  4. Problem beim Aktualisieren des Admin Adapters
    6.8k
Geplant Angeheftet Gesperrt Verschoben Ungelöst ioBroker Allgemein
32 Beiträge 5 Kommentatoren 3.5k Aufrufe 4 Beobachtet
  • E Ecopilot
    @thomas-braun said in Problem beim Aktualisieren des Admin Adapters:
    iob upgrade self
    raik@raspberrypi:~ $ iob stop
    raik@raspberrypi:~ $ cd /opt/iobroker
    raik@raspberrypi:/opt/iobroker $ npm install iobroker.js-controller@5.0.0 --omit=dev
    npm error code ETARGET
    npm error notarget No matching version found for iobroker.js-controller@5.0.0.
    npm error notarget In most cases you or one of your dependencies are requesting
    npm error notarget a package version that doesn't exist.
    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-12-29T21_48_50_900Z-debug-0.log
    raik@raspberrypi:/opt/iobroker $ npm install iobroker.js-controller@5.0.17 --omit=dev
    added 15 packages, removed 5 packages, and changed 16 packages in 37s
    72 packages are looking for funding
      run `npm fund` for details
    raik@raspberrypi:/opt/iobroker $ npm install iobroker.js-controller@6.0.0 --omit=dev
    removed 33 packages, and changed 14 packages in 33s
    raik@raspberrypi:/opt/iobroker $ npm install iobroker.js-controller@7.0.0 --omit=dev
    added 2 packages, removed 2 packages, and changed 14 packages in 31s
    raik@raspberrypi:/opt/iobroker $ iob update
    Used repository: stable
    Adapter    "admin"        : 7.1.5    , installed 5.3.8  [Updatable]
    Adapter    "backitup"     : 3.0.25   , installed 2.4.6  [Updatable]
    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
    Adapter    "fritzbox"     : 0.6.0    , installed 0.2.1  [Updatable]
    Adapter    "fronius"      : 2.1.1    , installed 1.1.3  [Updatable]
    Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.12 [Updatable]
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "javascript"   : 8.8.3    , installed 5.2.21 [Updatable]
    Controller "js-controller": 7.0.6    , installed 7.0.0  [Updatable]
    Adapter    "mqtt"         : 6.1.2    , installed 2.1.14 [Updatable]
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    raik@raspberrypi:/opt/iobroker $ iob upgrade self
    Update js-controller from @7.0.0 to @7.0.6
    Stopped Objects DB
    Stopped States DB
    NPM version: 10.8.2
    Installing iobroker.js-controller@7.0.6... (System call)
    changed 12 packages in 27s
    @ecopilot sagte in Problem beim Aktualisieren des Admin Adapters:
    Da liegt der controller v5.0.0 wohl nicht mehr auf npm
      @ecopilot
      Mach es einzeln, den admin dann als letzten.
      Ecopilot
      Das funktioniert nicht, da werden Abhängigkeiten beanstandet.
      raik@raspberrypi:/opt/iobroker $ iob upgrade fronius
      Cannot check dependencies: Invalid version of "admin". Installed "5.3.8", required ">=6.13.16
      • E Ecopilot
        @ecopilot
        Dependency hell.
        Handelt man sich ein, wenn das Ding nie Updates bekommt....
        iob upgrade admin@6.13.16 --omit=dev
        E 1 Antwort Letzte Antwort
          @ecopilot
          Dependency hell.
          Ecopilot
          Es läuft immer wieder auf das Problem mit den nicht lesbaren Eigenschaften hinaus.
          raik@raspberrypi:/opt/iobroker $ iob upgrade admin@6.13.16 --omit=dev
          BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
          Would you like to upgrade admin from @5.3.8 to @6.13.16 now? [(y)es, (n)o]: y
          Update admin from @5.3.8 to @6.13.16
          Cannot upgrade: Cannot read properties of undefined (reading 'enabled')
          • E Ecopilot
            @ecopilot
            Da sind ja noch mehr Adapter. Versuch die nacheinander hochzuziehen.
            E 2 Antworten Letzte Antwort
              @ecopilot
              Ecopilot
              Ich muss jetzt erst mal in die Horizontale... ich mache morgen an der Stelle weiter....
              Danke erst mal für Deine Bemühungen. 👍
                mcm1957M Online
                mcm1957M Online
                mcm1957
                @homoran said in Problem beim Aktualisieren des Admin Adapters:
                5.0.19 ist der letzte aktuelle 5er.
                Ob 5.0.0 jemals online ging kann ich mich nicht erinnern. Beim schrittweisen hochpäppeln sollte man immer die aktualleste Version der jeweiligen major nehmen da die ersten Versionen einer Major durchaus fehlerhaft sein können.
                Support Repositoryverwaltung.
                LESEN - gute Forenbeitrage
                • E Ecopilot
                  Ecopilot
                  schrieb am zuletzt editiert von Ecopilot
                  @ecopilot
                  ich habe jetzt mal alle Adapter, bei denen es funktioniert, schrittweise bis auf die Sollversion hoch gezogen.
                  Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
                  Adapter    "fronius"      : 2.1.1    , installed 2.1.1
                  Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                  Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                  Controller "js-controller": 7.0.6    , installed 7.0.6
                  Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                  Nur der "Admin" und der "Backitup" lassen sich nicht updaten. Da kommt immer wieder der Fehler mit den nicht lesbaren Eigenschaften.
                  raik@raspberrypi:/opt/iobroker $ iob upgrade backitup@2.11.0
                  Would you like to upgrade backitup from @2.4.6 to @2.11.0 now? [(y)es, (n)o]: y
                  Update backitup from @2.4.6 to @2.11.0
                  raik@raspberrypi:/opt/iobroker $ iob upgrade backitup@2.4.16
                  Would you like to upgrade backitup from @2.4.6 to @2.4.16 now? [(y)es, (n)o]: y
                  Update backitup from @2.4.6 to @2.4.16
                  raik@raspberrypi:/opt/iobroker $ iob upgrade admin@5.4.9
                  Would you like to upgrade admin from @5.3.8 to @5.4.9 now? [(y)es, (n)o]: y
                  Update admin from @5.3.8 to @5.4.9
                  Wie bekommt man das jetzt weg?
                    @ecopilot
                    Ecopilot
                    Gibt es irgendwo ein log, wo man sieht, was da nicht lesbar ist? Die Meldung an sich ist nicht besonders aussagefähig.
                    Oder bringt es was, die beiden Adapter über npm hoch zu ziehen?
                    Das wird zwar vermutlich nicht das Grundlegende Problem lösen, aber das System wäre erst mal wieder lauffähig. Oder bin ich da auf dem Holzweg?
                    mcm1957M HomoranH 2 Antworten Letzte Antwort
                    • E Ecopilot
                      mcm1957M Online
                      mcm1957M Online
                      mcm1957
                      @foxriver76
                      @apollon77
                      @Bluefox
                      Habt ihr ne Idee insbesondere auch was ein allfälliger aussagekräftigeres Log betrifft?
                      • E Ecopilot
                        @ecopilot hast du es mal mit dem --debug Flag versucht?
                        also iob ugrade adapterName --debug?
                          Ecopilot
                          Ja, da kommt auch nicht mehr.
                          raik@raspberrypi:~ $ iob upgrade admin@6.13.16 --debug
                          • E Ecopilot
                            @ecopilot Danke.
                            Ich würde es jetzt mit einer Neuinstallation (ggf. Downgrade des Controllers) und dem Restore des aktuellsten Backups versuchen.
                            Dürfte letztendlich schneller gehen.
                              @ecopilot Danke.
                              Ecopilot
                              @Thomas-Braun
                              @mcm1957
                              Ich habe die beiden störrischen Adapter jetzt erst mal per npm hochgezogen und jetzt funktioniert das System erst mal wieder auf neustem Stand. Beim nächsten Update wird es dann sicher wieder das gleiche Problem geben. Vlt. hat bis dahin jemand eine Idee, wie da eine bessere Diagnose möglich ist. Jetzt ist auch etwas Zeit, um das System dann mal mit Version 12 (bookworm) neu aufzusetzen.
                              Euch vielen Dank für die Unterstützung und einen guten Rutsch.
