  4. Problem beim Aktualisieren des Admin Adapters
    6.8k
Geplant Angeheftet Gesperrt Verschoben Ungelöst ioBroker Allgemein
32 Beiträge 5 Kommentatoren 3.5k Aufrufe 4 Beobachtet
  • E Ecopilot
    In welchem Zustand mit der 7.0.6?
    @ecopilot
    Im jetzigen Zustand. Damit man mal sieht was da überhaupt gerade Phase ist.
    E 1 Antwort Letzte Antwort
      @ecopilot
      Ecopilot
      Das ist die Ausgabe von iob diag im aktuellen funktionierenden Zustand mit der 4.0.23.
      Script v.2024-10-19
      *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 4 Model B Rev 1.5
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       22:18:03 up 1 day,  3:36,  2 users,  load average: 0.92, 0.45, 0.31
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Sun 2024-12-29 22:18:03 CET
                 Universal time: Sun 2024-12-29 21:18:03 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      raik
      HOME=/home/raik
      GROUPS=raik adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            3.8G        922M        1.5G        0.0K        1.4G        2.8G
      Swap:            99M          0B         99M
      Total:          3.9G        922M        1.6G
      Active iob-Instances:   16
               3793 M total memory
                923 M used memory
               1091 M active memory
                989 M inactive memory
               1494 M free memory
                446 M buffer memory
                929 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      top - 22:18:04 up 1 day,  3:36,  2 users,  load average: 0.92, 0.45, 0.31
      Tasks: 169 total,   1 running, 168 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  1.4 us,  2.9 sy,  0.0 ni, 95.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3793.3 total,   1494.2 free,    922.9 used,   1376.2 buff/cache
      MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2794.2 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      /dev/root      ext4       29G  5.8G   23G  21% /
      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
      tmpfs          tmpfs     759M  848K  758M   1% /run
      /dev/sda3      fuseblk    90G  767M   89G   1% /media/Daten
      /dev/sda1      vfat      255M   31M  225M  13% /boot
      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
      [Sat Dec 28 18:41:58 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:A8:7A:E0 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=04937d0c-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Sat Dec 28 18:42:00 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Sat Dec 28 18:42:00 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Sat Dec 28 18:42:02 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
      Show mounted filesystems:
      TARGET         SOURCE    FSTYPE  OPTIONS
      /              /dev/sda2 ext4    rw,noatime
      |-/media/Daten /dev/sda3 fuseblk rw,relatime,user_id=0,group_id=0,allow_other,blksize=4096
      `-/boot        /dev/sda1 vfat    rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      /var:
      2.0G    /var/
      1.3G    /var/log/journal/ed031130534d46b5a0be8a8e1b815909
      1.3G    /var/log
      468M    /var/cache
      Archived and active journals take up 1.2G in the file system.
      /opt/iobroker/backups:
      50M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      385M    /opt/iobroker/iobroker-data/
      331M    /opt/iobroker/iobroker-data/files
      78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
      67M     /opt/iobroker/iobroker-data/files/echarts.admin
      61M     /opt/iobroker/iobroker-data/files/echarts
      26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
      26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.70a15e1f.js.map
      18M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.5fe9c7da.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.18.1
      /usr/bin/node           v20.18.1
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.4
      nodejs:
        Installed: 20.18.1-1nodesource1
        Candidate: 20.18.1-1nodesource1
        Version table:
       *** 20.18.1-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u5 500
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
           12.22.12~dfsg-1~deb11u4 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      raspberrypi         raspberrypi (version: 4.0.23, hostname: raspberrypi   , alive, uptime: 41522)
      Core adapters versions
      js-controller:  4.0.23
      admin:          5.3.8
      javascript:     5.2.21
      nodejs modules from github:     0
      Adapter State
      + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
      + system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              -  enabled
      + system.adapter.fronius.0                : fronius               : raspberrypi                              -  enabled
      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 18701
      + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 12001
      + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 12010
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.vis-history.0            : vis-history           : raspberrypi                              -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              -  enabled
        system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 7.1.5    , installed 5.3.8  [Updatable]
      Adapter    "backitup"     : 3.0.25   , installed 2.4.6  [Updatable]
      Adapter    "echarts"      : 1.9.2    , installed 1.9.2
      Adapter    "fritzbox"     : 0.6.0    , installed 0.2.1  [Updatable]
      Adapter    "fronius"      : 2.1.1    , installed 1.1.3  [Updatable]
      Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.12 [Updatable]
      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
      Adapter    "javascript"   : 8.8.3    , installed 5.2.21 [Updatable]
      Controller "js-controller": 7.0.6    , installed 4.0.23 [Updatable]
      Adapter    "mqtt"         : 6.1.2    , installed 2.1.14 [Updatable]
      Adapter    "web"          : 6.2.5    , installed 6.2.5
      Objects and States
      Objects:        3317
      States:         2076
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:18701           0.0.0.0:*               LISTEN      1001       292985     28745/io.hm-rpc.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14735      534/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       291610     28935/io.mqtt.0
      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       291611     28935/io.mqtt.0
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       291372     28667/iobroker.js-c
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       291367     28667/iobroker.js-c
      tcp        0      0 0.0.0.0:12010           0.0.0.0:*               LISTEN      1001       292622     28778/io.hm-rpc.2
      tcp        0      0 0.0.0.0:12001           0.0.0.0:*               LISTEN      1001       293019     28763/io.hm-rpc.1
      tcp6       0      0 :::22                   :::*                    LISTEN      0          14737      534/sshd: /usr/sbin
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       292923     28685/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       293358     29370/io.web.0
      udp        0      0 0.0.0.0:57884           0.0.0.0:*                           108        13536      393/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13534      393/avahi-daemon: r
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12254      693/dhcpcd
      udp6       0      0 :::41843                :::*                                108        13537      393/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        13535      393/avahi-daemon: r
      2024-12-29 20:52:50.229  - info: web.0 (29370) <== Disconnect system.user.admin from ::ffff:192.168.178.50 vis.0
      2024-12-29 20:52:55.287  - info: web.0 (29370) ==> Connected system.user.admin from ::ffff:192.168.178.50
      2024-12-29 20:54:13.638  - info: mqtt.0 (28935) Client [2] connected with secret 1735502053636_64
      2024-12-29 20:54:13.657  - info: mqtt.0 (28935) Client [2] subscribes on "mqtt.0.Zisterne.Modus"
      2024-12-29 20:54:38.711  - info: mqtt.0 (28935) Client [2] connection closed: timeout
      2024-12-29 21:08:52.135  - info: mqtt.0 (28935) Client [2] connected with secret 1735502932133_1808
      2024-12-29 21:08:52.158  - info: mqtt.0 (28935) Client [2] subscribes on "mqtt.0.Zisterne.Modus"
      2024-12-29 21:09:17.830  - info: mqtt.0 (28935) Client [2] connection closed: timeout
      2024-12-29 21:18:10.201  - info: web.0 (29370) ==> Connected system.user.admin from ::ffff:192.168.178.50
      2024-12-29 21:18:11.280  - info: web.0 (29370) <== Disconnect system.user.admin from ::ffff:192.168.178.50 vis.0
      2024-12-29 21:23:30.565  - info: mqtt.0 (28935) Client [2] connected with secret 1735503810564_9974
      2024-12-29 21:23:30.588  - info: mqtt.0 (28935) Client [2] subscribes on "mqtt.0.Zisterne.Modus"
      2024-12-29 21:23:55.687  - info: mqtt.0 (28935) Client [2] connection closed: timeout
      2024-12-29 21:32:53.598  - error: hm-rpc.0 (28745) Ping error [raspberrypi:hm-rpc.0:2597ee68cadec398d13f29e3977d2fda]: response timeout
      2024-12-29 21:32:53.601  - info: hm-rpc.0 (28745) Disconnected
      2024-12-29 21:32:54.085  - info: hm-rpc.0 (28745) Connected
      2024-12-29 21:38:09.299  - info: mqtt.0 (28935) Client [2] connected with secret 1735504689297_533
      2024-12-29 21:38:09.320  - info: mqtt.0 (28935) Client [2] subscribes on "mqtt.0.Zisterne.Modus"
      2024-12-29 21:38:34.806  - info: mqtt.0 (28935) Client [2] connection closed: timeout
      2024-12-29 21:52:48.588  - info: mqtt.0 (28935) Client [2] connected with secret 1735505568587_867
      2024-12-29 21:52:48.608  - info: mqtt.0 (28935) Client [2] subscribes on "mqtt.0.Zisterne.Modus"
      2024-12-29 21:53:13.925  - info: mqtt.0 (28935) Client [2] connection closed: timeout
      2024-12-29 22:07:26.562  - info: mqtt.0 (28935) Client [2] connected with secret 1735506446561_3595
      2024-12-29 22:07:26.585  - info: mqtt.0 (28935) Client [2] subscribes on "mqtt.0.Zisterne.Modus"
      2024-12-29 22:07:51.783  - info: mqtt.0 (28935) Client [2] connection closed: timeout
      • E Ecopilot
        Script v.2024-10-19
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
        OS is similar to:
        Docker          : false
        Kernel          : aarch64
        Userland        : 64 bit
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        raik
        HOME=/home/raik
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            99M          0B         99M
                 3793 M total memory
                  923 M used memory
                 1494 M free memory
                  446 M buffer memory
                  929 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        *** FILESYSTEM ***
        /var:
        2.0G    /var/
        1.3G    /var/log
        468M    /var/cache
        USB-Devices by-id:
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin:          5.3.8
        javascript:     5.2.21
        Adapter State
        + instance is alive
        Objects and States
        Objects:        3317
        States:         2076
        Pending Updates: 0
        @ecopilot sagte in Problem beim Aktualisieren des Admin Adapters:
        Kannste schon mal auf Version 12 (bookworm) bringen --> Per NEUINSTALLATION.
        Im jetzigen System:
        iob update
        iob upgrade all -y
          Im jetzigen System:
          iob update
          iob upgrade all -y
          Ecopilot
          @thomas-braun said in Problem beim Aktualisieren des Admin Adapters:
          Im jetzigen System:
          raik@raspberrypi:~ $ iob update
          raik@raspberrypi:~ $ iob upgrade all -y
          Update admin from @5.3.8 to @7.1.5
          Cannot upgrade: Cannot read properties of undefined (reading 'enabled')
          • E Ecopilot
            Im jetzigen System:
            @ecopilot
            Das kommt halt davon, wenn man da alles versumpfen lässt...
            iob stop
            cd /opt/iobroker
            npm install iobroker.js-controller@5.0.0 --omit=dev
            npm install iobroker.js-controller@6.0.0 --omit=dev
            npm install iobroker.js-controller@7.0.0 --omit=dev
            iob update
            iob upgrade self
              @ecopilot
              iob stop
              cd /opt/iobroker
              iob update
              iob upgrade self
              Ecopilot
              iob upgrade self
              raik@raspberrypi:~ $ iob stop
              raik@raspberrypi:~ $ cd /opt/iobroker
              raik@raspberrypi:/opt/iobroker $ npm install iobroker.js-controller@5.0.0 --omit=dev
              npm error code ETARGET
              npm error notarget No matching version found for iobroker.js-controller@5.0.0.
              npm error notarget In most cases you or one of your dependencies are requesting
              npm error notarget a package version that doesn't exist.
              npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-12-29T21_48_50_900Z-debug-0.log
              raik@raspberrypi:/opt/iobroker $ npm install iobroker.js-controller@5.0.17 --omit=dev
              added 15 packages, removed 5 packages, and changed 16 packages in 37s
              72 packages are looking for funding
                run `npm fund` for details
              raik@raspberrypi:/opt/iobroker $ npm install iobroker.js-controller@6.0.0 --omit=dev
              removed 33 packages, and changed 14 packages in 33s
              raik@raspberrypi:/opt/iobroker $ npm install iobroker.js-controller@7.0.0 --omit=dev
              added 2 packages, removed 2 packages, and changed 14 packages in 31s
              raik@raspberrypi:/opt/iobroker $ iob update
              Controller "js-controller": 7.0.6    , installed 7.0.0  [Updatable]
              raik@raspberrypi:/opt/iobroker $ iob upgrade self
              Update js-controller from @7.0.0 to @7.0.6
              Stopped Objects DB
              Stopped States DB
              NPM version: 10.8.2
              Installing iobroker.js-controller@7.0.6... (System call)
              changed 12 packages in 27s
              • E Ecopilot
                iob upgrade self
                Stopped Objects DB
                Stopped States DB
                NPM version: 10.8.2
                @ecopilot
                Dann schau jetzt mal ob du die einzelnen Adapter nachgezogen bekommst.
                  @ecopilot
                  Ecopilot
                  Nee, das gleiche Problem besteht immer noch.
                  raik@raspberrypi:/opt/iobroker $ iob upgrade all -y
                  • E Ecopilot
                    @ecopilot
                    Mach es einzeln, den admin dann als letzten.
                    • E Ecopilot
                      iob upgrade self
                      Stopped Objects DB
                      Stopped States DB
                      NPM version: 10.8.2
                      Da liegt der controller v5.0.0 wohl nicht mehr auf npm
                        @ecopilot
                        Ecopilot
                        Das funktioniert nicht, da werden Abhängigkeiten beanstandet.
                        raik@raspberrypi:/opt/iobroker $ iob upgrade fronius
                        Cannot check dependencies: Invalid version of "admin". Installed "5.3.8", required ">=6.13.16
                        • E Ecopilot
                          @ecopilot
                          Dependency hell.
                          Handelt man sich ein, wenn das Ding nie Updates bekommt....
                          iob upgrade admin@6.13.16 --omit=dev
                            @ecopilot
                            Dependency hell.
                            Ecopilot
                            Es läuft immer wieder auf das Problem mit den nicht lesbaren Eigenschaften hinaus.
                            raik@raspberrypi:/opt/iobroker $ iob upgrade admin@6.13.16 --omit=dev
                            BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                            Would you like to upgrade admin from @5.3.8 to @6.13.16 now? [(y)es, (n)o]: y
                            Update admin from @5.3.8 to @6.13.16
                            • E Ecopilot
                              @ecopilot
                              Da sind ja noch mehr Adapter. Versuch die nacheinander hochzuziehen.
                              E 2 Antworten Letzte Antwort
                                @ecopilot
                                Ecopilot
                                Ich muss jetzt erst mal in die Horizontale... ich mache morgen an der Stelle weiter....
                                Danke erst mal für Deine Bemühungen. 👍
                                  mcm1957M Online
                                  mcm1957M Online
                                  mcm1957
                                  @homoran said in Problem beim Aktualisieren des Admin Adapters:
                                  5.0.19 ist der letzte aktuelle 5er.
                                  Ob 5.0.0 jemals online ging kann ich mich nicht erinnern. Beim schrittweisen hochpäppeln sollte man immer die aktualleste Version der jeweiligen major nehmen da die ersten Versionen einer Major durchaus fehlerhaft sein können.
                                  Support Repositoryverwaltung.
                                  LESEN - gute Forenbeitrage
                                  • E Ecopilot
                                    Ecopilot
                                    schrieb am zuletzt editiert von Ecopilot
                                    @ecopilot
                                    ich habe jetzt mal alle Adapter, bei denen es funktioniert, schrittweise bis auf die Sollversion hoch gezogen.
                                    Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
                                    Adapter    "fronius"      : 2.1.1    , installed 2.1.1
                                    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                                    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                                    Controller "js-controller": 7.0.6    , installed 7.0.6
                                    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                                    Nur der "Admin" und der "Backitup" lassen sich nicht updaten. Da kommt immer wieder der Fehler mit den nicht lesbaren Eigenschaften.
                                    raik@raspberrypi:/opt/iobroker $ iob upgrade backitup@2.11.0
                                    Would you like to upgrade backitup from @2.4.6 to @2.11.0 now? [(y)es, (n)o]: y
                                    Update backitup from @2.4.6 to @2.11.0
                                    raik@raspberrypi:/opt/iobroker $ iob upgrade backitup@2.4.16
                                    Would you like to upgrade backitup from @2.4.6 to @2.4.16 now? [(y)es, (n)o]: y
                                    Update backitup from @2.4.6 to @2.4.16
                                    raik@raspberrypi:/opt/iobroker $ iob upgrade admin@5.4.9
                                    Would you like to upgrade admin from @5.3.8 to @5.4.9 now? [(y)es, (n)o]: y
                                    Update admin from @5.3.8 to @5.4.9
                                    Wie bekommt man das jetzt weg?
                                      @ecopilot
                                      Ecopilot
                                      Gibt es irgendwo ein log, wo man sieht, was da nicht lesbar ist? Die Meldung an sich ist nicht besonders aussagefähig.
                                      Oder bringt es was, die beiden Adapter über npm hoch zu ziehen?
                                      Das wird zwar vermutlich nicht das Grundlegende Problem lösen, aber das System wäre erst mal wieder lauffähig. Oder bin ich da auf dem Holzweg?
                                      mcm1957M HomoranH 2 Antworten Letzte Antwort
                                      • E Ecopilot
                                        mcm1957M Online
                                        mcm1957M Online
                                        mcm1957
                                        @foxriver76
                                        @apollon77
                                        @Bluefox
                                        Habt ihr ne Idee insbesondere auch was ein allfälliger aussagekräftigeres Log betrifft?
                                        • E Ecopilot
                                          @ecopilot hast du es mal mit dem --debug Flag versucht?
                                          also iob ugrade adapterName --debug?
