo}(H1">
                          <field name="NUM">5</field>
                        </block>
                      </value>
                    </block>
                  </statement>
                </block>
                • surfer09S surfer09
                          </block>
                        </value>
                      </block>
                    </statement>
                  </block>
                  B Online
                  B Online
                  bolliy
                  #762
                  @surfer09 du musst den entsprechenden Control state ändern: sun2000.0.inverter.0.control.battery.dischargeCutoffCapacity
                  Stephan
                  • B bolliy
                    Stephan
                    surfer09S Offline
                    surfer09S Offline
                    surfer09
                    #763
                    @bolliy Mensch, super! Danke dir! 🙂
                      B Online
                      B Online
                      bolliy
                      #764
                      @surfer09 alle Einstellungen stehen im Wiki: https://github.com/bolliy/ioBroker.sun2000/wiki/Battery-control
                      • Fredi WiegisserF Fredi Wiegisser
                        @bolliy vielleicht noch etwas Kleines zur Info. Die Register 32091 und 32093 meines Sun2000 12KTL M5 weisen eine falsche Uhrzeit aus für die Inverter Start- und Stopzeit, obschon GMT+1 korrekt eingetragen ist. Angezeigt wird aktuell die Sommerzeit, also 1h zu viel. Ich gehe davon aus, dass die Register unbehandelt im Adapter zur Verfügung stehen und direkt vom Inverter ausgelesen werden. Falls das so ist, plane ich einen Service Request bei Huawei.
                        Fredi WiegisserF Offline
                        Fredi Wiegisser
                        #765
                        @fredi-wiegisser laut Huawei Service Request, sehen sie hier keinen Fehler bei sich. Schade, dann bleibt die Uhrzeit halt falsch bis Huawei merkt, dass die Register fehlerhafte Inhalte haben.
                        • B bolliy
                          @martink und nochmal unter dem Reiter modbus Timing auto adjust anhaken. Damit die richtigen Einstellungen ermittelt werden können....
                          MartinK.M Offline
                          MartinK.M Offline
                          MartinK.
                          #766
                          @bolliy Also ich habe diese Warnmeldung jetzt auch wieder im log,
                          obwohl der SDongle aktivert ist, und ID1 hat ??
                          Error while reading from 10.79.1.255 [Reg: 37100, Len: 38, modbusID: 1] with: Timed out
                          Modbus Timing auto-adjust ist auch aktiviert ?
                          Der Adapter läuft sonst super, aber immer diese Meldungen.
                          Was kann man denn noch anpassen ?
                          ...konnte ich helfen ? Dann würde ich mich über ein Voting freuen ! (rechts unten)...
                          • MartinK.M MartinK.
                            B Online
                            B Online
                            bolliy
                            #767
                            @martink wie viele timeout Fehler treten am Tag auf?
                            Sofern diese bei der Änderung des Betriebszustands auftreten, ist dieses tolerierbar.
                            Ansonsten bitte dieses beachten: https://github.com/bolliy/ioBroker.sun2000/wiki/Fehlerprotokollierung-und-Fehlerbehebung-(troubleshooting)
                            Stephan
                            MartinK.M 1 Antwort Letzte Antwort
                            • B bolliy
                              Stephan
                              MartinK.M Offline
                              MartinK.M Offline
                              MartinK.
                              #768
                              @bolliy Also in den letzten 24 Std waren es Insgesamt 273 Warnmeldungen. Alle beziehen sich auf den selben Timeout-Fehler beim Lesen von Daten von der IP-Adresse 10.79.1.255 über Modbus. Immer nur dieser Code:
                              [Reg: 37113, Len: 2, modbusID: 1] with: Timed out
                              Reg: 32064, Reg: 32080 Reg: 37100
                              Reg: 37113, Reg: 47415
                                B Online
                                B Online
                                bolliy
                                #769
                                @martink das sind zu viele timeouts! Hast du noch ein anderes Geräte/ioBroker Instanz, welche auf den modbus des Wechselrichters zugreift? Sind alle Geräteeinheiten auf dem aktuellen Firmwarestand?
                                Stephan
                                • B bolliy
                                  Stephan
                                  MartinK.M Offline
                                  MartinK.M Offline
                                  MartinK.
                                  #770
                                  @bolliy Also es greift nur der SUN2000 Adapter mit einer Instanz darauf zu (und der Fusion Solar Account), der die Daten an die Fusion App schickt. Sonst nichts. Die Hardware hatte ich zuletzt im Januar auf Updates überprüft, als ich den SUN Adapter installiert habe. Das könnte ich nochmal machen. Aber kann das einen Timeout Fehler verursachen ?
                                  Das ist der aktuelle Software stand vom WR
                                  SUN2000-10KTL-M1
                                  Softwareversion : V100R001C00SPC161
                                  C B 2 Antworten Letzte Antwort
                                    SUN2000-10KTL-M1
                                    CyberBob
                                    #771
                                    ich möchte das wenn ich Tagsüber das Auto lade, die Batterie NICHT entladen wird. Ich bekomme es leider einfach nicht hin :-( Ich würde es gern mit Blockly lösen. Kann mir da Jemand bei helfen ?
                                    Vielen Dank !
                                    Gruß Andreas
                                    Samson71S D 2 Antworten Letzte Antwort
                                    • C CyberBob
                                      Vielen Dank !
                                      Gruß Andreas
                                      Samson71S Offline
                                      Samson71S Offline
                                      Samson71
                                      #772
                                      @cyberbob
                                      Es gilt wie immer. Zeige Deine Versuche/Ansätze und dann kann Dir ggf. jemand sagen ob und wenn ja Du irgendwo einen gedanklichen Fehler drin hast. Durch stumpfes Vorkauen ohne eigene Ansätze gibt es auch keine Lernkurve dabei.
                                      Markus
                                      Bitte beachten:
                                      C 1 Antwort Letzte Antwort
                                      • Samson71S Samson71
                                        @cyberbob
                                        CyberBob
                                        #773
                                        @samson71 ich bin mir schon nicht sicher welches Register das richtige dafür ist ...Unbenannt.JPG
                                        Das erste oder das zweite ?!
                                        und wäre es dann so richtig ? also die Batterie wird mit max. 500 W entladen ?
                                        • C CyberBob
                                          Vielen Dank !
                                          Gruß Andreas
                                          dragst3r
                                          schrieb am zuletzt editiert von dragst3r
                                          #774
                                          @cyberbob einfach einen Trigger auf das Objekt vom Ladepunkt setzen (true/false) und entsprechend die Batterie dann entsperren/sperren. Das Thema hatte ich bereits hier oder auch auf Github angerissen, da dies auch gerne so EVCC macht. Dort wird auch beschrieben welche Objekte du ansteuern musst. Ich empfehle aber erstmal das alles zu simulieren und das Verhalten zu prüfen.
                                          EDIT:
                                          https://github.com/bolliy/ioBroker.sun2000/wiki/Erzwungenes-Laden-und-Entladen-der-Batterie-(Force-charge-discharge-battery)
                                          Steffen
