iobroker nach zigbee installation nicht mehr ansprechbar
iob start admin -
hat jemand eine Idee wie ich hier weiter komme ??
Script v.2025-02-23 *** BASE SYSTEM *** Static hostname: iobroker Icon name: computer Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.6.74+rpt-rpi-v8 Architecture: arm64 OS is similar to: Model : Raspberry Pi 4 Model B Rev 1.1 Docker : false Virtualization : none Kernel : aarch64 Userland : 64 bit Systemuptime and Load: 20:34:32 up 4:10, 3 users, load average: 2.01, 3.00, 3.38 CPU threads: 4 *** LIFE CYCLE STATUS *** Operating System is the current Debian stable version codenamed 'bookworm'! *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** TIME AND TIMEZONES *** Local time: Mon 2025-03-03 20:34:32 CET Universal time: Mon 2025-03-03 19:34:32 UTC RTC time: n/a Time zone: Europe/Berlin (CET, +0100) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': pi HOME=/home/pi GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c *** DISPLAY-SERVER SETUP *** Display-Server: false Desktop: Terminal: tty *** MEMORY *** total used free shared buff/cache available Mem: 1.9G 837M 221M 1.2M 950M 1.1G Swap: 209M 262K 209M Total: 2.1G 837M 430M Active iob-Instances: 12 1846 M total memory 798 M used memory 744 M active memory 731 M inactive memory 210 M free memory 41 M buffer memory 864 M swap cache 199 M total swap 0 M used swap 199 M free swap *** top - Table Of Processes *** top - 20:34:32 up 4:10, 3 users, load average: 2.01, 3.00, 3.38 Tasks: 180 total, 2 running, 178 sleeping, 0 stopped, 0 zombie %Cpu(s): 0.0 us, 20.0 sy, 0.0 ni, 80.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 1846.8 total, 210.2 free, 799.2 used, 906.7 buff/cache MiB Swap: 200.0 total, 199.7 free, 0.2 used. 1047.6 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION * NetworkManager-wait-online.service loaded failed failed Network Manager Wait Online LOAD = Reflects whether the unit definition was properly loaded. ACTIVE = The high-level unit activation state, i.e. generalization of SUB. SUB = The low-level unit activation state, values depend on unit type. 1 loaded units listed. *** DMESG CRITICAL ERRORS *** No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 660M 0 660M 0% /dev tmpfs tmpfs 185M 1.3M 184M 1% /run /dev/mmcblk0p2 ext4 14G 7.8G 5.3G 60% / tmpfs tmpfs 924M 0 924M 0% /dev/shm tmpfs tmpfs 5.0M 16K 5.0M 1% /run/lock /dev/mmcblk0p1 vfat 510M 65M 446M 13% /boot/firmware tmpfs tmpfs 185M 0 185M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Mon Mar 3 16:24:11 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmiize=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=089bb4f7-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=AT [Mon Mar 3 16:24:26 2025] EXT4-fs (mmcblk0p2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none. [Mon Mar 3 16:24:28 2025] EXT4-fs (mmcblk0p2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w. Quota mode: none. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/mmcblk0p2 ext4 rw,noatime `-/boot/firmware /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 1.4G /var/ 677M /var/log/journal/4a8789595c9241c69387c9238a2f02df 677M /var/log/journal 677M /var/log 292M /var/cache Archived and active journals take up 676.4M in the file system. /opt/iobroker/backups: 203M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 2.3G /opt/iobroker/iobroker-data/ 1.3G /opt/iobroker/iobroker-data/files 980M /opt/iobroker/iobroker-data/0_userdata.0 617M /opt/iobroker/iobroker-data/files/javascript.admin 560M /opt/iobroker/iobroker-data/files/javascript.admin/static The five largest files in iobroker-data are: 38M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map 26M /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map 26M /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map 24M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map 24M /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.1e6546bb.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': No Devices found 'by-id' Zigbee Network Settings on your coordinator/in nvbackup are: zigbee.X Extended Pan ID: *** MASKED *** Pan ID: *** MASKED *** Channel: *** MASKED *** Network Key: *** MASKED *** To unmask the settings run 'iob diag --unmask' *** NodeJS-Installation *** /usr/bin/nodejs v20.18.3 /usr/bin/node v20.18.3 /usr/bin/npm 10.8.2 /usr/bin/npx 10.8.2 /usr/bin/corepack 0.30.0 nodejs: Installed: 20.18.3-1nodesource1 Candidate: 20.18.3-1nodesource1 Version table: *** 20.18.3-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 100 /var/lib/dpkg/status 20.18.2-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.18.1-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.18.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.17.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.16.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.15.1-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.15.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.14.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.13.1-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.13.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.12.2-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.12.1-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.12.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.11.1-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.11.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.10.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.9.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.8.1-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.8.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.7.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.6.1-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.6.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.5.1-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.5.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.4.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.3.1-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.3.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.2.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.1.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.0.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 18.19.0+dfsg-6~deb12u2 500 500 http://deb.debian.org/debian bookworm/main arm64 Packages 18.19.0+dfsg-6~deb12u1 500 500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Hosts: iobroker iobroker (version: 7.0.6, hostname: iobroker , alive, uptime: 413) Core adapters versions js-controller: 7.0.6 admin: 7.4.10 javascript: 8.8.3 nodejs modules from github: 0 Adapter State system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.backitup.0 : backitup : iobroker - enabled system.adapter.bydbatt.0 : bydbatt : iobroker - disabled + system.adapter.discovery.0 : discovery : iobroker - enabled system.adapter.flot.0 : flot : iobroker - disabled system.adapter.fronius-solarweb.0 : fronius-solarweb : iobroker - disabled system.adapter.fronius-wattpilot.0 : fronius-wattpilot : iobroker - disabled + system.adapter.g-homa.0 : g-homa : iobroker - enabled system.adapter.habpanel.0 : habpanel : iobroker - disabled + system.adapter.history.0 : history : iobroker - enabled + system.adapter.javascript.0 : javascript : iobroker - enabled + system.adapter.modbus.0 : modbus : iobroker - enabled + system.adapter.modbus.1 : modbus : iobroker - enabled + system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1880, bind: 0.0.0.0 system.adapter.opendtu.0 : opendtu : iobroker - disabled system.adapter.rickshaw.0 : rickshaw : iobroker - disabled + system.adapter.shelly.0 : shelly : iobroker - enabled, port: 1882, bind: :: + system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1886, bind: 0.0.0.0 system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 10.0.0.99, run as: admin + system.adapter.ws.0 : ws : iobroker - enabled, port: 8084, bind: 0.0.0.0, run as: admin + instance is alive Enabled adapters with bindings system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1880, bind: 0.0.0.0 + system.adapter.shelly.0 : shelly : iobroker - enabled, port: 1882, bind: :: + system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1886, bind: 0.0.0.0 system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 10.0.0.99, run as: admin + system.adapter.ws.0 : ws : iobroker - enabled, port: 8084, bind: 0.0.0.0, run as: admin ioBroker-Repositories ┌─────────┬──────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼──────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴──────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): stable Upgrade policy: none Installed ioBroker-Adapters Used repository: stable Cannot read or parse /opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common//../node_modules/iobroker.zigbee2mqtt/io-package.json: /opt/iobroker/node_modules/iobroker.zigbee2mqtt/io-package.json: Unexpected end o Cannot read or parse /opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common//../node_modules/iobroker.zigbee2mqtt/io-package.json: /opt/iobroker/node_modules/iobroker.zigbee2mqtt/io-package.json: Unexpected end o Adapter "admin" : 7.4.10 , installed 7.4.10 Adapter "backitup" : 3.0.31 , installed 3.0.31 Adapter "bydbatt" : 1.1.0 , installed 1.1.0 Adapter "discovery" : 5.0.0 , installed 5.0.0 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "fronius-solarweb": 0.0.3 , installed 0.0.3 Adapter "fronius-wattpilot": 4.6.3, installed 4.6.3 Adapter "g-homa" : 0.5.3 , installed 0.5.3 Adapter "habpanel" : 0.5.0 , installed 0.5.0 Adapter "history" : 3.0.1 , installed 3.0.1 Adapter "javascript" : 8.8.3 , installed 8.8.3 Controller "js-controller": 7.0.6 , installed 7.0.6 Adapter "modbus" : 6.3.2 , installed 6.3.2 Adapter "mqtt" : 6.1.2 , installed 6.1.2 Adapter "opendtu" : 3.1.0 , installed 3.1.0 Adapter "rickshaw" : 1.0.0 , installed 1.0.0 Adapter "shelly" : 8.5.1 , installed 8.5.1 Adapter "simple-api" : 2.8.0 , installed 2.8.0 Adapter "socketio" : 6.7.1 , installed 6.7.1 Adapter "sonoff" : 3.1.2 , installed 3.1.2 Adapter "web" : 6.2.5 , installed 6.2.5 Adapter "ws" : 2.6.2 , installed 2.6.2 Objects and States Please stand by - This may take a while Objects: 7875 States: 6378 *** OS-Repositories and Updates *** Hit:1 http://deb.debian.org/debian bookworm InRelease Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease Hit:3 http://deb.debian.org/debian bookworm-updates InRelease Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 5655 667/sshd: /usr/sbin tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 52181 14177/iobroker.js-c tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 52176 14177/iobroker.js-c tcp 0 0 0.0.0.0:1880 0.0.0.0:* LISTEN 1001 54979 14423/io.mqtt.0 tcp 0 0 0.0.0.0:1886 0.0.0.0:* LISTEN 1001 54903 14390/io.sonoff.0 tcp6 0 0 :::22 :::* LISTEN 0 5657 667/sshd: /usr/sbin tcp6 0 0 :::1882 :::* LISTEN 1001 52842 14354/io.shelly.0 tcp6 0 0 :::50000 :::* LISTEN 1001 53981 14466/io.g-homa.0 tcp6 0 0 :::8084 :::* LISTEN 1001 52945 14648/io.ws.0 udp 0 0 0.0.0.0:51304 0.0.0.0:* 104 4990 504/avahi-daemon: r udp 0 0 0.0.0.0:5353 0.0.0.0:* 104 4988 504/avahi-daemon: r udp6 0 0 :::35924 :::* 104 4991 504/avahi-daemon: r udp6 0 0 :::5353 :::* 104 4989 504/avahi-daemon: r udp6 0 0 fe80::fd4e:3335:540:546 :::* 0 6458 607/NetworkManager *** Log File - Last 25 Lines *** 2025-03-03 20:35:52.298 - warn: modbus.1 (14339) [DevID_201] Poll error count: 1 code: {"errorCode":131,"exceptionCode":11,"message":"GATEWAY TARGET DEVICE FAILED TO RESPOND"} 2025-03-03 20:35:46.948 - error: host.iobroker Caught by controller[0]: node:internal/modules/package_json_reader:93 2025-03-03 20:35:46.948 - error: host.iobroker Caught by controller[0]: throw error; 2025-03-03 20:35:46.948 - error: host.iobroker Caught by controller[0]: ^ 2025-03-03 20:35:46.949 - error: host.iobroker Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/side-channel/package.json: Unexpected end of JSON input 2025-03-03 20:35:46.949 - error: host.iobroker Caught by controller[0]: at parse (<anonymous>) 2025-03-03 20:35:46.949 - error: host.iobroker Caught by controller[0]: at read (node:internal/modules/package_json_reader:80:16) 2025-03-03 20:35:46.949 - error: host.iobroker Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:141:10) 2025-03-03 20:35:46.950 - error: host.iobroker Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:630:15) 2025-03-03 20:35:46.950 - error: host.iobroker Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:724:31) 2025-03-03 20:35:46.950 - error: host.iobroker Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1211:27) 2025-03-03 20:35:46.951 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1051:27) 2025-03-03 20:35:46.951 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1311:19) 2025-03-03 20:35:46.951 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/helpers:179:18) 2025-03-03 20:35:46.951 - error: host.iobroker Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/qs/lib/stringify.js:3:22) { 2025-03-03 20:35:46.952 - error: host.iobroker Caught by controller[0]: path: '/opt/iobroker/node_modules/side-channel/package.json' 2025-03-03 20:35:46.952 - error: host.iobroker Caught by controller[0]: } 2025-03-03 20:35:46.953 - error: host.iobroker Caught by controller[0]: Node.js v20.18.3 2025-03-03 20:35:46.954 - error: host.iobroker instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED) 2025-03-03 20:35:46.954 - info: host.iobroker Restart adapter system.adapter.web.0 because enabled 2025-03-03 20:36:02.376 - info: shelly.0 (14354) [Sys.timezone] 10.0.0.52 (shellyplus1pm / shellyplus1pm-fcb467ba5318 / shellyplus1pm#fcb467ba5318#1): Configured timezone "Europe/Vienna" and system timezone "Europe/Berlin" do not match. P 2025-03-03 20:36:02.447 - warn: modbus.1 (14339) [DevID_1/holdingRegs/40314] Calculation of a scaleFactor which is based on another scaleFactor seems strange. Please check the config for address 40314 ! 2025-03-03 20:36:02.721 - warn: modbus.1 (14339) [DevID_201] Poll error count: 1 code: {"errorCode":131,"exceptionCode":11,"message":"GATEWAY TARGET DEVICE FAILED TO RESPOND"} 2025-03-03 20:36:03.343 - info: javascript.0 (14271) script.js.leistungssteuerung: schalter 6 of 2025-03-03 20:36:03.501 - info: host.iobroker instance system.adapter.admin.0 in version "7.4.10" started with pid 17168============ Mark until here for C&P =============
@w-m-77 sagte in iobroker nach zigbee installation nicht mehr ansprechbar:
bind: 10.0.0.99
Ist das bewusst?
bind: 10.0.0.99
Ist das bewusst?
leider mit wenig Erfolg
mit welcher Meldung?
iob start admin --debugggf kommen deine Probleme auch daher
Also da ist was ziemlich faul:
Used repository: stable Cannot read or parse /opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common//../node_modules/iobroker.zigbee2mqtt/io-package.json: /opt/iobroker/node_modules/iobroker.zigbee2mqtt/io-package.json: Unexpected end o Cannot read or parse /opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common//../node_modules/iobroker.zigbee2mqtt/io-package.json: /opt/iobroker/node_modules/iobroker.zigbee2mqtt/io-package.json: Unexpected end o Adapter "admin" : 7.4.10 , installed 7.4.10Die Zigbee Installation selbst ist da schief gelaufen. Aus welcher Quelle hast du denn ZigBee installiert? Ich würd in jedem Fall mal versuchen den Adapter neu zu (re-)installieren.
Außerdem schreibst du dass das Problem nach der Installtion von Zigbee aufgetreten ist. Die defekten Files gehören aber zu zigbee2mqtt. Was hast du genau imstalliert?
Der Diskspace ist dir nicjht zufällig bei der Installation augegangen? Derzeit sond zwar 40% frei - aber es gab schon user die es nicht für wichtig empfunden haben zu schreiben, dass sie ein Installtionsproblem hatte und nachher erst Platz geschaffen haben ...
@mcm1957
stimmt da war ich wohl etwas ungenau in der Ausfürhrung ...war im Detail der "Zigbee2mqtt" adapter direkt über die IOB Oberflächeden verfügbaren Speicherplatz habe ich vor der installation nicht kontrolliert... allerdings danach auch nicht aufgeräumt..
reinstallieren über die Konsole.. wie müsste das aussehen??
@mcm1957
iob update iob upgrade zigbee2mqtt@3.0.2 --debugversuchen, wenn du auf stable unterwegs bist.
@thomas-braun sagte in iobroker nach zigbee installation nicht mehr ansprechbar:
upgrade
ist das nicht eher
install, bzwadd, da der Adapter ja gar nicht installiert istunabhängig davon,
bewusst?, das dieser aber nicht eigenständig läuft, ist hoffentlich bekannt
upgrade
ist das nicht eher
Wenn ich
richtig interpretiere ist der Adapter schon installiert. Wenn auch irgendwie 'krumm'.
Edit: Hast wohl Recht, der Adapter taucht oben im
iob diagnicht auf. -
Wenn ich
iob diagnicht auf.@thomas-braun sehe ich jedoch nicht so
dann müsste er ja da gelistet sein, oder nicht? -
dann müsste er ja da gelistet sein, oder nicht?Das ist wohl eine krumme/unvollständige Installation.
sollte ja auch nicht auftauchen.
pi@iobroker:~ $ iob upgrade zigbee2mqtt@3.0.2 --debug Cannot upgrade: /opt/iobroker/node_modules/iobroker.zigbee2mqtt/io-package.json: Unexpected end of JSON input pi@iobroker:~ $ iob install zigbee2mqtt@3.0.2 --debug adapter "zigbee2mqtt" already installed. Use "upgrade" to upgrade to a newer version.MOD-EDIT: Code in code-tags gesetzt!
Und deinstallieren geht vermutlich auch nicht?
schätze das ist der seltene Fall wo die Leiche mit npm oder rm weg muss. Bin nur am Handy. Ev kannst du ha die richtigen Befehle vorschlagen.Danje.
Versuch mal
cd /opt/iobroker && npm uninstall iobroker.zigbee2mqtt -
Versuch mal
cd /opt/iobroker && npm uninstall iobroker.zigbee2mqttHerzlichen Dank Thomas !!
läuft wieder ... jetzt werd ich mich mal mit folgendem Thema beschäftigen: wie kann man am besten externe Backups erstellen und auf einem neuen System wiederherstellen ...
p.s: !!ich hoffe meine kleine Kaffeespende kommt den mir helfenden Händen irgendwie zu gute!! -
p.s: !!ich hoffe meine kleine Kaffeespende kommt den mir helfenden Händen irgendwie zu gute!!@w-m-77 sagte in iobroker nach zigbee installation nicht mehr ansprechbar:
mit backitup
Versuch mal
cd /opt/iobroker && npm uninstall iobroker.zigbee2mqtt@thomas-braun said in iobroker nach zigbee installation nicht mehr ansprechbar:
Versuch mal
