  4. [gelöst] iobroker Backup auf andere SSD
17 Beiträge 2 Kommentatoren 1.3k Aufrufe 2 Beobachtet
  • D DGR
    PARTUUID=4cacc907-01 /mnt/SSD2 ext4 defaults,noatime,nofail 0 2
    Bei "NAS/Kopieren" habe ich "Lokal Kopieren" angegeben
    @dgr sagte in iobroker Backup auf andere SSD:
    Änder das mal auf
    PARTUUID=4cacc907-01 /mnt/SSD2 ext4 defaults,users,noatime,nofail 0 2
    Dann
    sudo systemctl daemon-reload
      Änder das mal auf
      Dann
      DGR
      @thomas-braun said in iobroker Backup auf andere SSD:
      keine Änderung, gleicher Fehler
      • D DGR
        @dgr
        Hast du die Partionen jetzt nochmal gemountet?
          @dgr
          DGR
          habe gerade rebbot gemacht. Dann backup:
          12:23:39.904INFOguiBackup gestartet ...
          12:23:39.964DEBUGmountdone
          12:23:41.002DEBUGiobrokerhost.raspi2 338 objects saved
          12:23:41.024DEBUGiobrokerhost.raspi2 237 states saved
          12:23:41.026DEBUGiobrokerhost.raspi2 Validating backup ...
          12:23:41.068DEBUGiobrokerhost.raspi2 "config.json" is valid
          12:23:41.071DEBUGiobrokerhost.raspi2 "objects.jsonl" exists
          12:23:41.073DEBUGiobrokerhost.raspi2 "states.jsonl" exists
          12:23:41.125DEBUGiobrokerhost.raspi2 JSONL lines are valid
          12:23:41.128DEBUGiobrokerhost.raspi2 The backup is valid!
          12:23:41.288DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2024_12_01-12_23_42_backupiobroker.tar.gz
          12:23:41.334DEBUGiobrokerThis backup can only be restored with js-controller version 7.0 or higher
          12:23:42.295DEBUGiobrokerdone
          12:23:43.225DEBUGhistoryDBcompress from historyDB started ...
          12:23:43.227DEBUGhistoryDBBackup created: /opt/iobroker/backups/historyDB_2024_12_01-12_23_45_backupiobroker.tar.gz
          12:23:43.268DEBUGhistoryDBdone
          12:23:44.128DEBUGjavascriptsCreated javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
          12:23:44.180DEBUGjavascriptsTry deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
          12:23:44.181DEBUGjavascriptsJavascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
          12:23:44.224DEBUGjavascriptsBackup created: /opt/iobroker/backups/javascripts_2024_12_01-12_23_46_backupiobroker.tar.gz
          12:23:44.226DEBUGjavascriptsdone
          12:23:45.114ERRORcifsError: EACCES: permission denied, open '/mnt/SSD2/iobroker-backup/historyDB_2024_12_01-12_23_45_backupiobroker.tar.gz'
          12:23:45.132DEBUGcifsCopy javascripts_2024_12_01-12_23_46_backupiobroker.tar.gz...
          12:23:45.133ERRORcifsError: EACCES: permission denied, open '/mnt/SSD2/iobroker-backup/javascripts_2024_12_01-12_23_46_backupiobroker.tar.gz'
          12:23:45.135DEBUGcifsdone
          12:23:45.698ERRORcleanBackup files not deleted from /opt/iobroker/backups because some errors.
          12:23:45.732DEBUGcleandone
          12:23:45.862DEBUGhistoryHTMLnew history html values created
          12:23:45.950DEBUGhistoryHTMLdone
          12:23:46.108DEBUGhistoryJSONnew history json values created
          12:23:46.195DEBUGhistoryJSONdone
          12:23:46.258DEBUGumountdone
          12:23:47.314DEBUGtelegramdone
          12:23:48.620DEBUGnotificationAdmin notification will be sent
          12:23:48.664DEBUGnotificationdone
          12:23:48.782INFOguiDas Backup wurde erfolgreich erstellt!
          • D DGR
            Welche Rechte hat denn die Datei?
            ls -l /mnt/SSD2/iobroker-backup/historyDB_2024_12_01-12_23_45_backupiobroker.tar.gz
            • D DGR
              @dgr
              Näheres findet sich ausführlich im ubuntu-wiki:
              https://wiki.ubuntuusers.de/mount/
                DGR
                Die Datei gibt es nicht, war ja bei Erstellung Zugriff verweigert
                • D DGR
                  @dgr
                  Funktioniert das manuelle mounten?
                  ls -l /mnt/SSD2
                  umount /mnt/SSD2
                  mount /mnt/SSD2
                    @dgr
                    ls -l /mnt/SSD2
                    umount /mnt/SSD2
                    mount /mnt/SSD2
                    DGR
                    pi@raspi2:~ $ ls -l /mnt/SSD2
                    insgesamt 28
                    drwxr-xr-x  2 root root  4096 28. Nov 19:11 iobroker-backup
                    drwxr-xr-x  2 root root  4096  1. Dez 10:14 iobroker-history
                    drwx------  2 root root 16384 23. Nov 08:51 lost+found
                    drwxr-xr-x 11 root root  4096  1. Dez 03:31 raspi2
                    pi@raspi2:~ $ umount /mnt/SSD2
                    pi@raspi2:~ $ mount /mnt/SSD2
                    pi@raspi2:~ $
                    • D DGR
                      @dgr
                      Ich mounte eine SMB-Freigabe z. B. mit uid und gid Optionen:
                      //fritz.nas/FRITZ.NAS/Hitachi-HTS545012B9SA00-01/iobbackups/chet /opt/iobroker/backups cifs credentials=/home/iobroker/.smbcredentials,users,noserverino,noauto,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0770,dir_mode=0770,vers=3.1.1 0 0
                      • D DGR
                        insgesamt 28
                        pi@raspi2:~ $
                        @dgr
                        Die Dateien dürfen nicht root gehören.
                        Jedenfalls nicht mit den Rechten.
                          @dgr
                          DGR
                          läuft jetzt:
                          12:44:53.640INFOguiBackup gestartet ...
                          12:44:53.650DEBUGmountdone
                          12:44:54.697DEBUGiobrokerhost.raspi2 338 objects saved
                          12:44:54.701DEBUGiobrokerhost.raspi2 237 states saved
                          12:44:54.703DEBUGiobrokerhost.raspi2 Validating backup ...
                          12:44:54.704DEBUGiobrokerhost.raspi2 "config.json" is valid
                          12:44:54.707DEBUGiobrokerhost.raspi2 "objects.jsonl" exists
                          12:44:54.803DEBUGiobrokerhost.raspi2 JSONL lines are valid
                          12:44:54.961DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2024_12_01-12_44_55_backupiobroker.tar.gz
                          12:44:55.005DEBUGiobrokerThis backup can only be restored with js-controller version 7.0 or higher
                          12:44:55.970DEBUGiobrokerdone
                          12:44:56.873DEBUGhistoryDBcompress from historyDB started ...
                          12:44:56.876DEBUGhistoryDBBackup created: /opt/iobroker/backups/historyDB_2024_12_01-12_44_58_backupiobroker.tar.gz
                          12:44:56.917DEBUGhistoryDBdone
                          12:44:57.776DEBUGjavascriptsCreated javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
                          12:44:57.825DEBUGjavascriptsTry deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
                          12:44:57.865DEBUGjavascriptsJavascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
                          12:44:57.867DEBUGjavascriptsdone
                          12:44:58.728DEBUGcifsused copy path: /mnt/SSD2/iobroker-backup
                          12:44:58.735DEBUGcifsCopy iobroker_2024_12_01-12_44_55_backupiobroker.tar.gz...
                          12:44:58.737DEBUGcifsCopy historyDB_2024_12_01-12_44_58_backupiobroker.tar.gz...
                          12:44:58.740DEBUGcifsCopy javascripts_2024_12_01-12_44_59_backupiobroker.tar.gz...
                          12:44:58.742DEBUGcifsdone
                          12:44:59.356DEBUGcleandone
                          12:44:59.493DEBUGhistoryHTMLnew history html values created
                          12:44:59.539DEBUGhistoryHTMLdone
                          12:44:59.695DEBUGhistoryJSONnew history json values created
                          12:44:59.737DEBUGhistoryJSONdone
                          12:44:59.844DEBUGumountdone
                          12:45:00.900DEBUGtelegramdone
                          12:45:02.203DEBUGnotificationdone
                          12:45:02.353INFOguiDas Backup wurde erfolgreich erstellt!
                          Änderung war :
                          sudo chmod a+rwx /mnt/SSD2/iobroker-backup
                          sudo chmod a+rwx /mnt/SSD2/iobroker-history
                          insgesamt 28
                          drwxrwxrwx  2 root root  4096  1. Dez 12:45 iobroker-backup
                          drwxrwxrwx  2 root root  4096  1. Dez 10:14 iobroker-history
                          Danke für die Hilfe.
                          • D DGR
                            läuft jetzt:
                            Änderung war :
                            insgesamt 28
                            @dgr
                            Freigabe für Hinz-und-Kunz und alle und jeden geht natürlich immer.
                            Ist aber ja nicht der Sinn von Rrechten und Rollen.
                            Aber wenn es so reicht...
                              @dgr
                              DGR
                              habe die Rechte nochmal geändert.
