  4. iobroker nach zigbee installation nicht mehr ansprechbar
    1.0k
    6.1k
22 Beiträge 7 Kommentatoren 2.8k Aufrufe 7 Beobachtet
  • W w m 77
    hat jemand eine Idee wie ich hier weiter komme ??
    Script v.2025-02-23
    *** BASE SYSTEM ***
     Static hostname: iobroker
           Icon name: computer
              Kernel: Linux 6.6.74+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     20:34:32 up  4:10,  3 users,  load average: 2.01, 3.00, 3.38
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Mon 2025-03-03 20:34:32 CET
               Universal time: Mon 2025-03-03 19:34:32 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            1.9G        837M        221M        1.2M        950M        1.1G
    Swap:           209M        262K        209M
    Total:          2.1G        837M        430M
    Active iob-Instances:   12
             1846 M total memory
              798 M used memory
              744 M active memory
              731 M inactive memory
              210 M free memory
               41 M buffer memory
              864 M swap cache
              199 M total swap
                0 M used swap
              199 M free swap
    top - 20:34:32 up  4:10,  3 users,  load average: 2.01, 3.00, 3.38
    Tasks: 180 total,   2 running, 178 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us, 20.0 sy,  0.0 ni, 80.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   1846.8 total,    210.2 free,    799.2 used,    906.7 buff/cache
    MiB Swap:    200.0 total,    199.7 free,      0.2 used.   1047.6 avail Mem
    *** FAILED SERVICES ***
      UNIT                               LOAD   ACTIVE SUB    DESCRIPTION
    * NetworkManager-wait-online.service loaded failed failed Network Manager Wait Online
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  660M     0  660M   0% /dev
    tmpfs          tmpfs     185M  1.3M  184M   1% /run
    /dev/mmcblk0p2 ext4       14G  7.8G  5.3G  60% /
    tmpfs          tmpfs     924M     0  924M   0% /dev/shm
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   65M  446M  13% /boot/firmware
    tmpfs          tmpfs     185M     0  185M   0% /run/user/1000
    [Mon Mar  3 16:24:11 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmiize=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=089bb4f7-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=AT
    [Mon Mar  3 16:24:26 2025] EXT4-fs (mmcblk0p2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
    [Mon Mar  3 16:24:28 2025] EXT4-fs (mmcblk0p2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w. Quota mode: none.
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.4G    /var/
    677M    /var/log/journal/4a8789595c9241c69387c9238a2f02df
    677M    /var/log
    292M    /var/cache
    Archived and active journals take up 676.4M in the file system.
    /opt/iobroker/backups:
    203M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    2.3G    /opt/iobroker/iobroker-data/
    1.3G    /opt/iobroker/iobroker-data/files
    980M    /opt/iobroker/iobroker-data/0_userdata.0
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
    26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.1e6546bb.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.3
    /usr/bin/node           v20.18.3
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.30.0
    nodejs:
      Installed: 20.18.3-1nodesource1
      Candidate: 20.18.3-1nodesource1
      Version table:
     *** 20.18.3-1nodesource1 600
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
         20.18.2-1nodesource1 600
         20.18.1-1nodesource1 600
         20.18.0-1nodesource1 600
         20.17.0-1nodesource1 600
         20.16.0-1nodesource1 600
         20.15.1-1nodesource1 600
         20.15.0-1nodesource1 600
         20.14.0-1nodesource1 600
         20.13.1-1nodesource1 600
         20.13.0-1nodesource1 600
         20.12.2-1nodesource1 600
         20.12.1-1nodesource1 600
         20.12.0-1nodesource1 600
         20.11.1-1nodesource1 600
         20.11.0-1nodesource1 600
         20.10.0-1nodesource1 600
         20.9.0-1nodesource1 600
         20.8.1-1nodesource1 600
         20.8.0-1nodesource1 600
         20.7.0-1nodesource1 600
         20.6.1-1nodesource1 600
         20.6.0-1nodesource1 600
         20.5.1-1nodesource1 600
         20.5.0-1nodesource1 600
         20.4.0-1nodesource1 600
         20.3.1-1nodesource1 600
         20.3.0-1nodesource1 600
         20.2.0-1nodesource1 600
         20.1.0-1nodesource1 600
         20.0.0-1nodesource1 600
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 413)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.4.10
    javascript:     8.8.3
    nodejs modules from github:     0
    Adapter State
      system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      system.adapter.bydbatt.0                : bydbatt               : iobroker                                 - disabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
      system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobroker                                 - disabled
      system.adapter.fronius-wattpilot.0      : fronius-wattpilot     : iobroker                                 - disabled
    + system.adapter.g-homa.0                 : g-homa                : iobroker                                 -  enabled
      system.adapter.habpanel.0               : habpanel              : iobroker                                 - disabled
    + system.adapter.history.0                : history               : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
    + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
      system.adapter.opendtu.0                : opendtu               : iobroker                                 - disabled
      system.adapter.rickshaw.0               : rickshaw              : iobroker                                 - disabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: ::
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
      system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 10.0.0.99, run as: admin
    + system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Cannot read or parse /opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common//../node_modules/iobroker.zigbee2mqtt/io-package.json: /opt/iobroker/node_modules/iobroker.zigbee2mqtt/io-package.json: Unexpected end o
    Adapter    "admin"        : 7.4.10   , installed 7.4.10
    Adapter    "backitup"     : 3.0.31   , installed 3.0.31
    Adapter    "bydbatt"      : 1.1.0    , installed 1.1.0
    Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
    Adapter    "fronius-wattpilot": 4.6.3, installed 4.6.3
    Adapter    "g-homa"       : 0.5.3    , installed 0.5.3
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "modbus"       : 6.3.2    , installed 6.3.2
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
    Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
    Adapter    "shelly"       : 8.5.1    , installed 8.5.1
    Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Objects and States
    Objects:        7875
    States:         6378
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5655       667/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       52181      14177/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       52176      14177/iobroker.js-c
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       54979      14423/io.mqtt.0
    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       54903      14390/io.sonoff.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          5657       667/sshd: /usr/sbin
    tcp6       0      0 :::1882                 :::*                    LISTEN      1001       52842      14354/io.shelly.0
    tcp6       0      0 :::50000                :::*                    LISTEN      1001       53981      14466/io.g-homa.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       52945      14648/io.ws.0
    udp        0      0 0.0.0.0:51304           0.0.0.0:*                           104        4990       504/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4988       504/avahi-daemon: r
    udp6       0      0 :::35924                :::*                                104        4991       504/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        4989       504/avahi-daemon: r
    udp6       0      0 fe80::fd4e:3335:540:546 :::*                                0          6458       607/NetworkManager
    2025-03-03 20:35:52.298  - warn: modbus.1 (14339) [DevID_201] Poll error count: 1 code: {"errorCode":131,"exceptionCode":11,"message":"GATEWAY TARGET DEVICE FAILED TO RESPOND"}
    2025-03-03 20:35:46.948  - error: host.iobroker Caught by controller[0]: node:internal/modules/package_json_reader:93
    2025-03-03 20:35:46.948  - error: host.iobroker Caught by controller[0]:         throw error;
    2025-03-03 20:35:46.948  - error: host.iobroker Caught by controller[0]:         ^
    2025-03-03 20:35:46.949  - error: host.iobroker Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/side-channel/package.json: Unexpected end of JSON input
    2025-03-03 20:35:46.949  - error: host.iobroker Caught by controller[0]:     at parse (<anonymous>)
    2025-03-03 20:35:46.949  - error: host.iobroker Caught by controller[0]:     at read (node:internal/modules/package_json_reader:80:16)
    2025-03-03 20:35:46.949  - error: host.iobroker Caught by controller[0]:     at readPackage (node:internal/modules/package_json_reader:141:10)
    2025-03-03 20:35:46.950  - error: host.iobroker Caught by controller[0]:     at resolveExports (node:internal/modules/cjs/loader:630:15)
    2025-03-03 20:35:46.950  - error: host.iobroker Caught by controller[0]:     at Module._findPath (node:internal/modules/cjs/loader:724:31)
    2025-03-03 20:35:46.950  - error: host.iobroker Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1211:27)
    2025-03-03 20:35:46.951  - error: host.iobroker Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1051:27)
    2025-03-03 20:35:46.951  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1311:19)
    2025-03-03 20:35:46.951  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
    2025-03-03 20:35:46.951  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/qs/lib/stringify.js:3:22) {
    2025-03-03 20:35:46.952  - error: host.iobroker Caught by controller[0]:   path: '/opt/iobroker/node_modules/side-channel/package.json'
    2025-03-03 20:35:46.952  - error: host.iobroker Caught by controller[0]: }
    2025-03-03 20:35:46.953  - error: host.iobroker Caught by controller[0]: Node.js v20.18.3
    2025-03-03 20:35:46.954  - error: host.iobroker instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2025-03-03 20:35:46.954  - info: host.iobroker Restart adapter system.adapter.web.0 because enabled
    2025-03-03 20:36:02.376  - info: shelly.0 (14354) [Sys.timezone] 10.0.0.52 (shellyplus1pm / shellyplus1pm-fcb467ba5318 / shellyplus1pm#fcb467ba5318#1): Configured timezone "Europe/Vienna" and system timezone "Europe/Berlin" do not match. P
    2025-03-03 20:36:02.447  - warn: modbus.1 (14339) [DevID_1/holdingRegs/40314] Calculation of a scaleFactor which is based on another scaleFactor seems strange. Please check the config for address 40314 !
    2025-03-03 20:36:02.721  - warn: modbus.1 (14339) [DevID_201] Poll error count: 1 code: {"errorCode":131,"exceptionCode":11,"message":"GATEWAY TARGET DEVICE FAILED TO RESPOND"}
    2025-03-03 20:36:03.343  - info: javascript.0 (14271) script.js.leistungssteuerung: schalter 6 of
    2025-03-03 20:36:03.501  - info: host.iobroker instance system.adapter.admin.0 in version "7.4.10" started with pid 17168
    crunchipC Abwesend
    crunchipC Abwesend
    @w-m-77 sagte in iobroker nach zigbee installation nicht mehr ansprechbar:
    bind: 10.0.0.99
    Ist das bewusst?
    W 1 Antwort Letzte Antwort
      bind: 10.0.0.99
      Ist das bewusst?
      W Offline
      W Offline
      w m 77
      @crunchip ja, hab ich so ausgewählt..
      • crunchipC Abwesend
        crunchipC Abwesend
        leider mit wenig Erfolg
        mit welcher Meldung?
        iob start admin --debug
        ggf kommen deine Probleme auch daher
        • W w m 77
          mcm1957M Online
          mcm1957M Online
          mcm1957
          @w-m-77
          Also da ist was ziemlich faul:
          Die Zigbee Installation selbst ist da schief gelaufen. Aus welcher Quelle hast du denn ZigBee installiert? Ich würd in jedem Fall mal versuchen den Adapter neu zu (re-)installieren.
          Außerdem schreibst du dass das Problem nach der Installtion von Zigbee aufgetreten ist. Die defekten Files gehören aber zu zigbee2mqtt. Was hast du genau imstalliert?
          Der Diskspace ist dir nicjht zufällig bei der Installation augegangen? Derzeit sond zwar 40% frei - aber es gab schon user die es nicht für wichtig empfunden haben zu schreiben, dass sie ein Installtionsproblem hatte und nachher erst Platz geschaffen haben ...
          Support Repositoryverwaltung.
          LESEN - gute Forenbeitrage
          • mcm1957M mcm1957
            @w-m-77
            W Offline
            W Offline
            w m 77
            @mcm1957
            stimmt da war ich wohl etwas ungenau in der Ausfürhrung ...war im Detail der "Zigbee2mqtt" adapter direkt über die IOB Oberfläche
            den verfügbaren Speicherplatz habe ich vor der installation nicht kontrolliert... allerdings danach auch nicht aufgeräumt..
            reinstallieren über die Konsole.. wie müsste das aussehen??
            • W w m 77
              @mcm1957
              @w-m-77
              iob update
              iob upgrade zigbee2mqtt@3.0.2 --debug
              versuchen, wenn du auf stable unterwegs bist.
                crunchipC Abwesend
                @thomas-braun sagte in iobroker nach zigbee installation nicht mehr ansprechbar:
                upgrade
                ist das nicht eher install, bzw add , da der Adapter ja gar nicht installiert ist
                unabhängig davon,
                bewusst?, das dieser aber nicht eigenständig läuft, ist hoffentlich bekannt
                  upgrade
                  unabhängig davon,
                  @crunchip
                  Wenn ich
                  richtig interpretiere ist der Adapter schon installiert. Wenn auch irgendwie 'krumm'.
                  Edit: Hast wohl Recht, der Adapter taucht oben im iob diag nicht auf.
                    @crunchip
                    Wenn ich
                    crunchipC Abwesend
                    crunchipC Abwesend
                    @thomas-braun sehe ich jedoch nicht so
                    dann müsste er ja da gelistet sein, oder nicht?
                      @crunchip
                      Das ist wohl eine krumme/unvollständige Installation.
                      sollte ja auch nicht auftauchen.
                        @crunchip
                        W Offline
                        W Offline
                        w m 77
                        pi@iobroker:~ $ iob upgrade zigbee2mqtt@3.0.2 --debug
                        Cannot upgrade: /opt/iobroker/node_modules/iobroker.zigbee2mqtt/io-package.json: Unexpected end of JSON input
                        pi@iobroker:~ $ iob install zigbee2mqtt@3.0.2 --debug
                        adapter "zigbee2mqtt" already installed. Use "upgrade" to upgrade to a newer version.
                        • W w m 77
                          @w-m-77
                          Und deinstallieren geht vermutlich auch nicht?
                            @w-m-77
                            mcm1957M Online
                            mcm1957M Online
                            mcm1957
                            schätze das ist der seltene Fall wo die Leiche mit npm oder rm weg muss. Bin nur am Handy. Ev kannst du ha die richtigen Befehle vorschlagen.
                            Danje.
                            • W w m 77
                              Versuch mal
                              cd /opt/iobroker && npm uninstall iobroker.zigbee2mqtt
                              W 2 Antworten Letzte Antwort
                                Versuch mal
                                W Offline
                                W Offline
                                w m 77
                                schrieb am zuletzt editiert von w m 77
                                Herzlichen Dank Thomas !!👏
                                läuft wieder ... jetzt werd ich mich mal mit folgendem Thema beschäftigen: wie kann man am besten externe Backups erstellen und auf einem neuen System wiederherstellen ...
                                p.s: !!ich hoffe meine kleine Kaffeespende kommt den mir helfenden Händen irgendwie zu gute!!
                                • W w m 77
                                  mit backitup
                                    Versuch mal
                                    W Offline
                                    W Offline
                                    w m 77
                                    @thomas-braun said in iobroker nach zigbee installation nicht mehr ansprechbar:
                                    Versuch mal
