  4. Test Adapter VeSync
    6.8k
Test Adapter VeSync
142 Beiträge 34 Kommentatoren 36.3k Aufrufe 29 Beobachtet
    sherlock
    #104
    vesync.0 2024-10-20 11:33:29.377	debug	{"traceId":"","code":-11000029,"msg":"illegal argument","module":null,"stacktrace":null,"result":null}
    vesync.0 2024-10-20 11:33:28.995	debug	{"traceId":"","code":0,"msg":"request success","module":null,"stacktrace":null,"result":{"isRequiredVerify":true,"accountID":"11758821","avatarIcon":"https://image.vesync.com/defaultImages/user/avatar_nor.png","birthday":"","gender":"","acceptLanguage":"de","userType":"1","nickName":"vesync.de1304","mailConfirmation":true,"termsStatus":true,"gdprStatus":true,"countryCode":"DE","registerAppVersion":"VeSync 4.3.70 build17","registerTime":"2023-07-30 14:55:12","verifyEmail":"xxx@xxx.de","measureUnit":"Imperial","weightG":0,"heightCm":0,"weightTargetSt":0,"heightUnit":"FT","heightFt":0,"weightTargetKg":0,"weightTargetLb":0,"weightUnit":"KG","maximalHeartRate":0,"targetBfr":0,"displayFlag":[],"targetStatus":0,"realWeightKg":0,"realWeightLb":0,"realWeightUnit":"lb","heartRateZones":0,"runStepLongCm":0,"walkStepLongCm":0,"stepTarget":0,"sleepTargetMins":0,"token":"100100qSdz78CimQp4KlaFap-WgZE1ubX1_HzV3ckzgUtA_d-uRrfAbS5cph4WZ-8rn6aZpysslfh9pqm2SHTFXTuUnysfnGAjtAk=","accountLockTimeInSec":null}}
    vesync.0 2024-10-20 11:33:28.493	info	Login to VeSync
      sherlock
      #105
      Login is working, aber
      vesync.0 | 2024-10-20 15:12:38.271 | debug | {"traceId":"","code":-11000029,"msg":"illegal argument","module":null,"stacktrace":null,"result":null}
      vesync.0 | 2024-10-20 15:12:38.174 | silly | States user redis pmessage vesync.0.*/vesync.0.info.connection:{"val":true,"ack":true,"ts":1729429958171,"q":0,"from":"system.adapter.vesync.0","user":"system.user.admin","lc":1729429958171}
      vesync.0 | 2024-10-20 15:12:38.155 | info | Login successful
      vesync.0 | 2024-10-20 15:12:38.154 | debug | {"traceId":"","code":0,"msg":"request success","module":null,"stacktrace":null,"result":{"isRequiredVerify":true,"accountID":"11758821","avatarIcon":"https://image.vesync.com/defaultImages/user/avatar_nor.png","birthday":"","gender":"","acceptLanguage":"de","userType":"1","nickName":"vesync.de1304","mailConfirmation":true,"termsStatus":true,"gdprStatus":true,"countryCode":"DE","registerAppVersion":"VeSync 4.3.70 build17","registerTime":"2023-07-30 14:55:12","verifyEmail":"x@xlk.de","measureUnit":"Imperial","weightG":0,"heightCm":0,"weightTargetSt":0,"heightUnit":"FT","heightFt":0,"weightTargetKg":0,"weightTargetLb":0,"weightUnit":"KG","maximalHeartRate":0,"targetBfr":0,"displayFlag":[],"targetStatus":0,"realWeightKg":0,"realWeightLb":0,"realWeightUnit":"lb","heartRateZones":0,"runStepLongCm":0,"walkStepLongCm":0,"stepTarget":0,"sleepTargetMins":0,"token":"100100qCd34cSrkgp5I1mHZ5SQgdr4q_fMpzOZbRWF57ZLqycgPJ4m-kpKzS2NTr52QgeS5IgJKcH3nP43qBcDru827dc4sXcLF4o=","accountLockTimeInSec":null}}
      vesync.0 | 2024-10-20 15:12:37.803 | silly | States user redis pmessage vesync.0.*/vesync.0.info.connection:{"val":false,"ack":true,"ts":1729429957799,"q":0,"from":"system.adapter.vesync.0","user":"system.user.admin","lc":1729429952451}
      vesync.0 | 2024-10-20 15:12:37.668 | info | Login to VeSync
      vesync.0 | 2024-10-20 15:12:37.665 | debug | terminalId: 943C353585EE4F82AE1E9C66B4B68087
      vesync.0 | 2024-10-20 15:12:37.653 | silly | States system redis pmessage system.adapter.vesync.0.logLevel/system.adapter.vesync.0.logLevel:{"val":"silly","ack":true,"ts":1729429957635,"q":0,"from":"system.adapter.vesync.0","lc":1729429841840}
      vesync.0 | 2024-10-20 15:12:37.589 | info | starting. Version 0.0.7 (non-npm: TA2k/ioBroker.vesync#06244eda18f3fb8303e929e1955d96c1712f2305) in /opt/iobroker/node_modules/iobroker.vesync, node: v22.10.0, js-controller: 5.0.19
      sniping
      was fehlt ist das Device
      sniping2
      Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
      Hier gehts zur Hilfe.
      • S sherlock
        sniping
        sniping2
        maxlox
        #106
        @sherlock
        Hallo
        Habe leider das Problem das der Adapter Vers. 0.0.8
        Den Fehler: 2024-12-21 15:50:57.883 error {"traceId":"","code":-11000022,"msg":"illegal argument","module":null,"stacktrace":null,"result":null}
        bringt.
        In den Instanzen hat der Adapter ein Rufzeichen mit der Meldung:
        (X in rot)Verbunden mit Gerät oder Dienst.
        Bis vor ein paar Tagen hat der Adapter noch funktioniert.
        Wäre für eine Hilfe sehr dankbar.
        P T 2 Antworten Letzte Antwort
        • M maxlox
          @sherlock
          Hallo
          bringt.
          Papi 0
          schrieb am zuletzt editiert von Papi 0
          #107
          @maxlox
          Ich würde sagen, Ruhe bewahren, denn exakt denselben Fehler hatte ich heute Morgen auch.
          Momentan scheint er aber wieder zu laufen.
          Edit:
          Heute (22.12.24) ist 0.0.7 wieder mit demselben Fehler erschienen.
          Ich möchte 0.0.9 aber nicht ausprobieren, da man dafür das Latest-Repo auswählen muss.
          Bananenprodukte sind mir zu gefährlich.
          • M maxlox
            @sherlock
            Hallo
            bringt.
            tombox
            #108
            @maxlox 0.0.9 testen
            Sven BergS 1 Antwort Letzte Antwort
            • T tombox
              Sven BergS Offline
              Sven BergS Offline
              Sven Berg
              #109
              @tombox Wann wird die Heißluftfriteuse Cosori Modell CAF-TF101S unterstützt? Wie kann ich dabei helfen?
              • Sven BergS Sven Berg
                tombox
                #110
                @sven-berg hast du das gerät mit mir geshared was funktionier genau nicht
                  mk122
                  #111
                  @tombox Hallo, ich verwende den Luftbefeuchter LV600S der wunderbar mit dem Adapter funktioniert. Bei unserem zweiten im Haus der OasisMist 1000S, funktioniert zwar der "status" Ordner den er laufend aktualisieren kann, jedoch alle "remote" Parameter werden nicht gelesen und angenommen, sie wurden nur beim ersten einrichten einmalig ausgelesen. Hast du eine Idee was da die mögliche Ursache sein kann? Vielen Dank! Lg
                  • M mk122
                    tombox
                    #112
                    @mk122 sagt der debug log irgendwas
                    M T 2 Antworten Letzte Antwort
                    • T tombox
                      mk122
                      #113
                      @tombox Danke für deine Antwort. Ja, code 11000000.
                      "{"traceId":"1736450305669","code":0,"msg":"request success","module":null,"stacktrace":null,"result":{"traceId":"1736450305669","code":11000000}}"
                      • T tombox
                        tombox
                        #114
                        @tombox scheint aber so dass der Befehl angenommen und verarbeitet wird
                        • J JoJAPJo
                          @tombox: Hallo, besteht die Möglichkeit den Adapter so zu verändern, dass man bei den veSync Steckdosen auch die aktuelle Watt Zahl sehen kann: Hintergrund ist, dass ich zwei Wechselrichter hinter solchen Steckdosen habe und ich gerne deren Daten auslesen möchte...
                          Danke im Voraus und Gruß
                          JoJAPJo
                          @tombox Sorry, hatte die Stable aktiv, in der Beta schon aufgenommen und gefunden:
                          Super Arbeit! Danke!
                          robbsen
                          schrieb am zuletzt editiert von robbsen
                          #115
                          @jojapjo ich scheine blind zu sein, habe Version 0.0.9 sehe diesen wert aber leider nicht :( (Watt Zahl) welche Version brauche ich denn dafür
                          scheint aber grundsätzlich ja zu funktionieren https://www.home-assistant.io/integrations/vesync/
                          • R robbsen
                            JoJAPJo
                            #116
                            @robbsen: Ich habe gerade auch einmal auf die Version 0.0.9 geupdatet;
                            Der Wert lautet realTimePower:
                            zu finden wäre es wie folgt:
                            vesync
                            ->0
                            -->Info
                            --->vs........ (Device-ID)
                            ---->status
                            Daniel
                            R 1 Antwort Letzte Antwort
                            • J JoJAPJo
                              vesync
                              ->0
                              -->Info
                              ---->status
                              Daniel
                              robbsen
                              #117
                              @jojapjo ok also diesen Datenpunkt habe ich eindeutig nicht trotz Version 0.0.9, spannen das es ihn bei dir gibt.
                              • R robbsen
                                mcm1957M Online
                                mcm1957M Online
                                mcm1957
                                #118
                                @robbsen
                                Von wo / wie installiert?
                                LATEST Repository oder GitHub?
                                Support Repositoryverwaltung.
                                LESEN - gute Forenbeitrage
                                • R Offline
                                  robbsen
                                  #119
                                  Direkt über den Link von Github runtergeladen, auch versucht über TA2k/ioBroker.vesync also ebenfalls Github
                                  • R robbsen
                                    mcm1957M Online
                                    mcm1957M Online
                                    mcm1957
                                    #120
                                    @robbsen said in Test Adapter VeSync:
                                    Bei Github Installationsn sagen die Versionsnummern absolut nichts aus. Die Versionnummer wird im Allgemeinen erst beim Erstellen einer Release geändert. Version 1.2.3 kann sich zwischen der offiziellen Release auf npm und dem Stand auf Github total unterscheiden. Auch zwei Github Installation mit selber Versinsnummer müssen nicht ein Bit identisch haben.
                                    Wenn du bei Github Installationen eine eindeutige Referenz des SW Standes haben willst, musst du den Github SHA nehmen. Dazu mit der Maus auf die GH Katze gehen. Der SHA wird dir als Tooltip angezeigt:
                                    Mit der INfo kannst den exakten SW STand identifizieren.
                                    • NegaleinN Offline
                                      NegaleinN Offline
                                      Negalein
                                      #121
                                      Hallo
                                      Ich habe heute den AirFryer CS158-AF mit dem Adapter (0.0.9) verbunden.
                                      Klappte sofort. :)
                                      Unter vesync.0.vssk8fa8b19425c9c4ffe882e0027886.status werden die DP korrekt aktualisiert.
                                      Aber wie steuere ich den AirFryer vom ioB aus?
                                      Egal was in vesync.0.vssk8fa8b19425c9c4ffe882e0027886.remote geschaltet wird, der AirFryer macht keinen Murks. :(
                                      ° Fixer ---> iob fix
                                      • NegaleinN Negalein
                                        Hallo
                                        Klappte sofort. :)
                                        tombox
                                        #122
                                        @negalein was sagt der debug log
                                        • T tombox
                                          NegaleinN Offline
                                          NegaleinN Offline
                                          Negalein
                                          #123
                                          @tombox sagte in Test Adapter VeSync:
                                          ich glaub ich habs (teilweise)
                                          Um einen Kochforgang zu starten, muss in vesync.0.vssk8fa8b19425c9c4ffe882e0027886.remote.cookMode der DP dementsprechend beschrieben werden.
                                            "accountId": "xxxxxxxxxxxxx",
                                            "appointmentTs": 0,
                                            "cookSetTemp": 175,
                                            "cookSetTime": 15,
                                            "cookStatus": "cooking",
                                            "customRecipe": "Manuell",
                                            "mode": "custom",
                                            "readyStart": true,
                                            "recipeId": 1,
                                            "recipeType": 3,
                                            "tempUnit": "celsius"
                                          Das hat funktioniert (Ich muss also zB in VIS den Inhalt an den DP schicken? Wie?).
                                          Aber vesync.0.vssk8fa8b19425c9c4ffe882e0027886.remote.startCook macht nichts.
                                            "accountId": "xxxxxxxxxx",
                                            "cookTempDECP": 0,
                                            "hasPreheat": 0,
                                            "hasWarm": false,
                                            "imageUrl": "",
                                            "mode": "Chicken",
                                            "readyStart": true,
                                            "recipeId": 2,
                                            "recipeName": "Huhn",
                                            "recipeType": 3,
                                            "startAct": {
                                              "appointingTime": 0,
                                              "cookSetTime": 780,
                                              "cookTemp": 210,
                                              "cookTempDECP": 0,
                                              "imageUrl": "",
                                              "level": 0,
                                              "preheatTemp": 0,
                                              "shakeTime": 0,
                                              "targetTemp": 0
                                            "tempUnit": "c"
                                          vesync.0 2025-01-24 08:54:12.554	info	{"traceId":"xxxxxxxxxxxxxxx","code":-11000030,"msg":"illegal argument","module":null,"stacktrace":null,"result":null}
                                          mehr kommt da nicht. Auch keine Debug-Meldung.
                                          Kochvorgang gestartet und dann versucht mit vesync.0.vssk8fa8b19425c9c4ffe882e0027886.remote.endCook zu beenden, funktioniert nicht.
                                          vesync.0 2025-01-24 08:56:33.350	info	{"traceId":"xxxxxxxxxxxxxxx","code":-11000030,"msg":"illegal argument","module":null,"stacktrace":null,"result":null}
                                          PS: ich lese im Thresd immer wieder von .status.stepArray01.mode und .remote.setPurifierMode.
                                          Diese gibt es bei mir nicht.
