  4. fritzdect Adapter Fehler alle 10 Sekunden im Log
28 Beiträge 12 Kommentatoren 4.4k Aufrufe 10 Beobachtet
  • P pjo123456
    @ro75
    ```bash
    Script v.2024-10-19
    *** BASE SYSTEM ***
     Static hostname: ioBrokerMasterLXC
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
    Operating System: Ubuntu 23.04
              Kernel: Linux 6.8.12-5-pve
        Architecture: x86-64
    Firmware Version: F5
    OS is similar to: debian
    model name      : Intel(R) Core(TM) i5-4200U CPU @ 1.60GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     12:27:59 up 8 days, 14:36,  2 users,  load average: 1.17, 0.48, 0.21
    CPU threads: 1
    *** LIFE CYCLE STATUS ***
    Ubuntu Release codenamed 'lunar' reached its END OF LIFE and needs to be updated to the latest LTS release 'noble' NOW!
    *** TIME AND TIMEZONES ***
                   Local time: Sun 2024-12-29 12:27:59 CET
               Universal time: Sun 2024-12-29 11:27:59 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    root
    HOME=/root
    GROUPS=root
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev bluetooth
    A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'!
    A root login is not required in most Linux Distributions.
    Run 'iobroker fix' or use the system tools to create a user.
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
    *** MEMORY ***
    Mem:            3.2G        1.4G        274M         94K        1.6G        1.8G
    Swap:           536M        244M        292M
    Total:          3.8G        1.6G        567M
    Active iob-Instances:   23
             3072 M total memory
             1326 M used memory
             1241 M active memory
             1423 M inactive memory
              261 M free memory
                0 M buffer memory
             1484 M swap cache
              512 M total swap
              232 M used swap
              279 M free swap
    top - 12:27:59 up 8 days, 14:36,  2 users,  load average: 1.17, 0.48, 0.21
    Tasks:  50 total,   1 running,  49 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3072.0 total,    259.3 free,   1327.8 used,   1485.2 buff/cache
    MiB Swap:    512.0 total,    279.0 free,    233.0 used.   1744.2 avail Mem
    *** FAILED SERVICES ***
      UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    dmesg: read kernel buffer failed: Operation not permitted
    No critical errors detected
    *** FILESYSTEM ***
    /dev/loop0     ext4       19G   13G  5.2G  71% /
    none           tmpfs     492K  4.0K  488K   1% /dev
    efivarfs       efivarfs  128K   96K   28K  78% /sys/firmware/efi/efivars
    tmpfs          tmpfs     7.8G     0  7.8G   0% /dev/shm
    tmpfs          tmpfs     3.2G  140K  3.2G   1% /run
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     1.6G     0  1.6G   0% /run/user/0
    Show mounted filesystems:
    TARGET SOURCE     FSTYPE OPTIONS
    /      /dev/loop0 ext4   rw,relatime
    /var:
    521M    /var/
    233M    /var/lib
    164M    /var/log
    163M    /var/log/journal/770cb772b2aa4c2a87f7acb50f04c359
    Archived and active journals take up 162.4M in the file system.
    /opt/iobroker/backups:
    315M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    7.7G    /opt/iobroker/iobroker-data/
    6.9G    /opt/iobroker/iobroker-data/history
    794M    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    14M     /opt/iobroker/iobroker-data/objects.jsonl
    12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
    9.6M    /opt/iobroker/iobroker-data/history/20240312/history.ble.1.c4~7c~8d~6b~f9~60.rssi.json
    9.5M    /opt/iobroker/iobroker-data/history/20240311/history.ble.1.c4~7c~8d~6b~f9~60.rssi.json
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.20.5
    /usr/bin/node           v18.20.5
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    nodejs:
      Installed: 18.20.5-1nodesource1
      Candidate: 18.20.5-1nodesource1
      Version table:
     *** 18.20.5-1nodesource1 600
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.20.4-1nodesource1 600
         18.20.3-1nodesource1 600
         18.20.2-1nodesource1 600
         18.20.1-1nodesource1 600
         18.20.0-1nodesource1 600
         18.19.1-1nodesource1 600
         18.19.0-1nodesource1 600
         18.18.2-1nodesource1 600
         18.18.1-1nodesource1 600
         18.18.0-1nodesource1 600
         18.17.1-1nodesource1 600
         18.17.0-1nodesource1 600
         18.16.1-1nodesource1 600
         18.16.0-1nodesource1 600
         18.15.0-1nodesource1 600
         18.14.2-1nodesource1 600
         18.14.1-1nodesource1 600
         18.14.0-1nodesource1 600
         18.13.0+dfsg1-1ubuntu2 500
            500 http://archive.ubuntu.com/ubuntu lunar/universe amd64 Packages
         18.13.0-1nodesource1 600
         18.12.0-1nodesource1 600
         18.11.0-1nodesource1 600
         18.10.0-1nodesource1 600
         18.9.1-1nodesource1 600
         18.9.0-1nodesource1 600
         18.8.0-1nodesource1 600
         18.7.0-1nodesource1 600
         18.6.0-1nodesource1 600
         18.5.0-1nodesource1 600
         18.4.0-1nodesource1 600
         18.3.0-1nodesource1 600
         18.2.0-1nodesource1 600
         18.1.0-1nodesource1 600
         18.0.0-1nodesource1 600
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    ioBroker-Slave2     ioBroker-Slave2 (version: 7.0.3, hostname: ioBroker-Slave2, alive, uptime: 741772)
    ioBrokerMasterLXC   ioBrokerMasterLXC (version: 7.0.3, hostname: ioBrokerMasterLXC, alive, uptime: 739393)
    Core adapters versions
    js-controller:  7.0.3
    admin:          7.1.5
    javascript:     8.8.3
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : ioBrokerMasterLXC                        -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : ioBroker-Slave2                          -  enabled
    + system.adapter.backitup.1               : backitup              : ioBrokerMasterLXC                        -  enabled
      system.adapter.ble.0                    : ble                   : ioBrokerMasterLXC                        - disabled
    + system.adapter.ble.1                    : ble                   : ioBroker-Slave2                          -  enabled
    + system.adapter.chromecast.0             : chromecast            : ioBrokerMasterLXC                        -  enabled
    + system.adapter.cloud.0                  : cloud                 : ioBrokerMasterLXC                        -  enabled
    + system.adapter.discovery.0              : discovery             : ioBrokerMasterLXC                        -  enabled
    + system.adapter.email.0                  : email                 : ioBrokerMasterLXC                        -  enabled
      system.adapter.flot.0                   : flot                  : ioBrokerMasterLXC                        - disabled
    + system.adapter.fritzbox.0               : fritzbox              : ioBrokerMasterLXC                        -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : ioBrokerMasterLXC                        -  enabled
    + system.adapter.history.0                : history               : ioBrokerMasterLXC                        -  enabled
      system.adapter.ical.0                   : ical                  : ioBrokerMasterLXC                        -  enabled
    + system.adapter.info.0                   : info                  : ioBrokerMasterLXC                        -  enabled
    + system.adapter.javascript.0             : javascript            : ioBrokerMasterLXC                        -  enabled
    + system.adapter.linux-control.0          : linux-control         : ioBrokerMasterLXC                        -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : ioBrokerMasterLXC                        -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.net-tools.0              : net-tools             : ioBrokerMasterLXC                        - disabled
      system.adapter.pi-hole.0                : pi-hole               : ioBrokerMasterLXC                        - disabled
    + system.adapter.ping.0                   : ping                  : ioBrokerMasterLXC                        -  enabled
    + system.adapter.proxmox.0                : proxmox               : ioBrokerMasterLXC                        -  enabled, port: 8006
    + system.adapter.rpi2.1                   : rpi2                  : ioBroker-Slave2                          -  enabled
    + system.adapter.sayit.0                  : sayit                 : ioBrokerMasterLXC                        -  enabled
    + system.adapter.sonoff.0                 : sonoff                : ioBrokerMasterLXC                        -  enabled, port: 1885, bind: 0.0.0.0
    + system.adapter.telegram.0               : telegram              : ioBrokerMasterLXC                        -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : ioBrokerMasterLXC                        - disabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : ioBrokerMasterLXC                        - disabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBrokerMasterLXC                        - disabled
      system.adapter.vis.0                    : vis                   : ioBrokerMasterLXC                        -  enabled
    + system.adapter.web.0                    : web                   : ioBrokerMasterLXC                        -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    │ (index) │   name   │                           url                           │ auto upgrade │
    │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
    │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.1.5    , installed 7.1.5
    Adapter    "backitup"     : 3.0.25   , installed 3.0.25
    Adapter    "ble"          : 0.14.0   , installed 0.14.0
    Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
    Adapter    "email"        : 1.3.1    , installed 1.3.1
    Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
    Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
    Adapter    "ical"         : 1.16.1   , installed 1.16.1
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.6    , installed 7.0.3  [Updatable]
    Adapter    "linux-control": 1.1.5    , installed 1.1.5
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
    Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
    Adapter    "sayit"        : 5.0.0    , installed 5.0.0
    Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
    Adapter    "telegram"     : 3.9.0    , installed 3.9.0
    Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
    Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Objects and States
    Objects:        3051
    States:         2539
    E: The repository 'http://archive.ubuntu.com/ubuntu lunar Release' no longer has a Release file.
    E: The repository 'http://archive.ubuntu.com/ubuntu lunar-updates Release' no longer has a Release file.
    E: The repository 'http://archive.ubuntu.com/ubuntu lunar-security Release' no longer has a Release file.
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      996        12306      101/systemd-resolve
    tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1000       240687     4857/io.sonoff.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       239390     4815/io.mqtt.0
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      996        12304      101/systemd-resolve
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       237188     4623/iobroker.js-co
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       237195     4623/iobroker.js-co
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          10612      1/init
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          12891      287/master
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          12892      287/master
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12314      1/init
    tcp6       0      0 :::111                  :::*                    LISTEN      0          10614      1/init
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       237339     4641/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       242532     5351/io.web.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       240819     4887/io.chromecast.
    udp        0      0 127.0.0.54:53           0.0.0.0:*                           996        12305      101/systemd-resolve
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           996        12303      101/systemd-resolve
    udp        0      0 192.168.1.67:68         0.0.0.0:*                           998        15897654   93/systemd-networkd
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          10613      1/init
    udp6       0      0 :::111                  :::*                                0          10615      1/init
    2024-12-29 12:25:22.449  - error: fritzdect.0 (358172) try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
    2024-12-29 12:25:32.450  - error: fritzdect.0 (358172) try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
    2024-12-29 12:25:42.456  - error: fritzdect.0 (358172) try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
    2024-12-29 12:25:52.450  - error: fritzdect.0 (358172) try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
    2024-12-29 12:25:55.734  - info: linux-control.0 (5366) getting data from ioBrokerSlave_2 (192.168.1.57:22)
    2024-12-29 12:25:55.738  - info: linux-control.0 (5366) [getConnection] Host 'ioBrokerSlave_2' (192.168.1.57:22) seems not to be online
    2024-12-29 12:26:02.457  - error: fritzdect.0 (358172) try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
    2024-12-29 12:26:12.475  - error: fritzdect.0 (358172) try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
    2024-12-29 12:26:22.457  - error: fritzdect.0 (358172) try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
    2024-12-29 12:26:32.489  - error: fritzdect.0 (358172) try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
    2024-12-29 12:26:42.484  - error: fritzdect.0 (358172) try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
    2024-12-29 12:26:52.464  - error: fritzdect.0 (358172) try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
    2024-12-29 12:26:55.743  - info: linux-control.0 (5366) getting data from ioBrokerSlave_2 (192.168.1.57:22)
    2024-12-29 12:26:55.746  - info: linux-control.0 (5366) [getConnection] Host 'ioBrokerSlave_2' (192.168.1.57:22) seems not to be online
    2024-12-29 12:27:02.458  - error: fritzdect.0 (358172) try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
    2024-12-29 12:27:12.460  - error: fritzdect.0 (358172) try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
    2024-12-29 12:27:22.487  - error: fritzdect.0 (358172) try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
    2024-12-29 12:27:32.465  - error: fritzdect.0 (358172) try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
    2024-12-29 12:27:42.467  - error: fritzdect.0 (358172) try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
    2024-12-29 12:27:52.505  - error: fritzdect.0 (358172) try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
    2024-12-29 12:27:55.753  - info: linux-control.0 (5366) getting data from ioBrokerSlave_2 (192.168.1.57:22)
    2024-12-29 12:27:55.756  - info: linux-control.0 (5366) [getConnection] Host 'ioBrokerSlave_2' (192.168.1.57:22) seems not to be online
    2024-12-29 12:28:02.475  - error: fritzdect.0 (358172) try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
    2024-12-29 12:28:12.464  - error: fritzdect.0 (358172) try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
    2024-12-29 12:28:22.468  - error: fritzdect.0 (358172) try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
    Adapter Konfiguration? Was benötigst du da? Screenshot?
    Ro75R Offline
    Ro75R Offline
    Ro75
    @pjo123456 sagte in fritzdect Adapter Fehler alle 10 Sekunden im Log:
    ja
    1. Ubuntu-Version ist nur eine "Zwischenversion" - bereits abgelaufen. Da muss was aktuelles her, ggfs. eine LTS Version
    2. nodejs - empfohlen V20.x
    3. Kernel Fehler.
    Ro75.
    • P Offline
      pjo123456
      @ro75 Hier die Konfig vom Adapter (ich hoffe es ist das richtige):
      zu 1.: Da muss ich mich erst belesen, wie ich das updaten muss
      zu 2.: werde ich machen
      zu 3.: kein Plan
      Moin aus dem Norden…
      Ro75R 1 Antwort Letzte Antwort
      • P pjo123456
        zu 3.: kein Plan
        Ro75R Offline
        Ro75R Offline
        Ro75
        @pjo123456 setze bei "excludes" dort bei allen 3 den Haken.
        Ro75.
        P 1 Antwort Letzte Antwort
        • Ro75R Ro75
          Ro75.
          pjo123456
          @ro75 Gemacht. Adapter neu gestartet aber der Fehler kommt immer noch alle 10 Sekunden.
          • P pjo123456
            Ro75R Offline
            Ro75R Offline
            Ro75
            @pjo123456 du hast Master / Slave - Betrieb?
            Ro75.
            • Ro75R Ro75
              Ro75.
              pjo123456
              @ro75 Ja. Master im LXC Container, Slave auf Raspi. Der Slave hat aber nur ein paar Bluetooth Thermometer.
              • P pjo123456
                haselchenH Offline
                haselchenH Offline
                haselchen
                @pjo123456
                Bist Du das mit dem Issue?
                https://github.com/foxthefox/ioBroker.fritzdect/issues/599
                Edit: Wenn nein, dann häng Dich mit ran.
                Dann brauchen wir hier nicht weiter suchen und Du kannst Dein System solange auf Stand bringen .
                • haselchenH haselchen
                  @pjo123456
                  pjo123456
                  @haselchen Moin!
                  Habe zwar auch ein Issue aufgemacht aber wegen einem anderen Problem. Aber vielleicht hängt das alles damit zusammen.
                  Issue 598: (https://github.com/foxthefox/ioBroker.fritzdect/issues/598)
                  • BertDerKleineB Offline
                    BertDerKleine
                    Ich hänge mich mal hier dran. Folgende Erlebnisse:
                    Nach dem Update meiner Fritzbox 7590ax auf FritzOS v8.02 gabs Probleme, die durch die Version 2.5.12 aus dem Beta repository behoben zu sein schienen.
                    Was ich aber erst sehr viel später festgestellt habe ist die Tatsache, dass der iobroker fritzdect Adapter v2.5.12 anscheinen per API calls die Box irgendwie zumüllt und das zur Folge hat, dass das UI der Fritzbox quasi unbrauchbar langsam wird. Selbst zum Login auf dem UI kann man 2 Minuten warten, bis sich der Screen aufgebaut hat.
                    Im Log finde ich derweil sowas hier unter v2.5.12, haufenweise:
                    2025-02-27 00:03:47.033  - error: fritzdect.0 (800200) --------------- error calling the fritzbox -----------
                    2025-02-27 00:03:47.034  - error: fritzdect.0 (800200) API msg   => error calling executeCommand
                    2025-02-27 00:03:47.034  - error: fritzdect.0 (800200) API funct => login_SID
                    2025-02-27 00:03:47.034  - error: fritzdect.0 (800200) no response part in returned error message
                    2025-02-27 00:03:47.034  - error: fritzdect.0 (800200) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"error http.request","function":"get_login_state","error":{"errno":-110,"code":"ETIMEDOUT","syscall":"connect","address":"192.168.178.1","port":80}}}
                    2025-02-27 00:04:07.513  - error: fritzdect.0 (800200) --------------- error calling the fritzbox -----------
                    2025-02-27 00:04:07.513  - error: fritzdect.0 (800200) API msg   => error calling executeCommand
                    2025-02-27 00:04:07.513  - error: fritzdect.0 (800200) API funct => login_SID
                    2025-02-27 00:04:07.513  - error: fritzdect.0 (800200) no response part in returned error message
                    2025-02-27 00:04:07.514  - error: fritzdect.0 (800200) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"error http.request","function":"get_login_state","error":{"errno":-110,"code":"ETIMEDOUT","syscall":"connect","address":"192.168.178.1","port":80}}}
                    2025-02-27 00:04:07.514  - warn: fritzdect.0 (800200) [Polling] <== TypeError: Cannot read properties of undefined (reading 'replace')
                    Erst durch den AVM Support ist mir der Tip mit dem Einfluss des Raspi mit dem iobroker bewusst geworden und die Fehler.
                    Ich habe dann denn Adapter wieder auf 2.5.11 gedowngraded und schwups läuft das UI der Fritzbox wieder normal.
                    Leider ist damit dann wieder der Adapter disfunktional. Die DP werden nicht aktualisiert und das Log wird nach 2-3 Minuten mit "try/catch issue updating device in updateDevices TypeError" Fehler zugespammt (unter v.2.5.12).
                    fritzdect.0
                    	2025-02-27 17:58:58.772	error	try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
                    fritzdect.0
                    	2025-02-27 17:58:53.820	error	try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
                    fritzdect.0
                    	2025-02-27 17:58:48.802	error	try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
                    fritzdect.0
                    	2025-02-27 17:58:43.881	error	try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
                    fritzdect.0
                    	2025-02-27 17:58:39.839	error	try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
                    fritzdect.0
                    	2025-02-27 17:58:33.011	info	going over to cyclic polling, messages to poll activity only in debug-mode
                    fritzdect.0
                    	2025-02-27 17:58:33.011	info	finished initial updating devices/groups
                    fritzdect.0
                    	2025-02-27 17:58:33.001	error	try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
                    fritzdect.0
                    	2025-02-27 17:58:32.070	info	start initial updating devices/groups
                    fritzdect.0
                    	2025-02-27 17:58:32.069	info	finished creating routines (if any)
                    fritzdect.0
                    	2025-02-27 17:58:31.903	info	CREATE Routines 6
                    fritzdect.0
                    	2025-02-27 17:58:31.086	info	start creating routines
                    fritzdect.0
                    	2025-02-27 17:58:31.085	info	routines are used(false)
                    fritzdect.0
                    	2025-02-27 17:58:31.085	info	finished creating templates (if any)
                    fritzdect.0
                    	2025-02-27 17:58:30.695	info	CREATE Templates 30
                    fritzdect.0
                    	2025-02-27 17:58:30.158	info	start creating templates
                    fritzdect.0
                    	2025-02-27 17:58:30.157	info	templates are used(false)
                    fritzdect.0
                    	2025-02-27 17:58:30.156	info	finished creating devices/groups (if any)
                    fritzdect.0
                    	2025-02-27 17:58:30.155	error	iob err => undefined
                    fritzdect.0
                    	2025-02-27 17:58:30.154	error	--------------- error calling the fritzbox -----------
                    fritzdect.0
                    	2025-02-27 17:58:30.152	error	try/catch createDevices TypeError: Cannot read properties of undefined (reading 'replace')
                    fritzdect.0
                    	2025-02-27 17:58:30.144	info	CREATE Devices 31
                    fritzdect.0
                    	2025-02-27 17:58:29.126	info	start creating devices/groups
                    fritzdect.0
                    	2025-02-27 17:58:29.124	info	finished creating global values
                    fritzdect.0
                    	2025-02-27 17:58:29.062	info	create Main object global channel list
                    fritzdect.0
                    	2025-02-27 17:58:29.061	info	____________________________________________
                    fritzdect.0
                    	2025-02-27 17:58:29.060	info	start creating global values
                    fritzdect.0
                    	2025-02-27 17:58:29.059	info	the rights are : {"Rights":{"Name":"HomeAuto","Access":"2"}}
                    fritzdect.0
                    	2025-02-27 17:58:28.351	info	checking user permissions
                    fritzdect.0
                    	2025-02-27 17:57:24.618	info	fritzdect uses USER: iobroker
                    fritzdect.0
                    	2025-02-27 17:57:24.574	info	fritzdect entered ready
                    fritzdect.0
                    	2025-02-27 17:57:24.547	info	starting. Version 2.5.11 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v20.18.2, js-controller: 7.0.6
                    fritzdect.0
                    	2025-02-27 17:57:11.032	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    fritzdect.0
                    	2025-02-27 17:57:11.031	info	terminating
                    fritzdect.0
                    	2025-02-27 17:57:11.030	info	cleaned everything up...
                    fritzdect.0
                    	2025-02-27 17:57:11.028	info	Got terminate signal TERMINATE_YOURSELF
                    Ich habe also die Wahl zwischen unbenutzbarer Fritzbox-UI, aber aktuellen DP in iobroker ODER funktionierender Fritzbox UI und fritzdect-Adapter kaputt.
                    Tips?
                    • P Offline
                      Peter c
                      @bertderkleine said in fritzdect Adapter Fehler alle 10 Sekunden im Log:
                      Tips?
                      Ich habe gerade auf Github gesehen, dass es eine Version 2.6.1 gibt. Die ist als debug Version ladbar. Mit der ist der Adapter wieder mit fritzboxOS 8.02 arbeitsfähig. Vielleicht geht es bei Dir damit auch.
                      BertDerKleineB Detlef MeissnerD 3 Antworten Letzte Antwort
                      • P Peter c
                        Tips?
                        BertDerKleine
                        @peter-c
                        Danke Dir. Ist einen Versuch wert.
                        • P Peter c
                          Tips?
                          BertDerKleine
                          @peter-c sagte in fritzdect Adapter Fehler alle 10 Sekunden im Log:
                          Es scheint, als ob die v2.6.1 mit FritzOS v8.02 so tut, wie es soll.
                          Danke Dir für den Tip!
                          P Walter.O.W 2 Antworten Letzte Antwort
                          • BertDerKleineB BertDerKleine
                            Peter c
                            Gerne
                            • P Peter c
                              Tips?
                              Detlef MeissnerD Offline
                              Detlef Meissner
                              @peter-c Hallo, ich bin Anfänger bei iobroker deshalb meine Frage, da meine Fritzbox nach Update auf ios Version 8.02 auch nicht mehr läuft, wie kann ich die Version 2.6.1 von Fritzbox dect bekommen und installieren?
                              Wie gessagt absoluter Neuling, die Update habe ich sonst wenn Verfügbar über iobroker installiert.
                              Vielen dank für eure Hilfe.
                              Gruß Detlef
                                Walter.O.W Online
                                Walter.O.W Online
                                Walter.O.
                                @bertderkleine sagte in fritzdect Adapter Fehler alle 10 Sekunden im Log:
                                Kannst du mir bitte mal den link geben zur 2.6.1 habe das gleiche Problem.
                                B BertDerKleineB 2 Antworten Letzte Antwort
                                • Walter.O.W Walter.O.
                                  brofelscher
                                  @walter-o und @Detlef-Meissner : Ich glaube er meint die NPM-Version vom "fritzdect"-Adapter. Ich hatte das gleiche Problem wie ihr und konnte es mit der besagten NPM-Version 2.6.0 vom fritzdect-Adapter lösen.
                                  • Dazu deinstalliert ihr erstmal den offiziellen Adapter: Adapter > fritzdect > Adapter löschen
                                  • Weiterhin im Reiter "Adapter" auf den "Expertenmodus" umschalten (Kopfsymbol oben in der Leiste)
                                  • Daraufhin seht ihr das Katzensymbol direkt unterhalb des Expertenmodus-Symbols. Nennt sich "Installieren aus eigener URL"
                                  • Standardmäßig sollte dort bereits "von NPM" ausgewählt sein, so das ihr aus der DropDown-Liste nur noch "fritzdect" wählen und suchen müsst.
                                  • Auf "Installieren" klicken
                                  • Im Nachgang noch eine neue Instanz für den Adapter anlegen
                                  • R Offline
                                    rso
                                    Bei mir tauchte seit dem Update der Fritzbox auf V8.02 ein unbekanntes Gerät (wie im Issue 599 beschrieben) im Smarthomebereich auf. Dieses habe ich mir erlaubt zu löschen. Danach funktioniert alles wieder, auch mit Adapterversion 2.5.11.
                                    Ü 1 Antwort Letzte Antwort
                                    • P pjo123456
                                      Moin!
                                      Ich bekomme im Log vom fritzdect Adapter diese Fehlermeldung:
                                      Adapter Version 2.5.11
                                      Kann mir jemand erklären was das Problem ist? Danke.
                                      Rico Sander
                                      @all
                                      Ich hänge mich mal an das Thema dran, da ich den gleichen Fehler nach Update der FB hatte.
                                      Dank Eurer Hinweise - also FritzDECT deinstallieren, FritzDECT neu aus NPM installieren, etc. - läuft das wieder.
                                      Nun mal eine generelle Frage, die vlt. auch für andere Situationen gilt:
                                      Nach Deinstallation des FritzDECT Adapters sind natürlich auch alle eingerichteten DP weg. Die Daten selbst sind zwar in der history DB, aber das nützt recht wenig, denn der neu installierte DECT Adapter hat diese DP nun nicht.
                                      Ich vermute, dass die Konfiguaration dieser Adapter-DP in der täglichen Sicherung steckt. Ein restore würde aber sicher die neue Version des DECT Adapters überschreiben, was kontraproduktiv wäre :-)
                                      Was mir dazu einfällt:
                                      • Man müsste die Konfiguaration von iob zurücksichern können, ohne das die neue Adapter-Version überschrieben wird,
                                      • oder nach einem restore die neue Adapterversion wie bei jedem Update "drüberbügeln", wobei die Frage steht, ob das geht.
                                      Musste also zwingend der alte Adapter deinstalliert werden?
                                      Und das wäre nach meinem Erkenntnisstand ein generelles Problem, welches in ähnlichen Situation auch auf andere Adapter zutreffen kann.
                                      Ich hoffe ich konnte klar und verständlich genug formulieren oder habe ich einen grundsätzlichen Gedankenfehler im BIO-RAM.
                                      Danke und einen schönen Wochenend-Rest.
                                      Wenns nicht geht, wie man will
                                      - muss mans tun, wie man kann.
                                      BertDerKleineB 1 Antwort Letzte Antwort
                                      • R rso
                                        Ü Offline
                                        Ü Offline
                                        Ünne
                                        @rso Ich hatte dasselbe Problem: nach Update unbekanntes Gerät. Nach dem Löschen des Gerätes gab es keine Fehlermeldungen mehr.
                                        Das ist die einfachste Methode . Super
                                          BertDerKleine
                                          @walter-o sagte in fritzdect Adapter Fehler alle 10 Sekunden im Log:
                                          Der einfachste Weg ist es, in der Adapterliste auf der Kachel die drei Punkte zudrücken und dann auf das Plussymbol für "eine bestimmte Version installieren":
                                          Dann im Feld "Version manuell eingeben" die Versionsnummer eingeben, also z.B. "2.6.1".
