  4. Zigbee Aktor nicht alle Kanäle steuerbar
    1.0k
    6.1k
25 Beiträge 3 Kommentatoren 3.2k Aufrufe 2 Beobachtet
  • M McBeath
    @asgothian
    Ich denke ich habe deine Anleitung korrekt umgesetzt.
    const fz = require('../converters/fromZigbee');
    const tz = require('../converters/toZigbee');
    const exposes = require('../lib/exposes');
    const {deviceEndpoints, onOff} = require('../lib/modernExtend');
    const reporting = require('../lib/reporting');
    const tuya = require('../lib/tuya');
    const {DefinitionWithExtend} = require('../lib/types');
    Ergebnis folgt... 👍
    Edit:
    Neue Fehlermeldung:
    zigbee.0
    	2025-02-02 13:15:01.411	info	0xa4c138ec5f5abc82 (addr 29562): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
    zigbee.0
    	2025-02-02 13:15:01.410	info	0xa4c1383751fb0da3 (addr 5952): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
    zigbee.0
    	2025-02-02 13:15:01.408	info	0xa4c138309c89ab50 (addr 28969): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
    zigbee.0
    	2025-02-02 13:15:01.407	info	0xa4c138c700eed6ce (addr 51531): TS0201 - Tuya Temperature & humidity sensor with display (EndDevice)
    zigbee.0
    	2025-02-02 13:15:01.404	info	0x282c02bfffeee4ec (addr 26254): 3RVS01031Z - Third Reality Zigbee vibration sensor (EndDevice)
    zigbee.0
    	2025-02-02 13:15:01.379	info	Currently 6 devices are joined:
    zigbee.0
    	2025-02-02 13:15:01.367	info	--> transmitPower : normal
    zigbee.0
    	2025-02-02 13:15:01.366	info	Unable to disable LED, unsupported function.
    zigbee.0
    	2025-02-02 13:15:01.366	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20240710}}
    zigbee.0
    	2025-02-02 13:14:59.863	info	Installed Version: iobroker.zigbee@1.10.14
    zigbee.0
    	2025-02-02 13:14:59.638	info	Starting Zigbee npm ...
    zigbee.0
    	2025-02-02 13:14:59.636	info	delete old Backup files. keep only last 10
    zigbee.0
    	2025-02-02 13:14:59.576	error	Unable to apply converter from module: /opt/iobroker/iobroker-data/zigbee_0/TZ3210_c7nc9w3c.js - the code does not run: SyntaxError: Unexpected token 'export'
    zigbee.0
    	2025-02-02 13:14:59.572	info	Apply converter from module: /opt/iobroker/iobroker-data/zigbee_0/TZ3210_c7nc9w3c.js
    zigbee.0
    	2025-02-02 13:14:59.539	info	starting. Version 1.10.14 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.18.2, js-controller: 7.0.6
    zigbee.0
    	2025-02-02 13:14:52.803	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zigbee.0
    	2025-02-02 13:14:52.801	info	terminating
    zigbee.0
    	2025-02-02 13:14:52.302	info	Zigbee: disabling joining new devices.
    zigbee.0
    	2025-02-02 13:14:52.300	info	cleaned everything up...
    zigbee.0
    	2025-02-02 13:14:52.299	info	Got terminate signal TERMINATE_YOURSELF
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    @mcbeath bitte aus
    export default definitions;
    dieses machen:
    //export default definitions;
    A.
    • AsgothianA Asgothian
      @mcbeath bitte aus
      dieses machen:
      A.
      McBeath
      @asgothian
      Jetzt kann er scheinbar was nicht finden..
      zigbee.0
      	2025-02-02 17:15:37.213	info	Currently 6 devices are joined:
      zigbee.0
      	2025-02-02 17:15:37.198	info	--> transmitPower : normal
      zigbee.0
      	2025-02-02 17:15:37.198	info	Unable to disable LED, unsupported function.
      zigbee.0
      	2025-02-02 17:15:37.197	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20240710}}
      zigbee.0
      	2025-02-02 17:15:35.723	info	Installed Version: iobroker.zigbee@1.10.14
      zigbee.0
      	2025-02-02 17:15:35.498	info	Starting Zigbee npm ...
      zigbee.0
      	2025-02-02 17:15:35.497	info	delete old Backup files. keep only last 10
      zigbee.0
      	2025-02-02 17:15:35.437	error	Unable to apply converter from module: /opt/iobroker/iobroker-data/zigbee_0/TZ3210_c7nc9w3c.js - the code does not run: Error: Cannot find module '../lib/modernExtend'Require stack:- /opt/iobroker/node_modules/iobroker.zigbee/main.js
      zigbee.0
      	2025-02-02 17:15:35.434	info	Apply converter from module: /opt/iobroker/iobroker-data/zigbee_0/TZ3210_c7nc9w3c.js
      zigbee.0
      	2025-02-02 17:15:35.402	info	starting. Version 1.10.14 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.18.2, js-controller: 7.0.6
      zigbee.0
      	2025-02-02 17:15:28.639	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      zigbee.0
      	2025-02-02 17:15:28.638	info	terminating
      zigbee.0
      	2025-02-02 17:15:28.139	info	Zigbee: disabling joining new devices.
      zigbee.0
      	2025-02-02 17:15:28.138	info	cleaned everything up...
      zigbee.0
      	2025-02-02 17:15:28.135	info	Got terminate signal TERMINATE_YOURSELF
      • M McBeath
        @asgothian
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @mcbeath versuch mal das require davon auszukommentieren. Ich glaube das braucht der nicht. (// an den Anfang der Zeile)
        A.
          A.
          McBeath
          @asgothian
          //const {deviceEndpoints, onOff} = require('../lib/modernExtend');
          Ergebnis:
          zigbee.0
          	2025-02-02 18:45:07.995	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20240710}}
          zigbee.0
          	2025-02-02 18:45:06.521	info	Installed Version: iobroker.zigbee@1.10.14
          zigbee.0
          	2025-02-02 18:45:06.239	info	Starting Zigbee npm ...
          zigbee.0
          	2025-02-02 18:45:06.237	info	delete old Backup files. keep only last 10
          zigbee.0
          	2025-02-02 18:45:06.174	error	Unable to apply converter from module: /opt/iobroker/iobroker-data/zigbee_0/TZ3210_c7nc9w3c.js - the code does not run: Error: Cannot find module '../lib/types'Require stack:- /opt/iobroker/node_modules/iobroker.zigbee/main.js
          zigbee.0
          	2025-02-02 18:45:06.170	info	Apply converter from module: /opt/iobroker/iobroker-data/zigbee_0/TZ3210_c7nc9w3c.js
          • M McBeath
            @asgothian
            Ergebnis:
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            @mcbeath auch auskommentieren. (das hättest du auch selber schon probieren können.. die Fehlermeldung ist die gleiche - da hat er was nicht gefunden)
              McBeath
              schrieb am zuletzt editiert von McBeath
              @asgothian
              In anbetracht, das ich 0,0 Ahnung habe, was ich hier mache, dachte ich es wäre besser nur nach Anleitung zu arbeiten. 😧
              ebensalls entfernt:
              //const {DefinitionWithExtend} = require('../lib/types');
              Jetzt läuft es! 😊
              das Objekt "state" habe ich manuell gelöscht, war vorher I1 und gab fehler raus.
              I2 und I3 funktionieren jetzt auch. Muss nur noch die Energiemessung checken, dann ist alles TOP! 👍 👏
              zigbee.0
              	2025-02-02 19:16:19.520	error	No state available for 'WP30-EU' with key 'state'
              zigbee.0
              	2025-02-02 19:15:42.201	info	debug devices set to []
              zigbee.0
              	2025-02-02 19:15:42.109	warn	download icon from https://www.zigbee2mqtt.io/images/devices/WP30-EU.png saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/WP30-EU.png
              zigbee.0
              	2025-02-02 19:15:42.096	info	Zigbee started
              zigbee.0
              	2025-02-02 19:15:42.096	info	0xa4c138afd9b5dc56 (addr 44048): WP30-EU - LELLKI Power cord 4 sockets EU (with power monitoring) (Router)
              zigbee.0
              	2025-02-02 19:15:42.094	info	0xa4c138ec5f5abc82 (addr 29562): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
              zigbee.0
              	2025-02-02 19:15:42.093	info	0xa4c1383751fb0da3 (addr 5952): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
              zigbee.0
              	2025-02-02 19:15:42.091	info	0xa4c138309c89ab50 (addr 28969): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
              zigbee.0
              	2025-02-02 19:15:42.090	info	0xa4c138c700eed6ce (addr 51531): TS0201 - Tuya Temperature & humidity sensor with display (EndDevice)
              zigbee.0
              	2025-02-02 19:15:42.088	info	0x282c02bfffeee4ec (addr 26254): 3RVS01031Z - Third Reality Zigbee vibration sensor (EndDevice)
              zigbee.0
              	2025-02-02 19:15:42.063	info	Currently 6 devices are joined:
              zigbee.0
              	2025-02-02 19:15:42.051	info	--> transmitPower : normal
              zigbee.0
              	2025-02-02 19:15:42.051	info	Unable to disable LED, unsupported function.
              zigbee.0
              	2025-02-02 19:15:42.050	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20240710}}
              zigbee.0
              	2025-02-02 19:15:40.553	info	Installed Version: iobroker.zigbee@1.10.14
              zigbee.0
              	2025-02-02 19:15:40.294	info	Starting Zigbee npm ...
              zigbee.0
              	2025-02-02 19:15:40.293	info	delete old Backup files. keep only last 10
              zigbee.0
              	2025-02-02 19:15:40.235	info	Apply converter from module: /opt/iobroker/iobroker-data/zigbee_0/TZ3210_c7nc9w3c.js
              Energiemessung funktioniert auch noch von hier aus alles tip top.
              • M McBeath
                @asgothian
                ebensalls entfernt:
                Jetzt läuft es! 😊
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                @mcbeath sagte in Zigbee Aktor nicht alle Kanäle steuerbar:
                Jetzt läuft es!
                für die Zukunft - keine Objekte im Zigbee Objektbaum manuell löschen - dazu gibt es im Adapter einen Button "state cleanup". Der löscht alles was durch Anpassung von Device-Definitionen so nicht mehr unterstützt wird.
                A.
                  Jetzt läuft es!
                  A.
                  McBeath
                  @asgothian
                  Okay, war bisher auch das erste mal. 😲
                  Wo versteckt sich den der clean up button?
                  Bin scheinbar zu blöd ihn zu finden, hab gerade schon mehrfach alles durchsucht... ich bin blind 😵
                  • M McBeath
                    @asgothian
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    HomoranH M 2 Antworten Letzte Antwort
                      @asgothian sagte in Zigbee Aktor nicht alle Kanäle steuerbar:
                      nur als Anregung:
                      kann man da ein anderes Icon nehmen?
                      Auf den Kacheln bedeutet das reconfigure.
                      Ich hätte hier erwartet: reconfigure all
                        McBeath
                        @asgothian
                        Okay, hatte ich jetzt auch nicht erkannt.
                          nur als Anregung:
                          AsgothianA Offline
                          AsgothianA Offline
                          Asgothian
                          @homoran sagte in Zigbee Aktor nicht alle Kanäle steuerbar:
                          nur als Anregung:
                          Ich bin für vorschläge offen. Beliebiges Material icon würde gehen. :) (Icons)
                            nur als Anregung:
                            @asgothian Danke!
                            auf die Schnelle hab ich jetzt nichts wirklich passendes und erkennbares gefunden
                              @asgothian Danke!
                              AsgothianA Offline
                              AsgothianA Offline
                              Asgothian
                              @homoran Es scheint ich hab gepatzt beim bereitstellen des Links. Ich hab nur zugriff auf die Icons hier:
                              https://materializecss.com/icons.html
                              Da gibt es die Cleaning-services nicht :/
                              A.
                              Nachtrag: was hältst du von dem hier :
                              Im Adapter Kontext: Screenshot 2025-02-03 at 11.30.23.png
                                A.
                                shit happens!
                                da finde ich auf Anhieb auch nix.
                                Sweep macht der
                                EDIT:
                                Dein edit gefällt mir.
                                Das Icon muss passen, nicht dessen Bezeichnung!
                                  shit happens!
                                  Sweep macht der
                                  EDIT:
                                  AsgothianA Offline
                                  AsgothianA Offline
                                  Asgothian
                                  @homoran Ok.. kommt geändert in die 1.10.15 und 2.0 :)
                                  A.
