  4. Zigbee Aktor nicht alle Kanäle steuerbar
    1.0k
    6.1k
25 Beiträge 3 Kommentatoren 3.2k Aufrufe 2 Beobachtet
  • AsgothianA Asgothian
    @mcbeath bitte aus
    export default definitions;
    dieses machen:
    //export default definitions;
    A.
    McBeath
    @asgothian
    Jetzt kann er scheinbar was nicht finden..
    zigbee.0
    	2025-02-02 17:15:37.213	info	Currently 6 devices are joined:
    zigbee.0
    	2025-02-02 17:15:37.198	info	--> transmitPower : normal
    zigbee.0
    	2025-02-02 17:15:37.198	info	Unable to disable LED, unsupported function.
    zigbee.0
    	2025-02-02 17:15:37.197	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20240710}}
    zigbee.0
    	2025-02-02 17:15:35.723	info	Installed Version: iobroker.zigbee@1.10.14
    zigbee.0
    	2025-02-02 17:15:35.498	info	Starting Zigbee npm ...
    zigbee.0
    	2025-02-02 17:15:35.497	info	delete old Backup files. keep only last 10
    zigbee.0
    	2025-02-02 17:15:35.437	error	Unable to apply converter from module: /opt/iobroker/iobroker-data/zigbee_0/TZ3210_c7nc9w3c.js - the code does not run: Error: Cannot find module '../lib/modernExtend'Require stack:- /opt/iobroker/node_modules/iobroker.zigbee/main.js
    zigbee.0
    	2025-02-02 17:15:35.434	info	Apply converter from module: /opt/iobroker/iobroker-data/zigbee_0/TZ3210_c7nc9w3c.js
    zigbee.0
    	2025-02-02 17:15:35.402	info	starting. Version 1.10.14 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.18.2, js-controller: 7.0.6
    zigbee.0
    	2025-02-02 17:15:28.639	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zigbee.0
    	2025-02-02 17:15:28.638	info	terminating
    zigbee.0
    	2025-02-02 17:15:28.139	info	Zigbee: disabling joining new devices.
    zigbee.0
    	2025-02-02 17:15:28.138	info	cleaned everything up...
    zigbee.0
    	2025-02-02 17:15:28.135	info	Got terminate signal TERMINATE_YOURSELF
    • M McBeath
      @asgothian
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @mcbeath versuch mal das require davon auszukommentieren. Ich glaube das braucht der nicht. (// an den Anfang der Zeile)
      A.
        A.
        McBeath
        @asgothian
        const fz = require('../converters/fromZigbee');
        const tz = require('../converters/toZigbee');
        const exposes = require('../lib/exposes');
        //const {deviceEndpoints, onOff} = require('../lib/modernExtend');
        const reporting = require('../lib/reporting');
        const tuya = require('../lib/tuya');
        const {DefinitionWithExtend} = require('../lib/types');
        Ergebnis:
        zigbee.0
        	2025-02-02 18:45:07.995	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20240710}}
        zigbee.0
        	2025-02-02 18:45:06.521	info	Installed Version: iobroker.zigbee@1.10.14
        zigbee.0
        	2025-02-02 18:45:06.239	info	Starting Zigbee npm ...
        zigbee.0
        	2025-02-02 18:45:06.237	info	delete old Backup files. keep only last 10
        zigbee.0
        	2025-02-02 18:45:06.174	error	Unable to apply converter from module: /opt/iobroker/iobroker-data/zigbee_0/TZ3210_c7nc9w3c.js - the code does not run: Error: Cannot find module '../lib/types'Require stack:- /opt/iobroker/node_modules/iobroker.zigbee/main.js
        zigbee.0
        	2025-02-02 18:45:06.170	info	Apply converter from module: /opt/iobroker/iobroker-data/zigbee_0/TZ3210_c7nc9w3c.js
        • M McBeath
          @asgothian
          Ergebnis:
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          AsgothianA Offline
          AsgothianA Offline
          Asgothian
          @mcbeath auch auskommentieren. (das hättest du auch selber schon probieren können.. die Fehlermeldung ist die gleiche - da hat er was nicht gefunden)
            McBeath
            schrieb am zuletzt editiert von McBeath
            @asgothian
            In anbetracht, das ich 0,0 Ahnung habe, was ich hier mache, dachte ich es wäre besser nur nach Anleitung zu arbeiten. 😧
            ebensalls entfernt:
            //const {DefinitionWithExtend} = require('../lib/types');
            Jetzt läuft es! 😊
            das Objekt "state" habe ich manuell gelöscht, war vorher I1 und gab fehler raus.
            I2 und I3 funktionieren jetzt auch. Muss nur noch die Energiemessung checken, dann ist alles TOP! 👍 👏
            zigbee.0
            	2025-02-02 19:16:19.520	error	No state available for 'WP30-EU' with key 'state'
            zigbee.0
            	2025-02-02 19:15:42.201	info	debug devices set to []
            zigbee.0
            	2025-02-02 19:15:42.109	warn	download icon from https://www.zigbee2mqtt.io/images/devices/WP30-EU.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/WP30-EU.png
            zigbee.0
            	2025-02-02 19:15:42.096	info	Zigbee started
            zigbee.0
            	2025-02-02 19:15:42.096	info	0xa4c138afd9b5dc56 (addr 44048): WP30-EU - LELLKI Power cord 4 sockets EU (with power monitoring) (Router)
            zigbee.0
            	2025-02-02 19:15:42.094	info	0xa4c138ec5f5abc82 (addr 29562): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
            zigbee.0
            	2025-02-02 19:15:42.093	info	0xa4c1383751fb0da3 (addr 5952): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
            zigbee.0
            	2025-02-02 19:15:42.091	info	0xa4c138309c89ab50 (addr 28969): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
            zigbee.0
            	2025-02-02 19:15:42.090	info	0xa4c138c700eed6ce (addr 51531): TS0201 - Tuya Temperature & humidity sensor with display (EndDevice)
            zigbee.0
            	2025-02-02 19:15:42.088	info	0x282c02bfffeee4ec (addr 26254): 3RVS01031Z - Third Reality Zigbee vibration sensor (EndDevice)
            zigbee.0
            	2025-02-02 19:15:42.063	info	Currently 6 devices are joined:
            zigbee.0
            	2025-02-02 19:15:42.051	info	--> transmitPower : normal
            zigbee.0
            	2025-02-02 19:15:42.051	info	Unable to disable LED, unsupported function.
            zigbee.0
            	2025-02-02 19:15:42.050	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20240710}}
            zigbee.0
            	2025-02-02 19:15:40.553	info	Installed Version: iobroker.zigbee@1.10.14
            zigbee.0
            	2025-02-02 19:15:40.294	info	Starting Zigbee npm ...
            zigbee.0
            	2025-02-02 19:15:40.293	info	delete old Backup files. keep only last 10
            zigbee.0
            	2025-02-02 19:15:40.235	info	Apply converter from module: /opt/iobroker/iobroker-data/zigbee_0/TZ3210_c7nc9w3c.js
            Energiemessung funktioniert auch noch von hier aus alles tip top.
            • M McBeath
              @asgothian
              ebensalls entfernt:
              Jetzt läuft es! 😊
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              @mcbeath sagte in Zigbee Aktor nicht alle Kanäle steuerbar:
              Jetzt läuft es!
              für die Zukunft - keine Objekte im Zigbee Objektbaum manuell löschen - dazu gibt es im Adapter einen Button "state cleanup". Der löscht alles was durch Anpassung von Device-Definitionen so nicht mehr unterstützt wird.
              A.
                Jetzt läuft es!
                A.
                McBeath
                @asgothian
                Okay, war bisher auch das erste mal. 😲
                Wo versteckt sich den der clean up button?
                Bin scheinbar zu blöd ihn zu finden, hab gerade schon mehrfach alles durchsucht... ich bin blind 😵
                • M McBeath
                  @asgothian
                  AsgothianA Offline
                  AsgothianA Offline
                  Asgothian
                  HomoranH M 2 Antworten Letzte Antwort
                    @asgothian sagte in Zigbee Aktor nicht alle Kanäle steuerbar:
                    nur als Anregung:
                    kann man da ein anderes Icon nehmen?
                    Auf den Kacheln bedeutet das reconfigure.
                    Ich hätte hier erwartet: reconfigure all
                      McBeath
                      @asgothian
                      Okay, hatte ich jetzt auch nicht erkannt.
                        nur als Anregung:
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        @homoran sagte in Zigbee Aktor nicht alle Kanäle steuerbar:
                        nur als Anregung:
                        Ich bin für vorschläge offen. Beliebiges Material icon würde gehen. :) (Icons)
                          nur als Anregung:
                          @asgothian Danke!
                          auf die Schnelle hab ich jetzt nichts wirklich passendes und erkennbares gefunden
                            @asgothian Danke!
                            AsgothianA Offline
                            AsgothianA Offline
                            Asgothian
                            @homoran Es scheint ich hab gepatzt beim bereitstellen des Links. Ich hab nur zugriff auf die Icons hier:
                            https://materializecss.com/icons.html
                            Da gibt es die Cleaning-services nicht :/
                            A.
                            Nachtrag: was hältst du von dem hier :
                            Im Adapter Kontext: Screenshot 2025-02-03 at 11.30.23.png
                              A.
                              shit happens!
                              da finde ich auf Anhieb auch nix.
                              Sweep macht der
                              EDIT:
                              Dein edit gefällt mir.
                              Das Icon muss passen, nicht dessen Bezeichnung!
                                shit happens!
                                Sweep macht der
                                EDIT:
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                @homoran Ok.. kommt geändert in die 1.10.15 und 2.0 :)
                                A.
