  4. Node-Red
  5. Gelöst: Wert in dynamische Struktur im ioBroker ablegen
    6.4k
91 Beiträge 2 Kommentatoren 13.6k Aufrufe 2 Beobachtet
  • M MartyBr
    Ich habe den Flow für die Mittelwertbildung auf den Node aggregate umgestellt.
    Die Delays dienen der richtigen Reihenfolge der drei Werte min, mean und max im Json. Das ganze wird in einem fortlaufenden Array unter Jahr.Monat abgelegt.
    Hier der Flow, der zumindest bei mir ohne Fehler erfolgreich läuft.
            "id": "ae673cf6cd8433a0",
            "type": "subflow",
            "name": "Datum in Topic",
            "info": "",
            "category": "",
            "in": [
                    "x": 60,
                    "y": 80,
                    "wires": [
                            "id": "2e1ea06b2e94bf1a"
            "out": [
                    "x": 820,
                    "y": 80,
                    "wires": [
                            "id": "fc37f5f9d2b0297b",
                            "port": 0
            "env": [
                    "name": "basePath",
                    "type": "str",
                    "value": "Test1.Test2"
            "meta": {},
            "color": "#DDAA99"
            "id": "2e1ea06b2e94bf1a",
            "type": "change",
            "z": "ae673cf6cd8433a0",
            "name": "",
            "rules": [
                    "t": "set",
                    "p": "datum",
                    "pt": "msg",
                    "to": "$moment().locale('de').format('YYYY.MMMM')",
                    "tot": "jsonata"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 230,
            "y": 80,
            "wires": [
                    "0e8de9437c3c420a"
            "id": "0e8de9437c3c420a",
            "type": "change",
            "name": "März zu Maerz",
            "rules": [
                    "t": "change",
                    "p": "datum",
                    "pt": "msg",
                    "from": "März",
                    "fromt": "str",
                    "to": "Maerz",
                    "tot": "str"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 440,
            "y": 80,
            "wires": [
                    "fc37f5f9d2b0297b"
            "type": "change",
            "name": "",
            "rules": [
                    "t": "set",
                    "p": "topic",
                    "pt": "msg",
                    "to": "\"0_userdata.0.\"  & $env(\"basePath\") & \".\" & datum & \".\" & topic",
                    "tot": "jsonata"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 660,
            "y": 80,
            "wires": [
            "id": "8c459eb88d1bf5f1",
            "type": "tab",
            "label": "Mittelwert",
            "disabled": false,
            "info": "",
            "env": []
            "id": "9b11db08a1cca5b3",
            "type": "aggregator",
            "z": "8c459eb88d1bf5f1",
            "name": "Mean",
            "topic": "mean",
            "intervalCount": "1",
            "intervalUnits": "d",
            "submitIncompleteInterval": true,
            "submitPerTopic": false,
            "aggregationType": "mean",
            "x": 290,
            "y": 260,
            "wires": [
                    "0290eb1787934b73"
            "id": "f33e1d253e22a2dd",
            "type": "ioBroker in",
            "name": "Aussentemperatur",
            "attrname": "payload",
            "topic": "mqtt.0.vitocal.outside_temperature",
            "payloadType": "value",
            "onlyack": "",
            "func": "all",
            "gap": "",
            "fireOnStart": "false",
            "outFormat": "MQTT",
            "x": 110,
            "y": 260,
            "wires": [
                    "5a18bba8160e8e94",
                    "9b11db08a1cca5b3",
                    "32753fd69085ce71"
            "id": "5a18bba8160e8e94",
            "name": "Min",
            "topic": "min",
            "aggregationType": "min",
            "x": 290,
            "y": 200,
            "wires": [
                    "15a56c790ce29f8d"
            "id": "32753fd69085ce71",
            "name": "Max",
            "topic": "max",
            "aggregationType": "max",
            "x": 290,
            "y": 320,
            "wires": [
                    "7a8c3b56e65b5059"
            "id": "15a56c790ce29f8d",
            "type": "join",
            "name": "",
            "mode": "custom",
            "build": "object",
            "property": "payload",
            "propertyType": "msg",
            "key": "topic",
            "joiner": "\\n",
            "joinerType": "str",
            "accumulate": true,
            "timeout": "60",
            "count": "3",
            "reduceRight": false,
            "reduceExp": "",
            "reduceInit": "",
            "reduceInitType": "",
            "reduceFixup": "",
            "x": 670,
            "y": 200,
            "wires": [
                    "8ef8ee85844f2bb2"
            "id": "8ef8ee85844f2bb2",
            "type": "change",
            "name": "",
            "rules": [
                    "t": "set",
                    "p": "topic",
                    "pt": "msg",
                    "to": "meanTmp",
                    "tot": "str"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 840,
            "y": 200,
            "wires": [
                    "5d3e4f7dea0efe7c"
            "id": "5d3e4f7dea0efe7c",
            "type": "subflow:ae673cf6cd8433a0",
            "env": [
                    "name": "basePath",
                    "value": "Heizung1.MonatsTabellen",
                    "type": "str"
            "x": 1040,
            "y": 200,
            "wires": [
                    "9aa634789fccf445"
            "id": "e44c746b92947c39",
            "type": "ioBroker out",
            "name": "",
            "topic": "",
            "ack": "true",
            "autoCreate": "true",
            "stateName": "",
            "role": "",
            "payloadType": "",
            "readonly": "false",
            "stateUnit": "°C",
            "stateMin": "",
            "stateMax": "",
            "x": 2920,
            "y": 280,
            "wires": []
            "id": "0290eb1787934b73",
            "type": "delay",
            "name": "",
            "pauseType": "delay",
            "timeout": "5",
            "timeoutUnits": "seconds",
            "rate": "1",
            "nbRateUnits": "1",
            "rateUnits": "second",
            "randomFirst": "1",
            "randomLast": "5",
            "randomUnits": "seconds",
            "drop": false,
            "allowrate": false,
            "outputs": 1,
            "x": 460,
            "y": 260,
            "wires": [
                    "15a56c790ce29f8d"
            "id": "7a8c3b56e65b5059",
            "type": "delay",
            "name": "",
            "timeout": "10",
            "rate": "1",
            "nbRateUnits": "1",
            "randomFirst": "1",
            "randomLast": "5",
            "drop": false,
            "allowrate": false,
            "outputs": 1,
            "x": 470,
            "y": 320,
            "wires": [
                    "15a56c790ce29f8d"
            "id": "9aa634789fccf445",
            "type": "switch",
            "name": "topic geändert?",
            "property": "topic",
            "rules": [
                    "t": "neq",
                    "v": "",
                    "vt": "prev"
                    "t": "eq",
                    "v": "",
                    "vt": "prev"
            "checkall": "true",
            "repair": false,
            "outputs": 2,
            "x": 1240,
            "y": 200,
            "wires": [
                    "c7fa49ea854690ed"
                    "edaece611a7db6d5"
            "id": "c7fa49ea854690ed",
            "type": "change",
            "name": "payload sichern und flow var löschen",
            "rules": [
                    "t": "move",
                    "p": "payload",
                    "pt": "msg",
                    "to": "payload_bak_mean",
                    "tot": "msg"
                    "t": "delete",
                    "p": "array_mean",
                    "pt": "flow"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 1530,
            "y": 180,
            "wires": [
                    "7fd2bba1daf6d9f3"
            "id": "edaece611a7db6d5",
            "type": "change",
            "name": "",
            "rules": [
                    "t": "set",
                    "p": "array_bezug",
                    "pt": "msg",
                    "to": "array_bezug",
                    "tot": "flow"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 1490,
            "y": 280,
            "wires": [
                    "515ae9918126f535"
            "id": "7fd2bba1daf6d9f3",
            "type": "ioBroker get",
            "name": "",
            "topic": "",
            "errOnInvalidState": "false",
            "x": 1800,
            "y": 180,
            "wires": [
                    "6e576a4e6d33f548"
            "id": "6e576a4e6d33f548",
            "type": "switch",
            "name": "IoB read ?",
            "rules": [
                    "t": "null"
                    "t": "nnull"
            "checkall": "true",
            "repair": false,
            "outputs": 2,
            "x": 2010,
            "y": 180,
            "wires": [
                    "ba58ec451fbfa53e"
                    "ae2e0346dd5f3824"
            "id": "ba58ec451fbfa53e",
            "type": "change",
            "name": "",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "[]",
                    "tot": "json"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 2250,
            "y": 160,
            "wires": [
                    "db03a4ed74093df5"
            "id": "ae2e0346dd5f3824",
            "type": "json",
            "name": "",
            "action": "",
            "pretty": false,
            "x": 2230,
            "y": 220,
            "wires": [
                    "db03a4ed74093df5"
            "id": "db03a4ed74093df5",
            "type": "change",
            "name": "payload wiederherstellen",
            "rules": [
                    "t": "move",
                    "p": "payload",
                    "pt": "msg",
                    "to": "array_mean",
                    "tot": "msg"
                    "t": "move",
                    "p": "payload_bak_mean",
                    "pt": "msg",
                    "to": "payload",
                    "tot": "msg"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 2490,
            "y": 160,
            "wires": [
                    "515ae9918126f535"
            "id": "515ae9918126f535",
            "type": "change",
            "name": "payload anhängen und sichern",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "$append(array_mean, payload)",
                    "tot": "jsonata"
                    "t": "set",
                    "p": "array_mean",
                    "pt": "flow",
                    "to": "payload",
                    "tot": "msg"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 2510,
            "y": 280,
            "wires": [
                    "0427391d23dcb6ad"
            "id": "0427391d23dcb6ad",
            "type": "json",
            "name": "",
            "action": "",
            "pretty": false,
            "x": 2750,
            "y": 280,
            "wires": [
                    "e44c746b92947c39"
    MartyBr
    schrieb am zuletzt editiert von MartyBr
    @mickym
    Ich habe noch eine Frage zu dem u.a. Flow. Ich würde gerne den Payload min, mean und max
    an die Tagesposition schieben.
    Also das bedeutet heute (09.02.2025) die 9 Position, das das Element 8.
    Man könnte doch mit einem Function Node den Code
    let i ===global.monatstage
    i = i-1
    msg.payload[i] = msg.payload[i].state
    schreiben. Ich habe Monatstage als globale Variable definiert.
    Mein Problem ist aber im Change node das append. Das widerspricht ja die Nutzung der Function Node.
    Hast du einen Tipp für mich?
    EDIT:
    Ich habe in der Doku gesehen, dass auch in der Change Node mit JSONata mit $sum(payload.state in die Elemente des Arrays geschrieben werden kann.
    Array Mean:
        "min": 0,
        "mean": 0,
        "max": 0
        "min": 0,
        "mean": 0,
        "max": 0
        "min": 0,
        "mean": 0,
        "max": 0
        "min": 0,
        "mean": 0,
        "max": 0
        "min": 0,
        "mean": 0,
        "max": 0
        "min": 0,
        "mean": 0,
        "max": 0
        "min": 0,
        "mean": 0,
        "max": 0
        "min": 0,
        "mean": 0,
        "max": 0
        "min": -4,
        "mean": 0.05,
        "max": 3.3
        "min": 0,
        "mean": 0,
        "max": 0
        "min": 0,
        "mean": 0,
        "max": 0
        "min": 0,
        "mean": 0,
        "max": 0
        "min": 0,
        "mean": 0,
        "max": 0
        "min": 0,
        "mean": 0,
        "max": 0
        "min": 0,
        "mean": 0,
        "max": 0
        "min": 0,
        "mean": 0,
        "max": 0
        "min": 0,
        "mean": 0,
        "max": 0
        "min": 0,
        "mean": 0,
        "max": 0
        "min": 0,
        "mean": 0,
        "max": 0
        "min": 0,
        "mean": 0,
        "max": 0
        "min": 0,
        "mean": 0,
        "max": 0
        "min": 0,
        "mean": 0,
        "max": 0
        "min": 0,
        "mean": 0,
        "max": 0
        "min": 0,
        "mean": 0,
        "max": 0
        "min": 0,
        "mean": 0,
        "max": 0
        "min": 0,
        "mean": 0,
        "max": 0
        "min": 0,
        "mean": 0,
        "max": 0
        "min": 0,
        "mean": 0,
        "max": 0
        "min": 0,
        "mean": 0,
        "max": 0
        "min": 0,
        "mean": 0,
        "max": 0
        "min": 0,
        "mean": 0,
        "max": 0
    code_tex[
            "type": "subflow",
            "info": "",
            "category": "",
            "in": [
                    "x": 60,
                    "y": 80,
                    "wires": [
            "out": [
                    "x": 820,
                    "y": 80,
                    "wires": [
                            "port": 0
            "env": [
                    "name": "basePath",
                    "type": "str",
            "meta": {},
            "color": "#DDAA99"
            "type": "change",
            "name": "",
            "rules": [
                    "t": "set",
                    "p": "datum",
                    "pt": "msg",
                    "tot": "jsonata"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 230,
            "y": 80,
            "wires": [
                    "0e8de9437c3c420a"
            "type": "change",
            "rules": [
                    "t": "change",
                    "p": "datum",
                    "pt": "msg",
                    "from": "März",
                    "fromt": "str",
                    "to": "Maerz",
                    "tot": "str"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 440,
            "y": 80,
            "wires": [
                    "fc37f5f9d2b0297b"
            "type": "change",
            "name": "",
            "rules": [
                    "t": "set",
                    "p": "topic",
                    "pt": "msg",
                    "tot": "jsonata"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 660,
            "y": 80,
            "wires": [
            "name": "Mean",
            "topic": "mean",
            "intervalUnits": "h",
            "x": 290,
            "y": 260,
            "wires": [
                    "0290eb1787934b73"
            "onlyack": "",
            "func": "all",
            "gap": "",
            "x": 110,
            "y": 260,
            "wires": [
                    "5a18bba8160e8e94",
                    "9b11db08a1cca5b3",
                    "32753fd69085ce71"
            "name": "Min",
            "topic": "min",
            "x": 290,
            "y": 200,
            "wires": [
                    "15a56c790ce29f8d"
            "name": "Max",
            "topic": "max",
            "x": 290,
            "y": 320,
            "wires": [
                    "7a8c3b56e65b5059"
            "type": "join",
            "name": "",
            "mode": "custom",
            "build": "object",
            "key": "topic",
            "joiner": "\\n",
            "accumulate": true,
            "timeout": "60",
            "count": "3",
            "reduceExp": "",
            "reduceInit": "",
            "reduceFixup": "",
            "x": 670,
            "y": 200,
            "wires": [
                    "8ef8ee85844f2bb2"
            "type": "change",
            "name": "",
            "rules": [
                    "t": "set",
                    "p": "topic",
                    "pt": "msg",
                    "to": "meanTmp",
                    "tot": "str"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 840,
            "y": 200,
            "wires": [
                    "5d3e4f7dea0efe7c"
            "env": [
                    "name": "basePath",
                    "type": "str"
            "x": 1040,
            "y": 200,
            "wires": [
                    "9aa634789fccf445"
            "name": "",
            "topic": "",
            "ack": "true",
            "stateName": "",
            "role": "",
            "payloadType": "",
            "stateUnit": "°C",
            "stateMin": "",
            "stateMax": "",
            "x": 2920,
            "y": 280,
            "wires": []
            "type": "delay",
            "name": "",
            "timeout": "5",
            "rate": "1",
            "nbRateUnits": "1",
            "randomFirst": "1",
            "randomLast": "5",
            "drop": false,
            "allowrate": false,
            "outputs": 1,
            "x": 460,
            "y": 260,
            "wires": [
                    "15a56c790ce29f8d"
            "type": "delay",
            "name": "",
            "timeout": "10",
            "rate": "1",
            "nbRateUnits": "1",
            "randomFirst": "1",
            "randomLast": "5",
            "drop": false,
            "allowrate": false,
            "outputs": 1,
            "x": 470,
            "y": 320,
            "wires": [
                    "15a56c790ce29f8d"
            "type": "switch",
            "rules": [
                    "t": "neq",
                    "v": "",
                    "vt": "prev"
                    "t": "eq",
                    "v": "",
                    "vt": "prev"
            "checkall": "true",
            "repair": false,
            "outputs": 2,
            "x": 1240,
            "y": 200,
            "wires": [
                    "c7fa49ea854690ed"
                    "edaece611a7db6d5"
            "type": "change",
            "rules": [
                    "t": "move",
                    "p": "payload",
                    "pt": "msg",
                    "tot": "msg"
                    "t": "delete",
                    "p": "array_mean",
                    "pt": "flow"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 1530,
            "y": 180,
            "wires": [
                    "7fd2bba1daf6d9f3"
            "type": "change",
            "name": "",
            "rules": [
                    "t": "set",
                    "p": "array_bezug",
                    "pt": "msg",
                    "tot": "flow"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 1490,
            "y": 280,
            "wires": [
                    "515ae9918126f535"
            "name": "",
            "topic": "",
            "x": 1800,
            "y": 180,
            "wires": [
                    "6e576a4e6d33f548"
            "type": "switch",
            "rules": [
                    "t": "null"
                    "t": "nnull"
            "checkall": "true",
            "repair": false,
            "outputs": 2,
            "x": 2010,
            "y": 180,
            "wires": [
                    "ba58ec451fbfa53e"
                    "ae2e0346dd5f3824"
            "type": "change",
            "name": "",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "[]",
                    "tot": "json"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 2250,
            "y": 160,
            "wires": [
                    "db03a4ed74093df5"
            "type": "json",
            "name": "",
            "action": "",
            "pretty": false,
            "x": 2230,
            "y": 220,
            "wires": [
                    "db03a4ed74093df5"
            "type": "change",
            "rules": [
                    "t": "move",
                    "p": "payload",
                    "pt": "msg",
                    "to": "array_mean",
                    "tot": "msg"
                    "t": "move",
                    "pt": "msg",
                    "to": "payload",
                    "tot": "msg"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 2490,
            "y": 160,
            "wires": [
                    "515ae9918126f535"
            "type": "change",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "tot": "jsonata"
                    "t": "set",
                    "p": "array_mean",
                    "pt": "flow",
                    "to": "payload",
                    "tot": "msg"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 2510,
            "y": 280,
            "wires": [
                    "0427391d23dcb6ad"
            "type": "json",
            "name": "",
            "action": "",
            "pretty": false,
            "x": 2750,
            "y": 280,
            "wires": [
                    "e44c746b92947c39"
            "id": "809efb6124c3639c",
            "type": "change",
            "name": "",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "$moment().date()",
                    "tot": "jsonata"
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "monatstage",
                    "tot": "global"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 290,
            "y": 460,
            "wires": [
                    "a27f09da64977051"
            "id": "02c66f19b70ff804",
            "type": "inject",
            "name": "",
            "props": [
                    "p": "payload"
                    "p": "topic",
                    "vt": "str"
            "repeat": "300",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "",
            "payloadType": "date",
            "x": 110,
            "y": 460,
            "wires": [
                    "809efb6124c3639c"
            "id": "a27f09da64977051",
            "type": "debug",
            "name": "Datum",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "complete": "payload",
            "targetType": "msg",
            "statusVal": "",
            "statusType": "auto",
            "x": 470,
            "y": 460,
            "wires": []
            "id": "be82df1e7a1f3571",
            "type": "change",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "tot": "jsonata"
                    "t": "set",
                    "p": "array_mean",
                    "pt": "flow",
                    "to": "payload",
                    "tot": "msg"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 2470,
            "y": 380,
            "wires": [
    ]t
    Martin
    Homematic und Homematic IP
    • mickymM Offline
      mickymM Offline
      mickym
      du brauchst keine monatstage etc. du hast doch ein Array und da bildest du einfach den durchschnitt der werte. das Array wid doch jeden monat neu geschrieben
      • mickymM mickym
        MartyBr
        @mickym
        Ich dachte mir das nur als Fallback, wenn iobroker / Node-red mal steht und ein Tag übersprungen wird.
        So klappt es wunderbar und ich fuchse mich so langsam in die Materie ein.
        Martin
        M mickymM 2 Antworten Letzte Antwort
        • M MartyBr
          @mickym
          MartyBr
          @mickym
          Ich sehe gerade den Read IOB Baustein. Liesst dieser die Anzahl der Elemente im Array ein? Ich sehe hier keine Einstellungen oder Code.
          Martin
          • M MartyBr
            @mickym
            mickymM Offline
            mickymM Offline
            mickym
            @martybr aber gerade wenn ein Tag übersprungen wird, ist es doch sinnvoller den Durschnitt der real gemessenen Werte zu nehmen.
              MartyBr
              @mickym
              In meinem Anwendungsfall setze ich die täglichen Temperaturen im Verhältnis zu den Heizungsverbräuchen, also mehr Stromverbrauch der Wärmepumpe bei niedrigeren Außentemperaturen.
              Das dient daher zur Einschätzung der Effektivität der Wärmepumpe.
              Ich hoffe, ich habe hier meinen Ansatz erklären können 🤓
              Martin
              • M MartyBr
                @mickym
                mickymM Offline
                mickymM Offline
                mickym
                @martybr sagte in Wert in dynamische Struktur im ioBroker ablegen:
                @mickym
                na eben, dann ist es doch sinnvoller, wenn deine Arrays sich aus Tageswerten zusammensetzt, davon den Durchschnitt zu nehmen, als durch eine fixe theoretische Anzahl an Tagen. Sprich Dein Array enthält nur 26 Werte im Februar- dann ist es doch sinnvoller den Durchschnitt aus 26 Werten zu nehmen, als die Summe durch 28 zu teilen.
                • mickymM Offline
                  mickymM Offline
                  mickym
                  ja aner mach wie du denkst. ja mit Jsonata kannst du Durchnitt, Summen etc. über Arrays bilden.
                  am einfachsten ist es dann wenn du das Array in einen Datenpunkt schreibst auch gleich die aggregierten Werte in entsprechende Datenpunkte zu schreiben
                  • mickymM mickym
                    MartyBr
                    @mickym
                    Kannst du mir die Syntax nennen? Wie schreibe ich mit JSONata in ein Element des Array?
                    Ich mache mich dann an die Arbeit.
                    Die täglichen Temperaturwerte habe ich ja im Flow. Ich muss sie dann mit save payload.state [i] an die richtige Stelle schreiben.
                    Martin
                    • M MartyBr
                      @mickym
                      mickymM Offline
                      mickymM Offline
                      mickym
                      @martybr na wenn du ein Array in deiner payload bereits hast, dann halt payload[index]
                      das Element muss aber schon existieren
                      • M MartyBr
                        @mickym
                        mickymM Offline
                        mickymM Offline
                        mickym
                        Warum das denn? - Die werden doch jeden Tag einfach hinten angehängt
                        • mickymM mickym
                          MartyBr
                          @mickym
                          Im Normalfall ist das die optimale Lösung. Ich habe den Fall betrachtet, wenn das System Nachts steht und somit der eine Wert nicht generiert wird. In der nächsten Nacht wird dann ein neuer Wert an die Position des ausgefallenen geschrieben. Das ist nicht Systemkritisch, stört mich einfach, weil der Wert für den entsprechenden Tag nicht stimmt.
                          Das scheint aber ein diffiziles Problem zu sein. Aktuell bekomme ich nur Fehler.
                          Martin
                          • M MartyBr
                            @mickym
                            mickymM Offline
                            mickymM Offline
                            mickym
                            @martybr Wie gesagt - ich würde die Position eines Arrays nicht mit einem bestimmten Tag verknüpfen. Sonst hast Du Lücken und das macht alles kompliziert
                            • mickymM mickym
                              MartyBr
                              @mickym
                              Ich habe aber ansonsten das Problem, dass ich die Temperaturwerte nicht mit den Heizungswerten verknüpfen kann. Auch die Heizungswerte laufen in Arrays Tagesgenau ein.
                              Leider bisher aber in Javascript. Ich versuche ja mit deiner Hilfe die "Programme" in Node-Red umzusetzen.
                              Ich habe hier schöne Grafiken, die diese Werte Temperatur Tag x mit dem Energiewert Tag x anzeigen.
                              Ich halte die Tagesgenaue Speicherung zu absolut notwendig. Aktuell läuft es mit dem append. Ein Problem tritt ja nur bei einem Serverausfall auf.
                              Martin
                              • M MartyBr
                                @mickym
                                mickymM Offline
                                mickymM Offline
                                mickym
                                @martybr Gut - wie Du auf einzelne Elemente mittels einer ChangeNode zugreifst, habe ich Dir ja untengepostet.
                                Wenn Du programmatisch ein Array mit einer definierten Zahl an Elementen erstellen willst.
                                [0..payload-1].($:=0)
                                • mickymM mickym
                                  MartyBr
                                  @mickym
                                  Okay, ich setze mich mal dran.
                                  Danke für deine Geduld.
                                  Martin
                                  • mickymM mickym
                                    mickymM Offline
                                    mickymM Offline
                                    mickym
                                    So ich habe Dir mal - glaub nach Deinen Wünschen - das mal theoratisch über ChangeNodes implementiert.
                                    Eingespeist wird eine Temperatur über die Inject Node und über die Change Node habe ich hier mal folgendes gemacht:
                                    1. Regel - Ermittlung der Anzahhl Tage des aktuellen Monats:
                                    $moment().endOf("month").date()
                                    Ermittelt die Anzahl der Tage des aktuellen Monats. (Du siehst wie kurz man das anstelle der function Nodes machen kann).
                                    1. Regel - Erstellt ein Array mit Anzahl Elementen anhand der Tage des aktuellen Monats wird dann durch Einlesen des Datenpunkts ersetzt
                                    [0..numDaysOfMonth-1].($:=0)
                                    1. Regel - Ermittelt den aktuellen Tag des Monats:
                                    $moment().date()
                                    1. Regel - Iteriert durch das Array und setzt am Index (da mit 0 beginnt, also an Position 8), die payload.
                                    $map(array,function($v,$i){$i=dayOfMonth-1 ? payload : $v })
                                    So ich hoffe das hilft Dir weiter:
                                           "id": "b9038fc06bf41c8f",
                                           "type": "inject",
                                           "z": "7e6af0015415146d",
                                           "name": "",
                                           "props": [
                                                   "p": "payload"
                                           "repeat": "",
                                           "crontab": "",
                                           "once": false,
                                           "onceDelay": 0.1,
                                           "topic": "",
                                           "payload": "20.5",
                                           "payloadType": "num",
                                           "x": 150,
                                           "y": 6720,
                                           "wires": [
                                                   "d06e37f57f6a9c68"
                                           "id": "d06e37f57f6a9c68",
                                           "type": "change",
                                           "name": "",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "numDaysOfMonth",
                                                   "pt": "msg",
                                                   "to": "$moment().endOf(\"month\").date()",
                                                   "tot": "jsonata"
                                                   "t": "set",
                                                   "p": "array",
                                                   "pt": "msg",
                                                   "to": "[0..numDaysOfMonth-1].($:=0)",
                                                   "tot": "jsonata"
                                                   "t": "set",
                                                   "p": "dayOfMonth",
                                                   "pt": "msg",
                                                   "tot": "jsonata"
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "to": "$map(array,function($v,$i){$i=dayOfMonth-1 ? payload : $v })",
                                                   "tot": "jsonata"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 330,
                                           "y": 6720,
                                           "wires": [
                                                   "a3565f08d7626565"
                                           "id": "a3565f08d7626565",
                                           "type": "debug",
                                           "name": "Modify element of array",
                                           "active": true,
                                           "tosidebar": true,
                                           "console": false,
                                           "tostatus": false,
                                           "complete": "true",
                                           "targetType": "full",
                                           "statusVal": "",
                                           "x": 570,
                                           "y": 6720,
                                           "wires": []
                                    • mickymM mickym
                                      $moment().date()
                                             "type": "inject",
                                             "name": "",
                                             "props": [
                                                     "p": "payload"
                                             "repeat": "",
                                             "crontab": "",
                                             "once": false,
                                             "onceDelay": 0.1,
                                             "topic": "",
                                             "payload": "20.5",
                                             "x": 150,
                                             "y": 6720,
                                             "wires": [
                                                     "d06e37f57f6a9c68"
                                             "type": "change",
                                             "name": "",
                                             "rules": [
                                                     "t": "set",
                                                     "pt": "msg",
                                                     "tot": "jsonata"
                                                     "t": "set",
                                                     "p": "array",
                                                     "pt": "msg",
                                                     "tot": "jsonata"
                                                     "t": "set",
                                                     "p": "dayOfMonth",
                                                     "pt": "msg",
                                                     "tot": "jsonata"
                                                     "t": "set",
                                                     "p": "payload",
                                                     "pt": "msg",
                                                     "tot": "jsonata"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 330,
                                             "y": 6720,
                                             "wires": [
                                                     "a3565f08d7626565"
                                             "type": "debug",
                                             "active": true,
                                             "tosidebar": true,
                                             "console": false,
                                             "tostatus": false,
                                             "complete": "true",
                                             "statusVal": "",
                                             "x": 570,
                                             "y": 6720,
                                             "wires": []
                                      MartyBr
                                      @mickym
                                      Danke dir. Ich setze das Morgen um. Aktuell muss ich das Rededuell Merz-Scholz noch sacken lassen.
                                      Martin
                                      • mickymM mickym
                                        $moment().date()
                                               "type": "inject",
                                               "name": "",
                                               "props": [
                                                       "p": "payload"
                                               "repeat": "",
                                               "crontab": "",
                                               "once": false,
                                               "onceDelay": 0.1,
                                               "topic": "",
                                               "payload": "20.5",
                                               "x": 150,
                                               "y": 6720,
                                               "wires": [
                                                       "d06e37f57f6a9c68"
                                               "type": "change",
                                               "name": "",
                                               "rules": [
                                                       "t": "set",
                                                       "pt": "msg",
                                                       "tot": "jsonata"
                                                       "t": "set",
                                                       "p": "array",
                                                       "pt": "msg",
                                                       "tot": "jsonata"
                                                       "t": "set",
                                                       "p": "dayOfMonth",
                                                       "pt": "msg",
                                                       "tot": "jsonata"
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "tot": "jsonata"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 330,
                                               "y": 6720,
                                               "wires": [
                                                       "a3565f08d7626565"
                                               "type": "debug",
                                               "active": true,
                                               "tosidebar": true,
                                               "console": false,
                                               "tostatus": false,
                                               "complete": "true",
                                               "statusVal": "",
                                               "x": 570,
                                               "y": 6720,
                                               "wires": []
                                        mickymM Offline
                                        mickymM Offline
                                        mickym
                                        @MartyBr
                                        So hier muss ich selbst immer probieren, wenn ich innerhalb eines Arrays was updaten will und nicht die explizite map Funktion nutzen will.
                                        Um also das X.te Element des Monats einen arrays zu aktualisieren, kann man anstelle von
                                        auch folgendes schreiben:
                                        array#$i.($i=$$.dayOfMonth -1 ? $$.payload : $)
                                               "type": "inject",
                                               "name": "",
                                               "props": [
                                                       "p": "payload"
                                               "repeat": "",
                                               "crontab": "",
                                               "once": false,
                                               "onceDelay": 0.1,
                                               "topic": "",
                                               "payload": "20.5",
                                               "x": 290,
                                               "y": 6720,
                                               "wires": [
                                                       "d06e37f57f6a9c68"
                                               "type": "change",
                                               "name": "",
                                               "rules": [
                                                       "t": "set",
                                                       "pt": "msg",
                                                       "tot": "jsonata"
                                                       "t": "set",
                                                       "p": "array",
                                                       "pt": "msg",
                                                       "tot": "jsonata"
                                                       "t": "set",
                                                       "p": "dayOfMonth",
                                                       "pt": "msg",
                                                       "tot": "jsonata"
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "to": "array#$i.($i=$$.dayOfMonth -1 ? $$.payload : $)",
                                                       "tot": "jsonata"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 470,
                                               "y": 6720,
                                               "wires": [
                                                       "a3565f08d7626565"
                                               "type": "debug",
                                               "active": true,
                                               "tosidebar": true,
                                               "console": false,
                                               "tostatus": false,
                                               "complete": "true",
                                               "statusVal": "",
                                               "x": 710,
                                               "y": 6720,
                                               "wires": []
                                        • mickymM mickym
                                          @MartyBr
                                                 "type": "inject",
                                                 "name": "",
                                                 "props": [
                                                         "p": "payload"
                                                 "repeat": "",
                                                 "crontab": "",
                                                 "once": false,
                                                 "onceDelay": 0.1,
                                                 "topic": "",
                                                 "payload": "20.5",
                                                 "x": 290,
                                                 "y": 6720,
                                                 "wires": [
                                                         "d06e37f57f6a9c68"
                                                 "type": "change",
                                                 "name": "",
                                                 "rules": [
                                                         "t": "set",
                                                         "pt": "msg",
                                                         "tot": "jsonata"
                                                         "t": "set",
                                                         "p": "array",
                                                         "pt": "msg",
                                                         "tot": "jsonata"
                                                         "t": "set",
                                                         "p": "dayOfMonth",
                                                         "pt": "msg",
                                                         "tot": "jsonata"
                                                         "t": "set",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "tot": "jsonata"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 470,
                                                 "y": 6720,
                                                 "wires": [
                                                         "a3565f08d7626565"
                                                 "type": "debug",
                                                 "active": true,
                                                 "tosidebar": true,
                                                 "console": false,
                                                 "tostatus": false,
                                                 "complete": "true",
                                                 "statusVal": "",
                                                 "x": 710,
                                                 "y": 6720,
                                                 "wires": []
                                          MartyBr
                                          @mickym
                                          Vielen Dank. Ich habe den Node in meine Flows eingebaut und lasse das mal ein paar Tage laufen. Dann sollten ja Daten in den Arrays sein.
                                          Die Flows sind nun erheblich kürzer geworden. Wenn alles läuft stelle ich den Flow hier ein.
                                          Vielleicht kann ja noch jemand davon profitieren.
                                          Martin
