  4. Test Adapter TP-Link Tapo
891 Beiträge 124 Kommentatoren 492.0k Aufrufe 108 Beobachtet
  • M mbw
    @tombox
    Hi zusammen, bei mir funktioniert die P100 leider nicht mit der Version 0.4.1
    tapo.0 2024-11-29 14:52:46.529	info	starting. Version 0.4.1 (non-npm: TA2k/ioBroker.tapo#259c74d007bc086f3f508243dd2c523c5c74ded4) in /opt/iobroker/node_modules/iobroker.tapo, node: v20.18.0, js-controller: 6.0.11
    tapo.0 2024-11-29 14:52:46.581	info	Login tp TAPO App
    tapo.0 2024-11-29 14:52:46.597	debug	QNPZ/8BSviD1DAjHLsWv7Q==
    tapo.0 2024-11-29 14:52:47.005	debug	{"error_code":0,"result":{"lockedMinutes":0,"lastCheckDate":"Fri Nov 29 12:20:16 UTC 2024","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","failedAttempts":0,"riskDetected":0,"remainAttempts":0,"errorCode":"0","supportedMFATypes":[],"token":"XXXX-XXXX","accountId":"XXXX","regionCode":"DE","regTime":"2020-08-12 21:31:15","nickname":"XXXX","email":"XXXX","refreshToken":"XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"}}
    tapo.0 2024-11-29 14:52:47.007	info	Login succesfull
    tapo.0 2024-11-29 14:52:47.009	debug	yfoQzXVQIYQWjRDZuXyppQ==
    tapo.0 2024-11-29 14:52:47.229	debug	{"error_code":0,"result":{"totalNum":1,"deviceList":[{"deviceType":"SMART.TAPOPLUG","role":0,"fwVer":"1.3.7 Build 20230711 Rel. 61904","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"8022EE8F8F78F7107794A37DA2C24FCC1CEA0F01","deviceName":"P100","deviceHwVer":"1.0","alias":"U21hcnRlIFN0ZWNrZG9zZQ==","deviceMac":"B09575BA1B94","oemId":"9552772F906C60A9AEEA36A3347B6EBC","deviceModel":"P100","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","isSameRegion":true,"status":0}],"currentIndex":0}}
    tapo.0 2024-11-29 14:52:47.231	info	Found 1 devices
    tapo.0 2024-11-29 14:52:47.233	debug	Found device 8022EE8F8F78F7107794A37DA2C24FCC1CEA0F01 Smarte Steckdose
    tapo.0 2024-11-29 14:52:47.493	debug	{"hwVer":"1.0","category":"plug","model":"P100","ssid":"ZmF3by5uZXQuaG9tZQ==","mac":"B09575BA1B94","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","oemId":"9552772F906C60A9AEEA36A3347B6EBC","fwVer":"1.3.7 Build 20230711 Rel. 61904","ip":"192.168.6.134","onboardingTime":1732888328,"role":0,"deviceType":"SMART.TAPOPLUG","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com"}
    tapo.0 2024-11-29 14:52:47.496	info	Init device 8022EE8F8F78F7107794A37DA2C24FCC1CEA0F01 type P100 with ip 192.168.6.134
    tapo.0 2024-11-29 14:52:47.498	debug	Constructing P100 on host: 192.168.6.134
    tapo.0 2024-11-29 14:52:47.578	debug	Handshake P100 on host: 192.168.6.134
    tapo.0 2024-11-29 14:52:47.626	debug	Received Handshake P100 on host response: 192.168.6.134
    tapo.0 2024-11-29 14:52:47.631	error	106 Error Code: 0, Success 192.168.6.134
    tapo.0 2024-11-29 14:52:47.632	debug	Detected KLAP device
    tapo.0 2024-11-29 14:52:47.633	debug	Trying new habdshake
    tapo.0 2024-11-29 14:52:47.852	error	276 Error: Request failed with status code 404
    tapo.0 2024-11-29 14:52:47.854	error	TypeError: res.subarray is not a function
    tapo.0 2024-11-29 14:52:47.854	error	KLAP Handshake failed
    tapo.0 2024-11-29 14:52:47.855	error	undefined
    tapo.0 2024-11-29 14:52:47.856	error	52 - Get Device Info failed
    tapo.0 2024-11-29 14:52:47.856	info	Initialized 8022EE8F8F78F7107794A37DA2C24FCC1CEA0F01
    tapo.0 2024-11-29 14:52:47.856	debug	initResult 8022EE8F8F78F7107794A37DA2C24FCC1CEA0F01 undefined
    tapo.0 2024-11-29 14:52:47.878	info	Wait for connections for non camera devices
    tapo.0 2024-11-29 14:52:57.879	info	Start first Update
    tapo.0 2024-11-29 14:52:57.880	debug	Update done
    T
    T
    tombox
    #619
    @mbw bitte die GitHub version testen
    Firmware update ist nicht verfügbar?
    • T tombox
      M
      M
      mbw
      #620
      @tombox ich habe die Version von github installiert. Firmware ist auf dem neuesten Stand.
      • T tombox
        @hant0r bitte mit 0.4.1 testen
        Hant0rH
        Hant0rH
        Hant0r
        #621
        @tombox sagte in Test Adapter TP-Link Tapo:
        Habe ich installiert. Dennoch wird das Log zugesamt :D
        tapo.0 2024-11-29 21:00:02.365	info	true
        tapo.0 2024-11-29 21:00:02.356	info	true
        tapo.0 2024-11-29 20:55:02.309	info	true
        tapo.0 2024-11-29 20:55:02.302	info	true
        tapo.0 2024-11-29 20:50:02.220	info	true
        tapo.0 2024-11-29 20:50:02.207	info	true
        tapo.0 2024-11-29 20:45:02.534	info	true
        tapo.0 2024-11-29 20:45:02.299	info	true
        Hatte eben auch das hier
        tapo.0 2024-11-29 20:45:02.292	warn	State "tapo.0.80220719A059A5A7CC58B902714B8CC72~~~~~~~.tod`y_runtime" has no existing object, this might lead to an error in future versions
        Aber die Namen sind nun bei der DPs drin 😇 .. mega - vielen Dank 😘👏
        • M mbw
          T
          T
          tombox
          #622
          @mbw Bitte erneut installieren und Instanz neustarten
          M 2 Antworten Letzte Antwort
          • Hant0rH Hant0r
            T
            T
            tombox
            #623
            @hant0r Wird dauernd die Farbe verändert oder sowas bitte auch die aktuelle GitHub version testen
            Hant0rH 1 Antwort Letzte Antwort
            • T tombox
              Hant0rH
              Hant0rH
              Hant0r
              #624
              Habe die neuste Version (v0.4.2-beta.0) installiert, aber es kommt immer noch drei mal alle 5 Minuten.
              Ich verändere keine Farbe oder so. Ich habe von Tapo nur 5 Zwischenstecker.
              tapo.0 2024-12-01 14:15:02.290	info	setPowerState result: true
              tapo.0 2024-12-01 14:15:02.285	info	setPowerState result: true
              tapo.0 2024-12-01 14:15:02.267	info	setPowerState result: true
              tapo.0 2024-12-01 14:10:02.309	info	setPowerState result: true
              tapo.0 2024-12-01 14:10:02.305	info	setPowerState result: true
              tapo.0 2024-12-01 14:10:02.300	info	setPowerState result: true
              tapo.0 2024-12-01 14:05:02.296	info	setPowerState result: true
              tapo.0 2024-12-01 14:05:02.289	info	setPowerState result: true
              tapo.0 2024-12-01 14:05:02.275	info	setPowerState result: true
              tapo.0 2024-12-01 14:00:02.381	info	setPowerState result: true
              tapo.0 2024-12-01 14:00:02.379	info	setPowerState result: true
              tapo.0 2024-12-01 14:00:02.375	info	setPowerState result: true
              • Hant0rH Hant0r
                T
                T
                tombox
                #625
                @hant0r weil du setPowerState alle 5 Minuten auf true setzt
                Hant0rH Walter WhiteW 2 Antworten Letzte Antwort
                • T tombox
                  Hant0rH
                  Hant0rH
                  Hant0r
                  #626
                  Hmm, im Moment ist es eigentlich hell und alle Lichter sind daher aus (Dekolichter) ... muss ich mal die Scritpe debuggen, wo das gesetzt wird.
                  Abgesehen davon, dass ggf. meine Scripte nicht sehr sinnvoll aufgebaut sind, indem ein True-Wert auf True gesetzt wird, aber macht diese "Info" Sinn im Log?
                  • T tombox
                    M
                    M
                    mbw
                    #627
                    @tombox Hi nochmal, habe den Adapter komplett entfernt und neu installiert in Version v0.4.2-beta. Benutzerdaten neu eingegeben und bekomme jetzt folgende Meldung im log:
                    2024-12-02 09:03:38.911  - warn: tapo.0 (1423626) Could not perform strict object check of state tapo.0.info.connection: DB closed
                    2024-12-02 09:03:47.305  - error: tapo.0 (1423661) 106 Error Code: 0, Success 192.168.6.134
                    2024-12-02 09:03:47.538  - error: tapo.0 (1423661) 276 Error: Request failed with status code 404
                    2024-12-02 09:03:47.540  - error: tapo.0 (1423661) TypeError: res.subarray is not a function
                    2024-12-02 09:03:47.540  - error: tapo.0 (1423661) KLAP Handshake failed. Try old handshake
                    2024-12-02 09:03:47.543  - error: tapo.0 (1423661) undefined
                    2024-12-02 09:03:47.543  - error: tapo.0 (1423661) 52 - Get Device Info failed
                    P100 lässt sich nicht schalten.
                    • T tombox
                      Walter WhiteW
                      Walter WhiteW
                      Walter White
                      #628
                      @tombox bei mir funktioniert auch Version 0.4.2 Beta immer noch nicht:
                      • Hant0rH
                        Hant0rH
                        Hant0r
                        #629
                        Ich habe eben nochmal etwas rumprobiert, weil ich micht gewundert hatte nur "true" Werte im Log zu haben. Und tatsächlich, im Log wird immer protokolliert, dass der Wert auf true gesetzt wird. Egal welchen Wert er in Wirklichkeit bekommt.
                        Ulkig ist dabei: Wird der Wert nochmals auf den selben gesetzt (den er schon hatte), wird es einmal im Log protokolliert, ändert man den Wert (z. B: von true auf false) kommt das ganze zweimal:
                        tapo.0       2024-12-03 09:04:07.876	info	setPowerState result: true
                        tapo.0       2024-12-03 09:04:07.862	info	setPowerState result: true
                        javascript.0 2024-12-03 09:04:06.754	info	script.js.Test.Skript_2: Wert "tapo.0.80163291F3***.remote.setPowerState" ist "true" - setze ihn in 1 sek auf "false"
                        tapo.0       2024-12-03 09:03:56.787	info	setPowerState result: true
                        javascript.0 2024-12-03 09:03:55.753	info	script.js.Test.Skript_2: Wert "tapo.0.80163291F3***.remote.setPowerState" ist "true" - setze ihn in 1 sek nochmal auf "true"
                        tapo.0       2024-12-03 09:03:45.876	info	setPowerState result: true
                        tapo.0       2024-12-03 09:03:45.862	info	setPowerState result: true
                        javascript.0 2024-12-03 09:03:44.752	info	script.js.Test.Skript_2: Wert "tapo.0.80163291F3***.remote.setPowerState" ist "false" - setze ihn in 1 sek auf "true"
                        tapo.0       2024-12-03 09:03:34.779	info	setPowerState result: true
                        javascript.0 2024-12-03 09:03:33.752	info	script.js.Test.Skript_2: Wert "tapo.0.80163291F3***.remote.setPowerState" ist "false" - setze ihn in 1 sek nochmal auf "false"
                        • T tombox
                          M
                          M
                          mbw
                          #630
                          @tombox ich habe mir auf einem Raspberry PI jetzt diese Python-Lib installiert und kann damit die P100-Steckdose schalten. Vielleicht kann man da was vergleichen...
                          TapoP100
                          • S
                            S
                            SaarlandUHU
                            schrieb am zuletzt editiert von SaarlandUHU
                            #631
                            Ich habe seit gestern das Phänomen, dass meine Steckdosen zwar als Objekt auftauchen, aber die Steuerung nicht funktioniert. Die Kamera, die ebenfalls verbunden ist, funktioniert.
                            Ich habe die aktuellste Version von github installiert. Habe auch den Adapter mal komplett entfernt, aber leider auch keine Besserung. Testweise habe ich eine der Steckaus der App entfernt, zurückgesetzt und neu a gelernt, aber auch das hat keine Besserung gebracht.
                            Unten noch das log mit den Meldungen vom tapo-Adapter
                            Vielen Dank schonmal für eure Hilfen.
                            2024-12-03 16:55:38.028 - info: tapo.0 (349204) starting. Version 0.4.2-beta.0 (non-npm: TA2k/ioBroker.tapo#a2dd9aa04e398cc529e52200885617655d09e11d) in /opt/iobroker/node_modules/iobroker.tapo, node: v20.18.0, js-controller: 7.0.3
                            2024-12-03 16:55:38.051 - info: tapo.0 (349204) Login tp TAPO App
                            2024-12-03 16:55:38.399 - info: tapo.0 (349204) Login succesfull
                            2024-12-03 16:55:38.602 - info: tapo.0 (349204) Found 9 devices
                            2024-12-03 16:55:38.925 - info: tapo.0 (349204) Init device 802223B4BB0D32243FD8BAAC89D0DACF1F0646E8 type P100 with ip 192.168.178.47
                            2024-12-03 16:55:39.001 - info: tapo.0 (349204) Trying KLAP Auth
                            2024-12-03 16:55:39.076 - error: tapo.0 (349204) 276 Error: socket hang up
                            2024-12-03 16:55:39.077 - error: tapo.0 (349204) TypeError: res.subarray is not a function
                            2024-12-03 16:55:39.077 - error: tapo.0 (349204) KLAP Handshake failed. Try old handshake
                            2024-12-03 16:55:39.077 - error: tapo.0 (349204) undefined
                            2024-12-03 16:55:39.078 - error: tapo.0 (349204) 52 - Get Device Info failed
                            2024-12-03 16:55:39.078 - info: tapo.0 (349204) Initialized 802223B4BB0D32243FD8BAAC89D0DACF1F0646E8
                            2024-12-03 16:55:39.278 - info: tapo.0 (349204) Init device 80225099418DA3FAA1D0664722DDDC5E1F066D97 type P100 with ip 192.168.178.83
                            2024-12-03 16:55:39.325 - info: tapo.0 (349204) Trying KLAP Auth
                            2024-12-03 16:55:39.330 - error: tapo.0 (349204) 276 Error: socket hang up
                            2024-12-03 16:55:39.331 - error: tapo.0 (349204) TypeError: res.subarray is not a function
                            2024-12-03 16:55:39.331 - error: tapo.0 (349204) KLAP Handshake failed. Try old handshake
                            2024-12-03 16:55:39.331 - error: tapo.0 (349204) undefined
                            2024-12-03 16:55:39.331 - error: tapo.0 (349204) 52 - Get Device Info failed
                            2024-12-03 16:55:39.331 - info: tapo.0 (349204) Initialized 80225099418DA3FAA1D0664722DDDC5E1F066D97
                            2024-12-03 16:55:39.663 - info: tapo.0 (349204) Init device 802268D4FFE5C5601E347444D0A04B8B1F0646F2 type P100 with ip 192.168.178.46
                            2024-12-03 16:55:39.726 - info: tapo.0 (349204) Trying KLAP Auth
                            2024-12-03 16:55:39.730 - error: tapo.0 (349204) 276 Error: socket hang up
                            2024-12-03 16:55:39.731 - error: tapo.0 (349204) TypeError: res.subarray is not a function
                            2024-12-03 16:55:39.731 - error: tapo.0 (349204) KLAP Handshake failed. Try old handshake
                            2024-12-03 16:55:39.731 - error: tapo.0 (349204) undefined
                            2024-12-03 16:55:39.731 - error: tapo.0 (349204) 52 - Get Device Info failed
                            2024-12-03 16:55:39.731 - info: tapo.0 (349204) Initialized 802268D4FFE5C5601E347444D0A04B8B1F0646F2
                            2024-12-03 16:55:39.948 - info: tapo.0 (349204) Init device 80221A1E53A32FBD1405E7644240FEFA1F6DA9F0 type P100 with ip 192.168.178.73
                            2024-12-03 16:55:40.011 - info: tapo.0 (349204) Trying KLAP Auth
                            2024-12-03 16:55:40.014 - error: tapo.0 (349204) 276 Error: socket hang up
                            2024-12-03 16:55:40.014 - error: tapo.0 (349204) TypeError: res.subarray is not a function
                            2024-12-03 16:55:40.015 - error: tapo.0 (349204) KLAP Handshake failed. Try old handshake
                            2024-12-03 16:55:40.015 - error: tapo.0 (349204) undefined
                            2024-12-03 16:55:40.015 - error: tapo.0 (349204) 52 - Get Device Info failed
                            2024-12-03 16:55:40.015 - info: tapo.0 (349204) Initialized 80221A1E53A32FBD1405E7644240FEFA1F6DA9F0
                            2024-12-03 16:55:40.238 - info: tapo.0 (349204) Init device 802217E11A793DE8F5E95B43F48523D71F6EE40F type P100 with ip 192.168.178.84
                            2024-12-03 16:55:40.284 - info: tapo.0 (349204) Trying KLAP Auth
                            2024-12-03 16:55:40.287 - error: tapo.0 (349204) 276 Error: socket hang up
                            2024-12-03 16:55:40.288 - error: tapo.0 (349204) TypeError: res.subarray is not a function
                            2024-12-03 16:55:40.288 - error: tapo.0 (349204) KLAP Handshake failed. Try old handshake
                            2024-12-03 16:55:40.288 - error: tapo.0 (349204) undefined
                            2024-12-03 16:55:40.288 - error: tapo.0 (349204) 52 - Get Device Info failed
                            2024-12-03 16:55:40.288 - info: tapo.0 (349204) Initialized 802217E11A793DE8F5E95B43F48523D71F6EE40F
                            2024-12-03 16:55:40.522 - info: tapo.0 (349204) Init device 80227C9387D02CB80B2A97FAA7B45D451F6DBE41 type P100 with ip 192.168.178.79
                            2024-12-03 16:55:40.632 - info: tapo.0 (349204) Trying KLAP Auth
                            2024-12-03 16:55:40.635 - error: tapo.0 (349204) 276 Error: socket hang up
                            2024-12-03 16:55:40.636 - error: tapo.0 (349204) TypeError: res.subarray is not a function
                            2024-12-03 16:55:40.636 - error: tapo.0 (349204) KLAP Handshake failed. Try old handshake
                            2024-12-03 16:55:40.636 - error: tapo.0 (349204) undefined
                            2024-12-03 16:55:40.636 - error: tapo.0 (349204) 52 - Get Device Info failed
                            2024-12-03 16:55:40.636 - info: tapo.0 (349204) Initialized 80227C9387D02CB80B2A97FAA7B45D451F6DBE41
                            2024-12-03 16:55:40.946 - info: tapo.0 (349204) Init device 8021A5C95BDC23B3A5C4ED9A6B165AB421F4DC24 type C510W 1.0 with ip 192.168.178.104
                            2024-12-03 16:55:41.072 - info: tapo.0 (349204) 8021A5C95BDC23B3A5C4ED9A6B165AB421F4DC24 Received device info {"manufacturer":"tp-link","model":"Tapo C510W","firmwareVersion":"1.2.3 Build 240802 Rel.52500n","serialNumber":"a1382fe0","hardwareId":1}
                            2024-12-03 16:55:41.080 - info: tapo.0 (349204) Initialized 8021A5C95BDC23B3A5C4ED9A6B165AB421F4DC24
                            2024-12-03 16:55:41.354 - info: tapo.0 (349204) Init device 8022409EF7482B099F90B71629A073D31F050586 type P100 with ip 192.168.178.48
                            2024-12-03 16:55:41.402 - info: tapo.0 (349204) Trying KLAP Auth
                            2024-12-03 16:55:41.407 - error: tapo.0 (349204) 276 Error: socket hang up
                            2024-12-03 16:55:41.407 - error: tapo.0 (349204) TypeError: res.subarray is not a function
                            2024-12-03 16:55:41.407 - error: tapo.0 (349204) KLAP Handshake failed. Try old handshake
                            2024-12-03 16:55:41.407 - error: tapo.0 (349204) undefined
                            2024-12-03 16:55:41.407 - error: tapo.0 (349204) 52 - Get Device Info failed
                            2024-12-03 16:55:41.407 - info: tapo.0 (349204) Initialized 8022409EF7482B099F90B71629A073D31F050586
                            2024-12-03 16:55:41.644 - info: tapo.0 (349204) Init device 8022F09FD11B3954491C051CBA331E321F6E863A type P100 with ip 192.168.178.85
                            2024-12-03 16:55:41.714 - info: tapo.0 (349204) Trying KLAP Auth
                            2024-12-03 16:55:41.721 - error: tapo.0 (349204) 276 Error: socket hang up
                            2024-12-03 16:55:41.722 - error: tapo.0 (349204) TypeError: res.subarray is not a function
                            2024-12-03 16:55:41.722 - error: tapo.0 (349204) KLAP Handshake failed. Try old handshake
                            2024-12-03 16:55:41.722 - error: tapo.0 (349204) undefined
                            2024-12-03 16:55:41.722 - error: tapo.0 (349204) 52 - Get Device Info failed
                            2024-12-03 16:55:41.722 - info: tapo.0 (349204) Initialized 8022F09FD11B3954491C051CBA331E321F6E863A
                            2024-12-03 16:55:41.783 - info: tapo.0 (349204) Wait for connections for non camera devices
                            • M mbw
                              TapoP100
                              T
                              T
                              tombox
                              #632
                              @mbw Funktioniert denn v0.3.3 bei dir?
                              • S SaarlandUHU
                                T
                                T
                                tombox
                                #633
                                @saarlanduhu @mbw
                                Bitte die GitHub version testen und debug log schicken
                                S Mr. QiM 2 Antworten Letzte Antwort
                                • T tombox
                                  @saarlanduhu @mbw
                                  S
                                  S
                                  SaarlandUHU
                                  #634
                                  @tombox habe die v0.4.2-beta.1 installiert, nachfolgend die Logeinträge vom Tapo-Adapter nach dem Adapterstart.
                                  2024-12-04 20:52:58.874 - debug: tapo.0 (10659) Redis Objects: Use Redis connection: 0.0.0.0:9001
                                  2024-12-04 20:52:58.902 - debug: tapo.0 (10659) Objects client ready ... initialize now
                                  2024-12-04 20:52:58.903 - debug: tapo.0 (10659) Objects create System PubSub Client
                                  2024-12-04 20:52:58.904 - debug: tapo.0 (10659) Objects create User PubSub Client
                                  2024-12-04 20:52:58.964 - debug: tapo.0 (10659) Objects client initialize lua scripts
                                  2024-12-04 20:52:58.968 - debug: tapo.0 (10659) Objects connected to redis: 0.0.0.0:9001
                                  2024-12-04 20:52:59.002 - debug: tapo.0 (10659) Redis States: Use Redis connection: 0.0.0.0:9000
                                  2024-12-04 20:52:59.023 - debug: tapo.0 (10659) States create System PubSub Client
                                  2024-12-04 20:52:59.023 - debug: tapo.0 (10659) States create User PubSub Client
                                  2024-12-04 20:52:59.101 - debug: tapo.0 (10659) States connected to redis: 0.0.0.0:9000
                                  2024-12-04 20:52:59.131 - debug: tapo.0 (10659) Plugin sentry Initialize Plugin (enabled=true)
                                  2024-12-04 20:52:59.322 - info: tapo.0 (10659) starting. Version 0.4.2-beta.1 (non-npm: TA2k/ioBroker.tapo#516afe55b3c7b3d96b88654bee9be7c715bcf185) in /opt/iobroker/node_modules/iobroker.tapo, node: v20.18.0, js-controller: 7.0.3
                                  2024-12-04 20:52:59.344 - info: tapo.0 (10659) Login tp TAPO App
                                  2024-12-04 20:52:59.390 - debug: tapo.0 (10659) 2hbOJ6AxBUzD8XglsNYpdg==
                                  2024-12-04 20:52:59.849 - debug: tapo.0 (10659) {"error_code":0,"result":{"lockedMinutes":0,"lastCheckDate":"Tue Nov 12 10:35:38 UTC 2024","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","failedAttempts":0,"riskDetected":0,"remainAttempts":0,"errorCode":"0","supportedMFATypes":[],"token":"0f9b4e47-BTP348LlHA6YpYsab3S0LqP","accountId":"46592481","regionCode":"DE","regTime":"2021-11-15 18:57:35","nickname":"krass.dan","email":"krass.dan@gmail.com","refreshToken":"45e2eb3089fe476bbfeeeebb960366b4"}}
                                  2024-12-04 20:52:59.850 - info: tapo.0 (10659) Login succesfull
                                  2024-12-04 20:52:59.850 - debug: tapo.0 (10659) yfoQzXVQIYQWjRDZuXyppQ==
                                  2024-12-04 20:53:00.056 - debug: tapo.0 (10659) {"error_code":0,"result":{"totalNum":9,"deviceList":[{"deviceType":"SMART.TAPOPLUG","role":0,"fwVer":"1.5.5 Build 20230927 Rel. 40646","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"802223B4BB0D32243FD8BAAC89D0DACF1F0646E8","deviceName":"P100","deviceHwVer":"1.20.0","alias":"V0IgS8O8Y2hlIFN0cmHDn2U=","deviceMac":"B0A7B9DD961D","oemId":"D7C5ADFD37188938BA82FD0FE208D1E7","deviceModel":"P100","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","isSameRegion":true,"status":0},{"deviceType":"SMART.TAPOPLUG","role":0,"fwVer":"1.5.5 Build 20230927 Rel. 40646","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"80225099418DA3FAA1D0664722DDDC5E1F066D97","deviceName":"P100","deviceHwVer":"1.20.0","alias":"V0IgQmFk","deviceMac":"B0A7B9DD95F9","oemId":"D7C5ADFD37188938BA82FD0FE208D1E7","deviceModel":"P100","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","isSameRegion":true,"status":0},{"deviceType":"SMART.TAPOPLUG","role":0,"fwVer":"1.5.5 Build 20230927 Rel. 40646","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"802268D4FFE5C5601E347444D0A04B8B1F0646F2","deviceName":"P100","deviceHwVer":"1.20.0","alias":"V0IgS8O8Y2hlIHPDvGQ=","deviceMac":"B0A7B9DD9BCA","oemId":"D7C5ADFD37188938BA82FD0FE208D1E7","deviceModel":"P100","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","isSameRegion":true,"status":0},{"deviceType":"SMART.TAPOPLUG","role":0,"fwVer":"1.5.5 Build 20230927 Rel. 40646","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"80221A1E53A32FBD1405E7644240FEFA1F6DA9F0","deviceName":"P100","deviceHwVer":"1.20.0","alias":"V0IgRmVuc3RlciBzw7xk","deviceMac":"B4B024E5B643","oemId":"D7C5ADFD37188938BA82FD0FE208D1E7","deviceModel":"P100","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","isSameRegion":true,"status":0},{"deviceType":"SMART.TAPOPLUG","role":0,"fwVer":"1.5.5 Build 20230927 Rel. 40646","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"802217E11A793DE8F5E95B43F48523D71F6EE40F","deviceName":"P100","deviceHwVer":"1.20.0","alias":"V0IgQmFsa29uIGxpbmtz","deviceMac":"B4B024E5A05C","oemId":"D7C5ADFD37188938BA82FD0FE208D1E7","deviceModel":"P100","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","isSameRegion":true,"status":0},{"deviceType":"SMART.TAPOPLUG","role":0,"fwVer":"1.5.5 Build 20230927 Rel. 40646","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"80227C9387D02CB80B2A97FAA7B45D451F6DBE41","deviceName":"P100","deviceHwVer":"1.20.0","alias":"V0IgQmFsa29uIHJlY2h0cw==","deviceMac":"B4B024E5BED5","oemId":"D7C5ADFD37188938BA82FD0FE208D1E7","deviceModel":"P100","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","isSameRegion":true,"status":0},{"deviceType":"SMART.IPCAMERA","role":0,"fwVer":"1.2.3 Build 240802 Rel.52500n","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"8021A5C95BDC23B3A5C4ED9A6B165AB421F4DC24","deviceName":"C510W 1.0","deviceHwVer":"1.0","alias":"Kamera Carport 360","deviceMac":"A842A1382FE0","oemId":"CBF298FDF6A1EA18D53CCB1E4D60CCB9","deviceModel":"C510W","hwId":"FE658AE4C353452D7B112AB94C679C3D","fwId":"B0A5537E15AA5B2FF42EE5C7F1897445","isSameRegion":true,"status":0},{"deviceType":"SMART.TAPOPLUG","role":0,"fwVer":"1.5.5 Build 20230927 Rel. 40646","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"8022409EF7482B099F90B71629A073D31F050586","deviceName":"P100","deviceHwVer":"1.20.0","alias":"V0IgVHJlcHBlbmZlbnN0ZXI=","deviceMac":"B0A7B9DD8161","oemId":"D7C5ADFD37188938BA82FD0FE208D1E7","deviceModel":"P100","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","isSameRegion":true,"status":0},{"deviceType":"SMART.TAPOPLUG","role":0,"fwVer":"1.5.5 Build 20230927 Rel. 40646","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"8022F09FD11B3954491C051CBA331E321F6E863A","deviceName":"P100","deviceHwVer":"1.20.0","alias":"V0IgQsO8cm8=","deviceMac":"B4B024E5C6FD","oemId":"D7C5ADFD37188938BA82FD0FE208D1E7","deviceModel":"P100","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","isSameRegion":true,"status":0}],"currentIndex":8}}
                                  2024-12-04 20:53:00.056 - info: tapo.0 (10659) Found 9 devices
                                  2024-12-04 20:53:00.056 - debug: tapo.0 (10659) Found device 802223B4BB0D32243FD8BAAC89D0DACF1F0646E8 WB Küche Straße
                                  2024-12-04 20:53:00.371 - debug: tapo.0 (10659) {"hwVer":"1.20.0","category":"plug","model":"P100","ssid":"d0lOVEVSTkVUWl9pc19jb21pbmc=","mac":"B0A7B9DD961D","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","oemId":"D7C5ADFD37188938BA82FD0FE208D1E7","fwVer":"1.5.5 Build 20230927 Rel. 40646","ip":"192.168.178.47","onboardingTime":1,"role":0,"deviceType":"SMART.TAPOPLUG","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com"}
                                  2024-12-04 20:53:00.372 - info: tapo.0 (10659) Init device 802223B4BB0D32243FD8BAAC89D0DACF1F0646E8 type P100 with ip 192.168.178.47
                                  2024-12-04 20:53:00.372 - debug: tapo.0 (10659) Constructing P100 on host: 192.168.178.47
                                  2024-12-04 20:53:00.420 - debug: tapo.0 (10659) Old Handshake P100 on host: 192.168.178.47
                                  2024-12-04 20:53:00.443 - debug: tapo.0 (10659) Received Old Handshake P100 on host response: 192.168.178.47
                                  2024-12-04 20:53:00.443 - info: tapo.0 (10659) Trying KLAP Auth
                                  2024-12-04 20:53:00.443 - debug: tapo.0 (10659) Detected KLAP device
                                  2024-12-04 20:53:00.444 - debug: tapo.0 (10659) Trying new handshake
                                  2024-12-04 20:53:00.509 - error: tapo.0 (10659) 276 Error: socket hang up
                                  2024-12-04 20:53:00.510 - debug: tapo.0 (10659) New Handshake 1 failed
                                  2024-12-04 20:53:00.510 - error: tapo.0 (10659) undefined
                                  2024-12-04 20:53:00.510 - error: tapo.0 (10659) 52 - Get Device Info failed
                                  2024-12-04 20:53:00.510 - info: tapo.0 (10659) Initialized 802223B4BB0D32243FD8BAAC89D0DACF1F0646E8
                                  2024-12-04 20:53:00.510 - debug: tapo.0 (10659) initResult 802223B4BB0D32243FD8BAAC89D0DACF1F0646E8 undefined
                                  2024-12-04 20:53:00.511 - debug: tapo.0 (10659) Found device 80225099418DA3FAA1D0664722DDDC5E1F066D97 WB Bad
                                  2024-12-04 20:53:00.768 - debug: tapo.0 (10659) {"hwVer":"1.20.0","category":"plug","model":"P100","ssid":"d0lOVEVSTkVUWl9pc19jb21pbmc=","mac":"B0A7B9DD95F9","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","oemId":"D7C5ADFD37188938BA82FD0FE208D1E7","fwVer":"1.5.5 Build 20230927 Rel. 40646","ip":"192.168.178.83","onboardingTime":1,"role":0,"deviceType":"SMART.TAPOPLUG","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com"}
                                  2024-12-04 20:53:00.769 - info: tapo.0 (10659) Init device 80225099418DA3FAA1D0664722DDDC5E1F066D97 type P100 with ip 192.168.178.83
                                  2024-12-04 20:53:00.769 - debug: tapo.0 (10659) Constructing P100 on host: 192.168.178.83
                                  2024-12-04 20:53:00.807 - debug: tapo.0 (10659) Old Handshake P100 on host: 192.168.178.83
                                  2024-12-04 20:53:00.823 - debug: tapo.0 (10659) Received Old Handshake P100 on host response: 192.168.178.83
                                  2024-12-04 20:53:00.823 - info: tapo.0 (10659) Trying KLAP Auth
                                  2024-12-04 20:53:00.823 - debug: tapo.0 (10659) Detected KLAP device
                                  2024-12-04 20:53:00.823 - debug: tapo.0 (10659) Trying new handshake
                                  2024-12-04 20:53:00.827 - error: tapo.0 (10659) 276 Error: socket hang up
                                  2024-12-04 20:53:00.828 - debug: tapo.0 (10659) New Handshake 1 failed
                                  2024-12-04 20:53:00.828 - error: tapo.0 (10659) undefined
                                  2024-12-04 20:53:00.828 - error: tapo.0 (10659) 52 - Get Device Info failed
                                  2024-12-04 20:53:00.828 - info: tapo.0 (10659) Initialized 80225099418DA3FAA1D0664722DDDC5E1F066D97
                                  2024-12-04 20:53:00.828 - debug: tapo.0 (10659) initResult 80225099418DA3FAA1D0664722DDDC5E1F066D97 undefined
                                  2024-12-04 20:53:00.828 - debug: tapo.0 (10659) Found device 802268D4FFE5C5601E347444D0A04B8B1F0646F2 WB Küche süd
                                  2024-12-04 20:53:01.090 - debug: tapo.0 (10659) {"hwVer":"1.20.0","category":"plug","model":"P100","ssid":"d0lOVEVSTkVUWl9pc19jb21pbmc=","mac":"B0A7B9DD9BCA","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","oemId":"D7C5ADFD37188938BA82FD0FE208D1E7","fwVer":"1.5.5 Build 20230927 Rel. 40646","ip":"192.168.178.46","onboardingTime":1,"role":0,"deviceType":"SMART.TAPOPLUG","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com"}
                                  2024-12-04 20:53:01.090 - info: tapo.0 (10659) Init device 802268D4FFE5C5601E347444D0A04B8B1F0646F2 type P100 with ip 192.168.178.46
                                  2024-12-04 20:53:01.090 - debug: tapo.0 (10659) Constructing P100 on host: 192.168.178.46
                                  2024-12-04 20:53:01.147 - debug: tapo.0 (10659) Old Handshake P100 on host: 192.168.178.46
                                  2024-12-04 20:53:01.172 - debug: tapo.0 (10659) Received Old Handshake P100 on host response: 192.168.178.46
                                  2024-12-04 20:53:01.172 - info: tapo.0 (10659) Trying KLAP Auth
                                  2024-12-04 20:53:01.172 - debug: tapo.0 (10659) Detected KLAP device
                                  2024-12-04 20:53:01.172 - debug: tapo.0 (10659) Trying new handshake
                                  2024-12-04 20:53:01.176 - error: tapo.0 (10659) 276 Error: socket hang up
                                  2024-12-04 20:53:01.177 - debug: tapo.0 (10659) New Handshake 1 failed
                                  2024-12-04 20:53:01.177 - error: tapo.0 (10659) undefined
                                  2024-12-04 20:53:01.177 - error: tapo.0 (10659) 52 - Get Device Info failed
                                  2024-12-04 20:53:01.177 - info: tapo.0 (10659) Initialized 802268D4FFE5C5601E347444D0A04B8B1F0646F2
                                  2024-12-04 20:53:01.177 - debug: tapo.0 (10659) initResult 802268D4FFE5C5601E347444D0A04B8B1F0646F2 undefined
                                  2024-12-04 20:53:01.177 - debug: tapo.0 (10659) Found device 80221A1E53A32FBD1405E7644240FEFA1F6DA9F0 WB Fenster süd
                                  2024-12-04 20:53:01.387 - debug: tapo.0 (10659) {"hwVer":"1.20.0","category":"plug","model":"P100","ssid":"d0lOVEVSTkVUWl9pc19jb21pbmc=","mac":"B4B024E5B643","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","oemId":"D7C5ADFD37188938BA82FD0FE208D1E7","fwVer":"1.5.5 Build 20230927 Rel. 40646","ip":"192.168.178.73","onboardingTime":1733237358,"role":0,"deviceType":"SMART.TAPOPLUG","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com"}
                                  2024-12-04 20:53:01.388 - info: tapo.0 (10659) Init device 80221A1E53A32FBD1405E7644240FEFA1F6DA9F0 type P100 with ip 192.168.178.73
                                  2024-12-04 20:53:01.388 - debug: tapo.0 (10659) Constructing P100 on host: 192.168.178.73
                                  2024-12-04 20:53:01.425 - debug: tapo.0 (10659) Old Handshake P100 on host: 192.168.178.73
                                  2024-12-04 20:53:01.442 - debug: tapo.0 (10659) Received Old Handshake P100 on host response: 192.168.178.73
                                  2024-12-04 20:53:01.442 - info: tapo.0 (10659) Trying KLAP Auth
                                  2024-12-04 20:53:01.442 - debug: tapo.0 (10659) Detected KLAP device
                                  2024-12-04 20:53:01.442 - debug: tapo.0 (10659) Trying new handshake
                                  2024-12-04 20:53:01.446 - error: tapo.0 (10659) 276 Error: socket hang up
                                  2024-12-04 20:53:01.446 - debug: tapo.0 (10659) New Handshake 1 failed
                                  2024-12-04 20:53:01.446 - error: tapo.0 (10659) undefined
                                  2024-12-04 20:53:01.446 - error: tapo.0 (10659) 52 - Get Device Info failed
                                  2024-12-04 20:53:01.446 - info: tapo.0 (10659) Initialized 80221A1E53A32FBD1405E7644240FEFA1F6DA9F0
                                  2024-12-04 20:53:01.446 - debug: tapo.0 (10659) initResult 80221A1E53A32FBD1405E7644240FEFA1F6DA9F0 undefined
                                  2024-12-04 20:53:01.447 - debug: tapo.0 (10659) Found device 802217E11A793DE8F5E95B43F48523D71F6EE40F WB Balkon links
                                  2024-12-04 20:53:01.670 - debug: tapo.0 (10659) {"hwVer":"1.20.0","category":"plug","model":"P100","ssid":"d0lOVEVSTkVUWl9pc19jb21pbmc=","mac":"B4B024E5A05C","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","oemId":"D7C5ADFD37188938BA82FD0FE208D1E7","fwVer":"1.5.5 Build 20230927 Rel. 40646","ip":"192.168.178.84","onboardingTime":1,"role":0,"deviceType":"SMART.TAPOPLUG","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com"}
                                  2024-12-04 20:53:01.671 - info: tapo.0 (10659) Init device 802217E11A793DE8F5E95B43F48523D71F6EE40F type P100 with ip 192.168.178.84
                                  2024-12-04 20:53:01.671 - debug: tapo.0 (10659) Constructing P100 on host: 192.168.178.84
                                  2024-12-04 20:53:01.714 - debug: tapo.0 (10659) Old Handshake P100 on host: 192.168.178.84
                                  2024-12-04 20:53:01.727 - debug: tapo.0 (10659) Received Old Handshake P100 on host response: 192.168.178.84
                                  2024-12-04 20:53:01.728 - info: tapo.0 (10659) Trying KLAP Auth
                                  2024-12-04 20:53:01.728 - debug: tapo.0 (10659) Detected KLAP device
                                  2024-12-04 20:53:01.728 - debug: tapo.0 (10659) Trying new handshake
                                  2024-12-04 20:53:01.731 - error: tapo.0 (10659) 276 Error: socket hang up
                                  2024-12-04 20:53:01.731 - debug: tapo.0 (10659) New Handshake 1 failed
                                  2024-12-04 20:53:01.731 - error: tapo.0 (10659) undefined
                                  2024-12-04 20:53:01.731 - error: tapo.0 (10659) 52 - Get Device Info failed
                                  2024-12-04 20:53:01.731 - info: tapo.0 (10659) Initialized 802217E11A793DE8F5E95B43F48523D71F6EE40F
                                  2024-12-04 20:53:01.731 - debug: tapo.0 (10659) initResult 802217E11A793DE8F5E95B43F48523D71F6EE40F undefined
                                  2024-12-04 20:53:01.731 - debug: tapo.0 (10659) Found device 80227C9387D02CB80B2A97FAA7B45D451F6DBE41 WB Balkon rechts
                                  2024-12-04 20:53:01.970 - debug: tapo.0 (10659) {"hwVer":"1.20.0","category":"plug","model":"P100","ssid":"d0lOVEVSTkVUWl9pc19jb21pbmc=","mac":"B4B024E5BED5","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","oemId":"D7C5ADFD37188938BA82FD0FE208D1E7","fwVer":"1.5.5 Build 20230927 Rel. 40646","ip":"192.168.178.79","onboardingTime":1,"role":0,"deviceType":"SMART.TAPOPLUG","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com"}
                                  2024-12-04 20:53:01.970 - info: tapo.0 (10659) Init device 80227C9387D02CB80B2A97FAA7B45D451F6DBE41 type P100 with ip 192.168.178.79
                                  2024-12-04 20:53:01.970 - debug: tapo.0 (10659) Constructing P100 on host: 192.168.178.79
                                  2024-12-04 20:53:02.012 - debug: tapo.0 (10659) Old Handshake P100 on host: 192.168.178.79
                                  2024-12-04 20:53:02.035 - debug: tapo.0 (10659) Received Old Handshake P100 on host response: 192.168.178.79
                                  2024-12-04 20:53:02.035 - info: tapo.0 (10659) Trying KLAP Auth
                                  2024-12-04 20:53:02.035 - debug: tapo.0 (10659) Detected KLAP device
                                  2024-12-04 20:53:02.035 - debug: tapo.0 (10659) Trying new handshake
                                  2024-12-04 20:53:02.039 - error: tapo.0 (10659) 276 Error: socket hang up
                                  2024-12-04 20:53:02.039 - debug: tapo.0 (10659) New Handshake 1 failed
                                  2024-12-04 20:53:02.039 - error: tapo.0 (10659) undefined
                                  2024-12-04 20:53:02.039 - error: tapo.0 (10659) 52 - Get Device Info failed
                                  2024-12-04 20:53:02.039 - info: tapo.0 (10659) Initialized 80227C9387D02CB80B2A97FAA7B45D451F6DBE41
                                  2024-12-04 20:53:02.039 - debug: tapo.0 (10659) initResult 80227C9387D02CB80B2A97FAA7B45D451F6DBE41 undefined
                                  2024-12-04 20:53:02.039 - debug: tapo.0 (10659) Found device 8021A5C95BDC23B3A5C4ED9A6B165AB421F4DC24 Kamera Carport 360
                                  2024-12-04 20:53:02.262 - debug: tapo.0 (10659) {"hwVer":"1.0","category":"camera","model":"C510W 1.0","ssid":"wINTERNETZ_is_coming","mac":"A842A1382FE0","hwId":"FE658AE4C353452D7B112AB94C679C3D","fwId":"B0A5537E15AA5B2FF42EE5C7F1897445","oemId":"CBF298FDF6A1EA18D53CCB1E4D60CCB9","fwVer":"1.2.3 Build 240802 Rel.52500n","ip":"192.168.178.104","onboardingTime":1705167105,"role":0,"deviceType":"SMART.IPCAMERA","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com"}
                                  2024-12-04 20:53:02.262 - info: tapo.0 (10659) Init device 8021A5C95BDC23B3A5C4ED9A6B165AB421F4DC24 type C510W 1.0 with ip 192.168.178.104
                                  2024-12-04 20:53:02.379 - info: tapo.0 (10659) 8021A5C95BDC23B3A5C4ED9A6B165AB421F4DC24 Received device info {"manufacturer":"tp-link","model":"Tapo C510W","firmwareVersion":"1.2.3 Build 240802 Rel.52500n","serialNumber":"a1382fe0","hardwareId":1}
                                  2024-12-04 20:53:02.380 - debug: tapo.0 (10659) {"manufacturer":"tp-link","model":"Tapo C510W","firmwareVersion":"1.2.3 Build 240802 Rel.52500n","serialNumber":"a1382fe0","hardwareId":1}
                                  2024-12-04 20:53:02.380 - debug: tapo.0 (10659) Init event emitter for 8021A5C95BDC23B3A5C4ED9A6B165AB421F4DC24
                                  2024-12-04 20:53:02.404 - debug: tapo.0 (10659) Init event listener for "motion"
                                  2024-12-04 20:53:02.404 - info: tapo.0 (10659) Initialized 8021A5C95BDC23B3A5C4ED9A6B165AB421F4DC24
                                  2024-12-04 20:53:02.404 - debug: tapo.0 (10659) initResult 8021A5C95BDC23B3A5C4ED9A6B165AB421F4DC24 undefined
                                  2024-12-04 20:53:02.405 - debug: tapo.0 (10659) Found device 8022409EF7482B099F90B71629A073D31F050586 WB Treppenfenster
                                  2024-12-04 20:53:02.593 - debug: tapo.0 (10659) {"hwVer":"1.20.0","category":"plug","model":"P100","ssid":"d0lOVEVSTkVUWl9pc19jb21pbmc=","mac":"B0A7B9DD8161","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","oemId":"D7C5ADFD37188938BA82FD0FE208D1E7","fwVer":"1.5.5 Build 20230927 Rel. 40646","ip":"192.168.178.48","onboardingTime":1,"role":0,"deviceType":"SMART.TAPOPLUG","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com"}
                                  2024-12-04 20:53:02.593 - info: tapo.0 (10659) Init device 8022409EF7482B099F90B71629A073D31F050586 type P100 with ip 192.168.178.48
                                  2024-12-04 20:53:02.594 - debug: tapo.0 (10659) Constructing P100 on host: 192.168.178.48
                                  2024-12-04 20:53:02.634 - debug: tapo.0 (10659) Old Handshake P100 on host: 192.168.178.48
                                  2024-12-04 20:53:02.646 - debug: tapo.0 (10659) Received Old Handshake P100 on host response: 192.168.178.48
                                  2024-12-04 20:53:02.646 - info: tapo.0 (10659) Trying KLAP Auth
                                  2024-12-04 20:53:02.646 - debug: tapo.0 (10659) Detected KLAP device
                                  2024-12-04 20:53:02.646 - debug: tapo.0 (10659) Trying new handshake
                                  2024-12-04 20:53:02.649 - error: tapo.0 (10659) 276 Error: socket hang up
                                  2024-12-04 20:53:02.649 - debug: tapo.0 (10659) New Handshake 1 failed
                                  2024-12-04 20:53:02.649 - error: tapo.0 (10659) undefined
                                  2024-12-04 20:53:02.649 - error: tapo.0 (10659) 52 - Get Device Info failed
                                  2024-12-04 20:53:02.650 - info: tapo.0 (10659) Initialized 8022409EF7482B099F90B71629A073D31F050586
                                  2024-12-04 20:53:02.650 - debug: tapo.0 (10659) initResult 8022409EF7482B099F90B71629A073D31F050586 undefined
                                  2024-12-04 20:53:02.650 - debug: tapo.0 (10659) Found device 8022F09FD11B3954491C051CBA331E321F6E863A WB Büro
                                  2024-12-04 20:53:02.928 - debug: tapo.0 (10659) {"hwVer":"1.20.0","category":"plug","model":"P100","ssid":"d0lOVEVSTkVUWl9pc19jb21pbmc=","mac":"B4B024E5C6FD","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","oemId":"D7C5ADFD37188938BA82FD0FE208D1E7","fwVer":"1.5.5 Build 20230927 Rel. 40646","ip":"192.168.178.85","onboardingTime":1,"role":0,"deviceType":"SMART.TAPOPLUG","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com"}
                                  2024-12-04 20:53:02.928 - info: tapo.0 (10659) Init device 8022F09FD11B3954491C051CBA331E321F6E863A type P100 with ip 192.168.178.85
                                  2024-12-04 20:53:02.928 - debug: tapo.0 (10659) Constructing P100 on host: 192.168.178.85
                                  2024-12-04 20:53:02.992 - debug: tapo.0 (10659) Old Handshake P100 on host: 192.168.178.85
                                  2024-12-04 20:53:03.012 - debug: tapo.0 (10659) Received Old Handshake P100 on host response: 192.168.178.85
                                  2024-12-04 20:53:03.013 - info: tapo.0 (10659) Trying KLAP Auth
                                  2024-12-04 20:53:03.013 - debug: tapo.0 (10659) Detected KLAP device
                                  2024-12-04 20:53:03.013 - debug: tapo.0 (10659) Trying new handshake
                                  2024-12-04 20:53:03.016 - error: tapo.0 (10659) 276 Error: socket hang up
                                  2024-12-04 20:53:03.016 - debug: tapo.0 (10659) New Handshake 1 failed
                                  2024-12-04 20:53:03.017 - error: tapo.0 (10659) undefined
                                  2024-12-04 20:53:03.017 - error: tapo.0 (10659) 52 - Get Device Info failed
                                  2024-12-04 20:53:03.017 - info: tapo.0 (10659) Initialized 8022F09FD11B3954491C051CBA331E321F6E863A
                                  2024-12-04 20:53:03.017 - debug: tapo.0 (10659) initResult 8022F09FD11B3954491C051CBA331E321F6E863A undefined
                                  2024-12-04 20:53:03.067 - info: tapo.0 (10659) Wait for connections for non camera devices
                                  2024-12-04 20:53:13.068 - info: tapo.0 (10659) Start first Update
                                  2024-12-04 20:53:13.069 - debug: tapo.0 (10659) Receive camera status
                                  2024-12-04 20:53:13.070 - debug: tapo.0 (10659) New API request
                                  2024-12-04 20:53:13.070 - debug: tapo.0 (10659) isSecureConnection: Checking secure connection...
                                  2024-12-04 20:53:13.213 - debug: tapo.0 (10659) isSecureConnection response
                                  2024-12-04 20:53:13.214 - debug: tapo.0 (10659) refreshStok: Refreshing stok...
                                  2024-12-04 20:53:13.339 - debug: tapo.0 (10659) refreshStok: Login response
                                  2024-12-04 20:53:13.340 - debug: tapo.0 (10659) refreshStok: sending start_seq request
                                  2024-12-04 20:53:13.500 - debug: tapo.0 (10659) refreshStok: start_seq response
                                  2024-12-04 20:53:13.500 - debug: tapo.0 (10659) refreshStok: Success in obtaining STOK
                                  2024-12-04 20:53:13.639 - debug: tapo.0 (10659) API response
                                  2024-12-04 20:53:13.640 - debug: tapo.0 (10659) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":true,"led":false}
                                  2024-12-04 20:53:13.640 - debug: tapo.0 (10659) Update done
                                  2024-12-04 20:53:23.082 - debug: tapo.0 (10659) Receive camera status
                                  2024-12-04 20:53:23.083 - debug: tapo.0 (10659) New API request
                                  2024-12-04 20:53:23.278 - debug: tapo.0 (10659) API response
                                  2024-12-04 20:53:23.278 - debug: tapo.0 (10659) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":true,"led":false}
                                  2024-12-04 20:53:23.278 - debug: tapo.0 (10659) Update done
                                  2024-12-04 20:53:33.083 - debug: tapo.0 (10659) Receive camera status
                                  2024-12-04 20:53:33.084 - debug: tapo.0 (10659) New API request
                                  2024-12-04 20:53:33.217 - debug: tapo.0 (10659) API response
                                  2024-12-04 20:53:33.217 - debug: tapo.0 (10659) {"alarm":false,"eyes":true,"notifications":true,"motionDetection":true,"led":false}
                                  2024-12-04 20:53:33.218 - debug: tapo.0 (10659) Update done
                                  [/s]
                                  • T tombox
                                    M
                                    M
                                    mbw
                                    #635
                                    @tombox Nein, ich bekomme auch mit Version 0.3.3 folgende Fehlermeldung: tapo.0 (1780571) 52 - Get Device Info failed
                                    • T tombox
                                      @saarlanduhu @mbw
                                      Mr. QiM
                                      Mr. QiM
                                      Mr. Qi
                                      schrieb am zuletzt editiert von Mr. Qi
                                      #636
                                      Hallo ich habe mir heute die frische 0.4.2-beta 1 von Git heruntergeladen mit folgendem ergebnis:
                                      2024-12-05 16:57:26.345 - debug: tapo.0 (168476) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                      2024-12-05 16:57:26.426 - debug: tapo.0 (168476) Objects client ready ... initialize now
                                      2024-12-05 16:57:26.474 - debug: tapo.0 (168476) Objects create System PubSub Client
                                      2024-12-05 16:57:26.476 - debug: tapo.0 (168476) Objects create User PubSub Client
                                      2024-12-05 16:57:26.603 - debug: tapo.0 (168476) Objects client initialize lua scripts
                                      2024-12-05 16:57:26.613 - debug: tapo.0 (168476) Objects connected to redis: 127.0.0.1:9001
                                      2024-12-05 16:57:26.726 - debug: tapo.0 (168476) Redis States: Use Redis connection: 127.0.0.1:9000
                                      2024-12-05 16:57:26.835 - debug: tapo.0 (168476) States create System PubSub Client
                                      2024-12-05 16:57:26.837 - debug: tapo.0 (168476) States create User PubSub Client
                                      2024-12-05 16:57:26.949 - debug: tapo.0 (168476) States connected to redis: 127.0.0.1:9000
                                      2024-12-05 16:57:27.015 - debug: tapo.0 (168476) Plugin sentry Initialize Plugin (enabled=true)
                                      2024-12-05 16:57:27.479 - info: tapo.0 (168476) starting. Version 0.4.2-beta.1 (non-npm: TA2k/ioBroker.tapo#516afe55b3c7b3d96b88654bee9be7c715bcf185) in /opt/iobroker/node_modules/iobroker.tapo, node: v20.18.0, js-controller: 7.0.3
                                      2024-12-05 16:57:27.534 - info: tapo.0 (168476) Login tp TAPO App
                                      2024-12-05 16:57:27.547 - debug: tapo.0 (168476) kqqZynDbNaIemNWTUEs5Gg==
                                      2024-12-05 16:57:28.191 - debug: tapo.0 (168476) {"error_code":0,"result":{"lockedMinutes":0,"lastCheckDate":"Tue Dec 03 11:15:53 UTC 2024","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","failedAttempts":0,"riskDetected":0,"remainAttempts":0,"errorCode":"0","supportedMFATypes":[],"token":"f61dbee1-BTFMwczSekYA6JcLPu8lfc3","accountId":"15386249","regionCode":"DE","regTime":"2020-05-25 17:11:37","nickname":"patrickpause1987","email":"patrickpause1987@gmail.com","refreshToken":"8118679223a348ca822f05c482f1a22f"}}
                                      2024-12-05 16:57:28.192 - info: tapo.0 (168476) Login succesfull
                                      2024-12-05 16:57:28.194 - debug: tapo.0 (168476) yfoQzXVQIYQWjRDZuXyppQ==
                                      2024-12-05 16:57:28.550 - debug: tapo.0 (168476) {"error_code":0,"result":{"totalNum":13,"deviceList":[{"deviceType":"SMART.TAPOPLUG","role":0,"fwVer":"1.5.5 Build 20230927 Rel. 40646","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"8022A5EFAA615D52B648F0CA58ACB16A1DB5CF5A","deviceName":"P100","deviceHwVer":"1.20.0","alias":"V29obnppbW1lciBMaWNodA==","deviceMac":"E4C32A7AE548","oemId":"D7C5ADFD37188938BA82FD0FE208D1E7","deviceModel":"P100","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","isSameRegion":true,"status":0},{"deviceType":"SMART.TAPOPLUG","role":0,"fwVer":"1.5.5 Build 20230927 Rel. 40646","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"8022A8810D00CDC184D2E3A433A25AAA1DB4FA4D","deviceName":"P100","deviceHwVer":"1.20.0","alias":"QmFkbGljaHQg","deviceMac":"E4C32A7B00EC","oemId":"D7C5ADFD37188938BA82FD0FE208D1E7","deviceModel":"P100","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","isSameRegion":true,"status":0},{"deviceType":"SMART.TAPOPLUG","role":0,"fwVer":"1.5.5 Build 20230927 Rel. 40646","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"8022EF6B400BF37DE7A0DEDB654A12A821F509E6","deviceName":"P100","deviceHwVer":"1.20.0","alias":"QmFybGljaHQg","deviceMac":"5C628B848BA7","oemId":"D7C5ADFD37188938BA82FD0FE208D1E7","deviceModel":"P100","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","isSameRegion":true,"status":0},{"deviceType":"SMART.TAPOPLUG","role":0,"fwVer":"1.5.5 Build 20230927 Rel. 40646","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"802285CCFD29BDF54996539678B6104521F42AC5","deviceName":"P100","deviceHwVer":"1.20.0","alias":"U3Rlcm4=","deviceMac":"5C628B848B74","oemId":"D7C5ADFD37188938BA82FD0FE208D1E7","deviceModel":"P100","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","isSameRegion":true,"status":0},{"deviceType":"SMART.TAPOPLUG","role":0,"fwVer":"1.5.5 Build 20230927 Rel. 40646","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"8022A7F2873E7648EC523DBE3523CFA11DB53F91","deviceName":"P100","deviceHwVer":"1.20.0","alias":"Qm94IEFibHVmdA==","deviceMac":"E4C32A7AE54A","oemId":"D7C5ADFD37188938BA82FD0FE208D1E7","deviceModel":"P100","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","isSameRegion":true,"status":0},{"deviceType":"SMART.IPCAMERA","role":0,"fwVer":"1.3.14 Build 240716 Rel.41863n(4555)","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"8021358BB4A527CB280AB30A8BDA3D671CDD26E7","deviceName":"C200","deviceHwVer":"1.0","alias":"Wohzimmer","deviceMac":"B0957585DB3F","oemId":"8902D2F34FCE407721DE92F5759839C2","deviceModel":"C200","hwId":"84415C8E236887E785A849DF3CF77B02","fwId":"51092D48A2DB8C169A4C78E4D6102BC6","isSameRegion":true,"status":0},{"deviceType":"SMART.TAPOPLUG","role":0,"fwVer":"1.5.5 Build 20230927 Rel. 40646","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"80229A326AB1C0A14703A582444F23E221F4115A","deviceName":"P100","deviceHwVer":"1.20.0","alias":"WmlydWxhdGlvbnMgZ2VibMOkc2U=","deviceMac":"5C628B848BA9","oemId":"D7C5ADFD37188938BA82FD0FE208D1E7","deviceModel":"P100","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","isSameRegion":true,"status":0},{"deviceType":"SMART.IPCAMERA","role":0,"fwVer":"1.3.11 Build 231116 Rel.69367n(4555)","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"80216A1079A8ACEAAA069730BEB957071E902D8A","deviceName":"C310","deviceHwVer":"2.0","alias":"Box Kamera","deviceMac":"60A4B738F93E","oemId":"8254843D1E8318CB5C2BC8BF94D189FA","deviceModel":"C310","hwId":"4F7FF895442ABA53E14CD582ED5BA10F","fwId":"E82C0BDFA47337D394F2ED1D7B7683DF","isSameRegion":true,"status":0},{"deviceType":"SMART.IPCAMERA","role":0,"fwVer":"1.1.4 Build 240506 Rel.39487n","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"8021CBA4909610A206E139C3FC03DE1822E48FC5","deviceName":"C500 1.0","deviceHwVer":"1.0","alias":"Tapo_C500_3","deviceMac":"A86E844CA102","oemId":"0E1D0C2B5D536BC012D688DED78100AD","deviceModel":"C500","hwId":"C914043E1250C81FD816001F474FA63A","fwId":"ECD1920B486ED964132C0784183D1684","isSameRegion":true,"status":0},{"deviceType":"SMART.TAPOPLUG","role":0,"fwVer":"1.5.5 Build 20230927 Rel. 40646","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"80223319522707959DE0F1272BFAC53B1DB5A17E","deviceName":"P100","deviceHwVer":"1.20.0","alias":"Qm94IExFRA==","deviceMac":"E4C32A7ADE84","oemId":"D7C5ADFD37188938BA82FD0FE208D1E7","deviceModel":"P100","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","isSameRegion":true,"status":0},{"deviceType":"SMART.IPCAMERA","role":0,"fwVer":"1.3.11 Build 231116 Rel.69367n(4555)","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"80217FF0997E1DACDDDCBF13B6B966611EB22199","deviceName":"C310","deviceHwVer":"2.0","alias":"Einfahrt","deviceMac":"60A4B7FD0F22","oemId":"8254843D1E8318CB5C2BC8BF94D189FA","deviceModel":"C310","hwId":"4F7FF895442ABA53E14CD582ED5BA10F","fwId":"E82C0BDFA47337D394F2ED1D7B7683DF","isSameRegion":true,"status":0},{"deviceType":"SMART.IPCAMERA","role":0,"fwVer":"1.1.4 Build 240506 Rel.39487n","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"8021886637E6AFF404F8434554466A6B22E4035E","deviceName":"C500 1.0","deviceHwVer":"1.0","alias":"Tapo_C500_1","deviceMac":"A86E844CA10D","oemId":"0E1D0C2B5D536BC012D688DED78100AD","deviceModel":"C500","hwId":"C914043E1250C81FD816001F474FA63A","fwId":"ECD1920B486ED964132C0784183D1684","isSameRegion":true,"status":0},{"deviceType":"SMART.IPCAMERA","role":0,"fwVer":"1.1.4 Build 240506 Rel.39487n","appServerUrl":"https://n-euw1-wap-gw.tplinkcloud.com","deviceRegion":"eu-west-1","roleType":"owner","deviceId":"8021D0AE6DDA96751C98FB10EB6BB38522E3A62E","deviceName":"C500 1.0","deviceHwVer":"1.0","alias":"Tapo_C500_2","deviceMac":"A86E8441688D","oemId":"0E1D0C2B5D536BC012D688DED78100AD","deviceModel":"C500","hwId":"C914043E1250C81FD816001F474FA63A","fwId":"ECD1920B486ED964132C0784183D1684","isSameRegion":true,"status":0}],"currentIndex":12}}
                                      2024-12-05 16:57:28.551 - info: tapo.0 (168476) Found 13 devices
                                      2024-12-05 16:57:28.552 - debug: tapo.0 (168476) Found device 8022A5EFAA615D52B648F0CA58ACB16A1DB5CF5A Wohnzimmer Licht
                                      2024-12-05 16:57:28.934 - debug: tapo.0 (168476) {"hwVer":"1.20.0","category":"plug","model":"P100","ssid":"VW1icmVsbGEtQklPc3lzMi40","mac":"E4C32A7AE548","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","oemId":"D7C5ADFD37188938BA82FD0FE208D1E7","fwVer":"1.5.5 Build 20230927 Rel. 40646","ip":"177.188.102.40","onboardingTime":1727032704,"role":0,"deviceType":"SMART.TAPOPLUG","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com"}
                                      2024-12-05 16:57:28.936 - info: tapo.0 (168476) Init device 8022A5EFAA615D52B648F0CA58ACB16A1DB5CF5A type P100 with ip 177.188.102.40
                                      2024-12-05 16:57:28.937 - debug: tapo.0 (168476) Constructing P100 on host: 177.188.102.40
                                      2024-12-05 16:57:29.022 - debug: tapo.0 (168476) Old Handshake P100 on host: 177.188.102.40
                                      2024-12-05 16:57:29.046 - debug: tapo.0 (168476) Received Old Handshake P100 on host response: 177.188.102.40
                                      2024-12-05 16:57:29.048 - info: tapo.0 (168476) Trying KLAP Auth
                                      2024-12-05 16:57:29.049 - debug: tapo.0 (168476) Detected KLAP device
                                      2024-12-05 16:57:29.049 - debug: tapo.0 (168476) Trying new handshake
                                      2024-12-05 16:57:29.244 - error: tapo.0 (168476) 276 Error: socket hang up
                                      2024-12-05 16:57:29.245 - debug: tapo.0 (168476) New Handshake 1 failed
                                      2024-12-05 16:57:29.246 - error: tapo.0 (168476) undefined
                                      2024-12-05 16:57:29.247 - error: tapo.0 (168476) 52 - Get Device Info failed
                                      2024-12-05 16:57:29.247 - info: tapo.0 (168476) Initialized 8022A5EFAA615D52B648F0CA58ACB16A1DB5CF5A
                                      2024-12-05 16:57:29.247 - debug: tapo.0 (168476) initResult 8022A5EFAA615D52B648F0CA58ACB16A1DB5CF5A undefined
                                      2024-12-05 16:57:29.248 - debug: tapo.0 (168476) Found device 8022A8810D00CDC184D2E3A433A25AAA1DB4FA4D Badlicht
                                      2024-12-05 16:57:29.617 - debug: tapo.0 (168476) {"hwVer":"1.20.0","category":"plug","model":"P100","ssid":"VW1icmVsbGEtQklPc3lzMi40","mac":"E4C32A7B00EC","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","oemId":"D7C5ADFD37188938BA82FD0FE208D1E7","fwVer":"1.5.5 Build 20230927 Rel. 40646","ip":"177.188.102.223","onboardingTime":1725011406,"role":0,"deviceType":"SMART.TAPOPLUG","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com"}
                                      2024-12-05 16:57:29.618 - info: tapo.0 (168476) Init device 8022A8810D00CDC184D2E3A433A25AAA1DB4FA4D type P100 with ip 177.188.102.223
                                      2024-12-05 16:57:29.619 - debug: tapo.0 (168476) Constructing P100 on host: 177.188.102.223
                                      2024-12-05 16:57:29.699 - debug: tapo.0 (168476) Old Handshake P100 on host: 177.188.102.223
                                      2024-12-05 16:57:29.718 - debug: tapo.0 (168476) Received Old Handshake P100 on host response: 177.188.102.223
                                      2024-12-05 16:57:29.719 - info: tapo.0 (168476) Trying KLAP Auth
                                      2024-12-05 16:57:29.719 - debug: tapo.0 (168476) Detected KLAP device
                                      2024-12-05 16:57:29.719 - debug: tapo.0 (168476) Trying new handshake
                                      2024-12-05 16:57:29.729 - error: tapo.0 (168476) 276 Error: socket hang up
                                      2024-12-05 16:57:29.730 - debug: tapo.0 (168476) New Handshake 1 failed
                                      2024-12-05 16:57:29.730 - error: tapo.0 (168476) undefined
                                      2024-12-05 16:57:29.731 - error: tapo.0 (168476) 52 - Get Device Info failed
                                      2024-12-05 16:57:29.731 - info: tapo.0 (168476) Initialized 8022A8810D00CDC184D2E3A433A25AAA1DB4FA4D
                                      2024-12-05 16:57:29.731 - debug: tapo.0 (168476) initResult 8022A8810D00CDC184D2E3A433A25AAA1DB4FA4D undefined
                                      2024-12-05 16:57:29.731 - debug: tapo.0 (168476) Found device 8022EF6B400BF37DE7A0DEDB654A12A821F509E6 Barlicht
                                      2024-12-05 16:57:30.399 - debug: tapo.0 (168476) {"hwVer":"1.20.0","category":"plug","model":"P100","ssid":"VW1icmVsbGEtQklPc3lzMi40","mac":"5C628B848BA7","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","oemId":"D7C5ADFD37188938BA82FD0FE208D1E7","fwVer":"1.5.5 Build 20230927 Rel. 40646","ip":"177.188.102.200","onboardingTime":1725139265,"role":0,"deviceType":"SMART.TAPOPLUG","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com"}
                                      2024-12-05 16:57:30.400 - info: tapo.0 (168476) Init device 8022EF6B400BF37DE7A0DEDB654A12A821F509E6 type P100 with ip 177.188.102.200
                                      2024-12-05 16:57:30.401 - debug: tapo.0 (168476) Constructing P100 on host: 177.188.102.200
                                      2024-12-05 16:57:30.491 - debug: tapo.0 (168476) Old Handshake P100 on host: 177.188.102.200
                                      2024-12-05 16:57:35.503 - error: tapo.0 (168476) timeout of 5000ms exceeded
                                      2024-12-05 16:57:35.504 - debug: tapo.0 (168476) Detected KLAP device
                                      2024-12-05 16:57:35.505 - debug: tapo.0 (168476) Trying new handshake
                                      2024-12-05 16:57:40.516 - error: tapo.0 (168476) 276 Error: timeout of 5000ms exceeded
                                      2024-12-05 16:57:40.517 - debug: tapo.0 (168476) New Handshake 1 failed
                                      2024-12-05 16:57:40.517 - error: tapo.0 (168476) undefined
                                      2024-12-05 16:57:40.518 - error: tapo.0 (168476) 52 - Get Device Info failed
                                      2024-12-05 16:57:40.518 - info: tapo.0 (168476) Initialized 8022EF6B400BF37DE7A0DEDB654A12A821F509E6
                                      2024-12-05 16:57:40.518 - debug: tapo.0 (168476) initResult 8022EF6B400BF37DE7A0DEDB654A12A821F509E6 undefined
                                      2024-12-05 16:57:40.519 - debug: tapo.0 (168476) Found device 802285CCFD29BDF54996539678B6104521F42AC5 Stern
                                      2024-12-05 16:57:40.914 - debug: tapo.0 (168476) {"hwVer":"1.20.0","category":"plug","model":"P100","ssid":"VW1icmVsbGEtQklPc3lzMi40","mac":"5C628B848B74","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","oemId":"D7C5ADFD37188938BA82FD0FE208D1E7","fwVer":"1.5.5 Build 20230927 Rel. 40646","ip":"177.188.102.248","onboardingTime":1733320453,"role":0,"deviceType":"SMART.TAPOPLUG","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com"}
                                      2024-12-05 16:57:40.915 - info: tapo.0 (168476) Init device 802285CCFD29BDF54996539678B6104521F42AC5 type P100 with ip 177.188.102.248
                                      2024-12-05 16:57:40.916 - debug: tapo.0 (168476) Constructing P100 on host: 177.188.102.248
                                      2024-12-05 16:57:41.023 - debug: tapo.0 (168476) Old Handshake P100 on host: 177.188.102.248
                                      2024-12-05 16:57:41.042 - debug: tapo.0 (168476) Received Old Handshake P100 on host response: 177.188.102.248
                                      2024-12-05 16:57:41.043 - info: tapo.0 (168476) Trying KLAP Auth
                                      2024-12-05 16:57:41.043 - debug: tapo.0 (168476) Detected KLAP device
                                      2024-12-05 16:57:41.044 - debug: tapo.0 (168476) Trying new handshake
                                      2024-12-05 16:57:41.053 - error: tapo.0 (168476) 276 Error: socket hang up
                                      2024-12-05 16:57:41.053 - debug: tapo.0 (168476) New Handshake 1 failed
                                      2024-12-05 16:57:41.054 - error: tapo.0 (168476) undefined
                                      2024-12-05 16:57:41.054 - error: tapo.0 (168476) 52 - Get Device Info failed
                                      2024-12-05 16:57:41.054 - info: tapo.0 (168476) Initialized 802285CCFD29BDF54996539678B6104521F42AC5
                                      2024-12-05 16:57:41.054 - debug: tapo.0 (168476) initResult 802285CCFD29BDF54996539678B6104521F42AC5 undefined
                                      2024-12-05 16:57:41.055 - debug: tapo.0 (168476) Found device 8022A7F2873E7648EC523DBE3523CFA11DB53F91 Box Abluft
                                      2024-12-05 16:57:41.455 - debug: tapo.0 (168476) {"hwVer":"1.20.0","category":"plug","model":"P100","ssid":"VW1icmVsbGEtQklPc3lzMi40","mac":"E4C32A7AE54A","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","oemId":"D7C5ADFD37188938BA82FD0FE208D1E7","fwVer":"1.5.5 Build 20230927 Rel. 40646","ip":"177.188.102.9","onboardingTime":1725280774,"role":0,"deviceType":"SMART.TAPOPLUG","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com"}
                                      2024-12-05 16:57:41.456 - info: tapo.0 (168476) Init device 8022A7F2873E7648EC523DBE3523CFA11DB53F91 type P100 with ip 177.188.102.9
                                      2024-12-05 16:57:41.457 - debug: tapo.0 (168476) Constructing P100 on host: 177.188.102.9
                                      2024-12-05 16:57:41.529 - debug: tapo.0 (168476) Old Handshake P100 on host: 177.188.102.9
                                      2024-12-05 16:57:44.614 - error: tapo.0 (168476) connect EHOSTUNREACH 177.188.102.9:80
                                      2024-12-05 16:57:44.615 - debug: tapo.0 (168476) Detected KLAP device
                                      2024-12-05 16:57:44.615 - debug: tapo.0 (168476) Trying new handshake
                                      2024-12-05 16:57:47.688 - error: tapo.0 (168476) 276 Error: connect EHOSTUNREACH 177.188.102.9:80
                                      2024-12-05 16:57:47.689 - debug: tapo.0 (168476) New Handshake 1 failed
                                      2024-12-05 16:57:47.690 - error: tapo.0 (168476) undefined
                                      2024-12-05 16:57:47.691 - error: tapo.0 (168476) 52 - Get Device Info failed
                                      2024-12-05 16:57:47.691 - info: tapo.0 (168476) Initialized 8022A7F2873E7648EC523DBE3523CFA11DB53F91
                                      2024-12-05 16:57:47.692 - debug: tapo.0 (168476) initResult 8022A7F2873E7648EC523DBE3523CFA11DB53F91 undefined
                                      2024-12-05 16:57:47.693 - debug: tapo.0 (168476) Found device 8021358BB4A527CB280AB30A8BDA3D671CDD26E7 Wohzimmer
                                      2024-12-05 16:57:48.120 - debug: tapo.0 (168476) {"hwVer":"1.0","category":"camera","model":"C200","ssid":"Umbrella-BIOsys2.4","mac":"B0957585DB3F","hwId":"84415C8E236887E785A849DF3CF77B02","fwId":"51092D48A2DB8C169A4C78E4D6102BC6","oemId":"8902D2F34FCE407721DE92F5759839C2","fwVer":"1.3.14 Build 240716 Rel.41863n(4555)","ip":"177.188.102.31","onboardingTime":1725010237,"role":0,"deviceType":"SMART.IPCAMERA","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com"}
                                      2024-12-05 16:57:48.121 - info: tapo.0 (168476) Init device 8021358BB4A527CB280AB30A8BDA3D671CDD26E7 type C200 with ip 177.188.102.31
                                      2024-12-05 16:57:49.345 - info: tapo.0 (168476) 8021358BB4A527CB280AB30A8BDA3D671CDD26E7 Received device info {"manufacturer":"tp-link","model":"Tapo C200","firmwareVersion":"1.3.14 Build 240716 Rel.41863n(4555)","serialNumber":"7585db3f","hardwareId":1}
                                      2024-12-05 16:57:49.346 - debug: tapo.0 (168476) {"manufacturer":"tp-link","model":"Tapo C200","firmwareVersion":"1.3.14 Build 240716 Rel.41863n(4555)","serialNumber":"7585db3f","hardwareId":1}
                                      2024-12-05 16:57:49.347 - debug: tapo.0 (168476) Init event emitter for 8021358BB4A527CB280AB30A8BDA3D671CDD26E7
                                      2024-12-05 16:57:49.355 - debug: tapo.0 (168476) Init event listener for "motion"
                                      2024-12-05 16:57:49.355 - info: tapo.0 (168476) Initialized 8021358BB4A527CB280AB30A8BDA3D671CDD26E7
                                      2024-12-05 16:57:49.355 - debug: tapo.0 (168476) initResult 8021358BB4A527CB280AB30A8BDA3D671CDD26E7 undefined
                                      2024-12-05 16:57:49.356 - debug: tapo.0 (168476) Found device 80229A326AB1C0A14703A582444F23E221F4115A Zirulations gebläse
                                      2024-12-05 16:57:49.780 - debug: tapo.0 (168476) {"hwVer":"1.20.0","category":"plug","model":"P100","ssid":"VW1icmVsbGEtQklPc3lzMi40","mac":"5C628B848BA9","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","oemId":"D7C5ADFD37188938BA82FD0FE208D1E7","fwVer":"1.5.5 Build 20230927 Rel. 40646","ip":"177.188.102.206","onboardingTime":1725280164,"role":0,"deviceType":"SMART.TAPOPLUG","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com"}
                                      2024-12-05 16:57:49.781 - info: tapo.0 (168476) Init device 80229A326AB1C0A14703A582444F23E221F4115A type P100 with ip 177.188.102.206
                                      2024-12-05 16:57:49.781 - debug: tapo.0 (168476) Constructing P100 on host: 177.188.102.206
                                      2024-12-05 16:57:49.871 - debug: tapo.0 (168476) Old Handshake P100 on host: 177.188.102.206
                                      2024-12-05 16:57:52.935 - error: tapo.0 (168476) connect EHOSTUNREACH 177.188.102.206:80
                                      2024-12-05 16:57:52.936 - debug: tapo.0 (168476) Detected KLAP device
                                      2024-12-05 16:57:52.936 - debug: tapo.0 (168476) Trying new handshake
                                      2024-12-05 16:57:56.008 - error: tapo.0 (168476) 276 Error: connect EHOSTUNREACH 177.188.102.206:80
                                      2024-12-05 16:57:56.008 - debug: tapo.0 (168476) New Handshake 1 failed
                                      2024-12-05 16:57:56.009 - error: tapo.0 (168476) undefined
                                      2024-12-05 16:57:56.010 - error: tapo.0 (168476) 52 - Get Device Info failed
                                      2024-12-05 16:57:56.010 - info: tapo.0 (168476) Initialized 80229A326AB1C0A14703A582444F23E221F4115A
                                      2024-12-05 16:57:56.011 - debug: tapo.0 (168476) initResult 80229A326AB1C0A14703A582444F23E221F4115A undefined
                                      2024-12-05 16:57:56.012 - debug: tapo.0 (168476) Found device 80216A1079A8ACEAAA069730BEB957071E902D8A Box Kamera
                                      2024-12-05 16:57:56.406 - debug: tapo.0 (168476) {"hwVer":"2.0","category":"camera","model":"C310","ssid":"Umbrella-BIOsys2.4","mac":"60A4B738F93E","hwId":"4F7FF895442ABA53E14CD582ED5BA10F","fwId":"E82C0BDFA47337D394F2ED1D7B7683DF","oemId":"8254843D1E8318CB5C2BC8BF94D189FA","fwVer":"1.3.11 Build 231116 Rel.69367n(4555)","ip":"177.188.102.39","onboardingTime":1727103410,"role":0,"deviceType":"SMART.IPCAMERA","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com"}
                                      2024-12-05 16:57:56.407 - info: tapo.0 (168476) Init device 80216A1079A8ACEAAA069730BEB957071E902D8A type C310 with ip 177.188.102.39
                                      2024-12-05 16:57:56.609 - info: tapo.0 (168476) 80216A1079A8ACEAAA069730BEB957071E902D8A Received device info {"manufacturer":"tp-link","model":"Tapo C310","firmwareVersion":"1.3.11 Build 231116 Rel.69367n(4555)","serialNumber":"b738f93e","hardwareId":2}
                                      2024-12-05 16:57:56.609 - debug: tapo.0 (168476) {"manufacturer":"tp-link","model":"Tapo C310","firmwareVersion":"1.3.11 Build 231116 Rel.69367n(4555)","serialNumber":"b738f93e","hardwareId":2}
                                      2024-12-05 16:57:56.610 - debug: tapo.0 (168476) Init event emitter for 80216A1079A8ACEAAA069730BEB957071E902D8A
                                      2024-12-05 16:57:56.617 - debug: tapo.0 (168476) Init event listener for "motion"
                                      2024-12-05 16:57:56.618 - info: tapo.0 (168476) Initialized 80216A1079A8ACEAAA069730BEB957071E902D8A
                                      2024-12-05 16:57:56.618 - debug: tapo.0 (168476) initResult 80216A1079A8ACEAAA069730BEB957071E902D8A undefined
                                      2024-12-05 16:57:56.619 - debug: tapo.0 (168476) Found device 8021CBA4909610A206E139C3FC03DE1822E48FC5 Tapo_C500_3
                                      2024-12-05 16:57:57.059 - debug: tapo.0 (168476) {"hwVer":"1.0","category":"camera","model":"C500 1.0","ssid":"Umbrella-BIOsys2.4","mac":"A86E844CA102","hwId":"C914043E1250C81FD816001F474FA63A","fwId":"ECD1920B486ED964132C0784183D1684","oemId":"0E1D0C2B5D536BC012D688DED78100AD","fwVer":"1.1.4 Build 240506 Rel.39487n","ip":"177.188.102.250","onboardingTime":1727105791,"role":0,"deviceType":"SMART.IPCAMERA","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com"}
                                      2024-12-05 16:57:57.060 - info: tapo.0 (168476) Init device 8021CBA4909610A206E139C3FC03DE1822E48FC5 type C500 1.0 with ip 177.188.102.250
                                      2024-12-05 16:58:00.131 - error: tapo.0 (168476) Error: connect EHOSTUNREACH 177.188.102.250:2020
                                      2024-12-05 16:58:00.132 - debug: tapo.0 (168476) initResult 8021CBA4909610A206E139C3FC03DE1822E48FC5 undefined
                                      2024-12-05 16:58:00.132 - debug: tapo.0 (168476) Found device 80223319522707959DE0F1272BFAC53B1DB5A17E Box LED
                                      2024-12-05 16:58:00.396 - debug: tapo.0 (168476) {"hwVer":"1.20.0","category":"plug","model":"P100","ssid":"VW1icmVsbGEtQklPc3lzMi40","mac":"E4C32A7ADE84","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","oemId":"D7C5ADFD37188938BA82FD0FE208D1E7","fwVer":"1.5.5 Build 20230927 Rel. 40646","ip":"177.188.102.192","onboardingTime":1725280012,"role":0,"deviceType":"SMART.TAPOPLUG","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com"}
                                      2024-12-05 16:58:00.397 - info: tapo.0 (168476) Init device 80223319522707959DE0F1272BFAC53B1DB5A17E type P100 with ip 177.188.102.192
                                      2024-12-05 16:58:00.398 - debug: tapo.0 (168476) Constructing P100 on host: 177.188.102.192
                                      2024-12-05 16:58:00.471 - debug: tapo.0 (168476) Old Handshake P100 on host: 177.188.102.192
                                      2024-12-05 16:58:03.525 - error: tapo.0 (168476) connect EHOSTUNREACH 177.188.102.192:80
                                      2024-12-05 16:58:03.525 - debug: tapo.0 (168476) Detected KLAP device
                                      2024-12-05 16:58:03.525 - debug: tapo.0 (168476) Trying new handshake
                                      2024-12-05 16:58:06.597 - error: tapo.0 (168476) 276 Error: connect EHOSTUNREACH 177.188.102.192:80
                                      2024-12-05 16:58:06.597 - debug: tapo.0 (168476) New Handshake 1 failed
                                      2024-12-05 16:58:06.598 - error: tapo.0 (168476) undefined
                                      2024-12-05 16:58:06.598 - error: tapo.0 (168476) 52 - Get Device Info failed
                                      2024-12-05 16:58:06.598 - info: tapo.0 (168476) Initialized 80223319522707959DE0F1272BFAC53B1DB5A17E
                                      2024-12-05 16:58:06.598 - debug: tapo.0 (168476) initResult 80223319522707959DE0F1272BFAC53B1DB5A17E undefined
                                      2024-12-05 16:58:06.599 - debug: tapo.0 (168476) Found device 80217FF0997E1DACDDDCBF13B6B966611EB22199  )�j �
                                      2024-12-05 16:58:06.907 - debug: tapo.0 (168476) {"hwVer":"2.0","category":"camera","model":"C310","ssid":"Umbrella-BIOsys2.4","mac":"60A4B7FD0F22","hwId":"4F7FF895442ABA53E14CD582ED5BA10F","fwId":"E82C0BDFA47337D394F2ED1D7B7683DF","oemId":"8254843D1E8318CB5C2BC8BF94D189FA","fwVer":"1.3.11 Build 231116 Rel.69367n(4555)","ip":"177.188.102.38","onboardingTime":1727093313,"role":0,"deviceType":"SMART.IPCAMERA","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com"}
                                      2024-12-05 16:58:06.908 - info: tapo.0 (168476) Init device 80217FF0997E1DACDDDCBF13B6B966611EB22199 type C310 with ip 177.188.102.38
                                      2024-12-05 16:58:07.189 - info: tapo.0 (168476) 80217FF0997E1DACDDDCBF13B6B966611EB22199 Received device info {"manufacturer":"tp-link","model":"Tapo C310","firmwareVersion":"1.3.11 Build 231116 Rel.69367n(4555)","serialNumber":"b7fd0f22","hardwareId":2}
                                      2024-12-05 16:58:07.190 - debug: tapo.0 (168476) {"manufacturer":"tp-link","model":"Tapo C310","firmwareVersion":"1.3.11 Build 231116 Rel.69367n(4555)","serialNumber":"b7fd0f22","hardwareId":2}
                                      2024-12-05 16:58:07.191 - debug: tapo.0 (168476) Init event emitter for 80217FF0997E1DACDDDCBF13B6B966611EB22199
                                      2024-12-05 16:58:07.197 - debug: tapo.0 (168476) Init event listener for "motion"
                                      2024-12-05 16:58:07.197 - info: tapo.0 (168476) Initialized 80217FF0997E1DACDDDCBF13B6B966611EB22199
                                      2024-12-05 16:58:07.197 - debug: tapo.0 (168476) initResult 80217FF0997E1DACDDDCBF13B6B966611EB22199 undefined
                                      2024-12-05 16:58:07.198 - debug: tapo.0 (168476) Found device 8021886637E6AFF404F8434554466A6B22E4035E Tapo_C500_1
                                      2024-12-05 16:58:07.617 - debug: tapo.0 (168476) {"hwVer":"1.0","category":"camera","model":"C500 1.0","ssid":"Umbrella-BIOsys2.4","mac":"A86E844CA10D","hwId":"C914043E1250C81FD816001F474FA63A","fwId":"ECD1920B486ED964132C0784183D1684","oemId":"0E1D0C2B5D536BC012D688DED78100AD","fwVer":"1.1.4 Build 240506 Rel.39487n","ip":"177.188.102.232","onboardingTime":1694177983,"role":0,"deviceType":"SMART.IPCAMERA","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com"}
                                      2024-12-05 16:58:07.618 - info: tapo.0 (168476) Init device 8021886637E6AFF404F8434554466A6B22E4035E type C500 1.0 with ip 177.188.102.232
                                      2024-12-05 16:58:10.691 - error: tapo.0 (168476) Error: connect EHOSTUNREACH 177.188.102.232:2020
                                      2024-12-05 16:58:10.692 - debug: tapo.0 (168476) initResult 8021886637E6AFF404F8434554466A6B22E4035E undefined
                                      2024-12-05 16:58:10.692 - debug: tapo.0 (168476) Found device 8021D0AE6DDA96751C98FB10EB6BB38522E3A62E Tapo_C500_2
                                      2024-12-05 16:58:10.893 - info: tr-064.0 (22743) forEachConfiguredDevice: in GetSpecificHostEntry 18(PC-IobrokerMaster-W/DC:A6:32:29:75:66) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                      2024-12-05 16:58:11.043 - debug: tapo.0 (168476) {"hwVer":"1.0","category":"camera","model":"C500 1.0","ssid":"Umbrella-BIOsys2.4","mac":"A86E8441688D","hwId":"C914043E1250C81FD816001F474FA63A","fwId":"ECD1920B486ED964132C0784183D1684","oemId":"0E1D0C2B5D536BC012D688DED78100AD","fwVer":"1.1.4 Build 240506 Rel.39487n","ip":"177.188.102.233","onboardingTime":1727105081,"role":0,"deviceType":"SMART.IPCAMERA","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com"}
                                      2024-12-05 16:58:11.045 - info: tapo.0 (168476) Init device 8021D0AE6DDA96751C98FB10EB6BB38522E3A62E type C500 1.0 with ip 177.188.102.233
                                      2024-12-05 16:58:14.115 - error: tapo.0 (168476) Error: connect EHOSTUNREACH 177.188.102.233:2020
                                      2024-12-05 16:58:14.115 - debug: tapo.0 (168476) initResult 8021D0AE6DDA96751C98FB10EB6BB38522E3A62E undefined
                                      2024-12-05 16:58:14.124 - info: tapo.0 (168476) Wait for connections for non camera devices
                                      2024-12-05 16:58:24.125 - info: tapo.0 (168476) Start first Update
                                      2024-12-05 16:58:24.127 - debug: tapo.0 (168476) Receive camera status
                                      2024-12-05 16:58:24.130 - debug: tapo.0 (168476) New API request
                                      2024-12-05 16:58:24.131 - debug: tapo.0 (168476) isSecureConnection: Checking secure connection...
                                      2024-12-05 16:58:24.801 - debug: tapo.0 (168476) isSecureConnection response
                                      2024-12-05 16:58:24.804 - debug: tapo.0 (168476) refreshStok: Refreshing stok...
                                      2024-12-05 16:58:24.919 - debug: tapo.0 (168476) refreshStok: Login response
                                      2024-12-05 16:58:24.920 - debug: tapo.0 (168476) Invalid device confirm, expected "sha256" or "md5" to match, but none found
                                      2024-12-05 16:58:24.921 - debug: tapo.0 (168476) refreshStock: Invalid device confirm, retrying: 0/3.
                                      2024-12-05 16:58:24.922 - debug: tapo.0 (168476) refreshStok: Refreshing stok...
                                      2024-12-05 16:58:24.998 - debug: tapo.0 (168476) refreshStok: Login response
                                      2024-12-05 16:58:24.999 - debug: tapo.0 (168476) Invalid device confirm, expected "sha256" or "md5" to match, but none found
                                      2024-12-05 16:58:25.000 - debug: tapo.0 (168476) refreshStock: Invalid device confirm, retrying: 1/3.
                                      2024-12-05 16:58:25.000 - debug: tapo.0 (168476) refreshStok: Refreshing stok...
                                      2024-12-05 16:58:25.070 - debug: tapo.0 (168476) refreshStok: Login response
                                      2024-12-05 16:58:25.071 - debug: tapo.0 (168476) Invalid device confirm, expected "sha256" or "md5" to match, but none found
                                      2024-12-05 16:58:25.071 - debug: tapo.0 (168476) refreshStock: Invalid device confirm, retrying: 2/3.
                                      2024-12-05 16:58:25.072 - debug: tapo.0 (168476) refreshStok: Refreshing stok...
                                      2024-12-05 16:58:25.140 - debug: tapo.0 (168476) refreshStok: Login response
                                      2024-12-05 16:58:25.141 - debug: tapo.0 (168476) Invalid device confirm, expected "sha256" or "md5" to match, but none found
                                      2024-12-05 16:58:25.142 - debug: tapo.0 (168476) refreshStock: Invalid device confirm and loginRetryCount exhausted, raising exception
                                      2024-12-05 16:58:25.142 - error: tapo.0 (168476) Invalid device confirm. Firmware Fix by TP-Link expected in Dezember 2024. Only motion detection is supported.
                                      2024-12-05 16:58:25.143 - error: tapo.0 (168476) Or follow https://github.com/JurajNyiri/HomeAssistant-Tapo-Control/blob/main/add_camera_with_new_firmware.md
                                      2024-12-05 16:58:25.143 - error: tapo.0 (168476) STOK not found
                                      2024-12-05 16:58:25.209 - debug: tapo.0 (168476) API response
                                      2024-12-05 16:58:25.210 - debug: tapo.0 (168476) API request failed
                                      2024-12-05 16:58:25.210 - error: tapo.0 (168476) No response data found
                                      2024-12-05 16:58:25.210 - debug: tapo.0 (168476) {}
                                      2024-12-05 16:58:25.211 - error: tapo.0 (168476) No stok found for: 8021358BB4A527CB280AB30A8BDA3D671CDD26E7 Ingore device until next restart
                                      2024-12-05 16:58:25.211 - debug: tapo.0 (168476) Receive camera status
                                      2024-12-05 16:58:25.212 - debug: tapo.0 (168476) New API request
                                      2024-12-05 16:58:25.212 - debug: tapo.0 (168476) isSecureConnection: Checking secure connection...
                                      2024-12-05 16:58:25.432 - debug: tapo.0 (168476) isSecureConnection response
                                      2024-12-05 16:58:25.433 - debug: tapo.0 (168476) refreshStok: Refreshing stok...
                                      2024-12-05 16:58:25.460 - debug: tapo.0 (168476) refreshStok: Login response
                                      2024-12-05 16:58:25.461 - debug: tapo.0 (168476) Invalid device confirm, expected "sha256" or "md5" to match, but none found
                                      2024-12-05 16:58:25.461 - debug: tapo.0 (168476) refreshStock: Invalid device confirm, retrying: 0/3.
                                      2024-12-05 16:58:25.461 - debug: tapo.0 (168476) refreshStok: Refreshing stok...
                                      2024-12-05 16:58:25.491 - debug: tapo.0 (168476) refreshStok: Login response
                                      2024-12-05 16:58:25.492 - debug: tapo.0 (168476) Invalid device confirm, expected "sha256" or "md5" to match, but none found
                                      2024-12-05 16:58:25.492 - debug: tapo.0 (168476) refreshStock: Invalid device confirm, retrying: 1/3.
                                      2024-12-05 16:58:25.492 - debug: tapo.0 (168476) refreshStok: Refreshing stok...
                                      2024-12-05 16:58:25.527 - debug: tapo.0 (168476) refreshStok: Login response
                                      2024-12-05 16:58:25.527 - debug: tapo.0 (168476) Invalid device confirm, expected "sha256" or "md5" to match, but none found
                                      2024-12-05 16:58:25.528 - debug: tapo.0 (168476) refreshStock: Invalid device confirm, retrying: 2/3.
                                      2024-12-05 16:58:25.528 - debug: tapo.0 (168476) refreshStok: Refreshing stok...
                                      2024-12-05 16:58:25.555 - debug: tapo.0 (168476) refreshStok: Login response
                                      2024-12-05 16:58:25.556 - debug: tapo.0 (168476) Invalid device confirm, expected "sha256" or "md5" to match, but none found
                                      2024-12-05 16:58:25.556 - debug: tapo.0 (168476) refreshStock: Invalid device confirm and loginRetryCount exhausted, raising exception
                                      2024-12-05 16:58:25.556 - error: tapo.0 (168476) Invalid device confirm. Firmware Fix by TP-Link expected in Dezember 2024. Only motion detection is supported.
                                      2024-12-05 16:58:25.556 - error: tapo.0 (168476) Or follow https://github.com/JurajNyiri/HomeAssistant-Tapo-Control/blob/main/add_camera_with_new_firmware.md
                                      2024-12-05 16:58:25.557 - error: tapo.0 (168476) STOK not found
                                      2024-12-05 16:58:25.583 - debug: tapo.0 (168476) API response
                                      2024-12-05 16:58:25.583 - debug: tapo.0 (168476) API request failed
                                      2024-12-05 16:58:25.584 - error: tapo.0 (168476) No response data found
                                      2024-12-05 16:58:25.584 - debug: tapo.0 (168476) {}
                                      2024-12-05 16:58:25.584 - error: tapo.0 (168476) No stok found for: 80216A1079A8ACEAAA069730BEB957071E902D8A Ingore device until next restart
                                      2024-12-05 16:58:25.585 - debug: tapo.0 (168476) Receive camera status
                                      2024-12-05 16:58:25.585 - debug: tapo.0 (168476) New API request
                                      2024-12-05 16:58:25.585 - debug: tapo.0 (168476) isSecureConnection: Checking secure connection...
                                      2024-12-05 16:58:28.645 - warn: tapo.0 (168476) TypeError: fetch failed
                                      2024-12-05 16:58:34.175 - debug: tapo.0 (168476) Receive camera status
                                      2024-12-05 16:58:34.176 - debug: tapo.0 (168476) New API request
                                      2024-12-05 16:58:34.176 - debug: tapo.0 (168476) isSecureConnection: Checking secure connection...
                                      2024-12-05 16:58:37.253 - warn: tapo.0 (168476) TypeError: fetch failed
                                      2024-12-05 16:58:44.175 - debug: tapo.0 (168476) Receive camera status
                                      2024-12-05 16:58:44.176 - debug: tapo.0 (168476) New API request
                                      2024-12-05 16:58:44.177 - debug: tapo.0 (168476) isSecureConnection: Checking secure connection...
                                      2024-12-05 16:58:47.268 - warn: tapo.0 (168476) TypeError: fetch failed
                                      2024-12-05 16:58:54.176 - debug: tapo.0 (168476) Receive camera status
                                      2024-12-05 16:58:54.177 - debug: tapo.0 (168476) New API request
                                      2024-12-05 16:58:54.177 - debug: tapo.0 (168476) isSecureConnection: Checking secure connection...
                                      2024-12-05 16:58:57.252 - warn: tapo.0 (168476) TypeError: fetch failed
                                      2024-12-05 16:59:04.178 - debug: tapo.0 (168476) Receive camera status
                                      2024-12-05 16:59:04.178 - debug: tapo.0 (168476) New API request
                                      2024-12-05 16:59:04.179 - debug: tapo.0 (168476) isSecureConnection: Checking secure connection...
                                      2024-12-05 16:59:07.238 - warn: tapo.0 (168476) TypeError: fetch failed
                                      2024-12-05 16:59:14.179 - debug: tapo.0 (168476) Receive camera status
                                      2024-12-05 16:59:14.180 - debug: tapo.0 (168476) New API request
                                      2024-12-05 16:59:14.180 - debug: tapo.0 (168476) isSecureConnection: Checking secure connection...
                                      2024-12-05 16:59:17.253 - warn: tapo.0 (168476) TypeError: fetch failed
                                      2024-12-05 16:59:24.179 - debug: tapo.0 (168476) Receive camera status
                                      2024-12-05 16:59:24.180 - debug: tapo.0 (168476) New API request
                                      2024-12-05 16:59:24.181 - debug: tapo.0 (168476) isSecureConnection: Checking secure connection...
                                      2024-12-05 16:59:27.272 - warn: tapo.0 (168476) TypeError: fetch failed
                                      2024-12-05 16:59:34.180 - debug: tapo.0 (168476) Receive camera status
                                      2024-12-05 16:59:34.181 - debug: tapo.0 (168476) New API request
                                      2024-12-05 16:59:34.182 - debug: tapo.0 (168476) isSecureConnection: Checking secure connection...
                                      2024-12-05 16:59:37.252 - warn: tapo.0 (168476) TypeError: fetch failed
                                      2024-12-05 16:59:44.181 - debug: tapo.0 (168476) Receive camera status
                                      2024-12-05 16:59:44.182 - debug: tapo.0 (168476) New API request
                                      2024-12-05 16:59:44.183 - debug: tapo.0 (168476) isSecureConnection: Checking secure connection...
                                      2024-12-05 16:59:47.268 - warn: tapo.0 (168476) TypeError: fetch failed
                                      2024-12-05 16:59:54.182 - debug: tapo.0 (168476) Receive camera status
                                      2024-12-05 16:59:54.182 - debug: tapo.0 (168476) New API request
                                      2024-12-05 16:59:54.183 - debug: tapo.0 (168476) isSecureConnection: Checking secure connection...
                                      2024-12-05 16:59:57.251 - warn: tapo.0 (168476) TypeError: fetch failed
                                      2024-12-05 17:00:00.055 - info: host.iobroker instance system.adapter.ical.0 in version "1.15.0" started with pid 168689
                                      2024-12-05 17:00:02.952 - info: ical.0 (168689) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.0, js-controller: 7.0.3
                                      2024-12-05 17:00:04.078 - info: host.iobroker instance system.adapter.ical.1 in version "1.15.0" started with pid 168738
                                      2024-12-05 17:00:04.182 - debug: tapo.0 (168476) Receive camera status
                                      2024-12-05 17:00:04.183 - debug: tapo.0 (168476) New API request
                                      2024-12-05 17:00:04.184 - debug: tapo.0 (168476) isSecureConnection: Checking secure connection...
                                      2024-12-05 17:00:04.248 - info: ical.0 (168689) processing URL: Müll https://calendar.google.com/calendar/ical/s4ui58n39mbeq04597iktdkar8%40group.calendar.google.com/private-f698ad83a3b8024b21ec878526820fa0/basic.ics
                                      2024-12-05 17:00:07.057 - info: ical.1 (168738) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.0, js-controller: 7.0.3
                                      2024-12-05 17:00:07.267 - warn: tapo.0 (168476) TypeError: fetch failed
                                      2024-12-05 17:00:08.101 - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 168755
                                      2024-12-05 17:00:08.135 - info: ical.1 (168738) processing URL: calendar1 https://calendar.google.com/calendar/ical/q9imfepcvqifq4jod91r9527go%40group.calendar.google.com/private-a101f20a96a6b92b87f4e42d7c842c8b/basic.ics
                                      2024-12-05 17:00:09.808 - info: ical.0 (168689) Terminated (NO_ERROR): Without reason
                                      2024-12-05 17:00:10.352 - info: host.iobroker instance system.adapter.ical.0 having pid 168689 terminated with code 0 (NO_ERROR)
                                      2024-12-05 17:00:10.787 - info: dwd.0 (168755) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.0, js-controller: 7.0.3
                                      2024-12-05 17:00:12.127 - info: host.iobroker instance system.adapter.daswetter.1 in version "3.1.16" started with pid 168772
                                      2024-12-05 17:00:13.166 - info: dwd.0 (168755) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      2024-12-05 17:00:13.199 - info: ical.1 (168738) Terminated (NO_ERROR): Without reason
                                      2024-12-05 17:00:13.714 - info: host.iobroker instance system.adapter.dwd.0 having pid 168755 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      2024-12-05 17:00:13.780 - info: host.iobroker instance system.adapter.ical.1 having pid 168738 terminated with code 0 (NO_ERROR)
                                      2024-12-05 17:00:14.186 - debug: tapo.0 (168476) Receive camera status
                                      2024-12-05 17:00:14.187 - debug: tapo.0 (168476) New API request
                                      2024-12-05 17:00:14.187 - debug: tapo.0 (168476) isSecureConnection: Checking secure connection...
                                      2024-12-05 17:00:14.792 - info: daswetter.1 (168772) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.0, js-controller: 7.0.3
                                      2024-12-05 17:00:16.151 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.1.16" started with pid 168790
                                      2024-12-05 17:00:17.252 - warn: tapo.0 (168476) TypeError: fetch failed
                                      2024-12-05 17:00:19.525 - info: daswetter.0 (168790) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.0, js-controller: 7.0.3
                                      2024-12-05 17:00:24.187 - debug: tapo.0 (168476) Receive camera status
                                      2024-12-05 17:00:24.188 - debug: tapo.0 (168476) New API request
                                      2024-12-05 17:00:24.188 - debug: tapo.0 (168476) isSecureConnection: Checking secure connection...
                                      2024-12-05 17:00:33.945 - info: daswetter.1 (168772) still wrong data structure from server received! repaired...
                                      2024-12-05 17:00:34.189 - debug: tapo.0 (168476) Receive camera status
                                      2024-12-05 17:00:34.189 - debug: tapo.0 (168476) New API request
                                      2024-12-05 17:00:34.190 - debug: tapo.0 (168476) isSecureConnection: Checking secure connection...
                                      2024-12-05 17:00:37.252 - warn: tapo.0 (168476) TypeError: fetch failed
                                      2024-12-05 17:00:37.671 - info: daswetter.0 (168790) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                                      2024-12-05 17:00:38.190 - info: daswetter.0 (168790) cleaned everything up...
                                      2024-12-05 17:00:38.209 - info: host.iobroker instance system.adapter.daswetter.0 having pid 168790 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      2024-12-05 17:00:40.008 - info: daswetter.1 (168772) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                                      2024-12-05 17:00:40.525 - info: daswetter.1 (168772) cleaned everything up...
                                      2024-12-05 17:00:40.545 - info: host.iobroker instance system.adapter.daswetter.1 having pid 168772 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      2024-12-05 17:00:44.189 - debug: tapo.0 (168476) Receive camera status
                                      2024-12-05 17:00:44.190 - debug: tapo.0 (168476) New API request
                                      2024-12-05 17:00:44.190 - debug: tapo.0 (168476) isSecureConnection: Checking secure connection...
                                      2024-12-05 17:00:47.270 - warn: tapo.0 (168476) TypeError: fetch failed
                                      2024-12-05 17:00:54.190 - debug: tapo.0 (168476) Receive camera status
                                      2024-12-05 17:00:54.191 - debug: tapo.0 (168476) New API request
                                      2024-12-05 17:00:54.191 - debug: tapo.0 (168476) isSecureConnection: Checking secure connection...
                                      2024-12-05 17:00:57.252 - warn: tapo.0 (168476) TypeError: fetch failed
                                      • Mr. QiM Mr. Qi
                                        T
                                        T
                                        tombox
                                        #637
                                        @mr-qi bitte nochmal GitHub testen
                                        Mr. QiM 2 Antworten Letzte Antwort
                                        • T tombox
                                          Mr. QiM
                                          Mr. QiM
                                          Mr. Qi
                                          #638
                                          @tombox vielen dank für die schnelle reaktion! Ich habe mir die freiheit genommen heute morgen bei der ersten Tasse Kaffee die Git-v2 zu installieren.
                                          Ablauf der installation
                                          • Deinstallation des alten Adapters über Admin
                                          • Installation über Git-Link
                                          • Erstellen einer neuen Instans
                                          • Anmelden via Email und MFA
                                          beim ersten start lief es im Log genau so ab wie bei -v1 ich lass das jetzt erst mal laufen und ziehe später mal ein log raus und lade es hoch.
                                          84.1k
