  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. ZigBee Adapter CZC Zigbee Coordinator
106 Beiträge 6 Kommentatoren 17.9k Aufrufe 5 Beobachtet
  • AsgothianA Asgothian
    @fabio sagte in ZigBee Adapter CZC Zigbee Coordinator:
    @asgothian @arteck seid ihr so nett das im Adapter zu ändern:
    zigbee.0
    2025-01-13 07:07:04.251	warn	State value to set for "zigbee.0.54ef44100025b53b.device_temperature" has value "-2" less than min "0"
    zigbee.0
    2025-01-13 07:06:28.119	warn	State value to set for "zigbee.0.54ef441000510446.device_temperature" has value "-4" less than min "0"
    zigbee.0
    2025-01-13 07:04:10.874	warn	State value to set for "zigbee.0.54ef441000510446.device_temperature" has value "-2" less than min "0"
    zigbee.0
    2025-01-13 07:01:29.039	warn	State value to set for "zigbee.0.54ef441000510446.device_temperature" has value "-4" less than min "0"
    zigbee.0
    2025-01-13 07:01:16.881	warn	State value to set for "zigbee.0.54ef44100025b53b.device_temperature" has value "-1" less than min "0"
    zigbee.0
    2025-01-13 06:58:27.183	warn	State value to set for "zigbee.0.54ef441000510446.device_temperature" has value "-2" less than min "0"
    zigbee.0
    2025-01-13 06:56:29.944	warn	State value to set for "zigbee.0.54ef441000510446.device_temperature" has value "-3" less than min "0"
    zigbee.0
    2025-01-13 06:52:54.707	warn	State value to set for "zigbee.0.54ef441000510446.device_temperature" has value "-3" less than min "0"
    zigbee.0
    2025-01-13 06:51:30.847	warn	State value to set for "zigbee.0.54ef441000510446.device_temperature" has value "-3" less than min "0"
    zigbee.0
    2025-01-13 06:47:03.087	warn	State value to set for "zigbee.0.54ef441000510446.device_temperature" has value "-2" less than min "0"
    zigbee.0
    2025-01-13 06:46:31.731	warn	State value to set for "zigbee.0.54ef441000510446.device_temperature" has value "-2" less than min "0"
    zigbee.0
    2025-01-13 06:44:16.895	warn	State value to set for "zigbee.0.54ef44100025b53b.device_temperature" has value "-1" less than min "0"
    es handelt sich um diese Geräte:
    https://www.zigbee2mqtt.io/devices/SSM-U01.html
    Vielen Dank
    Herzliche Grüße
    Fabio
    Eher nein. Da s ist ein Fehler im zigbee-herdsman-converter oder im device. Das Weg zu filtern ist meiner Meinung nach keine gute Idee.
    A.
    FabioF Offline
    FabioF Offline
    Fabio
    @asgothian wegfiltern meinte ich nicht man sollte den Datenpunkt im Adapter nicht auf 0 lassen oder bis -10 Grad gehen, oder verstehe ich das was falsch? Ich habe jetzt min entfernt.
    Herzliche Grüße
    Fabio
    Iobroker:
    • Matter over Thread Hilfe
    • FabioF Fabio
      Herzliche Grüße
      Fabio
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @fabio Da die Min/Max werte aus den Exposes des zigbee-herdsman-converters stammen ist es nicht trivial die 'mal eben' abzuändern. Welche Min/Max werte stimmen ? Welche sollen geändert werden ? Der Code kann das nicht entscheiden.
      A.
      Nachtrag: du darfst dich darauf verlassen das der Zigbee-Adapter besagte min/max Werte neu setzt sobald er das Objekt neu schreibt. Das ist also eine temporäre Lösung.
      FabioF 1 Antwort Letzte Antwort
        A.
        FabioF Offline
        FabioF Offline
        Fabio
        @asgothian vielen Dank für deine Erklärung.
        Iobroker:
        • FabioF Fabio
          FabioF Offline
          FabioF Offline
          Fabio
          schrieb am zuletzt editiert von Fabio
          @Asgothian ich habe eine Frage ich versuche gerade diese Lampe anzulernen was auch teilweise klappt, aber er sagt das sie nicht supportedt wird. Der Link sagt was anderss. Was kann ich da tun?
          https://www.zigbee2mqtt.io/devices/RDM-35274001.html
          modelZigbee:RDM-35274001
          type:Router
          nwk:8537
          manuf id:4762
          manufacturer:Rademacher
          power:Mains (single phase)
          app version:2
          hard version:1
          zcl version:3
          stack version:2
          date code:20211117
          build:2.09.03
          interviewed:false
          configured:false
          endpoint:1
          profile:260
          input clusters:genBasic (0)
          genIdentify (3)
          genGroups (4)
          genScenes (5)
          genOnOff (6)
          genLevelCtrl (8)
          lightingColorCtrl (768)
          touchlink (4096)
          heimanSpecificInfraRedRemote (64642)
          output clusters:genOta (25)
          endpoint:242
          profile:41440
          output clusters:greenPower (33)
          zigbee.0
          2025-01-14 15:21:35.540	error	Failed to interview '0x8cf681fffedea27c', device has not successfully been paired. Try again !!!!!!!!!!
          zigbee.0
          2025-01-14 15:21:25.591	info	Device 0x8cf681fffedea27c "RDM-35274001" not present in statesMapping - relying on exposes for device definition.
          zigbee.0
          2025-01-14 15:21:25.521	info	Device '0x8cf681fffedea27c' announced itself
          Iobroker:
          • FabioF Fabio
            type:Router
            nwk:8537
            manuf id:4762
            app version:2
            hard version:1
            zcl version:3
            stack version:2
            date code:20211117
            build:2.09.03
            interviewed:false
            configured:false
            endpoint:1
            profile:260
            genIdentify (3)
            genGroups (4)
            genScenes (5)
            genOnOff (6)
            genLevelCtrl (8)
            touchlink (4096)
            endpoint:242
            profile:41440
            zigbee.0
            zigbee.0
            zigbee.0
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            @fabio
            Dieses kommt daher das der Zigbee Adapter nur bis zigbee-herdsman-converters 20.x kompatibel ist. Die Nutzung von 21.x ist erst ab Version 1.11 (ggf. 2.0) möglich. Ich gehe davon aus das die Lampe erst in version 21.x hinzugefügt wurde. Bei Zigbee2mqtt ist es nicht üblich geräte in ältere Zweige nachzupflegen.
            Du kannst versuchen die Leuchte über einen externen Konverter unterstützt zu bekommen. Dazu musst du den Code finden der die Lampe unterstützt, und daraus einen externen Konverter bauen (lassen ?) - und diesen dann als .js Datei im Datenverzeichnis des Zigbee-Adapters hinterlegen und in der Konfiguration eintragen.
            A
            FabioF 3 Antworten Letzte Antwort
              @fabio
              A
              FabioF Offline
              FabioF Offline
              Fabio
              @asgothian
              oh mein Gott das begreife ich nicht, dann schicke ich sie zurück.
              Herzliche Grüße und Danke
              Fabio
              Iobroker:
                @fabio
                A
                FabioF Offline
                FabioF Offline
                Fabio
                @asgothian heißt das denn im Umkehrschluss das der Zigbee Adapter in Zukunft und jetzt keine neuen ZigBee Geräte kann?
                Iobroker:
                • FabioF Fabio
                  doch, aber erst in neueren Versionen
                  @asgothian sagte in ZigBee Adapter CZC Zigbee Coordinator:
                    FabioF Offline
                    FabioF Offline
                    Fabio
                    @homoran Danke, echt ich werde zu alt für Smart Home.;-)
                    Herzliche Grüße
                    Fabio
                    Iobroker:
                    • FabioF Fabio
                      Herzliche Grüße
                      Fabio
                      echt ich werde zu alt für Smart Home. ;-)
                      enä do Jeck!
                        enä do Jeck!
                        FabioF Offline
                        FabioF Offline
                        Fabio
                        @homoran ;-)
                        Iobroker:
                          @fabio
                          A
                          FabioF Offline
                          FabioF Offline
                          Fabio
                          @asgothian @arteck es tut mir leid das ich immer so viele Fragen habe.
                          Aber wie und wo kann ich sehen welche Geräte mit dem jetzigen ZigBee Adapter laufen?
                          https://www.zigbee2mqtt.io/supported-devices/ hier sieht man zwar was aufgenommen wurde und wie was zu steuern ist, aber mehr auch nicht.
                          Vielen Dank und Grüße aus Köln
                          Fabio
                          Iobroker:
                          • FabioF Fabio
                            Fabio
                            AsgothianA Offline
                            AsgothianA Offline
                            Asgothian
                            @fabio da sist leider nicht einfach, da zigbee2mqtt keine Listen führt ab welcher Version der converter welche devices unterstützt werden. Du kannst versuchen den device-Namen der Liste bei zigbee2mqtt.io mit dem change log des Projektes koenkk/zigbee-herdsman-converters abzugleichen. Alle Geräte die erst ab Version 21. 0 unterstützt werden gehen aktuell nicht.
                            A.
                              A.
                              FabioF Offline
                              FabioF Offline
                              Fabio
                              @asgothian ich Danke dir.
                              Iobroker:
                              • arteckA Offline
                                arteckA Offline
                                arteck
                                am ende ist es so, dass alles was im zigbe2mqtt geht auch im zigbee adapter geht .. wenn der zeitnah aktuallisiert worden ist (bis jetzt hab ich es alle 2 Tage gemacht)
                                es gab eine riesen Änderung im zigbee2mqtt und da ist gerade @Asgothian das nachzuziehen im zigbee adapter
                                und
                                im zigbee adapter hast du nicht für manche Geräte die volle Kontrolle. wie den aqara fp1 wo man irgendwelche Zonen einstellen kann..
                                oder Thermostate .. die machen auch probleme..
                                wenn du solche Geräte nutzen willst oder wenn du mit den Einstellungen des Gerätes nicht klar kommst im zigbee adapter dann wechsel auf zigbee2mqtt.
                                das sind aber in meinen Augen vielleicht 5 % aller Geräte die spezielle Einstellungen haben
                                FabioF 2 Antworten Letzte Antwort
                                • arteckA arteck
                                  und
                                  FabioF Offline
                                  FabioF Offline
                                  Fabio
                                  @arteck vielen Dank dir.
                                  Iobroker:
                                  • arteckA arteck
                                    und
                                    FabioF Offline
                                    FabioF Offline
                                    Fabio
                                    @Asgothian @arteck @Homoran ich wünsche einen Guten morgen.
                                    Ich komme immer besser mit dem ZigBee Adapter und den Coordinator klar und auch weiter. ;-)
                                    Jetzt aber was "komisches".
                                    Ich schalte über eine Grupe 2-3 Geräte an das passiert dann auch.
                                    Aber in der Kachel wird das Gerät als aus angezeigt und im Datenpunkt selber auch, das ist natürlich schlecht, da ja jetzt nicht klar ist ob an oder aus.
                                    Schalte ich in der Kachel an oder aus, oder über Alexa, oder ein Skript ist alles korrekt und wird auch in den Datenpunkten wie in der Kachel richtig angezeigt
                                    Könnt ihr dass bitte mal testen. Das Verhalten tritt nur bei Gruppenschaltungen auf.
                                    Herzliche Grüße
                                    Fabio
                                    Was bedeutet das
                                    Device '0x00158d00053d4089' announced itself
                                    ich verstehe das es sich selber meldet, aber was wäre da der technische Hintergrund?
                                    Iobroker:
                                    • FabioF Fabio
                                      Herzliche Grüße
                                      Fabio
                                      Was bedeutet das
                                      arteckA Offline
                                      arteckA Offline
                                      arteck
                                      hä..
                                      nochmal on den objekten schaltest du die Gruppe auf an ... wie ?? brightness oder state ??
                                      was ist alles in der Gruppe ??
                                      ausserdem die Kachel ist nur reine Info.. ist nicht zum steuern gedacht..
                                      • arteckA arteck
                                        hä..
                                        FabioF Offline
                                        FabioF Offline
                                        Fabio
                                        @arteck ich schalte in der Gruppe vom ZigBee Adapter den State auf An oder AUS.
                                        Das sind Lampen wie auch Steckdosen drin.
                                        Wenn das in der Kachel nur zur Info ist, warum kann man dann über die Kachel steueren Dimmen und schalten etc.?
                                        Und das wäre auch kein Problem, warum ändert er den State nicht im Datenpunkt selber wenn man über die Gruppe schaltet?
                                        Fabio
                                        Iobroker:
                                        arteckA HomoranH 2 Antworten Letzte Antwort
                                        • FabioF Fabio
                                          Fabio
                                          arteckA Offline
                                          arteckA Offline
                                          arteck
                                          weil es geht .. punkt.. manchmal ist es hilfreich.. hast ein neues Gerät angelernt und willst mal EBEN schauen ob geschaltet wird.
                                          ausserdem .. es werden ALLE Geräte genommen.. also auch Sensorten.. ich pflücke jetzt nicht die Geräte auseinander um diese dann in die Kachel zu pressen... dazu kommt noch dass der Browser manchmal hier auch schmuhh macht mit dem Cache....
                                          also... OBJEKTE sind wichtig nicht die Kachel..
