  4. source does not exist for "read" function
    5.1k
52 Beiträge 4 Kommentatoren 4.9k Aufrufe 2 Beobachtet
    @mickym sagte in source does not exist for "read" function:
    Was ist den schlimm dieses Objekt zu posten,
    Nix.
    {"home_info":{"home_name":"Home","home_img":"","charging_power":"0.00","power_unit":"W"},"solar_list":[],"pps_info":{"pps_list":[],"total_charging_power":"0.00","power_unit":"W","total_battery_power":"0.00","updated_time":"","pps_status":0},"statistics":[{"type":"1","total":"289.00","unit":"kwh"},{"type":"2","total":"288.13","unit":"kg"},{"type":"3","total":"115.60","unit":"€"}],"topology_type":"1","solarbank_info":{"solarbank_list":[{"device_pn":"A17C0","device_sn":"AZB6Y60D40400300","device_name":"Solarbank E1600","device_img":"https://public-aiot-fra-prod.s3.dualstack.eu-central-1.amazonaws.com/anker-power/public/product/2024/05/10/iot-admin/FycLLqjHpYf0Bdab/20230719-144818.png","battery_power":"71","bind_site_status":"","charging_power":"61","power_unit":"W","charging_status":"1","status":"1","wireless_type":"1","main_version":"","photovoltaic_power":"61","output_power":"61","create_time":1721841629,"set_load_power":"","sub_package_num":0,"output_cutoff_data":10,"is_display":true,"bat_charge_power":"0"}],"total_charging_power":"0","power_unit":"W","charging_status":"0","total_battery_power":"0.71","updated_time":"2025-02-01 16:17:55","total_photovoltaic_power":"61","total_output_power":"61.00","display_set_power":false,"battery_discharge_power":"0","ac_power":"0","to_home_load":"0","is_display_data":true,"solar_power_1":"0","solar_power_2":"0","solar_power_3":"0","solar_power_4":"0","other_input_power":"0","micro_inverter_power":"61","micro_inverter_power_limit":"0","micro_inverter_low_power_limit":"0","grid_to_battery_power":"0","pei_heating_power":"0","backup_info":{"start_time":0,"end_time":0,"full_time":0}},"retain_load":"150W","scene_mode":0,"home_load_power":"0","updated_time":"01-01-0001 00:00:00","power_site_type":2,"site_id":"a26d801a-afc6-45c0-bb93-ab80ab3bcc29","powerpanel_list":[],"grid_info":null,"is_downgrade":false,"error_code":0,"smart_plug_info":null,"feature_switch":null,"other_loads_power":"0","priority_discharge_switch":0,"display_priority_discharge_tips":0,"priority_discharge_upgrade_devices":"","style_id":0,"is_show_priority_discharge":1}
    "total_battery_power":"0.71" dürfte die Ursache sein.
    mickymM Online
    mickymM Online
    mickym
    Um welchen Wert handelt es sich - ich hab das mal schön formatiert:
      "home_info": {
        "home_name": "Home",
        "home_img": "",
        "charging_power": "0.00",
        "power_unit": "W"
      "solar_list": [],
      "pps_info": {
        "pps_list": [],
        "total_charging_power": "0.00",
        "power_unit": "W",
        "total_battery_power": "0.00",
        "updated_time": "",
        "pps_status": 0
      "statistics": [
          "type": "1",
          "total": "289.00",
          "unit": "kwh"
          "type": "2",
          "total": "288.13",
          "unit": "kg"
          "type": "3",
          "total": "115.60",
          "unit": "€"
      "topology_type": "1",
      "solarbank_info": {
        "solarbank_list": [
            "device_pn": "A17C0",
            "device_sn": "AZV6Y60D30400300",
            "device_name": "Solarbank E1600",
            "device_img": "https://public-aiot-fra-prod.s3.dualstack.eu-central-1.amazonaws.com/anker-power/public/product/2024/05/10/iot-admin/FycLLqjHpYf0Bdab/20230719-144818.png",
            "battery_power": "71",
            "bind_site_status": "",
            "charging_power": "61",
            "power_unit": "W",
            "charging_status": "1",
            "status": "1",
            "wireless_type": "1",
            "main_version": "",
            "photovoltaic_power": "61",
            "output_power": "61",
            "create_time": 1721841629,
            "set_load_power": "",
            "sub_package_num": 0,
            "output_cutoff_data": 10,
            "is_display": true,
            "bat_charge_power": "0"
        "total_charging_power": "0",
        "power_unit": "W",
        "charging_status": "0",
        "total_battery_power": "0.71",
        "updated_time": "2025-02-01 16:17:55",
        "total_photovoltaic_power": "61",
        "total_output_power": "61.00",
        "display_set_power": false,
        "battery_discharge_power": "0",
        "ac_power": "0",
        "to_home_load": "0",
        "is_display_data": true,
        "solar_power_1": "0",
        "solar_power_2": "0",
        "solar_power_3": "0",
        "solar_power_4": "0",
        "other_input_power": "0",
        "micro_inverter_power": "61",
        "micro_inverter_power_limit": "0",
        "micro_inverter_low_power_limit": "0",
        "grid_to_battery_power": "0",
        "pei_heating_power": "0",
        "backup_info": {
          "start_time": 0,
          "end_time": 0,
          "full_time": 0
      "retain_load": "150W",
      "scene_mode": 0,
      "home_load_power": "0",
      "updated_time": "01-01-0001 00:00:00",
      "power_site_type": 2,
      "site_id": "a26d801a-afc6-45c0-bb93-cb80eb3bcc29",
      "powerpanel_list": [],
      "grid_info": null,
      "is_downgrade": false,
      "error_code": 0,
      "smart_plug_info": null,
      "feature_switch": null,
      "other_loads_power": "0",
      "priority_discharge_switch": 0,
      "display_priority_discharge_tips": 0,
      "priority_discharge_upgrade_devices": "",
      "style_id": 0,
      "is_show_priority_discharge": 1
    Es scheint mir das zu sein - und da sind alle Werte Strings
    einen Augenblick bitte.
    • mickymM Online
      mickymM Online
      mickym
      So dann probiere mal in der Konvertierungsfunktion für den Alias folgendes:
      Number(JSON.parse(val).solarbank_info.total_battery_power) *100
        Nix.
        @thomas-braun sagte: "total_battery_power":"0.71" dürfte die Ursache sein.
        Das ist nicht die Ursache, denn es findet bei Multiplikation eine implizite Wandlung statt:
          mickymM Online
          mickymM Online
          mickym
          @paul53 sagte in source does not exist for "read" function:
          Das mag zwar richtig sein, aber der Typ wird ja über das Skript festgelegt - zumindest ist es die Ursache, dass immer wieder auf String umgeschaltet wird und das erzeugt ja die Fehlermeldung. Die Konvertierung spielt dabei ja noch keine Rolle.
          • mickymM mickym
            Das wird eher mehr als weniger...
            2025-02-01 16:36:56.126  - error: history.0 (857) source in "alias.0.0_userdata.0.solix.solarbank_info.total_battery_power" does not exist for "read" function: "Number(JSON.parse(val).solarbank_info.total_battery_power) *100 "
            2025-02-01 16:36:56.129  - error: javascript.0 (888) source in "alias.0.0_userdata.0.solix.solarbank_info.total_battery_power" does not exist for "read" function: "Number(JSON.parse(val).solarbank_info.total_battery_power) *100 "
            2025-02-01 16:36:56.126  - error: admin.0 (846) Invalid read function for "alias.0.0_userdata.0.solix.solarbank_info.total_battery_power": "Number(JSON.parse(val).solarbank_info.total_battery_power) *100 " => Cannot read properties of undefined (reading 'total_battery_power')
            2025-02-01 16:36:56.128  - error: awtrix-light.0 (1329) Invalid read function for "alias.0.0_userdata.0.solix.solarbank_info.total_battery_power": "Number(JSON.parse(val).solarbank_info.total_battery_power) *100 " => Cannot read properties of undefined (reading 'total_battery_power')
              mickymM Online
              mickymM Online
              mickym
              @thomas-braun so mit der internen Konvertierung klappt es
              JSON.parse(val).solarbank_info.total_battery_power *100
              gibt das in die Lesefunktion des Alias ein
              Ich hab Dein ganzes Objekt in einen Datenpunkt geschrieben und dann im Alias extrahiert:
              • mickymM mickym
                Wo finde ich die denn?
                mickymM HomoranH 2 Antworten Letzte Antwort
                  mickymM Online
                  mickymM Online
                  mickym
                  @thomas-braun sagte in source does not exist for "read" function:
                  Na unter Objekte alias.0 solltest Du doch Deinen Alias finden, deswegen brauchst auch den Adapter nicht.
                  und der hat einen weiteren Tab:
                  Du kannst auch versuchen - die ganze Funktion in Deinen Adapter einzutragen - aber ich bevorzuge halt direkt im Alias Datenpunkt. Du musst halt den Haken Konvertierungsfunktion benutzen anhaken.
                  • mickymM mickym
                    @mickym
                    Funktioniert nicht. Wenn ich das im Alias als Konvertierung eintrage komm (NULL) dabei heraus.
                      @mickym
                      mickymM Online
                      mickymM Online
                      mickym
                      Dann musst Du Schritt für Schritt vorgehen, hast Du denn auch den Alias auf Dein Objekt und nicht auf Deinen 0_userdata.0 datenpunkt zeigen lassen?
                      Mach halt mal einen Screenshot von dem Aliastab
                      • mickymM mickym
                        Ich weiß es nicht. Das geht mir auch gerade so auf die Nerven, das bleibt jetzt so. Ist es halt falsch im Diagramm.
                          mickymM Online
                          mickymM Online
                          mickym
                          da muss Quelle rein: mqtt.0.solix.site.Stromstausee.scenInfo
                          Also oben:
                          und unten in der Konvertierung:
                          • mickymM mickym
                            Also oben:
                            Danke, das funktioniert nun.
                            Macht das Konstrukt natürlich insgesamt noch unübersichtlicher. Muss das vielleicht mal komplett überarbeiten.
                              mickymM Online
                              mickymM Online
                              mickym
                              @thomas-braun Na ich mag die JSONS - ich würde halt nur mit Alias arbeiten und dann nur die Alias erstellen und Werte aus dem Objekt extrahieren, die Du auch brauchst. Ich weiß nicht, ob Du unbedingt 100 Datenpunkte als Einzelobjekte brauchst.
                              Auch wenn Du später Blocklies nutzt - kannst Du doch auch leicht über Attribute direkt auf Einzelwerte auf dem Objekt zugreifen.
                              Wenn Du später auf einen Wert zugreifen willst und Dir ist das zu unübersichtlich , dann nutze den JSON Formatter der gibt Dir den Pfad aus:
                              • mickymM mickym
                                Natürlich nicht. War nur damals für mich am einfachsten, erstmal alles reinzuziehen und dann zerlegen zu lassen
                                  ehrlich?
                                  @homoran sagte in source does not exist for "read" function:
                                  wie sehen denn die beiden angemeckerten alias-Konfigurationen aus?
                                  was lange währt wird endlich gut!?
                                    ehrlich?
                                    Mit Alias habe ich ehrlich gesagt nie viel gemacht.
                                    Fand es auch immer unübersichtlich mit den ganzen Ansätzen.
                                    devices-Adapter, alias-Adapter, direkt in den Objekten...
                                      stimmt!
                                      deswegen immer nativ!
                                      (die drei aliases die ich bisher hab)
