  4. Node-Red
  5. Gelöst: Wert in dynamische Struktur im ioBroker ablegen
    6.4k
91 Beiträge 2 Kommentatoren 13.6k Aufrufe 2 Beobachtet
  • M MartyBr
    @mickym
    Jetzt bin auf den Geschmack gekommen. Ich habe jetzt versucht, einen JSON-Datenpunkt anzulegen. Das sieht auf dem ersten Blick auch gut aus. In kann aber im Objektbaum ioBroker die Daten nicht öffnen bzw. bearbeiten.
    Hier mal die Infos:
    Datensatz:
    Flow:
            "id": "ae673cf6cd8433a0",
            "type": "subflow",
            "name": "Datum in Topic",
            "info": "",
            "category": "",
            "in": [
                    "x": 60,
                    "y": 80,
                    "wires": [
                            "id": "2e1ea06b2e94bf1a"
            "out": [
                    "x": 820,
                    "y": 80,
                    "wires": [
                            "id": "fc37f5f9d2b0297b",
                            "port": 0
            "env": [
                    "name": "basePath",
                    "type": "str",
                    "value": "Test1.Test2"
            "meta": {},
            "color": "#DDAA99"
            "id": "2e1ea06b2e94bf1a",
            "type": "change",
            "z": "ae673cf6cd8433a0",
            "name": "",
            "rules": [
                    "t": "set",
                    "p": "datum",
                    "pt": "msg",
                    "to": "$moment().locale('de').format('YYYY.MMMM')",
                    "tot": "jsonata"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 230,
            "y": 80,
            "wires": [
                    "0e8de9437c3c420a"
            "id": "0e8de9437c3c420a",
            "type": "change",
            "name": "März zu Maerz",
            "rules": [
                    "t": "change",
                    "p": "datum",
                    "pt": "msg",
                    "from": "März",
                    "fromt": "str",
                    "to": "Maerz",
                    "tot": "str"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 440,
            "y": 80,
            "wires": [
                    "fc37f5f9d2b0297b"
            "type": "change",
            "name": "",
            "rules": [
                    "t": "set",
                    "p": "topic",
                    "pt": "msg",
                    "to": "\"0_userdata.0.\"  & $env(\"basePath\") & \".\" & datum & \".\" & topic",
                    "tot": "jsonata"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 660,
            "y": 80,
            "wires": [
            "id": "fad92726ff7c3254",
            "type": "tab",
            "label": "JSON",
            "disabled": false,
            "info": "",
            "env": []
            "id": "29a754f2b7a96a31",
            "type": "mqtt in",
            "z": "fad92726ff7c3254",
            "name": "ZuluftTemp",
            "topic": "vitocal/ZuluftTemp",
            "qos": "0",
            "datatype": "auto-detect",
            "broker": "bf311140.13d2b8",
            "nl": false,
            "rap": true,
            "rh": 0,
            "inputs": 0,
            "x": 100,
            "y": 120,
            "wires": [
                    "5026b4d763ed7dcc"
            "id": "535565225c8e6f99",
            "type": "subflow:ae673cf6cd8433a0",
            "env": [
                    "name": "basePath",
                    "value": "Test1.Test7",
                    "type": "str"
            "x": 780,
            "y": 180,
            "wires": [
                    "05ad3c7ae6fe582b",
                    "9c9e217c842acefc"
            "id": "05ad3c7ae6fe582b",
            "type": "ioBroker out",
            "name": "",
            "topic": "",
            "ack": "true",
            "autoCreate": "true",
            "stateName": "zuluft-neu",
            "role": "state",
            "payloadType": "object",
            "readonly": "",
            "stateUnit": "°C",
            "stateMin": "",
            "stateMax": "",
            "x": 980,
            "y": 180,
            "wires": []
            "id": "5026b4d763ed7dcc",
            "type": "change",
            "name": "Zuluft",
            "rules": [
                    "t": "set",
                    "p": "topic",
                    "pt": "msg",
                    "to": "Zuluft-Temp",
                    "tot": "str"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 310,
            "y": 120,
            "wires": [
                    "766be49e74305196"
            "id": "a3c1535e1da94552",
            "type": "mqtt in",
            "name": "AbluftTemp",
            "topic": "vitocal/AbluftTemp",
            "qos": "0",
            "nl": false,
            "rap": true,
            "rh": 0,
            "inputs": 0,
            "x": 110,
            "y": 240,
            "wires": [
                    "225419c87f910c3e"
            "id": "225419c87f910c3e",
            "type": "change",
            "name": "Abluft",
            "rules": [
                    "t": "set",
                    "p": "topic",
                    "pt": "msg",
                    "to": "Abluft-Temp",
                    "tot": "str"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 310,
            "y": 240,
            "wires": [
                    "766be49e74305196"
            "id": "766be49e74305196",
            "type": "join",
            "name": "",
            "mode": "custom",
            "build": "object",
            "property": "payload",
            "propertyType": "msg",
            "key": "topic",
            "joiner": "\\n",
            "joinerType": "str",
            "accumulate": true,
            "timeout": "60",
            "count": "2",
            "reduceRight": false,
            "reduceExp": "",
            "reduceInit": "",
            "reduceInitType": "",
            "reduceFixup": "",
            "x": 430,
            "y": 180,
            "wires": [
                    "dd61fc92c8961b14",
                    "457c8ae43cf33de1"
            "id": "224380ff0709c559",
            "type": "json",
            "name": "",
            "action": "",
            "pretty": true,
            "x": 610,
            "y": 180,
            "wires": [
                    "c828c8f4b32a9c0c",
                    "535565225c8e6f99"
            "id": "dd61fc92c8961b14",
            "type": "debug",
            "name": "debug 174",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "complete": "false",
            "statusVal": "",
            "statusType": "auto",
            "x": 510,
            "y": 80,
            "wires": []
            "id": "c828c8f4b32a9c0c",
            "type": "debug",
            "name": "debug 175",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "statusVal": "",
            "x": 710,
            "y": 100,
            "wires": []
            "id": "9c9e217c842acefc",
            "type": "debug",
            "name": "debug 176",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "statusVal": "",
            "x": 950,
            "y": 100,
            "wires": []
            "id": "457c8ae43cf33de1",
            "type": "change",
            "name": "",
            "rules": [
                    "t": "set",
                    "p": "topic",
                    "pt": "msg",
                    "to": "vitovent300",
                    "tot": "str"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 540,
            "y": 300,
            "wires": [
                    "224380ff0709c559",
                    "f92533e2c4de9cf4"
            "id": "f92533e2c4de9cf4",
            "type": "debug",
            "name": "debug 177",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "statusVal": "",
            "x": 730,
            "y": 360,
            "wires": []
            "id": "bf311140.13d2b8",
            "type": "mqtt-broker",
            "name": "Mosquito-Server",
            "broker": "192.168.178.10",
            "port": "1883",
            "clientid": "",
            "autoConnect": true,
            "usetls": false,
            "compatmode": false,
            "protocolVersion": "4",
            "keepalive": "60",
            "cleansession": true,
            "autoUnsubscribe": true,
            "birthTopic": "",
            "birthQos": "0",
            "birthPayload": "",
            "birthMsg": {},
            "closeTopic": "",
            "closeQos": "0",
            "closePayload": "",
            "closeMsg": {},
            "willTopic": "",
            "willQos": "0",
            "willPayload": "",
            "willMsg": {},
            "userProps": "",
            "sessionExpiry": ""
    Müssen evtl eckige Klammern um den Jason gesetzt werden (also [json]?
    mickymM Offline
    mickymM Offline
    mickym
    @martybr Na den Datenpunkt hast Du wahrscheinlich schreibgeschützt angelegt - siehst Du doch an dem Schloss. Musst Du wahrscheinlich beschreibbar machen, in der iobroker-Out Node. Oder im Nachhinein in den Objekteigenschaften des Datenpunktes.
    Ausserdem empfehle ich Dir - keinen Datentyp festzulegen - das macht die NOde selbst und wie gesagt musst Du es beschreibbar anlegen.
    Ja und wie gesagt - Objekte muss man als Strings - also JSON Strings schreiben und auch wieder in Objekte wandeln.
    iobroker kann nur Strings in den States verarbeiten.
    • M MartyBr
      @mickym
      Hier mal die Infos:
      Datensatz:
      Flow:
              "type": "subflow",
              "info": "",
              "category": "",
              "in": [
                      "x": 60,
                      "y": 80,
                      "wires": [
              "out": [
                      "x": 820,
                      "y": 80,
                      "wires": [
                              "port": 0
              "env": [
                      "name": "basePath",
                      "type": "str",
              "meta": {},
              "color": "#DDAA99"
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "datum",
                      "pt": "msg",
                      "tot": "jsonata"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 230,
              "y": 80,
              "wires": [
                      "0e8de9437c3c420a"
              "type": "change",
              "rules": [
                      "t": "change",
                      "p": "datum",
                      "pt": "msg",
                      "from": "März",
                      "fromt": "str",
                      "to": "Maerz",
                      "tot": "str"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 440,
              "y": 80,
              "wires": [
                      "fc37f5f9d2b0297b"
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "topic",
                      "pt": "msg",
                      "tot": "jsonata"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 660,
              "y": 80,
              "wires": [
              "type": "tab",
              "label": "JSON",
              "disabled": false,
              "info": "",
              "env": []
              "type": "mqtt in",
              "qos": "0",
              "nl": false,
              "rap": true,
              "rh": 0,
              "inputs": 0,
              "x": 100,
              "y": 120,
              "wires": [
                      "5026b4d763ed7dcc"
              "env": [
                      "name": "basePath",
                      "type": "str"
              "x": 780,
              "y": 180,
              "wires": [
                      "05ad3c7ae6fe582b",
                      "9c9e217c842acefc"
              "name": "",
              "topic": "",
              "ack": "true",
              "role": "state",
              "readonly": "",
              "stateUnit": "°C",
              "stateMin": "",
              "stateMax": "",
              "x": 980,
              "y": 180,
              "wires": []
              "type": "change",
              "name": "Zuluft",
              "rules": [
                      "t": "set",
                      "p": "topic",
                      "pt": "msg",
                      "tot": "str"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 310,
              "y": 120,
              "wires": [
                      "766be49e74305196"
              "type": "mqtt in",
              "qos": "0",
              "nl": false,
              "rap": true,
              "rh": 0,
              "inputs": 0,
              "x": 110,
              "y": 240,
              "wires": [
                      "225419c87f910c3e"
              "type": "change",
              "name": "Abluft",
              "rules": [
                      "t": "set",
                      "p": "topic",
                      "pt": "msg",
                      "tot": "str"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 310,
              "y": 240,
              "wires": [
                      "766be49e74305196"
              "type": "join",
              "name": "",
              "mode": "custom",
              "build": "object",
              "key": "topic",
              "joiner": "\\n",
              "accumulate": true,
              "timeout": "60",
              "count": "2",
              "reduceExp": "",
              "reduceInit": "",
              "reduceFixup": "",
              "x": 430,
              "y": 180,
              "wires": [
                      "dd61fc92c8961b14",
                      "457c8ae43cf33de1"
              "type": "json",
              "name": "",
              "action": "",
              "pretty": true,
              "x": 610,
              "y": 180,
              "wires": [
                      "c828c8f4b32a9c0c",
                      "535565225c8e6f99"
              "type": "debug",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 510,
              "y": 80,
              "wires": []
              "type": "debug",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 710,
              "y": 100,
              "wires": []
              "type": "debug",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 950,
              "y": 100,
              "wires": []
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "topic",
                      "pt": "msg",
                      "tot": "str"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 540,
              "y": 300,
              "wires": [
                      "224380ff0709c559",
                      "f92533e2c4de9cf4"
              "type": "debug",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 730,
              "y": 360,
              "wires": []
              "port": "1883",
              "clientid": "",
              "usetls": false,
              "keepalive": "60",
              "birthTopic": "",
              "birthQos": "0",
              "birthPayload": "",
              "birthMsg": {},
              "closeTopic": "",
              "closeQos": "0",
              "closePayload": "",
              "closeMsg": {},
              "willTopic": "",
              "willQos": "0",
              "willPayload": "",
              "willMsg": {},
              "userProps": "",
              "sessionExpiry": ""
      mickymM Offline
      mickymM Offline
      mickym
      @martybr Es geht auch als Objekt zu öffnen - aber muss halt beschreibbar sein.
      Und wenn Du es nicht als Objekt, sondern richtig als String festlegst (wie gesagt normalerweise legt man nichts fest, dann wird automatisch der richtige Typ festgelegt), dann macht er auch einen JSON daraus:
      Grundsätzlich würde ich mir übrigens angewöhnen, die JSON Node immer direkt vor die Ausgabe in die iobroker-out -Node zu machen, damit man solange wie möglich mit Objekten arbeiten kann.
      M 2 Antworten Letzte Antwort
      • mickymM mickym
        MartyBr
        @mickym
        Okay, setze ich um.
        Martin
        Homematic und Homematic IP
        • mickymM mickym
          MartyBr
          @mickym
          Funktioniert jetzt.
          Hast du noch eine Idee wie ich die eckigen Klammern um den Datensatz setzen kann? Mit einem Change-Node?
          Martin
          • M MartyBr
            @mickym
            Funktioniert jetzt.
            mickymM Offline
            mickymM Offline
            mickym
            @martybr Eckige Klammern sind ein Array oder in Blockly Chargon eine Liste - Ja Du kannst einfach ein Array mit eckigen Klammern daraus machen - macht aber nur Sinn, wenn Du dann mehrere Objekte im Array hast.
            Selbstverstöndlich kannst Du ein Objekt in ein Array stellen. Wenn Du aber mehrere Objekte in ein Array machen mächtest, dann nutze die $append Funktion.
            Du solltest Dir angewöhnen - nie KLammern zu bezeichen, sondern was für Objekte Du erstellen möchtest.
            • mickymM mickym
              MartyBr
              @mickym
              Okay. das ist mein Ziel. Ich möchte Tageswerte in ein Monatsarray speichern. Das mit den Klammern hat funktioniert.
              Über Arrays muss ich mich erst kundig machen.
              Ziel ist, um 00:00 Uhr generierte Werte in ein Monatsarray zu speichern.
              Ich bereite mal einen Versuch vor.
              Martin
              • M MartyBr
                @mickym
                mickymM Offline
                mickymM Offline
                mickym
                @martybr Dann nimm die $append Funktion
                Hier zum Ausprobieren:
                       "id": "1db807e2530b5198",
                       "type": "change",
                       "z": "7e6af0015415146d",
                       "name": "Vorhandenes Array",
                       "rules": [
                               "t": "set",
                               "p": "array",
                               "pt": "msg",
                               "to": "[{\"Zuluft-Temp\":20.1,\"Abluft-Temp\":20.9},{\"Zuluft-Temp\":21.1,\"Abluft-Temp\":22.9}]",
                               "tot": "json"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 410,
                       "y": 6500,
                       "wires": [
                               "16c668ac241e55c4"
                       "id": "86b4268438857773",
                       "type": "inject",
                       "name": "Einzelnes Objekt",
                       "props": [
                               "p": "payload"
                       "repeat": "",
                       "crontab": "",
                       "once": false,
                       "onceDelay": 0.1,
                       "topic": "",
                       "payload": "{     \"Zuluft-Temp\": 20.1,     \"Abluft-Temp\": 20.9 }",
                       "payloadType": "json",
                       "x": 180,
                       "y": 6500,
                       "wires": [
                               "1db807e2530b5198"
                       "id": "16c668ac241e55c4",
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "$append(array, payload)",
                               "tot": "jsonata"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 630,
                       "y": 6500,
                       "wires": [
                               "c9cfdb97d8474804"
                       "id": "c9cfdb97d8474804",
                       "type": "debug",
                       "name": "Neues Array",
                       "active": true,
                       "tosidebar": true,
                       "console": false,
                       "tostatus": false,
                       "complete": "payload",
                       "targetType": "msg",
                       "statusVal": "",
                       "x": 850,
                       "y": 6500,
                       "wires": []
                • mickymM mickym
                         "type": "change",
                         "rules": [
                                 "t": "set",
                                 "p": "array",
                                 "pt": "msg",
                                 "tot": "json"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 410,
                         "y": 6500,
                         "wires": [
                                 "16c668ac241e55c4"
                         "type": "inject",
                         "props": [
                                 "p": "payload"
                         "repeat": "",
                         "crontab": "",
                         "once": false,
                         "onceDelay": 0.1,
                         "topic": "",
                         "x": 180,
                         "y": 6500,
                         "wires": [
                                 "1db807e2530b5198"
                         "type": "change",
                         "name": "",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 630,
                         "y": 6500,
                         "wires": [
                                 "c9cfdb97d8474804"
                         "type": "debug",
                         "active": true,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "statusVal": "",
                         "x": 850,
                         "y": 6500,
                         "wires": []
                  MartyBr
                  schrieb am zuletzt editiert von MartyBr
                  @mickym
                  das Array wird nach meinem Test nicht aufgefüllt, es bleibt immer nur ein Wert im Array.
                  Die $append scheint nicht zu wirken.
                          "id": "a0d8740faea1647b",
                          "type": "mqtt in",
                          "z": "5c488c180ba51f18",
                          "qos": "0",
                          "nl": false,
                          "rap": true,
                          "rh": 0,
                          "inputs": 0,
                          "x": 140,
                          "y": 260,
                          "wires": [
                                  "afdcb37ccbacb06f"
                          "id": "afdcb37ccbacb06f",
                          "type": "change",
                          "name": "Zuluft",
                          "rules": [
                                  "t": "set",
                                  "p": "topic",
                                  "pt": "msg",
                                  "to": "zuluft",
                                  "tot": "str"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 290,
                          "y": 320,
                          "wires": [
                                  "1643873aeecd8613"
                          "id": "1643873aeecd8613",
                          "type": "change",
                          "rules": [
                                  "t": "set",
                                  "p": "array",
                                  "pt": "msg",
                                  "to": "[]",
                                  "tot": "json"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 490,
                          "y": 280,
                          "wires": [
                                  "c9d97aec2949301c",
                                  "34c8064e4b5c52fa"
                          "id": "34c8064e4b5c52fa",
                          "type": "change",
                          "name": "",
                          "rules": [
                                  "t": "set",
                                  "p": "payload",
                                  "pt": "msg",
                                  "tot": "jsonata"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 610,
                          "y": 340,
                          "wires": [
                                  "5b551b24fc1bb26e"
                          "id": "5b551b24fc1bb26e",
                          "type": "debug",
                          "name": "debug 179",
                          "active": true,
                          "tosidebar": true,
                          "console": false,
                          "tostatus": false,
                          "statusVal": "",
                          "x": 750,
                          "y": 280,
                          "wires": []
                          "id": "c9d97aec2949301c",
                          "type": "debug",
                          "name": "debug 178",
                          "active": true,
                          "tosidebar": true,
                          "console": false,
                          "tostatus": false,
                          "statusVal": "",
                          "x": 710,
                          "y": 160,
                          "wires": []
                          "port": "1883",
                          "clientid": "",
                          "usetls": false,
                          "keepalive": "60",
                          "birthTopic": "",
                          "birthQos": "0",
                          "birthPayload": "",
                          "birthMsg": {},
                          "closeTopic": "",
                          "closeQos": "0",
                          "closePayload": "",
                          "closeMsg": {},
                          "willTopic": "",
                          "willQos": "0",
                          "willPayload": "",
                          "willMsg": {},
                          "userProps": "",
                          "sessionExpiry": ""
                  Was mache ich falsch?
                  Edit:
                  Als Ziel benötige ich für die 4 Werte jeweils ein Array mit
                  Wert1,
                  Wert2,
                  Wert3,
                  Wert28
                  Anzahl der Werte entspricht der Zahl der Tage im laufenden Monat.
                  Martin
                  • M MartyBr
                    @mickym
                            "type": "mqtt in",
                            "qos": "0",
                            "nl": false,
                            "rap": true,
                            "rh": 0,
                            "inputs": 0,
                            "x": 140,
                            "y": 260,
                            "wires": [
                                    "afdcb37ccbacb06f"
                            "type": "change",
                            "name": "Zuluft",
                            "rules": [
                                    "t": "set",
                                    "p": "topic",
                                    "pt": "msg",
                                    "to": "zuluft",
                                    "tot": "str"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 290,
                            "y": 320,
                            "wires": [
                                    "1643873aeecd8613"
                            "type": "change",
                            "rules": [
                                    "t": "set",
                                    "p": "array",
                                    "pt": "msg",
                                    "to": "[]",
                                    "tot": "json"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 490,
                            "y": 280,
                            "wires": [
                                    "c9d97aec2949301c",
                                    "34c8064e4b5c52fa"
                            "type": "change",
                            "name": "",
                            "rules": [
                                    "t": "set",
                                    "p": "payload",
                                    "pt": "msg",
                                    "tot": "jsonata"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 610,
                            "y": 340,
                            "wires": [
                                    "5b551b24fc1bb26e"
                            "type": "debug",
                            "active": true,
                            "tosidebar": true,
                            "console": false,
                            "tostatus": false,
                            "statusVal": "",
                            "x": 750,
                            "y": 280,
                            "wires": []
                            "type": "debug",
                            "active": true,
                            "tosidebar": true,
                            "console": false,
                            "tostatus": false,
                            "statusVal": "",
                            "x": 710,
                            "y": 160,
                            "wires": []
                            "port": "1883",
                            "clientid": "",
                            "usetls": false,
                            "keepalive": "60",
                            "birthTopic": "",
                            "birthQos": "0",
                            "birthPayload": "",
                            "birthMsg": {},
                            "closeTopic": "",
                            "closeQos": "0",
                            "closePayload": "",
                            "closeMsg": {},
                            "willTopic": "",
                            "willQos": "0",
                            "willPayload": "",
                            "willMsg": {},
                            "userProps": "",
                            "sessionExpiry": ""
                    Edit:
                    Wert1,
                    Wert2,
                    Wert3,
                    Wert28
                    mickymM Offline
                    mickymM Offline
                    mickym
                    @martybr Na Du mergst ein leeres Array mit einem skalaren Wert. Dann ist es doch richtig, dass nur ein Wert in dem Array ist. Du musst das Array ja speichern und dann den nächsten Wert anhängen.
                    So hängst Du doch immer wieder nur EIN Wert an ein leeres Array. Du musst doch das Array irgendwo abspeichern und dann das neu erstellte Array mit einem neuen Wert ergänzen.
                    Also überleg Dir wohin Du Dein Array Ergebnis des Anhänges abspeichern willst. In einer Variable oder in einem Datenpunkt.
                    Oder mit anderen Worten: Ein Wert an ein leeres Array angehängt, gibt immer nur ein Array mit einem Wert.
                    • mickymM mickym
                      MartyBr
                      @mickym
                      Okay, das ist ein Ansatzpunkt. Ich mache mir mal Gedanken.
                      Danke für deine Unterstützung.
                      Martin
                      • M MartyBr
                        @mickym
                        mickymM Offline
                        mickymM Offline
                        mickym
                        @martybr sagte in Wert in dynamische Struktur im ioBroker ablegen:
                        @mickym
                        Ich habs Dir mal mit eine Flowvariable gemacht. Das heißt das Ergebnis wird in eine Variable gespeichert und dann wieder eingelesen und der neue Wert angehängt.
                               "type": "mqtt in",
                               "d": true,
                               "qos": "0",
                               "nl": false,
                               "rap": true,
                               "rh": 0,
                               "inputs": 0,
                               "x": 260,
                               "y": 6740,
                               "wires": [
                                       "afdcb37ccbacb06f"
                               "type": "change",
                               "name": "Zuluft",
                               "rules": [
                                       "t": "set",
                                       "p": "topic",
                                       "pt": "msg",
                                       "to": "zuluft",
                                       "tot": "str"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 410,
                               "y": 6800,
                               "wires": [
                                       "1643873aeecd8613"
                               "type": "change",
                               "rules": [
                                       "t": "set",
                                       "p": "array",
                                       "pt": "msg",
                                       "to": "array",
                                       "tot": "flow"
                                       "t": "set",
                                       "p": "array",
                                       "pt": "msg",
                                       "to": "array ? array : []",
                                       "tot": "jsonata"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 610,
                               "y": 6760,
                               "wires": [
                                       "c9d97aec2949301c",
                                       "34c8064e4b5c52fa"
                               "type": "change",
                               "name": "",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "tot": "jsonata"
                                       "t": "set",
                                       "p": "array",
                                       "pt": "flow",
                                       "to": "payload",
                                       "tot": "msg"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 850,
                               "y": 6760,
                               "wires": [
                                       "5b551b24fc1bb26e"
                               "type": "debug",
                               "active": true,
                               "tosidebar": true,
                               "console": false,
                               "tostatus": false,
                               "statusVal": "",
                               "x": 1070,
                               "y": 6740,
                               "wires": []
                               "type": "debug",
                               "active": true,
                               "tosidebar": true,
                               "console": false,
                               "tostatus": false,
                               "statusVal": "",
                               "x": 830,
                               "y": 6640,
                               "wires": []
                               "id": "7961970716d0df25",
                               "type": "inject",
                               "name": "",
                               "props": [
                                       "p": "payload"
                               "repeat": "",
                               "crontab": "",
                               "once": false,
                               "onceDelay": 0.1,
                               "topic": "",
                               "payload": "20.2",
                               "payloadType": "num",
                               "x": 230,
                               "y": 6800,
                               "wires": [
                                       "afdcb37ccbacb06f"
                               "port": "1883",
                               "clientid": "",
                               "usetls": false,
                               "keepalive": "60",
                               "birthTopic": "",
                               "birthQos": "0",
                               "birthPayload": "",
                               "birthMsg": {},
                               "closeTopic": "",
                               "closeQos": "0",
                               "closePayload": "",
                               "closeMsg": {},
                               "willTopic": "",
                               "willQos": "0",
                               "willPayload": "",
                               "willMsg": {},
                               "userProps": "",
                               "sessionExpiry": ""
                        • mickymM mickym
                          @mickym
                                 "type": "mqtt in",
                                 "d": true,
                                 "qos": "0",
                                 "nl": false,
                                 "rap": true,
                                 "rh": 0,
                                 "inputs": 0,
                                 "x": 260,
                                 "y": 6740,
                                 "wires": [
                                         "afdcb37ccbacb06f"
                                 "type": "change",
                                 "name": "Zuluft",
                                 "rules": [
                                         "t": "set",
                                         "p": "topic",
                                         "pt": "msg",
                                         "to": "zuluft",
                                         "tot": "str"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 410,
                                 "y": 6800,
                                 "wires": [
                                         "1643873aeecd8613"
                                 "type": "change",
                                 "rules": [
                                         "t": "set",
                                         "p": "array",
                                         "pt": "msg",
                                         "to": "array",
                                         "tot": "flow"
                                         "t": "set",
                                         "p": "array",
                                         "pt": "msg",
                                         "tot": "jsonata"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 610,
                                 "y": 6760,
                                 "wires": [
                                         "c9d97aec2949301c",
                                         "34c8064e4b5c52fa"
                                 "type": "change",
                                 "name": "",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "tot": "jsonata"
                                         "t": "set",
                                         "p": "array",
                                         "pt": "flow",
                                         "to": "payload",
                                         "tot": "msg"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 850,
                                 "y": 6760,
                                 "wires": [
                                         "5b551b24fc1bb26e"
                                 "type": "debug",
                                 "active": true,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 1070,
                                 "y": 6740,
                                 "wires": []
                                 "type": "debug",
                                 "active": true,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 830,
                                 "y": 6640,
                                 "wires": []
                                 "type": "inject",
                                 "name": "",
                                 "props": [
                                         "p": "payload"
                                 "repeat": "",
                                 "crontab": "",
                                 "once": false,
                                 "onceDelay": 0.1,
                                 "topic": "",
                                 "payload": "20.2",
                                 "x": 230,
                                 "y": 6800,
                                 "wires": [
                                         "afdcb37ccbacb06f"
                                 "port": "1883",
                                 "clientid": "",
                                 "usetls": false,
                                 "keepalive": "60",
                                 "birthTopic": "",
                                 "birthQos": "0",
                                 "birthPayload": "",
                                 "birthMsg": {},
                                 "closeTopic": "",
                                 "closeQos": "0",
                                 "closePayload": "",
                                 "closeMsg": {},
                                 "willTopic": "",
                                 "willQos": "0",
                                 "willPayload": "",
                                 "willMsg": {},
                                 "userProps": "",
                                 "sessionExpiry": ""
                          MartyBr
                          @mickym
                          Der Flow funktioniert.
                          Ich habe eine Objektveriable in ioBroker.
                                 "type": "mqtt in",
                                 "d": true,
                                 "qos": "0",
                                 "nl": false,
                                 "rap": true,
                                 "rh": 0,
                                 "inputs": 0,
                                 "x": 260,
                                 "y": 6740,
                                 "wires": [
                                         "afdcb37ccbacb06f"
                                 "type": "change",
                                 "name": "Zuluft",
                                 "rules": [
                                         "t": "set",
                                         "p": "topic",
                                         "pt": "msg",
                                         "to": "zuluft",
                                         "tot": "str"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 410,
                                 "y": 6800,
                                 "wires": [
                                         "1643873aeecd8613"
                                 "type": "change",
                                 "rules": [
                                         "t": "set",
                                         "p": "array",
                                         "pt": "msg",
                                         "to": "array",
                                         "tot": "flow"
                                         "t": "set",
                                         "p": "array",
                                         "pt": "msg",
                                         "tot": "jsonata"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 610,
                                 "y": 6760,
                                 "wires": [
                                         "c9d97aec2949301c",
                                         "34c8064e4b5c52fa"
                                 "type": "change",
                                 "name": "",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "tot": "jsonata"
                                         "t": "set",
                                         "p": "array",
                                         "pt": "flow",
                                         "to": "payload",
                                         "tot": "msg"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 850,
                                 "y": 6760,
                                 "wires": [
                                         "5b551b24fc1bb26e"
                                 "type": "debug",
                                 "active": true,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 1070,
                                 "y": 6740,
                                 "wires": []
                                 "type": "debug",
                                 "active": true,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 830,
                                 "y": 6640,
                                 "wires": []
                                 "type": "inject",
                                 "name": "",
                                 "props": [
                                         "p": "payload"
                                 "repeat": "",
                                 "crontab": "",
                                 "once": false,
                                 "onceDelay": 0.1,
                                 "topic": "",
                                 "payload": "20.2",
                                 "x": 230,
                                 "y": 6800,
                                 "wires": [
                                         "afdcb37ccbacb06f"
                                 "port": "1883",
                                 "clientid": "",
                                 "usetls": false,
                                 "keepalive": "60",
                                 "birthTopic": "",
                                 "birthQos": "0",
                                 "birthPayload": "",
                                 "birthMsg": {},
                                 "closeTopic": "",
                                 "closeQos": "0",
                                 "closePayload": "",
                                 "closeMsg": {},
                                 "willTopic": "",
                                 "willQos": "0",
                                 "willPayload": "",
                                 "willMsg": {},
                                 "userProps": "",
                                 "sessionExpiry": ""
                          Wie kann ich das Array persistent ablegen?
                          Martin
                          • M MartyBr
                            @mickym
                                   "type": "mqtt in",
                                   "d": true,
                                   "qos": "0",
                                   "nl": false,
                                   "rap": true,
                                   "rh": 0,
                                   "inputs": 0,
                                   "x": 260,
                                   "y": 6740,
                                   "wires": [
                                           "afdcb37ccbacb06f"
                                   "type": "change",
                                   "name": "Zuluft",
                                   "rules": [
                                           "t": "set",
                                           "p": "topic",
                                           "pt": "msg",
                                           "to": "zuluft",
                                           "tot": "str"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 410,
                                   "y": 6800,
                                   "wires": [
                                           "1643873aeecd8613"
                                   "type": "change",
                                   "rules": [
                                           "t": "set",
                                           "p": "array",
                                           "pt": "msg",
                                           "to": "array",
                                           "tot": "flow"
                                           "t": "set",
                                           "p": "array",
                                           "pt": "msg",
                                           "tot": "jsonata"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 610,
                                   "y": 6760,
                                   "wires": [
                                           "c9d97aec2949301c",
                                           "34c8064e4b5c52fa"
                                   "type": "change",
                                   "name": "",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "tot": "jsonata"
                                           "t": "set",
                                           "p": "array",
                                           "pt": "flow",
                                           "to": "payload",
                                           "tot": "msg"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 850,
                                   "y": 6760,
                                   "wires": [
                                           "5b551b24fc1bb26e"
                                   "type": "debug",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 1070,
                                   "y": 6740,
                                   "wires": []
                                   "type": "debug",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 830,
                                   "y": 6640,
                                   "wires": []
                                   "type": "inject",
                                   "name": "",
                                   "props": [
                                           "p": "payload"
                                   "repeat": "",
                                   "crontab": "",
                                   "once": false,
                                   "onceDelay": 0.1,
                                   "topic": "",
                                   "payload": "20.2",
                                   "x": 230,
                                   "y": 6800,
                                   "wires": [
                                           "afdcb37ccbacb06f"
                                   "port": "1883",
                                   "clientid": "",
                                   "usetls": false,
                                   "keepalive": "60",
                                   "birthTopic": "",
                                   "birthQos": "0",
                                   "birthPayload": "",
                                   "birthMsg": {},
                                   "closeTopic": "",
                                   "closeQos": "0",
                                   "closePayload": "",
                                   "closeMsg": {},
                                   "willTopic": "",
                                   "willQos": "0",
                                   "willPayload": "",
                                   "willMsg": {},
                                   "userProps": "",
                                   "sessionExpiry": ""
                            mickymM Offline
                            mickymM Offline
                            mickym
                            @martybr
                            Datenpunkt im iobroker oder im mqtt - wo immer Du willst.
                            • mickymM mickym
                              @martybr
                              MartyBr
                              @mickym
                              Ich habe das mal so gemacht:
                                      "id": "99d066d4bbe5dca9",
                                      "type": "inject",
                                      "name": "",
                                      "props": [
                                              "p": "payload"
                                      "repeat": "",
                                      "crontab": "",
                                      "once": false,
                                      "onceDelay": 0.1,
                                      "topic": "",
                                      "payload": "20.2",
                                      "x": 350,
                                      "y": 700,
                                      "wires": [
                                              "994a1a0b6d25cef4"
                                      "id": "82d5f1b2aa875c35",
                                      "type": "mqtt in",
                                      "qos": "0",
                                      "nl": false,
                                      "rap": true,
                                      "rh": 0,
                                      "inputs": 0,
                                      "x": 420,
                                      "y": 620,
                                      "wires": [
                                              "994a1a0b6d25cef4"
                                      "id": "994a1a0b6d25cef4",
                                      "type": "change",
                                      "name": "Zuluft",
                                      "rules": [
                                              "t": "set",
                                              "p": "topic",
                                              "pt": "msg",
                                              "to": "zuluft",
                                              "tot": "str"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 530,
                                      "y": 700,
                                      "wires": [
                                              "4a49f7b7cb1d35d2"
                                      "id": "de7a183e542f367e",
                                      "type": "ioBroker get object",
                                      "name": "Test.Test-JSON",
                                      "topic": "0_userdata.0.Test.Test-JSON",
                                      "attrname": "array",
                                      "x": 620,
                                      "y": 580,
                                      "wires": [
                                      "id": "4a49f7b7cb1d35d2",
                                      "type": "change",
                                      "rules": [
                                              "t": "set",
                                              "p": "array",
                                              "pt": "msg",
                                              "to": "array",
                                              "tot": "flow"
                                              "t": "set",
                                              "p": "array",
                                              "pt": "msg",
                                              "tot": "jsonata"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 730,
                                      "y": 660,
                                      "wires": [
                                              "1bf56806da8b2399",
                                              "40df7a89751f5b92"
                                      "id": "40df7a89751f5b92",
                                      "type": "change",
                                      "name": "",
                                      "rules": [
                                              "t": "set",
                                              "p": "payload",
                                              "pt": "msg",
                                              "tot": "jsonata"
                                              "t": "set",
                                              "p": "array",
                                              "pt": "flow",
                                              "to": "payload",
                                              "tot": "msg"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 830,
                                      "y": 740,
                                      "wires": [
                                              "cb026a3b7a51d987",
                                              "8d9b65f4efb22698"
                                      "id": "cb026a3b7a51d987",
                                      "type": "debug",
                                      "active": true,
                                      "tosidebar": true,
                                      "console": false,
                                      "tostatus": false,
                                      "statusVal": "",
                                      "x": 890,
                                      "y": 800,
                                      "wires": []
                                      "id": "8d9b65f4efb22698",
                                      "ack": "true",
                                      "autoCreate": "false",
                                      "stateName": "",
                                      "role": "",
                                      "payloadType": "",
                                      "readonly": "",
                                      "stateUnit": "",
                                      "stateMin": "",
                                      "stateMax": "",
                                      "x": 1000,
                                      "y": 660,
                                      "wires": []
                                      "id": "1bf56806da8b2399",
                                      "type": "debug",
                                      "active": true,
                                      "tosidebar": true,
                                      "console": false,
                                      "tostatus": false,
                                      "statusVal": "",
                                      "x": 950,
                                      "y": 540,
                                      "wires": []
                                      "port": "1883",
                                      "clientid": "",
                                      "usetls": false,
                                      "keepalive": "60",
                                      "birthTopic": "",
                                      "birthQos": "0",
                                      "birthPayload": "",
                                      "birthMsg": {},
                                      "closeTopic": "",
                                      "closeQos": "0",
                                      "closePayload": "",
                                      "closeMsg": {},
                                      "willTopic": "",
                                      "willQos": "0",
                                      "willPayload": "",
                                      "willMsg": {},
                                      "userProps": "",
                                      "sessionExpiry": ""
                              Die Werte kommen auch richtig im Datenpunkt an.
                              Jetzt noch eine letzte Frage für Heute 😇
                              Der Flow soll einen Monat laufen. Wenn nun ein Neustart vom ioBroker erfolgt, muss der Flow am letzten Datensatz wieder aufsetzen. Muss der daher nicht den letzten Stand aus dem Speicherdatenpunkt wieder einlesen?
                              Edit:
                              Ich habe im Flow eine ioBroker-getObject. Die ist wahrscheinlich falsch. Richtig?
                              Martin
                              • M MartyBr
                                @mickym
                                        "type": "inject",
                                        "name": "",
                                        "props": [
                                                "p": "payload"
                                        "repeat": "",
                                        "crontab": "",
                                        "once": false,
                                        "onceDelay": 0.1,
                                        "topic": "",
                                        "payload": "20.2",
                                        "x": 350,
                                        "y": 700,
                                        "wires": [
                                                "994a1a0b6d25cef4"
                                        "type": "mqtt in",
                                        "qos": "0",
                                        "nl": false,
                                        "rap": true,
                                        "rh": 0,
                                        "inputs": 0,
                                        "x": 420,
                                        "y": 620,
                                        "wires": [
                                                "994a1a0b6d25cef4"
                                        "type": "change",
                                        "name": "Zuluft",
                                        "rules": [
                                                "t": "set",
                                                "p": "topic",
                                                "pt": "msg",
                                                "to": "zuluft",
                                                "tot": "str"
                                        "action": "",
                                        "property": "",
                                        "from": "",
                                        "to": "",
                                        "reg": false,
                                        "x": 530,
                                        "y": 700,
                                        "wires": [
                                                "4a49f7b7cb1d35d2"
                                        "x": 620,
                                        "y": 580,
                                        "wires": [
                                        "type": "change",
                                        "rules": [
                                                "t": "set",
                                                "p": "array",
                                                "pt": "msg",
                                                "to": "array",
                                                "tot": "flow"
                                                "t": "set",
                                                "p": "array",
                                                "pt": "msg",
                                                "tot": "jsonata"
                                        "action": "",
                                        "property": "",
                                        "from": "",
                                        "to": "",
                                        "reg": false,
                                        "x": 730,
                                        "y": 660,
                                        "wires": [
                                                "1bf56806da8b2399",
                                                "40df7a89751f5b92"
                                        "type": "change",
                                        "name": "",
                                        "rules": [
                                                "t": "set",
                                                "p": "payload",
                                                "pt": "msg",
                                                "tot": "jsonata"
                                                "t": "set",
                                                "p": "array",
                                                "pt": "flow",
                                                "to": "payload",
                                                "tot": "msg"
                                        "action": "",
                                        "property": "",
                                        "from": "",
                                        "to": "",
                                        "reg": false,
                                        "x": 830,
                                        "y": 740,
                                        "wires": [
                                                "cb026a3b7a51d987",
                                                "8d9b65f4efb22698"
                                        "type": "debug",
                                        "active": true,
                                        "tosidebar": true,
                                        "console": false,
                                        "tostatus": false,
                                        "statusVal": "",
                                        "x": 890,
                                        "y": 800,
                                        "wires": []
                                        "ack": "true",
                                        "stateName": "",
                                        "role": "",
                                        "payloadType": "",
                                        "readonly": "",
                                        "stateUnit": "",
                                        "stateMin": "",
                                        "stateMax": "",
                                        "x": 1000,
                                        "y": 660,
                                        "wires": []
                                        "type": "debug",
                                        "active": true,
                                        "tosidebar": true,
                                        "console": false,
                                        "tostatus": false,
                                        "statusVal": "",
                                        "x": 950,
                                        "y": 540,
                                        "wires": []
                                        "port": "1883",
                                        "clientid": "",
                                        "usetls": false,
                                        "keepalive": "60",
                                        "birthTopic": "",
                                        "birthQos": "0",
                                        "birthPayload": "",
                                        "birthMsg": {},
                                        "closeTopic": "",
                                        "closeQos": "0",
                                        "closePayload": "",
                                        "closeMsg": {},
                                        "willTopic": "",
                                        "willQos": "0",
                                        "willPayload": "",
                                        "willMsg": {},
                                        "userProps": "",
                                        "sessionExpiry": ""
                                Edit:
                                mickymM Offline
                                mickymM Offline
                                mickym
                                Nein Du willst kein Objekt, sondern entweder über iobroker- in oder get. Dann brauchst Du aber hinten nicht in eine flow Variable speichern - sondern die Flowvariable direkt über die iobroker-In füllen.
                                • mickymM mickym
                                  MartyBr
                                  @mickym
                                  Ich habe es noch nicht so ganz verstanden. Ich habe es nun so gebaut, wie ich es verstanden habe. Exemplarisch für zwei Flows / Arrays:
                                          "id": "5bbdcd58332d0b96",
                                          "type": "ioBroker in",
                                          "name": "Bezug täglich",
                                          "attrname": "payload",
                                          "topic": "0_userdata.0.Zaehler.Strombezug.Verbrauch.täglich",
                                          "payloadType": "value",
                                          "onlyack": "",
                                          "func": "all",
                                          "gap": "",
                                          "fireOnStart": "true",
                                          "outFormat": "MQTT",
                                          "x": 110,
                                          "y": 40,
                                          "wires": [
                                                  "53d6131492b2abed"
                                          "id": "4bb406f8dd2161dd",
                                          "name": "Einspeisung täglich",
                                          "topic": "0_userdata.0.Zaehler.Stromeinspeisung.Verbrauch.täglich",
                                          "onlyack": "",
                                          "func": "all",
                                          "gap": "",
                                          "x": 130,
                                          "y": 120,
                                          "wires": [
                                                  "c4e24a8d35d070ae"
                                          "id": "c4e24a8d35d070ae",
                                          "type": "change",
                                          "name": "Einspeisung",
                                          "rules": [
                                                  "t": "set",
                                                  "p": "topic",
                                                  "pt": "msg",
                                                  "to": "einspeisung",
                                                  "tot": "str"
                                          "action": "",
                                          "property": "",
                                          "from": "",
                                          "to": "",
                                          "reg": false,
                                          "x": 330,
                                          "y": 120,
                                          "wires": [
                                                  "278bac26e6737147"
                                          "id": "53d6131492b2abed",
                                          "type": "change",
                                          "name": "Bezug",
                                          "rules": [
                                                  "t": "set",
                                                  "p": "topic",
                                                  "pt": "msg",
                                                  "to": "bezug",
                                                  "tot": "str"
                                          "action": "",
                                          "property": "",
                                          "from": "",
                                          "to": "",
                                          "reg": false,
                                          "x": 270,
                                          "y": 40,
                                          "wires": [
                                                  "c617a78f8ddaca22"
                                          "id": "c617a78f8ddaca22",
                                          "type": "change",
                                          "rules": [
                                                  "t": "set",
                                                  "p": "array-bezug",
                                                  "pt": "msg",
                                                  "to": "array-bezug",
                                                  "tot": "flow"
                                                  "t": "set",
                                                  "p": "array-bezug",
                                                  "pt": "msg",
                                                  "to": "array-bezug ? array-bezug : []",
                                                  "tot": "jsonata"
                                          "action": "",
                                          "property": "",
                                          "from": "",
                                          "to": "",
                                          "reg": false,
                                          "x": 450,
                                          "y": 40,
                                          "wires": [
                                                  "ff519a511afeb6f1"
                                          "id": "ff519a511afeb6f1",
                                          "type": "change",
                                          "name": "",
                                          "rules": [
                                                  "t": "set",
                                                  "p": "payload",
                                                  "pt": "msg",
                                                  "to": "$append(array-bezug, payload)",
                                                  "tot": "jsonata"
                                                  "t": "set",
                                                  "p": "array-bezug",
                                                  "pt": "flow",
                                                  "to": "payload",
                                                  "tot": "msg"
                                          "action": "",
                                          "property": "",
                                          "from": "",
                                          "to": "",
                                          "reg": false,
                                          "x": 670,
                                          "y": 40,
                                          "wires": [
                                                  "3274ac485bf96d56"
                                          "id": "3274ac485bf96d56",
                                          "name": "Test.Bezug-JSON",
                                          "topic": "0_userdata.0.Test.Bezug-JSON",
                                          "ack": "true",
                                          "stateName": "",
                                          "role": "",
                                          "payloadType": "",
                                          "readonly": "false",
                                          "stateUnit": "",
                                          "stateMin": "",
                                          "stateMax": "",
                                          "x": 890,
                                          "y": 40,
                                          "wires": []
                                          "id": "278bac26e6737147",
                                          "type": "change",
                                          "rules": [
                                                  "t": "set",
                                                  "p": "array-einspeisung",
                                                  "pt": "msg",
                                                  "to": "array-einspeisung",
                                                  "tot": "flow"
                                                  "t": "set",
                                                  "pt": "msg",
                                                  "to": "array-einspeisung ? array-einspeisung : []",
                                                  "tot": "jsonata"
                                          "action": "",
                                          "property": "",
                                          "from": "",
                                          "to": "",
                                          "reg": false,
                                          "x": 530,
                                          "y": 120,
                                          "wires": [
                                                  "27eb027a108b6b2a"
                                          "id": "27eb027a108b6b2a",
                                          "type": "change",
                                          "name": "",
                                          "rules": [
                                                  "t": "set",
                                                  "p": "payload",
                                                  "pt": "msg",
                                                  "to": "$append(array-einspeisung, payload)",
                                                  "tot": "jsonata"
                                                  "t": "set",
                                                  "pt": "flow",
                                                  "to": "payload",
                                                  "tot": "msg"
                                          "action": "",
                                          "property": "",
                                          "from": "",
                                          "to": "",
                                          "reg": false,
                                          "x": 750,
                                          "y": 120,
                                          "wires": [
                                                  "8c3a9cbe90f64091"
                                          "id": "8c3a9cbe90f64091",
                                          "name": "Test.Einspeisung-JSON",
                                          "topic": "0_userdata.0.Test.Einspeisung-JSON",
                                          "ack": "true",
                                          "stateName": "",
                                          "role": "",
                                          "payloadType": "",
                                          "stateUnit": "",
                                          "stateMin": "",
                                          "stateMax": "",
                                          "x": 990,
                                          "y": 120,
                                          "wires": []
                                  Die Daten aktualisieren sich täglich. Wenn das in Ordnung ist, dann gehe ich an die Zeitsteuerung.
                                  Martin
                                    MartyBr
                                    @mickym
                                    Ich habe hier noch ein Problem, die Zahl der Tage im Monat in eine globale Variable zu schreiben. Statt der 28 Tage aus der Funktion liefert mir der Change Node nur payload == 5
                                            "id": "f6ed836d74798c7f",
                                            "type": "inject",
                                            "z": "3ebdbbcf49e0ac40",
                                            "name": "",
                                            "props": [
                                                    "p": "payload"
                                                    "p": "topic",
                                                    "vt": "str"
                                            "repeat": "",
                                            "crontab": "",
                                            "once": false,
                                            "onceDelay": 0.1,
                                            "topic": "",
                                            "payload": "",
                                            "payloadType": "date",
                                            "x": 100,
                                            "y": 400,
                                            "wires": [
                                                    "a3434007e702fcdc"
                                            "id": "7a09df47bef16411",
                                            "type": "function",
                                            "name": "function 1",
                                            "func": "// Eingabe: msg.payload sollte ein Datum im Format 'YYYY-MM-DD' sein\nlet inputDate = new Date(msg.payload);\n\n// Hole den Monat und das Jahr\nlet month = inputDate.getMonth(); // 0-11\nlet year = inputDate.getFullYear();\n\n// Berechne die Anzahl der Tage im Monat\nlet daysInMonth = new Date(year, month + 1, 0).getDate();\n\n// Setze das Ergebnis in msg.payload\nmsg.payload = daysInMonth;\n\nreturn msg;",
                                            "outputs": 1,
                                            "timeout": 0,
                                            "noerr": 0,
                                            "initialize": "",
                                            "finalize": "",
                                            "libs": [],
                                            "x": 480,
                                            "y": 400,
                                            "wires": [
                                                    "599b66169127c12d",
                                                    "185c42081279a5e0"
                                            "id": "a3434007e702fcdc",
                                            "type": "change",
                                            "name": "",
                                            "rules": [
                                                    "t": "set",
                                                    "p": "payload",
                                                    "pt": "msg",
                                                    "to": "$moment().locale('de').format('YYYY.MM.DD')",
                                                    "tot": "jsonata"
                                            "action": "",
                                            "property": "",
                                            "from": "",
                                            "to": "",
                                            "reg": false,
                                            "x": 290,
                                            "y": 400,
                                            "wires": [
                                                    "7a09df47bef16411"
                                            "id": "d8d647f4ae028cb8",
                                            "type": "debug",
                                            "name": "debug 182",
                                            "active": true,
                                            "tosidebar": true,
                                            "console": false,
                                            "tostatus": false,
                                            "statusVal": "",
                                            "x": 670,
                                            "y": 320,
                                            "wires": []
                                            "id": "599b66169127c12d",
                                            "type": "change",
                                            "name": "Monatstage",
                                            "rules": [
                                                    "t": "move",
                                                    "p": "payload",
                                                    "pt": "msg",
                                                    "to": "monatstage",
                                                    "tot": "global"
                                            "action": "",
                                            "property": "",
                                            "from": "",
                                            "to": "",
                                            "reg": false,
                                            "x": 650,
                                            "y": 400,
                                            "wires": [
                                                    "d8d647f4ae028cb8"
                                            "id": "185c42081279a5e0",
                                            "type": "debug",
                                            "name": "debug 183",
                                            "active": true,
                                            "tosidebar": true,
                                            "console": false,
                                            "tostatus": false,
                                            "statusVal": "",
                                            "x": 590,
                                            "y": 480,
                                            "wires": []
                                    Martin
                                    M mickymM 2 Antworten Letzte Antwort
                                    • M MartyBr
                                      @mickym
                                              "type": "inject",
                                              "name": "",
                                              "props": [
                                                      "p": "payload"
                                                      "p": "topic",
                                                      "vt": "str"
                                              "repeat": "",
                                              "crontab": "",
                                              "once": false,
                                              "onceDelay": 0.1,
                                              "topic": "",
                                              "payload": "",
                                              "x": 100,
                                              "y": 400,
                                              "wires": [
                                                      "a3434007e702fcdc"
                                              "type": "function",
                                              "outputs": 1,
                                              "timeout": 0,
                                              "noerr": 0,
                                              "initialize": "",
                                              "finalize": "",
                                              "libs": [],
                                              "x": 480,
                                              "y": 400,
                                              "wires": [
                                                      "599b66169127c12d",
                                                      "185c42081279a5e0"
                                              "type": "change",
                                              "name": "",
                                              "rules": [
                                                      "t": "set",
                                                      "p": "payload",
                                                      "pt": "msg",
                                                      "tot": "jsonata"
                                              "action": "",
                                              "property": "",
                                              "from": "",
                                              "to": "",
                                              "reg": false,
                                              "x": 290,
                                              "y": 400,
                                              "wires": [
                                                      "7a09df47bef16411"
                                              "type": "debug",
                                              "active": true,
                                              "tosidebar": true,
                                              "console": false,
                                              "tostatus": false,
                                              "statusVal": "",
                                              "x": 670,
                                              "y": 320,
                                              "wires": []
                                              "type": "change",
                                              "rules": [
                                                      "t": "move",
                                                      "p": "payload",
                                                      "pt": "msg",
                                                      "to": "monatstage",
                                                      "tot": "global"
                                              "action": "",
                                              "property": "",
                                              "from": "",
                                              "to": "",
                                              "reg": false,
                                              "x": 650,
                                              "y": 400,
                                              "wires": [
                                                      "d8d647f4ae028cb8"
                                              "type": "debug",
                                              "active": true,
                                              "tosidebar": true,
                                              "console": false,
                                              "tostatus": false,
                                              "statusVal": "",
                                              "x": 590,
                                              "y": 480,
                                              "wires": []
                                      MartyBr
                                      @mickym
                                      Ich glaube, dass ich das Problem gelöst habe:
                                              "type": "inject",
                                              "name": "",
                                              "props": [
                                                      "p": "payload"
                                                      "p": "topic",
                                                      "vt": "str"
                                              "repeat": "",
                                              "crontab": "",
                                              "once": false,
                                              "onceDelay": 0.1,
                                              "topic": "",
                                              "payload": "",
                                              "x": 100,
                                              "y": 400,
                                              "wires": [
                                                      "a3434007e702fcdc"
                                              "type": "function",
                                              "outputs": 1,
                                              "timeout": 0,
                                              "noerr": 0,
                                              "initialize": "",
                                              "finalize": "",
                                              "libs": [],
                                              "x": 480,
                                              "y": 400,
                                              "wires": [
                                                      "599b66169127c12d"
                                              "type": "change",
                                              "name": "",
                                              "rules": [
                                                      "t": "set",
                                                      "p": "payload",
                                                      "pt": "msg",
                                                      "tot": "jsonata"
                                              "action": "",
                                              "property": "",
                                              "from": "",
                                              "to": "",
                                              "reg": false,
                                              "x": 290,
                                              "y": 400,
                                              "wires": [
                                                      "7a09df47bef16411"
                                              "type": "debug",
                                              "active": true,
                                              "tosidebar": true,
                                              "console": false,
                                              "tostatus": false,
                                              "statusVal": "",
                                              "x": 650,
                                              "y": 340,
                                              "wires": []
                                              "type": "change",
                                              "rules": [
                                                      "t": "set",
                                                      "p": "payload",
                                                      "pt": "msg",
                                                      "to": "payload",
                                                      "tot": "msg"
                                                      "t": "set",
                                                      "p": "payload",
                                                      "pt": "msg",
                                                      "to": "monatstage",
                                                      "tot": "global"
                                              "action": "",
                                              "property": "",
                                              "from": "",
                                              "to": "",
                                              "reg": false,
                                              "x": 650,
                                              "y": 400,
                                              "wires": [
                                                      "d8d647f4ae028cb8"
                                              "type": "debug",
                                              "active": true,
                                              "tosidebar": true,
                                              "console": false,
                                              "tostatus": false,
                                              "statusVal": "",
                                              "x": 450,
                                              "y": 460,
                                              "wires": []
                                              "id": "5f695a4b2b007db0",
                                              "type": "change",
                                              "rules": [
                                                      "t": "set",
                                                      "p": "payload",
                                                      "pt": "msg",
                                                      "to": "monatstage",
                                                      "tot": "global"
                                              "action": "",
                                              "property": "",
                                              "from": "",
                                              "to": "",
                                              "reg": false,
                                              "x": 270,
                                              "y": 460,
                                              "wires": [
                                                      "185c42081279a5e0"
                                              "id": "0191af1c60e06008",
                                              "type": "inject",
                                              "name": "",
                                              "props": [
                                                      "p": "payload"
                                                      "p": "topic",
                                                      "vt": "str"
                                              "repeat": "",
                                              "crontab": "",
                                              "once": false,
                                              "onceDelay": 0.1,
                                              "topic": "",
                                              "payload": "",
                                              "x": 100,
                                              "y": 460,
                                              "wires": [
                                                      "5f695a4b2b007db0"
                                      Kannst du bitte mal darüber schauen?
                                      Martin
                                      • M MartyBr
                                        @mickym
                                                "type": "inject",
                                                "name": "",
                                                "props": [
                                                        "p": "payload"
                                                        "p": "topic",
                                                        "vt": "str"
                                                "repeat": "",
                                                "crontab": "",
                                                "once": false,
                                                "onceDelay": 0.1,
                                                "topic": "",
                                                "payload": "",
                                                "x": 100,
                                                "y": 400,
                                                "wires": [
                                                        "a3434007e702fcdc"
                                                "type": "function",
                                                "outputs": 1,
                                                "timeout": 0,
                                                "noerr": 0,
                                                "initialize": "",
                                                "finalize": "",
                                                "libs": [],
                                                "x": 480,
                                                "y": 400,
                                                "wires": [
                                                        "599b66169127c12d"
                                                "type": "change",
                                                "name": "",
                                                "rules": [
                                                        "t": "set",
                                                        "p": "payload",
                                                        "pt": "msg",
                                                        "tot": "jsonata"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 290,
                                                "y": 400,
                                                "wires": [
                                                        "7a09df47bef16411"
                                                "type": "debug",
                                                "active": true,
                                                "tosidebar": true,
                                                "console": false,
                                                "tostatus": false,
                                                "statusVal": "",
                                                "x": 650,
                                                "y": 340,
                                                "wires": []
                                                "type": "change",
                                                "rules": [
                                                        "t": "set",
                                                        "p": "payload",
                                                        "pt": "msg",
                                                        "to": "payload",
                                                        "tot": "msg"
                                                        "t": "set",
                                                        "p": "payload",
                                                        "pt": "msg",
                                                        "to": "monatstage",
                                                        "tot": "global"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 650,
                                                "y": 400,
                                                "wires": [
                                                        "d8d647f4ae028cb8"
                                                "type": "debug",
                                                "active": true,
                                                "tosidebar": true,
                                                "console": false,
                                                "tostatus": false,
                                                "statusVal": "",
                                                "x": 450,
                                                "y": 460,
                                                "wires": []
                                                "type": "change",
                                                "rules": [
                                                        "t": "set",
                                                        "p": "payload",
                                                        "pt": "msg",
                                                        "to": "monatstage",
                                                        "tot": "global"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 270,
                                                "y": 460,
                                                "wires": [
                                                        "185c42081279a5e0"
                                                "type": "inject",
                                                "name": "",
                                                "props": [
                                                        "p": "payload"
                                                        "p": "topic",
                                                        "vt": "str"
                                                "repeat": "",
                                                "crontab": "",
                                                "once": false,
                                                "onceDelay": 0.1,
                                                "topic": "",
                                                "payload": "",
                                                "x": 100,
                                                "y": 460,
                                                "wires": [
                                                        "5f695a4b2b007db0"
                                        MartyBr
                                        @mickym
                                        Ich habe hier noch einen Fehler im Flow. Ich habe nun die dynamische Datumsablage hinzugefügt und den iobroker out entsprechend geändert. Der Datenpunkt wird auch angelegt, aber als "number" und nicht als Array (mit [Wert1, Wert2,...].
                                                "type": "subflow",
                                                "info": "",
                                                "category": "",
                                                "in": [
                                                        "x": 60,
                                                        "y": 80,
                                                        "wires": [
                                                "out": [
                                                        "x": 820,
                                                        "y": 80,
                                                        "wires": [
        "port": 0
                                                "env": [
                                                        "name": "basePath",
                                                        "type": "str",
                                                "meta": {},
                                                "color": "#DDAA99"
                                                "type": "change",
                                                "name": "",
                                                "rules": [
                                                        "t": "set",
                                                        "p": "datum",
                                                        "pt": "msg",
                                                        "tot": "jsonata"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 230,
                                                "y": 80,
                                                "wires": [
                                                        "0e8de9437c3c420a"
                                                "type": "change",
                                                "rules": [
                                                        "t": "change",
                                                        "p": "datum",
                                                        "pt": "msg",
                                                        "from": "März",
                                                        "fromt": "str",
                                                        "to": "Maerz",
                                                        "tot": "str"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 440,
                                                "y": 80,
                                                "wires": [
                                                        "fc37f5f9d2b0297b"
                                                "type": "change",
                                                "name": "",
                                                "rules": [
                                                        "t": "set",
                                                        "p": "topic",
                                                        "pt": "msg",
                                                        "tot": "jsonata"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 660,
                                                "y": 80,
                                                "wires": [
                                                "id": "1d93ae2f970605e5",
                                                "type": "debug",
                                                "name": "debug 184",
                                                "active": true,
                                                "tosidebar": true,
                                                "console": false,
                                                "tostatus": false,
                                                "statusVal": "",
                                                "x": 1050,
                                                "y": 180,
                                                "wires": []
                                                "id": "e700e5e9b292c820",
                                                "name": "",
                                                "topic": "",
                                                "ack": "true",
                                                "stateName": "",
                                                "role": "",
                                                "payloadType": "",
                                                "stateUnit": "",
                                                "stateMin": "",
                                                "stateMax": "",
                                                "x": 1060,
                                                "y": 120,
                                                "wires": []
                                                "id": "5e8ce599dad4fa74",
                                                "name": "",
                                                "env": [
                                                        "name": "basePath",
                                                        "value": "Test1.Test5.MonatsTabellen",
                                                        "type": "str"
                                                "x": 860,
                                                "y": 40,
                                                "wires": [
                                                        "e700e5e9b292c820",
                                                        "1d93ae2f970605e5"
                                                "type": "change",
                                                "name": "",
                                                "rules": [
                                                        "t": "set",
                                                        "p": "payload",
                                                        "pt": "msg",
                                                        "tot": "jsonata"
                                                        "t": "set",
                                                        "p": "array-bezug",
                                                        "pt": "flow",
                                                        "to": "payload",
                                                        "tot": "msg"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 670,
                                                "y": 40,
                                                "wires": [
                                                        "5e8ce599dad4fa74"
                                                "type": "change",
                                                "rules": [
                                                        "t": "set",
                                                        "p": "array-bezug",
                                                        "pt": "msg",
                                                        "tot": "flow"
                                                        "t": "set",
                                                        "p": "array-bezug",
                                                        "pt": "msg",
                                                        "tot": "jsonata"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 450,
                                                "y": 40,
                                                "wires": [
                                                        "ff519a511afeb6f1"
                                                "type": "change",
                                                "name": "Bezug",
                                                "rules": [
                                                        "t": "set",
                                                        "p": "topic",
                                                        "pt": "msg",
                                                        "to": "Strombezug",
                                                        "tot": "str"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 270,
                                                "y": 40,
                                                "wires": [
                                                        "c617a78f8ddaca22"
                                                "onlyack": "",
                                                "func": "all",
                                                "gap": "",
                                                "x": 110,
                                                "y": 40,
                                                "wires": [
                                                        "53d6131492b2abed"
                                        Martin
                                        • M MartyBr
                                          @mickym
                                                  "type": "subflow",
                                                  "info": "",
                                                  "category": "",
                                                  "in": [
                                                          "x": 60,
                                                          "y": 80,
                                                          "wires": [
                                                  "out": [
                                                          "x": 820,
                                                          "y": 80,
                                                          "wires": [
        "port": 0
                                                  "env": [
                                                          "name": "basePath",
                                                          "type": "str",
                                                  "meta": {},
                                                  "color": "#DDAA99"
                                                  "type": "change",
                                                  "name": "",
                                                  "rules": [
                                                          "t": "set",
                                                          "p": "datum",
                                                          "pt": "msg",
                                                          "tot": "jsonata"
                                                  "action": "",
                                                  "property": "",
                                                  "from": "",
                                                  "to": "",
                                                  "reg": false,
                                                  "x": 230,
                                                  "y": 80,
                                                  "wires": [
                                                          "0e8de9437c3c420a"
                                                  "type": "change",
                                                  "rules": [
                                                          "t": "change",
                                                          "p": "datum",
                                                          "pt": "msg",
                                                          "from": "März",
                                                          "fromt": "str",
                                                          "to": "Maerz",
                                                          "tot": "str"
                                                  "action": "",
                                                  "property": "",
                                                  "from": "",
                                                  "to": "",
                                                  "reg": false,
                                                  "x": 440,
                                                  "y": 80,
                                                  "wires": [
                                                          "fc37f5f9d2b0297b"
                                                  "type": "change",
                                                  "name": "",
                                                  "rules": [
                                                          "t": "set",
                                                          "p": "topic",
                                                          "pt": "msg",
                                                          "tot": "jsonata"
                                                  "action": "",
                                                  "property": "",
                                                  "from": "",
                                                  "to": "",
                                                  "reg": false,
                                                  "x": 660,
                                                  "y": 80,
                                                  "wires": [
                                                  "type": "debug",
                                                  "active": true,
                                                  "tosidebar": true,
                                                  "console": false,
                                                  "tostatus": false,
                                                  "statusVal": "",
                                                  "x": 1050,
                                                  "y": 180,
                                                  "wires": []
                                                  "name": "",
                                                  "topic": "",
                                                  "ack": "true",
                                                  "stateName": "",
                                                  "role": "",
                                                  "payloadType": "",
                                                  "stateUnit": "",
                                                  "stateMin": "",
                                                  "stateMax": "",
                                                  "x": 1060,
                                                  "y": 120,
                                                  "wires": []
                                                  "name": "",
                                                  "env": [
                                                          "name": "basePath",
                                                          "type": "str"
                                                  "x": 860,
                                                  "y": 40,
                                                  "wires": [
                                                          "e700e5e9b292c820",
                                                          "1d93ae2f970605e5"
                                                  "type": "change",
                                                  "name": "",
                                                  "rules": [
                                                          "t": "set",
                                                          "p": "payload",
                                                          "pt": "msg",
                                                          "tot": "jsonata"
                                                          "t": "set",
                                                          "p": "array-bezug",
                                                          "pt": "flow",
                                                          "to": "payload",
                                                          "tot": "msg"
                                                  "action": "",
                                                  "property": "",
                                                  "from": "",
                                                  "to": "",
                                                  "reg": false,
                                                  "x": 670,
                                                  "y": 40,
                                                  "wires": [
                                                          "5e8ce599dad4fa74"
                                                  "type": "change",
                                                  "rules": [
                                                          "t": "set",
                                                          "p": "array-bezug",
                                                          "pt": "msg",
                                                          "tot": "flow"
                                                          "t": "set",
                                                          "p": "array-bezug",
                                                          "pt": "msg",
                                                          "tot": "jsonata"
                                                  "action": "",
                                                  "property": "",
                                                  "from": "",
                                                  "to": "",
                                                  "reg": false,
                                                  "x": 450,
                                                  "y": 40,
                                                  "wires": [
                                                          "ff519a511afeb6f1"
                                                  "type": "change",
                                                  "name": "Bezug",
                                                  "rules": [
                                                          "t": "set",
                                                          "p": "topic",
                                                          "pt": "msg",
                                                          "to": "Strombezug",
                                                          "tot": "str"
                                                  "action": "",
                                                  "property": "",
                                                  "from": "",
                                                  "to": "",
                                                  "reg": false,
                                                  "x": 270,
                                                  "y": 40,
                                                  "wires": [
                                                          "c617a78f8ddaca22"
                                                  "onlyack": "",
                                                  "func": "all",
                                                  "gap": "",
                                                  "x": 110,
                                                  "y": 40,
                                                  "wires": [
                                                          "53d6131492b2abed"
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          @martybr Also - ich habe nun gerade Deinen Flow importiert. Wäre übrigens auch gut, wenn Du mir eine Inject Node zur Simulation dran machen würdest, da ich ja in der Regel nicht deine Datenpunkte habe.
                                          Dann machst Du einen gravierenden Fehler, wenn Du in JSONATA meinst, du kannst "array-bezug" schreiben. Dann versucht JSONATA von einer Nachrichteneigenschaft "array" den Betrag der Nachrichteneigenschaft "bezug" zu subtrahieren, was natürlich beides nicht definiert bzw. exisitiert.
                                          Ich habe also in Deinem ganzen Flow - "array-bezug" durch "array_bezug" ersetzt.
                                          Dann haben wir doch besprochen, dass der iobroker KEINE Objekte bearbeiten kann. Also müssen wir bevor wir einen Datenpunkt beschreiben, diesen erst in einen String umwandeln.
                                          Also lösche Deinen Datenpunkt nochmals und setze eine JSON Node vor die iobroker-Out Node, so wie besprochen.
                                          Und zuletzt - speicherst Du zwar direkt in die Flow variable - aber Du wolltest doch persistent machen und Du liest ja nirgend Dein Array aus dem iobroker wieder ein?
                                          Also hören wir doch mal auf, das Ergebnis - also das neue Array direkt abzuspeichern:
                                          So nun muss man also wieder was aus dem Datenpunkt einlesen, den man in iobroker geschrieben hat. das ist aber kompliziert, da der Datenpunkt ja dynamisch sich dauernd ändert. Ich überlege mir mal was.
                                          Inzwischen kannst Du Dir ja den modifizierten Flow - als Basis schon mal abspeichern - dann auf der Basis machen wir weiter.
                                                 "type": "subflow",
                                                 "info": "",
                                                 "category": "",
                                                 "in": [
                                                         "x": 60,
                                                         "y": 80,
                                                         "wires": [
                                                 "out": [
                                                         "x": 820,
                                                         "y": 80,
                                                         "wires": [
        "port": 0
                                                 "env": [
                                                         "name": "basePath",
                                                         "type": "str",
                                                 "meta": {},
                                                 "color": "#DDAA99"
                                                 "type": "change",
                                                 "name": "",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "datum",
                                                         "pt": "msg",
                                                         "tot": "jsonata"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 230,
                                                 "y": 80,
                                                 "wires": [
                                                         "0e8de9437c3c420a"
                                                 "type": "change",
                                                 "rules": [
                                                         "t": "change",
                                                         "p": "datum",
                                                         "pt": "msg",
                                                         "from": "März",
                                                         "fromt": "str",
                                                         "to": "Maerz",
                                                         "tot": "str"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 440,
                                                 "y": 80,
                                                 "wires": [
                                                         "fc37f5f9d2b0297b"
                                                 "type": "change",
                                                 "name": "",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "topic",
                                                         "pt": "msg",
                                                         "tot": "jsonata"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 660,
                                                 "y": 80,
                                                 "wires": [
                                                 "id": "5073270521431406",
                                                 "type": "debug",
                                                 "z": "5dbdd0fd840b4eee",
                                                 "active": true,
                                                 "tosidebar": true,
                                                 "console": false,
                                                 "tostatus": false,
                                                 "statusVal": "",
                                                 "x": 1170,
                                                 "y": 300,
                                                 "wires": []
                                                 "id": "10bd7990f72c7776",
                                                 "name": "",
                                                 "topic": "",
                                                 "ack": "true",
                                                 "stateName": "",
                                                 "role": "",
                                                 "payloadType": "",
                                                 "stateUnit": "",
                                                 "stateMin": "",
                                                 "stateMax": "",
                                                 "x": 1340,
                                                 "y": 220,
                                                 "wires": []
                                                 "id": "147888cb9d8dbd57",
                                                 "name": "",
                                                 "env": [
                                                         "name": "basePath",
                                                         "type": "str"
                                                 "x": 1000,
                                                 "y": 160,
                                                 "wires": [
                                                         "5073270521431406",
                                                         "c097566fbf70cacc"
                                                 "id": "9226f70990baa228",
                                                 "type": "change",
                                                 "name": "",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "to": "$append(array_bezug, payload)",
                                                         "tot": "jsonata"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 790,
                                                 "y": 160,
                                                 "wires": [
                                                         "147888cb9d8dbd57"
                                                 "id": "102ed68150c3074f",
                                                 "type": "change",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "array_bezug",
                                                         "pt": "msg",
                                                         "to": "array_bezug",
                                                         "tot": "flow"
                                                         "t": "set",
                                                         "p": "array_bezug",
                                                         "pt": "msg",
                                                         "to": "array_bezug ? array_bezug : []",
                                                         "tot": "jsonata"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 570,
                                                 "y": 160,
                                                 "wires": [
                                                         "9226f70990baa228"
                                                 "id": "fbcf46d8f94203aa",
                                                 "type": "change",
                                                 "name": "Bezug",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "topic",
                                                         "pt": "msg",
                                                         "to": "Strombezug",
                                                         "tot": "str"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 350,
                                                 "y": 120,
                                                 "wires": [
                                                         "102ed68150c3074f"
                                                 "id": "a435b3ce1f53ba74",
                                                 "d": true,
                                                 "onlyack": "",
                                                 "func": "all",
                                                 "gap": "",
                                                 "x": 110,
                                                 "y": 160,
                                                 "wires": [
                                                         "fbcf46d8f94203aa"
                                                 "id": "779ae42084de3e0c",
                                                 "type": "inject",
                                                 "name": "",
                                                 "props": [
                                                         "p": "payload"
                                                         "p": "topic",
                                                         "vt": "str"
                                                 "repeat": "",
                                                 "crontab": "",
                                                 "once": false,
                                                 "onceDelay": 0.1,
                                                 "topic": "Bezug täglich",
                                                 "payload": "20.1",
                                                 "x": 110,
                                                 "y": 120,
                                                 "wires": [
                                                         "fbcf46d8f94203aa"
                                                 "id": "c097566fbf70cacc",
                                                 "type": "json",
                                                 "name": "",
                                                 "action": "",
                                                 "pretty": false,
                                                 "x": 1170,
                                                 "y": 220,
                                                 "wires": [
                                                         "10bd7990f72c7776"
                                          Ich denke, ich muss den ganzen Flow etwas umstellen, damit es auch einigermaßen effizient wird. Also vergiß Deinen/Meinen bisherigen Flow.
