  4. Zigbee Sonoff lässt sich nicht aktivieren- Herdsman Problem
40 Beiträge 9 Kommentatoren 5.3k Aufrufe 8 Beobachtet
  • D Dschones
    Hallo - ich bin neu in der Materie und viele meiner Probleme wurden durch dieses Forum schon gelöst.
    Diesmal aber nicht - ich bekomme meinen neuen SONOFF Zigbee 3.0 USB Dongle Plus nicht im IO Broker zum laufen.
    es ist immer dieses Bild:
    hier der passende Log dazu:
    2025-01-03 12:49:26.125 - info: zigbee.0 (7400) Got terminate signal TERMINATE_YOURSELF
    2025-01-03 12:49:26.131 - info: zigbee.0 (7400) cleaned everything up...
    2025-01-03 12:49:26.134 - info: zigbee.0 (7400) Zigbee: disabling joining new devices.
    2025-01-03 12:49:26.142 - info: zigbee.0 (7400) terminating
    2025-01-03 12:49:26.144 - info: zigbee.0 (7400) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-01-03 12:49:26.217 - info: host.iobroker-pi stopInstance system.adapter.zigbee.0 send kill signal
    2025-01-03 12:49:26.717 - info: host.iobroker-pi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-01-03 12:49:29.275 - info: host.iobroker-pi instance system.adapter.zigbee.0 started with pid 10642
    2025-01-03 12:49:33.967 - info: zigbee.0 (10642) starting. Version 1.10.13 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.20.5, js-controller: 4.0.23
    2025-01-03 12:49:34.077 - info: zigbee.0 (10642) delete old Backup files. keep only last 10
    2025-01-03 12:49:34.080 - info: zigbee.0 (10642) Starting Zigbee npm ...
    2025-01-03 12:49:34.863 - info: zigbee.0 (10642) Installed Version: iobroker.zigbee@1.10.13
    2025-01-03 12:49:55.119 - error: zigbee.0 (10642) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
    2025-01-03 12:49:55.120 - error: zigbee.0 (10642) Failed to start Zigbee
    2025-01-03 12:49:55.121 - error: zigbee.0 (10642) Error herdsman start
    2025-01-03 12:50:05.125 - info: zigbee.0 (10642) Try to reconnect. 1 attempts left
    2025-01-03 12:50:05.126 - info: zigbee.0 (10642) Starting Zigbee npm ...
    2025-01-03 12:50:05.138 - info: zigbee.0 (10642) Installed Version: iobroker.zigbee@1.10.13
    2025-01-03 12:50:05.305 - error: zigbee.0 (10642) Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
    2025-01-03 12:50:05.306 - error: zigbee.0 (10642) Failed to start Zigbee
    2025-01-03 12:50:05.307 - error: zigbee.0 (10642) Error herdsman start
    Die Einstellungen im Adapter sind die folgenden - ich haeb auch schon andere PAN ID's versucht , aber das Problem blieb das gleiche
    Was kann ich noch tun ? Der Zigbee - Adapter ist neu, mein raspberry pi 4 (4GB RAM; 64GB Speicher nahezu unbenutzt) ist aktuell
    Dnake für eure Hilfe !
    @dschones sagte in Zigbee Sonoff lässt sich nicht aktivieren- Herdsman Problem:
    Dann verwende als Neuling auch die aktuellen Versionen.
    node@20 und js-controller@7 sind das Stand heute.
    stimmt also nicht.
      stimmt also nicht.
      Dschones
      Sorry, das war unpräzise - hier der Log mit dem Richtigen / Aktuellen Version, das Problem ist aber das gleiche...
      025-01-03 14:30:10.628 - info: host.iobroker-pi stopInstance system.adapter.zigbee.0 (force=false, process=true)
      2025-01-03 14:30:10.633 - info: zigbee.0 (16404) Got terminate signal TERMINATE_YOURSELF
      2025-01-03 14:30:10.636 - info: zigbee.0 (16404) cleaned everything up...
      2025-01-03 14:30:10.639 - info: zigbee.0 (16404) Zigbee: disabling joining new devices.
      2025-01-03 14:30:10.647 - info: zigbee.0 (16404) terminating
      2025-01-03 14:30:10.648 - info: zigbee.0 (16404) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-01-03 14:30:10.753 - info: host.iobroker-pi stopInstance system.adapter.zigbee.0 send kill signal
      2025-01-03 14:30:11.138 - info: zigbee.0 (16404) terminating
      2025-01-03 14:30:11.234 - info: host.iobroker-pi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-01-03 14:30:14.769 - info: host.iobroker-pi instance system.adapter.zigbee.0 in version "1.10.13" started with pid 22621
      2025-01-03 14:30:20.074 - info: zigbee.0 (22621) starting. Version 1.10.13 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.1, js-controller: 7.0.6
      2025-01-03 14:30:20.174 - info: zigbee.0 (22621) delete old Backup files. keep only last 10
      2025-01-03 14:30:20.176 - info: zigbee.0 (22621) Starting Zigbee npm ...
      2025-01-03 14:30:20.515 - info: zigbee.0 (22621) Installed Version: iobroker.zigbee@1.10.13
      2025-01-03 14:30:28.032 - info: host.iobroker-pi instance system.adapter.daswetter.0 in version "3.1.3" started with pid 22688
      2025-01-03 14:30:31.031 - info: daswetter.0 (22688) starting. Version 3.1.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.1, js-controller: 7.0.6
      2025-01-03 14:30:41.100 - error: zigbee.0 (22621) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
      2025-01-03 14:30:41.102 - error: zigbee.0 (22621) Failed to start Zigbee
      2025-01-03 14:30:41.104 - error: zigbee.0 (22621) Error herdsman start
      2025-01-03 14:30:45.914 - info: daswetter.0 (22688) still wrong data structure from server received! repaired...
      2025-01-03 14:30:49.914 - info: daswetter.0 (22688) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2025-01-03 14:30:50.431 - info: daswetter.0 (22688) cleaned everything up...
      2025-01-03 14:30:50.445 - info: host.iobroker-pi instance system.adapter.daswetter.0 having pid 22688 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-01-03 14:30:51.110 - info: zigbee.0 (22621) Try to reconnect. 1 attempts left
      2025-01-03 14:30:51.112 - info: zigbee.0 (22621) Starting Zigbee npm ...
      2025-01-03 14:30:51.124 - info: zigbee.0 (22621) Installed Version: iobroker.zigbee@1.10.13
      2025-01-03 14:30:51.278 - error: zigbee.0 (22621) Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
      2025-01-03 14:30:51.280 - error: zigbee.0 (22621) Failed to start Zigbee
      2025-01-03 14:30:51.280 - error: zigbee.0 (22621) Error herdsman start
      was mache ich falsch?
      • D Dschones
        @dschones gib mal die Langversion von iob diag preis.
          Dschones
          @homoran said in Zigbee Sonoff lässt sich nicht aktivieren- Herdsman Problem:
          hmm ... das will irgendwie nicht - es kommt immer:
          *** iob diag is starting up, please wait ***
          iob diag needs to be updated. Please execute 'iobroker fix' first.
          Führe ich iobroker fix aus, so läuft folgendes durch, aber das Ergebnis ist das gleiche.
          pi@iobroker-pi:~ $ iobroker fix
          library: loaded
          Library version=2024-10-22
              Welcome to the ioBroker installation fixer!
              Script version: 2024-10-22
              You might need to enter your password a couple of times.
              Installing prerequisites (1/5)
          Get:1 http://deb.debian.org/debian bullseye-proposed-updates InRelease [54.0 kB]
          Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
          Hit:5 https://apt.pivccu.de/piVCCU stable InRelease
          Err:1 http://deb.debian.org/debian bullseye-proposed-updates InRelease
            The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
          Reading package lists... Done
          W: GPG error: http://deb.debian.org/debian bullseye-proposed-updates InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
          E: The repository 'http://deb.debian.org/debian bullseye-proposed-updates InRelease' is not signed.
          N: Updating from such a repository can't be done securely, and is therefore disabled by default.
          N: See apt-secure(8) manpage for repository creation and user configuration details.
          Installed polkitd
              Checking ioBroker user and directory permissions (2/5)
              Check and cleanup npm temporary directories (3/5)
          Done.
              Database maintenance (4/5)
          Checking for uncompressed JSONL databases... This might take a while!
          Compressing /opt/iobroker/iobroker-data/states.jsonl
          Compressing /opt/iobroker/iobroker-data/objects.jsonl
          Compressed 2 JSONL files. Done
              Checking autostart (5/5)
          ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ===
          Authentication is required to stop 'iobroker.service'.
          Authenticating as: ,,, (pi)
          Password:
          ==== AUTHENTICATION COMPLETE ===
          Enabling autostart...
          Autostart enabled!
              Your installation was fixed successfully
              Run iobroker start to start ioBroker again!
          HomoranH J 2 Antworten Letzte Antwort
          • D Dschones
            library: loaded
            Installed polkitd
            Done.
            Password:
            Autostart enabled!
            @dschones
            ist das ein Raspi?
            da braucht es im Moment eine Sonderbehandlung
            curl https://raw.githubusercontent.com/Grothesk242/ioBroker/refs/heads/Raspbian/diag.sh > iob_diag.sh
            chmod 744 iob_diag.sh
            ./iob_diag.sh
            • D Dschones
              library: loaded
              Installed polkitd
              Done.
              Password:
              Autostart enabled!
              Jaksa
              @dschones said in Zigbee Sonoff lässt sich nicht aktivieren- Herdsman Problem:
              library: loaded
              Installed polkitd
              Done.
              Password:
              Autostart enabled!
              Dein System ist alles nur nicht aktuell. Du hast da noch Debian Bullseye drauf laut den Paketquellen.
              Mach die Karte platt, installiert Debian Bookworm und probiere es dann nochmal.
              • D Dschones
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                Das ist auch nicht verwunderlich. Dem Adapter gelingt es nicht mit der Firmware auf dem Stick zu reden. Mögliche Ursachen:
                • Störungen durch USB3 (in welchem Port steckt der Zigbee-Stick ? In einem der USB3 oder einem der USB2, mit oder ohne USB Verlängerung
                • Defekte Firmware auf dem Stick - da wäre dann neu Flaschen angesagt
                • falsche Auswahl der Firmware im Adapter. Welchen Sonoff Dongle hast du genau ?
                A.
                p.s. All dies ist unabhängig von der alten Software auf dem PI4. Ein Update macht sicher Sinn, hat aber mit diesem Problem wenig bis nichts zu tun.
                • AsgothianA Asgothian
                  A.
                  Dschones
                  @asgothian said in Zigbee Sonoff lässt sich nicht aktivieren- Herdsman Problem:
                  ohne USB-Verlängerung , ich habe auch schon andere USB-Ports versucht - gleiches Ergebnis
                  pi@iobroker-pi:~ $ ls -la /dev/serial/by-id/
                  total 0
                  drwxr-xr-x 2 root root 80 Jan  2 22:17 .
                  drwxr-xr-x 4 root root 80 Jan  2 22:17 ..
                  lrwxrwxrwx 1 root root 13 Jan  2 22:17 usb-BSC_Computer_GmbH_FAM-USB-515_AB7BBEH                                                    P-if00-port0 -> ../../ttyUSB0
                  lrwxrwxrwx 1 root root 13 Jan  2 22:17 usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Pl                                                    us_902fb787e3e7ed119668d7770b2af5ab-if00-port0 -> ../../ttyUSB1
                  ok, das habe ich noch nicht in Betracht zu gezogen, das ding ist ja "frisch"
                  hast du da ne gute Anleitung ?
                  Hier:
                  A.
                  Das sehe ich ähnlich - Freunde von mir haben den Stick ebenfalls (auf noch viel älteren System) problemlos am laufen
                  AsgothianA CodierknechtC 2 Antworten Letzte Antwort
                    @dschones
                    ist das ein Raspi?
                    ./iob_diag.sh
                    Dschones
                    schrieb am zuletzt editiert von Dschones
                    da komme ich nicht weiter:
                    pi@iobroker-pi:~ $ curl https://raw.githubusercontent.com/Grothesk242/ioBroker/refs/heads/Raspbian/diag.sh > iob_diag.shchmod 744 iob_diag.sh./iob_diag.sh
                      % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                                     Dload  Upload   Total   Spent    Left  Speed
                    100 42291  100 42291    0     0   581k      0 --:--:-- --:--:-- --:--:--  581k
                      0     0    0     0    0     0      0      0 --:--:--  0:02:09 --:--:--     0
                    curl: (28) Failed to connect to 744 port 80: Connection timed out
                      0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0curl: (6) Could not resolve host: iob_diag.sh.
                    • D Dschones
                      total 0
                      Hier:
                      A.
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      Bitte eine USB Verlängerung einsetzen, damit der Stick vom PI weg kommt - ich denke da gibt es Störungen aus dem USB3 Bereich. Nutzt Du ggf. eine SSD ?
                      A.
                      • D Dschones
                        bitte die Befehle nicht verschmelzen
                          A.
                          Dschones
                          @asgothian
                          Usb- Verlängerung ist drin , Problem ist dasselbe
                            Dschones
                            da tut sich leider nix
                            100 42291  100 42291    0     0   522k      0 --:--:-- --:--:-- --:--:--  522k
                             0     0    0     0    0     0      0      0 --:--:--  0:00:24 --:--:--     0
                             0     0    0     0    0     0      0      0 --:--:--  0:02:11 --:--:--     0
                            was mache ich falsch ?
                            HomoranH Meister MopperM 2 Antworten Letzte Antwort
                            • D Dschones
                              du hast immer noch 2 Befehle verschmolzen!
                              sieh dir die drei einzelnen Befehle mal hier an
                              @homoran sagte in Zigbee Sonoff lässt sich nicht aktivieren- Herdsman Problem:
                              @dschones
                              ist das ein Raspi?
                              ./iob_diag.sh
                              • D Dschones
                                Meister MopperM Offline
                                Meister Mopper
                                @dschones
                                Du kannst das nicht einfach ins Clipboard kopieren und in der Konsole ausführen, denn es sind drei Befehle.
                                Du kannst sie allerdings mit && verbinden und dann in der Konsole ausführen. Dann wird der nächste Befehl erst ausgeführt, wenn der vorherige abgeschlossen ist.
                                z. B.
                                curl https://raw.githubusercontent.com/Grothesk242/ioBroker/refs/heads/Raspbian/diag.sh > iob_diag.sh && chmod 744 && iob_diag.sh && ./iob_diag.sh
                                Proxmox und HA ...
                                  @dschones
                                  ist das ein Raspi?
                                  ./iob_diag.sh
                                  Dschones
                                  sorry - ich bin da noch etwas zu ungeübt und unerfahren
                                  hier das Ergebnis
                                                          v.2024-12-09 Raspbian+zigbee diag+masking
                                     Static hostname: iobroker-pi
                                           Icon name: computer
                                    Operating System: Raspbian GNU/Linux 11 (bullseye)
                                              Kernel: Linux 6.1.21-v7l+
                                        Architecture: arm
                                  Kernel:                 armv7l
                                  Userland:               32 bit
                                  Timezone:               Europe/Berlin (CET, +0100)
                                  User-ID:                1000
                                  Display-Server:         false
                                  Boot Target:            multi-user.target
                                  Pending OS-Updates:     0
                                  Pending iob updates:    23
                                  Nodejs-Installation:
                                  /usr/bin/nodejs         v20.18.1
                                  /usr/bin/node           v20.18.1
                                  /usr/bin/npm            10.8.2
                                  /usr/bin/npx            10.8.2
                                  /usr/bin/corepack       0.29.4
                                  Recommended versions are nodejs 20.18.1 and npm 10.8.2
                                  nodeJS installation is correct
                                  MEMORY:
                                  Mem:            3.9G        1.1G        2.1G        0.0K        697M        2.6G
                                  Swap:            99M          0B         99M
                                  Total:          4.0G        1.1G        2.2G
                                  Active iob-Instances:   18
                                  Upgrade policy: none
                                  ioBroker Core:          js-controller           7.0.6
                                                          admin                   7.1.5
                                  Objects type: jsonl
                                  States  type: jsonl
                                  + system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                    system.adapter.web.0                    : web                   : iobroker-pi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                  Objects:                9605
                                  States:                 8668
                                  Size of iob-Database:
                                  15M     /opt/iobroker/iobroker-data/objects.jsonl
                                  2.8M    /opt/iobroker/iobroker-data/states.jsonl
                                  Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
                                  • D Dschones
                                    hier das Ergebnis
                                             Icon name: computer
                                          Architecture: arm
                                    Kernel:                 armv7l
                                    Userland:               32 bit
                                    User-ID:                1000
                                    /usr/bin/npm            10.8.2
                                    /usr/bin/npx            10.8.2
                                    MEMORY:
                                    Swap:            99M          0B         99M
                                                            admin                   7.1.5
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Objects:                9605
                                    States:                 8668
                                    hier das Ergebnis
                                    das ist leider nur das Summary!
                                    bitte die Langfassung, die kommt vorher.
                                    • D Dschones
                                      hier das Ergebnis
                                               Icon name: computer
                                            Architecture: arm
                                      Kernel:                 armv7l
                                      Userland:               32 bit
                                      User-ID:                1000
                                      /usr/bin/npm            10.8.2
                                      /usr/bin/npx            10.8.2
                                      MEMORY:
                                      Swap:            99M          0B         99M
                                                              admin                   7.1.5
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Objects:                9605
                                      States:                 8668
                                      Meister Mopper
                                      Bevor weitere geriatrische Analysen durchgeführt werden, solltest du nach meiner Meinung auf bookworm wechseln und zwar in der minimalen 64Bit-Version.
                                      Hast du aktuelle, funktionierende Backups mit dem backitup-Adapter außerhalb des ioBroker gesichert?
                                      Proxmox und HA ...
                                        hier das Ergebnis
                                        Dschones
                                        Script v.2024-12-09 Raspbian+zigbee diag+masking
                                        *** BASE SYSTEM ***
                                                 Icon name: computer
                                              Architecture: arm
                                        OS is similar to: debian
                                        Model           : Raspberry Pi 4 Model B Rev 1.5
                                        Docker          : false
                                        Virtualization  : none
                                        Kernel          : armv7l
                                        Userland        : 32 bit
                                        Systemuptime and Load:
                                         16:56:37 up 8 days, 18:38,  1 user,  load average: 0.65, 0.41, 0.25
                                        CPU threads: 4
                                        *** LIFE CYCLE STATUS ***
                                        *** RASPBERRY THROTTLING ***
                                        Current issues:
                                        Previously detected issues:
                                        *** TIME AND TIMEZONES ***
                                                       Local time: Sat 2025-01-11 16:56:38 CET
                                                   Universal time: Sat 2025-01-11 15:56:38 UTC
                                                         RTC time: Sat 2025-01-11 15:56:38
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        *** Users and Groups ***
                                        User that called 'iob diag':
                                        pi
                                        HOME=/home/pi
                                        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                        iobroker
                                        HOME=/home/iobroker
                                        *** DISPLAY-SERVER SETUP ***
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Mem:            3.9G        1.1G        1.8G        0.0K        982M        2.6G
                                        Swap:            99M          0B         99M
                                        Total:          4.0G        1.1G        1.9G
                                                 3887 M total memory
                                                 1106 M used memory
                                                  464 M active memory
                                                 1500 M inactive memory
                                                 1799 M free memory
                                                  113 M buffer memory
                                                  868 M swap cache
                                                   99 M total swap
                                                    0 M used swap
                                                   99 M free swap
                                        top - 16:56:38 up 8 days, 18:38,  1 user,  load average: 0.65, 0.41, 0.25
                                        Tasks: 190 total,   1 running, 189 sleeping,   0 stopped,   0 zombie
                                        %Cpu(s):  0.0 us,  3.0 sy,  0.0 ni, 97.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                        MiB Mem :   3887.9 total,   1799.4 free,   1105.6 used,    982.9 buff/cache
                                        MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2641.8 avail Mem
                                        *** FAILED SERVICES ***
                                        0 loaded units listed.
                                        *** DMESG CRITICAL ERRORS ***
                                        No critical errors detected
                                        *** FILESYSTEM ***
                                        /dev/root      ext4       58G  7.2G   49G  13% /
                                        devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                                        tmpfs          tmpfs     778M  876K  777M   1% /run
                                        /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
                                        tmpfs          tmpfs     389M     0  389M   0% /run/user/1000
                                        Show mounted filesystems:
                                        TARGET  SOURCE         FSTYPE OPTIONS
                                        /       /dev/mmcblk0p2 ext4   rw,noatime
                                        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                                        /var:
                                        du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
                                        3.3G    /var/
                                        1.9G    /var/log
                                        1.8G    /var/log/journal/834f3657738944fca3e7840589ae9346
                                        755M    /var/cache
                                        Archived and active journals take up 1.7G in the file system.
                                        /opt/iobroker/backups:
                                        402M    /opt/iobroker/backups/
                                        /opt/iobroker/iobroker-data:
                                        198M    /opt/iobroker/iobroker-data/
                                        132M    /opt/iobroker/iobroker-data/files
                                        49M     /opt/iobroker/iobroker-data/backup-objects
                                        48M     /opt/iobroker/iobroker-data/files/javascript.admin
                                        32M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                                        12M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js.map
                                        7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map
                                        6.6M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.8083c40d.js.map
                                        6.2M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js
                                        USB-Devices by-id:
                                        /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_902fb787e3e7ed119668d7770b2af5ab-if00-port0
                                        /dev/serial/by-id/usb-BSC_Computer_GmbH_FAM-USB-515_AB7BBEHP-if00-port0
                                        *** ZigBee Settings ***
                                        HINT:
                                        Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                                        zigbee.X
                                        Extended Pan ID:
                                        *** MASKED ***
                                        Pan ID:
                                        *** MASKED ***
                                        Channel:
                                        *** MASKED ***
                                        Network Key:
                                        *** MASKED ***
                                        *** NodeJS-Installation ***
                                        /usr/bin/npm            10.8.2
                                        /usr/bin/npx            10.8.2
                                        nodejs:
                                          Installed: 20.18.1-1nodesource1
                                          Candidate: 20.18.1-1nodesource1
                                          Version table:
                                         *** 20.18.1-1nodesource1 1001
                                                500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                                             20.18.0-1nodesource1 1001
                                             20.17.0-1nodesource1 1001
                                             20.16.0-1nodesource1 1001
                                             20.15.1-1nodesource1 1001
                                             20.15.0-1nodesource1 1001
                                             20.14.0-1nodesource1 1001
                                             20.13.1-1nodesource1 1001
                                             20.13.0-1nodesource1 1001
                                             20.12.2-1nodesource1 1001
                                             20.12.1-1nodesource1 1001
                                             20.12.0-1nodesource1 1001
                                             20.11.1-1nodesource1 1001
                                             20.11.0-1nodesource1 1001
                                             20.10.0-1nodesource1 1001
                                             20.9.0-1nodesource1 1001
                                             20.8.1-1nodesource1 1001
                                             20.8.0-1nodesource1 1001
                                             20.7.0-1nodesource1 1001
                                             20.6.1-1nodesource1 1001
                                             20.6.0-1nodesource1 1001
                                             20.5.1-1nodesource1 1001
                                             20.5.0-1nodesource1 1001
                                             20.4.0-1nodesource1 1001
                                             20.3.1-1nodesource1 1001
                                             20.3.0-1nodesource1 1001
                                             20.2.0-1nodesource1 1001
                                             20.1.0-1nodesource1 1001
                                             20.0.0-1nodesource1 1001
                                             12.22.12~dfsg-1~deb11u5 500
                                        No problems detected
                                        Errors in npm tree: 0
                                        *** ioBroker-Installation ***
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Hosts:
                                        iobroker-pi         iobroker-pi (version: 7.0.6, hostname: iobroker-pi   , alive, uptime: 673253)
                                        Core adapters versions
                                        admin:          7.1.5
                                        javascript:     6.0.3
                                        nodejs modules from github:     0
                                        Adapter State
                                        + system.adapter.backitup.0               : backitup              : iobroker-pi                              -  enabled
                                          system.adapter.daswetter.0              : daswetter             : iobroker-pi                              -  enabled
                                          system.adapter.discovery.0              : discovery             : iobroker-pi                              -  enabled
                                        + system.adapter.fronius.0                : fronius               : iobroker-pi                              -  enabled
                                          system.adapter.history.0                : history               : iobroker-pi                              -  enabled
                                        + system.adapter.hm-rega.1                : hm-rega               : iobroker-pi                              -  enabled
                                        + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-pi                              -  enabled, port: 0
                                        + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-pi                              -  enabled, port: 18701
                                        + system.adapter.javascript.0             : javascript            : iobroker-pi                              -  enabled
                                          system.adapter.modbus.0                 : modbus                : iobroker-pi                              - disabled
                                        + system.adapter.mqtt-client.0            : mqtt-client           : iobroker-pi                              -  enabled, port: 1883
                                        + system.adapter.ping.0                   : ping                  : iobroker-pi                              -  enabled
                                        + system.adapter.rpi2.0                   : rpi2                  : iobroker-pi                              -  enabled
                                          system.adapter.sayit.0                  : sayit                 : iobroker-pi                              -  enabled
                                        + system.adapter.shelly.0                 : shelly                : iobroker-pi                              -  enabled, port: 1882, bind: 0.0.0.0
                                        + system.adapter.smartmeter.0             : smartmeter            : iobroker-pi                              -  enabled
                                        + system.adapter.sonoff.0                 : sonoff                : iobroker-pi                              -  enabled, port: 1883, bind: 0.0.0.0
                                        + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker-pi                              -  enabled
                                        + system.adapter.terminal.0               : terminal              : iobroker-pi                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                                        + system.adapter.velux.0                  : velux                 : iobroker-pi                              -  enabled
                                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker-pi                              -  enabled
                                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker-pi                              -  enabled
                                          system.adapter.vis.0                    : vis                   : iobroker-pi                              -  enabled
                                        + system.adapter.zigbee.0                 : zigbee                : iobroker-pi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_902fb787e3e7ed119668d7770b2af5ab-if00-port0
                                        + instance is alive
                                        ioBroker-Repositories
                                        Active repo(s): stable
                                        Installed ioBroker-Instances
                                        Used repository: stable
                                        Adapter    "admin"        : 7.4.10   , installed 7.1.5  [Updatable]
                                        Adapter    "backitup"     : 3.0.31   , installed 2.4.12 [Updatable]
                                        Adapter    "daswetter"    : 3.2.2    , installed 3.1.3  [Updatable]
                                        Adapter    "discovery"    : 5.0.0    , installed 3.0.5  [Updatable]
                                        Adapter    "fronius"      : 2.1.1    , installed 2.0.2  [Updatable]
                                        Adapter    "history"      : 3.0.1    , installed 2.2.0  [Updatable]
                                        Adapter    "hm-rega"      : 5.1.0    , installed 3.0.40 [Updatable]
                                        Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.12 [Updatable]
                                        Adapter    "javascript"   : 8.8.3    , installed 6.0.3  [Updatable]
                                        Controller "js-controller": 7.0.6    , installed 7.0.6
                                        Adapter    "modbus"       : 6.3.2    , installed 5.0.11 [Updatable]
                                        Adapter    "mqtt-client"  : 2.1.0    , installed 2.1.0
                                        Adapter    "ping"         : 1.6.2    , installed 1.5.3  [Updatable]
                                        Adapter    "plenticore"   : 2.2.0    , installed 2.2.0
                                        Adapter    "rpi2"         : 2.2.1    , installed 1.3.2  [Updatable]
                                        Adapter    "sayit"        : 5.0.0    , installed 1.12.3 [Updatable]
                                        Adapter    "shelly"       : 8.5.1    , installed 8.2.1  [Updatable]
                                        Adapter    "simple-api"   : 2.8.0    , installed 2.7.1  [Updatable]
                                        Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                                        Adapter    "socketio"     : 6.7.1    , installed 4.2.0  [Updatable]
                                        Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
                                        Adapter    "tankerkoenig" : 3.4.0    , installed 2.1.1  [Updatable]
                                        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                                        Adapter    "velux"        : 0.0.8    , installed 0.0.7  [Updatable]
                                        Adapter    "vis"          : 1.5.6    , installed 1.4.15 [Updatable]
                                        Adapter    "vis-hqwidgets": 1.5.1    , installed 1.3.0  [Updatable]
                                        Adapter    "web"          : 6.2.5    , installed 4.3.0  [Updatable]
                                        Adapter    "ws"           : 2.6.2    , installed 1.3.0  [Updatable]
                                        Adapter    "zigbee"       : 1.10.14  , installed 1.10.13 [Updatable]
                                        Objects and States
                                        Objects:        9605
                                        States:         8668
                                        Pending Updates: 0
                                        *** Listening Ports ***
                                        tcp        0      0 192.168.178.50:18701    0.0.0.0:*               LISTEN      1001       1161594    6723/io.hm-rpc.1
                                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       1264871    20308/io.sonoff.0
                                        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       1160161    6800/io.shelly.0
                                        tcp        0      0 192.168.178.50:2010     0.0.0.0:*               LISTEN      1001       1159103    6518/io.hm-rpc.0
                                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16436      968/sshd: /usr/sbin
                                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1158040    6374/iobroker.js-co
                                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1158045    6374/iobroker.js-co
                                        tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          14656      1013/dnsmasq
                                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1160707    6397/io.admin.0
                                        tcp6       0      0 :::8088                 :::*                    LISTEN      1001       1161918    7217/io.terminal.0
                                        tcp6       0      0 :::22                   :::*                    LISTEN      0          16438      968/sshd: /usr/sbin
                                        udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          14655      1013/dnsmasq
                                        udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          14652      1013/dnsmasq
                                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12249      808/dhclient
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11089      406/avahi-daemon: r
                                        udp        0      0 0.0.0.0:38251           0.0.0.0:*                           108        11091      406/avahi-daemon: r
                                        udp6       0      0 :::5353                 :::*                                108        11090      406/avahi-daemon: r
                                        udp6       0      0 :::35121                :::*                                108        11092      406/avahi-daemon: r
                                        2025-01-11 16:13:12.167  - info: host.iobroker-pi instance system.adapter.velux.0 in version "0.0.7" started with pid 31891
                                        2025-01-11 16:13:14.688  - info: velux.0 (31891) starting. Version 0.0.7 in /opt/iobroker/node_modules/iobroker.velux, node: v20.18.1, js-controller: 7.0.6
                                        2025-01-11 16:13:14.999  - error: velux.0 (31891) null
                                        2025-01-11 16:13:15.004  - error: velux.0 (31891) Login was not successful
                                        2025-01-11 16:15:54.022  - info: host.iobroker-pi instance system.adapter.daswetter.0 in version "3.1.3" started with pid 32127
                                        2025-01-11 16:15:56.927  - info: daswetter.0 (32127) starting. Version 3.1.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.1, js-controller: 7.0.6
                                        2025-01-11 16:16:11.263  - info: daswetter.0 (32127) still wrong data structure from server received! repaired...
                                        2025-01-11 16:16:15.476  - info: daswetter.0 (32127) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                                        2025-01-11 16:16:15.997  - info: daswetter.0 (32127) cleaned everything up...
                                        2025-01-11 16:16:16.015  - info: host.iobroker-pi instance system.adapter.daswetter.0 having pid 32127 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        2025-01-11 16:30:54.025  - info: host.iobroker-pi instance system.adapter.daswetter.0 in version "3.1.3" started with pid 899
                                        2025-01-11 16:30:56.939  - info: daswetter.0 (899) starting. Version 3.1.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.1, js-controller: 7.0.6
                                        2025-01-11 16:31:11.118  - info: daswetter.0 (899) still wrong data structure from server received! repaired...
                                        2025-01-11 16:31:15.240  - info: daswetter.0 (899) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                                        2025-01-11 16:31:15.755  - info: daswetter.0 (899) cleaned everything up...
                                        2025-01-11 16:31:15.772  - info: host.iobroker-pi instance system.adapter.daswetter.0 having pid 899 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        2025-01-11 16:45:54.020  - info: host.iobroker-pi instance system.adapter.daswetter.0 in version "3.1.3" started with pid 3933
                                        2025-01-11 16:45:56.966  - info: daswetter.0 (3933) starting. Version 3.1.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.1, js-controller: 7.0.6
                                        2025-01-11 16:46:11.024  - info: daswetter.0 (3933) still wrong data structure from server received! repaired...
                                        2025-01-11 16:46:15.423  - info: daswetter.0 (3933) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                                        2025-01-11 16:46:15.941  - info: daswetter.0 (3933) cleaned everything up...
                                        2025-01-11 16:46:15.958  - info: host.iobroker-pi instance system.adapter.daswetter.0 having pid 3933 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        2025-01-11 16:51:25.964  - info: admin.0 (6397) Request actual repository...
                                        2025-01-11 16:51:26.593  - info: host.iobroker-pi Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                                        2025-01-11 16:51:31.666  - info: admin.0 (6397) Repository received successfully.
                                        • D Dschones
                                          *** BASE SYSTEM ***
                                                   Icon name: computer
                                                Architecture: arm
                                          Docker          : false
                                          Kernel          : armv7l
                                          Userland        : 32 bit
                                          CPU threads: 4
                                          Current issues:
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          pi
                                          HOME=/home/pi
                                          iobroker
                                          HOME=/home/iobroker
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Swap:            99M          0B         99M
                                                   3887 M total memory
                                                   1106 M used memory
                                                    464 M active memory
                                                   1799 M free memory
                                                    113 M buffer memory
                                                    868 M swap cache
                                                     99 M total swap
                                                      0 M used swap
                                                     99 M free swap
                                          *** FILESYSTEM ***
                                          /var:
                                          3.3G    /var/
                                          1.9G    /var/log
                                          755M    /var/cache
                                          USB-Devices by-id:
                                          HINT:
                                          zigbee.X
                                          Extended Pan ID:
                                          *** MASKED ***
                                          Pan ID:
                                          *** MASKED ***
                                          Channel:
                                          *** MASKED ***
                                          Network Key:
                                          *** MASKED ***
                                          /usr/bin/npm            10.8.2
                                          /usr/bin/npx            10.8.2
                                          nodejs:
                                            Version table:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Hosts:
                                          admin:          7.1.5
                                          javascript:     6.0.3
                                          Adapter State
                                          + instance is alive
                                          Objects and States
                                          Objects:        9605
                                          States:         8668
                                          Pending Updates: 0
                                          Meister Mopper
                                          @dschones
                                          Ich würde die vielen Adapter-Upgrades durchführen, eine backitup-Sicherung durchführen und diese extern sichern. Anschließend würde ich das System mit dem aktuellen Debian 12.9 neu aufsetzen (wie oben beschrieben).
                                          Alles andere ist vermeidbare Mehrarbeit.
                                          Danach kann man das Zigbee-Problem angehen.
                                          Proxmox und HA ...
