  3. Off Topic
  4. Pflege des Betriebssystems
  5. Raspberry hängt sich alle paar Tage auf
Geplant Angeheftet Gesperrt Verschoben Pflege des Betriebssystems
35 Beiträge 5 Kommentatoren 3.9k Aufrufe 3 Beobachtet
  • G gmt94
    ```bash
    Script v.2024-10-19
    *** BASE SYSTEM ***
     Static hostname: raspberrypi
           Icon name: computer
              Kernel: Linux 6.6.62+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     20:23:51 up 34 min,  2 users,  load average: 1.83, 13.07, 26.13
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Sat 2024-11-30 20:23:51 CET
               Universal time: Sat 2024-11-30 19:23:51 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    Henning
    HOME=/home/Henning
    GROUPS=Henning adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            4.0G        2.6G        1.0G        221K        374M        1.3G
    Swap:           536M        279M        257M
    Total:          4.5G        2.9G        1.3G
    Active iob-Instances:   38
             3791 M total memory
             2516 M used memory
             2131 M active memory
              529 M inactive memory
              991 M free memory
               47 M buffer memory
              310 M swap cache
              511 M total swap
              266 M used swap
              245 M free swap
    top - 20:23:52 up 34 min,  2 users,  load average: 1.83, 13.07, 26.13
    Tasks: 212 total,   4 running, 208 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 45.5 us, 18.2 sy,  0.0 ni, 27.3 id,  0.0 wa,  0.0 hi,  9.1 si,  0.0 st
    MiB Mem :   3791.9 total,    989.4 free,   2517.9 used,    357.8 buff/cache
    MiB Swap:    512.0 total,    245.8 free,    266.2 used.   1274.0 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     380M  1.2M  379M   1% /run
    /dev/mmcblk0p2 ext4      116G  9.6G  100G   9% /
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   55M  456M  11% /boot/firmware
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Sat Nov 30 19:49:48 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:3E:50:20 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=3b6acbc1-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sat Nov 30 19:49:50 2024] EXT4-fs (mmcblk0p2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
    [Sat Nov 30 19:49:51 2024] EXT4-fs (mmcblk0p2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.4G    /var/
    536M    /var/cache
    522M    /var/cache/apt
    407M    /var/cache/apt/archives
    205M    /var/lib
    Archived and active journals take up 152.0M in the file system.
    /opt/iobroker/backups:
    54M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.5G    /opt/iobroker/iobroker-data/
    1.2G    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    67M     /opt/iobroker/iobroker-data/states.jsonl
    34M     /opt/iobroker/iobroker-data/objects.jsonl
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    24M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
    20M     /opt/iobroker/iobroker-data/files/fullcalendar.admin/static/js/main.c13d3761.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_7636aa5207e7ed119292d6770b2af5ab-if00-port0
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/ttyUSB0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.1
    /usr/bin/node           v20.18.1
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    nodejs:
      Installed: 20.18.1-1nodesource1
      Candidate: 20.18.1-1nodesource1
      Version table:
     *** 20.18.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    raspberrypi         raspberrypi (version: 7.0.3, hostname: raspberrypi   , alive, uptime: 2041)
    Core adapters versions
    js-controller:  7.0.3
    admin:          7.4.1
    javascript:     8.8.3
    nodejs modules from github:     2
    +-- iobroker.icons-open-icon-library-png@0.1.3 (git+ssh://git@github.com/ioBroker/ioBroker.icons-open-icon-library-png.git#0847a79d713ee6725ccb6ccfb044c025b73ec946)
    | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
    Adapter State
    + system.adapter.backitup.1               : backitup              : raspberrypi                              -  enabled
      system.adapter.bambulab.0               : bambulab              : raspberrypi                              - disabled, port: 8883
    + system.adapter.energiefluss.0           : energiefluss          : raspberrypi                              -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              -  enabled
      system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
    + system.adapter.followthesun.0           : followthesun          : raspberrypi                              -  enabled
    + system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              -  enabled
    + system.adapter.fullcalendar.0           : fullcalendar          : raspberrypi                              -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
    + system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              -  enabled
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.ical.1                   : ical                  : raspberrypi                              -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              - disabled
      system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              - disabled
    + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
    + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
    + system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.mielecloudservice.0      : mielecloudservice     : raspberrypi                              -  enabled
    + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
    + system.adapter.moma.0                   : moma                  : raspberrypi                              -  enabled
      system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, port: 1883, bind: 0.0.0.0
      system.adapter.nina.0                   : nina                  : raspberrypi                              - disabled
      system.adapter.node-red.0               : node-red              : raspberrypi                              - disabled, port: 1880, bind: 0.0.0.0
      system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              -  enabled
    + system.adapter.operating-hours.0        : operating-hours       : raspberrypi                              -  enabled
      system.adapter.proxy.0                  : proxy                 : raspberrypi                              -  enabled
    + system.adapter.pvforecast.0             : pvforecast            : raspberrypi                              -  enabled
    + system.adapter.reolink.0                : reolink               : raspberrypi                              -  enabled
      system.adapter.rickshaw.0               : rickshaw              : raspberrypi                              - disabled
    + system.adapter.roborock.0               : roborock              : raspberrypi                              -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
      system.adapter.schoolfree.0             : schoolfree            : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              -  enabled
    + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 192.168.178.2, run as: admin
      system.adapter.sprinklecontrol.0        : sprinklecontrol       : raspberrypi                              - disabled
    + system.adapter.synology.0               : synology              : raspberrypi                              -  enabled, port: 5001
    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
      system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              - disabled
      system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
      system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : raspberrypi                              - disabled
      system.adapter.vis-map.0                : vis-map               : raspberrypi                              - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
      system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
    + system.adapter.webuntis.0               : webuntis              : raspberrypi                              -  enabled
      system.adapter.worx.0                   : worx                  : raspberrypi                              - disabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyUSB0
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name            │ url                                                  │ auto upgrade │
    │ 0       │ 'Beta (latest)' │ 'http://iobroker.live/repo/sources-dist-latest.json' │ false        │
    │ 1       │ 'stable'        │ 'http://download.iobroker.net/sources-dist.json'     │ true         │
    Active repo(s): stable
    Upgrade policy: minor
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.1.5    , installed 7.4.1
    Adapter    "backitup"     : 3.0.25   , installed 3.0.25
    Adapter    "energiefluss" : 3.6.1    , installed 3.6.1
    Adapter    "fb-checkpresence": 1.2.5 , installed 1.2.5
    Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
    Adapter    "followthesun" : 0.5.1    , installed 0.5.1
    Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
    Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
    Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "homeconnect"  : 1.4.1    , installed 1.4.1
    Adapter    "ical"         : 1.16.1   , installed 1.16.1
    Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.3    , installed 7.0.3
    Adapter    "mielecloudservice": 6.5.7, installed 6.5.7
    Adapter    "modbus"       : 6.3.2    , installed 6.4.0
    Adapter    "moma"         : 1.2.9    , installed 1.2.9
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "node-red"     : 5.2.1    , installed 5.2.1
    Adapter    "openweathermap": 1.1.2   , installed 1.1.2
    Adapter    "operating-hours": 1.1.0  , installed 1.1.0
    Adapter    "proxy"        : 1.3.2    , installed 1.3.2
    Adapter    "pvforecast"   : 3.0.0    , installed 3.0.0
    Adapter    "reolink"      : 1.1.2    , installed 1.1.2
    Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
    Adapter    "roborock"     : 0.6.17   , installed 0.6.17
    Adapter    "rpi2"         : 2.2.1    , installed 2.2.1
    Adapter    "schoolfree"   : 1.1.5    , installed 1.1.5
    Adapter    "shelly"       : 8.2.1    , installed 8.4.0
    Adapter    "shuttercontrol": 1.8.3   , installed 1.8.3
    Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
    Adapter    "synology"     : 3.1.0    , installed 3.1.0
    Adapter    "telegram"     : 3.9.0    , installed 3.9.0
    Adapter    "trashschedule": 3.3.0    , installed 3.4.0
    Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
    Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
    Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "webuntis"     : 0.3.4    , installed 0.3.4
    Adapter    "worx"         : 3.1.1    , installed 3.1.1
    Adapter    "zigbee"       : 1.10.3   , installed 1.10.13
    Objects and States
    Objects:        12531
    States:         9413
    W: https://packages.grafana.com/enterprise/deb/dists/stable/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
    Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://packages.grafana.com/enterprise/deb stable InRelease
    Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:7 https://repos.influxdata.com/debian stable InRelease
    Reading package lists...
    Pending Updates: 3
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5073       616/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       13608      2065/io.jarvis.0
    tcp        0      0 192.168.178.2:8701      0.0.0.0:*               LISTEN      1001       8817       1273/io.hm-rpc.1
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       9879       1596/io.shelly.1
    tcp        0      0 192.168.178.2:8087      0.0.0.0:*               LISTEN      1001       10236      2152/io.simple-api.
    tcp        0      0 192.168.178.2:42001     0.0.0.0:*               LISTEN      1001       8784       1210/io.hm-rpc.0
    tcp        0      0 192.168.178.2:42010     0.0.0.0:*               LISTEN      1001       9550       1295/io.hm-rpc.2
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       5696       723/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       5701       723/iobroker.js-con
    tcp6       0      0 :::6824                 :::*                    LISTEN      1001       14576      818/io.roborock.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          5075       616/sshd: /usr/sbin
    tcp6       0      0 :::7906                 :::*                    LISTEN      1001       14577      818/io.roborock.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       5955       903/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       11980      2194/io.web.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        6407       668/influxd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5259       473/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       13522      1589/io.shelly.0
    udp        0      0 0.0.0.0:53271           0.0.0.0:*                           104        5261       473/avahi-daemon: r
    udp6       0      0 :::59834                :::*                                104        5262       473/avahi-daemon: r
    udp6       0      0 fe80::6fb1:756e:fa2:546 :::*                                0          1952       557/NetworkManager
    udp6       0      0 :::5353                 :::*                                104        5260       473/avahi-daemon: r
    2024-11-30 20:24:37.367  - info: modbus.0 (1452) Disconnected from slave 192.168.178.20
    2024-11-30 20:24:39.370  - info: modbus.0 (1452) Connected to slave 192.168.178.20
    2024-11-30 20:24:40.384  - info: modbus.0 (1452) Disconnected from slave 192.168.178.20
    2024-11-30 20:24:42.392  - info: modbus.0 (1452) Connected to slave 192.168.178.20
    2024-11-30 20:24:43.411  - info: modbus.0 (1452) Disconnected from slave 192.168.178.20
    2024-11-30 20:24:45.414  - info: modbus.0 (1452) Connected to slave 192.168.178.20
    2024-11-30 20:24:46.419  - info: modbus.0 (1452) Disconnected from slave 192.168.178.20
    2024-11-30 20:24:48.422  - info: modbus.0 (1452) Connected to slave 192.168.178.20
    2024-11-30 20:24:49.430  - info: modbus.0 (1452) Disconnected from slave 192.168.178.20
    2024-11-30 20:24:51.434  - info: modbus.0 (1452) Connected to slave 192.168.178.20
    2024-11-30 20:24:52.441  - info: modbus.0 (1452) Disconnected from slave 192.168.178.20
    2024-11-30 20:24:54.444  - info: modbus.0 (1452) Connected to slave 192.168.178.20
    2024-11-30 20:24:55.450  - info: modbus.0 (1452) Disconnected from slave 192.168.178.20
    2024-11-30 20:24:57.451  - info: modbus.0 (1452) Connected to slave 192.168.178.20
    2024-11-30 20:24:58.456  - info: modbus.0 (1452) Disconnected from slave 192.168.178.20
    2024-11-30 20:25:00.460  - info: modbus.0 (1452) Connected to slave 192.168.178.20
    2024-11-30 20:25:01.465  - info: modbus.0 (1452) Disconnected from slave 192.168.178.20
    2024-11-30 20:25:03.468  - info: modbus.0 (1452) Connected to slave 192.168.178.20
    2024-11-30 20:25:04.479  - info: modbus.0 (1452) Disconnected from slave 192.168.178.20
    2024-11-30 20:25:06.481  - info: modbus.0 (1452) Connected to slave 192.168.178.20
    2024-11-30 20:25:07.486  - info: modbus.0 (1452) Disconnected from slave 192.168.178.20
    2024-11-30 20:25:09.488  - info: modbus.0 (1452) Connected to slave 192.168.178.20
    2024-11-30 20:25:10.492  - info: modbus.0 (1452) Disconnected from slave 192.168.178.20
    2024-11-30 20:25:12.495  - info: modbus.0 (1452) Connected to slave 192.168.178.20
    2024-11-30 20:25:13.502  - info: modbus.0 (1452) Disconnected from slave 192.168.178.20
    iob diag has finished.
    @gmt94 sagte in Raspberry hängt sich alle paar Tage auf:
    da siehst du, dass der pi wieder runterkommt.
    aber irgendwas hat ihn massiv beschäftigt.
    G 1 Antwort Letzte Antwort
      auf dem PI läuft sonst nur noch influx und Grafana.
      und 30 Instanzen bei 4 GB RAM!??
      gmt94
      Sorry ich bin nur Anwender....ich bin immer davon ausgegangen, dass so ein Pi das locker wegesteckt. :-)
      Also am besten auf den 5er upgraden?
        gmt94
        @homoran said in Raspberry hängt sich alle paar Tage auf:
        Ich hatte häufig das in letzter Zeit das ich beim Starten des WebAdapter diese Timeoutmeldung bekomme habe....Das war jedoch noch auf dem alten Buster System, mit dem Neuen kam das nur einmal vor.
        • G gmt94
          ```bash
          Script v.2024-10-19
          *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
          OS is similar to:
          Docker          : false
          Kernel          : aarch64
          Userland        : 64 bit
          CPU threads: 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          Henning
          HOME=/home/Henning
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal:       tty
          *** MEMORY ***
                   3791 M total memory
                   2516 M used memory
                    991 M free memory
                     47 M buffer memory
                    310 M swap cache
                    511 M total swap
                    266 M used swap
                    245 M free swap
          *** FILESYSTEM ***
          /var:
          1.4G    /var/
          536M    /var/cache
          522M    /var/cache/apt
          205M    /var/lib
          USB-Devices by-id:
          HINT:
          /dev/ttyUSB0
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.4.1
          javascript:     8.8.3
          Adapter State
          + instance is alive
          Objects and States
          Objects:        12531
          States:         9413
          Pending Updates: 3
          192.168.178.20
          was ist das?
          Dein modbus baut im Sekundentakt Die Verbindung dahin ab und wieder auf.
          Das ist nicht normal.
          da bei mir das beta repo auf standard war.
          auch der Modbus Adapter ist nicht stable.
          nicht der 4er ist das Problem, eher die nur 4GB RAM.
          zeig mal bitte die aktuelle Ausgabe von top
            192.168.178.20
            was ist das?
            gmt94
            192.168.178.20
            was ist das?
            Der Modbus-Adapter greift auf meinen Wechselrichter zu.
            hier die ausgabe:
            === Mark text until here for copying ===
            Henning@raspberrypi:~ $ top
            top - 20:37:50 up 48 min,  1 user,  load average: 2.58, 3.32, 12.16
            Tasks: 199 total,   2 running, 197 sleeping,   0 stopped,   0 zombie
            %Cpu(s): 23.3 us,  8.4 sy,  0.0 ni, 66.8 id,  0.2 wa,  0.0 hi,  1.3 si,  0.0 st
            MiB Mem :   3791.9 total,    557.3 free,   2585.2 used,    725.2 buff/cache
            MiB Swap:    512.0 total,    262.1 free,    249.9 used.   1206.7 avail Mem
                PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
                723 iobroker  20   0 9972764 434300  20096 S  35.7  11.2  16:46.68 iobroker.js-con
               6508 iobroker  20   0 9346900 128868  41472 S  35.1   3.3   6:32.14 io.fb-checkpres
               1589 iobroker  20   0 9229288 124072  19584 S   9.7   3.2   4:20.53 io.shelly.0
               2121 iobroker  20   0 9178600  64608  20224 S   5.8   1.7   1:20.57 io.reolink.0
               2072 iobroker  20   0 9211160  96820  19328 R   5.2   2.5   2:47.49 io.moma.0
               2194 iobroker  20   0 9480040  98104  19072 S   3.9   2.5   2:37.86 io.web.0
               7594 iobroker  20   0 9569032 242504  51968 S   3.9   6.2   2:00.68 io.javascript.0
                991 iobroker  20   0 9447496  62448  16512 S   2.6   1.6   1:48.92 io.influxdb.0
               2065 iobroker  20   0 9206908  80496  16384 S   1.9   2.1   2:15.02 io.jarvis.0
               1452 iobroker  20   0 9171480  53380  17152 S   1.3   1.4   0:20.35 io.modbus.0
             128852 Henning   20   0   11740   4864   2688 R   1.3   0.1   0:00.24 top
                 16 root      20   0       0      0      0 S   0.6   0.0   0:01.82 ksoftirqd/0
                 17 root      20   0       0      0      0 I   0.6   0.0   0:04.42 rcu_preempt
                668 influxdb  20   0 1628972  65220  18104 S   0.6   1.7   0:36.14 influxd
                807 iobroker  20   0 9474788  70804  21504 S   0.6   1.8   0:23.39 io.telegram.0
                903 iobroker  20   0 9567888 163308  19840 S   0.6   4.2   0:49.50 io.admin.0
               1409 iobroker  20   0   10.8g  77200  19968 S   0.6   2.0   0:38.11 io.synology.0
               1690 iobroker  20   0 9417128 104860  16512 S   0.6   2.7   0:19.44 io.zigbee.0
               1704 iobroker  20   0 9163860  43756  16000 S   0.6   1.1   0:09.81 io.energiefluss
              26428 Henning   20   0   19852   6300   4480 S   0.6   0.2   0:00.08 sshd
                  1 root      20   0  168516   7176   5056 S   0.0   0.2   0:02.94 systemd
                  2 root      20   0       0      0      0 S   0.0   0.0   0:00.05 kthreadd
                  3 root      20   0       0      0      0 S   0.0   0.0   0:00.00 pool_workqueue_release
                  4 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-rcu_g
                  5 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-rcu_p
                  6 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-slub_
                  7 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-netns
                 11 root      20   0       0      0      0 I   0.0   0.0   0:00.20 kworker/u8:0-ext4-rsv-conversion
                 12 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-mm_pe
                 13 root      20   0       0      0      0 I   0.0   0.0   0:00.00 rcu_tasks_kthread
                 14 root      20   0       0      0      0 I   0.0   0.0   0:00.00 rcu_tasks_rude_kthread
                 15 root      20   0       0      0      0 I   0.0   0.0   0:00.00 rcu_tasks_trace_kthread
                 18 root      rt   0       0      0      0 S   0.0   0.0   0:00.03 migration/0
                 19 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/0
                 20 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/1
                 21 root      rt   0       0      0      0 S   0.0   0.0   0:00.03 migration/1
                 22 root      20   0       0      0      0 S   0.0   0.0   0:01.09 ksoftirqd/1
                 25 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/2
                 26 root      rt   0       0      0      0 S   0.0   0.0   0:00.02 migration/2
                 27 root      20   0       0      0      0 S   0.0   0.0   0:01.11 ksoftirqd/2
                 30 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/3
                 31 root      rt   0       0      0      0 S   0.0   0.0   0:00.03 migration/3
                 32 root      20   0       0      0      0 S   0.0   0.0   0:01.10 ksoftirqd/3
                 36 root      20   0       0      0      0 I   0.0   0.0   0:00.08 kworker/u10:0-events_unbound
                 38 root      20   0       0      0      0 I   0.0   0.0   0:00.05 kworker/u12:0-events_unbound
                 39 root      20   0       0      0      0 S   0.0   0.0   0:00.00 kdevtmpfs
                 40 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-inet_
                 41 root      20   0       0      0      0 I   0.0   0.0   0:01.09 kworker/u9:1-events_unbound
            • G gmt94
              192.168.178.20
              was ist das?
              hier die ausgabe:
              Hat sich gefangen, aber auf reichlich hohem level.
              Du solltest hier ab und an mal reinsehen, noch besser die Vitaldaten visualisieren und loggen
              der controller und fb checkpresence sind im Moment die beschäftigsten
              Dir ist in der Zwischenzeit der RAM ausgegangen
                gmt94
                Unter welchem Reiter in den Objekten finde ich die ganzen Einträge zum loggen?
                • G gmt94
                  such mal als Experte unter system.host.
                  kann aber auch sein, dass ich einiges selber via blockly abrufe, müsste ich dann suchen.
                  Wichtig sind erst einmal CPU Daten und ggf. noch die Speicherdaten vom RAM
                    gmt94
                    Unter dem Adapter Moma habe ich das hier gefunden:
                    • G gmt94
                      Adapter Moma
                      kenne ich nicht
                      EDIT
                      Hab mal danach gesucht.
                      ist nur im Beta (gewesen??)
                      ist seit >3 Jahren nicht mehr gepflegt worden
                      So etwas kann auch dein System instabil machen, wenn es nicht auf die aktuellen Verhältnisse angepasst wurde.
                      G mcm1957M 2 Antworten Letzte Antwort
                      • G Offline
                        gmt94
                        Ui, hab ich gleich mal runter geworfen...
                        also den Expertenmodus hab ich anbekommen, jedoch finde ich kein system.host
                        • G gmt94
                          oder the long way
                            Adapter Moma
                            kenne ich nicht
                            EDIT
                            gmt94
                            Habs doch system.host gefunden und logge die daten mal mit.
                            Ich habe auch mal in den fb CheckPresence auf 20s Abfragezeit von einer Sekunde erhöht...Mein System läuft jetzt schon mal deutlich schneller. So schnell hat es schon lange nicht mehr reagiert.
                              oder the long way
                              gmt94
                              Hey, ich habe jetzt mal knapp 24h aufgenommen.
                              Eben hab ich mal testweise die Vis2 in Betrieb genommen und da ist er dann wieder ausgestiegen. Die Vis2 Instance ist jetzt wieder deaktiviert und ich bleibe erstmal bei meiner alten Vis.
                              Anbei die Verläufe der CPU sowie des Memory:
                              G HomoranH 2 Antworten Letzte Antwort
                              • G gmt94
                                gmt94
                                und hier nochmal der Verlauf der letzten beiden Stunden:
                                • G gmt94
                                  sowie des Memory:
                                  was ist das für eine Einheit?
                                  Prozent?
                                  Wenn ja wofür.
                                  Mem free, mem used, mem available?
                                  Dauerhaft 80+% used zeigt dass du zuwenig RAM hast
                                  Auch cpu load ist irgendwie unsinnig.
                                  Fie load average (1, 5, 15) sollte maximal 4 sein, optimal kleiner 1
                                    sowie des Memory:
                                    Prozent?
                                    Wenn ja wofür.
                                    gmt94
                                    so habe jetzt nochmal geschaut, was ich alles habe und die Einheiten angepasst.
                                    Die Load 1-15 Werte habe jetzt mal mitgeloggt.
                                    Aktuell stehen sie alle unter 1. Eben waren sie jedoch über 1-1,5.
                                    Also zwangsläufig dann demnächst auf einen Pi5 mit 8GB wechseln, oder gibt es auch welche mit 16GB?
                                    • G gmt94
                                      8GB ist der derzeitig größte.
                                      • G Offline
                                        gmt94
                                        und hier nochmal die Diagramme der letzten 3h:
                                          gmt94
                                          oder wird demnächst ein Nachfolgemodell kommen mit mehr Leistung und RAM?
