  4. iobroker host Betriebssystem-Paket-Updates verfügbar
18 Beiträge 6 Kommentatoren 1.8k Aufrufe 4 Beobachtet
  • haselchenH haselchen
    @mike2712
    Wenn Du die Updates durchgeführt hast, dann auf den Button Bestätigen und Schliessen klicken.
    Danach sollte die Meldung nicht mehr auftauchen.
    mike2712
    @haselchen ich habe keine Updates durchgeführt, sondern ein neues Images gezogen, deswegen bin ich unsicher, es scheint ja nicht aktuell zu sein wenn man sich die neueren Versionen anschaut.
    ase-files/stable 12.4+deb12u7 amd64 [upgradable from: 12.4+deb12u5]
    bash/stable 5.2.15-2+b7 amd64 [upgradable from: 5.2.15-2+b2]
    curl/stable 7.88.1-10+deb12u7 amd64 [upgradable from: 7.88.1-10+deb12u5]
    gir1.2-gdkpixbuf-2.0/stable 2.42.10+dfsg-1+deb12u1 amd64 [upgradable from: 2.42.10+dfsg-1+b1]
    git-man/stable-security 1:2.39.5-0+deb12u1 all [upgradable from: 1:2.39.2-1.1]
    git/stable-security 1:2.39.5-0+deb12u1 amd64 [upgradable from: 1:2.39.2-1.1]
    gosu/stable 1.14-1+b10 amd64 [upgradable from: 1.14-1+b6]
    libarchive13/stable,stable-security 3.6.2-1+deb12u1 amd64 [upgradable from: 3.6.2-1]
    libc-bin/stable 2.36-9+deb12u8 amd64 [upgradable from: 2.36-9+deb12u6]
    libc-dev-bin/stable 2.36-9+deb12u8 amd64 [upgradable from: 2.36-9+deb12u6]
    libc-l10n/stable 2.36-9+deb12u8 all [upgradable from: 2.36-9+deb12u6]
    libc6-dev/stable 2.36-9+deb12u8 amd64 [upgradable from: 2.36-9+deb12u6]
    libc6/stable 2.36-9+deb12u8 amd64 [upgradable from: 2.36-9+deb12u6]
    libcurl3-gnutls/stable 7.88.1-10+deb12u7 amd64 [upgradable from: 7.88.1-10+deb12u5]
    libcurl4/stable 7.88.1-10+deb12u7 amd64 [upgradable from: 7.88.1-10+deb12u5]
    libexpat1-dev/stable-security 2.5.0-1+deb12u1 amd64 [upgradable from: 2.5.0-1]
    libexpat1/stable-security 2.5.0-1+deb12u1 amd64 [upgradable from: 2.5.0-1]
    libfreetype-dev/stable 2.12.1+dfsg-5+deb12u3 amd64 [upgradable from: 2.12.1+dfsg-5]
    libfreetype6/stable 2.12.1+dfsg-5+deb12u3 amd64 [upgradable from: 2.12.1+dfsg-5]
    libgdk-pixbuf-2.0-0/stable 2.42.10+dfsg-1+deb12u1 amd64 [upgradable from: 2.42.10+dfsg-1+b1]
    libgdk-pixbuf-2.0-dev/stable 2.42.10+dfsg-1+deb12u1 amd64 [upgradable from: 2.42.10+dfsg-1+b1]
    libgdk-pixbuf2.0-bin/stable 2.42.10+dfsg-1+deb12u1 amd64 [upgradable from: 2.42.10+dfsg-1+b1]
    libgdk-pixbuf2.0-common/stable 2.42.10+dfsg-1+deb12u1 all [upgradable from: 2.42.10+dfsg-1]
    libglib2.0-0/stable 2.74.6-2+deb12u3 amd64 [upgradable from: 2.74.6-2]
    libglib2.0-bin/stable 2.74.6-2+deb12u3 amd64 [upgradable from: 2.74.6-2]
    libglib2.0-data/stable 2.74.6-2+deb12u3 all [upgradable from: 2.74.6-2]
    libglib2.0-dev-bin/stable 2.74.6-2+deb12u3 amd64 [upgradable from: 2.74.6-2]
    libglib2.0-dev/stable 2.74.6-2+deb12u3 amd64 [upgradable from: 2.74.6-2]
    libgnutls30/stable 3.7.9-2+deb12u3 amd64 [upgradable from: 3.7.9-2+deb12u2]
    libgssapi-krb5-2/stable,stable-security 1.20.1-2+deb12u2 amd64 [upgradable from: 1.20.1-2+deb12u1]
    libk5crypto3/stable,stable-security 1.20.1-2+deb12u2 amd64 [upgradable from: 1.20.1-2+deb12u1]
    libkrb5-3/stable,stable-security 1.20.1-2+deb12u2 amd64 [upgradable from: 1.20.1-2+deb12u1]
    libkrb5support0/stable,stable-security 1.20.1-2+deb12u2 amd64 [upgradable from: 1.20.1-2+deb12u1]
    libpython3.11-dev/stable-security 3.11.2-6+deb12u3 amd64 [upgradable from: 3.11.2-6]
    libpython3.11-minimal/stable-security 3.11.2-6+deb12u3 amd64 [upgradable from: 3.11.2-6]
    libpython3.11-stdlib/stable-security 3.11.2-6+deb12u3 amd64 [upgradable from: 3.11.2-6]
    libpython3.11/stable-security 3.11.2-6+deb12u3 amd64 [upgradable from: 3.11.2-6]
    libseccomp2/stable 2.5.4-1+deb12u1 amd64 [upgradable from: 2.5.4-1+b3]
    libssl3/stable-security 3.0.14-1~deb12u2 amd64 [upgradable from: 3.0.11-1~deb12u2]
    libsystemd0/stable 252.30-1~deb12u2 amd64 [upgradable from: 252.22-1~deb12u1]
    libudev-dev/stable 252.30-1~deb12u2 amd64 [upgradable from: 252.22-1~deb12u1]
    libudev1/stable 252.30-1~deb12u2 amd64 [upgradable from: 252.22-1~deb12u1]
    linux-libc-dev/stable 6.1.106-3 amd64 [upgradable from: 6.1.85-1]
    locales/stable 2.36-9+deb12u8 all [upgradable from: 2.36-9+deb12u6]
    nodejs/nodistro 18.20.4-1nodesource1 amd64 [upgradable from: 18.20.2-1nodesource1]
    openssl/stable-security 3.0.14-1~deb12u2 amd64 [upgradable from: 3.0.11-1~deb12u2]
    udev/stable 252.30-1~deb12u2 amd64 [upgradable from: 252.22-1~deb12u1]
    ioBroker im Docker auf Qnap TS-453A 16GB Ram 4-Bay
      Dürfen darfst du das überall, gewusst wie...
      Aber ein vorgekauter Docker-Container sollte dann auch vom Ersteller aktuell gehalten werden.
      Der Verwender muss dann nur regelmäßig das Dosenfutter erneuern.
      mike2712
      schrieb am zuletzt editiert von mike2712
      @thomas-braun das bedeutet das das Image nicht aktuell war? Das war die latest v10 Version
      Ich weiß bei Updates nie was ich machen Muss / Kann / Darf oder Soll :-(
      Meistens schon mal gar nicht wie, Adapter sind einfach, das geht mehr oder weniger alleine.
      • M mike2712
        @mike2712
        Ich weiß nicht was die Debian-Basis für das Image ist.
        Momentan ist PointRelease 12.8 aktuell.
          mike2712
          @thomas-braun Da bin ich auch überfragt, ich war froh das ich das neue ziehen konnte, hab auch gerade keinen Plan wie ich das genau rausbekomme.
          Das einzige was ich rausfinden konnte ist 12. Kann ich das irgendwie rausfinden, kann ich das manuell updaten?
          Scheinbar wurde letzte mal was in v9 gemacht, folgender Auszug aus dem changelog
          v9.0.0 (09.10.2023)
          update official docs
          v9.0.0-beta.2 (28.09.2023)
          fix issue with unlocking features in backitup (#381)
          fix issue with fresh initializing iobroker
          v9.0.0-beta.1 (24.09.2023)
          remove special settings script and env for zwave (#377)
          simplify ci/ reduce gh actions
          ignore errors in "silent cleanup" on first start (#369)
          cleanup/ restructure repo
          update nodejs setup process
          update base image to debian 12 (bookworm)
          improve security by avoiding root (except startup script itself)
          restrict iobroker command line commands (start/ stop/ node fix)
          integrate maintenance script into iobroker command
          move container config files location
          • M mike2712
            v9.0.0 (09.10.2023)
            @mike2712
            Sinn und Zweck eines Dockers ist es ja nicht eine richtige Installation zu ersetzen, sondern eine reproduzierbare Konfiguration des Systems zu haben. Updates des Gesamtsystems über den Paketmanager sind da nicht vorgesehen.
            Weswegen ich die Fertigkost auch nicht verwende.
            • mcm1957M Online
              mcm1957M Online
              mcm1957
              Ab js-controller 6.10.0 sollten keine OS Updates im Docker Umfeld merh gemeldet werden da diese Meldungen dort wenig / keinen Sinn machen.
              https://github.com/ioBroker/ioBroker.js-controller/blob/master/CHANGELOG.md#6010-2024-08-05---kiera
              Kann es sein, dass du noch einen älteren js-controller einsetzt?
              Support Repositoryverwaltung.
              LESEN - gute Forenbeitrage
              • mcm1957M mcm1957
                mike2712
                @mcm1957 laut dem was iobroker sagt, erster Post 7.03
                • M mike2712
                  mcm1957M Online
                  mcm1957M Online
                  mcm1957
                  @mike2712
                  Hmm komisch. Da sollten die News eigentlich nicht mehr kommen.
                  Kann es sein, dass die älter und unbestätigt sind?
                  Sonst ev. @foxriver76 einbinden um zu checlken warum die Updatenotifications noch kommen ob wohld as ein Docker Environment ist.
                  • mcm1957M mcm1957
                    @mike2712
                    mike2712
                    @mcm1957
                    ich bin ehrlich gesagt etwas überfordert, es scheint ja neuere Dateien zu geben, siehe Post Nr.5 , kann soll ich die irgendwie updaten ?
                    • M mike2712
                      @mcm1957
                      Marc BergM Online
                      Marc BergM Online
                      Marc Berg
                      @mike2712 sagte in iobroker host Betriebssystem-Paket-Updates verfügbar:
                      Hier geht einiges durcheinander, aber eigentlich ist es ganz einfach:
                      1. mit aktuelleren JS-Controller- und Admin(!)-Versionen werden im Docker keine Betriebsystem-Updates mehr angezeigt. Stattdessen wird angezeigt, ob es ein aktuelleres Buanet-Image gibt. Um die ganz korrekte Version rauszusuchen, fehlt mir gerade die Zeit.
                      2. auch ein "latest-V10" Image wird regelmäßig aktualisiert, also einfach ein neues Images ziehen, um Betriebssystem Updates zu erhalten.
                      3. Alternativ kann du weiterhin mit apt update/apt upgrade im Container Updates ziehen, wenn du kein neues Image runterladen willst.
                      • Marc BergM Marc Berg
                        mike2712
                        @marc-berg Danke für die Information, das latest-V10 habe ich ja ganz aktuell gezogen, ich werde es händisch versuchen. Vielen Dank
                        • M mike2712
                          Marc BergM Online
                          Marc BergM Online
                          Marc Berg
                          Das kann nicht sein, das aktuelle Image ist vom 05.12. und ist "up to date":
                          root@iobroker:/opt/iobroker# apt update
                          Get:1 http://deb.debian.org/debian bookworm InRelease [151 kB]
                          Get:2 https://repos.influxdata.com/debian stable InRelease [6907 B]
                          Get:3 http://deb.debian.org/debian bookworm-updates InRelease [55.4 kB]
                          Get:4 http://deb.debian.org/debian-security bookworm-security InRelease [48.0 kB]
                          Get:5 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB]
                          Get:6 http://deb.debian.org/debian bookworm/main amd64 Packages [8789 kB]
                          Get:7 https://repos.influxdata.com/debian stable/main amd64 Packages [14.1 kB]
                          Get:8 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages [9928 B]
                          Get:9 http://deb.debian.org/debian bookworm-updates/main amd64 Packages [8856 B]
                          Get:10 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages [236 kB]
                          Fetched 9331 kB in 2s (5175 kB/s)
                          Reading package lists... Done
                          All packages are up to date.
                          Was sagt
                          cat /opt/.docker_config/.build
                            mike2712
                            @marc-berg
                            Irgendwie ist das auch auf QNAP alles anders als sonst, ich weiß gar nicht wie ich in diese Kommandozeile rein komme wo man die Befehle eingeben kann.
                            Unter Inspect konnte ich aber Informationen finden, das File scheint vom 05.12.2024 zu sein.
                            Inspect - buanet/iobroker:latest-v10
                            Architecture:"amd64"
                            Author:""
                            Comment:"buildkit.dockerfile.v0"
                            Config:{
                            AttachStderr:false
                            AttachStdin:false
                            AttachStdout:false
                            Domainname:""
                            Entrypoint:[
                            "/bin/bash"
                            "-c"
                            "/opt/scripts/iobroker_startup.sh"
                            Env:[
                            "PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin"
                            "DEBIAN_FRONTEND=teletype"
                            "BUILD=20241205.234336"
                            "LANG=de_DE.UTF-8"
                            "LANGUAGE=de_DE:de"
                            "LC_ALL=de_DE.UTF-8"
                            "SETGID=1000"
                            "SETUID=1000"
                            "TZ=Europe/Berlin"
                            ExposedPorts:{}
                            Healthcheck:{}
                            Hostname:""
                            Image:""
                            Labels:{}
                            OpenStdin:false
                            StdinOnce:false
                            Tty:false
                            User:""
                            Volumes:{}
                            WorkingDir:"/opt/iobroker/"
                            ContainerConfig:{}
                            Created:"2024-12-05T23:46:01.285830734Z"
                            DockerVersion:""
                            GraphDriver:{}
                            Metadata:{}
                            Os:"linux"
                            Parent:""
                            RepoDigests:[]
                            RepoTags:[]
                            RootFS:{}
                            VirtualSize:1569544565
                              mike2712
                              @marc-berg
                              root@iobroker:/opt/iobroker# cat /opt/.docker_config/.build
                              20241205.234336
