  4. Tuya. 3.17.0
Tuya. 3.17.0
55 Beiträge 11 Kommentatoren 10.8k Aufrufe 13 Beobachtet
  • O oFbEQnpoLKKl6mbY5e13
    @apollon77
    2025-01-09 09:58:41.122  - debug: tuya.0 (6579) bf37eczusfmpzprl: Use following Schema for pwogbugv2zhvbvv9: {"schema":[{"code":"switch_1","defaultValue":"","canTrigger":true,"iconname":"icon-dp_power2","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"开关1","property":{"type":"bool"},"subType":"bool","id":1,"editPermission":false}],"schemaExt":[]}
    2025-01-09 09:58:41.124  - debug: tuya.0 (6579) bf37eczusfmpzprl: Init device with data (after merge): {"data":{"accessType":1,"activeTime":1733524097,"baseAttribute":128,"cloudOnline":false,"communication":{"communicationModes":[{"pv":"","type":8},{"pv":"","type":0}],"connectionStatus":0,"dataModel":1,"mqttTopicAttr":1},"dataPointInfo":{"dpMaxTime":1733524097194,"dpName":{},"dps":{"1":false},"dpsTime":{"1":1733524097194}},"devAttribute":0,"devId":"bf37eczusfmpzprl","devKey":"","deviceTopo":{},"iconUrl":"https://images.tuyaeu.com/smart/icon/ay1553676862206wvxjp/88217e1500025e67acc2007d12d53e93.png","lat":"52.04","localKey":"1/9?*[<agEIafXVL","lon":"10.31","mac":"","meta":{},"name":"Sengled Wi-Fi Plug","otaInfo":{"otaModuleMap":{},"otaUpgradeModes":[0],"supportAuto":true},"ownerId":"151918892","productId":"pwogbugv2zhvbvv9","runtimeEnv":"prod","timezoneId":"Europe/Berlin","uuid":"bf37eczusfmpzprl","virtual":false,"virtualExperience":false,"dpName":{},"groudId":151918892,"schema":[{"code":"switch_1","defaultValue":"","canTrigger":true,"iconname":"icon-dp_power2","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"开关1","property":{"type":"bool"},"subType":"bool","id":1,"editPermission":false}],"productKey":"pwogbugv2zhvbvv9","schemaExt":[],"version":"","dpCodes":{"switch_1":{"code":"switch_1","defaultValue":"","canTrigger":true,"iconname":"icon-dp_power2","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"开关1","property":{"type":"bool"},"subType":"bool","id":1,"editPermission":false}}},"errorcount":0,"localKey":"1/9?*[<agEIafXVL","name":"Sengled Wi-Fi Plug","dpIdList":[1],"objectsInitialized":true,"noLocalConnection":false}
    2025-01-09 09:58:41.135  - debug: tuya.0 (6579) bf37eczusfmpzprl: Create device objects if not exist
    2025-01-09 09:58:41.137  - debug: tuya.0 (6579) bf37eczusfmpzprl: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_1","id":1,"role":"switch","native":{"code":"switch_1","defaultValue":"","canTrigger":true,"iconname":"icon-dp_power2","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"开关1","property":{"type":"bool"},"subType":"bool","id":1,"editPermission":false}}]
    2025-01-09 09:58:41.139  - debug: tuya.0 (6579) bf37eczusfmpzprl Register onChange for 1
    2025-01-09 09:58:41.140  - debug: tuya.0 (6579) Initial cloud device sync done
    @ofbeqnpolkkl6mby5e13 Was soll mir das Log zeigen?
    O 1 Antwort Letzte Antwort
    • apollon77A apollon77
      O Abwesend
      O Abwesend
      @apollon77
      Keine Ahnung, mehr gibt das Log für das Gerät halt nicht her. Vergessen wir das.
        @apollon77
        @ofbeqnpolkkl6mby5e13 Da sollte mehr kommen ... sonst hast du ein DNS problem :-) Aber ggf sind das generellere logs ohne die Devcie ID
          padrinoP Offline
          padrinoP Offline
          padrino
          schrieb am zuletzt editiert von padrino
          also, ich kann nur sagen, dass ich eine recht alte Hama "Birne" habe, die heute Nacht einfach aufgehört hat über den 20/switch_led DP zu funktionieren.🤷
          Neustart und neue Synchronisation mit Cloud und DP/Baum löschen hat nix gebracht.
          Hab' nun die Beta gefunden und installiert, und taddaa, läuft wieder - auch einfach so. 😌
          Ich sag da mal danke. =)
          • padrinoP padrino
            @padrino
            Ja, hatte ich auch schon, und seit Anfang des Jahres gehen viele Devices auch einfach so offline..
            Fazit: im laufe des Jahres fliegt der Tuya Kram raus..
              @padrino
              padrinoP Offline
              padrinoP Offline
              padrino
              @ilovegym sagte in Tuya. 3.17.0:
              @padrino
              Ist doch irgendwie seltsam, dass die offline gehen, wenn sie von der Cloud entkoppelt sind, da kann doch "von außen" keiner Schuld sein, gibt ja auch kein Firmware Update...
              • padrinoP padrino
                @padrino
                @padrino Naja oder auch nicht ... es gab einige Geräte die ständig abgestürzt sind wenn Cloud weg war. Am Ende wissen die das ja nicht und versuchen ständig in die Cloud zu verbinden ... denke das sowas ggf auch issues triggert weil die glaube ich in so einem Umfeld nicht getstet werden :-)
                  @apollon77
                  das kann gut sein, seitdem ich meine wieder der Cloud zugaenglich gemacht habe, sind sie oefters online.. oder funktionieren sogar, wenn sie als offline angezeigt werden... versteh das manchmal nicht.. aber ich muss ja nicht alles wissen .. "D
                    Aktuelle Test Version 3.17.0
                    Veröffentlichungsdatum 08.01.2025
                    Halli Hallo an alle Tuya-Freunde,
                    heute gibt es den Tuya Adapter in 3.17.0 als Beta. Der Adapter bringt Unterstützung für Geräte mit Tuya Protokoll 3.5 und behebt einige Issues die durch Änderungen von Tuya verursacht wurden. Mit Unterstützung von @simatec wurde der Adapter auch etwas mehr Responsive.
                    Details:
                    • Added support for Tuya 3.5 devices
                    • Fixed several errors report by Sentry
                    • Tried to reduce memory usage by only loading Schema definitions when needed and giving memory free afterward
                    • More schema information were added/updated
                    • Added enhanced logic for AC/DC states and generalized it for more devices
                    • Fixed raw data parsing for some devices
                    • Adjusted special handling for TempSet, TempCurrent and FloorTemp states to return correct values
                    • Responsive Design added
                    Bitte meldet alle Probleme hier bzw auf GitHub.
                    Ingo
                    M Online
                    M Online
                    michihorn
                    @apollon77 Hallöchen ich habe eine Installation bei der wird das TUYA Kennwort immer wieder vergessen.
                    Also das Feld "Kennwort" ist dann einfach leer.
                    Michael
                    • M michihorn
                      Michael
                      @michihorn
                      Hello, prima, meine Glaskugel sagt, dass da dann was nicht stimmt.
                      Fuer mal in der Console "iob diag" aus, und poste die Ausgabe in Code-Tags, bitte.
                        @michihorn
                        M Online
                        M Online
                        michihorn
                        @ilovegym ;-) da hat die Glaskugel recht, leider kann ich den Fehler aktuell nicht präsentieren. Seit Samstag läuft der Adapter. Das bedeutet nicht, das alle OK ist, kann sein, dass in ein Paar Tagen ohne Hinweis, das Kennwort wieder weg ist. Hatte ich nun schon ein paar mal. Ich habe jetzt erstmal im LOG "silly" eingestellt. Mal schauen ob das was zu shen ist.
                        • M michihorn
                          @michihorn
                          Hi, nein, von silly hat keiner was gesagt.
                          Erstmal ein iob diag, damit man mal weiss, um was es ueberhaupt geht.
                          Wenn der Adapter geht, muss das pw ja gespeichert sein, sofern du ihn auch neu gestartet hast.
                          Vielleicht wird es nur nicht im Admin angezeigt. Aber dazu braucht man erstmal ein iob diag.
                            @michihorn
                            M Online
                            M Online
                            michihorn
                            schrieb am zuletzt editiert von michihorn
                            @ilovegym Aktuell habe ich keine Probleme, der IOB steht in meinem Ferienhaus, wenn ich Freitag dorthin fahre, werden über GEOFANCY einige Aktionen von TUYA Geräten erwartet. Letzten Freitag war es auch so, IOB hat meine Anreise erkannt, Tuya-Thermostat sollte hochregeln, Auf dem Parkplatz angekommen, sollte die Gartenbeleuchtung und Flurbeleuchtung angehen. IOB hat auch die entsprechenden Tuya Geräte angesprochen, aber es erfolgte keine Auslösung weil das Cloud-Passwort verschwunden war. Anbei ein Bild so wie es gerade aussieht.
                            ```bash
                            Script v.2025-02-02
                            *** BASE SYSTEM ***
                               Static hostname: iobroker-pi
                                     Icon name: computer
                              Operating System: Raspbian GNU/Linux 11 (bullseye)
                                        Kernel: Linux 6.1.21-v8+
                                  Architecture: arm64
                            OS is similar to: debian
                            Model           : Raspberry Pi 4 Model B Rev 1.5
                            Docker          : false
                            Virtualization  : none
                            Kernel          : aarch64
                            Userland        : 32 bit
                            Systemuptime and Load:
                             13:02:09 up 16 days, 15:31,  1 user,  load average: 0.59, 0.45, 0.45
                            CPU threads: 4
                            *** LIFE CYCLE STATUS ***
                            Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
                            *** RASPBERRY THROTTLING ***
                            Current issues:
                            Previously detected issues:
                            ~ Under-voltage has occurred
                            ~ Arm frequency capping has occurred
                            *** TIME AND TIMEZONES ***
                                           Local time: Mon 2025-02-10 13:02:09 CET
                                       Universal time: Mon 2025-02-10 12:02:09 UTC
                                             RTC time: n/a
                                            Time zone: Europe/Amsterdam (CET, +0100)
                                          NTP service: active
                                      RTC in local TZ: no
                            *** Users and Groups ***
                            User that called 'iob diag':
                            gthrn
                            HOME=/home/gthrn
                            GROUPS=gthrn adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                            iobroker
                            HOME=/home/iobroker
                            *** DISPLAY-SERVER SETUP ***
                            Display-Server: false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:            7.9G        1.6G        4.5G        1.0M        1.8G        6.2G
                            Swap:            99M          0B         99M
                            Total:          8.0G        1.6G        4.6G
                            Active iob-Instances:   21
                                     7862 M total memory
                                     1566 M used memory
                                     1658 M active memory
                                     1521 M inactive memory
                                     4482 M free memory
                                      147 M buffer memory
                                     1665 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            top - 13:02:10 up 16 days, 15:31,  1 user,  load average: 0.59, 0.45, 0.45
                            Tasks: 166 total,   1 running, 165 sleeping,   0 stopped,   0 zombie
                            %Cpu(s):  0.0 us,  4.3 sy,  0.0 ni, 95.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                            MiB Mem :   7862.2 total,   4482.4 free,   1566.7 used,   1813.1 buff/cache
                            MiB Swap:    100.0 total,    100.0 free,      0.0 used.   6164.5 avail Mem
                            *** FAILED SERVICES ***
                            0 loaded units listed.
                            *** DMESG CRITICAL ERRORS ***
                            140 CRITICAL ERRORS DETECTED!
                            Check 'sudo dmesg --level=emerg,alert,crit -T' for details
                            *** FILESYSTEM ***
                            /dev/root      ext4       59G   11G   46G  19% /
                            devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                            tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                            tmpfs          tmpfs     1.6G  1.1M  1.6G   1% /run
                            /dev/sda1      vfat      255M   51M  205M  20% /boot
                            tmpfs          tmpfs     787M     0  787M   0% /run/user/1000
                            [Fri Jan 24 21:30:22 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:DE:B0:AA vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=ttyS0,115200 console=tty1 root=PARTUUID=c7239adf-02 rootfstype=ext4 fsck.repair=yes rootwait
                            [Fri Jan 24 21:30:25 2025] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
                            [Fri Jan 24 21:30:25 2025] EXT4-fs (sda2): write access will be enabled during recovery
                            [Fri Jan 24 21:30:26 2025] EXT4-fs (sda2): orphan cleanup on readonly fs
                            [Fri Jan 24 21:30:26 2025] EXT4-fs (sda2): 3 orphan inodes deleted
                            [Fri Jan 24 21:30:26 2025] EXT4-fs (sda2): recovery complete
                            [Fri Jan 24 21:30:26 2025] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                            [Fri Jan 24 21:30:26 2025] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                            [Fri Jan 24 21:30:30 2025] EXT4-fs (sda2): re-mounted. Quota mode: none.
                            Show mounted filesystems:
                            TARGET  SOURCE    FSTYPE OPTIONS
                            /       /dev/sda2 ext4   rw,noatime
                            `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                            /var:
                            1.4G    /var/
                            763M    /var/log
                            761M    /var/log/journal/3f7e426fbacf414fbfbc4f1541fa25b4
                            451M    /var/cache
                            Archived and active journals take up 760.2M in the file system.
                            /opt/iobroker/backups:
                            1.3G    /opt/iobroker/backups/
                            4.0K    /opt/iobroker/backups/zigbee_0
                            /opt/iobroker/iobroker-data:
                            588M    /opt/iobroker/iobroker-data/
                            424M    /opt/iobroker/iobroker-data/files
                            158M    /opt/iobroker/iobroker-data/files/admin.admin
                            157M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                            19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.6964fae2.js.map
                            15M     /opt/iobroker/iobroker-data/objects.jsonl
                            14M     /opt/iobroker/iobroker-data/states.jsonl
                            7.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.6964fae2.js
                            7.4M    /opt/iobroker/iobroker-data/files/javascript.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_icons-material_esm_index_js.3514cab0.chunk.js.map
                            USB-Devices by-id:
                            No Devices found 'by-id'
                            HINT:
                            Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                            tcp
                            *** NodeJS-Installation ***
                            /usr/bin/nodejs         v20.18.1
                            /usr/bin/node           v20.18.1
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            /usr/bin/corepack       0.29.4
                            nodejs:
                              Installed: 20.18.1-1nodesource1
                              Candidate: 20.18.1-1nodesource1
                              Version table:
                             *** 20.18.1-1nodesource1 600
                                    500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                                 20.18.0-1nodesource1 600
                                 20.17.0-1nodesource1 600
                                 20.16.0-1nodesource1 600
                                 20.15.1-1nodesource1 600
                                 20.15.0-1nodesource1 600
                                 20.14.0-1nodesource1 600
                                 20.13.1-1nodesource1 600
                                 20.13.0-1nodesource1 600
                                 20.12.2-1nodesource1 600
                                 20.12.1-1nodesource1 600
                                 20.12.0-1nodesource1 600
                                 20.11.1-1nodesource1 600
                                 20.11.0-1nodesource1 600
                                 20.10.0-1nodesource1 600
                                 20.9.0-1nodesource1 600
                                 20.8.1-1nodesource1 600
                                 20.8.0-1nodesource1 600
                                 20.7.0-1nodesource1 600
                                 20.6.1-1nodesource1 600
                                 20.6.0-1nodesource1 600
                                 20.5.1-1nodesource1 600
                                 20.5.0-1nodesource1 600
                                 20.4.0-1nodesource1 600
                                 20.3.1-1nodesource1 600
                                 20.3.0-1nodesource1 600
                                 20.2.0-1nodesource1 600
                                 20.1.0-1nodesource1 600
                                 20.0.0-1nodesource1 600
                                 12.22.12~dfsg-1~deb11u5 500
                            No problems detected
                            Errors in npm tree: 0
                            *** ioBroker-Installation ***
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            GTHRN-pi            GTHRN-pi (version: 7.0.6, hostname: GTHRN-pi      , alive, uptime: 1438305)
                            Core adapters versions
                            js-controller:  7.0.6
                            admin:          7.4.21
                            javascript:     8.9.1
                            nodejs modules from github:     4
                            +-- iobroker.device-watcher@2.12.1 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.device-watcher.git#fb49d0b7d1af160318904a143bcea7cab85764c4)
                            +-- iobroker.telegram@4.0.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.telegram.git#b4cfff1fa1dadc8a33905f86208d3b5319c1e585)
                            +-- iobroker.tuya@3.17.0 (git+ssh://git@github.com/Apollon77/ioBroker.tuya.git#007d61f5c03c1150dcf67d40f5967e651caf776c)
                            +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
                            Adapter State
                            + system.adapter.admin.0                  : admin                 : GTHRN-pi                                 -  enabled, compact disabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                            + system.adapter.backitup.0               : backitup              : GTHRN-pi                                 -  enabled, compact disabled
                              system.adapter.daikin.0                 : daikin                : GTHRN-pi                                 - disabled, compact disabled
                              system.adapter.daswetter.0              : daswetter             : GTHRN-pi                                 -  enabled, compact disabled
                            + system.adapter.device-watcher.0         : device-watcher        : GTHRN-pi                                 -  enabled, compact disabled
                            + system.adapter.espresense.0             : espresense            : GTHRN-pi                                 -  enabled, compact disabled
                              system.adapter.feiertage.0              : feiertage             : GTHRN-pi                                 -  enabled, compact disabled
                            + system.adapter.fullybrowser.0           : fullybrowser          : GTHRN-pi                                 -  enabled, compact disabled
                            + system.adapter.history.0                : history               : GTHRN-pi                                 -  enabled, compact disabled
                            + system.adapter.hue.0                    : hue                   : GTHRN-pi                                 -  enabled, compact disabled, port: 443
                              system.adapter.icons-material-png.0     : icons-material-png    : GTHRN-pi                                 - disabled
                              system.adapter.icons-material-svg.0     : icons-material-svg    : GTHRN-pi                                 - disabled
                              system.adapter.icons-mfd-png.0          : icons-mfd-png         : GTHRN-pi                                 - disabled
                              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : GTHRN-pi                                 - disabled
                            + system.adapter.iot.0                    : iot                   : GTHRN-pi                                 -  enabled, compact disabled
                            + system.adapter.iot.1                    : iot                   : GTHRN-pi                                 -  enabled, compact disabled
                            + system.adapter.iot.2                    : iot                   : GTHRN-pi                                 -  enabled, compact disabled
                            + system.adapter.javascript.0             : javascript            : GTHRN-pi                                 -  enabled, compact disabled
                            + system.adapter.mqtt-client.2            : mqtt-client           : GTHRN-pi                                 -  enabled, compact disabled, port: 3075
                            + system.adapter.mqtt.2                   : mqtt                  : GTHRN-pi                                 -  enabled, compact disabled, port: 3075, bind: 0.0.0.0
                            + system.adapter.ping.0                   : ping                  : GTHRN-pi                                 -  enabled, compact disabled
                            + system.adapter.ring.0                   : ring                  : GTHRN-pi                                 -  enabled, compact disabled
                            + system.adapter.telegram.0               : telegram              : GTHRN-pi                                 -  enabled, compact disabled, port: 8443, bind: 0.0.0.0
                            + system.adapter.tuya.0                   : tuya                  : GTHRN-pi                                 -  enabled, compact disabled
                              system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : GTHRN-pi                                 - disabled
                              system.adapter.vis-google-fonts.0       : vis-google-fonts      : GTHRN-pi                                 -  enabled, compact disabled
                              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : GTHRN-pi                                 - disabled
                              system.adapter.vis-icontwo.0            : vis-icontwo           : GTHRN-pi                                 - disabled, compact disabled
                            + system.adapter.vis-inventwo.0           : vis-inventwo          : GTHRN-pi                                 -  enabled, compact disabled
                              system.adapter.vis-keyboard.0           : vis-keyboard          : GTHRN-pi                                 - disabled
                              system.adapter.vis-metro.0              : vis-metro             : GTHRN-pi                                 - disabled
                              system.adapter.vis-timeandweather.0     : vis-timeandweather    : GTHRN-pi                                 - disabled
                              system.adapter.vis.0                    : vis                   : GTHRN-pi                                 -  enabled, compact disabled
                            + system.adapter.web.0                    : web                   : GTHRN-pi                                 -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
                            + system.adapter.zigbee.0                 : zigbee                : GTHRN-pi                                 -  enabled, compact disabled, port: tcp://192.168.188.120:6638
                            + instance is alive
                            ioBroker-Repositories
                            Active repo(s): beta
                            Upgrade policy: none
                            Installed ioBroker-Instances
                            Used repository: beta
                            Adapter    "admin"        : 7.4.21   , installed 7.4.21
                            Adapter    "backitup"     : 3.0.31   , installed 3.0.31
                            Adapter    "daikin"       : 1.4.2    , installed 1.4.2
                            Adapter    "daswetter"    : 3.2.2    , installed 3.2.2
                            Adapter    "device-watcher": 2.12.1  , installed 2.12.1
                            Adapter    "espresense"   : 0.6.3    , installed 0.6.3
                            Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
                            Adapter    "fullybrowser" : 3.0.13   , installed 3.0.13
                            Adapter    "hue"          : 3.14.1   , installed 3.14.1
                            Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                            Adapter    "iot"          : 3.4.5    , installed 3.4.5
                            Adapter    "javascript"   : 8.9.1    , installed 8.9.1
                            Controller "js-controller": 7.0.6    , installed 7.0.6
                            Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                            Adapter    "mqtt-client"  : 3.0.0    , installed 2.1.0  [Updatable]
                            Adapter    "ping"         : 1.7.9    , installed 1.7.9
                            Adapter    "ring"         : 6.3.0    , installed 6.3.0
                            Adapter    "socketio"     : 7.0.0    , installed 6.7.1  [Updatable]
                            Adapter    "telegram"     : 4.0.0    , installed 4.0.0
                            Adapter    "tuya"         : 3.17.0   , installed 3.17.0
                            Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
                            Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                            Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                            Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
                            Adapter    "web"          : 6.3.1    , installed 6.3.1
                            Adapter    "ws"           : 3.0.1    , installed 2.6.2  [Updatable]
                            Adapter    "zigbee"       : 1.10.14  , installed 1.10.14
                            Objects and States
                            Objects:        6671
                            States:         5793
                            Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                            Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                            Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
                            Reading package lists...
                            Pending Updates: 25
                            *** Listening Ports ***
                            tcp        0      0 0.0.0.0:3075            0.0.0.0:*               LISTEN      1001       15868      1189/io.mqtt.2
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14125      489/iobroker.js-con
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12785      489/iobroker.js-con
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1889       517/sshd: /usr/sbin
                            tcp6       0      0 :::3001                 :::*                    LISTEN      1001       16749      1222/io.fullybrowse
                            tcp6       0      0 :::3030                 :::*                    LISTEN      1001       2653440    9688/io.espresense.
                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       18441      1239/io.web.0
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       2652026    9576/io.admin.0
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          1891       517/sshd: /usr/sbin
                            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1906       695/dhcpcd
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13907      373/avahi-daemon: r
                            udp        0      0 0.0.0.0:50523           0.0.0.0:*                           108        13909      373/avahi-daemon: r
                            udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       2659021    10456/io.tuya.0
                            udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       2659022    10456/io.tuya.0
                            udp6       0      0 :::546                  :::*                                0          115745     695/dhcpcd
                            udp6       0      0 :::5353                 :::*                                108        13908      373/avahi-daemon: r
                            udp6       0      0 :::39322                :::*                                108        13910      373/avahi-daemon: r
                            2025-02-10 13:00:53.082  - info: daswetter.0 (18166) starting. Version 3.2.2 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.1, js-controller: 7.0.6
                            2025-02-10 13:01:07.031  - info: javascript.0 (28533) script.js.SYSTEM.Devicewatcher_status_an_loggger: true
                            2025-02-10 13:01:11.150  - info: daswetter.0 (18166) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                            2025-02-10 13:01:11.670  - info: daswetter.0 (18166) cleaned everything up...
                            2025-02-10 13:01:11.689  - info: host.GTHRN-pi instance system.adapter.daswetter.0 having pid 18166 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2025-02-10 13:01:22.032  - info: javascript.0 (28533) script.js.SYSTEM.Devicewatcher_status_an_loggger: true
                            2025-02-10 13:01:37.031  - info: javascript.0 (28533) script.js.SYSTEM.Devicewatcher_status_an_loggger: true
                            2025-02-10 13:01:52.034  - info: javascript.0 (28533) script.js.SYSTEM.Devicewatcher_status_an_loggger: true
                            2025-02-10 13:02:00.052  - info: javascript.0 (28533) script.js.SYSTEM.Temp_CPU: 38.4°C
                            2025-02-10 13:02:07.035  - info: javascript.0 (28533) script.js.SYSTEM.Devicewatcher_status_an_loggger: true
                            2025-02-10 13:02:22.037  - info: javascript.0 (28533) script.js.SYSTEM.Devicewatcher_status_an_loggger: true
                            2025-02-10 13:02:37.042  - info: javascript.0 (28533) script.js.SYSTEM.Devicewatcher_status_an_loggger: true
                            2025-02-10 13:02:56.454  - info: javascript.0 (28533) script.js.SYSTEM.Devicewatcher_status_an_loggger: true
                            2025-02-10 13:03:07.041  - info: javascript.0 (28533) script.js.SYSTEM.Devicewatcher_status_an_loggger: true
                            2025-02-10 13:03:07.163  - info: admin.0 (9576) <== Disconnect system.user.admin from ::ffff:192.168.178.196 admin
                            2025-02-10 13:03:16.659  - info: admin.0 (9576) ==> Connected system.user.admin from ::ffff:192.168.178.196
                            2025-02-10 13:03:22.044  - info: javascript.0 (28533) script.js.SYSTEM.Devicewatcher_status_an_loggger: true
                            2025-02-10 13:03:24.803  - warn: host.GTHRN-pi Could not check for new OS updates: Command failed: sudo apt list --upgradeable
                            WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
                            E: Problem renaming the file /var/cache/apt/pkgcache.bin.2vsJAl to /var/cache/apt/pkgcache.bin - rename (2: No such file or directory)
                            W: You may want to run apt-get update to correct these problems
                            E: The package cache file is corrupted
                            LatziL ? Thomas BraunT U 4 Antworten Letzte Antwort
                            • M michihorn
                              ```bash
                              Script v.2025-02-02
                              *** BASE SYSTEM ***
                                       Icon name: computer
                                    Architecture: arm64
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : 32 bit
                              CPU threads: 4
                              Current issues:
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              gthrn
                              HOME=/home/gthrn
                              iobroker
                              HOME=/home/iobroker
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Swap:            99M          0B         99M
                                       7862 M total memory
                                       1566 M used memory
                                       4482 M free memory
                                        147 M buffer memory
                                       1665 M swap cache
                                         99 M total swap
                                          0 M used swap
                                         99 M free swap
                              *** FILESYSTEM ***
                              /var:
                              1.4G    /var/
                              763M    /var/log
                              451M    /var/cache
                              USB-Devices by-id:
                              HINT:
                              tcp
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              nodejs:
                                Version table:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Hosts:
                              admin:          7.4.21
                              javascript:     8.9.1
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        6671
                              States:         5793
                              Pending Updates: 25
                              LatziL Online
                              LatziL Online
                              Latzi
                              @michihorn
                              du hast da einige Adapter von github installiert (unter anderem tuya), den gibt es auch im lastest:
                              github:	3.17.0
                              latest:	3.17.0 for 32 days
                              stable:	3.16.0 for 5 months
                              Von github nur nach Absprache mit dem Entwickler installieren ;-)
                              • M michihorn
                                ```bash
                                Script v.2025-02-02
                                *** BASE SYSTEM ***
                                         Icon name: computer
                                      Architecture: arm64
                                Docker          : false
                                Kernel          : aarch64
                                Userland        : 32 bit
                                CPU threads: 4
                                Current issues:
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                gthrn
                                HOME=/home/gthrn
                                iobroker
                                HOME=/home/iobroker
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Swap:            99M          0B         99M
                                         7862 M total memory
                                         1566 M used memory
                                         4482 M free memory
                                          147 M buffer memory
                                         1665 M swap cache
                                           99 M total swap
                                            0 M used swap
                                           99 M free swap
                                *** FILESYSTEM ***
                                /var:
                                1.4G    /var/
                                763M    /var/log
                                451M    /var/cache
                                USB-Devices by-id:
                                HINT:
                                tcp
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                nodejs:
                                  Version table:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                Hosts:
                                admin:          7.4.21
                                javascript:     8.9.1
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        6671
                                States:         5793
                                Pending Updates: 25
                                @michihorn
                                Danke, jetzt kann man Hilfe leisten. Ich vermute mal zu 90% liegt das am aktuell von dir installierten Admin-Adapter V7.4.21, der hat seit ner Zeit n Bug bei der Eingabe in die Felder.. gibt auch n Issue zu.
                                Bei Einsatz von Beta Versionen besser immer die Issues dazu lesen, oder, in der Gartenhuette, erst gar nicht einsetzen.
                                Da lieber mit den Versionen auf Stable bleiben, die heissen ja nicht zufaellig Stable..
                                • M michihorn
                                  ```bash
                                  Script v.2025-02-02
                                  *** BASE SYSTEM ***
                                           Icon name: computer
                                        Architecture: arm64
                                  Docker          : false
                                  Kernel          : aarch64
                                  Userland        : 32 bit
                                  CPU threads: 4
                                  Current issues:
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  gthrn
                                  HOME=/home/gthrn
                                  iobroker
                                  HOME=/home/iobroker
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Swap:            99M          0B         99M
                                           7862 M total memory
                                           1566 M used memory
                                           4482 M free memory
                                            147 M buffer memory
                                           1665 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  *** FILESYSTEM ***
                                  /var:
                                  1.4G    /var/
                                  763M    /var/log
                                  451M    /var/cache
                                  USB-Devices by-id:
                                  HINT:
                                  tcp
                                  /usr/bin/npm            10.8.2
                                  /usr/bin/npx            10.8.2
                                  nodejs:
                                    Version table:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Hosts:
                                  admin:          7.4.21
                                  javascript:     8.9.1
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        6671
                                  States:         5793
                                  Pending Updates: 25
                                  @michihorn
                                  Und losgelöst vom tuya solltest du die Kiste eh mal neuaufsetzen.
                                  Als RaspberryOS 12 'Bookworm' in der 64Bit-Version.
                                  Vielleicht erledigen sich dann diese Fehler:
                                  In den Paket-Quellen fehlt das security-Repo. Und der cache ist auch krumm:
                                    @michihorn
                                    M Online
                                    M Online
                                    michihorn
                                    @thomas-braun sagte in Tuya. 3.17.0:
                                    Wie kann ich das fixen?
                                    Thomas BraunT ? 2 Antworten Letzte Antwort
                                    • M michihorn
                                      @michihorn
                                      Sinnvoll? Per kompletter Neuinstallation, die du ja ohnehin machen musst.
                                      • M michihorn
                                        @michihorn
                                        Haste noch n Raspi zuhause? Dann zieh dir n Backup vom iobroker aus der Gartenhuette, setz zuhause n neuen mit Bookworm auf, restore deine Daten und mit der fertigen SD Karte gehste dann in die Gartenhuette und tauschst die aus.
                                        Ich wuerd an dem alten Bullseye nicht mehr rumdoktern. Solange der noch laeuft ist ja gut, aber ich wuerde die Zeit nutzen und die Konfig (ich denke, du hast da mehr als iobroker drauf?) neu aufsetzen.
                                        • M michihorn
                                          ```bash
                                          Script v.2025-02-02
                                          *** BASE SYSTEM ***
                                                   Icon name: computer
                                                Architecture: arm64
                                          Docker          : false
                                          Kernel          : aarch64
                                          Userland        : 32 bit
                                          CPU threads: 4
                                          Current issues:
                                                           RTC time: n/a
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          gthrn
                                          HOME=/home/gthrn
                                          iobroker
                                          HOME=/home/iobroker
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Swap:            99M          0B         99M
                                                   7862 M total memory
                                                   1566 M used memory
                                                   4482 M free memory
                                                    147 M buffer memory
                                                   1665 M swap cache
                                                     99 M total swap
                                                      0 M used swap
                                                     99 M free swap
                                          *** FILESYSTEM ***
                                          /var:
                                          1.4G    /var/
                                          763M    /var/log
                                          451M    /var/cache
                                          USB-Devices by-id:
                                          HINT:
                                          tcp
                                          /usr/bin/npm            10.8.2
                                          /usr/bin/npx            10.8.2
                                          nodejs:
                                            Version table:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Hosts:
                                          admin:          7.4.21
                                          javascript:     8.9.1
                                          Adapter State
                                          + instance is alive
                                          Objects and States
                                          Objects:        6671
                                          States:         5793
                                          Pending Updates: 25
                                          U Offline
                                          U Offline
                                          Urs
                                          Hab mir den Tuya Adapter installiert und funktioniert soweit auch, das obwohl der Adapter anzeigt dass er nicht verbunden sei:
                                          Ich vermute mal dass das damit zusammen hängt dass das Tuya Gerät (Heizofen zum Frostschutz) in einem entfernten Netzwerk liegt und somit die Daten nur über die Cloud kommen.
                                          Irgendwie hat die Vergangenheit gezeigt dass es eine sehr schlechte Idee ist auf Cloud Lösungen in welcher Form auch immer zu setzen das letzte mal letzte Woche) darum die Frage: Wie wahrscheinlich ist es dass der Tuya Adapter in Zukunft Geräte ansprechen kann welche in einem anderen Netzwerk leben und über eine VPN-Verbindung (Wireguard) mit dem Netzwerk in dem Iobroker lebt verbunden ist? Mein Iobroker ist z. B. in 192.168.1.x und das Tuya Gerät in 10.10.100.x wo noch weitere Geräte Daten an Iobroker senden (z. B. KNX, MQTT...)
                                          Vielen Dank
                                          ? apollon77A 2 Antworten Letzte Antwort
