  4. Probleme nach Wechsel des ZigBee Coordinators
21 Beiträge 6 Kommentatoren 2.9k Aufrufe 4 Beobachtet
  • K Kuddel
    @arteck
    Ikeda Fernbedienung mit 180 Sekunden Dauert
    Gesamtübersicht
    Log nach dem Instanz Start (Instanz Log Modus = Info)
    2024-11-29 09:38:42.051 - info: zigbee.0 (1805592) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.0, js-controller: 6.0.11
    2024-11-29 09:38:42.089 - info: zigbee.0 (1805592) Starting Zigbee npm ...
    2024-11-29 09:38:42.217 - info: zigbee.0 (1805592) Installed Version: iobroker.zigbee@1.10.3
    2024-11-29 09:38:43.674 - info: zigbee.0 (1805592) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20240710}}
    2024-11-29 09:38:43.683 - info: zigbee.0 (1805592) Unable to disable LED, unsupported function.
    2024-11-29 09:38:43.684 - info: zigbee.0 (1805592) --> transmitPower : high+
    2024-11-29 09:38:43.691 - info: zigbee.0 (1805592) Currently 12 devices are joined:
    2024-11-29 09:38:43.716 - info: zigbee.0 (1805592) 0x00158d0002b9584e (addr 18540): RTCGQ11LM - Aqara Motion sensor (EndDevice)
    2024-11-29 09:38:43.717 - info: zigbee.0 (1805592) 0x00158d0002579f57 (addr 57020): RTCGQ11LM - Aqara Motion sensor (EndDevice)
    2024-11-29 09:38:43.718 - info: zigbee.0 (1805592) -> Configuring 0xbc33acfffe1b51ca TRADFRI remote control
    2024-11-29 09:38:43.720 - info: zigbee.0 (1805592) 0xbc33acfffe1b51ca (addr 3856): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
    2024-11-29 09:38:43.720 - info: zigbee.0 (1805592) 0x0c4314fffe51eeaf (addr 9976): Not supported (model undefined)(Unknown)
    2024-11-29 09:38:43.721 - info: zigbee.0 (1805592) 0x7cb03eaa0a08a3e2 (addr 58171): AB3257001NJ - OSRAM Smart+ plug (Router)
    2024-11-29 09:38:43.721 - info: zigbee.0 (1805592) 0x00158d0008066b3a (addr 40765): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
    2024-11-29 09:38:43.723 - info: zigbee.0 (1805592) 0xa4c138bea13bbbed (addr 44898): A1Z - Nous Smart plug (with power monitoring) (Router)
    2024-11-29 09:38:43.723 - info: zigbee.0 (1805592) 0x00158d00047eb0e8 (addr 30354): RTCGQ11LM - Aqara Motion sensor (EndDevice)
    2024-11-29 09:38:43.723 - info: zigbee.0 (1805592) 0x00158d00083a666d (addr 32863): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
    2024-11-29 09:38:43.724 - info: zigbee.0 (1805592) 0x00158d0008482826 (addr 6573): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
    2024-11-29 09:38:43.724 - info: zigbee.0 (1805592) 0x00158d0008074456 (addr 34886): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
    2024-11-29 09:38:43.725 - info: zigbee.0 (1805592) 0x00158d00094d4c37 (addr 44684): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
    2024-11-29 09:38:43.725 - info: zigbee.0 (1805592) Zigbee started
    2024-11-29 09:38:43.729 - warn: zigbee.0 (1805592) download icon RC_Kinderzimmer for undefined Device not available. Check your devices.
    2024-11-29 09:38:43.763 - info: zigbee.0 (1805592) debug devices set to []
    2024-11-29 09:38:43.899 - error: zigbee.0 (1805592) Device 0x0c4314fffe51eeaf "undefined" not described in statesMapping.
    2024-11-29 09:38:53.752 - warn: zigbee.0 (1805592) DeviceConfigure: 0xbc33acfffe1b51ca TRADFRI remote control Failed to configure. When device works is all fine when not wake up the device and check again
    2024-11-29 09:39:17.901 - warn: zigbee.0 (1805592) DeviceAvailability:Failed to ping 0xa4c138bea13bbbed TS011F
    chucky666C Online
    chucky666C Online
    chucky666
    @kuddel
    Moin , ich kann dir aus erfahrung sagen , das es sehr lange dauert bis sich das Zigbee netzwerk optimal vernetzt
      Ich hab den Teil mal aus dem Marktplatz entfernt.
      Gat ja damit nichts mehr zu tun.
      @Kuddel bitte provisorischen Threadtitel anpassen!
      • chucky666C chucky666
        @kuddel
        Kuddel
        @chucky666 dann halte ich mal über das Wochenende die Füße still.
        Das Paaring der Ikea Fernbedienung geht leider immer nocht nicht :-(
        • K Kuddel
          @kuddel Danke für das Ändern des Threadtitels.
          Ich sehe da im Moment allerdings die Ursache (noch) nicht beim Koordinator.
            Kuddel
            @homoran ich weiß auch noch nicht in welche Richtung das Problem geht, da ja z.B. zwei Steckdosen erfolgreich verbunden sind.
            Ich muss denke ich mit den einzelnen Geräten weiter testen. Über x Minuten die Batterie rausnehmen etc.
            • K Kuddel
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              @kuddel sagte in Probleme mit dem cod.m ZigBee Coordinator:
              da es sich um batterie-betriebene Geräte handelt musst du abwarten bis sie als verbunden gezeigt werden. Auch ist die Karte da nicht relevant - die Frage ist ob du mit den Geräten etwas steuern kannst, sprich ob die Datenpunkte aktualisiert werden.
              A.
              • AsgothianA Asgothian
                A.
                Kuddel
                @asgothian Es sind alles nur Sensoren (Bewegungsmelder / Fensterkontakte) und zwei Fernbedienungen
                • K Kuddel
                  arteckA Offline
                  arteckA Offline
                  arteck
                  @kuddel ist das ne Osram oder Ledvance ??
                  • arteckA arteck
                    Kuddel
                    @arteck ja.
                    Ist deine Rückfrage jetzt ein gutes Zeichen ^^ ?
                    • K Kuddel
                      @arteck ja.
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      @arteck ja.
                      Nein. Deine Antwort aber auch nicht. Was ist denn nun ? Eine Osram Steckdose oder eine Ledvance Steckdose ?
                      A.
                      • K Kuddel
                        @arteck
                        Gesamtübersicht
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        @arteck
                        Gesamtübersicht
                        Du musst die Fernbedienung ggf. wach halten, damit das funktioniert.
                        Und dann weiter probieren.
                          @arteck ja.
                          A.
                          Kuddel
                          @asgothian ist eine Osram
                          -1
                          • K Kuddel
                            Kuddel
                            schrieb am zuletzt editiert von Kuddel
                            Ich habe eben noch einmal gestetet.
                            MIt dem LAN Gateway bekomme ich keine Zigbee Geräte verbunden.
                            Man sieht auch im Pairing-Vorgang keinerlei Einträge.
                            Wenn ich das Ganze mit den gleiche Geräten und einen USB Zigebbe Stick am ioBroker mache, funzt es.
                            Ich vermute, dass ich evtl. im Gateway etwas falsch eingestellt habe.
                            Vllt. kann @pmayer helfen.
                            • K Kuddel
                              Kuddel
                              So langsam geht es vorran.
                              Ich konnte jetzt doch die erste Ikea Fernbedienung anlernen :-)
                              pmayerP 1 Antwort Letzte Antwort
                              • K Kuddel
                                pmayerP Offline
                                pmayerP Offline
                                pmayer
                                @kuddel Geht es jetzt?
                                Ansonsten hier noch mal unserer Tutorial für ioBroker: https://docs.codm.de/zigbee/tutorials/setup-iobroker/
                                • pmayerP pmayer
                                  Kuddel
                                  @pmayer alles etwas träger, aber das liegt wohl einfach an Zigbee.
                                  Das Anlernen der Ikea Fernbedienungen hat geklappt.
                                  Mal sehen ob sich meine Fesntersensoren und Bewegungsmelder auch noch freiwillig melden.
                                  • K Kuddel
                                    pmayerP Offline
                                    pmayerP Offline
                                    pmayer
                                    @kuddel Die Ikea Fernbedienung (Taster) ist bei mir auch immer sehr zickig.
                                    Trotzdem sollte es zügig schalten.
                                    Kann aber natürlich sein, je nach Gegebenheiten, dass es ein einen Moment dauert, bis das Mesh sich sortiert hat.
