  3. Entwicklung
  4. Migration ESLint 9.x
    6.6k
38 Beiträge 9 Kommentatoren 5.9k Aufrufe 11 Beobachtet
  • OliverIOO OliverIO
    @ticaki
    sorry, falsch geschrieben
    T Nicht stören
    T Nicht stören
    ticaki
    @oliverio
    Wow Danke für den Tip.
         * Executes a specified action on the player.
         * @async
         * @param {object} actionVal - The action details.
         * @param {string} actionVal.mode - The mode of the action (e.g., playback, navigation).
         * @param {string} actionVal.action - The specific action to be triggered.
         * @param {any} actionVal.val - The value associated with the action.
         * @description This function checks if the specified action is supported. If it is, it constructs
         * a request to trigger the action on the player using its IP and port. It handles specific action
         * conversions if needed (e.g., percent, lastPlayed, playKey) and logs the execution process.
         * In case of success or failure, appropriate logs are generated.
         * @throws Will log a warning if the action is not supported or if there is an error in triggering the action.
    oder
        /*************  ✨ Codeium Command ⭐  *************/
         * @description
         * Create controls for the player. The controls are created under the node
         * `playing._Controls` and are organized by the protocol capabilities of the player.
         * The controls are created as channels, and each control has a role and a description.
         * The controls are also subscribed to the adapter, so that the adapter can receive
         * updates when the control is changed.
         * @example
         * <pre>
         *     node: 'playing._Controls.playback.play',
         *     role: 'button.play',
         *     description: 'Play'
         * </pre>
        /******  8ebdcdf2-34ee-47e0-b7e4-740379644d94  *******/
    Spenden
    • SKBS Offline
      SKBS Offline
      SKB
      Könnte mir hier wohl jemand helfen, wie man dies in VS Code aktiviert?
      Habe die Extension installiert, aber "Prettier"-Hinweise, sowie Lint Infos bekomme ich nicht. Dafür die "normalen" Fehler, die immer kommen, weil ich die Core Module auf dem Editier-Rechner nicht installiert habe ;)
      L 1 Antwort Letzte Antwort
      • SKBS SKB
        L Online
        L Online
        Lucky_ESA
        @skb sagte in Migration ESLint 9.x:
        Die Anleitung hier ist veraltet und es sollte die Vorgaben vom Core Team verwendet werden.
        Hier der aktuelle Anleitung
        Gruß//Lucky
        SKBS 1 Antwort Letzte Antwort
        • L Lucky_ESA
          Gruß//Lucky
          SKBS Offline
          SKBS Offline
          SKB
          @lucky_esa Danke für deine Antwort - war aber nicht meine Frage. Ich wollte wissen, wie ich VS-Code einstelle, damit der Prettier auch da greift und ich nicht jedes Mal eslint mit --fix aurufen muss, weil die Leerzeichen nich passen ;)
          Dennoch klappte das mit ein wenig Google dann ganz gut.
          • SKBS SKB
            OliverIOO Offline
            OliverIOO Offline
            OliverIO
            @skb
            ich glaube du verwechselst da etwas.
            eslint und prettier sind 2 tools
            1.) prettier formatiert deinen code beim speichern. es können nur relativ wenige vorgaben gemacht werden
            2.) eslint prüft den code auf probleme und kann diese ggfs auch beheben.
            voraussetzungen für irgendwelche vscode erweiterungen, ist, das diese tools über die kommandozeile verfügbar sind (ob global installiert oder über irgendwelche packages, wie iobroker/eslint-config)
            ich verwende die folgenden beiden Erweiterungen
            Name: Prettier - Code formatter
            Description: Code formatter using prettier
            Version: 11.0.0
            Publisher: Prettier
            VS Marketplace Link: https://marketplace.visualstudio.com/items?itemName=esbenp.prettier-vscode
            Description: Integrates ESLint JavaScript into VS Code.
            Version: 3.0.10
            Publisher: Microsoft
            VS Marketplace Link: https://marketplace.visualstudio.com/items?itemName=dbaeumer.vscode-eslint
            diese machen nix anderes, als die tools zu bestimmten Ereignissen (beim speichern, bei code changes, etc) aufzurufen.
            eslint interpretiert den output und stellt bspw diese im Problem-Tab je Datei dar plus irgendwelches gekringele an den entsprechenden Code-Stellen.
            Für prettier muss man evtl. noch das bevorzugte Formatiertool in vscode einstellen
            über Menü File->Preferences>Settings, dann im Suchfeld "default formatter" eingeben.
            anstatt global elint mit dem --fix parameter zu verwenden, kann man in vscode im problemetab direkt rechte maustaste auf ein problem machen. da werden dann evtl für viele probleme automatische fixes angeboten. dort kann auch ggfs. nach problemtyp separat entschieden werden, ob alles oder nur das eine problem nun behoben wird.
            es gibt diese automatischen fixe nicht für alle probleme.
            auch hier kann ich codemium nochmal empfehlen, darüber kann man sich manche probleme detailliert erklären lassen und ggfs auch entsprechende fixes vorschlagen lassen.
            Einen seltsamen Effekt, bei dem ich lange suchen musste war, das eslint angemeckter hat, das ich tabulatro statt spaces verwende, ich das behoben habe, gespeichert habe und dann waren die tabs wieder da, obwohl alles richtig (spaces) eingestellt war.
            ich habe dann die tabulator-zeichen mit einem anderen tool getauscht, danach gab es dieses problem in vscode nicht mehr. es betraf aber auch nur genau eine einzelne datei.
            Meine Adapter und Widgets
            Links im Profil
              @skb
              Version: 11.0.0
              Publisher: Prettier
              Version: 3.0.10
              SKBS Offline
              SKBS Offline
              SKB
              @oliverio Verwechselt habe ich hier eigentlich nichts.
              Wenn ich - genau wie du - die Tabs verwendet habe, wollte Eslint beim prüfen immer die Leerzeichen einfügen, was ja dann durch "--fix" behoben wird. Jedoch wollte ich nicht jedes Mal den Fix durchlaufen lassen - ist ja sinnlos.
              Habe den Prettier jetzt so eingestellt, das er beim Speichern den Code mit den Leerzeichen passend macht, wie in der Prettier-Config von ioBroker.
              Nun laufen die Dinge durch ;)
              Falls es jemand braucht - hier die Settings für VS-Code und prettier:
                "prettier.printWidth": 120,
                "prettier.semi": true,
                "prettier.tabWidth": 4,
                "prettier.useTabs": false,
                "prettier.trailingComma": "all",
                "prettier.singleQuote": true,
                "prettier.singleAttributePerLine": true,
                "prettier.endOfLine": "lf",
                "prettier.bracketSpacing": true,
                "prettier.arrowParens": "avoid",
                "prettier.quoteProps": "as-needed"
              • SKBS SKB
                OliverIOO Offline
                OliverIOO Offline
                OliverIO
                @skb
                wenn du dieser anleitung gefolgt bist, sind das mehr oder weniger genau die einstellungen
                https://github.com/ioBroker/eslint-config/blob/main/MIGRATION.md
                https://github.com/ioBroker/eslint-config/blob/main/prettier.config.mjs
                ich habe bei prettier für markdown noch eine kleine erweiterung drin, das die aufzählungspunkte auch nur mit einem leerzeichen und nicht mit 3 leerzeichen abgetrennt werden
                Links im Profil
                  @skb
                  SKBS Offline
                  SKBS Offline
                  SKB
                  @oliverio Genau - aber, da stand nichts von VS-Code und das war meine Frage, die ich diesbezüglich hatte :)
                  • SKBS SKB
                    OliverIOO Offline
                    OliverIOO Offline
                    OliverIO
                    @skb
                    die konfiguration der tools eslint und prettier ist ja unabhängig von vscode.
                    es soll leute geben, die notepad nutzen und darüber dann ebenfalls automatisiert die befehle im hintergrund aufrufen.
                    wer mit typescript programmiert hat da sozusagen auch ein tool laufen, das auf dateiänderungen scannt und dann sofort das transpiling anstößt. im gleichen zug werdne auch wieder eslint/prettier ausgeführt.
                    Links im Profil
                      @skb
                      SKBS Offline
                      SKBS Offline
                      SKB
                      @oliverio Ich habe nichts anders behauptet.
                      Meine Frage war: "Wie stelle ich VS-Code ein, damit die gleichen Einstellungen wie bei Prettier greifen?"
                      Diese habe ich mir inzwischen selbst beantworten können. Danke!
                      • SKBS SKB
                        OliverIOO Offline
                        OliverIOO Offline
                        OliverIO
                        @skb
                        ja das geht auch, ist aber unnötig wenn man die extenstion verwendet.
                        Links im Profil
                          @skb
                          SKBS Offline
                          SKBS Offline
                          SKB
                          @oliverio Achso, wo ist das denn unnötig?
                          Wenn ich die Extension nutze, greift dort eben nicht die Space, sondern die Tabs und die werden dann von Eslint eben wieder als Warning mitgeteilt.
                          Somit muss man eben die Extension schon einstellen - ansonsten laufen die beiden Dinge eben nicht synchron!
                          OliverIOO T 2 Antworten Letzte Antwort
                          • SKBS SKB
                            OliverIOO Offline
                            OliverIOO Offline
                            OliverIO
                            @skb
                            den effekt hatte ich auch (einmal), hatte ich oben beschrieben
                            Links im Profil
                            • SKBS SKB
                              T Nicht stören
                              T Nicht stören
                              ticaki
                              @skb
                              so sieht meine setting.json aus und es läuft für JS sychron:
                                  "eslint.enable": true,
                                  "editor.defaultFormatter": "esbenp.prettier-vscode",
                                  "[javascript]": {
                                  "json.schemas": [
                                          "fileMatch": [
                                              "io-package.json"
                                          "url": "https://raw.githubusercontent.com/ioBroker/ioBroker.js-controller/master/schemas/io-package.json"
                                          "fileMatch": [
                                              "admin/jsonConfig.json",
                                              "admin/jsonCustom.json",
                                              "admin/jsonTab.json"
                                          "url": "https://raw.githubusercontent.com/ioBroker/adapter-react-v5/main/schemas/jsonConfig.json"
                              ansonsten hab ich die default Einstellungen die mit eslint 9 kommen.
                              Spenden
                              SKBS FeuersturmF 2 Antworten Letzte Antwort
                              • T ticaki
                                @skb
                                    "[javascript]": {
                                    "json.schemas": [
                                            "fileMatch": [
                                                "io-package.json"
                                            "fileMatch": [
                                SKBS Offline
                                SKBS Offline
                                SKB
                                @ticaki Danke, das du mich verstanden hast 😉
                                So in etwa habe ich meine Einstellungen auch - außer eben die Leerzeichen noch aktiviert.
                                • T ticaki
                                  @skb
                                      "[javascript]": {
                                      "json.schemas": [
                                              "fileMatch": [
                                                  "io-package.json"
                                              "fileMatch": [
                                  FeuersturmF Offline
                                  FeuersturmF Offline
                                  Feuersturm
                                  @ticaki Ich versuche gerade ESLint bei mir einzurichten in VSCode. Wenn ich deine settings.json so übernehme bekomme ich folgende Meldung
                                  Fehlt da wirklich ein Komma oder hab ich noch irgendwas falsch konfiguriert?
                                  Ich hab die Erweiterungen Prettier - Code formatter und ESLint in VSCode installiert und der Adapter wurde auch schon auf ESLint 9 umgestellt.
                                  mcm1957M T 2 Antworten Letzte Antwort
                                  • FeuersturmF Feuersturm
                                    mcm1957M Online
                                    mcm1957M Online
                                    mcm1957
                                    @feuersturm
                                    Da fehlt m.E: ein Beistrich vor jsonSchemas um das ein gültige json werden zu lassen.
                                    EDIT: Der Beistrich ist im Example da - ging wohl auf der Reise der Zeichen verloren.
                                    Support Repositoryverwaltung.
                                    LESEN - gute Forenbeitrage
                                    • mcm1957M mcm1957
                                      @feuersturm
                                      FeuersturmF Offline
                                      FeuersturmF Offline
                                      Feuersturm
                                      @mcm1957 Ich musste erst einmal nachlesen, was ein Beistrich ist :-)
                                      Was meinst du damit, dass er im "Example" da ist?
                                      L mcm1957M 2 Antworten Letzte Antwort
                                        L Online
                                        L Online
                                        Lucky_ESA
                                        schrieb am zuletzt editiert von Lucky_ESA
                                        @feuersturm sagte in Migration ESLint 9.x:
                                        Da fehlt ein Komma hinter }
                                          mcm1957M Online
                                          mcm1957M Online
                                          mcm1957
                                          @feuersturm
                                          Sorry, das Example ist auch falsch. Da hab ich schlecht geschaut.
                                          Da gehört ein Komma nach der }
                                          Das File ist ein ganz normales json file was die Syntax betrifft.
