  4. Tuya. 3.17.0
Tuya. 3.17.0
55 Beiträge 11 Kommentatoren 10.8k Aufrufe 13 Beobachtet
  • apollon77A apollon77
    @ofbeqnpolkkl6mby5e13 naja kannst am Ende mal Debug log an machen dann siehst Du ob er die geräte findet oder ob er was findet aber nicht zuordnen kann ...
    O Abwesend
    O Abwesend
    oFbEQnpoLKKl6mbY5e13
    @apollon77
    Hoffe, das reicht:
    2025-01-09 09:58:35.866  - debug: tuya.0 (6579) bf37eczusfmpzprl: Init device with data (after merge): {"data":{"accessType":1,"activeTime":1733524097,"baseAttribute":128,"cloudOnline":false,"communication":{"communicationModes":[{"pv":"","type":8},{"pv":"","type":0}],"connectionStatus":0,"dataModel":1,"mqttTopicAttr":1},"dataPointInfo":{"dpMaxTime":1733524097194,"dpName":{},"dps":{"1":false},"dpsTime":{"1":1733524097194}},"devAttribute":0,"devId":"bf37eczusfmpzprl","devKey":"","deviceTopo":{},"iconUrl":"https://images.tuyaeu.com/smart/icon/ay1553676862206wvxjp/88217e1500025e67acc2007d12d53e93.png","lat":"52.04","localKey":"1/9?*[<agEIafXVL","lon":"10.31","mac":"","meta":{},"name":"Sengled Wi-Fi Plug","otaInfo":{"otaModuleMap":{},"otaUpgradeModes":[0],"supportAuto":true},"ownerId":"151918892","productId":"pwogbugv2zhvbvv9","runtimeEnv":"prod","timezoneId":"Europe/Berlin","uuid":"bf37eczusfmpzprl","virtual":false,"virtualExperience":false,"dpName":{},"groudId":151918892,"schema":[{"code":"switch_1","defaultValue":"","canTrigger":true,"iconname":"icon-dp_power2","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"开关1","property":{"type":"bool"},"subType":"bool","id":1,"editPermission":false}],"productKey":"pwogbugv2zhvbvv9","schemaExt":[],"version":"","dpCodes":{"switch_1":{"code":"switch_1","defaultValue":"","canTrigger":true,"iconname":"icon-dp_power2","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"开关1","property":{"type":"bool"},"subType":"bool","id":1,"editPermission":false}}},"errorcount":0}
    2025-01-09 09:58:35.892  - debug: tuya.0 (6579) bf37eczusfmpzprl: Create device objects if not exist
    2025-01-09 09:58:35.893  - debug: tuya.0 (6579) bf37eczusfmpzprl: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_1","id":1,"role":"switch","native":{"code":"switch_1","defaultValue":"","canTrigger":true,"iconname":"icon-dp_power2","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"开关1","property":{"type":"bool"},"subType":"bool","id":1,"editPermission":false}}]
    2025-01-09 09:58:35.893  - debug: tuya.0 (6579) bf37eczusfmpzprl Register onChange for 1
    2025-01-09 09:58:36.190  - info: tuya.0 (6579) bf37eczusfmpzprl: Connect locally to device
    2025-01-09 09:58:36.192  - debug: tuya.0 (6579) bf37eczusfmpzprl: Try to initialize encrypted device with received UDP messages (#IPs: 0): version=undefined, key=1/9?*[<agEIafXVL
    2025-01-09 09:58:36.193  - debug: tuya.0 (6579) bf37eczusfmpzprl: None of the discovered devices matches :-(
    • O oFbEQnpoLKKl6mbY5e13
      @apollon77
      Hoffe, das reicht:
      @ofbeqnpolkkl6mby5e13 Neeeee ... Weil das der start ist wo er noch nichts discovered hat ... von daher ... bissl später meistens
      O 1 Antwort Letzte Antwort
        O Abwesend
        O Abwesend
        @apollon77
        2025-01-09 09:58:41.122  - debug: tuya.0 (6579) bf37eczusfmpzprl: Use following Schema for pwogbugv2zhvbvv9: {"schema":[{"code":"switch_1","defaultValue":"","canTrigger":true,"iconname":"icon-dp_power2","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"开关1","property":{"type":"bool"},"subType":"bool","id":1,"editPermission":false}],"schemaExt":[]}
        2025-01-09 09:58:41.124  - debug: tuya.0 (6579) bf37eczusfmpzprl: Init device with data (after merge): {"data":{"accessType":1,"activeTime":1733524097,"baseAttribute":128,"cloudOnline":false,"communication":{"communicationModes":[{"pv":"","type":8},{"pv":"","type":0}],"connectionStatus":0,"dataModel":1,"mqttTopicAttr":1},"dataPointInfo":{"dpMaxTime":1733524097194,"dpName":{},"dps":{"1":false},"dpsTime":{"1":1733524097194}},"devAttribute":0,"devId":"bf37eczusfmpzprl","devKey":"","deviceTopo":{},"iconUrl":"https://images.tuyaeu.com/smart/icon/ay1553676862206wvxjp/88217e1500025e67acc2007d12d53e93.png","lat":"52.04","localKey":"1/9?*[<agEIafXVL","lon":"10.31","mac":"","meta":{},"name":"Sengled Wi-Fi Plug","otaInfo":{"otaModuleMap":{},"otaUpgradeModes":[0],"supportAuto":true},"ownerId":"151918892","productId":"pwogbugv2zhvbvv9","runtimeEnv":"prod","timezoneId":"Europe/Berlin","uuid":"bf37eczusfmpzprl","virtual":false,"virtualExperience":false,"dpName":{},"groudId":151918892,"schema":[{"code":"switch_1","defaultValue":"","canTrigger":true,"iconname":"icon-dp_power2","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"开关1","property":{"type":"bool"},"subType":"bool","id":1,"editPermission":false}],"productKey":"pwogbugv2zhvbvv9","schemaExt":[],"version":"","dpCodes":{"switch_1":{"code":"switch_1","defaultValue":"","canTrigger":true,"iconname":"icon-dp_power2","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"开关1","property":{"type":"bool"},"subType":"bool","id":1,"editPermission":false}}},"errorcount":0,"localKey":"1/9?*[<agEIafXVL","name":"Sengled Wi-Fi Plug","dpIdList":[1],"objectsInitialized":true,"noLocalConnection":false}
        2025-01-09 09:58:41.135  - debug: tuya.0 (6579) bf37eczusfmpzprl: Create device objects if not exist
        2025-01-09 09:58:41.137  - debug: tuya.0 (6579) bf37eczusfmpzprl: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_1","id":1,"role":"switch","native":{"code":"switch_1","defaultValue":"","canTrigger":true,"iconname":"icon-dp_power2","type":"obj","executable":true,"mode":"rw","defaultRecommend":true,"name":"开关1","property":{"type":"bool"},"subType":"bool","id":1,"editPermission":false}}]
        2025-01-09 09:58:41.139  - debug: tuya.0 (6579) bf37eczusfmpzprl Register onChange for 1
        2025-01-09 09:58:41.140  - debug: tuya.0 (6579) Initial cloud device sync done
          @apollon77
          @ofbeqnpolkkl6mby5e13 Was soll mir das Log zeigen?
            O Abwesend
            O Abwesend
            @apollon77
            Keine Ahnung, mehr gibt das Log für das Gerät halt nicht her. Vergessen wir das.
              @apollon77
              @ofbeqnpolkkl6mby5e13 Da sollte mehr kommen ... sonst hast du ein DNS problem :-) Aber ggf sind das generellere logs ohne die Devcie ID
                padrinoP Offline
                padrinoP Offline
                padrino
                schrieb am zuletzt editiert von padrino
                also, ich kann nur sagen, dass ich eine recht alte Hama "Birne" habe, die heute Nacht einfach aufgehört hat über den 20/switch_led DP zu funktionieren.🤷
                Neustart und neue Synchronisation mit Cloud und DP/Baum löschen hat nix gebracht.
                Hab' nun die Beta gefunden und installiert, und taddaa, läuft wieder - auch einfach so. 😌
                Ich sag da mal danke. =)
                • padrinoP padrino
                  @padrino
                  Ja, hatte ich auch schon, und seit Anfang des Jahres gehen viele Devices auch einfach so offline..
                  Fazit: im laufe des Jahres fliegt der Tuya Kram raus..
                    @padrino
                    padrinoP Offline
                    padrinoP Offline
                    padrino
                    @ilovegym sagte in Tuya. 3.17.0:
                    @padrino
                    Ist doch irgendwie seltsam, dass die offline gehen, wenn sie von der Cloud entkoppelt sind, da kann doch "von außen" keiner Schuld sein, gibt ja auch kein Firmware Update...
                    • padrinoP padrino
                      @padrino
                      @padrino Naja oder auch nicht ... es gab einige Geräte die ständig abgestürzt sind wenn Cloud weg war. Am Ende wissen die das ja nicht und versuchen ständig in die Cloud zu verbinden ... denke das sowas ggf auch issues triggert weil die glaube ich in so einem Umfeld nicht getstet werden :-)
                        @apollon77
                        das kann gut sein, seitdem ich meine wieder der Cloud zugaenglich gemacht habe, sind sie oefters online.. oder funktionieren sogar, wenn sie als offline angezeigt werden... versteh das manchmal nicht.. aber ich muss ja nicht alles wissen .. "D
                          Aktuelle Test Version 3.17.0
                          Veröffentlichungsdatum 08.01.2025
                          Halli Hallo an alle Tuya-Freunde,
                          heute gibt es den Tuya Adapter in 3.17.0 als Beta. Der Adapter bringt Unterstützung für Geräte mit Tuya Protokoll 3.5 und behebt einige Issues die durch Änderungen von Tuya verursacht wurden. Mit Unterstützung von @simatec wurde der Adapter auch etwas mehr Responsive.
                          Details:
                          • Added support for Tuya 3.5 devices
                          • Fixed several errors report by Sentry
                          • Tried to reduce memory usage by only loading Schema definitions when needed and giving memory free afterward
                          • More schema information were added/updated
                          • Added enhanced logic for AC/DC states and generalized it for more devices
                          • Fixed raw data parsing for some devices
                          • Adjusted special handling for TempSet, TempCurrent and FloorTemp states to return correct values
                          • Responsive Design added
                          Bitte meldet alle Probleme hier bzw auf GitHub.
                          Ingo
                          M Online
                          M Online
                          michihorn
                          @apollon77 Hallöchen ich habe eine Installation bei der wird das TUYA Kennwort immer wieder vergessen.
                          Also das Feld "Kennwort" ist dann einfach leer.
                          Michael
                          • M michihorn
                            Michael
                            @michihorn
                            Hello, prima, meine Glaskugel sagt, dass da dann was nicht stimmt.
                            Fuer mal in der Console "iob diag" aus, und poste die Ausgabe in Code-Tags, bitte.
                              @michihorn
                              M Online
                              M Online
                              michihorn
                              @ilovegym ;-) da hat die Glaskugel recht, leider kann ich den Fehler aktuell nicht präsentieren. Seit Samstag läuft der Adapter. Das bedeutet nicht, das alle OK ist, kann sein, dass in ein Paar Tagen ohne Hinweis, das Kennwort wieder weg ist. Hatte ich nun schon ein paar mal. Ich habe jetzt erstmal im LOG "silly" eingestellt. Mal schauen ob das was zu shen ist.
                              • M michihorn
                                @michihorn
                                Hi, nein, von silly hat keiner was gesagt.
                                Erstmal ein iob diag, damit man mal weiss, um was es ueberhaupt geht.
                                Wenn der Adapter geht, muss das pw ja gespeichert sein, sofern du ihn auch neu gestartet hast.
                                Vielleicht wird es nur nicht im Admin angezeigt. Aber dazu braucht man erstmal ein iob diag.
                                  @michihorn
                                  M Online
                                  M Online
                                  michihorn
                                  schrieb am zuletzt editiert von michihorn
                                  @ilovegym Aktuell habe ich keine Probleme, der IOB steht in meinem Ferienhaus, wenn ich Freitag dorthin fahre, werden über GEOFANCY einige Aktionen von TUYA Geräten erwartet. Letzten Freitag war es auch so, IOB hat meine Anreise erkannt, Tuya-Thermostat sollte hochregeln, Auf dem Parkplatz angekommen, sollte die Gartenbeleuchtung und Flurbeleuchtung angehen. IOB hat auch die entsprechenden Tuya Geräte angesprochen, aber es erfolgte keine Auslösung weil das Cloud-Passwort verschwunden war. Anbei ein Bild so wie es gerade aussieht.
                                  ```bash
                                  Script v.2025-02-02
                                  *** BASE SYSTEM ***
                                     Static hostname: iobroker-pi
                                           Icon name: computer
                                    Operating System: Raspbian GNU/Linux 11 (bullseye)
                                              Kernel: Linux 6.1.21-v8+
                                        Architecture: arm64
                                  OS is similar to: debian
                                  Model           : Raspberry Pi 4 Model B Rev 1.5
                                  Docker          : false
                                  Virtualization  : none
                                  Kernel          : aarch64
                                  Userland        : 32 bit
                                  Systemuptime and Load:
                                   13:02:09 up 16 days, 15:31,  1 user,  load average: 0.59, 0.45, 0.45
                                  CPU threads: 4
                                  *** LIFE CYCLE STATUS ***
                                  Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
                                  *** RASPBERRY THROTTLING ***
                                  Current issues:
                                  Previously detected issues:
                                  ~ Under-voltage has occurred
                                  ~ Arm frequency capping has occurred
                                  *** TIME AND TIMEZONES ***
                                                 Local time: Mon 2025-02-10 13:02:09 CET
                                             Universal time: Mon 2025-02-10 12:02:09 UTC
                                                   RTC time: n/a
                                                  Time zone: Europe/Amsterdam (CET, +0100)
                                                NTP service: active
                                            RTC in local TZ: no
                                  *** Users and Groups ***
                                  User that called 'iob diag':
                                  gthrn
                                  HOME=/home/gthrn
                                  GROUPS=gthrn adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                  iobroker
                                  HOME=/home/iobroker
                                  *** DISPLAY-SERVER SETUP ***
                                  Display-Server: false
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Mem:            7.9G        1.6G        4.5G        1.0M        1.8G        6.2G
                                  Swap:            99M          0B         99M
                                  Total:          8.0G        1.6G        4.6G
                                  Active iob-Instances:   21
                                           7862 M total memory
                                           1566 M used memory
                                           1658 M active memory
                                           1521 M inactive memory
                                           4482 M free memory
                                            147 M buffer memory
                                           1665 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  top - 13:02:10 up 16 days, 15:31,  1 user,  load average: 0.59, 0.45, 0.45
                                  Tasks: 166 total,   1 running, 165 sleeping,   0 stopped,   0 zombie
                                  %Cpu(s):  0.0 us,  4.3 sy,  0.0 ni, 95.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                  MiB Mem :   7862.2 total,   4482.4 free,   1566.7 used,   1813.1 buff/cache
                                  MiB Swap:    100.0 total,    100.0 free,      0.0 used.   6164.5 avail Mem
                                  *** FAILED SERVICES ***
                                  0 loaded units listed.
                                  *** DMESG CRITICAL ERRORS ***
                                  140 CRITICAL ERRORS DETECTED!
                                  Check 'sudo dmesg --level=emerg,alert,crit -T' for details
                                  *** FILESYSTEM ***
                                  /dev/root      ext4       59G   11G   46G  19% /
                                  devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                                  tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                                  tmpfs          tmpfs     1.6G  1.1M  1.6G   1% /run
                                  /dev/sda1      vfat      255M   51M  205M  20% /boot
                                  tmpfs          tmpfs     787M     0  787M   0% /run/user/1000
                                  [Fri Jan 24 21:30:22 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:DE:B0:AA vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=ttyS0,115200 console=tty1 root=PARTUUID=c7239adf-02 rootfstype=ext4 fsck.repair=yes rootwait
                                  [Fri Jan 24 21:30:25 2025] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
                                  [Fri Jan 24 21:30:25 2025] EXT4-fs (sda2): write access will be enabled during recovery
                                  [Fri Jan 24 21:30:26 2025] EXT4-fs (sda2): orphan cleanup on readonly fs
                                  [Fri Jan 24 21:30:26 2025] EXT4-fs (sda2): 3 orphan inodes deleted
                                  [Fri Jan 24 21:30:26 2025] EXT4-fs (sda2): recovery complete
                                  [Fri Jan 24 21:30:26 2025] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                                  [Fri Jan 24 21:30:26 2025] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                                  [Fri Jan 24 21:30:30 2025] EXT4-fs (sda2): re-mounted. Quota mode: none.
                                  Show mounted filesystems:
                                  TARGET  SOURCE    FSTYPE OPTIONS
                                  /       /dev/sda2 ext4   rw,noatime
                                  `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                  /var:
                                  1.4G    /var/
                                  763M    /var/log
                                  761M    /var/log/journal/3f7e426fbacf414fbfbc4f1541fa25b4
                                  451M    /var/cache
                                  Archived and active journals take up 760.2M in the file system.
                                  /opt/iobroker/backups:
                                  1.3G    /opt/iobroker/backups/
                                  4.0K    /opt/iobroker/backups/zigbee_0
                                  /opt/iobroker/iobroker-data:
                                  588M    /opt/iobroker/iobroker-data/
                                  424M    /opt/iobroker/iobroker-data/files
                                  158M    /opt/iobroker/iobroker-data/files/admin.admin
                                  157M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                                  19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.6964fae2.js.map
                                  15M     /opt/iobroker/iobroker-data/objects.jsonl
                                  14M     /opt/iobroker/iobroker-data/states.jsonl
                                  7.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.6964fae2.js
                                  7.4M    /opt/iobroker/iobroker-data/files/javascript.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_icons-material_esm_index_js.3514cab0.chunk.js.map
                                  USB-Devices by-id:
                                  No Devices found 'by-id'
                                  HINT:
                                  Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                                  tcp
                                  *** NodeJS-Installation ***
                                  /usr/bin/nodejs         v20.18.1
                                  /usr/bin/node           v20.18.1
                                  /usr/bin/npm            10.8.2
                                  /usr/bin/npx            10.8.2
                                  /usr/bin/corepack       0.29.4
                                  nodejs:
                                    Installed: 20.18.1-1nodesource1
                                    Candidate: 20.18.1-1nodesource1
                                    Version table:
                                   *** 20.18.1-1nodesource1 600
                                          500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                                       20.18.0-1nodesource1 600
                                       20.17.0-1nodesource1 600
                                       20.16.0-1nodesource1 600
                                       20.15.1-1nodesource1 600
                                       20.15.0-1nodesource1 600
                                       20.14.0-1nodesource1 600
                                       20.13.1-1nodesource1 600
                                       20.13.0-1nodesource1 600
                                       20.12.2-1nodesource1 600
                                       20.12.1-1nodesource1 600
                                       20.12.0-1nodesource1 600
                                       20.11.1-1nodesource1 600
                                       20.11.0-1nodesource1 600
                                       20.10.0-1nodesource1 600
                                       20.9.0-1nodesource1 600
                                       20.8.1-1nodesource1 600
                                       20.8.0-1nodesource1 600
                                       20.7.0-1nodesource1 600
                                       20.6.1-1nodesource1 600
                                       20.6.0-1nodesource1 600
                                       20.5.1-1nodesource1 600
                                       20.5.0-1nodesource1 600
                                       20.4.0-1nodesource1 600
                                       20.3.1-1nodesource1 600
                                       20.3.0-1nodesource1 600
                                       20.2.0-1nodesource1 600
                                       20.1.0-1nodesource1 600
                                       20.0.0-1nodesource1 600
                                       12.22.12~dfsg-1~deb11u5 500
                                  No problems detected
                                  Errors in npm tree: 0
                                  *** ioBroker-Installation ***
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Hosts:
                                  GTHRN-pi            GTHRN-pi (version: 7.0.6, hostname: GTHRN-pi      , alive, uptime: 1438305)
                                  Core adapters versions
                                  js-controller:  7.0.6
                                  admin:          7.4.21
                                  javascript:     8.9.1
                                  nodejs modules from github:     4
                                  +-- iobroker.device-watcher@2.12.1 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.device-watcher.git#fb49d0b7d1af160318904a143bcea7cab85764c4)
                                  +-- iobroker.telegram@4.0.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.telegram.git#b4cfff1fa1dadc8a33905f86208d3b5319c1e585)
                                  +-- iobroker.tuya@3.17.0 (git+ssh://git@github.com/Apollon77/ioBroker.tuya.git#007d61f5c03c1150dcf67d40f5967e651caf776c)
                                  +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
                                  Adapter State
                                  + system.adapter.admin.0                  : admin                 : GTHRN-pi                                 -  enabled, compact disabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                  + system.adapter.backitup.0               : backitup              : GTHRN-pi                                 -  enabled, compact disabled
                                    system.adapter.daikin.0                 : daikin                : GTHRN-pi                                 - disabled, compact disabled
                                    system.adapter.daswetter.0              : daswetter             : GTHRN-pi                                 -  enabled, compact disabled
                                  + system.adapter.device-watcher.0         : device-watcher        : GTHRN-pi                                 -  enabled, compact disabled
                                  + system.adapter.espresense.0             : espresense            : GTHRN-pi                                 -  enabled, compact disabled
                                    system.adapter.feiertage.0              : feiertage             : GTHRN-pi                                 -  enabled, compact disabled
                                  + system.adapter.fullybrowser.0           : fullybrowser          : GTHRN-pi                                 -  enabled, compact disabled
                                  + system.adapter.history.0                : history               : GTHRN-pi                                 -  enabled, compact disabled
                                  + system.adapter.hue.0                    : hue                   : GTHRN-pi                                 -  enabled, compact disabled, port: 443
                                    system.adapter.icons-material-png.0     : icons-material-png    : GTHRN-pi                                 - disabled
                                    system.adapter.icons-material-svg.0     : icons-material-svg    : GTHRN-pi                                 - disabled
                                    system.adapter.icons-mfd-png.0          : icons-mfd-png         : GTHRN-pi                                 - disabled
                                    system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : GTHRN-pi                                 - disabled
                                  + system.adapter.iot.0                    : iot                   : GTHRN-pi                                 -  enabled, compact disabled
                                  + system.adapter.iot.1                    : iot                   : GTHRN-pi                                 -  enabled, compact disabled
                                  + system.adapter.iot.2                    : iot                   : GTHRN-pi                                 -  enabled, compact disabled
                                  + system.adapter.javascript.0             : javascript            : GTHRN-pi                                 -  enabled, compact disabled
                                  + system.adapter.mqtt-client.2            : mqtt-client           : GTHRN-pi                                 -  enabled, compact disabled, port: 3075
                                  + system.adapter.mqtt.2                   : mqtt                  : GTHRN-pi                                 -  enabled, compact disabled, port: 3075, bind: 0.0.0.0
                                  + system.adapter.ping.0                   : ping                  : GTHRN-pi                                 -  enabled, compact disabled
                                  + system.adapter.ring.0                   : ring                  : GTHRN-pi                                 -  enabled, compact disabled
                                  + system.adapter.telegram.0               : telegram              : GTHRN-pi                                 -  enabled, compact disabled, port: 8443, bind: 0.0.0.0
                                  + system.adapter.tuya.0                   : tuya                  : GTHRN-pi                                 -  enabled, compact disabled
                                    system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : GTHRN-pi                                 - disabled
                                    system.adapter.vis-google-fonts.0       : vis-google-fonts      : GTHRN-pi                                 -  enabled, compact disabled
                                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : GTHRN-pi                                 - disabled
                                    system.adapter.vis-icontwo.0            : vis-icontwo           : GTHRN-pi                                 - disabled, compact disabled
                                  + system.adapter.vis-inventwo.0           : vis-inventwo          : GTHRN-pi                                 -  enabled, compact disabled
                                    system.adapter.vis-keyboard.0           : vis-keyboard          : GTHRN-pi                                 - disabled
                                    system.adapter.vis-metro.0              : vis-metro             : GTHRN-pi                                 - disabled
                                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : GTHRN-pi                                 - disabled
                                    system.adapter.vis.0                    : vis                   : GTHRN-pi                                 -  enabled, compact disabled
                                  + system.adapter.web.0                    : web                   : GTHRN-pi                                 -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
                                  + system.adapter.zigbee.0                 : zigbee                : GTHRN-pi                                 -  enabled, compact disabled, port: tcp://192.168.188.120:6638
                                  + instance is alive
                                  ioBroker-Repositories
                                  Active repo(s): beta
                                  Upgrade policy: none
                                  Installed ioBroker-Instances
                                  Used repository: beta
                                  Adapter    "admin"        : 7.4.21   , installed 7.4.21
                                  Adapter    "backitup"     : 3.0.31   , installed 3.0.31
                                  Adapter    "daikin"       : 1.4.2    , installed 1.4.2
                                  Adapter    "daswetter"    : 3.2.2    , installed 3.2.2
                                  Adapter    "device-watcher": 2.12.1  , installed 2.12.1
                                  Adapter    "espresense"   : 0.6.3    , installed 0.6.3
                                  Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
                                  Adapter    "fullybrowser" : 3.0.13   , installed 3.0.13
                                  Adapter    "hue"          : 3.14.1   , installed 3.14.1
                                  Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                                  Adapter    "iot"          : 3.4.5    , installed 3.4.5
                                  Adapter    "javascript"   : 8.9.1    , installed 8.9.1
                                  Controller "js-controller": 7.0.6    , installed 7.0.6
                                  Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                                  Adapter    "mqtt-client"  : 3.0.0    , installed 2.1.0  [Updatable]
                                  Adapter    "ping"         : 1.7.9    , installed 1.7.9
                                  Adapter    "ring"         : 6.3.0    , installed 6.3.0
                                  Adapter    "socketio"     : 7.0.0    , installed 6.7.1  [Updatable]
                                  Adapter    "telegram"     : 4.0.0    , installed 4.0.0
                                  Adapter    "tuya"         : 3.17.0   , installed 3.17.0
                                  Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
                                  Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                                  Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                                  Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
                                  Adapter    "web"          : 6.3.1    , installed 6.3.1
                                  Adapter    "ws"           : 3.0.1    , installed 2.6.2  [Updatable]
                                  Adapter    "zigbee"       : 1.10.14  , installed 1.10.14
                                  Objects and States
                                  Objects:        6671
                                  States:         5793
                                  Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                  Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                                  Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
                                  Reading package lists...
                                  Pending Updates: 25
                                  *** Listening Ports ***
                                  tcp        0      0 0.0.0.0:3075            0.0.0.0:*               LISTEN      1001       15868      1189/io.mqtt.2
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14125      489/iobroker.js-con
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12785      489/iobroker.js-con
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1889       517/sshd: /usr/sbin
                                  tcp6       0      0 :::3001                 :::*                    LISTEN      1001       16749      1222/io.fullybrowse
                                  tcp6       0      0 :::3030                 :::*                    LISTEN      1001       2653440    9688/io.espresense.
                                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       18441      1239/io.web.0
                                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       2652026    9576/io.admin.0
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          1891       517/sshd: /usr/sbin
                                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1906       695/dhcpcd
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13907      373/avahi-daemon: r
                                  udp        0      0 0.0.0.0:50523           0.0.0.0:*                           108        13909      373/avahi-daemon: r
                                  udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       2659021    10456/io.tuya.0
                                  udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       2659022    10456/io.tuya.0
                                  udp6       0      0 :::546                  :::*                                0          115745     695/dhcpcd
                                  udp6       0      0 :::5353                 :::*                                108        13908      373/avahi-daemon: r
                                  udp6       0      0 :::39322                :::*                                108        13910      373/avahi-daemon: r
                                  2025-02-10 13:00:53.082  - info: daswetter.0 (18166) starting. Version 3.2.2 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.1, js-controller: 7.0.6
                                  2025-02-10 13:01:07.031  - info: javascript.0 (28533) script.js.SYSTEM.Devicewatcher_status_an_loggger: true
                                  2025-02-10 13:01:11.150  - info: daswetter.0 (18166) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                                  2025-02-10 13:01:11.670  - info: daswetter.0 (18166) cleaned everything up...
                                  2025-02-10 13:01:11.689  - info: host.GTHRN-pi instance system.adapter.daswetter.0 having pid 18166 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2025-02-10 13:01:22.032  - info: javascript.0 (28533) script.js.SYSTEM.Devicewatcher_status_an_loggger: true
                                  2025-02-10 13:01:37.031  - info: javascript.0 (28533) script.js.SYSTEM.Devicewatcher_status_an_loggger: true
                                  2025-02-10 13:01:52.034  - info: javascript.0 (28533) script.js.SYSTEM.Devicewatcher_status_an_loggger: true
                                  2025-02-10 13:02:00.052  - info: javascript.0 (28533) script.js.SYSTEM.Temp_CPU: 38.4°C
                                  2025-02-10 13:02:07.035  - info: javascript.0 (28533) script.js.SYSTEM.Devicewatcher_status_an_loggger: true
                                  2025-02-10 13:02:22.037  - info: javascript.0 (28533) script.js.SYSTEM.Devicewatcher_status_an_loggger: true
                                  2025-02-10 13:02:37.042  - info: javascript.0 (28533) script.js.SYSTEM.Devicewatcher_status_an_loggger: true
                                  2025-02-10 13:02:56.454  - info: javascript.0 (28533) script.js.SYSTEM.Devicewatcher_status_an_loggger: true
                                  2025-02-10 13:03:07.041  - info: javascript.0 (28533) script.js.SYSTEM.Devicewatcher_status_an_loggger: true
                                  2025-02-10 13:03:07.163  - info: admin.0 (9576) <== Disconnect system.user.admin from ::ffff:192.168.178.196 admin
                                  2025-02-10 13:03:16.659  - info: admin.0 (9576) ==> Connected system.user.admin from ::ffff:192.168.178.196
                                  2025-02-10 13:03:22.044  - info: javascript.0 (28533) script.js.SYSTEM.Devicewatcher_status_an_loggger: true
                                  2025-02-10 13:03:24.803  - warn: host.GTHRN-pi Could not check for new OS updates: Command failed: sudo apt list --upgradeable
                                  WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
                                  E: Problem renaming the file /var/cache/apt/pkgcache.bin.2vsJAl to /var/cache/apt/pkgcache.bin - rename (2: No such file or directory)
                                  W: You may want to run apt-get update to correct these problems
                                  E: The package cache file is corrupted
                                  LatziL ? Thomas BraunT U 4 Antworten Letzte Antwort
                                  • M michihorn
                                    ```bash
                                    Script v.2025-02-02
                                    *** BASE SYSTEM ***
                                             Icon name: computer
                                          Architecture: arm64
                                    Docker          : false
                                    Kernel          : aarch64
                                    Userland        : 32 bit
                                    CPU threads: 4
                                    Current issues:
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    gthrn
                                    HOME=/home/gthrn
                                    iobroker
                                    HOME=/home/iobroker
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Swap:            99M          0B         99M
                                             7862 M total memory
                                             1566 M used memory
                                             4482 M free memory
                                              147 M buffer memory
                                             1665 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    *** FILESYSTEM ***
                                    /var:
                                    1.4G    /var/
                                    763M    /var/log
                                    451M    /var/cache
                                    USB-Devices by-id:
                                    HINT:
                                    tcp
                                    /usr/bin/npm            10.8.2
                                    /usr/bin/npx            10.8.2
                                    nodejs:
                                      Version table:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Hosts:
                                    admin:          7.4.21
                                    javascript:     8.9.1
                                    Adapter State
                                    + instance is alive
                                    Objects and States
                                    Objects:        6671
                                    States:         5793
                                    Pending Updates: 25
                                    LatziL Online
                                    LatziL Online
                                    Latzi
                                    @michihorn
                                    du hast da einige Adapter von github installiert (unter anderem tuya), den gibt es auch im lastest:
                                    github:	3.17.0
                                    latest:	3.17.0 for 32 days
                                    stable:	3.16.0 for 5 months
                                    Von github nur nach Absprache mit dem Entwickler installieren ;-)
                                    • M michihorn
                                      ```bash
                                      Script v.2025-02-02
                                      *** BASE SYSTEM ***
                                               Icon name: computer
                                            Architecture: arm64
                                      Docker          : false
                                      Kernel          : aarch64
                                      Userland        : 32 bit
                                      CPU threads: 4
                                      Current issues:
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      gthrn
                                      HOME=/home/gthrn
                                      iobroker
                                      HOME=/home/iobroker
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Swap:            99M          0B         99M
                                               7862 M total memory
                                               1566 M used memory
                                               4482 M free memory
                                                147 M buffer memory
                                               1665 M swap cache
                                                 99 M total swap
                                                  0 M used swap
                                                 99 M free swap
                                      *** FILESYSTEM ***
                                      /var:
                                      1.4G    /var/
                                      763M    /var/log
                                      451M    /var/cache
                                      USB-Devices by-id:
                                      HINT:
                                      tcp
                                      /usr/bin/npm            10.8.2
                                      /usr/bin/npx            10.8.2
                                      nodejs:
                                        Version table:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Hosts:
                                      admin:          7.4.21
                                      javascript:     8.9.1
                                      Adapter State
                                      + instance is alive
                                      Objects and States
                                      Objects:        6671
                                      States:         5793
                                      Pending Updates: 25
                                      @michihorn
                                      Danke, jetzt kann man Hilfe leisten. Ich vermute mal zu 90% liegt das am aktuell von dir installierten Admin-Adapter V7.4.21, der hat seit ner Zeit n Bug bei der Eingabe in die Felder.. gibt auch n Issue zu.
                                      Bei Einsatz von Beta Versionen besser immer die Issues dazu lesen, oder, in der Gartenhuette, erst gar nicht einsetzen.
                                      Da lieber mit den Versionen auf Stable bleiben, die heissen ja nicht zufaellig Stable..
                                      • M michihorn
                                        ```bash
                                        Script v.2025-02-02
                                        *** BASE SYSTEM ***
                                                 Icon name: computer
                                              Architecture: arm64
                                        Docker          : false
                                        Kernel          : aarch64
                                        Userland        : 32 bit
                                        CPU threads: 4
                                        Current issues:
                                                         RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        gthrn
                                        HOME=/home/gthrn
                                        iobroker
                                        HOME=/home/iobroker
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Swap:            99M          0B         99M
                                                 7862 M total memory
                                                 1566 M used memory
                                                 4482 M free memory
                                                  147 M buffer memory
                                                 1665 M swap cache
                                                   99 M total swap
                                                    0 M used swap
                                                   99 M free swap
                                        *** FILESYSTEM ***
                                        /var:
                                        1.4G    /var/
                                        763M    /var/log
                                        451M    /var/cache
                                        USB-Devices by-id:
                                        HINT:
                                        tcp
                                        /usr/bin/npm            10.8.2
                                        /usr/bin/npx            10.8.2
                                        nodejs:
                                          Version table:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Hosts:
                                        admin:          7.4.21
                                        javascript:     8.9.1
                                        Adapter State
                                        + instance is alive
                                        Objects and States
                                        Objects:        6671
                                        States:         5793
                                        Pending Updates: 25
                                        @michihorn
                                        Und losgelöst vom tuya solltest du die Kiste eh mal neuaufsetzen.
                                        Als RaspberryOS 12 'Bookworm' in der 64Bit-Version.
                                        Vielleicht erledigen sich dann diese Fehler:
                                        In den Paket-Quellen fehlt das security-Repo. Und der cache ist auch krumm:
                                          @michihorn
                                          M Online
                                          M Online
                                          michihorn
                                          @thomas-braun sagte in Tuya. 3.17.0:
                                          Wie kann ich das fixen?
                                          Thomas BraunT ? 2 Antworten Letzte Antwort
