  3. Einsteigerfragen
  4. Umzug von Raspberry auf Wyse Box 5070
    5.3k
wyse box 5070umzug
29 Beiträge 6 Kommentatoren 3.6k Aufrufe 5 Beobachtet
  • P Offline
    PB74
    ...hier die Ausgabe von iob_diag der Wyse Box 5070:
    Script v.2024-12-09 Raspbian+zigbee diag+masking
    *** BASE SYSTEM ***
     Static hostname: iobroker002
           Icon name: computer-desktop
             Chassis: desktop 🖥️
              Kernel: Linux 6.1.0-30-amd64
        Architecture: x86-64
     Hardware Vendor: Dell Inc.
      Hardware Model: Wyse 5070 Thin Client
    Firmware Version: 1.34.0
    OS is similar to:
    model name      : Intel(R) Celeron(R) J4105 CPU @ 1.50GHz
    Docker          : false
    Virtualization  : none
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     17:34:46 up 2 min,  1 user,  load average: 0.23, 0.13, 0.05
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** TIME AND TIMEZONES ***
                   Local time: Thu 2025-02-06 17:34:46 CET
               Universal time: Thu 2025-02-06 16:34:46 UTC
                     RTC time: Thu 2025-02-06 16:34:46
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    peter
    HOME=/home/peter
    GROUPS=peter cdrom floppy sudo audio dip video plugdev users netdev iobroker
    iobroker
    [sudo] password for peter:
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            8.1G        742M        7.4G        1.2M        241M        7.4G
    Swap:           1.0G          0B        1.0G
    Total:          9.2G        742M        8.4G
    Active iob-Instances:   5
             7761 M total memory
              693 M used memory
              113 M active memory
              423 M inactive memory
             7072 M free memory
               23 M buffer memory
              207 M swap cache
              976 M total swap
                0 M used swap
              976 M free swap
    top - 17:35:04 up 2 min,  1 user,  load average: 0.17, 0.12, 0.05
    Tasks: 119 total,   1 running, 118 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 20.0 us,  0.0 sy,  0.0 ni, 80.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   7761.7 total,   7070.8 free,    695.8 used,    230.6 buff/cache
    MiB Swap:    977.0 total,    977.0 free,      0.0 used.   7065.9 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  3.8G     0  3.8G   0% /dev
    tmpfs          tmpfs     777M  892K  776M   1% /run
    /dev/sda2      ext4      116G  4.9G  105G   5% /
    tmpfs          tmpfs     3.8G     0  3.8G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    /dev/sda1      vfat      511M  5.9M  506M   2% /boot/efi
    tmpfs          tmpfs     777M     0  777M   0% /run/user/1000
    [Thu Feb  6 17:32:33 2025] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Thu Feb  6 17:32:34 2025] EXT4-fs (sda2): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET      SOURCE    FSTYPE OPTIONS
    /           /dev/sda2 ext4   rw,relatime,errors=remount-ro
    `-/boot/efi /dev/sda1 vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
    /var:
    464M    /var/
    251M    /var/cache
    244M    /var/cache/apt
    175M    /var/lib
    168M    /var/cache/apt/archives
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    799M    /opt/iobroker/iobroker-data/
    793M    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
    8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
    7.4M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_icons-material_esm_index_js.d7ed606b.chunk.js.map
    7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.a9c6d34a.chunk.js.map
    7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.7e9d7842.chunk.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.2
    /usr/bin/node           v20.18.2
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    nodejs:
      Installed: 20.18.2-1nodesource1
      Candidate: 20.18.2-1nodesource1
      Version table:
     *** 20.18.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker002         iobroker002 (version: 7.0.6, hostname: iobroker002   , alive, uptime: 152)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.4.10
    javascript:     8.8.3
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker002                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : iobroker002                              -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker002                              -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker002                              -  enabled
      system.adapter.telegram.0               : telegram              : iobroker002                              - disabled, port: 8443, bind: 0.0.0.0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.4.10   , installed 7.4.10
    Adapter    "backitup"     : 3.0.31   , installed 3.0.31
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "telegram"     : 4.0.0    , installed 4.0.0
    Objects and States
    Objects:        230
    States:         139
    Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists... Done
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          14370      1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14711      555/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14723      536/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14718      536/iobroker.js-con
    tcp6       0      0 :::111                  :::*                    LISTEN      0          14371      1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14713      555/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14764      587/io.admin.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          17024      503/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          13117      1/init
    udp6       0      0 :::111                  :::*                                0          14305      1/init
    2025-02-06 17:32:37.852  - info: host.iobroker002 Delete state "system.host.iobroker002.versions.nodeNewestNext"
    2025-02-06 17:32:37.855  - info: host.iobroker002 Delete state "system.host.iobroker002.versions.npmCurrent"
    2025-02-06 17:32:37.858  - info: host.iobroker002 Delete state "system.host.iobroker002.versions.npmNewest"
    2025-02-06 17:32:37.861  - info: host.iobroker002 Delete state "system.host.iobroker002.versions.npmNewestNext"
    2025-02-06 17:32:37.863  - info: host.iobroker002 Some obsolete host states deleted.
    2025-02-06 17:32:39.257  - info: admin.0 (587) starting. Version 7.4.10 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.2, js-controller: 7.0.6
    2025-02-06 17:32:39.286  - info: admin.0 (587) requesting all objects
    2025-02-06 17:32:39.379  - warn: admin.0 (587) Cannot check node.js versions: Error: getaddrinfo EAI_AGAIN nodejs.org
    2025-02-06 17:32:39.727  - info: admin.0 (587) received all objects
    2025-02-06 17:32:39.767  - warn: admin.0 (587) Cannot update news: getaddrinfo EAI_AGAIN iobroker.live
    2025-02-06 17:32:39.952  - info: admin.0 (587) socket.io server listening on port 8081
    2025-02-06 17:32:39.955  - info: admin.0 (587) http server listening on port 8081
    2025-02-06 17:32:39.955  - info: admin.0 (587) Use link "http://127.0.0.1:8081" to configure.
    2025-02-06 17:32:39.967  - warn: admin.0 (587) Cannot update rating: getaddrinfo EAI_AGAIN rating.iobroker.net
    2025-02-06 17:32:41.874  - info: host.iobroker002 instance system.adapter.javascript.0 in version "8.8.3" started with pid 603
    2025-02-06 17:32:43.377  - info: javascript.0 (603) starting. Version 8.8.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.18.2, js-controller: 7.0.6
    2025-02-06 17:32:43.545  - info: javascript.0 (603) requesting all states
    2025-02-06 17:32:43.546  - info: javascript.0 (603) requesting all objects
    2025-02-06 17:32:43.827  - info: javascript.0 (603) received all objects
    2025-02-06 17:32:43.828  - info: javascript.0 (603) received all states
    2025-02-06 17:32:45.848  - info: host.iobroker002 instance system.adapter.backitup.0 in version "3.0.31" started with pid 627
    2025-02-06 17:32:46.871  - info: backitup.0 (627) starting. Version 3.0.31 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.18.2, js-controller: 7.0.6
    2025-02-06 17:32:46.908  - info: backitup.0 (627) [iobroker] backup will be activated at 02:48 every 1 day(s)
    2025-02-06 17:32:49.838  - info: host.iobroker002 instance system.adapter.discovery.0 in version "5.0.0" started with pid 643
    2025-02-06 17:32:50.802  - info: discovery.0 (643) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.18.2, js-controller: 7.0.6
    • P Offline
      PB74
      ... die Langversion von top:
      top - 17:41:23 up 8 min,  1 user,  load average: 0,00, 0,09, 0,07
      Tasks: 102 total,   1 running, 101 sleeping,   0 stopped,   0 zombie
      %CPU(s):  0,9 us,  0,2 sy,  0,0 ni, 98,8 id,  0,1 wa,  0,0 hi,  0,0 si,  0,0 st
      MiB Spch:   7761,7 total,   6811,9 free,    753,3 used,    438,1 buff/cache
      MiB Swap:    977,0 total,    977,0 free,      0,0 used.   7008,4 avail Spch
          PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     ZEIT+ BEFEHL
          536 iobroker  20   0   21,1g 176212  44552 S   2,7   2,2   0:13.50 iobroker.js-con
          603 iobroker  20   0   21,1g 148772  45028 S   0,7   1,9   0:06.00 io.javascript.0
          587 iobroker  20   0   21,2g 116048  50036 S   0,3   1,5   0:04.60 io.admin.0
          643 iobroker  20   0   21,0g  72664  44336 S   0,3   0,9   0:02.27 io.discovery.0
            1 root      20   0  167680  12040   9052 S   0,0   0,2   0:00.91 systemd
            2 root      20   0       0      0      0 S   0,0   0,0   0:00.00 kthreadd
            3 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rcu_gp
            4 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rcu_par_gp
            5 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 slub_flushwq
            6 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 netns
            9 root      20   0       0      0      0 I   0,0   0,0   0:00.08 kworker/u8:0-events_unbound
           10 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 mm_percpu_wq
           11 root      20   0       0      0      0 I   0,0   0,0   0:00.00 rcu_tasks_kthread
           12 root      20   0       0      0      0 I   0,0   0,0   0:00.00 rcu_tasks_rude_kthread
           13 root      20   0       0      0      0 I   0,0   0,0   0:00.00 rcu_tasks_trace_kthread
           14 root      20   0       0      0      0 S   0,0   0,0   0:00.01 ksoftirqd/0
           15 root      20   0       0      0      0 I   0,0   0,0   0:00.15 rcu_preempt
           16 root      rt   0       0      0      0 S   0,0   0,0   0:00.00 migration/0
           18 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/0
           19 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/1
           20 root      rt   0       0      0      0 S   0,0   0,0   0:00.18 migration/1
           21 root      20   0       0      0      0 S   0,0   0,0   0:00.01 ksoftirqd/1
           23 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kworker/1:0H-events_highpri
           24 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/2
           25 root      rt   0       0      0      0 S   0,0   0,0   0:00.19 migration/2
           26 root      20   0       0      0      0 S   0,0   0,0   0:00.01 ksoftirqd/2
           28 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kworker/2:0H-events_highpri
           29 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/3
           30 root      rt   0       0      0      0 S   0,0   0,0   0:00.20 migration/3
           31 root      20   0       0      0      0 S   0,0   0,0   0:00.01 ksoftirqd/3
           33 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kworker/3:0H-events_highpri
           35 root      20   0       0      0      0 I   0,0   0,0   0:00.21 kworker/u8:1-events_unbound
           38 root      20   0       0      0      0 S   0,0   0,0   0:00.00 kdevtmpfs
           39 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 inet_frag_wq
           40 root      20   0       0      0      0 S   0,0   0,0   0:00.00 kauditd
           41 root      20   0       0      0      0 S   0,0   0,0   0:00.00 khungtaskd
           42 root      20   0       0      0      0 S   0,0   0,0   0:00.00 oom_reaper
           43 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 writeback
           44 root      20   0       0      0      0 S   0,0   0,0   0:00.04 kcompactd0
           45 root      25   5       0      0      0 S   0,0   0,0   0:00.00 ksmd
           47 root      39  19       0      0      0 S   0,0   0,0   0:00.06 khugepaged
           48 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kintegrityd
           49 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kblockd
           50 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 blkcg_punt_bio
           51 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 tpm_dev_wq
           52 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 edac-poller
           53 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 devfreq_wq
           54 root      20   0       0      0      0 I   0,0   0,0   0:00.00 kworker/2:1-cgroup_destroy
           55 root       0 -20       0      0      0 I   0,0   0,0   0:00.01 kworker/0:1H-kblockd
           56 root      20   0       0      0      0 S   0,0   0,0   0:00.00 kswapd0
           58 root      20   0       0      0      0 I   0,0   0,0   0:00.03 kworker/3:1-rcu_gp
           63 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kthrotld
           65 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 acpi_thermal_pm
           66 root      20   0       0      0      0 S   0,0   0,0   0:00.01 hwrng
           67 root      20   0       0      0      0 I   0,0   0,0   0:00.04 kworker/1:2-events
           68 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 mld
      • P PB74
        *** BASE SYSTEM ***
                 Chassis: desktop 🖥️
        OS is similar to:
        Docker          : false
        Kernel          : x86_64
        Userland        : 64 bit
        CPU threads: 4
                      NTP service: active
                  RTC in local TZ: no
        peter
        HOME=/home/peter
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           1.0G          0B        1.0G
                 7761 M total memory
                  693 M used memory
                  113 M active memory
                 7072 M free memory
                   23 M buffer memory
                  207 M swap cache
                  976 M total swap
                    0 M used swap
                  976 M free swap
        *** FILESYSTEM ***
        /var:
        464M    /var/
        251M    /var/cache
        244M    /var/cache/apt
        175M    /var/lib
        USB-Devices by-id:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin:          7.4.10
        javascript:     8.8.3
        Adapter State
        + instance is alive
        Objects and States
        Objects:        230
        States:         139
        Pending Updates: 0
        @pb74 sagte in Umzug von Raspberry auf Wyse Box 5070:
        Setz den peter noch in die Gruppe adm:
        sudo usermod -a -G adm peter
        Ansonsten schaut das gut aus.
        P 1 Antwort Letzte Antwort
          PB74
          @thomas-braun sagte in Umzug von Raspberry auf Wyse Box 5070:
          ... ist erledigt.
          Jetzt könnte ich also mit dem Restore nach https://forum.iobroker.net/topic/77524/iobroker-neuinstallation-mit-iob-backupdateien-des-adapters beginnen?
          • P PB74
            ... ist erledigt.
            @pb74
            Ja.
            • P Offline
              PB74
              Grafana + inluxdb sind nach Deinen Vorgaben unter https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind installiert.
              Was mich noch verunsichert: hat influxdb jetzt schon eine neue Datenbank installiert? Die muss ich doch löschen, bevor das Backup zurückgespielt wird 🤔
              • P PB74
                @pb74
                Zu influxdb kann ich nix sagen. Aber das Wiki zum Backitup-Adapter hat da soweit ich weiß was zum nachlesen.
                • P Offline
                  PB74
                  Irgendetwas mache ich (jede Menge) falsch:
                  Auf der Wyse-Box habe ich die Syntax für Grafana und influxdb so ausgeführt wie unter https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind angegeben.
                  Die Backitup-Konfiguration vom "alten Raspberry" habe ich exportiert und auf der "neuen Wyse-Box" importiert.
                  Dann das influxdb-backup und auch das iobroker-backup vom NAS auf die die lokale Platte meines Windows-Rechners überspielt und im backitup-Adapter über "Backup-Datei hochladen" wiederhergestellt (hoffentlich).
                  Trotzdem lässt sich die influxdb-Instanz nicht starten (bleibt gelb). Wenn ich dort die Verbindung testen will, erscheint die Fehlermeldung "Aggregate error".
                  Stop/Start des iobrokers hat nichts gebracht, Neustart der Wyse-Box auch nicht. Eine Schritt-für-Schritt-Anleitung hab ich auch nicht gefunden...
                  Unter dem Link https://forum.iobroker.net/topic/75332/umzug-auf-einen-raspberry-pi-5?_=1738824743331&lang=de fehlen meines Erachtens nach ein paar Zwischenschritte für den Anfänger; ich kann mich aber auch täuschen und möchte diese Doku nicht infrage stellen...
                  Vielleicht findet sich noch jemand, der mir helfen kann...danke.
                  • P Offline
                    PB74
                    ... vielleicht noch als Hinweis: ich benutze noch Influxdb 1.....
                    • P PB74
                      CodierknechtC Offline
                      Codierknecht
                      Unter dem Link ... fehlen meines Erachtens nach ein paar Zwischenschritte für den Anfänger
                      Meinst Du zu Influx? Das hat ja nix mit der Installation des Pi zu tun.
                      Solche "Zusatzpakete" obliegen dem geneigten Anwender.
                      HmIP|ZigBee|Tasmota|Unifi
                      Zabbix Certified Specialist
                      • P Offline
                        PB74
                        Meine Hoffnung war, diese Anleitung auf meinen Wysebox-Umzug anwenden zu können.
                        Es muss ja irgendwo dokumentiert sein, wie ich eine Influxdb 1 ordnungsgemäß wiederherstelle....wenn ich von einem Raspberry komme.
                        Da gibt es doch genügend Nutzer die vom Raspberry auf NUC umgezogen sind und die Datenbank mitgenommen haben.
                        Das gleiche muss ja auch mit grafana funktionieren.
                        • P PB74
                          Codierknecht
                          @pb74
                          Influx, Grafana, Motioneye, Frigate und was es sonst so alles gibt ist nicht Teil der ioBroker-Installation.
                          Da muss man sich schon selbst aufschlauen und kümmern.
                          Das hat in einer möglichst einfachen Anleitung für den ioBroker auf dem Pi ja auch wenig zu suchen. Es würde den ganzen Kram nur unnötig verkomplizieren.
                          Ich selbst nutze Influx nicht. Kann da also wenig weiterhelfen.
                          Aber Influx ist hier weit verbreitet. Wenn hier niemand antwortet, dann weil der Titel des Thread ja nicht darauf hinweist.
                          Es könnte helfen, dafür einen neuen Thread aufzumachen. Mit einem passenden Titel.
                          Edit
                          Bitte nicht als Vorwurf, sondern allein als Hinweis verstehen!
                          • CodierknechtC Codierknecht
                            @pb74
                            Edit
                            PB74
                            schrieb am zuletzt editiert von PB74
                            @codierknecht sagte in Umzug von Raspberry auf Wyse Box 5070:
                            Das ist ne gute Idee, so hab ich das noch gar nicht gesehen....werd ich machen.
                            ist vollkommen in Ordnung, danke Dir!
                            • P Offline
                              PB74
                              dank verschiedenster Helfer aus diesem Forum läuft meine Wyse-Box 5070 seit 8 Tagen 24/7 und bisher ohne Ausfälle.
                              Alles ließ sich ohne Verlust wiederherstellen, daher noch mal ein großes Dankeschön an @Codierknecht, @Homoran, @Thomas-Braun, @MartinP , @Thomas-Braun und @Marc-Berg sowie alle die ich hier unabsichtlich vergessen habe.
                              Ich vermute, das die 4 GB RAM meines Raspberry 4 bei meiner iobroker-Installation einfach manchmal nicht ausreichten; das neue System mit den 8GB scheint bis jetzt stabiler zu laufen.
                              Auch der Swap wird m.E. nicht genutzt (ich würde in meinem Leichtsinn die 0,8 MB venachlässigen 😁 )
                              Hier nur mal der Kopf von top:
                              top - 12:43:00 up 8 days, 17:57,  1 user,  load average: 0,55, 0,29, 0,19
                              Tasks: 131 total,   2 running, 129 sleeping,   0 stopped,   0 zombie
                              %CPU(s):  6,9 us,  1,0 sy,  0,0 ni, 91,6 id,  0,2 wa,  0,0 hi,  0,3 si,  0,0 st
                              MiB Spch:   7762,2 total,   1098,7 free,   2957,2 used,   4009,4 buff/cache
                              MiB Swap:    977,0 total,    976,2 free,      0,8 used.   4805,0 avail Spch
                              ... und die Langversion von iob diag:
                              Script v.2025-02-02
                              *** BASE SYSTEM ***
                               Static hostname: iobroker001
                                       Chassis: desktop 🖥️
                              OS is similar to:
                              Docker          : false
                              Kernel          : x86_64
                              Userland        : 64 bit
                               12:57:44 up 8 days, 18:12,  2 users,  load average: 0.52, 0.29, 0.22
                              CPU threads: 4
                                             Local time: Mon 2025-02-17 12:57:44 CET
                                         Universal time: Mon 2025-02-17 11:57:44 UTC
                                               RTC time: Mon 2025-02-17 11:57:44
                                            NTP service: active
                                        RTC in local TZ: no
                              peter
                              HOME=/home/peter
                              GROUPS=peter adm cdrom floppy sudo audio dip video plugdev users netdev iobroker
                              iobroker
                              HOME=/home/iobroker
                              Desktop:
                              Terminal:       tty
                              System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
                              *** MEMORY ***
                              Mem:            8.1G        3.1G        1.1G        1.2M        4.2G        5.0G
                              Swap:           1.0G        786K        1.0G
                              Total:          9.2G        3.1G        2.1G
                              Active iob-Instances:   25
                                       7762 M total memory
                                       2970 M used memory
                                       3089 M active memory
                                       3201 M inactive memory
                                       1064 M free memory
                                        576 M buffer memory
                                       3453 M swap cache
                                        976 M total swap
                                          0 M used swap
                                        976 M free swap
                              top - 12:57:44 up 8 days, 18:12,  2 users,  load average: 0.52, 0.29, 0.22
                              Tasks: 139 total,   1 running, 138 sleeping,   0 stopped,   0 zombie
                              %Cpu(s): 20.0 us, 20.0 sy,  0.0 ni, 60.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                              MiB Mem :   7762.2 total,   1063.2 free,   2971.8 used,   4030.3 buff/cache
                              MiB Swap:    977.0 total,    976.2 free,      0.8 used.   4790.4 avail Mem
                              *** FILESYSTEM ***
                              tmpfs          tmpfs     777M  900K  776M   1% /run
                              /dev/sda2      ext4      116G   11G   99G  10% /
                              [Sat Feb  8 18:45:03 2025] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                              [Sat Feb  8 18:45:04 2025] EXT4-fs (sda2): re-mounted. Quota mode: none.
                              /var:
                              2.9G    /var/
                              1.4G    /var/lib
                              1.3G    /var/log/journal/e793cd39d1d6469ead98053306475c23
                              1.3G    /var/log
                              Archived and active journals take up 1.2G in the file system.
                              584M    /opt/iobroker/backups/
                              1.6G    /opt/iobroker/iobroker-data/
                              1.3G    /opt/iobroker/iobroker-data/files
                              25M     /opt/iobroker/iobroker-data/objects.jsonl
                              24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                              24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
                              24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
                              24M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
                              USB-Devices by-id:
                              /usr/bin/nodejs         v20.18.3
                              /usr/bin/node           v20.18.3
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              /usr/bin/corepack       0.30.0
                              nodejs:
                                Installed: 20.18.3-1nodesource1
                                Candidate: 20.18.3-1nodesource1
                                Version table:
                               *** 20.18.3-1nodesource1 1001
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Hosts:
                              iobroker001         iobroker001 (version: 7.0.6, hostname: iobroker001   , alive, uptime: 756760)
                              admin:          7.4.10
                              javascript:     8.8.3
                              nodejs modules from github:     1
                              +-- iobroker.time-switch@2.2.2 (git+ssh://git@github.com/walli545/ioBroker.time-switch.git#45b5addb484d270dcac6d1bfdb1a9f86b444d80e)
                              Adapter State
                              + system.adapter.admin.0                  : admin                 : iobroker001                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              + system.adapter.backitup.0               : backitup              : iobroker001                              -  enabled
                              + system.adapter.discovery.0              : discovery             : iobroker001                              -  enabled
                              + system.adapter.hm-rega.0                : hm-rega               : iobroker001                              -  enabled
                              + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker001                              -  enabled, port: 0
                              + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker001                              -  enabled, port: 0
                              + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker001                              -  enabled, port: 0
                                system.adapter.icons-icons8.0           : icons-icons8          : iobroker001                              - disabled
                                system.adapter.icons-material-png.0     : icons-material-png    : iobroker001                              - disabled
                                system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker001                              - disabled
                                system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker001                              - disabled
                                system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker001                              - disabled
                              + system.adapter.influxdb.0               : influxdb              : iobroker001                              -  enabled, port: 8086
                              + system.adapter.javascript.0             : javascript            : iobroker001                              -  enabled
                              + system.adapter.modbus.0                 : modbus                : iobroker001                              -  enabled
                              + system.adapter.mytime.0                 : mytime                : iobroker001                              -  enabled
                              + system.adapter.opendtu.0                : opendtu               : iobroker001                              -  enabled
                                system.adapter.pvforecast.0             : pvforecast            : iobroker001                              - disabled
                                system.adapter.pvforecast.1             : pvforecast            : iobroker001                              - disabled
                                system.adapter.rpi2.0                   : rpi2                  : iobroker001                              - disabled
                              + system.adapter.s7.0                     : s7                    : iobroker001                              -  enabled
                              + system.adapter.s7.1                     : s7                    : iobroker001                              -  enabled
                              + system.adapter.s7.2                     : s7                    : iobroker001                              -  enabled
                              + system.adapter.socketio.0               : socketio              : iobroker001                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                              + system.adapter.sonoff.0                 : sonoff                : iobroker001                              -  enabled, port: 1883, bind: 192.168.1.141
                                system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker001                              - disabled
                              + system.adapter.telegram.0               : telegram              : iobroker001                              -  enabled, port: 8443, bind: 0.0.0.0
                              + system.adapter.terminal.0               : terminal              : iobroker001                              -  enabled, port: 8090, bind: 0.0.0.0, run as: admin
                              + system.adapter.time-switch.0            : time-switch           : iobroker001                              -  enabled
                              + system.adapter.tr-064.0                 : tr-064                : iobroker001                              -  enabled
                              + system.adapter.vis-2.0                  : vis-2                 : iobroker001                              -  enabled
                                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker001                              - disabled
                                system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker001                              - disabled
                              + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker001                              -  enabled
                                system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker001                              - disabled
                                system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker001                              - disabled
                                system.adapter.vis-plumb.0              : vis-plumb             : iobroker001                              - disabled
                                system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker001                              - disabled
                                system.adapter.vis.0                    : vis                   : iobroker001                              -  enabled
                              + system.adapter.web.0                    : web                   : iobroker001                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                              + instance is alive
                              │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
                              Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                              Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                              Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
                              Adapter    "modbus"       : 6.3.2    , installed 6.3.2
                              Adapter    "mytime"       : 1.4.0    , installed 1.4.0
                              Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
                              Adapter    "pvforecast"   : 4.1.0    , installed 4.1.0
                              Adapter    "rpi2"         : 2.3.1    , installed 2.3.1
                              Adapter    "s7"           : 1.4.3    , installed 1.4.3
                              Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
                              Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                              Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
                              Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
                              Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                              Adapter    "web"          : 6.2.5    , installed 6.2.5
                              Objects and States
                              Objects:        5696
                              States:         4812
                              Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
                              Hit:2 http://deb.debian.org/debian bookworm InRelease
                              Hit:3 https://repos.influxdata.com/debian stable InRelease
                              Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                              Hit:5 https://apt.grafana.com stable InRelease
                              Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
                              Pending Updates: 0
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17702      470/sshd: /usr/sbin
                              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          12798      1/init
                              tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        17710      495/influxd
                              tcp        0      0 192.168.1.141:1883      0.0.0.0:*               LISTEN      1001       20689      894/io.sonoff.0
                              tcp        0      0 192.168.1.141:2001      0.0.0.0:*               LISTEN      1001       21877      767/io.hm-rpc.0
                              tcp        0      0 192.168.1.141:2010      0.0.0.0:*               LISTEN      1001       21898      785/io.hm-rpc.1
                              tcp        0      0 192.168.1.141:8701      0.0.0.0:*               LISTEN      1001       22576      804/io.hm-rpc.2
                              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16148      540/iobroker.js-con
                              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16143      540/iobroker.js-con
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          17704      470/sshd: /usr/sbin
                              tcp6       0      0 :::111                  :::*                    LISTEN      0          12799      1/init
                              tcp6       0      0 :::3000                 :::*                    LISTEN      104        13207      539/grafana
                              tcp6       0      0 :::8090                 :::*                    LISTEN      1001       22770      969/io.terminal.0
                              tcp6       0      0 :::8084                 :::*                    LISTEN      1001       22745      954/io.socketio.0
                              tcp6       0      0 :::8086                 :::*                    LISTEN      999        17739      495/influxd
                              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       19509      610/io.admin.0
                              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22801      999/io.web.0
                              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16097      433/dhclient
                              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          14806      1/init
                              udp6       0      0 :::111                  :::*                                0          1340       1/init
                              2025-02-17 10:38:45.989  - info: javascript.0 (677) Start JavaScript script.js.common.Gerate_Zaehlen_V1 (Javascript/js)
                              2025-02-17 10:38:46.020  - info: javascript.0 (677) script.js.common.Gerate_Zaehlen_V1: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                              2025-02-17 10:42:05.940  - info: javascript.0 (677) Stopping script script.js.common.Gerate_Zaehlen_V1
                              2025-02-17 10:42:06.033  - info: javascript.0 (677) Start JavaScript script.js.common.Gerate_Zaehlen_V1 (Javascript/js)
                              2025-02-17 10:42:06.095  - info: javascript.0 (677) script.js.common.Gerate_Zaehlen_V1: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                              2025-02-17 10:42:15.949  - info: javascript.0 (677) Stopping script script.js.common.Gerate_Zaehlen_V1
                              2025-02-17 10:42:16.081  - info: javascript.0 (677) Start JavaScript script.js.common.Gerate_Zaehlen_V1 (Javascript/js)
                              2025-02-17 10:42:16.115  - info: javascript.0 (677) script.js.common.Gerate_Zaehlen_V1: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                              2025-02-17 10:44:58.721  - info: web.0 (999) ==> Connected system.user.admin from ::ffff:192.168.1.130
                              2025-02-17 10:46:28.367  - info: web.0 (999) <== Disconnect system.user.admin from ::ffff:192.168.1.130 vis.0
                              2025-02-17 10:55:28.230  - info: web.0 (999) ==> Connected system.user.admin from ::ffff:192.168.1.180
                              2025-02-17 10:58:02.345  - info: web.0 (999) <== Disconnect system.user.admin from ::ffff:192.168.1.180 vis.0
                              2025-02-17 11:00:00.116  - info: javascript.0 (677) script.js.common.Astrozeiten: Astro: Gültige Zeiten: [aktueller Tag: 8] | [nächster Tag: 6] | [Aktualisiert: 0] | Aktuelle Tageszeit: später Vormittag | Kommende Tageszeit: Mittag
                              2025-02-17 11:30:00.081  - info: javascript.0 (677) script.js.common.Astrozeiten: Astro: Gültige Zeiten: [aktueller Tag: 8] | [nächster Tag: 6] | [Aktualisiert: 0] | Aktuelle Tageszeit: später Vormittag | Kommende Tageszeit: Mittag
                              2025-02-17 12:00:00.117  - info: javascript.0 (677) script.js.common.Astrozeiten: Astro: Gültige Zeiten: [aktueller Tag: 8] | [nächster Tag: 6] | [Aktualisiert: 0] | Aktuelle Tageszeit: später Vormittag | Kommende Tageszeit: Mittag
                              2025-02-17 12:30:00.116  - info: javascript.0 (677) script.js.common.Astrozeiten: Astro: Gültige Zeiten: [aktueller Tag: 7] | [nächster Tag: 6] | [Aktualisiert: 1] | Aktuelle Tageszeit: Mittag | Kommende Tageszeit: früher Abend
                              2025-02-17 12:39:46.252  - info: javascript.0 (677) Stopping script script.js.common.Gerate_Zaehlen_V1
                              2025-02-17 12:39:46.345  - info: javascript.0 (677) Start JavaScript script.js.common.Gerate_Zaehlen_V1 (Javascript/js)
                              2025-02-17 12:39:46.433  - info: javascript.0 (677) script.js.common.Gerate_Zaehlen_V1: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                              2025-02-17 12:40:16.215  - info: javascript.0 (677) Stopping script script.js.common.Gerate_Zaehlen_V1
                              2025-02-17 12:40:16.265  - info: javascript.0 (677) Start JavaScript script.js.common.Gerate_Zaehlen_V1 (Javascript/js)
                              2025-02-17 12:40:16.297  - info: javascript.0 (677) script.js.common.Gerate_Zaehlen_V1: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                              2025-02-17 12:40:36.242  - info: javascript.0 (677) Stopping script script.js.common.Gerate_Zaehlen_V1
                              2025-02-17 12:40:36.345  - info: javascript.0 (677) Start JavaScript script.js.common.Gerate_Zaehlen_V1 (Javascript/js)
                              2025-02-17 12:40:36.378  - info: javascript.0 (677) script.js.common.Gerate_Zaehlen_V1: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                              Etwas ist mir aber noch unklar...
                              Beim Ausführen von ``ìob fix``` erhalte ich folgende Meldung:
                              Your system is booting into 'graphical.target', which means that a user interface or desktop is available. Usually a server is running without a desktop to have more RAM available. Do you want to switch to 'multi-user.target'? (y/N)
                              In einem anderen Thread habe ich zwar darüber gelesen aber nicht verstanden, ob bzw. was man da ändern sollte...
                              Ist eine Änderung empfehlenswert oder sollte man die Finger davon lassen wenn das System läuft?
                              Danke für eure Antworten!
                              • P PB74
                                Script v.2025-02-02
                                *** BASE SYSTEM ***
                                         Chassis: desktop 🖥️
                                OS is similar to:
                                Docker          : false
                                Kernel          : x86_64
                                Userland        : 64 bit
                                CPU threads: 4
                                              NTP service: active
                                          RTC in local TZ: no
                                peter
                                HOME=/home/peter
                                iobroker
                                HOME=/home/iobroker
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                         7762 M total memory
                                         2970 M used memory
                                         1064 M free memory
                                          576 M buffer memory
                                         3453 M swap cache
                                          976 M total swap
                                            0 M used swap
                                          976 M free swap
                                *** FILESYSTEM ***
                                /var:
                                2.9G    /var/
                                1.4G    /var/lib
                                1.3G    /var/log
                                USB-Devices by-id:
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                nodejs:
                                  Version table:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                Hosts:
                                admin:          7.4.10
                                javascript:     8.8.3
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        5696
                                States:         4812
                                Pending Updates: 0
                                Ich würde es auf 'multi-user' umstellen.
