  4. [gelöst] iobroker Backup auf andere SSD
17 Beiträge 2 Kommentatoren 1.3k Aufrufe 2 Beobachtet
  • D DGR
    @thomas-braun said in iobroker Backup auf andere SSD:
    sudo systemctl daemon-reload
    keine Änderung, gleicher Fehler
    @dgr
    Hast du die Partionen jetzt nochmal gemountet?
      @dgr
      DGR
      habe gerade rebbot gemacht. Dann backup:
      12:23:39.904INFOguiBackup gestartet ...
      12:23:39.964DEBUGmountdone
      12:23:41.002DEBUGiobrokerhost.raspi2 338 objects saved
      12:23:41.024DEBUGiobrokerhost.raspi2 237 states saved
      12:23:41.026DEBUGiobrokerhost.raspi2 Validating backup ...
      12:23:41.068DEBUGiobrokerhost.raspi2 "config.json" is valid
      12:23:41.071DEBUGiobrokerhost.raspi2 "objects.jsonl" exists
      12:23:41.073DEBUGiobrokerhost.raspi2 "states.jsonl" exists
      12:23:41.125DEBUGiobrokerhost.raspi2 JSONL lines are valid
      12:23:41.128DEBUGiobrokerhost.raspi2 The backup is valid!
      12:23:41.288DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2024_12_01-12_23_42_backupiobroker.tar.gz
      12:23:41.334DEBUGiobrokerThis backup can only be restored with js-controller version 7.0 or higher
      12:23:42.295DEBUGiobrokerdone
      12:23:43.225DEBUGhistoryDBcompress from historyDB started ...
      12:23:43.227DEBUGhistoryDBBackup created: /opt/iobroker/backups/historyDB_2024_12_01-12_23_45_backupiobroker.tar.gz
      12:23:43.268DEBUGhistoryDBdone
      12:23:44.128DEBUGjavascriptsCreated javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
      12:23:44.180DEBUGjavascriptsTry deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
      12:23:44.181DEBUGjavascriptsJavascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
      12:23:44.224DEBUGjavascriptsBackup created: /opt/iobroker/backups/javascripts_2024_12_01-12_23_46_backupiobroker.tar.gz
      12:23:44.226DEBUGjavascriptsdone
      12:23:45.114ERRORcifsError: EACCES: permission denied, open '/mnt/SSD2/iobroker-backup/historyDB_2024_12_01-12_23_45_backupiobroker.tar.gz'
      12:23:45.132DEBUGcifsCopy javascripts_2024_12_01-12_23_46_backupiobroker.tar.gz...
      12:23:45.133ERRORcifsError: EACCES: permission denied, open '/mnt/SSD2/iobroker-backup/javascripts_2024_12_01-12_23_46_backupiobroker.tar.gz'
      12:23:45.135DEBUGcifsdone
      12:23:45.698ERRORcleanBackup files not deleted from /opt/iobroker/backups because some errors.
      12:23:45.732DEBUGcleandone
      12:23:45.862DEBUGhistoryHTMLnew history html values created
      12:23:45.950DEBUGhistoryHTMLdone
      12:23:46.108DEBUGhistoryJSONnew history json values created
      12:23:46.195DEBUGhistoryJSONdone
      12:23:46.258DEBUGumountdone
      12:23:47.314DEBUGtelegramdone
      12:23:48.620DEBUGnotificationAdmin notification will be sent
      12:23:48.664DEBUGnotificationdone
      12:23:48.782INFOguiDas Backup wurde erfolgreich erstellt!
      • D DGR
        @dgr sagte in iobroker Backup auf andere SSD:
        Welche Rechte hat denn die Datei?
        ls -l /mnt/SSD2/iobroker-backup/historyDB_2024_12_01-12_23_45_backupiobroker.tar.gz
        • D DGR
          @dgr
          Näheres findet sich ausführlich im ubuntu-wiki:
          https://wiki.ubuntuusers.de/mount/
            DGR
            Die Datei gibt es nicht, war ja bei Erstellung Zugriff verweigert
            • D DGR
              @dgr
              Funktioniert das manuelle mounten?
              ls -l /mnt/SSD2
              umount /mnt/SSD2
              mount /mnt/SSD2
                @dgr
                ls -l /mnt/SSD2
                umount /mnt/SSD2
                mount /mnt/SSD2
                DGR
                pi@raspi2:~ $ ls -l /mnt/SSD2
                insgesamt 28
                drwxr-xr-x  2 root root  4096 28. Nov 19:11 iobroker-backup
                drwxr-xr-x  2 root root  4096  1. Dez 10:14 iobroker-history
                drwx------  2 root root 16384 23. Nov 08:51 lost+found
                drwxr-xr-x 11 root root  4096  1. Dez 03:31 raspi2
                pi@raspi2:~ $ umount /mnt/SSD2
                pi@raspi2:~ $ mount /mnt/SSD2
                pi@raspi2:~ $
                • D DGR
                  @dgr
                  Ich mounte eine SMB-Freigabe z. B. mit uid und gid Optionen:
                  //fritz.nas/FRITZ.NAS/Hitachi-HTS545012B9SA00-01/iobbackups/chet /opt/iobroker/backups cifs credentials=/home/iobroker/.smbcredentials,users,noserverino,noauto,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0770,dir_mode=0770,vers=3.1.1 0 0
                  • D DGR
                    insgesamt 28
                    pi@raspi2:~ $
                    @dgr
                    Die Dateien dürfen nicht root gehören.
                    Jedenfalls nicht mit den Rechten.
                      @dgr
                      DGR
                      läuft jetzt:
                      12:44:53.640INFOguiBackup gestartet ...
                      12:44:53.650DEBUGmountdone
                      12:44:54.697DEBUGiobrokerhost.raspi2 338 objects saved
                      12:44:54.701DEBUGiobrokerhost.raspi2 237 states saved
                      12:44:54.703DEBUGiobrokerhost.raspi2 Validating backup ...
                      12:44:54.704DEBUGiobrokerhost.raspi2 "config.json" is valid
                      12:44:54.707DEBUGiobrokerhost.raspi2 "objects.jsonl" exists
                      12:44:54.803DEBUGiobrokerhost.raspi2 JSONL lines are valid
                      12:44:54.961DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2024_12_01-12_44_55_backupiobroker.tar.gz
                      12:44:55.005DEBUGiobrokerThis backup can only be restored with js-controller version 7.0 or higher
                      12:44:55.970DEBUGiobrokerdone
                      12:44:56.873DEBUGhistoryDBcompress from historyDB started ...
                      12:44:56.876DEBUGhistoryDBBackup created: /opt/iobroker/backups/historyDB_2024_12_01-12_44_58_backupiobroker.tar.gz
                      12:44:56.917DEBUGhistoryDBdone
                      12:44:57.776DEBUGjavascriptsCreated javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
                      12:44:57.825DEBUGjavascriptsTry deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
                      12:44:57.865DEBUGjavascriptsJavascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
                      12:44:57.867DEBUGjavascriptsdone
                      12:44:58.728DEBUGcifsused copy path: /mnt/SSD2/iobroker-backup
                      12:44:58.735DEBUGcifsCopy iobroker_2024_12_01-12_44_55_backupiobroker.tar.gz...
                      12:44:58.737DEBUGcifsCopy historyDB_2024_12_01-12_44_58_backupiobroker.tar.gz...
                      12:44:58.740DEBUGcifsCopy javascripts_2024_12_01-12_44_59_backupiobroker.tar.gz...
                      12:44:58.742DEBUGcifsdone
                      12:44:59.356DEBUGcleandone
                      12:44:59.493DEBUGhistoryHTMLnew history html values created
                      12:44:59.539DEBUGhistoryHTMLdone
                      12:44:59.695DEBUGhistoryJSONnew history json values created
                      12:44:59.737DEBUGhistoryJSONdone
                      12:44:59.844DEBUGumountdone
                      12:45:00.900DEBUGtelegramdone
                      12:45:02.203DEBUGnotificationdone
                      12:45:02.353INFOguiDas Backup wurde erfolgreich erstellt!
                      Änderung war :
                      sudo chmod a+rwx /mnt/SSD2/iobroker-backup
                      sudo chmod a+rwx /mnt/SSD2/iobroker-history
                      insgesamt 28
                      drwxrwxrwx  2 root root  4096  1. Dez 12:45 iobroker-backup
                      drwxrwxrwx  2 root root  4096  1. Dez 10:14 iobroker-history
                      Danke für die Hilfe.
                      • D DGR
                        läuft jetzt:
                        Änderung war :
                        insgesamt 28
                        @dgr
                        Freigabe für Hinz-und-Kunz und alle und jeden geht natürlich immer.
                        Ist aber ja nicht der Sinn von Rrechten und Rollen.
                        Aber wenn es so reicht...
                          @dgr
                          DGR
                          habe die Rechte nochmal geändert.
