  4. Node-Red
  5. Gelöst: Wert in dynamische Struktur im ioBroker ablegen
    6.4k
91 Beiträge 2 Kommentatoren 13.6k Aufrufe 2 Beobachtet
  • M MartyBr
    @mickym
    Ich habe es mal so gemacht:
            "id": "7e0364b0b8f9043e",
            "type": "mqtt in",
            "z": "71de45f27137890c",
            "name": "Vitovent ZuluftTemp",
            "topic": "vitocal/ZuluftTemp",
            "qos": "0",
            "datatype": "auto-detect",
            "broker": "bf311140.13d2b8",
            "nl": false,
            "rap": true,
            "rh": 0,
            "inputs": 0,
            "x": 110,
            "y": 80,
            "wires": [
                    "f9c4e37a0e08b272"
            "id": "f9c4e37a0e08b272",
            "type": "change",
            "name": "",
            "rules": [
                    "t": "set",
                    "p": "datum",
                    "pt": "msg",
                    "to": "$moment().locale('de').format('YYYY.MMMM')",
                    "tot": "jsonata"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 330,
            "y": 80,
            "wires": [
                    "4b7e157254dd9a42"
            "id": "4b7e157254dd9a42",
            "type": "change",
            "name": "März zu Maerz",
            "rules": [
                    "t": "change",
                    "p": "datum",
                    "pt": "msg",
                    "from": "März",
                    "fromt": "str",
                    "to": "Maerz",
                    "tot": "str"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 540,
            "y": 80,
            "wires": [
                    "db5352ef5569bd02"
            "id": "db5352ef5569bd02",
            "type": "change",
            "name": "",
            "rules": [
                    "t": "set",
                    "p": "topic",
                    "pt": "msg",
                    "to": "\"0_userdata.0.Test1.Test2.\" & datum & \".\"",
                    "tot": "jsonata"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 740,
            "y": 80,
            "wires": [
                    "5f919db0295bc25c",
                    "9795ea0c497cd9c7"
            "id": "5f919db0295bc25c",
            "type": "debug",
            "name": "topic",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "complete": "payload",
            "targetType": "msg",
            "statusVal": "",
            "statusType": "auto",
            "x": 730,
            "y": 20,
            "wires": []
            "id": "9795ea0c497cd9c7",
            "type": "change",
            "name": "Variable",
            "rules": [
                    "t": "set",
                    "p": "topic",
                    "pt": "msg",
                    "to": "topic & \"zuluft-ganzneu\"",
                    "tot": "jsonata"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 920,
            "y": 80,
            "wires": [
                    "f0dd9b6950d71727",
                    "5ce63ee6255c1fd2"
            "id": "5ce63ee6255c1fd2",
            "type": "debug",
            "name": "topic2",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "statusVal": "",
            "x": 1110,
            "y": 20,
            "wires": []
            "id": "f0dd9b6950d71727",
            "type": "ioBroker out",
            "name": "",
            "topic": "",
            "ack": "true",
            "autoCreate": "true",
            "stateName": "zuluft-neu",
            "role": "state",
            "payloadType": "",
            "readonly": "",
            "stateUnit": "°C",
            "stateMin": "",
            "stateMax": "",
            "x": 1140,
            "y": 80,
            "wires": []
            "id": "bf311140.13d2b8",
            "type": "mqtt-broker",
            "name": "Mosquito-Server",
            "broker": "192.168.178.10",
            "port": "1883",
            "clientid": "",
            "autoConnect": true,
            "usetls": false,
            "compatmode": false,
            "protocolVersion": "4",
            "keepalive": "60",
            "cleansession": true,
            "autoUnsubscribe": true,
            "birthTopic": "",
            "birthQos": "0",
            "birthPayload": "",
            "birthMsg": {},
            "closeTopic": "",
            "closeQos": "0",
            "closePayload": "",
            "closeMsg": {},
            "willTopic": "",
            "willQos": "0",
            "willPayload": "",
            "willMsg": {},
            "userProps": "",
            "sessionExpiry": ""
    Die würde dann die ersten drei Chane Nodes in den Subflow speichern.
    Besteht eine Möglichkeit, den Change Node Variable irgendwo nachvollziehbar abzulegen?
    mickymM Offline
    mickymM Offline
    mickym
    @martybr Ich habe Dir doch gerade einen neuen Subflow geschickt - schau Dir den lieber mal an - das was Du gemacht hast, das funktioniert nicht. - Wie gesagt ich habe jetzt das Originaltopic genommen und einen variablen Basispfad über eine Variable, um es Dir zu zeigen. Du kannst natürlich auch noch weitere Variablen im Subflow nutzen - aber wie gesagt, das Originaltopic ist besser - weil Du dann auch mit EINER Subflow-Node viele Datenpunkte schreiben kannst.
    • mickymM mickym
      MartyBr
      @mickym
      Habe ich zu spät gesehen. Dein Flow funktioniert perfekt, ich habe nur einen Change nach dem MQTT gesetzt, da dieser einen hierarchischen DP erzeugt (..virocal/zuluft)
      Nun funktioniert es perfekt. Vielen Dank. Jetzt habe ich das System der Variablen verstanden. Ich muss mir trotzdem das Konzept hinter env(basePath) anschauen.
      Hier mein/unser Ergebnis:
              "id": "ae673cf6cd8433a0",
              "type": "subflow",
              "name": "Datum in Topic",
              "info": "",
              "category": "",
              "in": [
                      "x": 60,
                      "y": 80,
                      "wires": [
                              "id": "2e1ea06b2e94bf1a"
              "out": [
                      "x": 820,
                      "y": 80,
                      "wires": [
                              "id": "fc37f5f9d2b0297b",
                              "port": 0
              "env": [
                      "name": "basePath",
                      "type": "str",
                      "value": "Test1.Test2"
              "meta": {},
              "color": "#DDAA99"
              "id": "2e1ea06b2e94bf1a",
              "type": "change",
              "z": "ae673cf6cd8433a0",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "datum",
                      "pt": "msg",
                      "tot": "jsonata"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 230,
              "y": 80,
              "wires": [
                      "0e8de9437c3c420a"
              "id": "0e8de9437c3c420a",
              "type": "change",
              "rules": [
                      "t": "change",
                      "p": "datum",
                      "pt": "msg",
                      "from": "März",
                      "fromt": "str",
                      "to": "Maerz",
                      "tot": "str"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 440,
              "y": 80,
              "wires": [
                      "fc37f5f9d2b0297b"
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "topic",
                      "pt": "msg",
                      "to": "\"0_userdata.0.\"  & $env(\"basePath\") & \".\" & datum & \".\" & topic",
                      "tot": "jsonata"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 660,
              "y": 80,
              "wires": [
              "id": "71de45f27137890c",
              "type": "tab",
              "label": "Datum",
              "disabled": false,
              "info": "",
              "env": []
              "name": "",
              "topic": "",
              "ack": "true",
              "role": "state",
              "payloadType": "",
              "readonly": "",
              "stateUnit": "°C",
              "stateMin": "",
              "stateMax": "",
              "x": 720,
              "y": 80,
              "wires": []
              "type": "mqtt in",
              "qos": "0",
              "nl": false,
              "rap": true,
              "rh": 0,
              "inputs": 0,
              "x": 110,
              "y": 80,
              "wires": [
                      "90912a5dffeb17cc"
              "id": "e4826cebe9af4d64",
              "type": "debug",
              "name": "payload und topic",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 510,
              "y": 20,
              "wires": []
              "id": "5267d5edc8abe331",
              "type": "subflow:ae673cf6cd8433a0",
              "env": [
                      "name": "basePath",
                      "value": "Test1.Test5",
                      "type": "str"
              "x": 520,
              "y": 80,
              "wires": [
                      "e4826cebe9af4d64",
                      "f0dd9b6950d71727"
              "id": "90912a5dffeb17cc",
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "topic",
                      "pt": "msg",
                      "to": "Zuluft-Temp",
                      "tot": "str"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 320,
              "y": 80,
              "wires": [
                      "5267d5edc8abe331",
                      "527e1cef1285c117"
              "id": "527e1cef1285c117",
              "type": "debug",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 270,
              "y": 20,
              "wires": []
              "port": "1883",
              "clientid": "",
              "usetls": false,
              "keepalive": "60",
              "birthTopic": "",
              "birthQos": "0",
              "birthPayload": "",
              "birthMsg": {},
              "closeTopic": "",
              "closeQos": "0",
              "closePayload": "",
              "closeMsg": {},
              "willTopic": "",
              "willQos": "0",
              "willPayload": "",
              "willMsg": {},
              "userProps": "",
              "sessionExpiry": ""
      Martin
      Homematic und Homematic IP
      • M MartyBr
        @mickym
                "type": "subflow",
                "info": "",
                "category": "",
                "in": [
                        "x": 60,
                        "y": 80,
                        "wires": [
                "out": [
                        "x": 820,
                        "y": 80,
                        "wires": [
                                "port": 0
                "env": [
                        "name": "basePath",
                        "type": "str",
                "meta": {},
                "color": "#DDAA99"
                "type": "change",
                "name": "",
                "rules": [
                        "t": "set",
                        "p": "datum",
                        "pt": "msg",
                        "tot": "jsonata"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 230,
                "y": 80,
                "wires": [
                        "0e8de9437c3c420a"
                "type": "change",
                "rules": [
                        "t": "change",
                        "p": "datum",
                        "pt": "msg",
                        "from": "März",
                        "fromt": "str",
                        "to": "Maerz",
                        "tot": "str"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 440,
                "y": 80,
                "wires": [
                        "fc37f5f9d2b0297b"
                "type": "change",
                "name": "",
                "rules": [
                        "t": "set",
                        "p": "topic",
                        "pt": "msg",
                        "tot": "jsonata"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 660,
                "y": 80,
                "wires": [
                "type": "tab",
                "label": "Datum",
                "disabled": false,
                "info": "",
                "env": []
                "name": "",
                "topic": "",
                "ack": "true",
                "role": "state",
                "payloadType": "",
                "readonly": "",
                "stateUnit": "°C",
                "stateMin": "",
                "stateMax": "",
                "x": 720,
                "y": 80,
                "wires": []
                "type": "mqtt in",
                "qos": "0",
                "nl": false,
                "rap": true,
                "rh": 0,
                "inputs": 0,
                "x": 110,
                "y": 80,
                "wires": [
                        "90912a5dffeb17cc"
                "type": "debug",
                "active": true,
                "tosidebar": true,
                "console": false,
                "tostatus": false,
                "statusVal": "",
                "x": 510,
                "y": 20,
                "wires": []
                "env": [
                        "name": "basePath",
                        "type": "str"
                "x": 520,
                "y": 80,
                "wires": [
                        "e4826cebe9af4d64",
                        "f0dd9b6950d71727"
                "type": "change",
                "name": "",
                "rules": [
                        "t": "set",
                        "p": "topic",
                        "pt": "msg",
                        "tot": "str"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 320,
                "y": 80,
                "wires": [
                        "5267d5edc8abe331",
                        "527e1cef1285c117"
                "type": "debug",
                "active": true,
                "tosidebar": true,
                "console": false,
                "tostatus": false,
                "statusVal": "",
                "x": 270,
                "y": 20,
                "wires": []
                "port": "1883",
                "clientid": "",
                "usetls": false,
                "keepalive": "60",
                "birthTopic": "",
                "birthQos": "0",
                "birthPayload": "",
                "birthMsg": {},
                "closeTopic": "",
                "closeQos": "0",
                "closePayload": "",
                "closeMsg": {},
                "willTopic": "",
                "willQos": "0",
                "willPayload": "",
                "willMsg": {},
                "userProps": "",
                "sessionExpiry": ""
        mickymM Offline
        mickymM Offline
        mickym
        @martybr sagte in Wert in dynamische Struktur im ioBroker ablegen:
        Wie gesagt - hast Du ja super gemacht - kannst Du nun mit dem topic mehrere datenpunkte und oder sogar Hierarchien erzeugen.
        So habe ich ja auch meinen Subflow erzeugt mit dem Du ganze JSONS oder Bäume in iobroker Einzelwerte zerlegen kannst.
        Die Variablen in einer Subflow - gelten nur für diese Instanz - so kannst Du also eine ganze Menge in einer Instanz eines Subflows parametrisieren.
        Schau Dir mal meinen Subflow an, der JSONS oder ganze Bäume in Einzelwerte zerlegt:
        https://forum.iobroker.net/topic/43856/json-oder-javascript-objekt-in-iobroker-datenpunkte-zerlegen
        • mickymM mickym
          MartyBr
          @mickym
          Jetzt bin auf den Geschmack gekommen. Ich habe jetzt versucht, einen JSON-Datenpunkt anzulegen. Das sieht auf dem ersten Blick auch gut aus. In kann aber im Objektbaum ioBroker die Daten nicht öffnen bzw. bearbeiten.
          Hier mal die Infos:
          Datensatz:
          Flow:
                  "type": "subflow",
                  "info": "",
                  "category": "",
                  "in": [
                          "x": 60,
                          "y": 80,
                          "wires": [
                  "out": [
                          "x": 820,
                          "y": 80,
                          "wires": [
                                  "port": 0
                  "env": [
                          "name": "basePath",
                          "type": "str",
                  "meta": {},
                  "color": "#DDAA99"
                  "type": "change",
                  "name": "",
                  "rules": [
                          "t": "set",
                          "p": "datum",
                          "pt": "msg",
                          "tot": "jsonata"
                  "action": "",
                  "property": "",
                  "from": "",
                  "to": "",
                  "reg": false,
                  "x": 230,
                  "y": 80,
                  "wires": [
                          "0e8de9437c3c420a"
                  "type": "change",
                  "rules": [
                          "t": "change",
                          "p": "datum",
                          "pt": "msg",
                          "from": "März",
                          "fromt": "str",
                          "to": "Maerz",
                          "tot": "str"
                  "action": "",
                  "property": "",
                  "from": "",
                  "to": "",
                  "reg": false,
                  "x": 440,
                  "y": 80,
                  "wires": [
                          "fc37f5f9d2b0297b"
                  "type": "change",
                  "name": "",
                  "rules": [
                          "t": "set",
                          "p": "topic",
                          "pt": "msg",
                          "tot": "jsonata"
                  "action": "",
                  "property": "",
                  "from": "",
                  "to": "",
                  "reg": false,
                  "x": 660,
                  "y": 80,
                  "wires": [
                  "id": "fad92726ff7c3254",
                  "type": "tab",
                  "label": "JSON",
                  "disabled": false,
                  "info": "",
                  "env": []
                  "id": "29a754f2b7a96a31",
                  "type": "mqtt in",
                  "z": "fad92726ff7c3254",
                  "name": "ZuluftTemp",
                  "qos": "0",
                  "nl": false,
                  "rap": true,
                  "rh": 0,
                  "inputs": 0,
                  "x": 100,
                  "y": 120,
                  "wires": [
                          "5026b4d763ed7dcc"
                  "id": "535565225c8e6f99",
                  "env": [
                          "name": "basePath",
                          "value": "Test1.Test7",
                          "type": "str"
                  "x": 780,
                  "y": 180,
                  "wires": [
                          "05ad3c7ae6fe582b",
                          "9c9e217c842acefc"
                  "id": "05ad3c7ae6fe582b",
                  "name": "",
                  "topic": "",
                  "ack": "true",
                  "role": "state",
                  "payloadType": "object",
                  "readonly": "",
                  "stateUnit": "°C",
                  "stateMin": "",
                  "stateMax": "",
                  "x": 980,
                  "y": 180,
                  "wires": []
                  "id": "5026b4d763ed7dcc",
                  "type": "change",
                  "name": "Zuluft",
                  "rules": [
                          "t": "set",
                          "p": "topic",
                          "pt": "msg",
                          "tot": "str"
                  "action": "",
                  "property": "",
                  "from": "",
                  "to": "",
                  "reg": false,
                  "x": 310,
                  "y": 120,
                  "wires": [
                          "766be49e74305196"
                  "id": "a3c1535e1da94552",
                  "type": "mqtt in",
                  "name": "AbluftTemp",
                  "topic": "vitocal/AbluftTemp",
                  "qos": "0",
                  "nl": false,
                  "rap": true,
                  "rh": 0,
                  "inputs": 0,
                  "x": 110,
                  "y": 240,
                  "wires": [
                          "225419c87f910c3e"
                  "id": "225419c87f910c3e",
                  "type": "change",
                  "name": "Abluft",
                  "rules": [
                          "t": "set",
                          "p": "topic",
                          "pt": "msg",
                          "to": "Abluft-Temp",
                          "tot": "str"
                  "action": "",
                  "property": "",
                  "from": "",
                  "to": "",
                  "reg": false,
                  "x": 310,
                  "y": 240,
                  "wires": [
                          "766be49e74305196"
                  "id": "766be49e74305196",
                  "type": "join",
                  "name": "",
                  "mode": "custom",
                  "build": "object",
                  "property": "payload",
                  "propertyType": "msg",
                  "key": "topic",
                  "joiner": "\\n",
                  "joinerType": "str",
                  "accumulate": true,
                  "timeout": "60",
                  "count": "2",
                  "reduceRight": false,
                  "reduceExp": "",
                  "reduceInit": "",
                  "reduceInitType": "",
                  "reduceFixup": "",
                  "x": 430,
                  "y": 180,
                  "wires": [
                          "dd61fc92c8961b14",
                          "457c8ae43cf33de1"
                  "id": "224380ff0709c559",
                  "type": "json",
                  "name": "",
                  "action": "",
                  "pretty": true,
                  "x": 610,
                  "y": 180,
                  "wires": [
                          "c828c8f4b32a9c0c",
                          "535565225c8e6f99"
                  "id": "dd61fc92c8961b14",
                  "type": "debug",
                  "name": "debug 174",
                  "active": true,
                  "tosidebar": true,
                  "console": false,
                  "tostatus": false,
                  "complete": "false",
                  "statusVal": "",
                  "x": 510,
                  "y": 80,
                  "wires": []
                  "id": "c828c8f4b32a9c0c",
                  "type": "debug",
                  "name": "debug 175",
                  "active": true,
                  "tosidebar": true,
                  "console": false,
                  "tostatus": false,
                  "statusVal": "",
                  "x": 710,
                  "y": 100,
                  "wires": []
                  "id": "9c9e217c842acefc",
                  "type": "debug",
                  "name": "debug 176",
                  "active": true,
                  "tosidebar": true,
                  "console": false,
                  "tostatus": false,
                  "statusVal": "",
                  "x": 950,
                  "y": 100,
                  "wires": []
                  "id": "457c8ae43cf33de1",
                  "type": "change",
                  "name": "",
                  "rules": [
                          "t": "set",
                          "p": "topic",
                          "pt": "msg",
                          "to": "vitovent300",
                          "tot": "str"
                  "action": "",
                  "property": "",
                  "from": "",
                  "to": "",
                  "reg": false,
                  "x": 540,
                  "y": 300,
                  "wires": [
                          "224380ff0709c559",
                          "f92533e2c4de9cf4"
                  "id": "f92533e2c4de9cf4",
                  "type": "debug",
                  "name": "debug 177",
                  "active": true,
                  "tosidebar": true,
                  "console": false,
                  "tostatus": false,
                  "statusVal": "",
                  "x": 730,
                  "y": 360,
                  "wires": []
                  "port": "1883",
                  "clientid": "",
                  "usetls": false,
                  "keepalive": "60",
                  "birthTopic": "",
                  "birthQos": "0",
                  "birthPayload": "",
                  "birthMsg": {},
                  "closeTopic": "",
                  "closeQos": "0",
                  "closePayload": "",
                  "closeMsg": {},
                  "willTopic": "",
                  "willQos": "0",
                  "willPayload": "",
                  "willMsg": {},
                  "userProps": "",
                  "sessionExpiry": ""
          Müssen evtl eckige Klammern um den Jason gesetzt werden (also [json]?
          Martin
          • M MartyBr
            @mickym
            Hier mal die Infos:
            Datensatz:
            Flow:
                    "type": "subflow",
                    "info": "",
                    "category": "",
                    "in": [
                            "x": 60,
                            "y": 80,
                            "wires": [
                    "out": [
                            "x": 820,
                            "y": 80,
                            "wires": [
                                    "port": 0
                    "env": [
                            "name": "basePath",
                            "type": "str",
                    "meta": {},
                    "color": "#DDAA99"
                    "type": "change",
                    "name": "",
                    "rules": [
                            "t": "set",
                            "p": "datum",
                            "pt": "msg",
                            "tot": "jsonata"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 230,
                    "y": 80,
                    "wires": [
                            "0e8de9437c3c420a"
                    "type": "change",
                    "rules": [
                            "t": "change",
                            "p": "datum",
                            "pt": "msg",
                            "from": "März",
                            "fromt": "str",
                            "to": "Maerz",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 440,
                    "y": 80,
                    "wires": [
                            "fc37f5f9d2b0297b"
                    "type": "change",
                    "name": "",
                    "rules": [
                            "t": "set",
                            "p": "topic",
                            "pt": "msg",
                            "tot": "jsonata"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 660,
                    "y": 80,
                    "wires": [
                    "type": "tab",
                    "label": "JSON",
                    "disabled": false,
                    "info": "",
                    "env": []
                    "type": "mqtt in",
                    "qos": "0",
                    "nl": false,
                    "rap": true,
                    "rh": 0,
                    "inputs": 0,
                    "x": 100,
                    "y": 120,
                    "wires": [
                            "5026b4d763ed7dcc"
                    "env": [
                            "name": "basePath",
                            "type": "str"
                    "x": 780,
                    "y": 180,
                    "wires": [
                            "05ad3c7ae6fe582b",
                            "9c9e217c842acefc"
                    "name": "",
                    "topic": "",
                    "ack": "true",
                    "role": "state",
                    "readonly": "",
                    "stateUnit": "°C",
                    "stateMin": "",
                    "stateMax": "",
                    "x": 980,
                    "y": 180,
                    "wires": []
                    "type": "change",
                    "name": "Zuluft",
                    "rules": [
                            "t": "set",
                            "p": "topic",
                            "pt": "msg",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 310,
                    "y": 120,
                    "wires": [
                            "766be49e74305196"
                    "type": "mqtt in",
                    "qos": "0",
                    "nl": false,
                    "rap": true,
                    "rh": 0,
                    "inputs": 0,
                    "x": 110,
                    "y": 240,
                    "wires": [
                            "225419c87f910c3e"
                    "type": "change",
                    "name": "Abluft",
                    "rules": [
                            "t": "set",
                            "p": "topic",
                            "pt": "msg",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 310,
                    "y": 240,
                    "wires": [
                            "766be49e74305196"
                    "type": "join",
                    "name": "",
                    "mode": "custom",
                    "build": "object",
                    "key": "topic",
                    "joiner": "\\n",
                    "accumulate": true,
                    "timeout": "60",
                    "count": "2",
                    "reduceExp": "",
                    "reduceInit": "",
                    "reduceFixup": "",
                    "x": 430,
                    "y": 180,
                    "wires": [
                            "dd61fc92c8961b14",
                            "457c8ae43cf33de1"
                    "type": "json",
                    "name": "",
                    "action": "",
                    "pretty": true,
                    "x": 610,
                    "y": 180,
                    "wires": [
                            "c828c8f4b32a9c0c",
                            "535565225c8e6f99"
                    "type": "debug",
                    "active": true,
                    "tosidebar": true,
                    "console": false,
                    "tostatus": false,
                    "statusVal": "",
                    "x": 510,
                    "y": 80,
                    "wires": []
                    "type": "debug",
                    "active": true,
                    "tosidebar": true,
                    "console": false,
                    "tostatus": false,
                    "statusVal": "",
                    "x": 710,
                    "y": 100,
                    "wires": []
                    "type": "debug",
                    "active": true,
                    "tosidebar": true,
                    "console": false,
                    "tostatus": false,
                    "statusVal": "",
                    "x": 950,
                    "y": 100,
                    "wires": []
                    "type": "change",
                    "name": "",
                    "rules": [
                            "t": "set",
                            "p": "topic",
                            "pt": "msg",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 540,
                    "y": 300,
                    "wires": [
                            "224380ff0709c559",
                            "f92533e2c4de9cf4"
                    "type": "debug",
                    "active": true,
                    "tosidebar": true,
                    "console": false,
                    "tostatus": false,
                    "statusVal": "",
                    "x": 730,
                    "y": 360,
                    "wires": []
                    "port": "1883",
                    "clientid": "",
                    "usetls": false,
                    "keepalive": "60",
                    "birthTopic": "",
                    "birthQos": "0",
                    "birthPayload": "",
                    "birthMsg": {},
                    "closeTopic": "",
                    "closeQos": "0",
                    "closePayload": "",
                    "closeMsg": {},
                    "willTopic": "",
                    "willQos": "0",
                    "willPayload": "",
                    "willMsg": {},
                    "userProps": "",
                    "sessionExpiry": ""
            mickymM Offline
            mickymM Offline
            mickym
            @martybr Na den Datenpunkt hast Du wahrscheinlich schreibgeschützt angelegt - siehst Du doch an dem Schloss. Musst Du wahrscheinlich beschreibbar machen, in der iobroker-Out Node. Oder im Nachhinein in den Objekteigenschaften des Datenpunktes.
            Ausserdem empfehle ich Dir - keinen Datentyp festzulegen - das macht die NOde selbst und wie gesagt musst Du es beschreibbar anlegen.
            Ja und wie gesagt - Objekte muss man als Strings - also JSON Strings schreiben und auch wieder in Objekte wandeln.
            iobroker kann nur Strings in den States verarbeiten.
            • M MartyBr
              @mickym
              Hier mal die Infos:
              Datensatz:
              Flow:
                      "type": "subflow",
                      "info": "",
                      "category": "",
                      "in": [
                              "x": 60,
                              "y": 80,
                              "wires": [
                      "out": [
                              "x": 820,
                              "y": 80,
                              "wires": [
                                      "port": 0
                      "env": [
                              "name": "basePath",
                              "type": "str",
                      "meta": {},
                      "color": "#DDAA99"
                      "type": "change",
                      "name": "",
                      "rules": [
                              "t": "set",
                              "p": "datum",
                              "pt": "msg",
                              "tot": "jsonata"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 230,
                      "y": 80,
                      "wires": [
                              "0e8de9437c3c420a"
                      "type": "change",
                      "rules": [
                              "t": "change",
                              "p": "datum",
                              "pt": "msg",
                              "from": "März",
                              "fromt": "str",
                              "to": "Maerz",
                              "tot": "str"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 440,
                      "y": 80,
                      "wires": [
                              "fc37f5f9d2b0297b"
                      "type": "change",
                      "name": "",
                      "rules": [
                              "t": "set",
                              "p": "topic",
                              "pt": "msg",
                              "tot": "jsonata"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 660,
                      "y": 80,
                      "wires": [
                      "type": "tab",
                      "label": "JSON",
                      "disabled": false,
                      "info": "",
                      "env": []
                      "type": "mqtt in",
                      "qos": "0",
                      "nl": false,
                      "rap": true,
                      "rh": 0,
                      "inputs": 0,
                      "x": 100,
                      "y": 120,
                      "wires": [
                              "5026b4d763ed7dcc"
                      "env": [
                              "name": "basePath",
                              "type": "str"
                      "x": 780,
                      "y": 180,
                      "wires": [
                              "05ad3c7ae6fe582b",
                              "9c9e217c842acefc"
                      "name": "",
                      "topic": "",
                      "ack": "true",
                      "role": "state",
                      "readonly": "",
                      "stateUnit": "°C",
                      "stateMin": "",
                      "stateMax": "",
                      "x": 980,
                      "y": 180,
                      "wires": []
                      "type": "change",
                      "name": "Zuluft",
                      "rules": [
                              "t": "set",
                              "p": "topic",
                              "pt": "msg",
                              "tot": "str"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 310,
                      "y": 120,
                      "wires": [
                              "766be49e74305196"
                      "type": "mqtt in",
                      "qos": "0",
                      "nl": false,
                      "rap": true,
                      "rh": 0,
                      "inputs": 0,
                      "x": 110,
                      "y": 240,
                      "wires": [
                              "225419c87f910c3e"
                      "type": "change",
                      "name": "Abluft",
                      "rules": [
                              "t": "set",
                              "p": "topic",
                              "pt": "msg",
                              "tot": "str"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 310,
                      "y": 240,
                      "wires": [
                              "766be49e74305196"
                      "type": "join",
                      "name": "",
                      "mode": "custom",
                      "build": "object",
                      "key": "topic",
                      "joiner": "\\n",
                      "accumulate": true,
                      "timeout": "60",
                      "count": "2",
                      "reduceExp": "",
                      "reduceInit": "",
                      "reduceFixup": "",
                      "x": 430,
                      "y": 180,
                      "wires": [
                              "dd61fc92c8961b14",
                              "457c8ae43cf33de1"
                      "type": "json",
                      "name": "",
                      "action": "",
                      "pretty": true,
                      "x": 610,
                      "y": 180,
                      "wires": [
                              "c828c8f4b32a9c0c",
                              "535565225c8e6f99"
                      "type": "debug",
                      "active": true,
                      "tosidebar": true,
                      "console": false,
                      "tostatus": false,
                      "statusVal": "",
                      "x": 510,
                      "y": 80,
                      "wires": []
                      "type": "debug",
                      "active": true,
                      "tosidebar": true,
                      "console": false,
                      "tostatus": false,
                      "statusVal": "",
                      "x": 710,
                      "y": 100,
                      "wires": []
                      "type": "debug",
                      "active": true,
                      "tosidebar": true,
                      "console": false,
                      "tostatus": false,
                      "statusVal": "",
                      "x": 950,
                      "y": 100,
                      "wires": []
                      "type": "change",
                      "name": "",
                      "rules": [
                              "t": "set",
                              "p": "topic",
                              "pt": "msg",
                              "tot": "str"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 540,
                      "y": 300,
                      "wires": [
                              "224380ff0709c559",
                              "f92533e2c4de9cf4"
                      "type": "debug",
                      "active": true,
                      "tosidebar": true,
                      "console": false,
                      "tostatus": false,
                      "statusVal": "",
                      "x": 730,
                      "y": 360,
                      "wires": []
                      "port": "1883",
                      "clientid": "",
                      "usetls": false,
                      "keepalive": "60",
                      "birthTopic": "",
                      "birthQos": "0",
                      "birthPayload": "",
                      "birthMsg": {},
                      "closeTopic": "",
                      "closeQos": "0",
                      "closePayload": "",
                      "closeMsg": {},
                      "willTopic": "",
                      "willQos": "0",
                      "willPayload": "",
                      "willMsg": {},
                      "userProps": "",
                      "sessionExpiry": ""
              mickymM Offline
              mickymM Offline
              mickym
              @martybr Es geht auch als Objekt zu öffnen - aber muss halt beschreibbar sein.
              Und wenn Du es nicht als Objekt, sondern richtig als String festlegst (wie gesagt normalerweise legt man nichts fest, dann wird automatisch der richtige Typ festgelegt), dann macht er auch einen JSON daraus:
              Grundsätzlich würde ich mir übrigens angewöhnen, die JSON Node immer direkt vor die Ausgabe in die iobroker-out -Node zu machen, damit man solange wie möglich mit Objekten arbeiten kann.
              • mickymM mickym
                MartyBr
                @mickym
                Okay, setze ich um.
                Martin
                • mickymM mickym
                  MartyBr
                  @mickym
                  Funktioniert jetzt.
                  Hast du noch eine Idee wie ich die eckigen Klammern um den Datensatz setzen kann? Mit einem Change-Node?
                  Martin
                  • M MartyBr
                    @mickym
                    Funktioniert jetzt.
                    mickymM Offline
                    mickymM Offline
                    mickym
                    @martybr Eckige Klammern sind ein Array oder in Blockly Chargon eine Liste - Ja Du kannst einfach ein Array mit eckigen Klammern daraus machen - macht aber nur Sinn, wenn Du dann mehrere Objekte im Array hast.
                    Selbstverstöndlich kannst Du ein Objekt in ein Array stellen. Wenn Du aber mehrere Objekte in ein Array machen mächtest, dann nutze die $append Funktion.
                    Du solltest Dir angewöhnen - nie KLammern zu bezeichen, sondern was für Objekte Du erstellen möchtest.
                    • mickymM mickym
                      MartyBr
                      @mickym
                      Okay. das ist mein Ziel. Ich möchte Tageswerte in ein Monatsarray speichern. Das mit den Klammern hat funktioniert.
                      Über Arrays muss ich mich erst kundig machen.
                      Ziel ist, um 00:00 Uhr generierte Werte in ein Monatsarray zu speichern.
                      Ich bereite mal einen Versuch vor.
                      Martin
                      • M MartyBr
                        @mickym
                        mickymM Offline
                        mickymM Offline
                        mickym
                        @martybr Dann nimm die $append Funktion
                        Hier zum Ausprobieren:
                               "id": "1db807e2530b5198",
                               "type": "change",
                               "z": "7e6af0015415146d",
                               "name": "Vorhandenes Array",
                               "rules": [
                                       "t": "set",
                                       "p": "array",
                                       "pt": "msg",
                                       "to": "[{\"Zuluft-Temp\":20.1,\"Abluft-Temp\":20.9},{\"Zuluft-Temp\":21.1,\"Abluft-Temp\":22.9}]",
                                       "tot": "json"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 410,
                               "y": 6500,
                               "wires": [
                                       "16c668ac241e55c4"
                               "id": "86b4268438857773",
                               "type": "inject",
                               "name": "Einzelnes Objekt",
                               "props": [
                                       "p": "payload"
                               "repeat": "",
                               "crontab": "",
                               "once": false,
                               "onceDelay": 0.1,
                               "topic": "",
                               "payload": "{     \"Zuluft-Temp\": 20.1,     \"Abluft-Temp\": 20.9 }",
                               "payloadType": "json",
                               "x": 180,
                               "y": 6500,
                               "wires": [
                                       "1db807e2530b5198"
                               "id": "16c668ac241e55c4",
                               "type": "change",
                               "name": "",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "to": "$append(array, payload)",
                                       "tot": "jsonata"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 630,
                               "y": 6500,
                               "wires": [
                                       "c9cfdb97d8474804"
                               "id": "c9cfdb97d8474804",
                               "type": "debug",
                               "name": "Neues Array",
                               "active": true,
                               "tosidebar": true,
                               "console": false,
                               "tostatus": false,
                               "statusVal": "",
                               "x": 850,
                               "y": 6500,
                               "wires": []
                        • mickymM mickym
                                 "type": "change",
                                 "rules": [
                                         "t": "set",
                                         "p": "array",
                                         "pt": "msg",
                                         "tot": "json"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 410,
                                 "y": 6500,
                                 "wires": [
                                         "16c668ac241e55c4"
                                 "type": "inject",
                                 "props": [
                                         "p": "payload"
                                 "repeat": "",
                                 "crontab": "",
                                 "once": false,
                                 "onceDelay": 0.1,
                                 "topic": "",
                                 "x": 180,
                                 "y": 6500,
                                 "wires": [
                                         "1db807e2530b5198"
                                 "type": "change",
                                 "name": "",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "tot": "jsonata"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 630,
                                 "y": 6500,
                                 "wires": [
                                         "c9cfdb97d8474804"
                                 "type": "debug",
                                 "active": true,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 850,
                                 "y": 6500,
                                 "wires": []
                          MartyBr
                          schrieb am zuletzt editiert von MartyBr
                          @mickym
                          das Array wird nach meinem Test nicht aufgefüllt, es bleibt immer nur ein Wert im Array.
                          Die $append scheint nicht zu wirken.
                                  "id": "a0d8740faea1647b",
                                  "type": "mqtt in",
                                  "z": "5c488c180ba51f18",
                                  "qos": "0",
                                  "nl": false,
                                  "rap": true,
                                  "rh": 0,
                                  "inputs": 0,
                                  "x": 140,
                                  "y": 260,
                                  "wires": [
                                          "afdcb37ccbacb06f"
                                  "id": "afdcb37ccbacb06f",
                                  "type": "change",
                                  "name": "Zuluft",
                                  "rules": [
                                          "t": "set",
                                          "p": "topic",
                                          "pt": "msg",
                                          "to": "zuluft",
                                          "tot": "str"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 290,
                                  "y": 320,
                                  "wires": [
                                          "1643873aeecd8613"
                                  "id": "1643873aeecd8613",
                                  "type": "change",
                                  "rules": [
                                          "t": "set",
                                          "p": "array",
                                          "pt": "msg",
                                          "to": "[]",
                                          "tot": "json"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 490,
                                  "y": 280,
                                  "wires": [
                                          "c9d97aec2949301c",
                                          "34c8064e4b5c52fa"
                                  "id": "34c8064e4b5c52fa",
                                  "type": "change",
                                  "name": "",
                                  "rules": [
                                          "t": "set",
                                          "p": "payload",
                                          "pt": "msg",
                                          "tot": "jsonata"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 610,
                                  "y": 340,
                                  "wires": [
                                          "5b551b24fc1bb26e"
                                  "id": "5b551b24fc1bb26e",
                                  "type": "debug",
                                  "name": "debug 179",
                                  "active": true,
                                  "tosidebar": true,
                                  "console": false,
                                  "tostatus": false,
                                  "statusVal": "",
                                  "x": 750,
                                  "y": 280,
                                  "wires": []
                                  "id": "c9d97aec2949301c",
                                  "type": "debug",
                                  "name": "debug 178",
                                  "active": true,
                                  "tosidebar": true,
                                  "console": false,
                                  "tostatus": false,
                                  "statusVal": "",
                                  "x": 710,
                                  "y": 160,
                                  "wires": []
                                  "port": "1883",
                                  "clientid": "",
                                  "usetls": false,
                                  "keepalive": "60",
                                  "birthTopic": "",
                                  "birthQos": "0",
                                  "birthPayload": "",
                                  "birthMsg": {},
                                  "closeTopic": "",
                                  "closeQos": "0",
                                  "closePayload": "",
                                  "closeMsg": {},
                                  "willTopic": "",
                                  "willQos": "0",
                                  "willPayload": "",
                                  "willMsg": {},
                                  "userProps": "",
                                  "sessionExpiry": ""
                          Was mache ich falsch?
                          Edit:
                          Als Ziel benötige ich für die 4 Werte jeweils ein Array mit
                          Wert1,
                          Wert2,
                          Wert3,
                          Wert28
                          Anzahl der Werte entspricht der Zahl der Tage im laufenden Monat.
                          Martin
                          • M MartyBr
                            @mickym
                                    "type": "mqtt in",
                                    "qos": "0",
                                    "nl": false,
                                    "rap": true,
                                    "rh": 0,
                                    "inputs": 0,
                                    "x": 140,
                                    "y": 260,
                                    "wires": [
                                            "afdcb37ccbacb06f"
                                    "type": "change",
                                    "name": "Zuluft",
                                    "rules": [
                                            "t": "set",
                                            "p": "topic",
                                            "pt": "msg",
                                            "to": "zuluft",
                                            "tot": "str"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 290,
                                    "y": 320,
                                    "wires": [
                                            "1643873aeecd8613"
                                    "type": "change",
                                    "rules": [
                                            "t": "set",
                                            "p": "array",
                                            "pt": "msg",
                                            "to": "[]",
                                            "tot": "json"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 490,
                                    "y": 280,
                                    "wires": [
                                            "c9d97aec2949301c",
                                            "34c8064e4b5c52fa"
                                    "type": "change",
                                    "name": "",
                                    "rules": [
                                            "t": "set",
                                            "p": "payload",
                                            "pt": "msg",
                                            "tot": "jsonata"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 610,
                                    "y": 340,
                                    "wires": [
                                            "5b551b24fc1bb26e"
                                    "type": "debug",
                                    "active": true,
                                    "tosidebar": true,
                                    "console": false,
                                    "tostatus": false,
                                    "statusVal": "",
                                    "x": 750,
                                    "y": 280,
                                    "wires": []
                                    "type": "debug",
                                    "active": true,
                                    "tosidebar": true,
                                    "console": false,
                                    "tostatus": false,
                                    "statusVal": "",
                                    "x": 710,
                                    "y": 160,
                                    "wires": []
                                    "port": "1883",
                                    "clientid": "",
                                    "usetls": false,
                                    "keepalive": "60",
                                    "birthTopic": "",
                                    "birthQos": "0",
                                    "birthPayload": "",
                                    "birthMsg": {},
                                    "closeTopic": "",
                                    "closeQos": "0",
                                    "closePayload": "",
                                    "closeMsg": {},
                                    "willTopic": "",
                                    "willQos": "0",
                                    "willPayload": "",
                                    "willMsg": {},
                                    "userProps": "",
                                    "sessionExpiry": ""
                            Edit:
                            Wert1,
                            Wert2,
                            Wert3,
                            Wert28
                            mickymM Offline
                            mickymM Offline
                            mickym
                            @martybr Na Du mergst ein leeres Array mit einem skalaren Wert. Dann ist es doch richtig, dass nur ein Wert in dem Array ist. Du musst das Array ja speichern und dann den nächsten Wert anhängen.
                            So hängst Du doch immer wieder nur EIN Wert an ein leeres Array. Du musst doch das Array irgendwo abspeichern und dann das neu erstellte Array mit einem neuen Wert ergänzen.
                            Also überleg Dir wohin Du Dein Array Ergebnis des Anhänges abspeichern willst. In einer Variable oder in einem Datenpunkt.
                            Oder mit anderen Worten: Ein Wert an ein leeres Array angehängt, gibt immer nur ein Array mit einem Wert.
                            • mickymM mickym
                              MartyBr
                              @mickym
                              Okay, das ist ein Ansatzpunkt. Ich mache mir mal Gedanken.
                              Danke für deine Unterstützung.
                              Martin
                              • M MartyBr
                                @mickym
                                mickymM Offline
                                mickymM Offline
                                mickym
                                @mickym
                                Ich habs Dir mal mit eine Flowvariable gemacht. Das heißt das Ergebnis wird in eine Variable gespeichert und dann wieder eingelesen und der neue Wert angehängt.
                                       "type": "mqtt in",
                                       "d": true,
                                       "qos": "0",
                                       "nl": false,
                                       "rap": true,
                                       "rh": 0,
                                       "inputs": 0,
                                       "x": 260,
                                       "y": 6740,
                                       "wires": [
                                               "afdcb37ccbacb06f"
                                       "type": "change",
                                       "name": "Zuluft",
                                       "rules": [
                                               "t": "set",
                                               "p": "topic",
                                               "pt": "msg",
                                               "to": "zuluft",
                                               "tot": "str"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 410,
                                       "y": 6800,
                                       "wires": [
                                               "1643873aeecd8613"
                                       "type": "change",
                                       "rules": [
                                               "t": "set",
                                               "p": "array",
                                               "pt": "msg",
                                               "to": "array",
                                               "tot": "flow"
                                               "t": "set",
                                               "p": "array",
                                               "pt": "msg",
                                               "to": "array ? array : []",
                                               "tot": "jsonata"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 610,
                                       "y": 6760,
                                       "wires": [
                                               "c9d97aec2949301c",
                                               "34c8064e4b5c52fa"
                                       "type": "change",
                                       "name": "",
                                       "rules": [
                                               "t": "set",
                                               "p": "payload",
                                               "pt": "msg",
                                               "tot": "jsonata"
                                               "t": "set",
                                               "p": "array",
                                               "pt": "flow",
                                               "to": "payload",
                                               "tot": "msg"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 850,
                                       "y": 6760,
                                       "wires": [
                                               "5b551b24fc1bb26e"
                                       "type": "debug",
                                       "active": true,
                                       "tosidebar": true,
                                       "console": false,
                                       "tostatus": false,
                                       "statusVal": "",
                                       "x": 1070,
                                       "y": 6740,
                                       "wires": []
                                       "type": "debug",
                                       "active": true,
                                       "tosidebar": true,
                                       "console": false,
                                       "tostatus": false,
                                       "statusVal": "",
                                       "x": 830,
                                       "y": 6640,
                                       "wires": []
                                       "id": "7961970716d0df25",
                                       "type": "inject",
                                       "name": "",
                                       "props": [
                                               "p": "payload"
                                       "repeat": "",
                                       "crontab": "",
                                       "once": false,
                                       "onceDelay": 0.1,
                                       "topic": "",
                                       "payload": "20.2",
                                       "payloadType": "num",
                                       "x": 230,
                                       "y": 6800,
                                       "wires": [
                                               "afdcb37ccbacb06f"
                                       "port": "1883",
                                       "clientid": "",
                                       "usetls": false,
                                       "keepalive": "60",
                                       "birthTopic": "",
                                       "birthQos": "0",
                                       "birthPayload": "",
                                       "birthMsg": {},
                                       "closeTopic": "",
                                       "closeQos": "0",
                                       "closePayload": "",
                                       "closeMsg": {},
                                       "willTopic": "",
                                       "willQos": "0",
                                       "willPayload": "",
                                       "willMsg": {},
                                       "userProps": "",
                                       "sessionExpiry": ""
                                • mickymM mickym
                                  @mickym
                                         "type": "mqtt in",
                                         "d": true,
                                         "qos": "0",
                                         "nl": false,
                                         "rap": true,
                                         "rh": 0,
                                         "inputs": 0,
                                         "x": 260,
                                         "y": 6740,
                                         "wires": [
                                                 "afdcb37ccbacb06f"
                                         "type": "change",
                                         "name": "Zuluft",
                                         "rules": [
                                                 "t": "set",
                                                 "p": "topic",
                                                 "pt": "msg",
                                                 "to": "zuluft",
                                                 "tot": "str"
                                         "action": "",
                                         "property": "",
                                         "from": "",
                                         "to": "",
                                         "reg": false,
                                         "x": 410,
                                         "y": 6800,
                                         "wires": [
                                                 "1643873aeecd8613"
                                         "type": "change",
                                         "rules": [
                                                 "t": "set",
                                                 "p": "array",
                                                 "pt": "msg",
                                                 "to": "array",
                                                 "tot": "flow"
                                                 "t": "set",
                                                 "p": "array",
                                                 "pt": "msg",
                                                 "tot": "jsonata"
                                         "action": "",
                                         "property": "",
                                         "from": "",
                                         "to": "",
                                         "reg": false,
                                         "x": 610,
                                         "y": 6760,
                                         "wires": [
                                                 "c9d97aec2949301c",
                                                 "34c8064e4b5c52fa"
                                         "type": "change",
                                         "name": "",
                                         "rules": [
                                                 "t": "set",
                                                 "p": "payload",
                                                 "pt": "msg",
                                                 "tot": "jsonata"
                                                 "t": "set",
                                                 "p": "array",
                                                 "pt": "flow",
                                                 "to": "payload",
                                                 "tot": "msg"
                                         "action": "",
                                         "property": "",
                                         "from": "",
                                         "to": "",
                                         "reg": false,
                                         "x": 850,
                                         "y": 6760,
                                         "wires": [
                                                 "5b551b24fc1bb26e"
                                         "type": "debug",
                                         "active": true,
                                         "tosidebar": true,
                                         "console": false,
                                         "tostatus": false,
                                         "statusVal": "",
                                         "x": 1070,
                                         "y": 6740,
                                         "wires": []
                                         "type": "debug",
                                         "active": true,
                                         "tosidebar": true,
                                         "console": false,
                                         "tostatus": false,
                                         "statusVal": "",
                                         "x": 830,
                                         "y": 6640,
                                         "wires": []
                                         "type": "inject",
                                         "name": "",
                                         "props": [
                                                 "p": "payload"
                                         "repeat": "",
                                         "crontab": "",
                                         "once": false,
                                         "onceDelay": 0.1,
                                         "topic": "",
                                         "payload": "20.2",
                                         "x": 230,
                                         "y": 6800,
                                         "wires": [
                                                 "afdcb37ccbacb06f"
                                         "port": "1883",
                                         "clientid": "",
                                         "usetls": false,
                                         "keepalive": "60",
                                         "birthTopic": "",
                                         "birthQos": "0",
                                         "birthPayload": "",
                                         "birthMsg": {},
                                         "closeTopic": "",
                                         "closeQos": "0",
                                         "closePayload": "",
                                         "closeMsg": {},
                                         "willTopic": "",
                                         "willQos": "0",
                                         "willPayload": "",
                                         "willMsg": {},
                                         "userProps": "",
                                         "sessionExpiry": ""
                                  MartyBr
                                  @mickym
                                  Der Flow funktioniert.
                                  Ich habe eine Objektveriable in ioBroker.
                                         "type": "mqtt in",
                                         "d": true,
                                         "qos": "0",
                                         "nl": false,
                                         "rap": true,
                                         "rh": 0,
                                         "inputs": 0,
                                         "x": 260,
                                         "y": 6740,
                                         "wires": [
                                                 "afdcb37ccbacb06f"
                                         "type": "change",
                                         "name": "Zuluft",
                                         "rules": [
                                                 "t": "set",
                                                 "p": "topic",
                                                 "pt": "msg",
                                                 "to": "zuluft",
                                                 "tot": "str"
                                         "action": "",
                                         "property": "",
                                         "from": "",
                                         "to": "",
                                         "reg": false,
                                         "x": 410,
                                         "y": 6800,
                                         "wires": [
                                                 "1643873aeecd8613"
                                         "type": "change",
                                         "rules": [
                                                 "t": "set",
                                                 "p": "array",
                                                 "pt": "msg",
                                                 "to": "array",
                                                 "tot": "flow"
                                                 "t": "set",
                                                 "p": "array",
                                                 "pt": "msg",
                                                 "tot": "jsonata"
                                         "action": "",
                                         "property": "",
                                         "from": "",
                                         "to": "",
                                         "reg": false,
                                         "x": 610,
                                         "y": 6760,
                                         "wires": [
                                                 "c9d97aec2949301c",
                                                 "34c8064e4b5c52fa"
                                         "type": "change",
                                         "name": "",
                                         "rules": [
                                                 "t": "set",
                                                 "p": "payload",
                                                 "pt": "msg",
                                                 "tot": "jsonata"
                                                 "t": "set",
                                                 "p": "array",
                                                 "pt": "flow",
                                                 "to": "payload",
                                                 "tot": "msg"
                                         "action": "",
                                         "property": "",
                                         "from": "",
                                         "to": "",
                                         "reg": false,
                                         "x": 850,
                                         "y": 6760,
                                         "wires": [
                                                 "5b551b24fc1bb26e"
                                         "type": "debug",
                                         "active": true,
                                         "tosidebar": true,
                                         "console": false,
                                         "tostatus": false,
                                         "statusVal": "",
                                         "x": 1070,
                                         "y": 6740,
                                         "wires": []
                                         "type": "debug",
                                         "active": true,
                                         "tosidebar": true,
                                         "console": false,
                                         "tostatus": false,
                                         "statusVal": "",
                                         "x": 830,
                                         "y": 6640,
                                         "wires": []
                                         "type": "inject",
                                         "name": "",
                                         "props": [
                                                 "p": "payload"
                                         "repeat": "",
                                         "crontab": "",
                                         "once": false,
                                         "onceDelay": 0.1,
                                         "topic": "",
                                         "payload": "20.2",
                                         "x": 230,
                                         "y": 6800,
                                         "wires": [
                                                 "afdcb37ccbacb06f"
                                         "port": "1883",
                                         "clientid": "",
                                         "usetls": false,
                                         "keepalive": "60",
                                         "birthTopic": "",
                                         "birthQos": "0",
                                         "birthPayload": "",
                                         "birthMsg": {},
                                         "closeTopic": "",
                                         "closeQos": "0",
                                         "closePayload": "",
                                         "closeMsg": {},
                                         "willTopic": "",
                                         "willQos": "0",
                                         "willPayload": "",
                                         "willMsg": {},
                                         "userProps": "",
                                         "sessionExpiry": ""
                                  Wie kann ich das Array persistent ablegen?
                                  Martin
                                  • M MartyBr
                                    @mickym
                                           "type": "mqtt in",
                                           "d": true,
                                           "qos": "0",
                                           "nl": false,
                                           "rap": true,
                                           "rh": 0,
                                           "inputs": 0,
                                           "x": 260,
                                           "y": 6740,
                                           "wires": [
                                                   "afdcb37ccbacb06f"
                                           "type": "change",
                                           "name": "Zuluft",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "topic",
                                                   "pt": "msg",
                                                   "to": "zuluft",
                                                   "tot": "str"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 410,
                                           "y": 6800,
                                           "wires": [
                                                   "1643873aeecd8613"
                                           "type": "change",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "array",
                                                   "pt": "msg",
                                                   "to": "array",
                                                   "tot": "flow"
                                                   "t": "set",
                                                   "p": "array",
                                                   "pt": "msg",
                                                   "tot": "jsonata"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 610,
                                           "y": 6760,
                                           "wires": [
                                                   "c9d97aec2949301c",
                                                   "34c8064e4b5c52fa"
                                           "type": "change",
                                           "name": "",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "tot": "jsonata"
                                                   "t": "set",
                                                   "p": "array",
                                                   "pt": "flow",
                                                   "to": "payload",
                                                   "tot": "msg"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 850,
                                           "y": 6760,
                                           "wires": [
                                                   "5b551b24fc1bb26e"
                                           "type": "debug",
                                           "active": true,
                                           "tosidebar": true,
                                           "console": false,
                                           "tostatus": false,
                                           "statusVal": "",
                                           "x": 1070,
                                           "y": 6740,
                                           "wires": []
                                           "type": "debug",
                                           "active": true,
                                           "tosidebar": true,
                                           "console": false,
                                           "tostatus": false,
                                           "statusVal": "",
                                           "x": 830,
                                           "y": 6640,
                                           "wires": []
                                           "type": "inject",
                                           "name": "",
                                           "props": [
                                                   "p": "payload"
                                           "repeat": "",
                                           "crontab": "",
                                           "once": false,
                                           "onceDelay": 0.1,
                                           "topic": "",
                                           "payload": "20.2",
                                           "x": 230,
                                           "y": 6800,
                                           "wires": [
                                                   "afdcb37ccbacb06f"
                                           "port": "1883",
                                           "clientid": "",
                                           "usetls": false,
                                           "keepalive": "60",
                                           "birthTopic": "",
                                           "birthQos": "0",
                                           "birthPayload": "",
                                           "birthMsg": {},
                                           "closeTopic": "",
                                           "closeQos": "0",
                                           "closePayload": "",
                                           "closeMsg": {},
                                           "willTopic": "",
                                           "willQos": "0",
                                           "willPayload": "",
                                           "willMsg": {},
                                           "userProps": "",
                                           "sessionExpiry": ""
                                    mickymM Offline
                                    mickymM Offline
                                    mickym
                                    @martybr
                                    Datenpunkt im iobroker oder im mqtt - wo immer Du willst.
                                    • mickymM mickym
                                      @martybr
                                      MartyBr
                                      @mickym
                                      Ich habe das mal so gemacht:
                                              "id": "99d066d4bbe5dca9",
                                              "type": "inject",
                                              "name": "",
                                              "props": [
                                                      "p": "payload"
                                              "repeat": "",
                                              "crontab": "",
                                              "once": false,
                                              "onceDelay": 0.1,
                                              "topic": "",
                                              "payload": "20.2",
                                              "x": 350,
                                              "y": 700,
                                              "wires": [
                                                      "994a1a0b6d25cef4"
                                              "id": "82d5f1b2aa875c35",
                                              "type": "mqtt in",
                                              "qos": "0",
                                              "nl": false,
                                              "rap": true,
                                              "rh": 0,
                                              "inputs": 0,
                                              "x": 420,
                                              "y": 620,
                                              "wires": [
                                                      "994a1a0b6d25cef4"
                                              "id": "994a1a0b6d25cef4",
                                              "type": "change",
                                              "name": "Zuluft",
                                              "rules": [
                                                      "t": "set",
                                                      "p": "topic",
                                                      "pt": "msg",
                                                      "to": "zuluft",
                                                      "tot": "str"
                                              "action": "",
                                              "property": "",
                                              "from": "",
                                              "to": "",
                                              "reg": false,
                                              "x": 530,
                                              "y": 700,
                                              "wires": [
                                                      "4a49f7b7cb1d35d2"
                                              "id": "de7a183e542f367e",
                                              "type": "ioBroker get object",
                                              "name": "Test.Test-JSON",
                                              "topic": "0_userdata.0.Test.Test-JSON",
                                              "attrname": "array",
                                              "x": 620,
                                              "y": 580,
                                              "wires": [
                                              "id": "4a49f7b7cb1d35d2",
                                              "type": "change",
                                              "rules": [
                                                      "t": "set",
                                                      "p": "array",
                                                      "pt": "msg",
                                                      "to": "array",
                                                      "tot": "flow"
                                                      "t": "set",
                                                      "p": "array",
                                                      "pt": "msg",
                                                      "tot": "jsonata"
                                              "action": "",
                                              "property": "",
                                              "from": "",
                                              "to": "",
                                              "reg": false,
                                              "x": 730,
                                              "y": 660,
                                              "wires": [
                                                      "1bf56806da8b2399",
                                                      "40df7a89751f5b92"
                                              "id": "40df7a89751f5b92",
                                              "type": "change",
                                              "name": "",
                                              "rules": [
                                                      "t": "set",
                                                      "p": "payload",
                                                      "pt": "msg",
                                                      "tot": "jsonata"
                                                      "t": "set",
                                                      "p": "array",
                                                      "pt": "flow",
                                                      "to": "payload",
                                                      "tot": "msg"
                                              "action": "",
                                              "property": "",
                                              "from": "",
                                              "to": "",
                                              "reg": false,
                                              "x": 830,
                                              "y": 740,
                                              "wires": [
                                                      "cb026a3b7a51d987",
                                                      "8d9b65f4efb22698"
                                              "id": "cb026a3b7a51d987",
                                              "type": "debug",
                                              "active": true,
                                              "tosidebar": true,
                                              "console": false,
                                              "tostatus": false,
                                              "statusVal": "",
                                              "x": 890,
                                              "y": 800,
                                              "wires": []
                                              "id": "8d9b65f4efb22698",
                                              "ack": "true",
                                              "autoCreate": "false",
                                              "stateName": "",
                                              "role": "",
                                              "payloadType": "",
                                              "readonly": "",
                                              "stateUnit": "",
                                              "stateMin": "",
                                              "stateMax": "",
                                              "x": 1000,
                                              "y": 660,
                                              "wires": []
                                              "id": "1bf56806da8b2399",
                                              "type": "debug",
                                              "active": true,
                                              "tosidebar": true,
                                              "console": false,
                                              "tostatus": false,
                                              "statusVal": "",
                                              "x": 950,
                                              "y": 540,
                                              "wires": []
                                              "port": "1883",
                                              "clientid": "",
                                              "usetls": false,
                                              "keepalive": "60",
                                              "birthTopic": "",
                                              "birthQos": "0",
                                              "birthPayload": "",
                                              "birthMsg": {},
                                              "closeTopic": "",
                                              "closeQos": "0",
                                              "closePayload": "",
                                              "closeMsg": {},
                                              "willTopic": "",
                                              "willQos": "0",
                                              "willPayload": "",
                                              "willMsg": {},
                                              "userProps": "",
                                              "sessionExpiry": ""
                                      Die Werte kommen auch richtig im Datenpunkt an.
                                      Jetzt noch eine letzte Frage für Heute 😇
                                      Der Flow soll einen Monat laufen. Wenn nun ein Neustart vom ioBroker erfolgt, muss der Flow am letzten Datensatz wieder aufsetzen. Muss der daher nicht den letzten Stand aus dem Speicherdatenpunkt wieder einlesen?
                                      Edit:
                                      Ich habe im Flow eine ioBroker-getObject. Die ist wahrscheinlich falsch. Richtig?
                                      Martin
                                      • M MartyBr
                                        @mickym
                                                "type": "inject",
                                                "name": "",
                                                "props": [
                                                        "p": "payload"
                                                "repeat": "",
                                                "crontab": "",
                                                "once": false,
                                                "onceDelay": 0.1,
                                                "topic": "",
                                                "payload": "20.2",
                                                "x": 350,
                                                "y": 700,
                                                "wires": [
                                                        "994a1a0b6d25cef4"
                                                "type": "mqtt in",
                                                "qos": "0",
                                                "nl": false,
                                                "rap": true,
                                                "rh": 0,
                                                "inputs": 0,
                                                "x": 420,
                                                "y": 620,
                                                "wires": [
                                                        "994a1a0b6d25cef4"
                                                "type": "change",
                                                "name": "Zuluft",
                                                "rules": [
                                                        "t": "set",
                                                        "p": "topic",
                                                        "pt": "msg",
                                                        "to": "zuluft",
                                                        "tot": "str"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 530,
                                                "y": 700,
                                                "wires": [
                                                        "4a49f7b7cb1d35d2"
                                                "x": 620,
                                                "y": 580,
                                                "wires": [
                                                "type": "change",
                                                "rules": [
                                                        "t": "set",
                                                        "p": "array",
                                                        "pt": "msg",
                                                        "to": "array",
                                                        "tot": "flow"
                                                        "t": "set",
                                                        "p": "array",
                                                        "pt": "msg",
                                                        "tot": "jsonata"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 730,
                                                "y": 660,
                                                "wires": [
                                                        "1bf56806da8b2399",
                                                        "40df7a89751f5b92"
                                                "type": "change",
                                                "name": "",
                                                "rules": [
                                                        "t": "set",
                                                        "p": "payload",
                                                        "pt": "msg",
                                                        "tot": "jsonata"
                                                        "t": "set",
                                                        "p": "array",
                                                        "pt": "flow",
                                                        "to": "payload",
                                                        "tot": "msg"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 830,
                                                "y": 740,
                                                "wires": [
                                                        "cb026a3b7a51d987",
                                                        "8d9b65f4efb22698"
                                                "type": "debug",
                                                "active": true,
                                                "tosidebar": true,
                                                "console": false,
                                                "tostatus": false,
                                                "statusVal": "",
                                                "x": 890,
                                                "y": 800,
                                                "wires": []
                                                "ack": "true",
                                                "stateName": "",
                                                "role": "",
                                                "payloadType": "",
                                                "readonly": "",
                                                "stateUnit": "",
                                                "stateMin": "",
                                                "stateMax": "",
                                                "x": 1000,
                                                "y": 660,
                                                "wires": []
                                                "type": "debug",
                                                "active": true,
                                                "tosidebar": true,
                                                "console": false,
                                                "tostatus": false,
                                                "statusVal": "",
                                                "x": 950,
                                                "y": 540,
                                                "wires": []
                                                "port": "1883",
                                                "clientid": "",
                                                "usetls": false,
                                                "keepalive": "60",
                                                "birthTopic": "",
                                                "birthQos": "0",
                                                "birthPayload": "",
                                                "birthMsg": {},
                                                "closeTopic": "",
                                                "closeQos": "0",
                                                "closePayload": "",
                                                "closeMsg": {},
                                                "willTopic": "",
                                                "willQos": "0",
                                                "willPayload": "",
                                                "willMsg": {},
                                                "userProps": "",
                                                "sessionExpiry": ""
                                        Edit:
                                        mickymM Offline
                                        mickymM Offline
                                        mickym
                                        Nein Du willst kein Objekt, sondern entweder über iobroker- in oder get. Dann brauchst Du aber hinten nicht in eine flow Variable speichern - sondern die Flowvariable direkt über die iobroker-In füllen.
                                        • mickymM mickym
                                          MartyBr
                                          @mickym
                                          Ich habe es noch nicht so ganz verstanden. Ich habe es nun so gebaut, wie ich es verstanden habe. Exemplarisch für zwei Flows / Arrays:
                                                  "id": "5bbdcd58332d0b96",
                                                  "type": "ioBroker in",
                                                  "name": "Bezug täglich",
                                                  "attrname": "payload",
                                                  "topic": "0_userdata.0.Zaehler.Strombezug.Verbrauch.täglich",
                                                  "payloadType": "value",
                                                  "onlyack": "",
                                                  "func": "all",
                                                  "gap": "",
                                                  "fireOnStart": "true",
                                                  "outFormat": "MQTT",
                                                  "x": 110,
                                                  "y": 40,
                                                  "wires": [
                                                          "53d6131492b2abed"
                                                  "id": "4bb406f8dd2161dd",
                                                  "name": "Einspeisung täglich",
                                                  "topic": "0_userdata.0.Zaehler.Stromeinspeisung.Verbrauch.täglich",
                                                  "onlyack": "",
                                                  "func": "all",
                                                  "gap": "",
                                                  "x": 130,
                                                  "y": 120,
                                                  "wires": [
                                                          "c4e24a8d35d070ae"
                                                  "id": "c4e24a8d35d070ae",
                                                  "type": "change",
                                                  "name": "Einspeisung",
                                                  "rules": [
                                                          "t": "set",
                                                          "p": "topic",
                                                          "pt": "msg",
                                                          "to": "einspeisung",
                                                          "tot": "str"
                                                  "action": "",
                                                  "property": "",
                                                  "from": "",
                                                  "to": "",
                                                  "reg": false,
                                                  "x": 330,
                                                  "y": 120,
                                                  "wires": [
                                                          "278bac26e6737147"
                                                  "id": "53d6131492b2abed",
                                                  "type": "change",
                                                  "name": "Bezug",
                                                  "rules": [
                                                          "t": "set",
                                                          "p": "topic",
                                                          "pt": "msg",
                                                          "to": "bezug",
                                                          "tot": "str"
                                                  "action": "",
                                                  "property": "",
                                                  "from": "",
                                                  "to": "",
                                                  "reg": false,
                                                  "x": 270,
                                                  "y": 40,
                                                  "wires": [
                                                          "c617a78f8ddaca22"
                                                  "id": "c617a78f8ddaca22",
                                                  "type": "change",
                                                  "rules": [
                                                          "t": "set",
                                                          "p": "array-bezug",
                                                          "pt": "msg",
                                                          "to": "array-bezug",
                                                          "tot": "flow"
                                                          "t": "set",
                                                          "p": "array-bezug",
                                                          "pt": "msg",
                                                          "to": "array-bezug ? array-bezug : []",
                                                          "tot": "jsonata"
                                                  "action": "",
                                                  "property": "",
                                                  "from": "",
                                                  "to": "",
                                                  "reg": false,
                                                  "x": 450,
                                                  "y": 40,
                                                  "wires": [
                                                          "ff519a511afeb6f1"
                                                  "id": "ff519a511afeb6f1",
                                                  "type": "change",
                                                  "name": "",
                                                  "rules": [
                                                          "t": "set",
                                                          "p": "payload",
                                                          "pt": "msg",
                                                          "to": "$append(array-bezug, payload)",
                                                          "tot": "jsonata"
                                                          "t": "set",
                                                          "p": "array-bezug",
                                                          "pt": "flow",
                                                          "to": "payload",
                                                          "tot": "msg"
                                                  "action": "",
                                                  "property": "",
                                                  "from": "",
                                                  "to": "",
                                                  "reg": false,
                                                  "x": 670,
                                                  "y": 40,
                                                  "wires": [
                                                          "3274ac485bf96d56"
                                                  "id": "3274ac485bf96d56",
                                                  "name": "Test.Bezug-JSON",
                                                  "topic": "0_userdata.0.Test.Bezug-JSON",
                                                  "ack": "true",
                                                  "stateName": "",
                                                  "role": "",
                                                  "payloadType": "",
                                                  "readonly": "false",
                                                  "stateUnit": "",
                                                  "stateMin": "",
                                                  "stateMax": "",
                                                  "x": 890,
                                                  "y": 40,
                                                  "wires": []
                                                  "id": "278bac26e6737147",
                                                  "type": "change",
                                                  "rules": [
                                                          "t": "set",
                                                          "p": "array-einspeisung",
                                                          "pt": "msg",
                                                          "to": "array-einspeisung",
                                                          "tot": "flow"
                                                          "t": "set",
                                                          "pt": "msg",
                                                          "to": "array-einspeisung ? array-einspeisung : []",
                                                          "tot": "jsonata"
                                                  "action": "",
                                                  "property": "",
                                                  "from": "",
                                                  "to": "",
                                                  "reg": false,
                                                  "x": 530,
                                                  "y": 120,
                                                  "wires": [
                                                          "27eb027a108b6b2a"
                                                  "id": "27eb027a108b6b2a",
                                                  "type": "change",
                                                  "name": "",
                                                  "rules": [
                                                          "t": "set",
                                                          "p": "payload",
                                                          "pt": "msg",
                                                          "to": "$append(array-einspeisung, payload)",
                                                          "tot": "jsonata"
                                                          "t": "set",
                                                          "pt": "flow",
                                                          "to": "payload",
                                                          "tot": "msg"
                                                  "action": "",
                                                  "property": "",
                                                  "from": "",
                                                  "to": "",
                                                  "reg": false,
                                                  "x": 750,
                                                  "y": 120,
                                                  "wires": [
                                                          "8c3a9cbe90f64091"
                                                  "id": "8c3a9cbe90f64091",
                                                  "name": "Test.Einspeisung-JSON",
                                                  "topic": "0_userdata.0.Test.Einspeisung-JSON",
                                                  "ack": "true",
                                                  "stateName": "",
                                                  "role": "",
                                                  "payloadType": "",
                                                  "stateUnit": "",
                                                  "stateMin": "",
                                                  "stateMax": "",
                                                  "x": 990,
                                                  "y": 120,
                                                  "wires": []
                                          Die Daten aktualisieren sich täglich. Wenn das in Ordnung ist, dann gehe ich an die Zeitsteuerung.
                                          Martin
