  4. Test Adapter ta-blnet NPM/Latest"
42 Beiträge 7 Kommentatoren 8.4k Aufrufe 6 Beobachtet
    tomowner
    2024-12-23 10:43:43.129 - info: host.LenovoIObroker stopInstance system.adapter.ta-blnet.0 (force=false, process=true)
    2024-12-23 10:43:43.134 - info: ta-blnet.0 (9601) Got terminate signal TERMINATE_YOURSELF
    2024-12-23 10:43:43.135 - debug: ta-blnet.0 (9601) onUnload: Cleared orphan timeout.
    2024-12-23 10:43:43.135 - info: ta-blnet.0 (9601) terminating
    2024-12-23 10:43:43.136 - info: ta-blnet.0 (9601) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-12-23 10:43:43.226 - info: host.LenovoIObroker stopInstance system.adapter.ta-blnet.0 send kill signal
    2024-12-23 10:43:43.636 - info: ta-blnet.0 (9601) terminating
    2024-12-23 10:43:43.691 - info: host.LenovoIObroker instance system.adapter.ta-blnet.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-12-23 10:43:46.765 - info: easee.0 (9366) Token has expired - refresh
    2024-12-23 10:43:46.924 - info: easee.0 (9366) RefreshToken successful
    2024-12-23 10:43:47.086 - info: host.LenovoIObroker instance system.adapter.ta-blnet.0 in version "1.0.35" (non-npm: weberk/ioBroker.ta-blnet) started with pid 9660
    2024-12-23 10:43:47.927 - debug: ta-blnet.0 (9660) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2024-12-23 10:43:47.950 - debug: ta-blnet.0 (9660) Objects client ready ... initialize now
    2024-12-23 10:43:47.951 - debug: ta-blnet.0 (9660) Objects create System PubSub Client
    2024-12-23 10:43:47.951 - debug: ta-blnet.0 (9660) Objects create User PubSub Client
    2024-12-23 10:43:47.984 - debug: ta-blnet.0 (9660) Objects client initialize lua scripts
    2024-12-23 10:43:47.988 - debug: ta-blnet.0 (9660) Objects connected to redis: 127.0.0.1:9001
    2024-12-23 10:43:48.011 - debug: ta-blnet.0 (9660) Redis States: Use Redis connection: 127.0.0.1:9000
    2024-12-23 10:43:48.020 - debug: ta-blnet.0 (9660) States create System PubSub Client
    2024-12-23 10:43:48.021 - debug: ta-blnet.0 (9660) States create User PubSub Client
    2024-12-23 10:43:48.078 - debug: ta-blnet.0 (9660) States connected to redis: 127.0.0.1:9000
    2024-12-23 10:43:48.188 - info: ta-blnet.0 (9660) starting. Version 1.0.35 (non-npm: weberk/ioBroker.ta-blnet) in /opt/iobroker/node_modules/iobroker.ta-blnet, node: v20.18.1, js-controller: 7.0.3
    2024-12-23 10:43:48.199 - info: ta-blnet.0 (9660) config ip_address: 192.168.1.199
    2024-12-23 10:43:48.199 - info: ta-blnet.0 (9660) config port: 40000
    2024-12-23 10:43:48.200 - info: ta-blnet.0 (9660) config poll_interval: 30
    2024-12-23 10:43:48.200 - info: ta-blnet.0 (9660) expert_username: expert
    2024-12-23 10:43:48.200 - info: ta-blnet.0 (9660) expert_password: password
    2024-12-23 10:43:48.200 - info: ta-blnet.0 (9660) selected_ta_logger: BL-NET
    2024-12-23 10:43:48.201 - info: ta-blnet.0 (9660) JavaScript Configuration Object: {"requests":[{"can_node_number":7,"data_objects":"La,Ld,I,O,Na,Nd,D"},{"can_node_number":11,"data_objects":"I,O"},{"can_node_number":45,"data_objects":"I,O,D,Sg,Sd,St,Ss,Sp,Na,Nd,M,AM,AK,La,Ld"}]}
    2024-12-23 10:43:48.217 - debug: ta-blnet.0 (9660) onReady: Initialization time logger has changed.
    2024-12-23 10:43:48.217 - debug: ta-blnet.0 (9660) Objects to be deleted for: ta-blnet.0
    2024-12-23 10:43:48.218 - debug: ta-blnet.0 (9660) Deleting objects under ta-blnet.0.bl-net
    2024-12-23 10:43:48.234 - debug: ta-blnet.0 (9660) Deleting objects under ta-blnet.0.cmi
    W U 2 Antworten Letzte Antwort
    • T tomowner
      W Offline
      W Offline
      weberk
      schrieb am zuletzt editiert von weberk
      @tomowner dies sind die wesentlichen Parameter für den BL-NET:
      said in [Test Adapter ta\-blnet NPM/Latest"](/post/1231522):
      Wenn deine IP korrekt ist, sollte das passen.
      Jetzt fehlt mir der nächste Teil des Logs, wo es um die eigentliche fehlerhafte Kommunikation geht.
      Es dauert nach der Ausgabe der Konfig-Werte noch weitere 30s, bis die erste Kommunikation startet, also etwas Geduld...
      Aus deinen obigen Fehlermeldungen zu schliessen konnte der Adapter mit dem BLNET kurz erfolgreich reden, sonst würde er nicht wissen, dass dieser im 1DL-Modus arbeitet.
      D.h. wenn dann im Anschluss nicht erfolgreich die Daten ausgelesen werden kann es nur an 2 Gründen liegen:
      • der BLNET ist überlastet. Bitte schalte andere Zugriffe auf den BLNET aus (z.B. Webbrowser)
      • der BLNET denkt eine UVR1611 gilt es zu lesen und es kommen die Daten eines anderen Geräts rein.
      Mal sehn, was Dein Log an Erklärungen hergibt. Bitte erläutere zusätzlich Deine tatsächliche Systemkonfiguration.
      Klappt das Lesen der Daten mit Winsol?
      • T tomowner
        U Offline
        U Offline
        UlliJ
        @tomowner sagte in Test Adapter ta-blnet NPM/Latest":
        Json Konfiguration richtig? 3 Teilnehmer am Canbus? sieht irgendwie nach der Standardkonfig aus
        Proxmox auf iNuc, lxc für IoB, InfluxDB2, Grafana, u.a. *** Homematic & Homematic IP, Shellies, Zigbee etc
          tomowner
          Hallo Zusamnen,
          bei Umbauarbeiten (BL wurde nur zur Visualisierung verendet) war statt der DL der Can Bus angeschlossen. Den Fehler habe ich jetzt behoben. Der Zugriff funktioniert jetzt auch leider sehe ich noch keine Daten. Screenshot 2024-12-23 154740.png
          Danke für die Hilfe
          W 1 Antwort Letzte Antwort
          • T tomowner
            Hallo Zusamnen,
            Danke für die Hilfe
            W Offline
            W Offline
            weberk
            @tomowner ich bat ja um das Debug-Log unter 'Protokolle'.
            Unter Deiner Instanz sind keine BL-NET-Objekte angelegt. Unter den sichtbaren technischen Objekten ist auch der LogLevel, der als Info eingestellt scheint. Bitte prüfe unter den Instanzeinstellungen, dass debug aktiv ist.
            Hier mein Protokollabschnitt als Beispiel, wie ich ihn bitte auch von Dir brauche:
            ta-blnet.0
            2024-12-23 18:22:45.030	info	config port: 40000
            ta-blnet.0
            2024-12-23 18:22:45.030	info	config poll_interval: 30
            ta-blnet.0
            2024-12-23 18:22:45.030	info	expert_username: egal
            ta-blnet.0
            2024-12-23 18:22:45.030	info	expert_password: egal
            ta-blnet.0
            2024-12-23 18:22:45.030	info	selected_ta_logger: BL-NET
            ta-blnet.0
            2024-12-23 18:22:45.030	info	JavaScript Configuration Object: egal für BLNET
            ta-blnet.0
            2024-12-23 18:22:45.036	debug	onReady: Initialization time logger is the same as in configuration.
            ta-blnet.0
            2024-12-23 18:23:15.041	debug	Sent command - hex dump: 81
            ta-blnet.0
            2024-12-23 18:23:15.055	debug	Received module ID of BL-NET: 0xA8
            ta-blnet.0
            2024-12-23 18:23:15.056	debug	Initiate attempt to fetch data block from BL-NET
            ta-blnet.0
            2024-12-23 18:23:17.068	debug	Sent command - hex dump: AA
            ta-blnet.0
            2024-12-23 18:23:17.081	debug	Sent command as attempt: 1
            ta-blnet.0
            2024-12-23 18:23:17.083	debug	fetchDataBlockFromDevice - hex dump: 0F A8 27 39 0C 76 C0 10 0C 80 10 0C 11
            ta-blnet.0
            2024-12-23 18:23:17.084	debug	Received UVR mode of BL-NET: 1DL
            ta-blnet.0
            2024-12-23 18:23:17.084	debug	Received UVR type of BL-NET: UVR1611
            ta-blnet.0
            2024-12-23 18:23:18.066	debug	Sent command - hex dump: 81
            ta-blnet.0
            2024-12-23 18:23:18.074	debug	Received module ID of BL-NET: 0xA8
            ta-blnet.0
            2024-12-23 18:23:18.075	debug	Initiate attempt to fetch data block from BL-NET
            ta-blnet.0
            2024-12-23 18:23:19.095	debug	Sent command - hex dump: 82
            ta-blnet.0
            2024-12-23 18:23:19.108	debug	Received firmware version of BL-NET: 2.19
            ta-blnet.0
            2024-12-23 18:23:20.085	debug	Sent command - hex dump: AA
            ta-blnet.0
            2024-12-23 18:23:20.096	debug	Sent command as attempt: 1
            ta-blnet.0
            2024-12-23 18:23:20.099	debug	fetchDataBlockFromDevice - hex dump: 0F A8 27 39 0C 76 C0 10 0C 80 10 0C 11
            ta-blnet.0
            2024-12-23 18:23:20.099	debug	Received UVR mode of BL-NET: 1DL
            ta-blnet.0
            2024-12-23 18:23:20.099	debug	Received UVR type of BL-NET: UVR1611
            ta-blnet.0
            2024-12-23 18:23:21.124	debug	Sent command - hex dump: 21
            ta-blnet.0
            2024-12-23 18:23:21.160	debug	Received mode of BL-NET: 0x0x80
            ta-blnet.0
            2024-12-23 18:23:21.160	debug	End readDeviceInfo
            ta-blnet.0
            2024-12-23 18:23:21.160	debug	deviceInfo is defined as:{"uvr_mode":"1DL","uvr_type_str":["UVR1611"],"uvr_type_code":["76"],"channelNodes":[1],"module_id":"0xA8","firmware_version":"2.19","transmission_mode":"0x80"}
            ta-blnet.0
            2024-12-23 18:23:21.161	debug	fetchStateValuesFromDevice BL-NET for data frame: 1
            ta-blnet.0
            2024-12-23 18:23:21.161	debug	Initiate attempt to fetch data block from BL-NET
            ta-blnet.0
            2024-12-23 18:23:22.125	debug	Sent command - hex dump: 82
            ta-blnet.0
            2024-12-23 18:23:22.137	debug	Received firmware version of BL-NET: 2.19
            ta-blnet.0
            2024-12-23 18:23:23.178	debug	Sent command - hex dump: AB 01
            ta-blnet.0
            2024-12-23 18:23:23.192	debug	Sent command as attempt: 1
            ta-blnet.0
            2024-12-23 18:23:23.193	debug	fetchDataBlockFromDevice - hex dump: 80 1B 20 28 22 BC 21 2A 22 F0 20 B5 21 F2 20 20 22 0C 22 AB 21 19 21 FF 1F 6B 21 AD 21 FF 1F 00 30 00 00 00 00 00 80 01 00 00 00 00 31 25 54 00 0A 3C 00 01 00 01 00 0C E1
            ta-blnet.0
            2024-12-23 18:23:23.194	debug	UVR record created from binary record 1: {"Outputs":{"D01":{"value":0,"unit":"ON/OFF"},"D02":{"value":0,"unit":"ON/OFF"},"D03":{"value":0,"unit":"ON/OFF"},"D04":{"value":0,"unit":"ON/OFF"},"D05":{"value":0,"unit":"ON/OFF"},"D06":{"value":0,"unit":"ON/OFF"},"D07":{"value":0,"unit":"ON/OFF"},"D08":{"value":0,"unit":"ON/OFF"},"D09":{"value":0,"unit":"ON/OFF"},"D10":{"value":0,"unit":"ON/OFF"},"D11":{"value":0,"unit":"ON/OFF"},"D12":{"value":0,"unit":"ON/OFF"},"D13":{"value":0,"unit":"ON/OFF"}},"speed_levels":{"DzA1":{"value":null,"unit":""},"DzA2":{"value":null,"unit":""},"DzA6":{"value":null,"unit":""},"DzA7":{"value":0,"unit":""}},"Inputs":{"A01":{"value":2.7,"unit":"°C"},"A02":{"value":55.2,"unit":"°C"},"A03":{"value":44.4,"unit":"°C"},"A04":{"value":55.4,"unit":"°C"},"A05":{"value":24,"unit":"°C"},"A06":{"value":43.7,"unit":"°C"},"A07":{"value":24.2,"unit":"°C"},"A08":{"value":54.4,"unit":"°C"},"A09":{"value":52.4,"unit":"°C"},"A10":{"value":42.7,"unit":"°C"},"A11":{"value":28.1,"unit":"°C"},"D12":{"value":0,"unit":"ON/OFF"},"A13":{"value":36.3,"unit":"°C"},"A14":{"value":42.9,"unit":"°C"},"D15":{"value":0,"unit":"ON/OFF"},"A16":{"value":0,"unit":"l/h"}},"thermal_energy_counters_status":{"wmz1":{"value":true,"unit":""},"wmz2":{"value":false,"unit":""}},"thermal_energy_counters":{"current_heat_power1":{"value":0,"unit":"kW"},"total_heat_energy1":{"value":84952.1,"unit":"kWh"},"current_heat_power2":{"value":0,"unit":"kW"},"total_heat_energy2":{"value":0,"unit":"kWh"}}}
            ta-blnet.0
            2024-12-23 18:23:23.195	debug	fetchStateValuesFromDevice successful.
            ta-blnet.0
            2024-12-23 18:23:23.195	info	readSystemConfiguration succeeded.
            ta-blnet.0
            2024-12-23 18:23:23.195	debug	Setting connection status to: true
            ta-blnet.0
            2024-12-23 18:23:23.232	debug	logging_analog section: undefined
            ta-blnet.0
            2024-12-23 18:23:23.232	debug	logging_digital section: undefined
            ta-blnet.0
            2024-12-23 18:23:23.233	debug	inputs status: {"A01":{"value":2.7,"unit":"°C"},"A02":{"value":55.2,"unit":"°C"},"A03":{"value":44.4,"unit":"°C"},"A04":{"value":55.4,"unit":"°C"},"A05":{"value":24,"unit":"°C"},"A06":{"value":43.7,"unit":"°C"},"A07":{"value":24.2,"unit":"°C"},"A08":{"value":54.4,"unit":"°C"},"A09":{"value":52.4,"unit":"°C"},"A10":{"value":42.7,"unit":"°C"},"A11":{"value":28.1,"unit":"°C"},"D12":{"value":0,"unit":"ON/OFF"},"A13":{"value":36.3,"unit":"°C"},"A14":{"value":42.9,"unit":"°C"},"D15":{"value":0,"unit":"ON/OFF"},"A16":{"value":0,"unit":"l/h"}}
            ta-blnet.0
            2024-12-23 18:23:23.264	debug	outputs status: {"D01":{"value":0,"unit":"ON/OFF"},"D02":{"value":0,"unit":"ON/OFF"},"D03":{"value":0,"unit":"ON/OFF"},"D04":{"value":0,"unit":"ON/OFF"},"D05":{"value":0,"unit":"ON/OFF"},"D06":{"value":0,"unit":"ON/OFF"},"D07":{"value":0,"unit":"ON/OFF"},"D08":{"value":0,"unit":"ON/OFF"},"D09":{"value":0,"unit":"ON/OFF"},"D10":{"value":0,"unit":"ON/OFF"},"D11":{"value":0,"unit":"ON/OFF"},"D12":{"value":0,"unit":"ON/OFF"},"D13":{"value":0,"unit":"ON/OFF"}}
            ta-blnet.0
            2024-12-23 18:23:23.278	debug	network_analog section: undefined
            ta-blnet.0
            2024-12-23 18:23:23.278	debug	network_digital section: undefined
            ta-blnet.0
            2024-12-23 18:23:23.278	debug	dl-bus section: undefined
            ta-blnet.0
            2024-12-23 18:23:23.278	debug	general section: undefined
            ta-blnet.0
            2024-12-23 18:23:23.278	debug	date section: undefined
            ta-blnet.0
            2024-12-23 18:23:23.278	debug	time section: undefined
            ta-blnet.0
            2024-12-23 18:23:23.278	debug	sun section: undefined
            ta-blnet.0
            2024-12-23 18:23:23.278	debug	electrical_power section: undefined
            ta-blnet.0
            2024-12-23 18:23:23.279	debug	electrical_power section: undefined
            ta-blnet.0
            2024-12-23 18:23:23.279	debug	mbus section: undefined
            ta-blnet.0
            2024-12-23 18:23:23.279	debug	m-bus section: undefined
            ta-blnet.0
            2024-12-23 18:23:23.279	debug	modbus section: undefined
            ta-blnet.0
            2024-12-23 18:23:23.279	debug	knx section: undefined
            ta-blnet.0
            2024-12-23 18:23:23.280	debug	speed_levels status: {"DzA1":{"value":null,"unit":""},"DzA2":{"value":null,"unit":""},"DzA6":{"value":null,"unit":""},"DzA7":{"value":0,"unit":""}}
            ta-blnet.0
            2024-12-23 18:23:23.284	debug	thermal_energy_counters_status status: {"wmz1":{"value":true,"unit":""},"wmz2":{"value":false,"unit":""}}
            ta-blnet.0
            2024-12-23 18:23:23.286	debug	thermal_energy_counters status: {"current_heat_power1":{"value":0,"unit":"kW"},"total_heat_energy1":{"value":84952.1,"unit":"kWh"},"current_heat_power2":{"value":0,"unit":"kW"},"total_heat_energy2":{"value":0,"unit":"kWh"}}
            ta-blnet.0
            2024-12-23 18:23:23.290	debug	objects for metrics declared.
            ta-blnet.0
            2024-12-23 18:23:23.290	debug	Initialization succeeded.
            ta-blnet.0
            2024-12-23 18:23:23.290	debug	Polling state values from devices: [1]
            ta-blnet.0
            2024-12-23 18:23:23.290	debug	fetchStateValuesFromDevice BL-NET for data frame: 1
            ta-blnet.0
            2024-12-23 18:23:23.290	debug	Initiate attempt to fetch data block from BL-NET
            ta-blnet.0
            2024-12-23 18:23:24.153	debug	Sent command - hex dump: 21
            ta-blnet.0
            2024-12-23 18:23:24.168	debug	Received mode of BL-NET: 0x0x80
            ta-blnet.0
            2024-12-23 18:23:24.169	debug	End readDeviceInfo
            ta-blnet.0
            2024-12-23 18:23:24.169	debug	deviceInfo is defined as:{"uvr_mode":"1DL","uvr_type_str":["UVR1611"],"uvr_type_code":["76"],"channelNodes":[1],"module_id":"0xA8","firmware_version":"2.19","transmission_mode":"0x80"}
            ta-blnet.0
            2024-12-23 18:23:24.170	debug	fetchStateValuesFromDevice BL-NET for data frame: 1
            ta-blnet.0
            2024-12-23 18:23:24.170	debug	Initiate attempt to fetch data block from BL-NET
            ta-blnet.0
            2024-12-23 18:23:25.303	debug	Sent command - hex dump: AB 01
            ta-blnet.0
            2024-12-23 18:23:25.332	debug	Sent command as attempt: 1
            ta-blnet.0
            2024-12-23 18:23:25.332	debug	fetchDataBlockFromDevice - hex dump: 80 18 20 28 22 BC 21 2A 22 F0 20 B5 21 F2 20 20 22 0B 22 AB 21 19 21 FF 1F 6B 21 B0 21 FF 1F 00 30 00 00 00 00 00 80 01 00 00 00 00 31 25 54 00 03 00 02 00 00 01 06 00 98
            ta-blnet.0
            2024-12-23 18:23:25.333	debug	UVR record created from binary record 1: {"Outputs":{"D01":{"value":0,"unit":"ON/OFF"},"D02":{"value":0,"unit":"ON/OFF"},"D03":{"value":0,"unit":"ON/OFF"},"D04":{"value":0,"unit":"ON/OFF"},"D05":{"value":0,"unit":"ON/OFF"},"D06":{"value":0,"unit":"ON/OFF"},"D07":{"value":0,"unit":"ON/OFF"},"D08":{"value":0,"unit":"ON/OFF"},"D09":{"value":0,"unit":"ON/OFF"},"D10":{"value":0,"unit":"ON/OFF"},"D11":{"value":0,"unit":"ON/OFF"},"D12":{"value":0,"unit":"ON/OFF"},"D13":{"value":0,"unit":"ON/OFF"}},"speed_levels":{"DzA1":{"value":null,"unit":""},"DzA2":{"value":null,"unit":""},"DzA6":{"value":null,"unit":""},"DzA7":{"value":0,"unit":""}},"Inputs":{"A01":{"value":2.4,"unit":"°C"},"A02":{"value":55.2,"unit":"°C"},"A03":{"value":44.4,"unit":"°C"},"A04":{"value":55.4,"unit":"°C"},"A05":{"value":24,"unit":"°C"},"A06":{"value":43.7,"unit":"°C"},"A07":{"value":24.2,"unit":"°C"},"A08":{"value":54.4,"unit":"°C"},"A09":{"value":52.3,"unit":"°C"},"A10":{"value":42.7,"unit":"°C"},"A11":{"value":28.1,"unit":"°C"},"D12":{"value":0,"unit":"ON/OFF"},"A13":{"value":36.3,"unit":"°C"},"A14":{"value":43.2,"unit":"°C"},"D15":{"value":0,"unit":"ON/OFF"},"A16":{"value":0,"unit":"l/h"}},"thermal_energy_counters_status":{"wmz1":{"value":true,"unit":""},"wmz2":{"value":false,"unit":""}},"thermal_energy_counters":{"current_heat_power1":{"value":0,"unit":"kW"},"total_heat_energy1":{"value":84952.1,"unit":"kWh"},"current_heat_power2":{"value":0,"unit":"kW"},"total_heat_energy2":{"value":0,"unit":"kWh"}}}
            ta-blnet.0
            2024-12-23 18:23:25.333	debug	fetchStateValuesFromDevice successful.
            ta-blnet.0
            2024-12-23 18:23:25.345	debug	logging_analog section: undefined
            ta-blnet.0
            2024-12-23 18:23:25.345	debug	logging_digital section: undefined
            ta-blnet.0
            2024-12-23 18:23:25.345	debug	inputs status: {"A01":{"value":2.4,"unit":"°C"},"A02":{"value":55.2,"unit":"°C"},"A03":{"value":44.4,"unit":"°C"},"A04":{"value":55.4,"unit":"°C"},"A05":{"value":24,"unit":"°C"},"A06":{"value":43.7,"unit":"°C"},"A07":{"value":24.2,"unit":"°C"},"A08":{"value":54.4,"unit":"°C"},"A09":{"value":52.3,"unit":"°C"},"A10":{"value":42.7,"unit":"°C"},"A11":{"value":28.1,"unit":"°C"},"D12":{"value":0,"unit":"ON/OFF"},"A13":{"value":36.3,"unit":"°C"},"A14":{"value":43.2,"unit":"°C"},"D15":{"value":0,"unit":"ON/OFF"},"A16":{"value":0,"unit":"l/h"}}
            ta-blnet.0
            2024-12-23 18:23:25.364	debug	outputs status: {"D01":{"value":0,"unit":"ON/OFF"},"D02":{"value":0,"unit":"ON/OFF"},"D03":{"value":0,"unit":"ON/OFF"},"D04":{"value":0,"unit":"ON/OFF"},"D05":{"value":0,"unit":"ON/OFF"},"D06":{"value":0,"unit":"ON/OFF"},"D07":{"value":0,"unit":"ON/OFF"},"D08":{"value":0,"unit":"ON/OFF"},"D09":{"value":0,"unit":"ON/OFF"},"D10":{"value":0,"unit":"ON/OFF"},"D11":{"value":0,"unit":"ON/OFF"},"D12":{"value":0,"unit":"ON/OFF"},"D13":{"value":0,"unit":"ON/OFF"}}
            ta-blnet.0
            2024-12-23 18:23:25.378	debug	network_analog section: undefined
            ta-blnet.0
            2024-12-23 18:23:25.378	debug	network_digital section: undefined
            ta-blnet.0
            2024-12-23 18:23:25.378	debug	dl-bus section: undefined
            ta-blnet.0
            2024-12-23 18:23:25.378	debug	general section: undefined
            ta-blnet.0
            2024-12-23 18:23:25.378	debug	date section: undefined
            ta-blnet.0
            2024-12-23 18:23:25.378	debug	time section: undefined
            ta-blnet.0
            2024-12-23 18:23:25.378	debug	sun section: undefined
            ta-blnet.0
            2024-12-23 18:23:25.378	debug	electrical_power section: undefined
            ta-blnet.0
            2024-12-23 18:23:25.379	debug	electrical_power section: undefined
            ta-blnet.0
            2024-12-23 18:23:25.379	debug	mbus section: undefined
            ta-blnet.0
            2024-12-23 18:23:25.379	debug	m-bus section: undefined
            ta-blnet.0
            2024-12-23 18:23:25.379	debug	modbus section: undefined
            ta-blnet.0
            2024-12-23 18:23:25.379	debug	knx section: undefined
            ta-blnet.0
            2024-12-23 18:23:25.379	debug	speed_levels status: {"DzA1":{"value":null,"unit":""},"DzA2":{"value":null,"unit":""},"DzA6":{"value":null,"unit":""},"DzA7":{"value":0,"unit":""}}
            ta-blnet.0
            2024-12-23 18:23:25.384	debug	thermal_energy_counters_status status: {"wmz1":{"value":true,"unit":""},"wmz2":{"value":false,"unit":""}}
            ta-blnet.0
            2024-12-23 18:23:25.386	debug	thermal_energy_counters status: {"current_heat_power1":{"value":0,"unit":"kW"},"total_heat_energy1":{"value":84952.1,"unit":"kWh"},"current_heat_power2":{"value":0,"unit":"kW"},"total_heat_energy2":{"value":0,"unit":"kWh"}}
            ta-blnet.0
            2024-12-23 18:23:25.389	debug	objects for metrics updated.
            ta-blnet.0
            2024-12-23 18:23:26.181	debug	Sent command - hex dump: AB 01
            ta-blnet.0
            2024-12-23 18:23:26.191	debug	Sent command as attempt: 1
            ta-blnet.0
            2024-12-23 18:23:26.193	debug	Invalid short response from device
            ta-blnet.0
            2024-12-23 18:23:26.194	debug	fetchDataBlockFromDevice - hex dump: AB
            ta-blnet.0
            2024-12-23 18:23:28.206	debug	Sent command - hex dump: AB 01
            ta-blnet.0
            2024-12-23 18:23:28.217	debug	Sent command as attempt: 2
            ta-blnet.0
            2024-12-23 18:23:28.218	debug	fetchDataBlockFromDevice - hex dump: 80 18 20 28 22 BC 21 2A 22 F0 20 B5 21 F1 20 20 22 0D 22 AB 21 19 21 FF 1F 6C 21 AF 21 FF 1F 00 30 00 00 00 00 00 80 01 00 00 00 00 31 25 54 00 0A 3C 00 01 00 01 02 00 D7
            ta-blnet.0
            2024-12-23 18:23:28.220	debug	UVR record created from binary record 1: {"Outputs":{"D01":{"value":0,"unit":"ON/OFF"},"D02":{"value":0,"unit":"ON/OFF"},"D03":{"value":0,"unit":"ON/OFF"},"D04":{"value":0,"unit":"ON/OFF"},"D05":{"value":0,"unit":"ON/OFF"},"D06":{"value":0,"unit":"ON/OFF"},"D07":{"value":0,"unit":"ON/OFF"},"D08":{"value":0,"unit":"ON/OFF"},"D09":{"value":0,"unit":"ON/OFF"},"D10":{"value":0,"unit":"ON/OFF"},"D11":{"value":0,"unit":"ON/OFF"},"D12":{"value":0,"unit":"ON/OFF"},"D13":{"value":0,"unit":"ON/OFF"}},"speed_levels":{"DzA1":{"value":null,"unit":""},"DzA2":{"value":null,"unit":""},"DzA6":{"value":null,"unit":""},"DzA7":{"value":0,"unit":""}},"Inputs":{"A01":{"value":2.4,"unit":"°C"},"A02":{"value":55.2,"unit":"°C"},"A03":{"value":44.4,"unit":"°C"},"A04":{"value":55.4,"unit":"°C"},"A05":{"value":24,"unit":"°C"},"A06":{"value":43.7,"unit":"°C"},"A07":{"value":24.1,"unit":"°C"},"A08":{"value":54.4,"unit":"°C"},"A09":{"value":52.5,"unit":"°C"},"A10":{"value":42.7,"unit":"°C"},"A11":{"value":28.1,"unit":"°C"},"D12":{"value":0,"unit":"ON/OFF"},"A13":{"value":36.4,"unit":"°C"},"A14":{"value":43.1,"unit":"°C"},"D15":{"value":0,"unit":"ON/OFF"},"A16":{"value":0,"unit":"l/h"}},"thermal_energy_counters_status":{"wmz1":{"value":true,"unit":""},"wmz2":{"value":false,"unit":""}},"thermal_energy_counters":{"current_heat_power1":{"value":0,"unit":"kW"},"total_heat_energy1":{"value":84952.1,"unit":"kWh"},"current_heat_power2":{"value":0,"unit":"kW"},"total_heat_energy2":{"value":0,"unit":"kWh"}}}
            ta-blnet.0
            2024-12-23 18:23:28.220	debug	fetchStateValuesFromDevice successful.
            ta-blnet.0
            2024-12-23 18:23:28.223	info	readSystemConfiguration succeeded.
            ta-blnet.0
            2024-12-23 18:23:28.223	debug	Setting connection status to: true
            ta-blnet.0
            2024-12-23 18:23:28.263	debug	logging_analog section: undefined
            ta-blnet.0
            2024-12-23 18:23:28.263	debug	logging_digital section: undefined
            ta-blnet.0
            2024-12-23 18:23:28.264	debug	inputs status: {"A01":{"value":2.4,"unit":"°C"},"A02":{"value":55.2,"unit":"°C"},"A03":{"value":44.4,"unit":"°C"},"A04":{"value":55.4,"unit":"°C"},"A05":{"value":24,"unit":"°C"},"A06":{"value":43.7,"unit":"°C"},"A07":{"value":24.1,"unit":"°C"},"A08":{"value":54.4,"unit":"°C"},"A09":{"value":52.5,"unit":"°C"},"A10":{"value":42.7,"unit":"°C"},"A11":{"value":28.1,"unit":"°C"},"D12":{"value":0,"unit":"ON/OFF"},"A13":{"value":36.4,"unit":"°C"},"A14":{"value":43.1,"unit":"°C"},"D15":{"value":0,"unit":"ON/OFF"},"A16":{"value":0,"unit":"l/h"}}
            ta-blnet.0
            2024-12-23 18:23:28.290	debug	outputs status: {"D01":{"value":0,"unit":"ON/OFF"},"D02":{"value":0,"unit":"ON/OFF"},"D03":{"value":0,"unit":"ON/OFF"},"D04":{"value":0,"unit":"ON/OFF"},"D05":{"value":0,"unit":"ON/OFF"},"D06":{"value":0,"unit":"ON/OFF"},"D07":{"value":0,"unit":"ON/OFF"},"D08":{"value":0,"unit":"ON/OFF"},"D09":{"value":0,"unit":"ON/OFF"},"D10":{"value":0,"unit":"ON/OFF"},"D11":{"value":0,"unit":"ON/OFF"},"D12":{"value":0,"unit":"ON/OFF"},"D13":{"value":0,"unit":"ON/OFF"}}
            ta-blnet.0
            2024-12-23 18:23:28.305	debug	network_analog section: undefined
            ta-blnet.0
            2024-12-23 18:23:28.305	debug	network_digital section: undefined
            ta-blnet.0
            2024-12-23 18:23:28.305	debug	dl-bus section: undefined
            ta-blnet.0
            2024-12-23 18:23:28.305	debug	general section: undefined
            ta-blnet.0
            2024-12-23 18:23:28.305	debug	date section: undefined
            ta-blnet.0
            2024-12-23 18:23:28.305	debug	time section: undefined
            ta-blnet.0
            2024-12-23 18:23:28.305	debug	sun section: undefined
            ta-blnet.0
            2024-12-23 18:23:28.305	debug	electrical_power section: undefined
            ta-blnet.0
            ta-blnet.0
            2024-12-23 18:23:28.305	debug	mbus section: undefined
            ta-blnet.0
            2024-12-23 18:23:28.305	debug	m-bus section: undefined
            ta-blnet.0
            2024-12-23 18:23:28.305	debug	modbus section: undefined
            ta-blnet.0
            2024-12-23 18:23:28.305	debug	knx section: undefined
            ta-blnet.0
            2024-12-23 18:23:28.306	debug	speed_levels status: {"DzA1":{"value":null,"unit":""},"DzA2":{"value":null,"unit":""},"DzA6":{"value":null,"unit":""},"DzA7":{"value":0,"unit":""}}
            ta-blnet.0
            2024-12-23 18:23:28.310	debug	thermal_energy_counters_status status: {"wmz1":{"value":true,"unit":""},"wmz2":{"value":false,"unit":""}}
            ta-blnet.0
            2024-12-23 18:23:28.312	debug	thermal_energy_counters status: {"current_heat_power1":{"value":0,"unit":"kW"},"total_heat_energy1":{"value":84952.1,"unit":"kWh"},"current_heat_power2":{"value":0,"unit":"kW"},"total_heat_energy2":{"value":0,"unit":"kWh"}}
            ta-blnet.0
            2024-12-23 18:23:28.316	debug	objects for metrics declared.
            ta-blnet.0
            2024-12-23 18:23:28.316	debug	Initialization succeeded.
            ta-blnet.0
            2024-12-23 18:23:28.316	debug	Polling state values from devices: [1]
            ta-blnet.0
            2024-12-23 18:23:28.316	debug	fetchStateValuesFromDevice BL-NET for data frame: 1
            ta-blnet.0
            2024-12-23 18:23:28.316	debug	Initiate attempt to fetch data block from BL-NET
            ta-blnet.0
            2024-12-23 18:23:30.327	debug	Sent command - hex dump: AB 01
            ta-blnet.0
            2024-12-23 18:23:30.337	debug	Sent command as attempt: 1
            ta-blnet.0
            2024-12-23 18:23:30.338	debug	Invalid short response from device
            ta-blnet.0
            2024-12-23 18:23:30.338	debug	fetchDataBlockFromDevice - hex dump: AB
            ta-blnet.0
            2024-12-23 18:23:32.352	debug	Sent command - hex dump: AB 01
            ta-blnet.0
            2024-12-23 18:23:32.367	debug	Sent command as attempt: 2
            ta-blnet.0
            2024-12-23 18:23:32.367	debug	fetchDataBlockFromDevice - hex dump: 80 19 20 28 22 BC 21 2A 22 F0 20 B5 21 F2 20 20 22 0C 22 AB 21 19 21 FF 1F 6C 21 AF 21 FF 1F 00 30 00 00 00 00 00 80 01 00 00 00 00 31 25 54 00 0A 3C 00 01 06 00 0A 3C 21
            ta-blnet.0
            2024-12-23 18:23:32.372	debug	UVR record created from binary record 1: {"Outputs":{"D01":{"value":0,"unit":"ON/OFF"},"D02":{"value":0,"unit":"ON/OFF"},"D03":{"value":0,"unit":"ON/OFF"},"D04":{"value":0,"unit":"ON/OFF"},"D05":{"value":0,"unit":"ON/OFF"},"D06":{"value":0,"unit":"ON/OFF"},"D07":{"value":0,"unit":"ON/OFF"},"D08":{"value":0,"unit":"ON/OFF"},"D09":{"value":0,"unit":"ON/OFF"},"D10":{"value":0,"unit":"ON/OFF"},"D11":{"value":0,"unit":"ON/OFF"},"D12":{"value":0,"unit":"ON/OFF"},"D13":{"value":0,"unit":"ON/OFF"}},"speed_levels":{"DzA1":{"value":null,"unit":""},"DzA2":{"value":null,"unit":""},"DzA6":{"value":null,"unit":""},"DzA7":{"value":0,"unit":""}},"Inputs":{"A01":{"value":2.5,"unit":"°C"},"A02":{"value":55.2,"unit":"°C"},"A03":{"value":44.4,"unit":"°C"},"A04":{"value":55.4,"unit":"°C"},"A05":{"value":24,"unit":"°C"},"A06":{"value":43.7,"unit":"°C"},"A07":{"value":24.2,"unit":"°C"},"A08":{"value":54.4,"unit":"°C"},"A09":{"value":52.4,"unit":"°C"},"A10":{"value":42.7,"unit":"°C"},"A11":{"value":28.1,"unit":"°C"},"D12":{"value":0,"unit":"ON/OFF"},"A13":{"value":36.4,"unit":"°C"},"A14":{"value":43.1,"unit":"°C"},"D15":{"value":0,"unit":"ON/OFF"},"A16":{"value":0,"unit":"l/h"}},"thermal_energy_counters_status":{"wmz1":{"value":true,"unit":""},"wmz2":{"value":false,"unit":""}},"thermal_energy_counters":{"current_heat_power1":{"value":0,"unit":"kW"},"total_heat_energy1":{"value":84952.1,"unit":"kWh"},"current_heat_power2":{"value":0,"unit":"kW"},"total_heat_energy2":{"value":0,"unit":"kWh"}}}
            ta-blnet.0
            2024-12-23 18:23:32.372	debug	fetchStateValuesFromDevice successful.
            ta-blnet.0
            2024-12-23 18:23:32.396	debug	logging_analog section: undefined
            ta-blnet.0
            2024-12-23 18:23:32.396	debug	logging_digital section: undefined
            ta-blnet.0
            2024-12-23 18:23:32.396	debug	inputs status: {"A01":{"value":2.5,"unit":"°C"},"A02":{"value":55.2,"unit":"°C"},"A03":{"value":44.4,"unit":"°C"},"A04":{"value":55.4,"unit":"°C"},"A05":{"value":24,"unit":"°C"},"A06":{"value":43.7,"unit":"°C"},"A07":{"value":24.2,"unit":"°C"},"A08":{"value":54.4,"unit":"°C"},"A09":{"value":52.4,"unit":"°C"},"A10":{"value":42.7,"unit":"°C"},"A11":{"value":28.1,"unit":"°C"},"D12":{"value":0,"unit":"ON/OFF"},"A13":{"value":36.4,"unit":"°C"},"A14":{"value":43.1,"unit":"°C"},"D15":{"value":0,"unit":"ON/OFF"},"A16":{"value":0,"unit":"l/h"}}
            ta-blnet.0
            2024-12-23 18:23:32.411	debug	outputs status: {"D01":{"value":0,"unit":"ON/OFF"},"D02":{"value":0,"unit":"ON/OFF"},"D03":{"value":0,"unit":"ON/OFF"},"D04":{"value":0,"unit":"ON/OFF"},"D05":{"value":0,"unit":"ON/OFF"},"D06":{"value":0,"unit":"ON/OFF"},"D07":{"value":0,"unit":"ON/OFF"},"D08":{"value":0,"unit":"ON/OFF"},"D09":{"value":0,"unit":"ON/OFF"},"D10":{"value":0,"unit":"ON/OFF"},"D11":{"value":0,"unit":"ON/OFF"},"D12":{"value":0,"unit":"ON/OFF"},"D13":{"value":0,"unit":"ON/OFF"}}
            ta-blnet.0
            2024-12-23 18:23:32.424	debug	network_analog section: undefined
            ta-blnet.0
            2024-12-23 18:23:32.424	debug	network_digital section: undefined
            ta-blnet.0
            2024-12-23 18:23:32.424	debug	dl-bus section: undefined
            ta-blnet.0
            2024-12-23 18:23:32.424	debug	general section: undefined
            ta-blnet.0
            2024-12-23 18:23:32.424	debug	date section: undefined
            ta-blnet.0
            2024-12-23 18:23:32.424	debug	time section: undefined
            ta-blnet.0
            2024-12-23 18:23:32.424	debug	sun section: undefined
            ta-blnet.0
            2024-12-23 18:23:32.424	debug	electrical_power section: undefined
            ta-blnet.0
            2024-12-23 18:23:32.425	debug	electrical_power section: undefined
            ta-blnet.0
            2024-12-23 18:23:32.425	debug	mbus section: undefined
            ta-blnet.0
            2024-12-23 18:23:32.425	debug	m-bus section: undefined
            ta-blnet.0
            2024-12-23 18:23:32.425	debug	modbus section: undefined
            ta-blnet.0
            2024-12-23 18:23:32.425	debug	knx section: undefined
            ta-blnet.0
            2024-12-23 18:23:32.425	debug	speed_levels status: {"DzA1":{"value":null,"unit":""},"DzA2":{"value":null,"unit":""},"DzA6":{"value":null,"unit":""},"DzA7":{"value":0,"unit":""}}
            ta-blnet.0
            2024-12-23 18:23:32.430	debug	thermal_energy_counters_status status: {"wmz1":{"value":true,"unit":""},"wmz2":{"value":false,"unit":""}}
            ta-blnet.0
            2024-12-23 18:23:32.432	debug	thermal_energy_counters status: {"current_heat_power1":{"value":0,"unit":"kW"},"total_heat_energy1":{"value":84952.1,"unit":"kWh"},"current_heat_power2":{"value":0,"unit":"kW"},"total_heat_energy2":{"value":0,"unit":"kWh"}}
            ta-blnet.0
            2024-12-23 18:23:32.436	debug	objects for metrics updated.
            ta-blnet.0
            2024-12-23 18:23:55.390	debug	Polling state values from devices: [1]
            ta-blnet.0
            2024-12-23 18:23:55.391	debug	fetchStateValuesFromDevice BL-NET for data frame: 1
            ta-blnet.0
            2024-12-23 18:23:55.391	debug	Initiate attempt to fetch data block from BL-NET
            ta-blnet.0
            2024-12-23 18:23:57.408	debug	Sent command - hex dump: AB 01
            ta-blnet.0
            2024-12-23 18:23:57.423	debug	Sent command as attempt: 1
            ta-blnet.0
            2024-12-23 18:23:57.424	debug	fetchDataBlockFromDevice - hex dump: 80 1A 20 28 22 BC 21 2A 22 F0 20 B5 21 F2 20 20 22 0C 22 AB 21 19 21 FF 1F 6C 21 B0 21 FF 1F 00 30 00 00 00 00 00 80 01 00 00 00 00 31 25 54 00 0A 3C 03 00 00 01 00 01 DB
            ta-blnet.0
            2024-12-23 18:23:57.425	debug	UVR record created from binary record 1: {"Outputs":{"D01":{"value":0,"unit":"ON/OFF"},"D02":{"value":0,"unit":"ON/OFF"},"D03":{"value":0,"unit":"ON/OFF"},"D04":{"value":0,"unit":"ON/OFF"},"D05":{"value":0,"unit":"ON/OFF"},"D06":{"value":0,"unit":"ON/OFF"},"D07":{"value":0,"unit":"ON/OFF"},"D08":{"value":0,"unit":"ON/OFF"},"D09":{"value":0,"unit":"ON/OFF"},"D10":{"value":0,"unit":"ON/OFF"},"D11":{"value":0,"unit":"ON/OFF"},"D12":{"value":0,"unit":"ON/OFF"},"D13":{"value":0,"unit":"ON/OFF"}},"speed_levels":{"DzA1":{"value":null,"unit":""},"DzA2":{"value":null,"unit":""},"DzA6":{"value":null,"unit":""},"DzA7":{"value":0,"unit":""}},"Inputs":{"A01":{"value":2.6,"unit":"°C"},"A02":{"value":55.2,"unit":"°C"},"A03":{"value":44.4,"unit":"°C"},"A04":{"value":55.4,"unit":"°C"},"A05":{"value":24,"unit":"°C"},"A06":{"value":43.7,"unit":"°C"},"A07":{"value":24.2,"unit":"°C"},"A08":{"value":54.4,"unit":"°C"},"A09":{"value":52.4,"unit":"°C"},"A10":{"value":42.7,"unit":"°C"},"A11":{"value":28.1,"unit":"°C"},"D12":{"value":0,"unit":"ON/OFF"},"A13":{"value":36.4,"unit":"°C"},"A14":{"value":43.2,"unit":"°C"},"D15":{"value":0,"unit":"ON/OFF"},"A16":{"value":0,"unit":"l/h"}},"thermal_energy_counters_status":{"wmz1":{"value":true,"unit":""},"wmz2":{"value":false,"unit":""}},"thermal_energy_counters":{"current_heat_power1":{"value":0,"unit":"kW"},"total_heat_energy1":{"value":84952.1,"unit":"kWh"},"current_heat_power2":{"value":0,"unit":"kW"},"total_heat_energy2":{"value":0,"unit":"kWh"}}}
            ta-blnet.0
            2024-12-23 18:23:57.425	debug	fetchStateValuesFromDevice successful.
            ta-blnet.0
            2024-12-23 18:23:57.458	debug	logging_analog section: undefined
            ta-blnet.0
            2024-12-23 18:23:57.458	debug	logging_digital section: undefined
            ta-blnet.0
            2024-12-23 18:23:57.458	debug	inputs status: {"A01":{"value":2.6,"unit":"°C"},"A02":{"value":55.2,"unit":"°C"},"A03":{"value":44.4,"unit":"°C"},"A04":{"value":55.4,"unit":"°C"},"A05":{"value":24,"unit":"°C"},"A06":{"value":43.7,"unit":"°C"},"A07":{"value":24.2,"unit":"°C"},"A08":{"value":54.4,"unit":"°C"},"A09":{"value":52.4,"unit":"°C"},"A10":{"value":42.7,"unit":"°C"},"A11":{"value":28.1,"unit":"°C"},"D12":{"value":0,"unit":"ON/OFF"},"A13":{"value":36.4,"unit":"°C"},"A14":{"value":43.2,"unit":"°C"},"D15":{"value":0,"unit":"ON/OFF"},"A16":{"value":0,"unit":"l/h"}}
            ta-blnet.0
            2024-12-23 18:23:57.479	debug	outputs status: {"D01":{"value":0,"unit":"ON/OFF"},"D02":{"value":0,"unit":"ON/OFF"},"D03":{"value":0,"unit":"ON/OFF"},"D04":{"value":0,"unit":"ON/OFF"},"D05":{"value":0,"unit":"ON/OFF"},"D06":{"value":0,"unit":"ON/OFF"},"D07":{"value":0,"unit":"ON/OFF"},"D08":{"value":0,"unit":"ON/OFF"},"D09":{"value":0,"unit":"ON/OFF"},"D10":{"value":0,"unit":"ON/OFF"},"D11":{"value":0,"unit":"ON/OFF"},"D12":{"value":0,"unit":"ON/OFF"},"D13":{"value":0,"unit":"ON/OFF"}}
            ta-blnet.0
            2024-12-23 18:23:57.492	debug	network_analog section: undefined
            ta-blnet.0
            2024-12-23 18:23:57.492	debug	network_digital section: undefined
            ta-blnet.0
            2024-12-23 18:23:57.492	debug	dl-bus section: undefined
            ta-blnet.0
            2024-12-23 18:23:57.492	debug	general section: undefined
            ta-blnet.0
            2024-12-23 18:23:57.492	debug	date section: undefined
            ta-blnet.0
            2024-12-23 18:23:57.492	debug	time section: undefined
            ta-blnet.0
            2024-12-23 18:23:57.492	debug	sun section: undefined
            ta-blnet.0
            2024-12-23 18:23:57.492	debug	electrical_power section: undefined
            ta-blnet.0
            ta-blnet.0
            2024-12-23 18:23:57.492	debug	mbus section: undefined
            ta-blnet.0
            2024-12-23 18:23:57.492	debug	m-bus section: undefined
            ta-blnet.0
            2024-12-23 18:23:57.492	debug	modbus section: undefined
            ta-blnet.0
            2024-12-23 18:23:57.492	debug	knx section: undefined
            ta-blnet.0
            2024-12-23 18:23:57.492	debug	speed_levels status: {"DzA1":{"value":null,"unit":""},"DzA2":{"value":null,"unit":""},"DzA6":{"value":null,"unit":""},"DzA7":{"value":0,"unit":""}}
            ta-blnet.0
            2024-12-23 18:23:57.497	debug	thermal_energy_counters_status status: {"wmz1":{"value":true,"unit":""},"wmz2":{"value":false,"unit":""}}
            ta-blnet.0
            2024-12-23 18:23:57.499	debug	thermal_energy_counters status: {"current_heat_power1":{"value":0,"unit":"kW"},"total_heat_energy1":{"value":84952.1,"unit":"kWh"},"current_heat_power2":{"value":0,"unit":"kW"},"total_heat_energy2":{"value":0,"unit":"kWh"}}
            ta-blnet.0
            2024-12-23 18:23:57.502	debug	objects for metrics updated
            D.h. 1:1 aus dem Webbrowser rauskopiert. (Spoiler muss du anklicken, damit er sich öffnet).
            Ach ja und die Frage nach Winsol hast Du noch nicht beantwortet: klappt es die aktuellen Daten mit Winsol zu lesen?
            • W weberk
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              ta-blnet.0
              tomowner
              @weberk Hi, ich habe gerade WinSol installiert und ausgelesen. In der Instanz ist jetzt auch alles vorhanden. Das Problem scheint gelöst zu sein. Danke für die Hilfe.
              • T tomowner
                W Offline
                W Offline
                weberk
                @tomowner na das ist ja pünktlich zum Heiligabend?!
                Angenehme Feiertage!
                • Iob_TomI Offline
                  Iob_TomI Offline
                  Iob_Tom
                  als erstes frohe Weihnachten.
                  Leider habe ich ein Problem, bekomme keine Verbindung zum meinem CMI.
                  IP - CMI eingetragen, auf Port 80 umgestellt.
                  Experten Passwort geändert.
                  was muss ich genau in der JSON Datei ändern??
                  CMI = Port 56
                  UVR 1611x2 = Port 1
                  CanTouch = Port 50
                  Was mache ich falsch??
                  Bitt um Hilfe.
                  Danke Thomas
                  • Iob_TomI Offline
                    Iob_TomI Offline
                    Iob_Tom
                    Nachtrag:
                    habe jetzt folgende Fehlermeldung erhalten...
                    ta-blnet.0
                    2024-12-26 10:47:36.608 error Error during communication with device on attempt 1: [object Object]
                    ta-blnet.0
                    2024-12-26 10:48:36.616 warn NODE ERROR: Node not available (1 - NODE ERROR)
                    • Iob_TomI Iob_Tom
                      Nachtrag:
                      ta-blnet.0
                      ta-blnet.0
                      W Offline
                      W Offline
                      weberk
                      @iob_tom Frohe Weihnachten auch von mir.
                      Scheinst einen Schritt weiter. Bevor aber de TA-BLNET-Adapter funktioniert, solltest du CMI und seine CAN-Bus-Teilnehmer zusammenbringen.
                      Der Ethernetz TCP-Port 80 sollte passen. Der Rest sind CAN-Bus Adressen.
                      Meine Empfehlung: teste mit folgender CMI-Adresse im Web-Browser, bis die Liste der Datenobjekte für jeden CAN-Bus-Teilnehmer (jsonNode) korrekte Ergebnisse liefern:
                      http://user:pwd@192.168.30.40/INCLUDE/api.cgi?jsonnode=7&jsonparam=I,O,D,Sg,Sd,St,Ss,Sp,Na,Nd,M,AM,AK,La,Ld
                      Wenn das dann klappt kannst du diese Infos in die requests-Liste der Adapter-Konfiguration übernehmen.
                      Evtl. zunächst nur mit den Datenobjekten I,O starten.
                      Viel Erfolg - Klaus.
                      Iob_TomI 1 Antwort Letzte Antwort
                      • W weberk
                        Iob_TomI Offline
                        Iob_TomI Offline
                        Iob_Tom
                        @weberk
                        Danke für die Hilfe, jetzt funktionierts!
                        LG Thomas
                          katsu
                          Hallo Klaus,
                          vielen Dank für den coolen Adapter!
                          Ich habe Anfang Dezember angefangen ioBroker einzurichten. Mal gab es kleine, mal größere Probleme bis zum Totalverlust der Installation...
                          Kurz vor Weihnachten hatte ich jetzt angefangen die Werte meiner UVR16x2 auf dem CAN-Bus zur Verfügung zu stellen, damit ich diese dann
                          weiter verwenden kann. Dann an Weihnachten Deinen Adapter entdeckt und gleich mal versucht zu installieren. Hat zuerst nicht ganz geklappt,
                          trotz "RTFM!". Das man die Instanz selbst anlegen muss, habe ich dann in der Nachricht von "UlliJ" gesehen.
                          Noch kurz die korrekten Adressen eingetragen, den Adapter gestartet und seitdem habe ich alle Werte! Perfekt!
                          Die CAN Adressen 7, 11, 45 die Du oben angegeben hast, kenne ich nicht. Vermute das eine davon der BL-NET Bootloader ist.
                          Die Standardadressen der Geräte laut TA:
                          Gerät => CAN-Knoten-Adresse
                          CAN-BC2 => 48
                          CAN-EZ2 => 40
                          CAN-EZ3 => 40
                          CAN-I/O45 => 32
                          CAN-MTx2 => 50
                          CAN-TOUCH => 16
                          C.M.I. => 56
                          RSM610 => 32
                          UVR16x2 => 1
                          UVR65 => 12
                          UVR67 => 12
                          UVR610 => 32
                          UVR1611 => 1
                          (Warum kann man hier nichts vernünftig ausrichten? 😢 )
                          Kann natürlich abweichen falls diese bei einem Gerät geändert wurde! Bei mir z.B. je ein CAN-I/O45 auf 32 und 33, weil Adressen
                          ja nicht doppelt vergeben werden dürfen.
                          Gruß, Jürgen
                          G W 2 Antworten Letzte Antwort
                          • K katsu
                            Hallo Klaus,
                            CAN-BC2 => 48
                            CAN-EZ2 => 40
                            CAN-EZ3 => 40
                            CAN-I/O45 => 32
                            CAN-MTx2 => 50
                            CAN-TOUCH => 16
                            C.M.I. => 56
                            RSM610 => 32
                            UVR16x2 => 1
                            UVR65 => 12
                            UVR67 => 12
                            UVR610 => 32
                            UVR1611 => 1
                            Gruß, Jürgen
                            GerdDe
                            Forum Testing
                            schrieb am zuletzt editiert von GerdDe
                            @katsu, versuche im Json-Editor die Standard Werte zu editieren.
                            Hier mein Beispiel, das CMI mit Geräten der X2 Serie (Knoten 2, 4, 5, 6, 8, 10, 20, 21, 30, 40)
                            "requests": [
                            "can_node_number": 2,
                            "data_objects": "I,O,D,Sg,Sd,St,Ss,Na,Nd,La,Ld"
                            "can_node_number": 4,
                            "can_node_number": 5,
                            "can_node_number": 6,
                            "can_node_number": 8,
                            "can_node_number": 10,
                            "can_node_number": 20,
                            "can_node_number": 21,
                            "can_node_number": 30,
                            "can_node_number": 40,
                            VG Gerd
                            • K katsu
                              Hallo Klaus,
                              CAN-BC2 => 48
                              CAN-EZ2 => 40
                              CAN-EZ3 => 40
                              CAN-I/O45 => 32
                              CAN-MTx2 => 50
                              CAN-TOUCH => 16
                              C.M.I. => 56
                              RSM610 => 32
                              UVR16x2 => 1
                              UVR65 => 12
                              UVR67 => 12
                              UVR610 => 32
                              UVR1611 => 1
                              Gruß, Jürgen
                              W Offline
                              W Offline
                              weberk
                              @katsu freut mich dass es schlussendlich ging. 7,11,45 sollte ein Beispiel sein, welches die Struktur zeigt und dass hier eine Liste akzeptiert wird.
                              • G GerdDe
                                "requests": [
                                VG Gerd
                                W Offline
                                W Offline
                                weberk
                                @gerdde danke für die positive Rückmeldung mit vielen Geräten. Deine Geräteliste ist wahrscheinlich einzigartig!
                                  katsu
                                  schrieb am zuletzt editiert von katsu
                                  So, jetzt habe ich doch noch einen Fehler bei mir gefunden. Ich habe angefangen die Ein- und Ausgänge zu benennen und beim UVR16x2
                                  fehlen die digitalen Ausgänge 01-07, Outputs fängt erst bei 08 an.
                                  Ich habe mal von Hand die Ausgänge am UVR16x2 geschaltet und die fehlenden Ausgänge werden auch nicht an anderer Stelle angezeigt.
                                  Kann das sein das da im Adapter die Bereiche die gelesen werden nicht ganz passen? Habe mir mal den Quellcode angeschaut und festgestellt
                                  das ich da mit meinen C++ Kenntnissen noch nicht so ganz durchblicke. 🤣
                                  @GerdDe Das sind aber eine Menge Geräte. Ich dachte schon meine Installation wäre groß...
                                  Gruß, Jürgen
                                    katsu
                                    @weberk: Sorry, das Problem mit den fehlenden Ausgängen liegt nicht an Deinem Adapter!
                                    Wenn ich im Browser direkt http://192.168.0.34/INCLUDE/api.cgi?jsonnode=1&jsonparam=O eingebe, bekomme ich normalerweise alle Ausgänge.
                                    Was kommt ist aber leider nur das:
                                    "Header":{
                                    "Version":7,
                                    "Device":"87",
                                    "Timestamp":1735417238
                                    "Data":{
                                    "Outputs":[
                                    "Number":8,
                                    "AD":"D",
                                    "Value":{
                                    "Value":0,
                                    "Unit":"43"
                                    "Number":9,
                                    "AD":"D",
                                    "Value":{
                                    "Value":0,
                                    "Unit":"43"
                                    ...gekürzt...
                                    "Number":16,
                                    "AD":"D",
                                    "Value":{
                                    "Value":0,
                                    "Unit":"43"
                                    "Status":"OK",
                                    "Status code":0
                                    Folglich nicht Dein Problem...
                                    Da sendet wohl das UVR16x2 nicht mehr an Daten. Ausgang 1+2, 3+4, 6+7 sind Mischer-Ausgänge, Ausgang 5 ist nicht belegt. Entweder das Gerät sendet
                                    nur so doppelt belegte Ausgänge absichtlich nicht mit und unbelegte auch nicht, oder da gibt es ein Problem mit der Firmware. Ich werde mal den Ausgang
                                    1, 2 und 5 im Tapps mal umstellen und nochmal hochladen. Mal schauen was dann passiert.
                                    Gruß, Jürgen
                                    EDIT: Ok, habe Ausgang 1 und 2 NICHT mehr als Mischer konfiguriert und dann sind sie sichtbar! Außerdem sind nur konfigurierte Ausgänge sichtbar!
                                    Ausgang 5 konfiguriert > sichtbar, Konfiguration entfernt > unsichtbar!
                                    • K katsu
                                      "Header":{
                                      "Version":7,
                                      "Device":"87",
                                      "Data":{
                                      "Outputs":[
                                      "Number":8,
                                      "AD":"D",
                                      "Value":{
                                      "Value":0,
                                      "Unit":"43"
                                      "Number":9,
                                      "AD":"D",
                                      "Value":{
                                      "Value":0,
                                      "Unit":"43"
                                      ...gekürzt...
                                      "Number":16,
                                      "AD":"D",
                                      "Value":{
                                      "Value":0,
                                      "Unit":"43"
                                      "Status":"OK",
                                      "Status code":0
                                      Gruß, Jürgen
                                      W Offline
                                      W Offline
                                      weberk
                                      Nachdem der Adapter bei Euch nun nachweislich in BL-NET und CMI funktioniert, hab ich den Adapter für das ioBroker Stable Repo eingereicht.
                                      Vermutlich sehen ihn dann noch Nutzer, die nicht aus GitHub, NPM oder Latest installieren können.
                                      • E Offline
                                        Einstein 0
                                        schrieb am zuletzt editiert von Einstein 0
                                        bekomme leider meinen Adapter nicht zu laufen.
                                        Kann mir vielleicht jemand kurz helfen ob meine Konfig so passt?
                                        Habe ein CMI mit folgenden Knoten:
                                        Hier die JSON:
                                        Fehler:
                                        Danke euch...
                                        Gruß Einstein
                                        • E Einstein 0
                                          Hier die JSON:
                                          Fehler:
                                          Danke euch...
                                          Gruß Einstein
                                          W Offline
                                          W Offline
                                          weberk
                                          @einstein-0 : das CMI wird über Ethernetz kontaktiert. Also musst du es als CAN-Knoten rausnehmen.
                                          Bei den anderen Geräten hängt es davon ab, ob wirklich alle die gleichen Objekte liefern können.
                                          Mein Rat: klein anfangen in der Konfiguration und nach und nach hinzufügen. Try and Error, falls die Doku oder die tatsächliche Konfiguration im CMI nicht bekannt sind.
                                          Die beiden UVR1611 mit Input und Output-Objekt sollten ein solches minimales Setting sein, mit dem du einen ersten erfolgreichen Start erleben solltest.
                                          VG - Klaus.
