  3. Off Topic
  4. [erledigt]: Unraid oder TrueNAS?
    6.0k
180 Beiträge 19 Kommentatoren 41.7k Aufrufe 12 Beobachtet
  • haselchenH haselchen
    @crunchip
    @Codierknecht
    host.HomeServer
    2024-10-28 22:24:56.256	info	iobroker gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/usocket/node_modules/.bin/node-gyp" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/usocketgyp ERR! node -v v20.18.0gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
    host.HomeServer
    2024-10-28 22:24:56.256	info	iobroker gyp ERR! System Linux 6.1.106-Unraid
    host.HomeServer
    2024-10-28 22:24:56.254	info	iobroker gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/usocket/node_modules/node-gyp/lib/configure.js:117:21)gyp ERR! stack at /opt/iobroker/node_modules/usocket/node_modules/node-gyp/lib/configure.js:84:9gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)
    host.HomeServer
    2024-10-28 22:24:56.254	info	iobroker gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'
    host.HomeServer
    2024-10-28 22:24:56.253	info	iobroker gyp ERR! UNCAUGHT EXCEPTION
    host.HomeServer
    2024-10-28 22:24:55.745	info	iobroker gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
    host.HomeServer
    2024-10-28 22:24:55.540	info	iobroker gyp info using node-gyp@7.1.2gyp info using node@20.18.0 | linux | x64
    host.HomeServer
    2024-10-28 22:24:55.536	info	iobroker gyp info it worked if it ends with ok
    host.HomeServer
    2024-10-28 22:24:55.316	info	iobroker > usocket@0.3.0 install> node-gyp rebuild
    host.HomeServer
    2024-10-28 22:24:54.843	info	iobroker npm warn deprecated gauge@2.7.4: This package is no longer supported.
    host.HomeServer
    2024-10-28 22:24:54.830	info	iobroker npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
    host.HomeServer
    2024-10-28 22:24:54.828	info	iobroker npm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.
    host.HomeServer
    2024-10-28 22:24:54.823	info	iobroker npm warn deprecated npmlog@4.1.2: This package is no longer supported.
    Fragt mich mal seit welchem Update ich diese Fehler bekomme.
    In Unraid wird ja alle Nase lang ne neue Iobroker Container Version angeboten zum Update.
    Ob es mal daran lag oder an einem anderen Update, ich werden beim Aktualisieren der Adapter diese Fehler nicht los.
    Am Ende kommt ein OK und es funktioniert auch alles.
    Aber wie in Gottes Namen werde ich das los?
    CodierknechtC Offline
    Codierknecht
    #158
    @haselchen sagte in [erledigt]: Unraid oder TrueNAS?:
    Gute Frage, nächste Frage :man-shrugging:
    Habe meinen Container gerade erst aufgesetzt (Compose). Dienst auch nur zum Testen.
    HmIP|ZigBee|Tasmota|Unifi
    Zabbix Certified Specialist
      @crunchip
      @Codierknecht
      host.HomeServer
      host.HomeServer
      host.HomeServer
      host.HomeServer
      host.HomeServer
      host.HomeServer
      host.HomeServer
      host.HomeServer
      host.HomeServer
      host.HomeServer
      host.HomeServer
      host.HomeServer
      host.HomeServer
      crunchipC Abwesend
      crunchipC Abwesend
      #159
      @haselchen hab ich auch schon einige Zeit, scheint aber weiter keine Rolle zu spielen
        haselchenH Offline
        haselchenH Offline
        haselchen
        #160
        @crunchip
        Ich weiss nicht, ob mich das beruhigt :) :)
        Stört Dich das nicht bzw. haste bisher nie nach ner Lösung gesucht?
        Hab auch schon alles durchforstet, bekomme wenn nen Access Fehler im Log , wenn ich was mit node-gyp korrigieren will .
        Alles andere ausm Netz hilft auch nicht.
          @crunchip
          crunchipC Abwesend
          crunchipC Abwesend
          #161
          @haselchen Naja, was heisst stören, bisher hab ich noch nicht intensiv nach ner Lösung gesucht, weil ich mich letztendlich eh nicht damit auskenne.
          Ich Weiss nur, daß ich den Fehler erstmalig bei einem shelly Update gesehen hab und bei einem bestehenden Issue mit angefügt hatte (müsste ich aussuchen) da gab es aber diesbezüglich keine Rückmeldung.
          Bin mir auch nicht sicher ob ich kurz zuvor ein neues Docker Image geladen hatte, von daher Weiss ich nicht woher die Meldung kommt.
            haselchenH Offline
            haselchenH Offline
            haselchen
            #162
            @crunchip
            Saaaaage mal, hast Du Bluetooth in Unraid?
            Sprich einen Dongle in den Container durchgereicht?
            Ich hab einen ASUS BT500
            Wird auch schön überall angezeigt, ich bekomme aber den BLE Adapter ums verrecken nicht grün.
            Ganz am Anfang hatte ich es mal geschafft.
            Nun, egal welche Befehle ich eingebe, er bleibt gelb.
            Und ich hab echt alles ausprobiert.
            crunchipC Thomas BraunT 2 Antworten Letzte Antwort
              @crunchip
              crunchipC Abwesend
              crunchipC Abwesend
              #163
              @haselchen das geht nicht mit dem Docker soweit ich gelesen habe, hatte es auch schon vergeblich versucht.
              Weli es nicht als USB Gerät an sich zählt, sondern ein Netzwerkgerät darstellt, was erweiterte Rechte benötigt.
              Bleibt nur die alternative nen pi als slave
                haselchenH Offline
                haselchenH Offline
                haselchen
                #164
                @crunchip
                Also das funktioniert schon .
                Radar2 läuft .
                Und der BLE ging auch .
                Aber ich weiß nicht mehr wie ich das geschafft hatte.
                  @crunchip
                  #165
                  Der Adapter zickt im Moment aber auch auf anderen Systemen. Muss also nicht an Unraid liegen.
                    @crunchip
                    Radar2 läuft .
                    crunchipC Abwesend
                    crunchipC Abwesend
                    #166
                    Radar2 läuft
                    Samt ble?
                    Also ich hatte es mit dem internen Bluetooth probiert, weder in Radar2 noch den BLE selbst zum laufen bekommen.
                    Aber bei mir halb so wild, Radar2 funktioniert ohne ble ja auch und reine ble Geräte hab ich keine mehr, hab auf zigbee umgestellt.
                    haselchenH 2 Antworten Letzte Antwort
                      Radar2 läuft
                      Samt ble?
                      haselchenH Offline
                      haselchenH Offline
                      haselchen
                      #167
                      @crunchip
                      Mich halt es halt gefuchst das der Adapter auf gelb stehenbleibt.
                      Das ist mein innerer Monk 😂
                      Zumal er ja vorher grün war.
                      Und bei Smart Home ist mein Credo: ich muss mich drauf verlassen können.
                      ERSTMAL habe ich das Rumgefummel am BLE auf Eis gelegt.
                      Radar2 funktioniert ja. Aber ich wollte meinen FlowerCare halt, wie früher auch , im BLE anzeigen lassen.
                        Radar2 läuft
                        Samt ble?
                        haselchenH Offline
                        haselchenH Offline
                        haselchen
                        #168
                        @crunchip
                        Ich dümpel seit Stunden durchs Netz.
                        Hast Du adhoc ne Idee , mit welchem Plugin ich mp3 abspielen kann auf der Unraid Gui?
                        Ich hab da einen Musik Ordner , Unraid erkennt auch das es Musik ist (Notensymbol)
                        aber man kann sie nicht abspielen.
                        Ich muss immer per Laptop in den Ordner, um reinzuhören.
                        Hintergrund, ich will wissen ob Radio Edit oder Remix.
                        crunchipC MartinPM 2 Antworten Letzte Antwort
                          @crunchip
                          crunchipC Abwesend
                          crunchipC Abwesend
                          #169
                          @haselchen ich weiss nur den file editor bearbeiten, ob dann mp3`s gehen, kann ich dir nicht sagen, mp4 müsste eigentlich gehen, funktioniert bei mir allerdings nicht
                          https://www.youtube.com/watch?v=3M8TD2nq7FU
                            @crunchip
                            MartinPM Online
                            MartinPM Online
                            MartinP
                            #170
                            @haselchen hmm hat Unraid eine eigene GUi, die auf dem Server läuft, oder läuft die im Browser auf einem Desktop System?
                              haselchenH Offline
                              haselchenH Offline
                              haselchen
                              #171
                              @crunchip
                              Danke für den Tip.
                              Über die config Datei konnte ich ein paar Datei-Endungen hinzufügen.
                              MP3 leider nicht.
                              Wenn ich mal mehr Zeit und Lust habe , stöber ich im Unraid Forum mal rum.
                              Eventuell kann man ja den Musik Ordner mit nem Programm a la Winamp "verheiraten".
                              • MartinPM MartinP
                                Codierknecht
                                #172
                                @martinp sagte in [erledigt]: Unraid oder TrueNAS?:
                                Wie Proxmox: Die GUI ist HTML - also per Browser erreichbar.
                                • CodierknechtC Codierknecht
                                  MartinPM Online
                                  MartinPM Online
                                  MartinP
                                  #173
                                  @codierknecht hmm - dann ist doch der Browser für das Abspielen der mp3 Dateien zuständig.
                                  • MartinPM MartinP
                                    Codierknecht
                                    #174
                                    Wird aber nur als reiner Text in das HTML geprömpelt.
                                    Da kann der Browser dann nix mit anfangen.
                                      MartinPM Online
                                      MartinPM Online
                                      MartinP
                                      #175
                                      @codierknecht sind die Dateien denn im Verzeichnis eines Webservers?
                                      Die Blanks im Dateinamen sind auch nicht gerade hilfreich... müsste man Escapen.
                                        haselchenH Offline
                                        haselchenH Offline
                                        haselchen
                                        #176
                                        @crunchip
                                        Saaaage mal , hast Du auch eine Mail bekommen , dass in 2 Wochen Deine Lizenz automatisch upgegraded wird und man neu bezahlen muss ?
                                          @crunchip
                                          crunchipC Abwesend
                                          crunchipC Abwesend
                                          #177
                                          @haselchen email ja, aber da steht doch nur das es vergünstigt ist, wenn man ein upgrade machen möchte
                                          ansonsten bleibt alles beim alten>> Lifetime☺
