  4. "admin.0 Restart loop detected" und keine Trigger mehr
113 Beiträge 9 Kommentatoren 18.9k Aufrufe 6 Beobachtet
  • KlausStoertebekerK KlausStoertebeker
    Und hier, wie angefordert, die Ausgabe von iob diag:
    Script v.2025-02-23
    *** BASE SYSTEM ***
     Static hostname: Nordmanns-Raspberry-Pi5
           Icon name: computer
              Kernel: Linux 6.6.74+rpt-rpi-2712
        Architecture: arm64
    OS is similar to:
    Model		: Raspberry Pi 5 Model B Rev 1.0
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     10:18:32 up 16:45,  4 users,  load average: 0.28, 0.32, 0.30
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Fri 2025-02-28 10:18:32 CET
               Universal time: Fri 2025-02-28 09:18:32 UTC
                     RTC time: Fri 2025-02-28 09:18:32
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    ansgarhoeber
    HOME=/home/ansgarhoeber
    GROUPS=ansgarhoeber adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: true
    Desktop:
    Terminal: 	tty
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
    *** MEMORY ***
    Mem:            8.5G        2.5G        3.9G         98M        2.2G        5.9G
    Swap:           209M          0B        209M
    Total:          8.7G        2.5G        4.1G
    Active iob-Instances: 	25
             8064 M total memory
             2427 M used memory
             2371 M active memory
             1450 M inactive memory
             3700 M free memory
              394 M buffer memory
             1723 M swap cache
              199 M total swap
                0 M used swap
              199 M free swap
    top - 10:18:32 up 16:45,  4 users,  load average: 0.28, 0.32, 0.30
    Tasks: 267 total,   1 running, 266 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 33.3 us,  0.0 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8064.1 total,   3699.6 free,   2427.9 used,   2118.0 buff/cache
    MiB Swap:    200.0 total,    200.0 free,      0.0 used.   5636.2 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs          tmpfs     807M  6.4M  801M   1% /run
    /dev/nvme0n1p2 ext4      234G   12G  210G   6% /
    tmpfs          tmpfs     4.0G  288K  4.0G   1% /dev/shm
    tmpfs          tmpfs     5.0M   64K  5.0M   2% /run/lock
    /dev/nvme0n1p1 vfat      511M   77M  435M  15% /boot/firmware
    tmpfs          tmpfs     807M  208K  807M   1% /run/user/1000
    [Thu Feb 27 17:32:41 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=2C:CF:67:42:E1:7E vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=628bce8a-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
    [Thu Feb 27 17:32:42 2025] EXT4-fs (nvme0n1p2): mounted filesystem fc7a1f9e-4967-4f41-a1f5-1b5927e6c5f9 ro with ordered data mode. Quota mode: none.
    [Thu Feb 27 17:32:43 2025] EXT4-fs (nvme0n1p2): re-mounted fc7a1f9e-4967-4f41-a1f5-1b5927e6c5f9 r/w. Quota mode: none.
    Show mounted filesystems:
    TARGET               SOURCE         FSTYPE      OPTIONS
    /                    /dev/nvme0n1p2 ext4        rw,noatime
    |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    `-/boot/firmware     /dev/nvme0n1p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    2.3G	/var/
    1.6G	/var/cache/apt
    1.6G	/var/cache
    1.5G	/var/cache/apt/archives
    318M	/var/log
    Archived and active journals take up 316.6M in the file system.
    /opt/iobroker/backups:
    4.0K	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.4G	/opt/iobroker/iobroker-data/
    1.3G	/opt/iobroker/iobroker-data/files
    617M	/opt/iobroker/iobroker-data/files/javascript.admin
    560M	/opt/iobroker/iobroker-data/files/javascript.admin/static
    558M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
    26M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
    26M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
    24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    24M	/opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
    24M	/opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-0658_0200-if00
    /dev/serial/by-id/usb-EnOcean_GmbH_EnOcean_USB_300_DB_FT2PTYKW-if00-port0
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v20.18.3
    /usr/bin/node 		v20.18.3
    /usr/bin/npm 		10.8.2
    /usr/bin/npx 		10.8.2
    /usr/bin/corepack 	0.30.0
    nodejs:
      Installed: 20.18.3-1nodesource1
      Candidate: 20.18.3-1nodesource1
      Version table:
     *** 20.18.3-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    Nordmanns-Raspberry-Pi5 Nordmanns-Raspberry-Pi5 (version: 7.0.6, hostname: Nordmanns-Raspberry-Pi5, alive, uptime: 1348)
    Core adapters versions
    js-controller: 	7.0.6
    admin: 		7.4.10
    javascript: 	8.8.3
    nodejs modules from github: 	3
    +-- iobroker.homepilot20@0.0.68 (git+ssh://git@github.com/homecineplexx/ioBroker.homepilot20.git#d6dbb5c1b9a8cf5396bc139cd2e0dd7ad68aec10)
    +-- iobroker.icons-open-icon-library-png@0.1.3 (git+ssh://git@github.com/ioBroker/ioBroker.icons-open-icon-library-png.git#0847a79d713ee6725ccb6ccfb044c025b73ec946)
    | `-- kodi-ws@2.4.4 (git+https://git@github.com/iobroker-community-adapters/kodi-ws.git#ad5a1fdc5cd0a282e6818ff152594b5d32535103)
    Adapter State
      system.adapter.acme.0                   : acme                  : Nordmanns-Raspberry-Pi5                  - disabled
      system.adapter.adb.0                    : adb                   : Nordmanns-Raspberry-Pi5                  - disabled
    + system.adapter.admin.0                  : admin                 : Nordmanns-Raspberry-Pi5                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alias-manager.0          : alias-manager         : Nordmanns-Raspberry-Pi5                  - disabled
    + system.adapter.backitup.0               : backitup              : Nordmanns-Raspberry-Pi5                  -  enabled
    + system.adapter.broadlink2.0             : broadlink2            : Nordmanns-Raspberry-Pi5                  -  enabled
      system.adapter.discovery.0              : discovery             : Nordmanns-Raspberry-Pi5                  - disabled
      system.adapter.dwd.0                    : dwd                   : Nordmanns-Raspberry-Pi5                  - disabled
    + system.adapter.dysonairpurifier.0       : dysonairpurifier      : Nordmanns-Raspberry-Pi5                  -  enabled
    + system.adapter.echarts.0                : echarts               : Nordmanns-Raspberry-Pi5                  -  enabled
    + system.adapter.ekey.0                   : ekey                  : Nordmanns-Raspberry-Pi5                  -  enabled, port: 56000, bind: 0.0.0.0
      system.adapter.enocean.0                : enocean               : Nordmanns-Raspberry-Pi5                  - disabled
    + system.adapter.ford.0                   : ford                  : Nordmanns-Raspberry-Pi5                  -  enabled
    + system.adapter.homepilot20.0            : homepilot20           : Nordmanns-Raspberry-Pi5                  -  enabled
    + system.adapter.hue.0                    : hue                   : Nordmanns-Raspberry-Pi5                  -  enabled, port: 443
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : Nordmanns-Raspberry-Pi5                  - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: Nordmanns-Raspberry-Pi5                  - disabled
    + system.adapter.javascript.0             : javascript            : Nordmanns-Raspberry-Pi5                  -  enabled
    + system.adapter.kodi.0                   : kodi                  : Nordmanns-Raspberry-Pi5                  -  enabled, port: 9090
    + system.adapter.logparser.0              : logparser             : Nordmanns-Raspberry-Pi5                  -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : Nordmanns-Raspberry-Pi5                  -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.netatmo.0                : netatmo               : Nordmanns-Raspberry-Pi5                  -  enabled
    + system.adapter.nuki-extended.0          : nuki-extended         : Nordmanns-Raspberry-Pi5                  -  enabled
    + system.adapter.pioneer_sc_vsx.0         : pioneer_sc_vsx        : Nordmanns-Raspberry-Pi5                  -  enabled, port: 23
    + system.adapter.scenes.0                 : scenes                : Nordmanns-Raspberry-Pi5                  -  enabled
    + system.adapter.shelly.0                 : shelly                : Nordmanns-Raspberry-Pi5                  -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.signal-cmb.0             : signal-cmb            : Nordmanns-Raspberry-Pi5                  -  enabled
    + system.adapter.simple-api.0             : simple-api            : Nordmanns-Raspberry-Pi5                  -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.sql.0                    : sql                   : Nordmanns-Raspberry-Pi5                  -  enabled, port: 3306
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : Nordmanns-Raspberry-Pi5                  - disabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : Nordmanns-Raspberry-Pi5                  - disabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: Nordmanns-Raspberry-Pi5                  - disabled
    + system.adapter.vis-2.0                  : vis-2                 : Nordmanns-Raspberry-Pi5                  -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : Nordmanns-Raspberry-Pi5                  - disabled
    + system.adapter.web.0                    : web                   : Nordmanns-Raspberry-Pi5                  -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.zwave2.0                 : zwave2                : Nordmanns-Raspberry-Pi5                  -  enabled
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name     │ url                                            │ auto upgrade │
    │ 0       │ 'stable' │ 'https://repo.iobroker.live/sources-dist.json' │ false        │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "acme"         : 1.0.6    , installed 1.0.6
    Adapter    "adb"          : 0.0.7    , installed 0.0.7
    Adapter    "admin"        : 7.4.10   , installed 7.4.10
    Adapter    "alias-manager": 2.0.0    , installed 2.0.0
    Adapter    "backitup"     : 3.0.31   , installed 3.0.31
    Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
    Adapter    "dysonairpurifier": 3.2.6 , installed 3.2.6
    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
    Adapter    "ekey"         : 1.2.3    , installed 1.2.3
    Adapter    "ford"         : 1.0.4    , installed 1.0.4
    Adapter    "hue"          : 3.13.1   , installed 3.14.1
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "kodi"         : 3.1.0    , installed 3.1.0
    Adapter    "logparser"    : 2.2.2    , installed 2.2.2
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
    Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
    Adapter    "scenes"       : 3.2.3    , installed 3.2.3
    Adapter    "shelly"       : 8.5.1    , installed 8.5.1
    Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
    Adapter    "sql"          : 3.0.1    , installed 3.0.1
    Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
    Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
    Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.1
    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "zwave2"       : 3.1.0    , installed 3.1.0
    Objects and States
    Objects: 	10916
    States: 	7767
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:5 http://archive.raspberrypi.com/debian bookworm InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7028       952/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          340595     4540/cupsd
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       642705     6856/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       642700     6856/iobroker.js-co
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       643920     7030/io.mqtt.0
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       644598     7137/io.shelly.0
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       643921     7030/io.mqtt.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          7030       952/sshd: /usr/sbin
    tcp6       0      0 ::1:3350                :::*                    LISTEN      0          7019       938/xrdp-sesman
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          340594     4540/cupsd
    tcp6       0      0 :::3389                 :::*                    LISTEN      112        10341      959/xrdp
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       644313     6874/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       645370     7280/io.web.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       645341     7250/io.simple-api.
    udp        0      0 0.0.0.0:43600           0.0.0.0:*                           1001       643888     6989/io.broadlink2.
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       643886     6989/io.broadlink2.
    udp        0      0 0.0.0.0:56000           0.0.0.0:*                           1001       644015     7174/io.ekey.0
    udp        0      0 0.0.0.0:40060           0.0.0.0:*                           104        6893       759/avahi-daemon: r
    udp        0      0 0.0.0.0:40763           0.0.0.0:*                           1001       643889     6989/io.broadlink2.
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6891       759/avahi-daemon: r
    udp6       0      0 :::59916                :::*                                104        6894       759/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        6892       759/avahi-daemon: r
    2025-02-28 10:17:17.997  - warn: admin.0 (6874) Cannot read file ("pioneer_sc_vsx.admin"/"pioneer_sc_vsx.png"): Not exists
    2025-02-28 10:17:24.940  - info: pioneer_sc_vsx.0 (7219) Connection closed (ERROR: connect EHOSTUNREACH 192.168.4.69:23). Reconnect in 5 Sec.
    2025-02-28 10:17:26.043  - warn: admin.0 (6874) Cannot read file ("pioneer_sc_vsx.admin"/"pioneer_sc_vsx.png"): Not exists
    2025-02-28 10:17:33.004  - info: pioneer_sc_vsx.0 (7219) Connection closed (ERROR: connect EHOSTUNREACH 192.168.4.69:23). Reconnect in 5 Sec.
    2025-02-28 10:17:34.089  - warn: admin.0 (6874) Cannot read file ("pioneer_sc_vsx.admin"/"pioneer_sc_vsx.png"): Not exists
    2025-02-28 10:17:41.068  - info: pioneer_sc_vsx.0 (7219) Connection closed (ERROR: connect EHOSTUNREACH 192.168.4.69:23). Reconnect in 5 Sec.
    2025-02-28 10:17:42.000  - warn: admin.0 (6874) Cannot read file ("pioneer_sc_vsx.admin"/"pioneer_sc_vsx.png"): Not exists
    2025-02-28 10:17:49.132  - info: pioneer_sc_vsx.0 (7219) Connection closed (ERROR: connect EHOSTUNREACH 192.168.4.69:23). Reconnect in 5 Sec.
    2025-02-28 10:17:50.205  - warn: admin.0 (6874) Cannot read file ("pioneer_sc_vsx.admin"/"pioneer_sc_vsx.png"): Not exists
    2025-02-28 10:17:57.196  - info: pioneer_sc_vsx.0 (7219) Connection closed (ERROR: connect EHOSTUNREACH 192.168.4.69:23). Reconnect in 5 Sec.
    2025-02-28 10:17:58.250  - warn: admin.0 (6874) Cannot read file ("pioneer_sc_vsx.admin"/"pioneer_sc_vsx.png"): Not exists
    2025-02-28 10:18:05.260  - info: pioneer_sc_vsx.0 (7219) Connection closed (ERROR: connect EHOSTUNREACH 192.168.4.69:23). Reconnect in 5 Sec.
    2025-02-28 10:18:06.345  - warn: admin.0 (6874) Cannot read file ("pioneer_sc_vsx.admin"/"pioneer_sc_vsx.png"): Not exists
    2025-02-28 10:18:13.324  - info: pioneer_sc_vsx.0 (7219) Connection closed (ERROR: connect EHOSTUNREACH 192.168.4.69:23). Reconnect in 5 Sec.
    2025-02-28 10:18:14.371  - warn: admin.0 (6874) Cannot read file ("pioneer_sc_vsx.admin"/"pioneer_sc_vsx.png"): Not exists
    2025-02-28 10:18:21.388  - info: pioneer_sc_vsx.0 (7219) Connection closed (ERROR: connect EHOSTUNREACH 192.168.4.69:23). Reconnect in 5 Sec.
    2025-02-28 10:18:22.498  - warn: admin.0 (6874) Cannot read file ("pioneer_sc_vsx.admin"/"pioneer_sc_vsx.png"): Not exists
    2025-02-28 10:18:29.452  - info: pioneer_sc_vsx.0 (7219) Connection closed (ERROR: connect EHOSTUNREACH 192.168.4.69:23). Reconnect in 5 Sec.
    2025-02-28 10:18:30.512  - warn: admin.0 (6874) Cannot read file ("pioneer_sc_vsx.admin"/"pioneer_sc_vsx.png"): Not exists
    2025-02-28 10:18:37.516  - info: pioneer_sc_vsx.0 (7219) Connection closed (ERROR: connect EHOSTUNREACH 192.168.4.69:23). Reconnect in 5 Sec.
    2025-02-28 10:18:37.808  - warn: admin.0 (6874) Cannot read file ("pioneer_sc_vsx.admin"/"pioneer_sc_vsx.png"): Not exists
    2025-02-28 10:18:45.580  - info: pioneer_sc_vsx.0 (7219) Connection closed (ERROR: connect EHOSTUNREACH 192.168.4.69:23). Reconnect in 5 Sec.
    2025-02-28 10:18:45.975  - warn: admin.0 (6874) Cannot read file ("pioneer_sc_vsx.admin"/"pioneer_sc_vsx.png"): Not exists
    2025-02-28 10:18:53.644  - info: pioneer_sc_vsx.0 (7219) Connection closed (ERROR: connect EHOSTUNREACH 192.168.4.69:23). Reconnect in 5 Sec.
    2025-02-28 10:18:54.257  - warn: admin.0 (6874) Cannot read file ("pioneer_sc_vsx.admin"/"pioneer_sc_vsx.png"): Not exists
    Wobei ich die Warning
    nicht verstehe, denn die Datei ist vorhanden und ich kann sie mir auch mit einem Bildbetrachter anschauen. An den Zugriffsrechten sollte es eigentlich auch nicht liegen, denn ich habe einen iob fix durchgeführt...
    Und hier noch die Summary:
    			v.2025-02-23
           Icon name: computer
        Architecture: arm64
    Installation: 		native
    Kernel: 		aarch64
    Userland: 		64 bit
    Timezone: 		Europe/Berlin (CET, +0100)
    User-ID: 		1000
    Boot Target: 		graphical.target
    Pending OS-Updates: 	0
    Pending iob updates: 	0
    Nodejs-Installation:
    /usr/bin/npm 		10.8.2
    /usr/bin/npx 		10.8.2
    Recommended versions are nodejs 20.18.3 and npm 10.8.2
    nodeJS installation is correct
    MEMORY:
    Swap:           209M          0B        209M
    ioBroker Core: 		js-controller 		7.0.6
    			admin 			7.4.10
    ioBroker Status: 	iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    Objects: 		10916
    States: 		7767
    Size of iob-Database:
    19M	/opt/iobroker/iobroker-data/objects.jsonl
    11M	/opt/iobroker/iobroker-data/states.jsonl
    mcm1957M Online
    mcm1957M Online
    mcm1957
    @klausstoertebeker said in "admin.0 Restart loop detected" und keine Trigger mehr:
    pioneer_sc_vsx
    Wo hast den den den "Adapter" her?
    Unter Adapter State steht:
    Unter Installed ioBroker-Adapters ist er nicht gelistet.
    Der Adapter ist jedenfalls nicht in einem Repository gelistet. Egal wie du den in den System gepresst hast solltest du diesen hinterfragen. Eine saubere Github Installation scheint das auch nicht zu sein - auch wenn von Github only Adaptern dringend abgeraten wird.
    Hinweis:
    Von direkten Installation von GitHub - insbesondere auf produktiven Systemen - wird explizit abgeraten.
    GitHub Versionen können sich jederzeit (auch kurzfristig) ändern und durchaus auch in sich inkonsistent und fehlerhaft sein. Versionsangaben von GitHub Installationen sind Schall und Rauch da die Versionsnummer zumindest bei Verwendung der standardmäßigen Umgebung erst im Zuge der Releaseerstellung geändert wird.
    Auf explizite Aufforderung durch den Entwickler kann eine GitHub Installation zur Fehlereingrenzung oder zum Test neuer Funktionalität - unter Inkaufnahme des erhöhten Risikos - natürlich erfolgen.
    Adapter die nur via GitHub oder npm (also NICHT aus einem der beiden Repositories) installierbar sind sind mit erhöhter Vorsicht zu betrachten. Hier sollte der Entwickler drum ersucht werden eine Aufnahme in die Repositories zu veranlassen indem z.B. ein Issue im Adapterrepository erstellt wird.
    Und falls es irgendwie unklar ist:
    ioBroker unterstützt folgende Arten von Installation:
    • aus dem STABLE Repository
      Das sind Adapter Releases die keine groben Fehler aufweisen (sollten). Natürlich kann es auch dort Fehler geben, die Behebung davon obliegt dem jeweiligen Dev und kann ggF auch dauern.
    • aus dem LATEST Repository
      Das sind Adapter Releases die neu erstellt wurden und nur rudimentär getestet sind - oft auch als BETA Releases bezeichnet. Releases aus dem LATEST sind primär für unsere zahlreichen freiwilligen Tester gedacht. BETA / LATEST Releases können durchaus Fehler aufweisen - auch wenn ich davon ausgehe dass jeder aintainer dies zu vermeiden versucht. Vom Einsatz auf produktiven Systemen wird abgeraten außer man braucht irgenein neues Feature (z.B. neues Gerät) unbedingt. Hier muss dann jeder Entscheiden was ihm wichtig ist.
    • direkt von GITHUB
      Von Installationen direkt aus Giuthub wird definitiv abgeraten außer auf Anweisung des Maintainers und für den Fall dass man gemeinsam mit diesem etwas testen will. Details siehe oben.
    • direkt von npm
      Diese Installation kann erforderlich sein, wenn man eine bestimmte Version installieren möchte / muss. Im Normalfall sollte man direkte npm Installationen ebenso meiden wie direkte GitHub Installationen - ausgenommen um z.B. zu einer bekannten Version downzugraden - obwohl hier wenigstens ein definierter Stand garantiert ist.
    Adapter die NUR via npm und/oder nur via GitHub installierbar sind sollte man meiden - diese wurden nicht mal einem rudimentären Review unterzogen und sollten mit dem Attribut "vollständig auf eigenes Risiko verwenden" installiert werden. Hier empfiehlt es sich den Developer zu ersuchen eine Aufnahme in die Repos zu veranlassen. Wenn dieser darauf nicht reagiert sollte man von einer eher kurzen und unklaren Lebensdauer des Adapters ausgehen. Support meiner-/unsererseits für solche Adapter ist mit sicherheit minimalistisch.
    @mcm1957
    Support Repositoryverwaltung.
    LESEN - gute Forenbeitrage
    KlausStoertebekerK 1 Antwort Letzte Antwort
      @klausstoertebeker sagte in "admin.0 Restart loop detected" und keine Trigger mehr:
      Schalt den aus.
      KlausStoertebekerK Offline
      KlausStoertebeker
      Hallo Thomas,
      war am Wochenende nicht daheim, deshalb erst jetzt meine Antwort:
      Mein ioBroker läuft auf einem Raspberry Pi 5 (8 GByte) mit graphischer Benutzeroberfäche. Und das deutliche schneller als meinem Raspberry Pi 4B (8 GByte)...
      Oder glaubst Du, dass der in die ioBroker-Installation reinfunkt?
      ioBroker-Host: Raspberry Pi 5 (8GByte RAM) mit Halo8-KI-Hat, Argon ONE M.2-Gehäuse mit 256GByte PCIe-SSD
      • mcm1957M mcm1957
        pioneer_sc_vsx
        Hinweis:
        • direkt von GITHUB
        • direkt von npm
        @mcm1957
        KlausStoertebeker
        @mcm1957
        Hallo mcm1957,
        danke für die Info.
        Aber der pioneer_sc_vsx ist der einzige Adapter (installiert mit npm), mit dem ich meinen betagten Pioneer VSX-921-Receiver steurrn kann. Und bisher hat der auch tadellos funktioniert.
        Der andere, über das stable-Repository verfügbare, Pioneer-Adapter ist für meinen Receiver nicht nutzbar.
          @mcm1957
          Hallo mcm1957,
          danke für die Info.
          KlausStoertebeker
          Kann mir denn niemand erklären, warum ich keine Trigger mehr bekomme, weder ereignis- noch zeitgesteuert? Welcher Teil/Adapter von ioBroker ist denn für die Auslöung und Verarbeitung eines Triggers verantwortlich?
          Ich habe jetzt alles aus dem stable-Repository installiert - bis auf drei Adapter (enocean, pioneer_sc_vsx und homepilot20) - und hatte gehofft, dass sich die Probleme damit gelöst haben.
          Aber sie sind immer noch da und ich scheine ein Problem mit der Basisinstallation zu haben...
          mcm1957M crunchipC 2 Antworten Letzte Antwort
            mcm1957M Online
            mcm1957M Online
            mcm1957
            @klausstoertebeker
            Also nach meinem Kenntnisstand sollte die events der js-controller an hand der Subscriptions raisen und der javescript Adapter sollte die empfangen bzw subscriben.
            Ob nun irgendein anderer Adapter da stören kann - keine Ahnung.
            • crunchipC Offline
              crunchipC Offline
              jetzt muss ich doch mal genauer nachfragen, bzw würde vllt ein Beispiel helfen
              z.b. ein Beispiel script mit den entsprechenden Datenpunkten/Zeitstempel, bzw das log aus dem script
                crunchipC Offline
                crunchipC Offline
                oben ist es aber
                  KlausStoertebeker
                  @crunchip said in "admin.0 Restart loop detected" und keine Trigger mehr:
                  Moin moin crunchip,
                  mache ich gerne. Aber ich habe mir gestern Abend den Kopf zermartert, wie ich das machen wie ich Dir diese Informationen so zur Verfügung stellen kann, dass Du alles auf einmal sehen kannst...
                  Wäre ein "Bildschirm-Video" sinnvoll, in dem ich drei Firefox-Fenster aufnehme, in denen jeweils die Informationen parallel dargestellt werden?
                    oben ist es aber
                    KlausStoertebeker
                    oben ist es aber
                    Mittlerweile habe ich den Adapter iobroker.icons-open-icon-library-png auf die Version 0.1.2 downgegraded - die ist im stable-Repository verfügbar.
                    Und ich habe den enocean-Adapter (mit npm installiert) deinstalliert, ebenso wie den zwave2-Adapter (den hatte ich über das stable-Repository installiert).
                    Die einzigen Adapter, die ich jetzt noch von außerhalb des stable-Repository installiert habe, sind der homepilot20 - da läuft aber gerade die Bitte, den in das stable-Repository zu integrieren - und der pioneer_sc_vsx. Für letzteren gibt es nur die Möglichkeit, über npm zu installieren.
                    Somit habe ich nur noch Adapter installiert, die ich wirklich benötige...
                      Moin moin crunchip,
                      crunchipC Offline
                      crunchipC Offline
                      @klausstoertebeker du kannst doch irgendein passendes Script aufrufen und das darunterliegende Log zeigen bei script start.(ggf debug log einbauen)
                      Oder auch mal einen Datenpunkt aus deinen Objekten, da müsste sich doch der Zeit Stempel ändern, wenn etwas geschaltet wird
                      KlausStoertebekerK 2 Antworten Letzte Antwort
                        KlausStoertebeker
                        @crunchip
                        Das bekomme ich hin. Dann werde ich das Script-Log hier in Code-Tags einfügen und den Zeitstempel der Datenpunktänderung in den Text einfügen :-)
                          KlausStoertebeker
                          @crunchip
                          Hallo crunchip,
                          ich habe mich doch für ein Video Video entschieden, weil ich dort durch entsprechende Anordnung der Fenster die Reaktionen von ioBroker gleichzeitig darstellen kann und ich das für besser halte als das komplizierte Beschreiben mit Worten,
                          In dem Video siehst Du, wie
                          • ich in der Visualisierung "VIS-2" einen Button anklicke, der mit dem boolschen Objekt Schalter_Arbeitszimmer_Server-2 verknüft ist (Fenster links oben)
                          • das Objekt Schalter_Arbeitszimmer_Server-2 den Wert wechselt (unterer Bereich, markierte Zeile; Wechsel von false -> true -> false)
                          • die Funktion "Unterprogramm Server-2 schalten" nicht ausgelöst wird (ich habe mehrere "debug"-Blöcke eingefügt, keiner schreibt jedoch ins Skript-Log)
                            Das Blockly-Skript hat folgenden Inhalt:
                            <variables>
                              <variable id="}.JK6ksO42P4EA)Pm/q:">Server-2_heruntergefahren</variable>
                            </variables>
                            <block type="on" id="dpfW@o|Xb4KE-N4[V6kj" x="63" y="-87">
                              <field name="OID">0_userdata.0.Schalter.Schalter_Arbeitszimmer_Server-2</field>
                              <statement name="STATEMENT">
                                <block type="debug" id="9MmQ)U(CW|$CoZ{4:j_L">
                                  <field name="Severity">info</field>
                                  <value name="TEXT">
                                    <shadow type="text" id="(0ibH02O]P8f;LJnWxv8">
                                    </shadow>
                                    <block type="text" id="~3{3/4%#`IS700N)${Y?">
                                      <field name="TEXT">"Unterprogramm Server-2 schalten" gestartet</field>
                                    </block>
                                  </value>
                                  <next>
                                    <block type="controls_if" id="ZhJrg)}pep`{Pfq:@MR)">
                                      <value name="IF0">
                                        <block type="logic_compare" id="D}jsUEOC#BX=VjIs$=@u">
                                          <field name="OP">EQ</field>
                                          <value name="A">
                                            <block type="get_value" id="=1(_*k?^+dvYJ$h-@W5_">
                                            </block>
                                          </value>
                                          <value name="B">
                                            <block type="logic_boolean" id="/.z^fx89LEs[CUCacev,">
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                      <statement name="DO0">
                                        <block type="control" id="Z}:7nmbOWJ^dl0_h.K!N">
                                          <field name="OID">alias.0.Arbeitszimmer Server-2 Verbrauch und Schalter.Schalter</field>
                                          <value name="VALUE">
                                            <block type="logic_boolean" id="T}_]4*Xa:sCj#0])Q{@_">
                                            </block>
                                          </value>
                                          <next>
                                            <block type="debug" id="buTzmBW)ufvlE+k17)62">
                                              <value name="TEXT">
                                                </shadow>
                                                <block type="text" id="+*O/[2o#pc](Cq|_*[be">
                                                  <field name="TEXT">Server-2 eingeschatet</field>
                                                </block>
                                              </value>
                                            </block>
                                          </next>
                                        </block>
                                      </statement>
                                      <value name="IF1">
                                        <block type="logic_compare" id="MusPF0c$(T)4h!V]4RoQ">
                                          <value name="A">
                                            <block type="get_value" id="#II_Alpp%c2MKX#:].$l">
                                            </block>
                                          </value>
                                          <value name="B">
                                            <block type="logic_boolean" id="9s@KTW1P}:t1}n8?Rzhs">
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                      <statement name="DO1">
                                        <block type="control" id="{s_XQ;qrGJ)tHqnB!l?K">
                                          <field name="OID">0_userdata.0.Hilfsobjekte.Server-Ausschaltbefehl</field>
                                            <block type="text_replace" id="0|#Go{/Im:rLY9M5K5eU">
                                              <value name="FROM">
                                                <shadow type="text" id="X#T|Tfy`+jTZh4ztgY`2">
                                                  <field name="TEXT">x</field>
                                                </shadow>
                                                <block type="text_newline" id="jFvT@+lbKG!6v|3|*dp7">
                                                  <field name="Type">\n</field>
                                                </block>
                                              </value>
                                              <value name="TO">
                                                <shadow type="text" id="A)}{b7Gm2)tE]2g4~=KX">
                                                  <field name="TEXT">y</field>
                                                </shadow>
                                                <block type="text" id="(XZX6%uN`Z[h2QW0e^%5">
                                                  <field name="TEXT"></field>
                                                </block>
                                              </value>
                                              <value name="TEXT">
                                                <shadow type="text" id="tKZBuIpOe{/kC7q%j#2y">
                                                </shadow>
                                                <block type="text_join" id="Z0L-cG-_C)?/QTu+o%*a">
                                                  <value name="ADD0">
                                                    <block type="text" id="g8xwdz:?VoM!t1VQJ$*8">
                                                      <field name="TEXT">ssh admin@</field>
                                                    </block>
                                                  </value>
                                                  <value name="ADD1">
                                                    <block type="get_value" id=";SU=2SU{O/PjSk[wj~l/">
                                                      <field name="OID">0_userdata.0.Netzwerkadressen.IP-Adresse_Server-2</field>
                                                    </block>
                                                  </value>
                                                  <value name="ADD2">
                                                    <block type="text" id="m!H8v?xWJ/dFVX|-EA[D">
                                                      <field name="TEXT"> poweroff</field>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                          <next>
                                            <block type="exec" id="dINM^XRtRKI2zo0kDsWK">
                                              <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="false"></mutation>
                                              <field name="WITH_STATEMENT">FALSE</field>
                                              <field name="LOG">debug</field>
                                              <value name="COMMAND">
                                                <shadow type="text" id="+x)UNfi@Pd09uZn+)nj0">
                                                  <field name="TEXT">pwd</field>
                                                </shadow>
                                                <block type="text_replace" id="A-tOS.,Ab5-0p]4P=~y9">
                                                  <value name="FROM">
                                                    </shadow>
                                                    <block type="text_newline" id="W:HGu5V97#-a3jjZU.e^">
                                                    </block>
                                                  </value>
                                                  <value name="TO">
                                                    </shadow>
                                                    <block type="text" id="@*Ka=3uUO=13YbFc/{GG">
                                                    </block>
                                                  </value>
                                                  <value name="TEXT">
                                                    </shadow>
                                                    <block type="text_join" id="boC#i7RN}`2VmfBbk6zH">
                                                      <value name="ADD0">
                                                        <block type="text" id="RmGi6+2VY8]{d[q1mAR1">
                                                        </block>
                                                      </value>
                                                      <value name="ADD1">
                                                        <block type="get_value" id="a?wbLJ5YSs6!.a$*LMxn">
                                                        </block>
                                                      </value>
                                                      <value name="ADD2">
                                                        <block type="text" id="Jh*.IX(cz:U|oD~{u[7^">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <next>
                                                <block type="debug" id="FmqPTzo7kT3t`]ZC-uM-">
                                                  <value name="TEXT">
                                                    </shadow>
                                                    <block type="text" id="wi|%p$JN)Ou9]*1Vzjrz">
                                                      <field name="TEXT">Server-2 wird heruntergefahren</field>
                                                    </block>
                                                  </value>
                                                  <next>
                                                    <block type="debug" id="!-#Y#V,z_/BkVke1Yfbh">
                                                      <value name="TEXT">
                                                        </shadow>
                                                        <block type="get_value" id="YW0V%+Psc`G?+Sq6L+OV">
                                                        </block>
                                                      </value>
                                                      <next>
                                                        <block type="variables_set" id="_SZ^${a4.da.HVtVflw?">
                                                          <field name="VAR" id="}.JK6ksO42P4EA)Pm/q:">Server-2_heruntergefahren</field>
                                                            <block type="logic_boolean" id="]4cEN?|P.r=JC]R/0gDK">
                                                            </block>
                                                          </value>
                                                          <next>
                                                            <block type="controls_whileUntil" id="Jg$ka*@unOMXF)%64UHa">
                                                              <field name="MODE">WHILE</field>
                                                              <value name="BOOL">
        <block type="logic_compare" id="NV(rf0!]lu5I{X@1BMHM">
        <value name="A">
        <block type="variables_get" id="NGdQ)Elb3*]VK_oaDWP+">
        </block>
        </value>
        <value name="B">
        <block type="logic_boolean" id="q,s[qKLIpOnk9[%tP|,V">
        </block>
        </value>
        </block>
                                                              </value>
                                                              <statement name="DO">
        <block type="exec" id="M@mW6FL%_,0v]D|3(x4?">
        <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="true"></mutation>
        <field name="WITH_STATEMENT">TRUE</field>
        <field name="LOG"></field>
        <shadow type="text" id="2ISya|QWuK=oZ_Q{6whi">
        </shadow>
        <block type="text_join" id=".F*K;}^Ro%VIk;36qkkN">
        <value name="ADD0">
        <block type="text" id="xpen|W3sk1@1mMI^X$dx">
        <field name="TEXT">ping -c 1 </field>
        </block>
        </value>
        <value name="ADD1">
        <block type="get_value" id="+LBmpXG*J,6^@M@Gwrr8">
        </block>
        </value>
        </block>
        </value>
        <block type="controls_if" id="jDa`a4aMS,t+/r[Do_j/">
        <value name="IF0">
        <block type="logic_compare" id=":vrMh+x=v2bHQY;)}LC8">
        <field name="OP">NEQ</field>
        <value name="A">
        <block type="text_indexOf" id="RJ/#yna;Hqk(.JEQv+rQ">
        <field name="END">FIRST</field>
        <block type="exec_result" id="G/5sXUTA6F*eMir{LT(W">
        <field name="ATTR">result</field>
        </block>
        </value>
        <value name="FIND">
        <shadow type="text" id="XsuuVumbmWIWoZ69JRxC">
        <field name="TEXT">abc</field>
        </shadow>
        <block type="text" id=",v,6RfJ4n1ZN@SdO?,@/">
        <field name="TEXT">Destination Host Unreachable</field>
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="CD*8GZP9X4Ans5BZAy7t">
        <field name="NUM">0</field>
        </block>
        </value>
        </block>
        </value>
        <block type="variables_set" id="|vwYEzXZi}d;JR/hNu6j">
        <block type="logic_boolean" id="My%k3.H/,N]8O*b[;1z!">
        </block>
        </value>
        </block>
        </statement>
        </block>
        </statement>
        <next>
        <block type="timeouts_wait" id="KxzjUAu%2G~]*e7mro5Y">
        <field name="DELAY">60000</field>
        <field name="UNIT">ms</field>
        </block>
        </next>
        </block>
                                                              </statement>
                                                              <next>
        <block type="control" id="6ke8|yGP0)D=`8]C1-m%">
        <block type="logic_boolean" id="FL9Lkobw[krO}u*2Ef9L">
        </block>
        </value>
        </block>
                                                              </next>
                                                            </block>
                                                          </next>
                                                        </block>
                                                      </next>
                                                    </block>
                                                  </next>
                                                </block>
                                              </next>
                                            </block>
                                          </next>
                                        </block>
                                      </statement>
                                    </block>
                                  </next>
                                </block>
                              </statement>
                            </block>
                          </xml>
                          Hier das Admin-Log zum Download: Admin-Adapter-Log.json
                          Hier das Javascript-Log zum Download: Javascript-Adapter-Log.json
                          Ich hoffe, die Informationen reichen für den Anfang :-)
                          CodierknechtC crunchipC 2 Antworten Letzte Antwort
                            @crunchip
                            Hallo crunchip,
                              <variables>
                              </variables>
                                    <value name="TEXT">
                                      </shadow>
                                      </block>
                                    </value>
                                    <next>
                                        <value name="IF0">
                                            <value name="A">
                                              </block>
                                            </value>
                                            <value name="B">
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                              </block>
                                            </value>
                                            <next>
                                                <value name="TEXT">
                                                  </shadow>
                                                  </block>
                                                </value>
                                              </block>
                                            </next>
                                          </block>
                                        </statement>
                                        <value name="IF1">
                                            <value name="A">
                                              </block>
                                            </value>
                                            <value name="B">
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                                <value name="FROM">
                                                  </shadow>
                                                  </block>
                                                </value>
                                                <value name="TO">
                                                  </shadow>
                                                  </block>
                                                </value>
                                                <value name="TEXT">
                                                  </shadow>
                                                    <value name="ADD0">
                                                      </block>
                                                    </value>
                                                    <value name="ADD1">
                                                      </block>
                                                    </value>
                                                    <value name="ADD2">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                            <next>
                                                  </shadow>
                                                    <value name="FROM">
                                                      </shadow>
                                                      </block>
                                                    </value>
                                                    <value name="TO">
                                                      </shadow>
                                                      </block>
                                                    </value>
                                                    <value name="TEXT">
                                                      </shadow>
                                                        <value name="ADD0">
                                                          </block>
                                                        </value>
                                                        <value name="ADD1">
                                                          </block>
                                                        </value>
                                                        <value name="ADD2">
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                <next>
                                                    <value name="TEXT">
                                                      </shadow>
                                                      </block>
                                                    </value>
                                                    <next>
                                                        <value name="TEXT">
                                                          </shadow>
                                                          </block>
                                                        </value>
                                                        <next>
                                                              </block>
                                                            </value>
                                                            <next>
        <value name="BOOL">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </shadow>
        <value name="ADD0">
        </block>
        </value>
        <value name="ADD1">
        </block>
        </value>
        </block>
        </value>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="FIND">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        </block>
        </statement>
        <next>
        </block>
        </next>
        </block>
        </statement>
        <next>
        </block>
        </value>
        </block>
        </next>
                                                              </block>
                                                            </next>
                                                          </block>
                                                        </next>
                                                      </block>
                                                    </next>
                                                  </block>
                                                </next>
                                              </block>
                                            </next>
                                          </block>
                                        </statement>
                                      </block>
                                    </next>
                                  </block>
                                </statement>
                              </block>
                            </xml>
                            CodierknechtC Offline
                            Codierknecht
                            Blockly bitte immer auch als Screenshot.
                            Nur wenige werden Lust haben, das erstmal zu importieren um einen Blick darauf werfen zu können.
                            HmIP|ZigBee|Tasmota|Unifi
                            Zabbix Certified Specialist
                              @crunchip
                              Hallo crunchip,
                                <variables>
                                </variables>
                                      <value name="TEXT">
                                        </shadow>
                                        </block>
                                      </value>
                                      <next>
                                          <value name="IF0">
                                              <value name="A">
                                                </block>
                                              </value>
                                              <value name="B">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                                </block>
                                              </value>
                                              <next>
                                                  <value name="TEXT">
                                                    </shadow>
                                                    </block>
                                                  </value>
                                                </block>
                                              </next>
                                            </block>
                                          </statement>
                                          <value name="IF1">
                                              <value name="A">
                                                </block>
                                              </value>
                                              <value name="B">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                                  <value name="FROM">
                                                    </shadow>
                                                    </block>
                                                  </value>
                                                  <value name="TO">
                                                    </shadow>
                                                    </block>
                                                  </value>
                                                  <value name="TEXT">
                                                    </shadow>
                                                      <value name="ADD0">
                                                        </block>
                                                      </value>
                                                      <value name="ADD1">
                                                        </block>
                                                      </value>
                                                      <value name="ADD2">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <next>
                                                    </shadow>
                                                      <value name="FROM">
                                                        </shadow>
                                                        </block>
                                                      </value>
                                                      <value name="TO">
                                                        </shadow>
                                                        </block>
                                                      </value>
                                                      <value name="TEXT">
                                                        </shadow>
                                                          <value name="ADD0">
                                                            </block>
                                                          </value>
                                                          <value name="ADD1">
                                                            </block>
                                                          </value>
                                                          <value name="ADD2">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <next>
                                                      <value name="TEXT">
                                                        </shadow>
                                                        </block>
                                                      </value>
                                                      <next>
                                                          <value name="TEXT">
                                                            </shadow>
                                                            </block>
                                                          </value>
                                                          <next>
        </block>
                                                              </value>
                                                              <next>
        <value name="BOOL">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </shadow>
        <value name="ADD0">
        </block>
        </value>
        <value name="ADD1">
        </block>
        </value>
        </block>
        </value>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="FIND">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        </block>
        </statement>
        <next>
        </block>
        </next>
        </block>
        </statement>
        <next>
        </block>
        </value>
        </block>
        </next>
        </block>
                                                              </next>
                                                            </block>
                                                          </next>
                                                        </block>
                                                      </next>
                                                    </block>
                                                  </next>
                                                </block>
                                              </next>
                                            </block>
                                          </statement>
                                        </block>
                                      </next>
                                    </block>
                                  </statement>
                                </block>
                              </xml>
                              crunchipC Offline
                              crunchipC Offline
                                KlausStoertebeker
                                @crunchip
                                Ok, hier das Blockly-Skript als Bild:
                                Und hier das detaillierte Skript-Log nach betätigen des Buttons:
                                javascript.0	21:29:33.426	info	Stopping script script.js.IT-Gerätesteuerung.Unterprogramm_Arbeitszimmer_Server-2_schalten
                                javascript.0	21:29:33.475	info	Start JavaScript script.js.IT-Gerätesteuerung.Unterprogramm_Arbeitszimmer_Server-2_schalten (Blockly)
                                javascript.0	21:29:33.486	info	script.js.IT-Gerätesteuerung.Unterprogramm_Arbeitszimmer_Server-2_schalten: subscribe: {"pattern":{"id":"0_userdata.0.Schalter.Schalter_Arbeitszimmer_Server-2","change":"ne","q":0},"name":"script.js.IT-Gerätesteuerung.Unterprogramm_Arbeitszimmer_Server-2_schalten"}
                                javascript.0	21:29:33.486	info	script.js.IT-Gerätesteuerung.Unterprogramm_Arbeitszimmer_Server-2_schalten: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                Das Skript wurde wieder nicht getriggert.
                                HomoranH crunchipC CodierknechtC 3 Antworten Letzte Antwort
                                  @crunchip
                                  @klausstoertebeker Was ist das für ein "Schalter"?
                                    @crunchip
                                    crunchipC Offline
                                    crunchipC Offline
                                    da sollte eigentlich mehr kommen
                                    vllt, findet man etwas im debug modus?
                                      @crunchip sagte in "admin.0 Restart loop detected" und keine Trigger mehr:
                                      wenn wirklich nicht getriggert wird kommt gar nichts
                                        @crunchip
                                        Codierknecht
                                        @klausstoertebeker
                                        Was mir als erstes auffällt: Du fragst im Trigger nochmals den Wert ab. Und das auch noch 2x.
                                        Das ist völlig unnötig. Dafür nimmt man den Block "Wert" aus dem Bereich "Trigger". Der Trigger kennt schließlich seinen eigenen Wert.
                                        Und noch was: Wenn man einen bool'schen Wert abfragt, kann das "sonst falls" entfallen. Der Wert ist entweder true und es wird Teil 1 ausgeführt. Danach reicht ein "sonst", denn dann kann der Wert ja nur noch false sein.
                                        Prinzip:
                                        https://forum.iobroker.net/topic/70481/blockly-for-dummies-starthilfe-und-tipps
                                          crunchipC Offline
                                          crunchipC Offline
                                          @homoran aber warum sollte, wie zu Beginn genannt, kein einziger Trigger, funktionieren🤔
                                          Eventuell mal ein downgrade der Javascript Instanz hilfreich?
                                          Wenn es ein zeitliches Problem (falsche System Zeit) wäre, ist noch zu erklären, aber gar kein Trigger funktioniert, hab ich so bisher auch noch nicht gesehen
