  4. Test ioBroker unter Windows installieren - 2023 Edition
    1.0k
    6.1k
installation iobrokerwindowswindows installation
405 Beiträge 25 Kommentatoren 119.4k Aufrufe 22 Beobachtet
  • sigi234S sigi234
    @negalein
    Was kommt bei iob instances ?
    NegaleinN Offline
    NegaleinN Offline
    Negalein
    #362
    @sigi234 sagte in Test ioBroker unter Windows installieren - 2023 Edition:
    iob instances
    kennt er nicht
    D:\ioBroker>iob instances
    iobroker [command]
    Commands:
      iobroker setup                                               Setup ioBroker
      iobroker start [all|<adapter>.<instance>|<adapter>]          Starts the js-controller or a specified adapter instance or all instances of an adapter
      iobroker stop [<adapter>.<instance>|<adapter>]               stops the js-controller or a specified adapter instance or all instances of an adapter
      iobroker restart [<adapter>.<instance>|<adapter>]            Restarts js-controller or a specified adapter instance or all instances of an adapter  [aliases: r]
      iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
      iobroker info                                                Shows the host info
      iobroker logs [<adapter>]                                    Monitor log
      iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
      iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
      iobroker rebuild [<module>]                                  Rebuild all native modules or path
      iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub, if a package name is provided instead of an url, it will be installed from npm
      iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
      iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
      iobroker update [<repositoryUrl>]                            Update repository and list adapters
      iobroker upgrade                                             Upgrade management
      iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
      iobroker object                                              Object management  [aliases: o]
      iobroker state                                               State management  [aliases: s]
      iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
      iobroker list <type> [<filter>]                              List all entries, like objects
      iobroker chmod <mode> <file>                                 Change file rights
      iobroker chown <user> <group> <file>                         Change file ownership
      iobroker touch <file>                                        Touch file
      iobroker rm <file>                                           Remove file
      iobroker file                                                File management
      iobroker user                                                User commands
      iobroker group                                               group management
      iobroker host <hostname>                                     Set host to given hostname
      iobroker set <adapter>.<instance>                            Change settings of adapter config
      iobroker license <license.file or license.text>              Update license by given file
      iobroker cert                                                Certificate management
      iobroker clean <yes>                                         Clears all objects and states
      iobroker backup                                              Create backup
      iobroker restore <backup name or path>                       Restore a specified backup
      iobroker validate <backup name or path>                      Validate a specified backup
      iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
      iobroker repo                                                Show repo information
      iobroker uuid                                                Show uuid of the installation  [aliases: id]
      iobroker unsetup                                             Reset license, installation secret and language
      iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
      iobroker nodejs-update [<major-version>]                     Upgrade the Node.JS installation to the current LTS
      iobroker multihost                                           Multihost management
      iobroker compact                                             compact group management
      iobroker plugin                                              Plugin management
      iobroker vendor <passphrase> [<vendor.json>]                 Update the vendor information using given passphrase
      iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
    Options:
      --help  Show help  [boolean]
    ° Fixer ---> iob fix
    • NegaleinN Negalein
      iob instances
      kennt er nicht
      iobroker [command]
      Commands:
      Options:
      sigi234S Online
      sigi234S Online
      #363
      @negalein sagte in Test ioBroker unter Windows installieren - 2023 Edition:
      kennt er nicht
      Sorry:
      iob list instances
      • sigi234S sigi234
        kennt er nicht
        Sorry:
        iob list instances
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        #364
        iob list instances
        D:\ioBroker>iob list instances
          system.adapter.admin.0                  : admin                 : DESKTOP-7OQNUBI                          -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.backitup.0               : backitup              : DESKTOP-7OQNUBI                          -  enabled
          system.adapter.discovery.0              : discovery             : DESKTOP-7OQNUBI                          - disabled
        + instance is alive
          iob list instances
          + instance is alive
          sigi234S Online
          sigi234S Online
          #365
          @negalein
          Und da:
          • sigi234S sigi234
            @negalein
            Und da:
            NegaleinN Offline
            NegaleinN Offline
            Negalein
            #366
            Und da:
            nicht gestartet
            starte ich ihn dann manuell, läuft er kurz und beendet sich kurz darauf wieder
            sigi234S GaspodeG 2 Antworten Letzte Antwort
              Und da:
              nicht gestartet
              sigi234S Online
              sigi234S Online
              #367
              Und da:
              nicht gestartet
              1.Schritt:
              Hauptsystem (Linux) stoppen,
              Den iobroker-data Ordner kopieren und auf den Win Rechner sichern.
              1. Schritt:
              Iob stoppen, den Installer ausführen und die Win Installation wieder deinstallieren.
              Nachsehen ob auch alles gelöscht wurde, oder dann bei der Neuinstallation einen anderen Namen vergeben.
              Installer wieder starten , neu installieren und die Option Datenübernahme wählen.
              Der ioBroker Fixer kann nicht ausgewählt werden Die nächsten zwei Optionen können verändert werden, in der Regel ist es aber empfehlenswert, die Standardeinstellungen beizubehalten. Und schließlich bietet der Installer noch die Möglichkeit, die Konfiguration einer vorhandenen Installation zu übernehmen. Dafür ist der komplette Ordner "iobroker-data" erforderlich, der bei einer vorhandenen ioBroker Installation im ioBroker Ordner zu finden ist. Dieser kann von einer ioBroker Installation unter Windows oder Linux stammen. Die Daten werden während der Installation aus diesem Ordner übernommen, der Inhalt dieses Ordners wird nicht verändert. Nach Klick auf "Weiter" sehen wir jetzt die Zusammenfassung der geplanten Aktionen:
              Hinweis bei Datenübernahme:
              Wenn alles geklappt hat werden nach und nach die Adapter installiert.
              Das kann sehr lange dauern!
              • sigi234S sigi234
                Und da:
                nicht gestartet
                1.Schritt:
                1. Schritt:
                NegaleinN Offline
                NegaleinN Offline
                Negalein
                #368
                läuft ja auf Windows
                das ist noch keine Übernahme vom Hauptsystem.
                Wird erst mit Backitup-Restore gemacht, wenn alles 1A läuft.
                  sigi234S Online
                  sigi234S Online
                  #369
                  Läuft ja auf Windows
                  Du hast schon eine Windows Installation? Oder Proxmox?
                    @gaspode
                    Hallo
                    Ich hab heute ioB auf Win10 installiert.
                    Soweit lief alles perfekt.
                    Jetzt wollte ich mir gerade vom Hauptsystem (Linux) die Backitup-Config exportieren (funktionierte wie üblich) und am Win-Server in Backitup wieder importieren.
                    Seitdem ist der Win-ioB nicht mehr erreichbar.
                    23:21:59.473  - info: admin.0 (6588) ==> Connected system.user.admin from ::ffff:10.0.1.31
                    2025-02-21 23:22:15.885  - info: admin.0 (6588) ==> Connected system.user.admin from ::ffff:10.0.1.31
                    2025-02-21 23:23:36.471  - info: admin.0 (6588) <== Disconnect system.user.admin from ::ffff:10.0.1.31 backitup
                    2025-02-21 23:24:15.849  - info: host.DESKTOP-7OQNUBI "system.adapter.backitup.0" enabled
                    2025-02-21 23:24:16.089  - info: host.DESKTOP-7OQNUBI instance system.adapter.backitup.0 in version "3.0.31" started with pid 1168
                    2025-02-21 23:24:16.853  - error: backitup.0 (1168) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    2025-02-21 23:24:16.853  - error: backitup.0 (1168) unhandled promise rejection: Cannot read properties of undefined (reading 'cifsPassword')
                    2025-02-21 23:24:16.854  - error: backitup.0 (1168) TypeError: Cannot read properties of undefined (reading 'cifsPassword')
                        at AdapterClass._initAdapter (D:\ioBroker\node_modules\@iobroker\js-controller-adapter\build\cjs\lib\adapter\adapter.js:7709:31)
                    2025-02-21 23:24:16.854  - error: backitup.0 (1168) Cannot read properties of undefined (reading 'cifsPassword')
                    2025-02-21 23:24:17.370  - info: backitup.0 (1168) terminating
                    2025-02-21 23:24:17.370  - warn: backitup.0 (1168) Terminated (UNCAUGHT_EXCEPTION): Without reason
                    2025-02-21 23:24:17.922  - error: host.DESKTOP-7OQNUBI instance system.adapter.backitup.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                    2025-02-21 23:24:17.924  - error: host.DESKTOP-7OQNUBI uncaught exception: Cannot read properties of undefined (reading 'webInstance')
                    2025-02-21 23:24:17.924  - error: host.DESKTOP-7OQNUBI TypeError: Cannot read properties of undefined (reading 'webInstance')
                        at file:///D:/ioBroker/node_modules/iobroker.js-controller/build/esm/main.js:3533:53
                        at Immediate.<anonymous> (file:///D:/ioBroker/node_modules/iobroker.js-controller/build/esm/main.js:1041:31)
                        at process.processImmediate (node:internal/timers:485:21)
                    2025-02-21 23:24:17.924  - info: host.DESKTOP-7OQNUBI stopInstance system.adapter.admin.0 (force=false, process=true)
                    2025-02-21 23:24:17.925  - info: host.DESKTOP-7OQNUBI stopInstance system.adapter.backitup.0 (force=false, process=false)
                    2025-02-21 23:24:17.925  - info: host.DESKTOP-7OQNUBI stopInstance system.adapter.discovery.0 (force=false, process=false)
                    2025-02-21 23:24:17.928  - info: host.DESKTOP-7OQNUBI stopInstance system.adapter.admin.0 send kill signal
                    2025-02-21 23:24:17.933  - info: admin.0 (6588) Got terminate signal TERMINATE_YOURSELF
                    2025-02-21 23:24:17.933  - info: admin.0 (6588) terminating http server on port 8081
                    2025-02-21 23:24:17.935  - info: admin.0 (6588) terminating
                    2025-02-21 23:24:17.936  - info: admin.0 (6588) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2025-02-21 23:24:18.437  - info: admin.0 (6588) terminating
                    2025-02-21 23:24:18.455  - info: host.DESKTOP-7OQNUBI instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2025-02-21 23:24:18.455  - info: host.DESKTOP-7OQNUBI All instances are stopped.
                    2025-02-21 23:24:18.554  - info: host.DESKTOP-7OQNUBI terminated
                    2025-02-21 23:27:04.001  - info: host.DESKTOP-7OQNUBI iobroker.js-controller version 7.0.6 js-controller starting
                    2025-02-21 23:27:04.003  - info: host.DESKTOP-7OQNUBI Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
                    2025-02-21 23:27:04.003  - info: host.DESKTOP-7OQNUBI hostname: DESKTOP-7OQNUBI, node: v20.18.3
                    2025-02-21 23:27:04.003  - info: host.DESKTOP-7OQNUBI ip addresses: fdda:a0e6:8b95:b3ea:82d2:cc9f:5fbb:59bc fdda:a0e6:8b95:b3ea:c521:4a1a:2d8c:bddd fe80::a438:ce38:4724:945d 10.0.1.239
                    2025-02-21 23:27:04.316  - info: host.DESKTOP-7OQNUBI connected to Objects and States
                    2025-02-21 23:27:04.321  - info: host.DESKTOP-7OQNUBI added notifications configuration of host
                    2025-02-21 23:27:04.350  - info: host.DESKTOP-7OQNUBI 3 instances found
                    2025-02-21 23:27:04.353  - info: host.DESKTOP-7OQNUBI starting 2 instances
                    2025-02-21 23:27:04.583  - info: host.DESKTOP-7OQNUBI Delete state "system.host.DESKTOP-7OQNUBI.versions.nodeCurrent"
                    2025-02-21 23:27:04.601  - info: host.DESKTOP-7OQNUBI Delete state "system.host.DESKTOP-7OQNUBI.versions.nodeNewest"
                    2025-02-21 23:27:04.605  - info: host.DESKTOP-7OQNUBI Delete state "system.host.DESKTOP-7OQNUBI.versions.nodeNewestNext"
                    2025-02-21 23:27:04.610  - info: host.DESKTOP-7OQNUBI instance system.adapter.admin.0 in version "7.4.10" started with pid 3520
                    2025-02-21 23:27:04.612  - info: host.DESKTOP-7OQNUBI Delete state "system.host.DESKTOP-7OQNUBI.versions.npmCurrent"
                    2025-02-21 23:27:04.613  - info: host.DESKTOP-7OQNUBI Delete state "system.host.DESKTOP-7OQNUBI.versions.npmNewest"
                    2025-02-21 23:27:04.615  - info: host.DESKTOP-7OQNUBI Delete state "system.host.DESKTOP-7OQNUBI.versions.npmNewestNext"
                    2025-02-21 23:27:04.617  - info: host.DESKTOP-7OQNUBI Some obsolete host states deleted.
                    2025-02-21 23:27:05.670  - info: admin.0 (3520) starting. Version 7.4.10 in D:/ioBroker/node_modules/iobroker.admin, node: v20.18.3, js-controller: 7.0.6
                    2025-02-21 23:27:05.684  - info: admin.0 (3520) requesting all objects
                    2025-02-21 23:27:06.111  - info: admin.0 (3520) received all objects
                    2025-02-21 23:27:06.386  - info: admin.0 (3520) socket.io server listening on port 8081
                    2025-02-21 23:27:06.388  - info: admin.0 (3520) http server listening on port 8081
                    2025-02-21 23:27:06.388  - info: admin.0 (3520) Use link "http://127.0.0.1:8081" to configure.
                    2025-02-21 23:27:08.652  - info: host.DESKTOP-7OQNUBI instance system.adapter.backitup.0 in version "3.0.31" started with pid 3304
                    2025-02-21 23:27:09.580  - error: backitup.0 (3304) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    2025-02-21 23:27:09.581  - error: backitup.0 (3304) unhandled promise rejection: Cannot read properties of undefined (reading 'cifsPassword')
                    2025-02-21 23:27:09.582  - error: backitup.0 (3304) TypeError: Cannot read properties of undefined (reading 'cifsPassword')
                    2025-02-21 23:27:09.582  - error: backitup.0 (3304) Cannot read properties of undefined (reading 'cifsPassword')
                    2025-02-21 23:27:10.100  - info: backitup.0 (3304) terminating
                    2025-02-21 23:27:10.101  - warn: backitup.0 (3304) Terminated (UNCAUGHT_EXCEPTION): Without reason
                    2025-02-21 23:27:10.646  - error: host.DESKTOP-7OQNUBI instance system.adapter.backitup.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                    2025-02-21 23:27:10.648  - error: host.DESKTOP-7OQNUBI uncaught exception: Cannot read properties of undefined (reading 'webInstance')
                    2025-02-21 23:27:10.648  - error: host.DESKTOP-7OQNUBI TypeError: Cannot read properties of undefined (reading 'webInstance')
                    2025-02-21 23:27:10.649  - info: host.DESKTOP-7OQNUBI stopInstance system.adapter.admin.0 (force=false, process=true)
                    2025-02-21 23:27:10.650  - info: host.DESKTOP-7OQNUBI stopInstance system.adapter.backitup.0 (force=false, process=false)
                    2025-02-21 23:27:10.650  - info: host.DESKTOP-7OQNUBI stopInstance system.adapter.discovery.0 (force=false, process=false)
                    2025-02-21 23:27:10.652  - info: admin.0 (3520) Got terminate signal TERMINATE_YOURSELF
                    2025-02-21 23:27:10.652  - info: host.DESKTOP-7OQNUBI stopInstance system.adapter.admin.0 send kill signal
                    2025-02-21 23:27:10.652  - info: admin.0 (3520) terminating http server on port 8081
                    2025-02-21 23:27:10.653  - info: admin.0 (3520) terminating
                    2025-02-21 23:27:10.653  - info: admin.0 (3520) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2025-02-21 23:27:11.164  - info: admin.0 (3520) terminating
                    2025-02-21 23:27:11.203  - info: host.DESKTOP-7OQNUBI instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2025-02-21 23:27:11.203  - info: host.DESKTOP-7OQNUBI All instances are stopped.
                    2025-02-21 23:27:11.269  - info: host.DESKTOP-7OQNUBI terminated
                    2025-02-21 23:27:52.455  - info: host.DESKTOP-7OQNUBI iobroker.js-controller version 7.0.6 js-controller starting
                    2025-02-21 23:27:52.457  - info: host.DESKTOP-7OQNUBI Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
                    2025-02-21 23:27:52.457  - info: host.DESKTOP-7OQNUBI hostname: DESKTOP-7OQNUBI, node: v20.18.3
                    2025-02-21 23:27:52.457  - info: host.DESKTOP-7OQNUBI ip addresses: fdda:a0e6:8b95:b3ea:82d2:cc9f:5fbb:59bc fdda:a0e6:8b95:b3ea:c521:4a1a:2d8c:bddd fe80::a438:ce38:4724:945d 10.0.1.239
                    2025-02-21 23:27:52.754  - info: host.DESKTOP-7OQNUBI connected to Objects and States
                    2025-02-21 23:27:52.760  - info: host.DESKTOP-7OQNUBI added notifications configuration of host
                    2025-02-21 23:27:52.788  - info: host.DESKTOP-7OQNUBI 3 instances found
                    2025-02-21 23:27:52.791  - info: host.DESKTOP-7OQNUBI starting 2 instances
                    2025-02-21 23:27:53.020  - info: host.DESKTOP-7OQNUBI Delete state "system.host.DESKTOP-7OQNUBI.versions.nodeCurrent"
                    2025-02-21 23:27:53.036  - info: host.DESKTOP-7OQNUBI Delete state "system.host.DESKTOP-7OQNUBI.versions.nodeNewest"
                    2025-02-21 23:27:53.039  - info: host.DESKTOP-7OQNUBI Delete state "system.host.DESKTOP-7OQNUBI.versions.nodeNewestNext"
                    2025-02-21 23:27:53.044  - info: host.DESKTOP-7OQNUBI instance system.adapter.admin.0 in version "7.4.10" started with pid 7656
                    2025-02-21 23:27:53.046  - info: host.DESKTOP-7OQNUBI Delete state "system.host.DESKTOP-7OQNUBI.versions.npmCurrent"
                    2025-02-21 23:27:53.048  - info: host.DESKTOP-7OQNUBI Delete state "system.host.DESKTOP-7OQNUBI.versions.npmNewest"
                    2025-02-21 23:27:53.049  - info: host.DESKTOP-7OQNUBI Delete state "system.host.DESKTOP-7OQNUBI.versions.npmNewestNext"
                    2025-02-21 23:27:53.051  - info: host.DESKTOP-7OQNUBI Some obsolete host states deleted.
                    2025-02-21 23:27:54.046  - info: admin.0 (7656) starting. Version 7.4.10 in D:/ioBroker/node_modules/iobroker.admin, node: v20.18.3, js-controller: 7.0.6
                    2025-02-21 23:27:54.059  - info: admin.0 (7656) requesting all objects
                    2025-02-21 23:27:54.482  - info: admin.0 (7656) received all objects
                    2025-02-21 23:27:54.540  - info: admin.0 (7656) socket.io server listening on port 8081
                    2025-02-21 23:27:54.541  - info: admin.0 (7656) http server listening on port 8081
                    2025-02-21 23:27:54.542  - info: admin.0 (7656) Use link "http://127.0.0.1:8081" to configure.
                    2025-02-21 23:27:57.070  - info: host.DESKTOP-7OQNUBI instance system.adapter.backitup.0 in version "3.0.31" started with pid 9564
                    2025-02-21 23:27:57.885  - error: backitup.0 (9564) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    2025-02-21 23:27:57.886  - error: backitup.0 (9564) unhandled promise rejection: Cannot read properties of undefined (reading 'cifsPassword')
                    2025-02-21 23:27:57.887  - error: backitup.0 (9564) TypeError: Cannot read properties of undefined (reading 'cifsPassword')
                    2025-02-21 23:27:57.887  - error: backitup.0 (9564) Cannot read properties of undefined (reading 'cifsPassword')
                    2025-02-21 23:27:58.399  - info: backitup.0 (9564) terminating
                    2025-02-21 23:27:58.400  - warn: backitup.0 (9564) Terminated (UNCAUGHT_EXCEPTION): Without reason
                    2025-02-21 23:27:58.940  - error: host.DESKTOP-7OQNUBI instance system.adapter.backitup.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                    2025-02-21 23:27:58.942  - error: host.DESKTOP-7OQNUBI uncaught exception: Cannot read properties of undefined (reading 'webInstance')
                    2025-02-21 23:27:58.942  - error: host.DESKTOP-7OQNUBI TypeError: Cannot read properties of undefined (reading 'webInstance')
                    2025-02-21 23:27:58.943  - info: host.DESKTOP-7OQNUBI stopInstance system.adapter.admin.0 (force=false, process=true)
                    2025-02-21 23:27:58.943  - info: host.DESKTOP-7OQNUBI stopInstance system.adapter.backitup.0 (force=false, process=false)
                    2025-02-21 23:27:58.943  - info: host.DESKTOP-7OQNUBI stopInstance system.adapter.discovery.0 (force=false, process=false)
                    2025-02-21 23:27:58.945  - info: admin.0 (7656) Got terminate signal TERMINATE_YOURSELF
                    2025-02-21 23:27:58.945  - info: host.DESKTOP-7OQNUBI stopInstance system.adapter.admin.0 send kill signal
                    2025-02-21 23:27:58.945  - info: admin.0 (7656) terminating http server on port 8081
                    2025-02-21 23:27:58.946  - info: admin.0 (7656) terminating
                    2025-02-21 23:27:58.946  - info: admin.0 (7656) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2025-02-21 23:27:59.461  - info: admin.0 (7656) terminating
                    2025-02-21 23:27:59.498  - info: host.DESKTOP-7OQNUBI instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2025-02-21 23:27:59.498  - info: host.DESKTOP-7OQNUBI All instances are stopped.
                    2025-02-21 23:27:59.567  - info: host.DESKTOP-7OQNUBI terminated
                    2025-02-21 23:28:30.392  - info: host.DESKTOP-7OQNUBI iobroker.js-controller version 7.0.6 js-controller starting
                    2025-02-21 23:28:30.394  - info: host.DESKTOP-7OQNUBI Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
                    2025-02-21 23:28:30.394  - info: host.DESKTOP-7OQNUBI hostname: DESKTOP-7OQNUBI, node: v20.18.3
                    2025-02-21 23:28:30.394  - info: host.DESKTOP-7OQNUBI ip addresses: fdda:a0e6:8b95:b3ea:82d2:cc9f:5fbb:59bc fdda:a0e6:8b95:b3ea:c521:4a1a:2d8c:bddd fe80::a438:ce38:4724:945d 10.0.1.239
                    2025-02-21 23:28:30.689  - info: host.DESKTOP-7OQNUBI connected to Objects and States
                    2025-02-21 23:28:30.695  - info: host.DESKTOP-7OQNUBI added notifications configuration of host
                    2025-02-21 23:28:30.723  - info: host.DESKTOP-7OQNUBI 3 instances found
                    2025-02-21 23:28:30.726  - info: host.DESKTOP-7OQNUBI starting 2 instances
                    2025-02-21 23:28:30.969  - info: host.DESKTOP-7OQNUBI Delete state "system.host.DESKTOP-7OQNUBI.versions.nodeCurrent"
                    2025-02-21 23:28:30.984  - info: host.DESKTOP-7OQNUBI Delete state "system.host.DESKTOP-7OQNUBI.versions.nodeNewest"
                    2025-02-21 23:28:30.988  - info: host.DESKTOP-7OQNUBI Delete state "system.host.DESKTOP-7OQNUBI.versions.nodeNewestNext"
                    2025-02-21 23:28:30.993  - info: host.DESKTOP-7OQNUBI instance system.adapter.admin.0 in version "7.4.10" started with pid 2484
                    2025-02-21 23:28:30.995  - info: host.DESKTOP-7OQNUBI Delete state "system.host.DESKTOP-7OQNUBI.versions.npmCurrent"
                    2025-02-21 23:28:30.996  - info: host.DESKTOP-7OQNUBI Delete state "system.host.DESKTOP-7OQNUBI.versions.npmNewest"
                    2025-02-21 23:28:30.998  - info: host.DESKTOP-7OQNUBI Delete state "system.host.DESKTOP-7OQNUBI.versions.npmNewestNext"
                    2025-02-21 23:28:30.999  - info: host.DESKTOP-7OQNUBI Some obsolete host states deleted.
                    2025-02-21 23:28:31.997  - info: admin.0 (2484) starting. Version 7.4.10 in D:/ioBroker/node_modules/iobroker.admin, node: v20.18.3, js-controller: 7.0.6
                    2025-02-21 23:28:32.010  - info: admin.0 (2484) requesting all objects
                    2025-02-21 23:28:32.348  - info: admin.0 (2484) received all objects
                    2025-02-21 23:28:32.723  - info: admin.0 (2484) socket.io server listening on port 8081
                    2025-02-21 23:28:32.725  - info: admin.0 (2484) http server listening on port 8081
                    2025-02-21 23:28:32.725  - info: admin.0 (2484) Use link "http://127.0.0.1:8081" to configure.
                    2025-02-21 23:28:34.975  - info: host.DESKTOP-7OQNUBI instance system.adapter.backitup.0 in version "3.0.31" started with pid 7688
                    2025-02-21 23:28:35.830  - error: backitup.0 (7688) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    2025-02-21 23:28:35.831  - error: backitup.0 (7688) unhandled promise rejection: Cannot read properties of undefined (reading 'cifsPassword')
                    2025-02-21 23:28:35.832  - error: backitup.0 (7688) TypeError: Cannot read properties of undefined (reading 'cifsPassword')
                    2025-02-21 23:28:35.832  - error: backitup.0 (7688) Cannot read properties of undefined (reading 'cifsPassword')
                    2025-02-21 23:28:36.337  - info: backitup.0 (7688) terminating
                    2025-02-21 23:28:36.339  - warn: backitup.0 (7688) Terminated (UNCAUGHT_EXCEPTION): Without reason
                    2025-02-21 23:28:36.882  - error: host.DESKTOP-7OQNUBI instance system.adapter.backitup.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                    2025-02-21 23:28:36.885  - error: host.DESKTOP-7OQNUBI uncaught exception: Cannot read properties of undefined (reading 'webInstance')
                    2025-02-21 23:28:36.885  - error: host.DESKTOP-7OQNUBI TypeError: Cannot read properties of undefined (reading 'webInstance')
                    2025-02-21 23:28:36.886  - info: host.DESKTOP-7OQNUBI stopInstance system.adapter.admin.0 (force=false, process=true)
                    2025-02-21 23:28:36.886  - info: host.DESKTOP-7OQNUBI stopInstance system.adapter.backitup.0 (force=false, process=false)
                    2025-02-21 23:28:36.886  - info: host.DESKTOP-7OQNUBI stopInstance system.adapter.discovery.0 (force=false, process=false)
                    2025-02-21 23:28:36.888  - info: admin.0 (2484) Got terminate signal TERMINATE_YOURSELF
                    2025-02-21 23:28:36.888  - info: host.DESKTOP-7OQNUBI stopInstance system.adapter.admin.0 send kill signal
                    2025-02-21 23:28:36.888  - info: admin.0 (2484) terminating http server on port 8081
                    2025-02-21 23:28:36.889  - info: admin.0 (2484) terminating
                    2025-02-21 23:28:36.889  - info: admin.0 (2484) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2025-02-21 23:28:37.395  - info: admin.0 (2484) terminating
                    2025-02-21 23:28:37.426  - info: host.DESKTOP-7OQNUBI instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2025-02-21 23:28:37.426  - info: host.DESKTOP-7OQNUBI All instances are stopped.
                    2025-02-21 23:28:37.519  - info: host.DESKTOP-7OQNUBI terminated
                    die 3 .bat (Restart, Start, Stop) bringen keine Abhilfe.
                    Ebenso hilft ein Reboot der Maschine nicht.
                    Was könnte das sein?
                    sigi234S Online
                    sigi234S Online
                    #370
                    Das verstehe ich nicht
                    • sigi234S sigi234
                      NegaleinN Offline
                      NegaleinN Offline
                      Negalein
                      #371
                      Du hast schon eine Windows Installation? Oder Promox?
                      Hauptsystem ist Linux (Proxmox).
                      Dies bleibt solange, bis Windows perfekt und stabil läuft.
                      Erst dann wird mit Backitup ein Restore durchgeführt und das Hauptsystem stillgelegt.
                        sigi234S Online
                        sigi234S Online
                        #372
                        Aha, ok da kenne ich mich nicht aus. Ob das so funktioniert bin ich mir nicht sicher.
                        Da kann dir nur @Gaspode oder @simatec helfen bzw. was dazu sagen.
                        • NegaleinN Offline
                          NegaleinN Offline
                          Negalein
                          #373
                          Ich wollte die Konfig (Speicherorte, Settings, usw.) nicht manuell eingeben.
                          Deshalb hab ich vom Hauptsystem in Backitup einen Export der Settings gemacht
                          und am Win-System wieder importiert.
                          Hauptsystem
                          Win-System
                            Und da:
                            nicht gestartet
                            GaspodeG Offline
                            GaspodeG Offline
                            Gaspode
                            #374
                            @negalein said in Test ioBroker unter Windows installieren - 2023 Edition:
                            Und was steht dann anschließend im Log?
                            Zu Backitup kann ich nix sagen, generell würde ich bei einer Windows Neuinstallation aber dazu raten, die Daenübernahme mit dem Installer zu machen, wie @sigi234 bereits empfohlen hat.
                            • Windows Installation wieder deinstallieren
                            • Den iobroker-data Ordner der Linux Installation auf den Windows Rechner kopieren (ACHTUNG: irgendwohin, NICHT in den zukünftigen ioBroker Installationsordner!)
                            • Installation starten, Datenübernahme auswählen und den kopierten iobroker-data Ordner angeben.
                            • Nach erfolgter Installation werden dann alle benötigten Adapter automatisch nachinstalliert, dauert einige Minuten
                            NegaleinN 2 Antworten Letzte Antwort
                            • GaspodeG Gaspode
                              NegaleinN Offline
                              NegaleinN Offline
                              Negalein
                              #375
                              @gaspode sagte in Test ioBroker unter Windows installieren - 2023 Edition:
                              hab ihn schon deinstalliert.
                              Versuch es jetzt mit Datenübernahme.
                              In der Win-Ereignisanzeige steht nur
                              • GaspodeG Gaspode
                                NegaleinN Offline
                                NegaleinN Offline
                                Negalein
                                #376
                                @gaspode
                                hab ihn jetzt neu mit Datenübernahme installiert.
                                Lief alles durch.
                                ioBroker Dienst läuft, aber ich hab keinen Zugriff :(
                                Port passt und Admin läuft.
                                Aber leider kein Zugriff auf die Oberfläche
                                + system.adapter.admin.0                  : admin                 : Windows-Server                           -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                  system.adapter.alexa2.0                 : alexa2                : Windows-Server                           -  enabled
                                  system.adapter.alexa2.1                 : alexa2                : Windows-Server                           -  enabled
                                  system.adapter.alias-manager.0          : alias-manager         : Windows-Server                           - disabled
                                + system.adapter.backitup.0               : backitup              : Windows-Server                           -  enabled
                                  system.adapter.bayernluft.0             : bayernluft            : Windows-Server                           -  enabled
                                  system.adapter.birthdays.0              : birthdays             : Windows-Server                           -  enabled
                                  system.adapter.bring.0                  : bring                 : Windows-Server                           - disabled
                                  system.adapter.cloud.0                  : cloud                 : Windows-Server                           - disabled
                                  system.adapter.daswetter.0              : daswetter             : Windows-Server                           -  enabled
                                  system.adapter.denon.0                  : denon                 : Windows-Server                           -  enabled
                                  system.adapter.device-watcher.0         : device-watcher        : Windows-Server                           - disabled
                                  system.adapter.devices.0                : devices               : Windows-Server                           - disabled
                                  system.adapter.discovery.0              : discovery             : Windows-Server                           - disabled
                                  system.adapter.doorbird.0               : doorbird              : Windows-Server                           -  enabled
                                  system.adapter.dwd.0                    : dwd                   : Windows-Server                           -  enabled
                                  system.adapter.email.0                  : email                 : Windows-Server                           -  enabled
                                  system.adapter.energiefluss.0           : energiefluss          : Windows-Server                           -  enabled
                                  system.adapter.enigma2.0                : enigma2               : Windows-Server                           -  enabled
                                  system.adapter.enigma2.1                : enigma2               : Windows-Server                           - disabled
                                  system.adapter.eventlist.0              : eventlist             : Windows-Server                           -  enabled
                                  system.adapter.feiertage.0              : feiertage             : Windows-Server                           - disabled
                                  system.adapter.fitbit-fitness.0         : fitbit-fitness        : Windows-Server                           - disabled
                                  system.adapter.flot.0                   : flot                  : Windows-Server                           - disabled
                                  system.adapter.followthesun.0           : followthesun          : Windows-Server                           -  enabled
                                  system.adapter.fontui.0                 : fontui                : Windows-Server                           -  enabled
                                  system.adapter.fronius.0                : fronius               : Windows-Server                           -  enabled
                                  system.adapter.fuelpricemonitor.0       : fuelpricemonitor      : Windows-Server                           -  enabled
                                  system.adapter.fullybrowser.0           : fullybrowser          : Windows-Server                           -  enabled
                                  system.adapter.harmony.1                : harmony               : Windows-Server                           -  enabled
                                  system.adapter.history.0                : history               : Windows-Server                           -  enabled
                                  system.adapter.hm-rega.0                : hm-rega               : Windows-Server                           -  enabled
                                  system.adapter.hm-rpc.0                 : hm-rpc                : Windows-Server                           -  enabled, port: 0
                                  system.adapter.hm-rpc.1                 : hm-rpc                : Windows-Server                           -  enabled, port: 0
                                  system.adapter.hm-rpc.2                 : hm-rpc                : Windows-Server                           -  enabled, port: 0
                                  system.adapter.hs100.0                  : hs100                 : Windows-Server                           -  enabled
                                  system.adapter.hue.0                    : hue                   : Windows-Server                           -  enabled, port: 80
                                  system.adapter.ical.0                   : ical                  : Windows-Server                           -  enabled
                                  system.adapter.ical.1                   : ical                  : Windows-Server                           -  enabled
                                  system.adapter.ical.2                   : ical                  : Windows-Server                           -  enabled
                                  system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: Windows-Server                           - disabled
                                  system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : Windows-Server                           - disabled
                                  system.adapter.icons-icons8.0           : icons-icons8          : Windows-Server                           - disabled
                                  system.adapter.icons-material-png.0     : icons-material-png    : Windows-Server                           - disabled
                                  system.adapter.icons-material-svg.0     : icons-material-svg    : Windows-Server                           - disabled
                                  system.adapter.icons-mfd-png.0          : icons-mfd-png         : Windows-Server                           - disabled
                                  system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : Windows-Server                           - disabled
                                  system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: Windows-Server                           -  enabled
                                  system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : Windows-Server                           - disabled
                                  system.adapter.influxdb.0               : influxdb              : Windows-Server                           -  enabled, port: 32543
                                  system.adapter.influxdb.1               : influxdb              : Windows-Server                           -  enabled, port: 8086
                                  system.adapter.influxdb.2               : influxdb              : Windows-Server                           -  enabled, port: 8086
                                  system.adapter.iot.0                    : iot                   : Windows-Server                           -  enabled
                                  system.adapter.iot.1                    : iot                   : Windows-Server                           -  enabled
                                  system.adapter.iqontrol.0               : iqontrol              : Windows-Server                           - disabled
                                  system.adapter.javascript.0             : javascript            : Windows-Server                           -  enabled
                                  system.adapter.javascript.1             : javascript            : Windows-Server                           -  enabled
                                  system.adapter.lg-thinq.0               : lg-thinq              : Windows-Server                           -  enabled
                                  system.adapter.linkeddevices.0          : linkeddevices         : Windows-Server                           -  enabled
                                  system.adapter.linux-control.0          : linux-control         : Windows-Server                           -  enabled
                                  system.adapter.logparser.0              : logparser             : Windows-Server                           -  enabled
                                  system.adapter.meteoalarm.0             : meteoalarm            : Windows-Server                           - disabled
                                  system.adapter.mytime.0                 : mytime                : Windows-Server                           - disabled
                                  system.adapter.nina.0                   : nina                  : Windows-Server                           -  enabled
                                  system.adapter.node-red.0               : node-red              : Windows-Server                           -  enabled, port: 1880, bind: 0.0.0.0
                                  system.adapter.notification-manager.0   : notification-manager  : Windows-Server                           -  enabled
                                  system.adapter.nut.0                    : nut                   : Windows-Server                           -  enabled
                                  system.adapter.octoprint.0              : octoprint             : Windows-Server                           - disabled
                                  system.adapter.parser.0                 : parser                : Windows-Server                           -  enabled
                                  system.adapter.pegelalarm.0             : pegelalarm            : Windows-Server                           -  enabled
                                  system.adapter.pegelalarm.1             : pegelalarm            : Windows-Server                           -  enabled
                                  system.adapter.pi-hole.0                : pi-hole               : Windows-Server                           -  enabled
                                  system.adapter.ping.0                   : ping                  : Windows-Server                           -  enabled
                                  system.adapter.places.0                 : places                : Windows-Server                           - disabled
                                  system.adapter.pollenflug.0             : pollenflug            : Windows-Server                           -  enabled
                                  system.adapter.proxmox.0                : proxmox               : Windows-Server                           -  enabled, port: 8006
                                  system.adapter.proxy.0                  : proxy                 : Windows-Server                           -  enabled
                                  system.adapter.rest-api.0               : rest-api              : Windows-Server                           -  enabled, port: 8093, bind: 0.0.0.0 (SSL), run as: rest
                                  system.adapter.samsung.0                : samsung               : Windows-Server                           -  enabled
                                  system.adapter.schedule-switcher.0      : schedule-switcher     : Windows-Server                           -  enabled
                                  system.adapter.seq.0                    : seq                   : Windows-Server                           -  enabled, port: 443
                                  system.adapter.shelly.0                 : shelly                : Windows-Server                           -  enabled, port: 1882, bind: 0.0.0.0
                                  system.adapter.shuttercontrol.0         : shuttercontrol        : Windows-Server                           -  enabled
                                  system.adapter.simple-api.0             : simple-api            : Windows-Server                           -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                  system.adapter.snmp.0                   : snmp                  : Windows-Server                           -  enabled
                                  system.adapter.socketio.0               : socketio              : Windows-Server                           -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                                  system.adapter.sourceanalytix.0         : sourceanalytix        : Windows-Server                           -  enabled
                                  system.adapter.switchbot-hub.0          : switchbot-hub         : Windows-Server                           -  enabled
                                  system.adapter.synology.0               : synology              : Windows-Server                           -  enabled, port: 5001
                                  system.adapter.telegram-menu.0          : telegram-menu         : Windows-Server                           -  enabled
                                  system.adapter.telegram.0               : telegram              : Windows-Server                           -  enabled, port: 8443, bind: 0.0.0.0
                                  system.adapter.telegram.1               : telegram              : Windows-Server                           - disabled, port: 8443, bind: 0.0.0.0
                                  system.adapter.tractive-gps.0           : tractive-gps          : Windows-Server                           - disabled
                                  system.adapter.trashschedule.0          : trashschedule         : Windows-Server                           -  enabled
                                  system.adapter.unifi.0                  : unifi                 : Windows-Server                           -  enabled
                                  system.adapter.vesync.0                 : vesync                : Windows-Server                           - disabled
                                  system.adapter.vis-2-widgets-collection.0: vis-2-widgets-collection: Windows-Server                           -  enabled
                                  system.adapter.vis-2.0                  : vis-2                 : Windows-Server                           -  enabled
                                  system.adapter.vis-bars.0               : vis-bars              : Windows-Server                           - disabled
                                  system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : Windows-Server                           - disabled
                                  system.adapter.vis-colorpicker.0        : vis-colorpicker       : Windows-Server                           - disabled
                                  system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : Windows-Server                           - disabled
                                  system.adapter.vis-google-fonts.0       : vis-google-fonts      : Windows-Server                           -  enabled
                                  system.adapter.vis-history.0            : vis-history           : Windows-Server                           - disabled
                                  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : Windows-Server                           - disabled
                                  system.adapter.vis-icontwo.0            : vis-icontwo           : Windows-Server                           -  enabled
                                  system.adapter.vis-inventwo.0           : vis-inventwo          : Windows-Server                           -  enabled
                                  system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : Windows-Server                           - disabled
                                  system.adapter.vis-justgage.0           : vis-justgage          : Windows-Server                           - disabled
                                  system.adapter.vis-knob.0               : vis-knob              : Windows-Server                           - disabled
                                  system.adapter.vis-map.0                : vis-map               : Windows-Server                           - disabled
                                  system.adapter.vis-material.0           : vis-material          : Windows-Server                           - disabled
                                  system.adapter.vis-materialdesign.0     : vis-materialdesign    : Windows-Server                           - disabled
                                  system.adapter.vis-metro.0              : vis-metro             : Windows-Server                           - disabled
                                  system.adapter.vis-players.0            : vis-players           : Windows-Server                           - disabled
                                  system.adapter.vis-rgraph.0             : vis-rgraph            : Windows-Server                           - disabled
                                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : Windows-Server                           - disabled
                                  system.adapter.vis-weather.0            : vis-weather           : Windows-Server                           - disabled
                                  system.adapter.vis.0                    : vis                   : Windows-Server                           -  enabled
                                  system.adapter.weather-warnings.0       : weather-warnings      : Windows-Server                           -  enabled
                                  system.adapter.weatherunderground.0     : weatherunderground    : Windows-Server                           -  enabled
                                  system.adapter.web.0                    : web                   : Windows-Server                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                  system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : Windows-Server                           -  enabled
                                  system.adapter.wireguard.0              : wireguard             : Windows-Server                           -  enabled
                                  system.adapter.xbox.0                   : xbox                  : Windows-Server                           - disabled
                                + instance is alive
                                  @gaspode
                                  Lief alles durch.
                                  + instance is alive
                                  klassisch
                                  schrieb am zuletzt editiert von klassisch
                                  #377
                                  @negalein
                                  Zugriff vom Host aus oder von einem anderen Rechner?
                                  Firewall Thema?
                                  Hatte mal sowas
                                  https://forum.iobroker.net/post/848820
                                  folgende
                                  In Defender die node.exe "App kommunizieren lassen"
                                  • K klassisch
                                    @negalein
                                    Firewall Thema?
                                    Hatte mal sowas
                                    folgende
                                    NegaleinN Offline
                                    NegaleinN Offline
                                    Negalein
                                    #378
                                    @klassisch sagte in Test ioBroker unter Windows installieren - 2023 Edition:
                                    egal von wo
                                    ist sie.
                                    Oder meinst du anders?
                                    hab jetzt noch die iobroker.exe lt. deinem Beitrag in der FW ergänzt.
                                    Dienst gestartet, aber kein Zugriff.
                                    Und CPU fast auf Anschlag.
                                      egal von wo
                                      ist sie.
                                      klassisch
                                      #379
                                      @negalein Ja, die beiden sind schon mal gut
                                      ich hatte damals noch
                                      daemon\iobroker.exe
                                      aktiviert, siehe
                                      Stimmen die Ports?
                                      https://www.wintotal.de/tipp/anzeigen-der-benutzten-tcp-ports/
                                      netstat -o
                                      Output in Editor kopieren und nach 9000 suchen
                                      Die zugehörige Taskid nehmen und mit
                                      tasklist|find „NUMMER“
                                      schauen
                                      Sieht dann bei mir gerede so aus
                                      C:\>tasklist|find "9720"
                                      node.exe                      9720 Services                   0       346.256 K
                                      K NegaleinN 2 Antworten Letzte Antwort
                                      • K klassisch
                                        daemon\iobroker.exe
                                        aktiviert, siehe
                                        Stimmen die Ports?
                                        netstat -o
                                        schauen
                                        klassisch
                                        #380
                                        Was kommt auf dem Host auf
                                        http://localhost:8081
                                        http://localhost:8082/
                                        Irgendwo https aktiviert oder sowas?
                                        • K klassisch
                                          daemon\iobroker.exe
                                          aktiviert, siehe
                                          Stimmen die Ports?
                                          netstat -o
                                          schauen
                                          NegaleinN Offline
                                          NegaleinN Offline
                                          Negalein
                                          #381
                                          normal dass so viele kommen?
                                            TCP    127.0.0.1:53775        Windows-Server:9001    HERGESTELLT     8696
                                            TCP    127.0.0.1:53776        Windows-Server:9001    HERGESTELLT     8696
                                            TCP    127.0.0.1:53777        Windows-Server:9000    HERGESTELLT     8696
                                            TCP    127.0.0.1:53778        Windows-Server:9000    HERGESTELLT     8696
                                            TCP    127.0.0.1:53782        Windows-Server:9001    HERGESTELLT     10116
                                            TCP    127.0.0.1:53783        Windows-Server:9001    HERGESTELLT     10116
                                            TCP    127.0.0.1:53784        Windows-Server:9001    HERGESTELLT     10116
                                            TCP    127.0.0.1:53785        Windows-Server:9000    HERGESTELLT     10116
                                            TCP    127.0.0.1:53786        Windows-Server:9000    HERGESTELLT     10116
                                            TCP    127.0.0.1:53787        Windows-Server:9000    HERGESTELLT     10116
                                            TCP    127.0.0.1:53813        Windows-Server:9001    HERGESTELLT     10684
                                            TCP    127.0.0.1:53814        Windows-Server:9001    HERGESTELLT     10684
                                            TCP    127.0.0.1:53815        Windows-Server:9001    HERGESTELLT     10684
                                            TCP    127.0.0.1:53816        Windows-Server:9000    HERGESTELLT     10684
                                            TCP    127.0.0.1:53817        Windows-Server:9000    HERGESTELLT     10684
                                            TCP    127.0.0.1:53818        Windows-Server:9000    HERGESTELLT     10684
                                            TCP    127.0.0.1:53821        Windows-Server:9001    HERGESTELLT     5152
                                            TCP    127.0.0.1:53825        Windows-Server:9001    HERGESTELLT     5152
                                            TCP    127.0.0.1:53826        Windows-Server:9001    HERGESTELLT     5152
                                            TCP    127.0.0.1:53828        Windows-Server:9000    HERGESTELLT     5152
                                            TCP    127.0.0.1:53829        Windows-Server:9000    HERGESTELLT     5152
                                            TCP    127.0.0.1:53830        Windows-Server:9000    HERGESTELLT     5152
                                            TCP    127.0.0.1:53852        Windows-Server:9001    HERGESTELLT     3244
                                            TCP    127.0.0.1:53853        Windows-Server:9001    HERGESTELLT     3244
                                            TCP    127.0.0.1:53854        Windows-Server:9001    HERGESTELLT     3244
                                            TCP    127.0.0.1:53855        Windows-Server:9000    HERGESTELLT     3244
                                            TCP    127.0.0.1:53856        Windows-Server:9000    HERGESTELLT     3244
                                            TCP    127.0.0.1:53857        Windows-Server:9000    HERGESTELLT     3244
                                            TCP    127.0.0.1:54103        Windows-Server:9001    HERGESTELLT     6396
                                            TCP    127.0.0.1:54104        Windows-Server:9001    HERGESTELLT     6396
                                            TCP    127.0.0.1:54105        Windows-Server:9001    HERGESTELLT     6396
                                            TCP    127.0.0.1:54106        Windows-Server:9000    HERGESTELLT     6396
                                            TCP    127.0.0.1:54107        Windows-Server:9000    HERGESTELLT     6396
                                            TCP    127.0.0.1:54108        Windows-Server:9000    HERGESTELLT     6396
                                            TCP    127.0.0.1:54109        Windows-Server:9001    HERGESTELLT     6240
                                            TCP    127.0.0.1:54110        Windows-Server:9001    HERGESTELLT     6240
                                            TCP    127.0.0.1:54111        Windows-Server:9001    HERGESTELLT     6240
                                            TCP    127.0.0.1:54112        Windows-Server:9000    HERGESTELLT     6240
                                            TCP    127.0.0.1:54113        Windows-Server:9000    HERGESTELLT     6240
                                            TCP    127.0.0.1:54114        Windows-Server:9000    HERGESTELLT     6240
                                            TCP    127.0.0.1:54116        Windows-Server:9001    HERGESTELLT     2300
                                            TCP    127.0.0.1:54117        Windows-Server:9001    HERGESTELLT     2300
                                            TCP    127.0.0.1:54118        Windows-Server:9001    HERGESTELLT     2300
                                            TCP    127.0.0.1:54119        Windows-Server:9000    HERGESTELLT     2300
                                            TCP    127.0.0.1:54120        Windows-Server:9000    HERGESTELLT     2300
                                            TCP    127.0.0.1:54121        Windows-Server:9000    HERGESTELLT     2300
                                            TCP    127.0.0.1:54127        Windows-Server:9001    HERGESTELLT     6512
                                            TCP    127.0.0.1:54128        Windows-Server:9001    HERGESTELLT     6512
                                            TCP    127.0.0.1:54129        Windows-Server:9001    HERGESTELLT     6512
                                            TCP    127.0.0.1:54130        Windows-Server:9000    HERGESTELLT     6512
                                            TCP    127.0.0.1:54131        Windows-Server:9000    HERGESTELLT     6512
                                            TCP    127.0.0.1:54132        Windows-Server:9000    HERGESTELLT     6512
                                            TCP    127.0.0.1:54405        Windows-Server:9001    HERGESTELLT     2852
                                            TCP    127.0.0.1:54406        Windows-Server:9001    HERGESTELLT     2852
                                            TCP    127.0.0.1:54407        Windows-Server:9001    HERGESTELLT     2852
                                            TCP    127.0.0.1:54408        Windows-Server:9000    HERGESTELLT     2852
                                            TCP    127.0.0.1:54409        Windows-Server:9000    HERGESTELLT     2852
                                            TCP    127.0.0.1:54410        Windows-Server:9000    HERGESTELLT     2852
                                            TCP    127.0.0.1:54482        Windows-Server:9001    HERGESTELLT     9668
                                            TCP    127.0.0.1:54483        Windows-Server:9001    HERGESTELLT     9668
                                            TCP    127.0.0.1:54484        Windows-Server:9001    HERGESTELLT     9668
                                            TCP    127.0.0.1:54485        Windows-Server:9000    HERGESTELLT     9668
                                            TCP    127.0.0.1:54486        Windows-Server:9000    HERGESTELLT     9668
                                            TCP    127.0.0.1:54487        Windows-Server:9000    HERGESTELLT     9668
                                            TCP    127.0.0.1:54488        Windows-Server:9001    HERGESTELLT     872
                                            TCP    127.0.0.1:54489        Windows-Server:9001    HERGESTELLT     872
                                            TCP    127.0.0.1:54490        Windows-Server:9001    HERGESTELLT     872
                                            TCP    127.0.0.1:54491        Windows-Server:9000    HERGESTELLT     872
                                            TCP    127.0.0.1:54492        Windows-Server:9000    HERGESTELLT     872
                                            TCP    127.0.0.1:54493        Windows-Server:9000    HERGESTELLT     872
                                            TCP    127.0.0.1:54501        Windows-Server:9001    HERGESTELLT     4260
                                            TCP    127.0.0.1:54502        Windows-Server:9001    HERGESTELLT     4260
                                            TCP    127.0.0.1:54503        Windows-Server:9001    HERGESTELLT     4260
                                            TCP    127.0.0.1:54504        Windows-Server:9000    HERGESTELLT     4260
                                            TCP    127.0.0.1:54505        Windows-Server:9000    HERGESTELLT     4260
                                            TCP    127.0.0.1:54506        Windows-Server:9000    HERGESTELLT     4260
                                            TCP    127.0.0.1:54521        Windows-Server:9001    HERGESTELLT     11096
                                            TCP    127.0.0.1:54522        Windows-Server:9001    HERGESTELLT     11096
                                            TCP    127.0.0.1:54523        Windows-Server:9001    HERGESTELLT     11096
                                            TCP    127.0.0.1:54524        Windows-Server:9000    HERGESTELLT     11096
                                            TCP    127.0.0.1:54525        Windows-Server:9000    HERGESTELLT     11096
                                            TCP    127.0.0.1:54526        Windows-Server:9000    HERGESTELLT     11096
                                            TCP    127.0.0.1:54531        Windows-Server:9001    HERGESTELLT     6116
                                            TCP    127.0.0.1:54532        Windows-Server:9001    HERGESTELLT     6116
                                            TCP    127.0.0.1:54533        Windows-Server:9001    HERGESTELLT     6116
                                            TCP    127.0.0.1:54534        Windows-Server:9000    HERGESTELLT     6116
                                            TCP    127.0.0.1:54535        Windows-Server:9000    HERGESTELLT     6116
                                            TCP    127.0.0.1:54536        Windows-Server:9000    HERGESTELLT     6116
                                            TCP    127.0.0.1:54548        Windows-Server:9001    HERGESTELLT     6552
                                            TCP    127.0.0.1:54549        Windows-Server:9001    HERGESTELLT     6552
                                            TCP    127.0.0.1:54550        Windows-Server:9001    HERGESTELLT     6552
                                            TCP    127.0.0.1:54551        Windows-Server:9000    HERGESTELLT     6552
                                            TCP    127.0.0.1:54552        Windows-Server:9000    HERGESTELLT     6552
                                            TCP    127.0.0.1:54553        Windows-Server:9000    HERGESTELLT     6552
                                            TCP    127.0.0.1:54573        Windows-Server:9001    HERGESTELLT     10364
                                            TCP    127.0.0.1:54575        Windows-Server:9001    HERGESTELLT     10364
                                            TCP    127.0.0.1:54576        Windows-Server:9001    HERGESTELLT     10364
                                            TCP    127.0.0.1:54577        Windows-Server:9000    HERGESTELLT     10364
                                            TCP    127.0.0.1:54579        Windows-Server:9000    HERGESTELLT     10364
                                            TCP    127.0.0.1:54580        Windows-Server:9000    HERGESTELLT     10364
                                            TCP    127.0.0.1:54591        Windows-Server:9001    HERGESTELLT     10932
                                            TCP    127.0.0.1:54592        Windows-Server:9001    HERGESTELLT     10932
                                            TCP    127.0.0.1:54593        Windows-Server:9001    HERGESTELLT     10932
                                            TCP    127.0.0.1:54596        Windows-Server:9000    HERGESTELLT     10932
                                            TCP    127.0.0.1:54597        Windows-Server:9000    HERGESTELLT     10932
                                            TCP    127.0.0.1:54598        Windows-Server:9000    HERGESTELLT     10932
                                            TCP    127.0.0.1:54605        Windows-Server:9001    HERGESTELLT     9296
                                            TCP    127.0.0.1:54606        Windows-Server:9001    HERGESTELLT     9296
                                            TCP    127.0.0.1:54607        Windows-Server:9001    HERGESTELLT     9296
                                            TCP    127.0.0.1:54608        Windows-Server:9000    HERGESTELLT     9296
                                            TCP    127.0.0.1:54609        Windows-Server:9000    HERGESTELLT     9296
                                            TCP    127.0.0.1:54610        Windows-Server:9000    HERGESTELLT     9296
                                            TCP    127.0.0.1:54617        Windows-Server:9001    HERGESTELLT     1868
                                            TCP    127.0.0.1:54618        Windows-Server:9001    HERGESTELLT     1868
                                            TCP    127.0.0.1:54619        Windows-Server:9001    HERGESTELLT     1868
                                            TCP    127.0.0.1:54620        Windows-Server:9000    HERGESTELLT     1868
                                            TCP    127.0.0.1:54621        Windows-Server:9000    HERGESTELLT     1868
                                            TCP    127.0.0.1:54622        Windows-Server:9000    HERGESTELLT     1868
                                            TCP    127.0.0.1:54625        Windows-Server:9001    HERGESTELLT     10084
                                            TCP    127.0.0.1:54626        Windows-Server:9001    HERGESTELLT     10084
                                            TCP    127.0.0.1:54627        Windows-Server:9001    HERGESTELLT     10084
                                            TCP    127.0.0.1:54628        Windows-Server:9000    HERGESTELLT     10084
                                            TCP    127.0.0.1:54629        Windows-Server:9000    HERGESTELLT     10084
                                            TCP    127.0.0.1:54630        Windows-Server:9000    HERGESTELLT     10084
                                            TCP    127.0.0.1:54649        Windows-Server:9001    HERGESTELLT     6600
                                            TCP    127.0.0.1:54650        Windows-Server:9001    HERGESTELLT     6600
                                            TCP    127.0.0.1:54651        Windows-Server:9001    HERGESTELLT     6600
                                            TCP    127.0.0.1:54652        Windows-Server:9000    HERGESTELLT     6600
                                            TCP    127.0.0.1:54653        Windows-Server:9000    HERGESTELLT     6600
                                            TCP    127.0.0.1:54654        Windows-Server:9000    HERGESTELLT     6600
                                            TCP    127.0.0.1:54717        Windows-Server:9001    HERGESTELLT     6576
                                            TCP    127.0.0.1:54718        Windows-Server:9001    HERGESTELLT     6576
                                            TCP    127.0.0.1:54719        Windows-Server:9001    HERGESTELLT     6576
                                            TCP    127.0.0.1:54721        Windows-Server:9000    HERGESTELLT     6576
                                            TCP    127.0.0.1:54722        Windows-Server:9000    HERGESTELLT     6576
                                            TCP    127.0.0.1:54723        Windows-Server:9000    HERGESTELLT     6576
                                            TCP    127.0.0.1:54734        Windows-Server:9001    HERGESTELLT     1940
                                            TCP    127.0.0.1:54735        Windows-Server:9001    HERGESTELLT     1940
                                            TCP    127.0.0.1:54736        Windows-Server:9001    HERGESTELLT     1940
                                            TCP    127.0.0.1:54737        Windows-Server:9000    HERGESTELLT     1940
                                            TCP    127.0.0.1:54741        Windows-Server:9000    HERGESTELLT     1940
                                            TCP    127.0.0.1:54742        Windows-Server:9000    HERGESTELLT     1940
                                            TCP    127.0.0.1:54751        Windows-Server:9001    HERGESTELLT     8788
                                            TCP    127.0.0.1:54752        Windows-Server:9001    HERGESTELLT     8788
                                            TCP    127.0.0.1:54753        Windows-Server:9001    HERGESTELLT     8788
                                            TCP    127.0.0.1:54754        Windows-Server:9000    HERGESTELLT     8788
                                            TCP    127.0.0.1:54755        Windows-Server:9000    HERGESTELLT     8788
                                            TCP    127.0.0.1:54756        Windows-Server:9000    HERGESTELLT     8788
                                            TCP    127.0.0.1:54764        Windows-Server:9001    HERGESTELLT     3652
                                            TCP    127.0.0.1:54765        Windows-Server:9001    HERGESTELLT     3652
                                            TCP    127.0.0.1:54766        Windows-Server:9001    HERGESTELLT     3652
                                            TCP    127.0.0.1:54767        Windows-Server:9000    HERGESTELLT     3652
                                            TCP    127.0.0.1:54768        Windows-Server:9000    HERGESTELLT     3652
                                            TCP    127.0.0.1:54769        Windows-Server:9000    HERGESTELLT     3652
                                            TCP    127.0.0.1:54802        Windows-Server:9001    HERGESTELLT     3412
                                            TCP    127.0.0.1:54803        Windows-Server:9001    HERGESTELLT     3412
                                            TCP    127.0.0.1:54804        Windows-Server:9001    HERGESTELLT     3412
                                            TCP    127.0.0.1:54805        Windows-Server:9000    HERGESTELLT     3412
                                            TCP    127.0.0.1:54806        Windows-Server:9000    HERGESTELLT     3412
                                            TCP    127.0.0.1:54807        Windows-Server:9000    HERGESTELLT     3412
                                            TCP    127.0.0.1:54826        Windows-Server:9001    HERGESTELLT     6612
                                            TCP    127.0.0.1:54827        Windows-Server:9001    HERGESTELLT     6612
                                            TCP    127.0.0.1:54828        Windows-Server:9001    HERGESTELLT     6612
                                            TCP    127.0.0.1:54830        Windows-Server:9000    HERGESTELLT     6612
                                            TCP    127.0.0.1:54831        Windows-Server:9000    HERGESTELLT     6612
                                            TCP    127.0.0.1:54832        Windows-Server:9000    HERGESTELLT     6612
                                            TCP    127.0.0.1:54836        Windows-Server:9001    HERGESTELLT     788
                                            TCP    127.0.0.1:54837        Windows-Server:9001    HERGESTELLT     788
                                            TCP    127.0.0.1:54838        Windows-Server:9001    HERGESTELLT     788
                                            TCP    127.0.0.1:54840        Windows-Server:9000    HERGESTELLT     788
                                            TCP    127.0.0.1:54841        Windows-Server:9000    HERGESTELLT     788
                                            TCP    127.0.0.1:54842        Windows-Server:9000    HERGESTELLT     788
                                            TCP    127.0.0.1:54884        Windows-Server:9001    HERGESTELLT     3932
                                            TCP    127.0.0.1:54885        Windows-Server:9001    HERGESTELLT     3932
                                            TCP    127.0.0.1:54886        Windows-Server:9001    HERGESTELLT     3932
                                            TCP    127.0.0.1:54887        Windows-Server:9000    HERGESTELLT     3932
                                            TCP    127.0.0.1:54888        Windows-Server:9000    HERGESTELLT     3932
                                            TCP    127.0.0.1:54889        Windows-Server:9000    HERGESTELLT     3932
                                            TCP    127.0.0.1:54907        Windows-Server:9001    HERGESTELLT     9832
                                            TCP    127.0.0.1:54908        Windows-Server:9001    HERGESTELLT     9832
                                            TCP    127.0.0.1:54909        Windows-Server:9001    HERGESTELLT     9832
                                            TCP    127.0.0.1:54910        Windows-Server:9000    HERGESTELLT     9832
                                            TCP    127.0.0.1:54911        Windows-Server:9000    HERGESTELLT     9832
                                            TCP    127.0.0.1:54912        Windows-Server:9000    HERGESTELLT     9832
                                            TCP    127.0.0.1:54923        Windows-Server:9001    HERGESTELLT     3552
                                            TCP    127.0.0.1:54924        Windows-Server:9001    HERGESTELLT     3552
                                            TCP    127.0.0.1:54926        Windows-Server:9001    HERGESTELLT     3552
                                            TCP    127.0.0.1:54930        Windows-Server:9000    HERGESTELLT     3552
                                            TCP    127.0.0.1:54931        Windows-Server:9000    HERGESTELLT     3552
                                            TCP    127.0.0.1:54932        Windows-Server:9000    HERGESTELLT     3552
                                            TCP    127.0.0.1:54959        Windows-Server:9001    HERGESTELLT     8620
                                            TCP    127.0.0.1:54960        Windows-Server:9001    HERGESTELLT     8620
                                            TCP    127.0.0.1:54961        Windows-Server:9001    HERGESTELLT     8620
                                            TCP    127.0.0.1:54962        Windows-Server:9000    HERGESTELLT     8620
                                            TCP    127.0.0.1:54963        Windows-Server:9000    HERGESTELLT     8620
                                            TCP    127.0.0.1:54964        Windows-Server:9000    HERGESTELLT     8620
                                            TCP    127.0.0.1:55031        Windows-Server:9001    HERGESTELLT     7488
                                            TCP    127.0.0.1:55032        Windows-Server:9001    HERGESTELLT     7488
                                            TCP    127.0.0.1:55033        Windows-Server:9001    HERGESTELLT     7488
                                            TCP    127.0.0.1:55034        Windows-Server:9000    HERGESTELLT     7488
                                            TCP    127.0.0.1:55035        Windows-Server:9000    HERGESTELLT     7488
                                            TCP    127.0.0.1:55036        Windows-Server:9000    HERGESTELLT     7488
                                            TCP    127.0.0.1:55066        Windows-Server:9001    HERGESTELLT     5984
                                            TCP    127.0.0.1:55068        Windows-Server:9001    HERGESTELLT     5984
                                            TCP    127.0.0.1:55069        Windows-Server:9001    HERGESTELLT     5984
                                            TCP    127.0.0.1:55074        Windows-Server:9000    HERGESTELLT     5984
                                            TCP    127.0.0.1:55075        Windows-Server:9000    HERGESTELLT     5984
                                            TCP    127.0.0.1:55076        Windows-Server:9000    HERGESTELLT     5984
                                            TCP    127.0.0.1:55103        Windows-Server:9001    HERGESTELLT     2968
                                            TCP    127.0.0.1:55104        Windows-Server:9001    HERGESTELLT     2968
                                            TCP    127.0.0.1:55105        Windows-Server:9001    HERGESTELLT     2968
                                            TCP    127.0.0.1:55107        Windows-Server:9000    HERGESTELLT     2968
                                            TCP    127.0.0.1:55108        Windows-Server:9000    HERGESTELLT     2968
                                            TCP    127.0.0.1:55109        Windows-Server:9000    HERGESTELLT     2968
                                            TCP    127.0.0.1:55364        Windows-Server:9001    HERGESTELLT     8380
                                            TCP    127.0.0.1:55367        Windows-Server:9001    HERGESTELLT     8380
                                            TCP    127.0.0.1:55368        Windows-Server:9001    HERGESTELLT     8380
                                            TCP    127.0.0.1:55369        Windows-Server:9000    HERGESTELLT     8380
                                            TCP    127.0.0.1:55370        Windows-Server:9000    HERGESTELLT     8380
                                            TCP    127.0.0.1:55371        Windows-Server:9000    HERGESTELLT     8380
                                            TCP    127.0.0.1:55418        Windows-Server:9001    HERGESTELLT     4024
                                            TCP    127.0.0.1:55420        Windows-Server:9001    HERGESTELLT     4024
                                            TCP    127.0.0.1:55421        Windows-Server:9001    HERGESTELLT     4024
                                            TCP    127.0.0.1:55422        Windows-Server:9000    HERGESTELLT     4024
                                            TCP    127.0.0.1:55423        Windows-Server:9000    HERGESTELLT     4024
                                            TCP    127.0.0.1:55424        Windows-Server:9000    HERGESTELLT     4024
                                            TCP    127.0.0.1:55450        Windows-Server:9001    HERGESTELLT     4956
                                            TCP    127.0.0.1:55451        Windows-Server:9001    HERGESTELLT     4956
                                            TCP    127.0.0.1:55452        Windows-Server:9001    HERGESTELLT     4956
                                            TCP    127.0.0.1:55454        Windows-Server:9000    HERGESTELLT     4956
                                            TCP    127.0.0.1:55455        Windows-Server:9000    HERGESTELLT     4956
                                            TCP    127.0.0.1:55456        Windows-Server:9000    HERGESTELLT     4956
                                            TCP    127.0.0.1:55652        Windows-Server:9001    HERGESTELLT     10636
                                            TCP    127.0.0.1:55653        Windows-Server:9001    HERGESTELLT     10636
                                            TCP    127.0.0.1:55654        Windows-Server:9001    HERGESTELLT     10636
                                            TCP    127.0.0.1:55661        Windows-Server:9000    HERGESTELLT     10636
                                            TCP    127.0.0.1:55663        Windows-Server:9000    HERGESTELLT     10636
                                            TCP    127.0.0.1:55664        Windows-Server:9000    HERGESTELLT     10636
                                            TCP    127.0.0.1:55803        Windows-Server:9001    HERGESTELLT     2460
                                            TCP    127.0.0.1:55805        Windows-Server:9001    HERGESTELLT     2460
                                            TCP    127.0.0.1:55806        Windows-Server:9001    HERGESTELLT     2460
                                            TCP    127.0.0.1:55809        Windows-Server:9000    HERGESTELLT     2460
                                            TCP    127.0.0.1:55812        Windows-Server:9000    HERGESTELLT     2460
                                            TCP    127.0.0.1:55813        Windows-Server:9000    HERGESTELLT     2460
                                            TCP    127.0.0.1:55931        Windows-Server:9001    HERGESTELLT     2416
                                            TCP    127.0.0.1:55932        Windows-Server:9001    HERGESTELLT     2416
                                            TCP    127.0.0.1:55933        Windows-Server:9001    HERGESTELLT     2416
                                            TCP    127.0.0.1:55934        Windows-Server:9000    HERGESTELLT     2416
                                            TCP    127.0.0.1:55937        Windows-Server:9000    HERGESTELLT     2416
                                            TCP    127.0.0.1:55938        Windows-Server:9000    HERGESTELLT     2416
                                            TCP    127.0.0.1:56050        Windows-Server:9001    HERGESTELLT     8516
                                            TCP    127.0.0.1:56051        Windows-Server:9001    HERGESTELLT     8516
                                            TCP    127.0.0.1:56052        Windows-Server:9001    HERGESTELLT     8516
                                            TCP    127.0.0.1:56055        Windows-Server:9000    HERGESTELLT     8516
                                            TCP    127.0.0.1:56056        Windows-Server:9000    HERGESTELLT     8516
                                            TCP    127.0.0.1:56057        Windows-Server:9000    HERGESTELLT     8516
                                            TCP    127.0.0.1:56163        Windows-Server:9001    HERGESTELLT     6300
                                            TCP    127.0.0.1:56164        Windows-Server:9001    HERGESTELLT     6300
                                            TCP    127.0.0.1:56165        Windows-Server:9001    HERGESTELLT     6300
                                            TCP    127.0.0.1:56167        Windows-Server:9000    HERGESTELLT     6300
                                            TCP    127.0.0.1:56171        Windows-Server:9000    HERGESTELLT     6300
                                            TCP    127.0.0.1:56172        Windows-Server:9000    HERGESTELLT     6300
                                            TCP    127.0.0.1:56206        Windows-Server:9001    HERGESTELLT     4316
                                            TCP    127.0.0.1:56207        Windows-Server:9001    HERGESTELLT     4316
                                            TCP    127.0.0.1:56208        Windows-Server:9001    HERGESTELLT     4316
                                            TCP    127.0.0.1:56210        Windows-Server:9000    HERGESTELLT     4316
                                            TCP    127.0.0.1:56211        Windows-Server:9000    HERGESTELLT     4316
                                            TCP    127.0.0.1:56212        Windows-Server:9000    HERGESTELLT     4316
                                            TCP    127.0.0.1:56347        Windows-Server:9001    HERGESTELLT     4868
                                            TCP    127.0.0.1:56350        Windows-Server:9001    HERGESTELLT     4868
                                            TCP    127.0.0.1:56351        Windows-Server:9001    HERGESTELLT     4868
                                            TCP    127.0.0.1:56355        Windows-Server:9000    HERGESTELLT     4868
                                            TCP    127.0.0.1:56358        Windows-Server:9000    HERGESTELLT     4868
                                            TCP    127.0.0.1:56359        Windows-Server:9000    HERGESTELLT     4868
                                            TCP    127.0.0.1:56368        Windows-Server:9001    HERGESTELLT     6724
                                            TCP    127.0.0.1:56369        Windows-Server:9000    HERGESTELLT     6724
                                            TCP    127.0.0.1:56370        Windows-Server:9000    HERGESTELLT     6724
                                          K 2 Antworten Letzte Antwort
