  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. JK BMS mit Modbus Adapter über RS485 zu TCP einbinden.
    2.8k
    4.8k
    4.1k
111 Beiträge 8 Kommentatoren 17.9k Aufrufe 5 Beobachtet
  • Elektroniker86E Elektroniker86
    modbus.5
    2025-03-07 10:16:18.537	debug	Closing client on purpose.
    modbus.5
    2025-03-07 10:16:17.536	debug	Cleaning up request fifo.
    modbus.5
    2025-03-07 10:16:17.536	debug	Clearing timeout of the current request.
    modbus.5
    2025-03-07 10:16:17.536	debug	Socket closed with error
    modbus.5
    2025-03-07 10:16:17.531	info	Disconnected from slave 192.168.1.146
    modbus.5
    2025-03-07 10:16:17.531	debug	Closing client on purpose.
    modbus.5
    2025-03-07 10:16:17.480	warn	[DevID_1] Poll error count: 6 code: "App Timeout"
    modbus.5
    2025-03-07 10:16:12.369	warn	Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4
    modbus.5
    2025-03-07 10:16:12.279	debug	[DevID_1/holdingRegs] Poll address 4752 - 2 registers
    modbus.5
    2025-03-07 10:16:12.279	debug	[DevID_1] Poll start ---------------------
    modbus.5
    2025-03-07 10:16:11.228	warn	[DevID_1] Poll error count: 5 code: "App Timeout"
    modbus.5
    2025-03-07 10:16:06.105	warn	Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4
    modbus.5
    2025-03-07 10:16:06.027	debug	[DevID_1/holdingRegs] Poll address 4752 - 2 registers
    modbus.5
    2025-03-07 10:16:06.027	debug	[DevID_1] Poll start ---------------------
    modbus.5
    2025-03-07 10:16:04.975	warn	[DevID_1] Poll error count: 4 code: "App Timeout"
    modbus.5
    2025-03-07 10:15:59.843	warn	Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4
    modbus.5
    2025-03-07 10:15:59.775	debug	[DevID_1/holdingRegs] Poll address 4752 - 2 registers
    modbus.5
    2025-03-07 10:15:59.775	debug	[DevID_1] Poll start ---------------------
    modbus.5
    2025-03-07 10:15:58.724	warn	[DevID_1] Poll error count: 3 code: "App Timeout"
    modbus.5
    2025-03-07 10:15:53.629	warn	Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4
    modbus.5
    2025-03-07 10:15:53.523	debug	[DevID_1/holdingRegs] Poll address 4752 - 2 registers
    modbus.5
    2025-03-07 10:15:53.523	debug	[DevID_1] Poll start ---------------------
    modbus.5
    2025-03-07 10:15:52.471	warn	[DevID_1] Poll error count: 2 code: "App Timeout"
    modbus.5
    2025-03-07 10:15:47.365	warn	Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4
    modbus.5
    2025-03-07 10:15:47.270	debug	[DevID_1/holdingRegs] Poll address 4752 - 2 registers
    modbus.5
    2025-03-07 10:15:47.270	debug	[DevID_1] Poll start ---------------------
    modbus.5
    2025-03-07 10:15:46.219	warn	[DevID_1] Poll error count: 1 code: "App Timeout"
    modbus.5
    2025-03-07 10:15:41.103	warn	Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4
    modbus.5
    2025-03-07 10:15:41.019	debug	[DevID_1/holdingRegs] Poll address 4752 - 2 registers
    modbus.5
    2025-03-07 10:15:41.019	debug	Initialization of scale factors done!
    modbus.5
    2025-03-07 10:15:41.018	debug	[DevID_1] Poll start ---------------------
    modbus.5
    2025-03-07 10:15:41.018	info	Connected to slave 192.168.1.146
    modbus.5
    2025-03-07 10:15:40.927	debug	Add holdingRegisters.4752_Total_Battery_Voltage: {"_id":"holdingRegisters.4752_Total_Battery_Voltage","type":"state","common":{"name":"bat vol","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"mV"},"native":{"regType":"holdingRegs","address":4752,"deviceId":1,"type":"uint32be","len":2,"offset":4,"factor":1,"poll":true}}
    modbus.5
    2025-03-07 10:15:40.927	debug	Initialize Objects for holdingRegs: [{"_address":"4752","name":"Total Battery Voltage","description":"bat vol","unit":"mV","type":"uint32be","len":2,"factor":1,"offset":4,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":1,"address":4752,"id":"holdingRegisters.4752_Total_Battery_Voltage"}]
    modbus.5
    2025-03-07 10:15:40.927	debug	Initialize Objects for inputRegs: []
    modbus.5
    2025-03-07 10:15:40.927	debug	Initialize Objects for coils: []
    modbus.5
    2025-03-07 10:15:40.927	debug	Initialize Objects for disInputs: []
    modbus.5
    2025-03-07 10:15:40.874	info	starting. Version 6.3.2 in /opt/iobroker/node_modules/iobroker.modbus, node: v20.18.3, js-controller: 7.0.6
    modbus.5
    2025-03-07 10:15:40.764	debug	Plugin sentry Initialize Plugin (enabled=true)
    modbus.5
    2025-03-07 10:15:36.922	info	terminating
    modbus.5
    2025-03-07 10:15:36.437	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    modbus.5
    2025-03-07 10:15:36.437	debug	Plugin sentry destroyed
    modbus.5
    2025-03-07 10:15:36.437	info	terminating
    modbus.5
    2025-03-07 10:15:36.422	debug	Closing client on purpose.
    modbus.5
    2025-03-07 10:15:36.422	info	Got terminate signal TERMINATE_YOURSELF
    Sehr komisch alles, habe mit Modbus noch nie Probleme gehabt. Habe alle SMA Wechselrichter drin plus Energiezähler von EASTRoN und Heidelberg Ladestation die funktionieren super.
    @elektroniker86 sagte in JK BMS mit Modbus Adapter über RS485 zu TCP einbinden.:
    wo kommt der offset 4 her?
    edit!
    hast du den in der Zwischenzeit eingestellt?
    Warum?
    Das ist im Moment der einzige Fehler
      auf die Hälfte eingestellt.
      bitte auf 1 oder 2 stellen
      es gibt Geräte die sich sonst aufhängen.
      Muss nicht die Ursache sein, würde ich gerne ausschließen
      wo steht der Parameter denn?
      Hier
      steht 0, nicht 4
      Elektroniker86E Offline
      Elektroniker86
      @homoran sagte in JK BMS mit Modbus Adapter über RS485 zu TCP einbinden.:
      Hier
      steht 0, nicht 4
      Ich habe es so verstanden das ich den so einstellen soll
      Sorry
        Hier
        steht 0, nicht 4
        Sorry
        nein!
        2025-03-07 10:00:55.314 warn Error in handler for 3: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 3. Received 4
        Elektroniker86E 1 Antwort Letzte Antwort
          nein!
          Elektroniker86
          Ich habe den ZLAN wieder angeschlossen und offset auf 0
          modbus.5
          2025-03-07 10:47:53.458	info	Disconnected from slave 192.168.1.123
          modbus.5
          2025-03-07 10:47:53.458	debug	Closing client on purpose.
          modbus.5
          2025-03-07 10:47:52.457	debug	Cleaning up request fifo.
          modbus.5
          2025-03-07 10:47:52.457	debug	Clearing timeout of the current request.
          modbus.5
          2025-03-07 10:47:52.457	debug	Socket closed with error
          modbus.5
          2025-03-07 10:47:52.457	warn	[DevID_1] Poll error count: 7 code: {"err":"timeout","timeout":5000}
          modbus.5
          2025-03-07 10:47:52.456	error	Client in error state.
          modbus.5
          2025-03-07 10:47:52.456	error	Request timed out.
          modbus.5
          2025-03-07 10:47:52.456	warn	Error: undefined
          modbus.5
          2025-03-07 10:47:47.456	debug	[DevID_1/holdingRegs] Poll address 4752 - 2 registers
          modbus.5
          2025-03-07 10:47:47.456	debug	[DevID_1] Poll start ---------------------
          modbus.5
          2025-03-07 10:47:47.456	info	Connected to slave 192.168.1.123
            modbus.5
            modbus.5
            modbus.5
            modbus.5
            modbus.5
            modbus.5
            modbus.5
            modbus.5
            modbus.5
            modbus.5
            modbus.5
            modbus.5
            macht keinen Spaß ;-)
            den ZLAN
            ist was?
            gibt es da was einzustellen, was nicht zu den Adapter Einstellungen oder WR Einstellungen passt?
            • wendy2702W wendy2702
              ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
              Das sieht für mich so aus als wenn die Antwort zu lang ist und der reservierte Buffer nicht reicht.
              In deinem Link aus dem JSON steht für länge 0, hilft uns aber auch nicht weiter.
              Software zum testen:
              ModbusPoll
              GmodbusMaster
              RMMS (Radzio Modbus Master Simulator
              Elektroniker86
              schrieb am zuletzt editiert von Elektroniker86
              @wendy2702 sagte in JK BMS mit Modbus Adapter über RS485 zu TCP einbinden.:
              Den habe ich mal runtergeladen, aber da passiert überhaupt nichts habe die verbindung über den usb und den tcp Adapter probiert unten bei TX RX passiert nichts.
              Mit dem Programm vom JK BMS klappt die Verbindung mit dem usb Adapter einwandfrei.
                mit dem usb Adapter
                den sollte man immer nehmen, wenn möglich.
                Einen TCP2RS485 Konverter zwischenzuschalten bringt immer weitere Fehlermöglichkeiten mit sich
                  den ZLAN
                  ist was?
                  Elektroniker86
                  den ZLAN
                  Das ist der ZLAN RS485 Adapter hier im Screenshot alle Einstellungen.
                    mit dem usb Adapter
                    Elektroniker86
                    Ja, habe aber keine andere Möglichkeit da die Technik der PV Batterie in der Garage ist
                      Elektroniker86
                      @elektroniker86
                      Kann es sein das etwas mit der Adresse nicht stimmt ? Sollte man mal eine andere her nehmen?
                      Habe auch nicht verstanden warum wir jetzt die Adresse um die Spannung abzufragen in holding eingetragen haben, dachte holding ist nur um Werte zu setzen?
                        den ZLAN
                        den ZLAN
                        Damit kenne ich ich gar nicht aus, aber
                          den ZLAN
                          Elektroniker86
                          Ich habe das als DNS interpretiert falls man den Adapter von aussen erreichen möchte? Habe allerdings auch schon die IP vom ioBroker eingetragen gehabt.
                          Konnte kein unterschied feststellen...
                            @elektroniker86
                            weil es so in deiner Anleitung steht.
                            da halten sich aber leider viele Hersteller nicht dran
                              was stand dann im log?
                                Elektroniker86
                                Alles klar, verstanden
                                hier nochmal der log mit eingetragener io ip bei destination:
                                modbus.5
                                2025-03-07 11:06:47.158	info	Disconnected from slave 192.168.1.123
                                modbus.5
                                2025-03-07 11:06:47.157	debug	Closing client on purpose.
                                modbus.5
                                2025-03-07 11:06:46.157	debug	Cleaning up request fifo.
                                modbus.5
                                2025-03-07 11:06:46.157	debug	Clearing timeout of the current request.
                                modbus.5
                                2025-03-07 11:06:46.157	debug	Socket closed with error
                                modbus.5
                                2025-03-07 11:06:46.156	warn	[DevID_1] Poll error count: 2 code: {"err":"timeout","timeout":5000}
                                modbus.5
                                2025-03-07 11:06:46.156	error	Client in error state.
                                modbus.5
                                2025-03-07 11:06:46.156	error	Request timed out.
                                modbus.5
                                2025-03-07 11:06:46.156	warn	Error: undefined
                                modbus.5
                                2025-03-07 11:06:41.156	debug	[DevID_1/holdingRegs] Poll address 4752 - 2 registers
                                modbus.5
                                2025-03-07 11:06:41.155	debug	[DevID_1] Poll start ---------------------
                                modbus.5
                                2025-03-07 11:06:40.327	warn	Error in handler for 3: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
                                modbus.5
                                modbus.5
                                2025-03-07 11:06:40.104	warn	[DevID_1] Poll error count: 1 code: "ReadHoldingRegisters: Invalid FC 13"
                                modbus.5
                                2025-03-07 11:06:40.104	warn	Error in handler for 3: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
                                modbus.5
                                modbus.5
                                modbus.5
                                modbus.5
                                modbus.5
                                2025-03-07 11:06:40.103	warn	Error in handler for 3: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
                                modbus.5
                                modbus.5
                                modbus.5
                                modbus.5
                                2025-03-07 11:06:39.740	debug	[DevID_1/holdingRegs] Poll address 4752 - 2 registers
                                modbus.5
                                2025-03-07 11:06:39.740	debug	Initialization of scale factors done!
                                modbus.5
                                2025-03-07 11:06:39.739	debug	[DevID_1] Poll start ---------------------
                                modbus.5
                                2025-03-07 11:06:39.739	info	Connected to slave 192.168.1.123
                                  modbus.5
                                  modbus.5
                                  modbus.5
                                  modbus.5
                                  modbus.5
                                  modbus.5
                                  modbus.5
                                  modbus.5
                                  modbus.5
                                  modbus.5
                                  modbus.5
                                  modbus.5
                                  modbus.5
                                  modbus.5
                                  modbus.5
                                  modbus.5
                                  modbus.5
                                  modbus.5
                                  modbus.5
                                  modbus.5
                                  modbus.5
                                  modbus.5
                                  modbus.5
                                  modbus.5
                                  modbus.5
                                  modbus.5
                                  modbus.5
                                  Invalid FC 13
                                  ich hab keine Ahnung wo der herkommt
                                  es gibt anscheinend wirklich keinen FC13
                                  auch der buffer error ist wieder da
                                    Invalid FC 13
                                    Elektroniker86
                                    Sehr kurios, ich habe jetzt noch den Modbus Poll Runtergeladen. Kennst du dich mit dem Programm aus?
                                    Ich bekomme nicht mal eine Verbindung mit dem USB dongle hin......
                                    Screenshot 2025-03-07 112108.png Screenshot 2025-03-07 112015.png Screenshot 2025-03-07 111939.png
                                      nein.
                                      Bei mir ging es bisher mit allem out of the Box. Hab kein externes Programm gebraucht
                                      dann starte mal den WR neu
                                      • Elektroniker86E Offline
                                        Elektroniker86
                                        Am gleichen Laptop mit dem selben USB Dongle im JK Programm direkt eine Verbindung
                                        Hilft das was? Ne Art Konsole wo die Bus Nachrichten reinkommen?
                                          nein.
                                          Elektroniker86
                                          Der Wechselrichter Kommuniziert ja mit dem jk BMS über CAN..... Denke nicht das es daran liegt aber könnte das Kabel vom SI mal abstöpseln .....
                                          Ich möchte die Batteriewerte vom BMS auslesen da ich diese Werte nicht über den Sunny Island bekomme. Der Sunny liefert mir über Modbus nur den SOC und Lade bzw. Entladeleistung........
                                          Das JK Kommuniziert untereinander ( mehrere Batteriepacks) über Modbus
