  4. Backitup Fehler Zugriffsrechte? (EACCES: permission denied)
backitupaccess rights
23 Beiträge 3 Kommentatoren 1.6k Aufrufe 2 Beobachtet
  • D Dieter_P
    das wäre nun auf die Schnelle erledigt:
    Pending OS-Updates:     0
    Pending iob updates:    0
                            v.2024-10-19
       Static hostname: iobroker
             Icon name: computer-laptop
               Chassis: laptop
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 5.10.0-33-amd64
          Architecture: x86-64
    Kernel:                 x86_64
    Userland:               64 bit
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    Display-Server:         false
    Boot Target:            multi-user.target
    Nodejs-Installation:
    /usr/bin/nodejs         v20.18.1
    /usr/bin/node           v20.18.1
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    Recommended versions are nodejs 20.18.1 and npm 10.8.2
    nodeJS installation is correct
    MEMORY:
    Mem:            3.8G        2.0G        803M        1.0M        1.0G        1.6G
    Swap:           975M          0B        975M
    Total:          4.8G        2.0G        1.8G
    Active iob-Instances:   22
    Upgrade policy: none
    ioBroker Core:          js-controller           7.0.3
                            admin                   7.1.5
    Objects type: jsonl
    States  type: jsonl
    Objects:                7850
    States:                 6966
    Size of iob-Database:
    22M     /opt/iobroker/iobroker-data/objects.jsonl
    9.2M    /opt/iobroker/iobroker-data/states.jsonl
    Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
    ändert aber leider nichts:
    2024-12-14 10:20:23.400 - error: backitup.0 (923) [iobroker/iobroker] host.iobroker Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2024_12_14-10_20_02_backupiobroker.tar.gz'
    2024-12-14 10:20:23.420 - error: backitup.0 (923) [iobroker/iobroker] host.iobroker Backup not created: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2024_12_14-10_20_02_backupiobroker.tar.gz'
    2024-12-14 10:20:24.448 - error: backitup.0 (923) [iobroker/iobroker] [Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/config.json'] {
    2024-12-14 10:20:24.449 - error: backitup.0 (923) [iobroker/iobroker] errno: -2,
    2024-12-14 10:20:24.450 - error: backitup.0 (923) [iobroker/iobroker] code: 'ENOENT',
    2024-12-14 10:20:24.451 - error: backitup.0 (923) [iobroker/iobroker] syscall: 'open',
    2024-12-14 10:20:24.452 - error: backitup.0 (923) [iobroker/iobroker] path: '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/config.json'
    2024-12-14 10:20:24.453 - error: backitup.0 (923) [iobroker/iobroker] }
    2024-12-14 10:20:24.457 - error: backitup.0 (923) [iobroker/iobroker] [Error: ENOENT: no such file or directory, scandir '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/esphome.0'] {
    2024-12-14 10:20:24.458 - error: backitup.0 (923) [iobroker/iobroker] errno: -2,
    2024-12-14 10:20:24.459 - error: backitup.0 (923) [iobroker/iobroker] code: 'ENOENT',
    2024-12-14 10:20:24.460 - error: backitup.0 (923) [iobroker/iobroker] syscall: 'scandir',
    2024-12-14 10:20:24.462 - error: backitup.0 (923) [iobroker/iobroker] path: '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/esphome.0'
    2024-12-14 10:20:24.463 - error: backitup.0 (923) [iobroker/iobroker] }
    2024-12-14 10:20:24.464 - error: backitup.0 (923) [iobroker/iobroker] [Error: ENOENT: no such file or directory, scandir '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files'] {
    2024-12-14 10:20:24.465 - error: backitup.0 (923) [iobroker/iobroker] errno: -2,
    2024-12-14 10:20:24.466 - error: backitup.0 (923) [iobroker/iobroker] code: 'ENOENT',
    2024-12-14 10:20:24.466 - error: backitup.0 (923) [iobroker/iobroker] syscall: 'scandir',
    2024-12-14 10:20:24.467 - error: backitup.0 (923) [iobroker/iobroker] path: '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files'
    2024-12-14 10:20:24.468 - error: backitup.0 (923) [iobroker/iobroker] }
    2024-12-14 10:20:24.469 - error: backitup.0 (923) [iobroker/iobroker] [Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/objects.jsonl'] {
    2024-12-14 10:20:24.469 - error: backitup.0 (923) [iobroker/iobroker] errno: -2,
    2024-12-14 10:20:24.470 - error: backitup.0 (923) [iobroker/iobroker] code: 'ENOENT',
    2024-12-14 10:20:24.471 - error: backitup.0 (923) [iobroker/iobroker] syscall: 'open',
    2024-12-14 10:20:24.472 - error: backitup.0 (923) [iobroker/iobroker] path: '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/objects.jsonl'
    2024-12-14 10:20:24.472 - error: backitup.0 (923) [iobroker/iobroker] }
    2024-12-14 10:20:25.154 - warn: backitup.0 (923) [iobroker/influxDB] InfluxDB Backup tmp directory cannot created
    2024-12-14 10:20:25.500 - error: backitup.0 (923) [iobroker/influxDB] Error: Command failed: influx backup --bucket iobroker -t aapxj6Xr6CDRT4v_tS8uzlZ0tlmQ== "/opt/iobroker/backups/influxDB_2024_12_14-10_20_25_backupiobroker"
    2024-12-14 10:20:25.501 - error: backitup.0 (923) [iobroker/influxDB] Error: mkdir /opt/iobroker/backups/influxDB_2024_12_14-10_20_25_backupiobroker: permission denied
    2024-12-14 10:20:25.503 - error: backitup.0 (923) [iobroker] Error: Command failed: influx backup --bucket iobroker -t aapxj6Xr6CDRT4v_rAMTz8rXYuP0tlmQ== "/opt/iobroker/backups/influxDB_2024_12_14-10_20_25_backupiobroker"
    2024-12-14 10:20:25.685 - error: backitup.0 (923) [iobroker/mysql] Error: Command failed: mysqldump -u iobroker -p**** iobroker -h localhost -P 3306 > /opt/iobroker/backups/mysql_2024_12_14-10_20_25_backupiobroker.sql
    2024-12-14 10:20:25.687 - error: backitup.0 (923) [iobroker/mysql] /bin/sh: 1: cannot create /opt/iobroker/backups/mysql_2024_12_14-10_20_25_backupiobroker.sql: Permission denied
    2024-12-14 10:20:25.688 - error: backitup.0 (923) [iobroker] Error: Command failed: mysqldump -u iobroker -p**** iobroker -h localhost -P 3306 > /opt/iobroker/backups/mysql_2024_12_14-10_20_25_backupiobroker.sql
    2024-12-14 10:20:26.269 - info: admin.0 (781) ==> Connected system.user.admin from ::ffff:192.168.0.2
    2024-12-14 10:20:26.613 - error: backitup.0 (923) [iobroker/zigbee] Error: EACCES: permission denied, open '/opt/iobroker/backups/zigbee.0_2024_12_14-10_20_26_backupiobroker.tar.gz'
    2024-12-14 10:20:26.614 - error: backitup.0 (923) [iobroker] Error: EACCES: permission denied, open '/opt/iobroker/backups/zigbee.0_2024_12_14-10_20_26_backupiobroker.tar.gz'
    2024-12-14 10:20:26.750 - info: admin.0 (781) <== Disconnect system.user.admin from ::ffff:192.168.0.2 backitup
    2024-12-14 10:20:27.349 - warn: backitup.0 (923) [iobroker/javascripts] Javascript tmp directory "/opt/iobroker/backups/tmpScripts" cannot created ... Error: EACCES: permission denied, mkdir '/opt/iobroker/backups/tmpScripts'
    2024-12-14 10:20:27.750 - error: backitup.0 (923) [iobroker/javascripts] script.json cannot be written: Error: EACCES: permission denied, open '/opt/iobroker/backups/tmpScripts/script.json'
    2024-12-14 10:20:39.783 - warn: backitup.0 (923) [iobroker/javascripts] javascript Backup not created
    2024-12-14 10:20:40.260 - error: backitup.0 (923) [iobroker/esphome] Error: EACCES: permission denied, open '/opt/iobroker/backups/esphome.0_2024_12_14-10_20_40_backupiobroker.tar.gz'
    2024-12-14 10:20:40.262 - error: backitup.0 (923) [iobroker] Error: EACCES: permission denied, open '/opt/iobroker/backups/esphome.0_2024_12_14-10_20_40_backupiobroker.tar.gz'
    2024-12-14 10:20:41.320 - error: backitup.0 (923) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
    @dieter_p sagte in Backitup Fehler Zugriffsrechte? (EACCES: permission denied):
    nochmal bitte zum mitschreiben!
    ich hoffe ich bin jetzt auf dem richtigen Dampfer.
    Der Fehler tritt beim Erstellen eines Backups auf?
    seit dem Stromausfall?
    von dem "nur" das NAS betroffen war?
    stimmen die Zugriffsrechte für den share noch?
    wobei mich diese Art Meldung irritiert
    PS
    da war vor kurzem schon so ein (ähnlicher?) Fall
      PS
      Dieter_P
      @homoran said in Backitup Fehler Zugriffsrechte? (EACCES: permission denied):
      Ja, sowohl automatisierte Backups (bei Mir Nachts um 2:00h) oder manuell angestoßen
      Ich prüfe nach dem Stromausfall wo es überall hakt und finde Backitup. Vermute aber auf Basis der Logs und da eine anderer Stromkreis/Sicherung, dass es vielleicht mit dem Stromausfall nichts zu tun hat. Ausschließen kann ich es leider nicht. Letztes erfolgreiches Backup was auf dem NAS liegt vom 10.12. vielmehr kann ich nicht gesichert sagen.
      Du sprichst vom NAS? Hab die Synology (die war betroffen vom Stromausfall) nun von DSM 6.x auf DSM7.2 hochgezogen, darum könnte dort was sein. Aber der Log meldet
      08:27:42.467	INFO	gui	Backup gestartet ...
      08:27:52.704	DEBUG	mount	nfs-mount command: "sudo mount 192.168.7.100:/volume1/BACKUP/iobroker /opt/iobroker/backups"
      08:27:52.773	DEBUG	mount	mount successfully completed
      08:27:52.826	DEBUG	mount	done
      PS
      Ist ein dedizierter Nutzer mit exklusivem Bereich nur für Backups. Daher müßte ich überlegen wie ich das noch testen könnte.
      Vermutlich mit sowas wie WinSCP und dann NFS über den Log-In von IOBroker
      • D Dieter_P
        PS
        @dieter_p Der ähnliche Fall war wohl nicht ähnlich genug.
        Der bekam auch den Fehler 'could not pack', aber zusätzlich ENOSPACE.
        was es schließlich war, kam nicht endgültig raus. :-(
        Vielleicht weiss @thomas-braun noch mehr.
          Dieter_P
          vermute wir sprechen über den gleichen Fall. Hatte da was über die Suche gefunden und hatte das Problem dort auch aufs NAS/Synology verstanden.
          Ich bin nun aber weiter! Der Stromausfall war 9.12. ca. 19:00h
          Ich habe aber ein erfolgreichreiches Backup auf dem NAS vom 10.12. (2:00h)
          Somit der Stromausfall nicht das Problem für den IOBroker selbst.
          Ob ich danach in den folgenden Tagen durch mein Upgrade auf DSM 7.2 auf dem Synology NAS das Problem verursacht hab, kann weiterhin natürlich sein.
          • D Dieter_P
            https://forum.iobroker.net/post/1227546
            da wurde der mount auch erfolgreich erstellt
            sehe ich auch so
            das meinte ich vorhin mit "anderem Backup"
            D 2 Antworten Letzte Antwort
              sehe ich auch so
              Dieter_P
              Danke. Ich dreh mal in dieser Richtung eine Prüfschleife.
              Edit: Ja. Schnell einfach mal die Speicherung aufs NAS deaktiviert und BackitUp läuft Fehlerfrei durch. Also defintiv dort meine Baustelle und nicht beim IOBroker.
              Danke! (Somit ein aktuelles Backup und einem kompletten neuen Aufbau steht nix im Weg!)
                sehe ich auch so
                Dieter_P
                Die Tests, ergeben für mich keinen erfolgreichen mount bei mir. z.B.:
                pi@iobroker:~$ sudo mount -t nfs 196.168.7.100:/volume1/BACKUP/iobroker /mnt
                mount.nfs: Connection timed out
                Wo es nun bei mir hakt:
                Voherig mit DMS 6.X haben folgende Einstellungen funktioniert:
                Dort wurde doch als root der mount durchgeführt und es gibt keine dedizierte Möglichkeit einen Benutzer mit Passwort in backitup dafür zu konfigurieren? Richtig?
                In dem Synology NAS ist aber für die Zugriffsregel über NFS zwingend als Sicherheit etwas anzulegen:
                Kann gut sein, dass das unter DSM 6.X noch anders war.
                Somit kann das so ohne Benutzer Authentifizierung nicht mehr funktionieren, korrekt?
                • D Dieter_P
                  NFS (in der simpelsten Form ohne Kerberos usw.) funktioniert über die UID/GID des users. Die sollten also auf beiden Systemen gleich sein.
                    Dieter_P
                    @thomas-braun said in Backitup Fehler Zugriffsrechte? (EACCES: permission denied):
                    UID/GID
                    Danke. Da ich keine Möglichkeit sehe Backitup einen anderen User zu geben als "iobroker" hab ich den Benutzer nun auch auf dem NAS angelegt (nicht User: Backup oder sonstwas) und damit funktioniert es!
                    Danke!
                    • D Dieter_P
                      UID/GID
                      Danke!
                      Genauso macht man das.
