  4. Node-Red
  5. Node Red Optimierung PV Überschuss für Anfänger
    6.4k
73 Beiträge 2 Kommentatoren 11.3k Aufrufe 2 Beobachtet
  • mickymM mickym
    @harry_vlbg Ja aber so kann man das nicht importieren.
    Du musst das ganze in CodeTags packen und dann kannst Du das ganze noch mit einem Spoiler klein machen.
    Also erst das Auge:
    code_text
    dann den Codecs in den Spoiler
    und dann immer halb des Auges die CodeTags
    und dann innerhalb der CodeTags den Code des Exports den "code_text" überschreiben
    Harry_vlbg
    @mickym
           "id": "0be53785c72fb931",
           "type": "tab",
           "label": "Flow 1",
           "disabled": false,
           "info": "",
           "env": []
           "id": "cf09bc5276f7be79",
           "type": "shelly-gen2",
           "z": "0be53785c72fb931",
           "hostname": "192.168.178.54",
           "description": "Boiler_Bad",
           "mode": "polling",
           "verbose": false,
           "server": "",
           "outputmode": "event",
           "uploadretryinterval": 5000,
           "pollinginterval": "6000",
           "pollstatus": false,
           "getstatusoncommand": true,
           "devicetype": "SNSW-001P16EU",
           "devicetypemustmatchexactly": true,
           "captureblutooth": false,
           "outputs": 1,
           "x": 950,
           "y": 240,
           "wires": [
                   "aa58cc0f316c4f70"
           "inputLabels": [
               "payload.switch0.id"
           "outputLabels": [
               "1"
           "id": "8fab423dfb34e072",
           "type": "switch",
           "name": "Ladezustand Batterie > 95%",
           "property": "payload",
           "propertyType": "msg",
           "rules": [
                   "t": "gte",
                   "v": "95",
                   "vt": "num"
           "checkall": "true",
           "repair": false,
           "outputs": 1,
           "x": 160,
           "y": 240,
           "wires": [
                   "93e2aa46a4a02ee0"
           "id": "0b247bc8d9ca735e",
           "type": "victron-input-battery",
           "service": "com.victronenergy.battery/512",
           "path": "/Capacity",
           "serviceObj": {
               "name": "Pytes battery"
           "pathObj": {
               "type": "float",
               "name": "Capacity (Ah)"
           "name": "",
           "onlyChanges": true,
           "roundValues": "no",
           "x": 140,
           "y": 60,
           "wires": [
                   "8fab423dfb34e072"
           "id": "b2a7ee2ce7767b6b",
           "type": "http request",
           "name": "Shelly Befehl Boiler ein",
           "method": "GET",
           "ret": "txt",
           "paytoqs": "ignore",
           "url": "http://192.168.178.54/relay/0?turn=on",
           "tls": "",
           "persist": false,
           "proxy": "",
           "insecureHTTPParser": false,
           "authType": "",
           "senderr": false,
           "headers": [],
           "x": 670,
           "y": 140,
           "wires": [
                   "cf09bc5276f7be79",
                   "bc55c22dbd242ea5"
           "id": "bc55c22dbd242ea5",
           "type": "delay",
           "name": "",
           "pauseType": "delay",
           "timeout": "45",
           "timeoutUnits": "minutes",
           "rate": "1",
           "nbRateUnits": "1",
           "rateUnits": "second",
           "randomFirst": "1",
           "randomLast": "5",
           "randomUnits": "seconds",
           "drop": false,
           "allowrate": false,
           "outputs": 1,
           "x": 490,
           "y": 240,
           "wires": [
                   "a8814585a8e2257f"
           "id": "a8814585a8e2257f",
           "name": "Boiler aus nach 45 Min",
           "method": "GET",
           "ret": "txt",
           "url": "http://192.168.178.54/relay/0?turn=off",
           "tls": "",
           "persist": false,
           "proxy": "",
           "authType": "",
           "senderr": false,
           "headers": [],
           "x": 720,
           "y": 240,
           "wires": [
                   "cf09bc5276f7be79"
           "id": "93e2aa46a4a02ee0",
           "type": "delay",
           "name": "1 Message pro 12 H",
           "pauseType": "rate",
           "timeout": "5",
           "timeoutUnits": "seconds",
           "rate": "1",
           "nbRateUnits": "12",
           "rateUnits": "hour",
           "randomFirst": "1",
           "randomLast": "5",
           "drop": false,
           "allowrate": false,
           "outputs": 1,
           "x": 380,
           "y": 140,
           "wires": [
                   "b2a7ee2ce7767b6b"
           "info": "1 Message pro 12 Stunden um dem Boiler nicht mehrmals im tag einzuschalten.\n"
           "id": "aa58cc0f316c4f70",
           "type": "change",
           "name": "Boiler geheizt",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "boiler geheizt",
                   "tot": "str"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 1200,
           "y": 240,
           "wires": [
    • mickymM mickym
      Also ändere Deinen Post nochmal . so dass der Export entsprechend importierbar ist.
      Und dann werden wir uns um die Shelly Nodes kümmern - denn es macht keinen Sinn, dass Du HTTP und die Shelly Nodes verwendest.
      Harry_vlbg
      @mickym hat das jetzt so geklappt?
      funktioniert aber hervorragend mit http
      Ist halte ein Gen2
      • H Harry_vlbg
        Ist halte ein Gen2
        mickymM Offline
        mickymM Offline
        mickym
        @harry_vlbg Ja der import hat soweit funktioniert.
        Das Victron Teil habe ich nicht, aber das kann ich mit Inject Nodes simulieren.
        H 1 Antwort Letzte Antwort
        • mickymM mickym
          Harry_vlbg
          @mickym bin ich schon froh das ich das soweit geschafft habe ;-)
          wäre einfacher auf meinem PC.
          also du machst jetzt diesen Change Note mit der Variable Boiler geheizt und startest um 1 Uhr morgens am nächsten Tag den Boiler wenn er die letzten 12 Stunden nicht geheizt hat?
          • H Harry_vlbg
            Ist halte ein Gen2
            mickymM Offline
            mickymM Offline
            mickym
            @harry_vlbg sagte in Node Red Optimierung PV Überschuss für Anfänger:
            Ist halte ein Gen2
            Ja aber es macht keinen Sinn. Schau mal die Shelly Nodes bringen Beispiele mit. Als erstes probiere mal die Beispiele.
            Also erstes gehst Du unter import
            und unter Beispiele siehst Du die Beispiele, die Shelly mitliefert.
            Dann importierst Du mal das Beispiel mit dem switch:
            Als Hostname gibst mal Deinen Boiler IP-Adresse ein und schaust mal - ob Du mit dem Flow den Boiler schalten und auslesen kannst.
            Mit diesen Inject Nodes kannst Du ein- und ausschalten bzw. den Status abrufen.
            Schau mal ob das klappt.
            Ansonsten, wenn Du lieber über Http schalten willst - dann kannst Dir die Shelly Nodes wieder deinstallieren - weil die sonst überflüssig sind. Da kann man dann später auch Http nehmen.
            Er schaltet den Boiler aber nur für 2 Sekunden. Schau einfach mal, ob Du die Config auslesen kannst.
            Wir werden das ohne function Nodes machen
            und dieses toggle ausschalten. Aber wie gesagt wir können auch einfach anfangen - aber dann lösche die Shelly Nodes aus Deinem Flow - die dürfen NICHT dazwischenfunken. Wenn Du rein über HTTP schalten willst, dann verwende die erst mal nicht in Deinem Flow.
            H 3 Antworten Letzte Antwort
            • mickymM mickym
              Ist halte ein Gen2
              Harry_vlbg
              @mickym
              also ich bekomme fehlermeldungen
              20.1.2025, 20:12:02node: 4ec3bc22e66b23bf
              msg : string[39]
              "Wrong node type. Please use shelly-gen2"
              kann aber auch den shelly plus nicht auswählen. allerdings hat er eingeschaltet
              • mickymM mickym
                Ist halte ein Gen2
                Harry_vlbg
                @mickym der richtige wäre shelly plus 1 PM also bleiben wir beim alten
                • H Harry_vlbg
                  @mickym
                  msg : string[39]
                  mickymM Offline
                  mickymM Offline
                  mickym
                  @harry_vlbg
                  Wie gesagt, dann stelle mal in der Node - auf Deinen Typ um:
                  Also wie gesagt, wir können ja erstmal bei Deinem Schalten bleiben - ABER dann mach den Shelly Node aus Deinem Flow.
                  • mickymM mickym
                    Ist halte ein Gen2
                    Harry_vlbg
                    @mickym ich verwende eh nur den normalen http request.
                    heißt nur bei mir shelly befehl das ich mich auskenne.
                    bin hier ganz neu und auch nicht vom fach
                    • H Harry_vlbg
                      mickymM Offline
                      mickymM Offline
                      mickym
                      @harry_vlbg Ja wir machen es nur mit den HTTP Request Nodes erst mal.
                      Deine Shelly Node würde ich dann löschen
                      In der 1. Change Node setzen wird die Flow Variable boiler auf true und dann nach dem Ausschalten auf false.
                             "method": "GET",
                             "ret": "txt",
                             "tls": "",
                             "persist": false,
                             "proxy": "",
                             "authType": "",
                             "senderr": false,
                             "headers": [],
                             "x": 630,
                             "y": 140,
                             "wires": [
                                     "bc55c22dbd242ea5",
                                     "e2954a89ed9e7e6e"
                             "type": "delay",
                             "name": "",
                             "timeout": "45",
                             "rate": "1",
                             "nbRateUnits": "1",
                             "randomFirst": "1",
                             "randomLast": "5",
                             "drop": false,
                             "allowrate": false,
                             "outputs": 1,
                             "x": 930,
                             "y": 140,
                             "wires": [
                                     "a8814585a8e2257f"
                             "method": "GET",
                             "ret": "txt",
                             "tls": "",
                             "persist": false,
                             "proxy": "",
                             "authType": "",
                             "senderr": false,
                             "headers": [],
                             "x": 1160,
                             "y": 140,
                             "wires": [
                             "id": "e2954a89ed9e7e6e",
                             "type": "change",
                             "name": "",
                             "rules": [
                                     "t": "set",
                                     "p": "boiler",
                                     "pt": "flow",
                                     "to": "true",
                                     "tot": "bool"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 860,
                             "y": 200,
                             "wires": [
                      Wenn Du dann in das Kontextmenu gehst, solltest Du unter Flow eine Variable boiler haben, der signalisiert dass der Boiler angeschaltet wurde.
                      • mickymM mickym
                               "method": "GET",
                               "ret": "txt",
                               "tls": "",
                               "persist": false,
                               "proxy": "",
                               "authType": "",
                               "senderr": false,
                               "headers": [],
                               "x": 630,
                               "y": 140,
                               "wires": [
                                       "bc55c22dbd242ea5",
                                       "e2954a89ed9e7e6e"
                               "type": "delay",
                               "name": "",
                               "timeout": "45",
                               "rate": "1",
                               "nbRateUnits": "1",
                               "randomFirst": "1",
                               "randomLast": "5",
                               "drop": false,
                               "allowrate": false,
                               "outputs": 1,
                               "x": 930,
                               "y": 140,
                               "wires": [
                                       "a8814585a8e2257f"
                               "method": "GET",
                               "ret": "txt",
                               "tls": "",
                               "persist": false,
                               "proxy": "",
                               "authType": "",
                               "senderr": false,
                               "headers": [],
                               "x": 1160,
                               "y": 140,
                               "wires": [
                               "type": "change",
                               "name": "",
                               "rules": [
                                       "t": "set",
                                       "p": "boiler",
                                       "pt": "flow",
                                       "to": "true",
                                       "tot": "bool"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 860,
                               "y": 200,
                               "wires": [
                        Harry_vlbg
                        @mickym soweit so gut - habe ich
                        • H Harry_vlbg
                          mickymM Offline
                          mickymM Offline
                          mickym
                          Ja diese 2. Change Node kannst wieder löschen, weil wir wollen ja nur einmal prüfen, ob der Boiler eingeschaltet wurde.
                          • H Harry_vlbg
                            mickymM Offline
                            mickymM Offline
                            mickym
                            So nun müssen wir also jede Nacht um 1:00 Uhr prüfen, ob der Boiler eingeschaltet wurde.
                            Wir nehmen einfach eine InjectNode:
                            H mickymM 2 Antworten Letzte Antwort
                            • mickymM mickym
                              Harry_vlbg
                              @mickym also boiler hat eingeschaltet - musste noch zuerst den Ladeszustand ändern aber geht.
                              Kontektmenü finde ich keines
                              • mickymM mickym
                                Harry_vlbg
                                @mickym gefunden - flow boiler true
                                • H Harry_vlbg
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  Das Kontextmenü
                                  gut :)
                                  • mickymM mickym
                                    mickymM Offline
                                    mickymM Offline
                                    mickym
                                    @mickym sagte in Node Red Optimierung PV Überschuss für Anfänger:
                                    Dann mach wie gesagt eine Inject Node wie abgebildet, die jede Nacht um 1:00 Uhr triggert, aber Du kannst zum Test auch manuell die Inject Node auslösen.
                                    In der Switch Node überprüfen, wir nun ob die Variable blow auf true steht oder false.
                                    damit wenn Du NodeRed neu startest, setzen wir die boiler Variable erst mal auf false, damit diese initialisiert ist.
                                           "id": "aaa0ed39edb3edd4",
                                           "type": "inject",
                                           "name": "Um 1:00 Uhr",
                                           "props": [
                                                   "p": "payload"
                                           "repeat": "",
                                           "crontab": "00 01 * * *",
                                           "once": false,
                                           "onceDelay": 0.1,
                                           "topic": "",
                                           "payload": "true",
                                           "payloadType": "bool",
                                           "x": 500,
                                           "y": 420,
                                           "wires": [
                                                   "9e4761a142f09e81"
                                           "id": "9e4761a142f09e81",
                                           "type": "switch",
                                           "name": "",
                                           "property": "boiler",
                                           "propertyType": "flow",
                                           "rules": [
                                                   "t": "true"
                                                   "t": "false"
                                           "checkall": "true",
                                           "repair": false,
                                           "outputs": 2,
                                           "x": 670,
                                           "y": 420,
                                           "wires": [
                                           "id": "1ab25cdf4774aba9",
                                           "type": "inject",
                                           "name": "",
                                           "props": [
                                                   "p": "payload"
                                                   "p": "topic",
                                                   "vt": "str"
                                           "repeat": "",
                                           "crontab": "",
                                           "once": true,
                                           "onceDelay": 0.1,
                                           "topic": "boiler",
                                           "payload": "false",
                                           "x": 450,
                                           "y": 340,
                                           "wires": [
                                                   "64867f8e8ebed7e4"
                                           "id": "64867f8e8ebed7e4",
                                           "type": "change",
                                           "name": "",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "boiler",
                                                   "pt": "flow",
                                                   "to": "payload",
                                                   "tot": "msg"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 640,
                                           "y": 340,
                                           "wires": [
                                    • mickymM mickym
                                             "type": "inject",
                                             "props": [
                                                     "p": "payload"
                                             "repeat": "",
                                             "once": false,
                                             "onceDelay": 0.1,
                                             "topic": "",
                                             "payload": "true",
                                             "x": 500,
                                             "y": 420,
                                             "wires": [
                                                     "9e4761a142f09e81"
                                             "type": "switch",
                                             "name": "",
                                             "rules": [
                                                     "t": "true"
                                                     "t": "false"
                                             "checkall": "true",
                                             "repair": false,
                                             "outputs": 2,
                                             "x": 670,
                                             "y": 420,
                                             "wires": [
                                             "type": "inject",
                                             "name": "",
                                             "props": [
                                                     "p": "payload"
                                                     "p": "topic",
                                                     "vt": "str"
                                             "repeat": "",
                                             "crontab": "",
                                             "once": true,
                                             "onceDelay": 0.1,
                                             "topic": "boiler",
                                             "payload": "false",
                                             "x": 450,
                                             "y": 340,
                                             "wires": [
                                                     "64867f8e8ebed7e4"
                                             "type": "change",
                                             "name": "",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "boiler",
                                                     "pt": "flow",
                                                     "to": "payload",
                                                     "tot": "msg"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 640,
                                             "y": 340,
                                             "wires": [
                                      Harry_vlbg
                                      @mickym kann ich das importieren und brauche ich hier auch wieder augen und so?
                                      • H Harry_vlbg
                                        mickymM Offline
                                        mickymM Offline
                                        mickym
                                        @harry_vlbg
                                        nein kannst du direkt importieren
                                        einfach den Spoiler aufmachen und dann den Flow mit der Schaltfläche Copy to clipboard in die Zwischenablage kopieren und dann in das rosa Importfenster
                                        • mickymM mickym
                                          @harry_vlbg
                                          Harry_vlbg
                                          @mickym ok - status ist jetzt false - somit wieder löschen?
