  4. source does not exist for "read" function
    5.1k
52 Beiträge 4 Kommentatoren 4.9k Aufrufe 2 Beobachtet
  • mickymM mickym
    @thomas-braun Was ist den schlimm dieses Objekt zu posten, also den Wert von
    mqtt.0.solix.site.Stromstausee.scenInfo
    Aber wenn Du keine Lust hast, dann halt nicht.
    @mickym sagte in source does not exist for "read" function:
    Nix.
    {"home_info":{"home_name":"Home","home_img":"","charging_power":"0.00","power_unit":"W"},"solar_list":[],"pps_info":{"pps_list":[],"total_charging_power":"0.00","power_unit":"W","total_battery_power":"0.00","updated_time":"","pps_status":0},"statistics":[{"type":"1","total":"289.00","unit":"kwh"},{"type":"2","total":"288.13","unit":"kg"},{"type":"3","total":"115.60","unit":"€"}],"topology_type":"1","solarbank_info":{"solarbank_list":[{"device_pn":"A17C0","device_sn":"AZB6Y60D40400300","device_name":"Solarbank E1600","device_img":"https://public-aiot-fra-prod.s3.dualstack.eu-central-1.amazonaws.com/anker-power/public/product/2024/05/10/iot-admin/FycLLqjHpYf0Bdab/20230719-144818.png","battery_power":"71","bind_site_status":"","charging_power":"61","power_unit":"W","charging_status":"1","status":"1","wireless_type":"1","main_version":"","photovoltaic_power":"61","output_power":"61","create_time":1721841629,"set_load_power":"","sub_package_num":0,"output_cutoff_data":10,"is_display":true,"bat_charge_power":"0"}],"total_charging_power":"0","power_unit":"W","charging_status":"0","total_battery_power":"0.71","updated_time":"2025-02-01 16:17:55","total_photovoltaic_power":"61","total_output_power":"61.00","display_set_power":false,"battery_discharge_power":"0","ac_power":"0","to_home_load":"0","is_display_data":true,"solar_power_1":"0","solar_power_2":"0","solar_power_3":"0","solar_power_4":"0","other_input_power":"0","micro_inverter_power":"61","micro_inverter_power_limit":"0","micro_inverter_low_power_limit":"0","grid_to_battery_power":"0","pei_heating_power":"0","backup_info":{"start_time":0,"end_time":0,"full_time":0}},"retain_load":"150W","scene_mode":0,"home_load_power":"0","updated_time":"01-01-0001 00:00:00","power_site_type":2,"site_id":"a26d801a-afc6-45c0-bb93-ab80ab3bcc29","powerpanel_list":[],"grid_info":null,"is_downgrade":false,"error_code":0,"smart_plug_info":null,"feature_switch":null,"other_loads_power":"0","priority_discharge_switch":0,"display_priority_discharge_tips":0,"priority_discharge_upgrade_devices":"","style_id":0,"is_show_priority_discharge":1}
    "total_battery_power":"0.71" dürfte die Ursache sein.
    mickymM paul53P 2 Antworten Letzte Antwort
      Nix.
      mickymM Online
      mickymM Online
      mickym
      Um welchen Wert handelt es sich - ich hab das mal schön formatiert:
        "home_info": {
          "home_name": "Home",
          "home_img": "",
          "charging_power": "0.00",
          "power_unit": "W"
        "solar_list": [],
        "pps_info": {
          "pps_list": [],
          "total_charging_power": "0.00",
          "power_unit": "W",
          "total_battery_power": "0.00",
          "updated_time": "",
          "pps_status": 0
        "statistics": [
            "type": "1",
            "total": "289.00",
            "unit": "kwh"
            "type": "2",
            "total": "288.13",
            "unit": "kg"
            "type": "3",
            "total": "115.60",
            "unit": "€"
        "topology_type": "1",
        "solarbank_info": {
          "solarbank_list": [
              "device_pn": "A17C0",
              "device_sn": "AZV6Y60D30400300",
              "device_name": "Solarbank E1600",
              "device_img": "https://public-aiot-fra-prod.s3.dualstack.eu-central-1.amazonaws.com/anker-power/public/product/2024/05/10/iot-admin/FycLLqjHpYf0Bdab/20230719-144818.png",
              "battery_power": "71",
              "bind_site_status": "",
              "charging_power": "61",
              "power_unit": "W",
              "charging_status": "1",
              "status": "1",
              "wireless_type": "1",
              "main_version": "",
              "photovoltaic_power": "61",
              "output_power": "61",
              "create_time": 1721841629,
              "set_load_power": "",
              "sub_package_num": 0,
              "output_cutoff_data": 10,
              "is_display": true,
              "bat_charge_power": "0"
          "total_charging_power": "0",
          "power_unit": "W",
          "charging_status": "0",
          "total_battery_power": "0.71",
          "updated_time": "2025-02-01 16:17:55",
          "total_photovoltaic_power": "61",
          "total_output_power": "61.00",
          "display_set_power": false,
          "battery_discharge_power": "0",
          "ac_power": "0",
          "to_home_load": "0",
          "is_display_data": true,
          "solar_power_1": "0",
          "solar_power_2": "0",
          "solar_power_3": "0",
          "solar_power_4": "0",
          "other_input_power": "0",
          "micro_inverter_power": "61",
          "micro_inverter_power_limit": "0",
          "micro_inverter_low_power_limit": "0",
          "grid_to_battery_power": "0",
          "pei_heating_power": "0",
          "backup_info": {
            "start_time": 0,
            "end_time": 0,
            "full_time": 0
        "retain_load": "150W",
        "scene_mode": 0,
        "home_load_power": "0",
        "updated_time": "01-01-0001 00:00:00",
        "power_site_type": 2,
        "site_id": "a26d801a-afc6-45c0-bb93-cb80eb3bcc29",
        "powerpanel_list": [],
        "grid_info": null,
        "is_downgrade": false,
        "error_code": 0,
        "smart_plug_info": null,
        "feature_switch": null,
        "other_loads_power": "0",
        "priority_discharge_switch": 0,
        "display_priority_discharge_tips": 0,
        "priority_discharge_upgrade_devices": "",
        "style_id": 0,
        "is_show_priority_discharge": 1
      Es scheint mir das zu sein - und da sind alle Werte Strings
      einen Augenblick bitte.
      • mickymM Online
        mickymM Online
        mickym
        So dann probiere mal in der Konvertierungsfunktion für den Alias folgendes:
        Number(JSON.parse(val).solarbank_info.total_battery_power) *100
          Nix.
          @thomas-braun sagte: "total_battery_power":"0.71" dürfte die Ursache sein.
          Das ist nicht die Ursache, denn es findet bei Multiplikation eine implizite Wandlung statt:
            mickymM Online
            mickymM Online
            mickym
            @paul53 sagte in source does not exist for "read" function:
            Das mag zwar richtig sein, aber der Typ wird ja über das Skript festgelegt - zumindest ist es die Ursache, dass immer wieder auf String umgeschaltet wird und das erzeugt ja die Fehlermeldung. Die Konvertierung spielt dabei ja noch keine Rolle.
            • mickymM mickym
              Das wird eher mehr als weniger...
              2025-02-01 16:36:56.126  - error: history.0 (857) source in "alias.0.0_userdata.0.solix.solarbank_info.total_battery_power" does not exist for "read" function: "Number(JSON.parse(val).solarbank_info.total_battery_power) *100 "
              2025-02-01 16:36:56.129  - error: javascript.0 (888) source in "alias.0.0_userdata.0.solix.solarbank_info.total_battery_power" does not exist for "read" function: "Number(JSON.parse(val).solarbank_info.total_battery_power) *100 "
              2025-02-01 16:36:56.126  - error: admin.0 (846) Invalid read function for "alias.0.0_userdata.0.solix.solarbank_info.total_battery_power": "Number(JSON.parse(val).solarbank_info.total_battery_power) *100 " => Cannot read properties of undefined (reading 'total_battery_power')
              2025-02-01 16:36:56.128  - error: awtrix-light.0 (1329) Invalid read function for "alias.0.0_userdata.0.solix.solarbank_info.total_battery_power": "Number(JSON.parse(val).solarbank_info.total_battery_power) *100 " => Cannot read properties of undefined (reading 'total_battery_power')
                mickymM Online
                mickymM Online
                mickym
                @thomas-braun so mit der internen Konvertierung klappt es
                JSON.parse(val).solarbank_info.total_battery_power *100
                gibt das in die Lesefunktion des Alias ein
                Ich hab Dein ganzes Objekt in einen Datenpunkt geschrieben und dann im Alias extrahiert:
                • mickymM mickym
                  Wo finde ich die denn?
                  mickymM HomoranH 2 Antworten Letzte Antwort
                    mickymM Online
                    mickymM Online
                    mickym
                    @thomas-braun sagte in source does not exist for "read" function:
                    Na unter Objekte alias.0 solltest Du doch Deinen Alias finden, deswegen brauchst auch den Adapter nicht.
                    und der hat einen weiteren Tab:
                    Du kannst auch versuchen - die ganze Funktion in Deinen Adapter einzutragen - aber ich bevorzuge halt direkt im Alias Datenpunkt. Du musst halt den Haken Konvertierungsfunktion benutzen anhaken.
                    • mickymM mickym
                      @mickym
                      Funktioniert nicht. Wenn ich das im Alias als Konvertierung eintrage komm (NULL) dabei heraus.
                        @mickym
                        mickymM Online
                        mickymM Online
                        mickym
                        Dann musst Du Schritt für Schritt vorgehen, hast Du denn auch den Alias auf Dein Objekt und nicht auf Deinen 0_userdata.0 datenpunkt zeigen lassen?
                        Mach halt mal einen Screenshot von dem Aliastab
                        • mickymM mickym
                          Ich weiß es nicht. Das geht mir auch gerade so auf die Nerven, das bleibt jetzt so. Ist es halt falsch im Diagramm.
                            mickymM Online
                            mickymM Online
                            mickym
                            da muss Quelle rein: mqtt.0.solix.site.Stromstausee.scenInfo
                            Also oben:
                            und unten in der Konvertierung:
                            • mickymM mickym
                              Also oben:
                              Danke, das funktioniert nun.
                              Macht das Konstrukt natürlich insgesamt noch unübersichtlicher. Muss das vielleicht mal komplett überarbeiten.
                                mickymM Online
                                mickymM Online
                                mickym
                                @thomas-braun Na ich mag die JSONS - ich würde halt nur mit Alias arbeiten und dann nur die Alias erstellen und Werte aus dem Objekt extrahieren, die Du auch brauchst. Ich weiß nicht, ob Du unbedingt 100 Datenpunkte als Einzelobjekte brauchst.
                                Auch wenn Du später Blocklies nutzt - kannst Du doch auch leicht über Attribute direkt auf Einzelwerte auf dem Objekt zugreifen.
                                Wenn Du später auf einen Wert zugreifen willst und Dir ist das zu unübersichtlich , dann nutze den JSON Formatter der gibt Dir den Pfad aus:
                                • mickymM mickym
                                  Natürlich nicht. War nur damals für mich am einfachsten, erstmal alles reinzuziehen und dann zerlegen zu lassen
                                    ehrlich?
                                    @homoran sagte in source does not exist for "read" function:
                                    wie sehen denn die beiden angemeckerten alias-Konfigurationen aus?
                                    was lange währt wird endlich gut!?
                                      ehrlich?
                                      Mit Alias habe ich ehrlich gesagt nie viel gemacht.
                                      Fand es auch immer unübersichtlich mit den ganzen Ansätzen.
                                      devices-Adapter, alias-Adapter, direkt in den Objekten...
                                        stimmt!
                                        deswegen immer nativ!
                                        (die drei aliases die ich bisher hab)
