  4. Problem beim Aktualisieren des Admin Adapters
    6.8k
Geplant Angeheftet Gesperrt Verschoben Ungelöst ioBroker Allgemein
32 Beiträge 5 Kommentatoren 3.5k Aufrufe 4 Beobachtet
  • E Ecopilot
    @thomas-braun said in Problem beim Aktualisieren des Admin Adapters:
    Im jetzigen System:
    raik@raspberrypi:~ $ iob update
    Used repository: stable
    Adapter    "admin"        : 7.1.5    , installed 5.3.8  [Updatable]
    Adapter    "backitup"     : 3.0.25   , installed 2.4.6  [Updatable]
    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
    Adapter    "fritzbox"     : 0.6.0    , installed 0.2.1  [Updatable]
    Adapter    "fronius"      : 2.1.1    , installed 1.1.3  [Updatable]
    Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.12 [Updatable]
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "javascript"   : 8.8.3    , installed 5.2.21 [Updatable]
    Controller "js-controller": 7.0.6    , installed 4.0.23 [Updatable]
    Adapter    "mqtt"         : 6.1.2    , installed 2.1.14 [Updatable]
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    raik@raspberrypi:~ $ iob upgrade all -y
    Update admin from @5.3.8 to @7.1.5
    Cannot upgrade: Cannot read properties of undefined (reading 'enabled')
    @ecopilot
    Das kommt halt davon, wenn man da alles versumpfen lässt...
    iob stop
    cd /opt/iobroker
    npm install iobroker.js-controller@5.0.0 --omit=dev
    npm install iobroker.js-controller@6.0.0 --omit=dev
    npm install iobroker.js-controller@7.0.0 --omit=dev
    iob update
    iob upgrade self
    E 1 Antwort Letzte Antwort
      @ecopilot
      iob stop
      cd /opt/iobroker
      iob update
      iob upgrade self
      Ecopilot
      iob upgrade self
      raik@raspberrypi:~ $ iob stop
      raik@raspberrypi:~ $ cd /opt/iobroker
      raik@raspberrypi:/opt/iobroker $ npm install iobroker.js-controller@5.0.0 --omit=dev
      npm error code ETARGET
      npm error notarget No matching version found for iobroker.js-controller@5.0.0.
      npm error notarget In most cases you or one of your dependencies are requesting
      npm error notarget a package version that doesn't exist.
      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-12-29T21_48_50_900Z-debug-0.log
      raik@raspberrypi:/opt/iobroker $ npm install iobroker.js-controller@5.0.17 --omit=dev
      added 15 packages, removed 5 packages, and changed 16 packages in 37s
      72 packages are looking for funding
        run `npm fund` for details
      raik@raspberrypi:/opt/iobroker $ npm install iobroker.js-controller@6.0.0 --omit=dev
      removed 33 packages, and changed 14 packages in 33s
      raik@raspberrypi:/opt/iobroker $ npm install iobroker.js-controller@7.0.0 --omit=dev
      added 2 packages, removed 2 packages, and changed 14 packages in 31s
      raik@raspberrypi:/opt/iobroker $ iob update
      Controller "js-controller": 7.0.6    , installed 7.0.0  [Updatable]
      raik@raspberrypi:/opt/iobroker $ iob upgrade self
      Update js-controller from @7.0.0 to @7.0.6
      Stopped Objects DB
      Stopped States DB
      NPM version: 10.8.2
      Installing iobroker.js-controller@7.0.6... (System call)
      changed 12 packages in 27s
      • E Ecopilot
        iob upgrade self
        Stopped Objects DB
        Stopped States DB
        NPM version: 10.8.2
        @ecopilot
        Dann schau jetzt mal ob du die einzelnen Adapter nachgezogen bekommst.
          @ecopilot
          Ecopilot
          Nee, das gleiche Problem besteht immer noch.
          raik@raspberrypi:/opt/iobroker $ iob upgrade all -y
          • E Ecopilot
            @ecopilot
            Mach es einzeln, den admin dann als letzten.
            • E Ecopilot
              iob upgrade self
              Stopped Objects DB
              Stopped States DB
              NPM version: 10.8.2
              @ecopilot sagte in Problem beim Aktualisieren des Admin Adapters:
              Da liegt der controller v5.0.0 wohl nicht mehr auf npm
                @ecopilot
                Ecopilot
                Das funktioniert nicht, da werden Abhängigkeiten beanstandet.
                raik@raspberrypi:/opt/iobroker $ iob upgrade fronius
                Cannot check dependencies: Invalid version of "admin". Installed "5.3.8", required ">=6.13.16
                • E Ecopilot
                  @ecopilot
                  Dependency hell.
                  Handelt man sich ein, wenn das Ding nie Updates bekommt....
                  iob upgrade admin@6.13.16 --omit=dev
                    @ecopilot
                    Dependency hell.
                    Ecopilot
                    Es läuft immer wieder auf das Problem mit den nicht lesbaren Eigenschaften hinaus.
                    raik@raspberrypi:/opt/iobroker $ iob upgrade admin@6.13.16 --omit=dev
                    BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                    Would you like to upgrade admin from @5.3.8 to @6.13.16 now? [(y)es, (n)o]: y
                    Update admin from @5.3.8 to @6.13.16
                    • E Ecopilot
                      @ecopilot
                      Da sind ja noch mehr Adapter. Versuch die nacheinander hochzuziehen.
                      E 2 Antworten Letzte Antwort
                        @ecopilot
                        Ecopilot
                        Ich muss jetzt erst mal in die Horizontale... ich mache morgen an der Stelle weiter....
                        Danke erst mal für Deine Bemühungen. 👍
                          mcm1957M Online
                          mcm1957M Online
                          mcm1957
                          @homoran said in Problem beim Aktualisieren des Admin Adapters:
                          5.0.19 ist der letzte aktuelle 5er.
                          Ob 5.0.0 jemals online ging kann ich mich nicht erinnern. Beim schrittweisen hochpäppeln sollte man immer die aktualleste Version der jeweiligen major nehmen da die ersten Versionen einer Major durchaus fehlerhaft sein können.
                          Support Repositoryverwaltung.
                          LESEN - gute Forenbeitrage
                          • E Ecopilot
                            Ecopilot
                            schrieb am zuletzt editiert von Ecopilot
                            @ecopilot
                            ich habe jetzt mal alle Adapter, bei denen es funktioniert, schrittweise bis auf die Sollversion hoch gezogen.
                            Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
                            Adapter    "fronius"      : 2.1.1    , installed 2.1.1
                            Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                            Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                            Controller "js-controller": 7.0.6    , installed 7.0.6
                            Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                            Nur der "Admin" und der "Backitup" lassen sich nicht updaten. Da kommt immer wieder der Fehler mit den nicht lesbaren Eigenschaften.
                            raik@raspberrypi:/opt/iobroker $ iob upgrade backitup@2.11.0
                            Would you like to upgrade backitup from @2.4.6 to @2.11.0 now? [(y)es, (n)o]: y
                            Update backitup from @2.4.6 to @2.11.0
                            raik@raspberrypi:/opt/iobroker $ iob upgrade backitup@2.4.16
                            Would you like to upgrade backitup from @2.4.6 to @2.4.16 now? [(y)es, (n)o]: y
                            Update backitup from @2.4.6 to @2.4.16
                            raik@raspberrypi:/opt/iobroker $ iob upgrade admin@5.4.9
                            Would you like to upgrade admin from @5.3.8 to @5.4.9 now? [(y)es, (n)o]: y
                            Update admin from @5.3.8 to @5.4.9
                            Wie bekommt man das jetzt weg?
                              @ecopilot
                              Ecopilot
                              Gibt es irgendwo ein log, wo man sieht, was da nicht lesbar ist? Die Meldung an sich ist nicht besonders aussagefähig.
                              Oder bringt es was, die beiden Adapter über npm hoch zu ziehen?
                              Das wird zwar vermutlich nicht das Grundlegende Problem lösen, aber das System wäre erst mal wieder lauffähig. Oder bin ich da auf dem Holzweg?
                              mcm1957M HomoranH 2 Antworten Letzte Antwort
                              • E Ecopilot
                                mcm1957M Online
                                mcm1957M Online
                                mcm1957
                                @foxriver76
                                @apollon77
                                @Bluefox
                                Habt ihr ne Idee insbesondere auch was ein allfälliger aussagekräftigeres Log betrifft?
                                • E Ecopilot
                                  @ecopilot hast du es mal mit dem --debug Flag versucht?
                                  also iob ugrade adapterName --debug?
                                    Ecopilot
                                    Ja, da kommt auch nicht mehr.
                                    raik@raspberrypi:~ $ iob upgrade admin@6.13.16 --debug
                                    • E Ecopilot
                                      @ecopilot Danke.
                                      Ich würde es jetzt mit einer Neuinstallation (ggf. Downgrade des Controllers) und dem Restore des aktuellsten Backups versuchen.
                                      Dürfte letztendlich schneller gehen.
                                        @ecopilot Danke.
                                        Ecopilot
                                        @Thomas-Braun
                                        @mcm1957
                                        Ich habe die beiden störrischen Adapter jetzt erst mal per npm hochgezogen und jetzt funktioniert das System erst mal wieder auf neustem Stand. Beim nächsten Update wird es dann sicher wieder das gleiche Problem geben. Vlt. hat bis dahin jemand eine Idee, wie da eine bessere Diagnose möglich ist. Jetzt ist auch etwas Zeit, um das System dann mal mit Version 12 (bookworm) neu aufzusetzen.
                                        Euch vielen Dank für die Unterstützung und einen guten Rutsch.
